MUR820 – MUR860
Taiwan Semiconductor
8A, 200V - 600V Ultra Fast Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Glass passivated chip junction
High efficiency, Low VF
High current capability
High reliability
High surge current capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
8
A
VRRM
200 - 600
V
IFSM
100
A
TJ MAX
175
°C
Package
TO-220AC
Configuration
Single die
APPLICATIONS
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: TO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.80g (approximately)
TO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
MUR820
MUR840
MUR860
MUR820
MUR840
MUR860
UNIT
Repetitive peak reverse voltage
VRRM
200
400
600
V
Reverse voltage, total rms value
VR(RMS)
140
280
420
V
Forward current
Surge peak forward current 8.3ms single
half sine wave superimposed on rated load
Junction temperature
IF
8
A
IFSM
100
A
TJ
-55 to +175
°C
Storage temperature
TSTG
-55 to +175
°C
1
Version: K2103
MUR820 – MUR860
THERMAL PERFORMANCE
PARAMETER
Junction-to-case thermal resistance
MUR820
MUR840
MUR860
SYMBOL
TYP
UNIT
RӨJC
3
°C/W
RӨJC
2
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MUR820
Forward voltage
(1)
MUR840
IF = 8A, TJ = 25°C
VF
MUR860
Reverse current @ rated VR
TJ = 25°C
(2)
Reverse recovery time
IR
TJ = 100°C
MUR820
MUR840
MUR860
IF = 0.5A, IR = 1.0A
Irr = 0.25A
trr
TYP
MAX
UNIT
0.975
V
1.300
V
1.700
V
5
µA
250
µA
25
ns
50
ns
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MUR8x
TO-220AC
50 / Tube
MUR8xH
TO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 200V(MUR820) to 600V(MUR860)
2. “H” means AEC-Q101 qualified
2
Version: K2103
MUR820 – MUR860
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
8
CAPACITANCE (pF)
6
4
100
10
2
f=1.0MHz
Vsig=50mVp-p
1
25
50
75
100
125
150
175
0.1
1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=150°C
10
TJ=100°C
0.1
TJ=25°C
0.01
10
40
50
60
70
80
90
100
100 10
10
UF1DLW
MUR840
1
TJ=125°C
MUR820
TJ=25°C
0.1
1
MUR860
0.01
0.1
0.001
0.2
Pulse width 300μs
1% duty cycle
Pulse width
0.4 0.6 0.8
0.3
0.4
0.5
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1.0 1.2 1.4 1.6 1.8
0.6
0.7
0.8
0.9
2.0
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
120
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (uA)
Fig.4 Typical Forward Characteristics
1000
1
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
100
10
(A)
AVERAGE FORWARD CURRENT (A)
10
8.3ms single half sine wave
100
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: K2103
1.2
MUR820 – MUR860
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: K2103
MUR820 – MUR860
PACKAGE OUTLINE DIMENSIONS
TO-220AC
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: K2103
MUR820 – MUR860
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: K2103
很抱歉,暂时无法提供与“MUR860 C0G”相匹配的价格&库存,您可以联系我们找货
