HS3AB – HS3MB
4
Taiwan Semiconductor
3A, 50V - 1000V High Efficient Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Low forward voltage drop
Low profile package
Fast switching for high efficiency
Ideal for automated placement
Glass passivated chip junction
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
50 - 1000
V
IFSM
100
A
TJ MAX
150
°C
Package
DO-214AA (SMB)
Configuration
Single die
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Monitor
TV
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.093g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
HS
HS
HS
HS
HS
HS
HS
HS
3AB 3BB 3DB 3FB 3GB 3JB 3KB 3MB
HS
HS
HS
HS
HS
HS
HS
HS
3AB
3BB
3DB
3FB
3GB
3JB
3KB
3MB
UNIT
Repetitive peak reverse voltage
VRRM
50
100
200
300
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
35
70
140
210
280
420
560
700
V
Forward current
Surge peak forward current 8.3ms
single half sine-wave superimposed
on rated load
Junction temperature
IF
3
A
IFSM
100
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: L2102
HS3AB – HS3MB
4
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJA
60
°C/W
Junction-to-ambient thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
Junction capacitance
Reverse recovery time
HS3AB
HS3BB
HS3DB
HS3FB
I = 3A, TJ = 25°C
HS3GB F
HS3JB
HS3KB
HS3MB
TJ = 25°C
TJ = 100°C
HS3AB
HS3BB
HS3DB
HS3FB
1MHz, VR = 4.0V
HS3GB
HS3JB
HS3KB
HS3MB
HS3AB
HS3BB
HS3DB
HS3FB IF = 0.5A, IR = 1.0A,
HS3GB Irr = 0.25A
HS3JB
HS3KB
HS3MB
SYMBOL
VF
IR
TYP
MAX
UNIT
1.0
V
1.3
V
1.7
V
10
μA
250
μA
80
pF
50
pF
50
ns
75
ns
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
HS3xB
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1. "x" defines voltage from 50V(HS3AB) to 1000V(HS3MB)
2
Version: L2102
HS3AB – HS3MB
4
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
175
150
3
CAPACITANCE (pF)
2
1
125
100
HS3AB-HS3GB
75
50
HS3JB-HS3MB
25
50
75
100
125
0.1
150
1
10
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.4 Typical Forward Characteristics
100
TJ=125°C
10
TJ=25°C
1
60
1000
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
80
100
100 10
UF1DLW
1
HS3AB-HS3DB
TJ=125°C
10
TJ=25°C
0.1
(A)
AVERAGE FORWARD CURRENT (A)
4
HS3GB
0.01
1
Pulse width
0.001
0.1
0.3
0.4
0.4
0.6
0.5
0.8
0.6
1
0.7
HS3JB-HS3MB
0.8
0.9
1
1.2
1.4
1.6
1.1
1.8
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
3
Version: L2102
1.2
HS3AB – HS3MB
4
Fig.5 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
120
8.3ms single half sine wave
100
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: L2102
HS3AB – HS3MB
4
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: L2102
HS3AB – HS3MB
4
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: L2102
很抱歉,暂时无法提供与“HS3GB M4G”相匹配的价格&库存,您可以联系我们找货
