TSM110NB04LDCR
Taiwan Semiconductor
Dual N-Channel Power MOSFET
40V, 48A, 11mΩ
FEATURES
KEY PERFORMANCE PARAMETERS
● Low RDS(ON) to minimize conductive losses
PARAMETER
VALUE
UNIT
VDS
40
V
● Logic level
● Low gate charge for fast power switching
● 100% UIS and Rg tested
● RoHS Compliant
● Halogen-free according to IEC 61249-2-21
RDS(on) (max)
VGS = 10V
11
VGS = 4.5V
16
mΩ
Qg
12
nC
APPLICATIONS
● BLDC Motor Control
● Battery Power Management
● DC-DC Converter
● Secondary Synchronous Rectification
PDFN56 Dual
Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current
TC = 25°C
(Note 1)
Pulsed Drain Current
(Note 2)
Single Pulse Avalanche Current
(Note 2)
Single Pulse Avalanche Energy
Total Power Dissipation
LIMIT
UNIT
VDS
40
V
VGS
±20
V
ID
TA = 25°C
SYMBOL
TC = 25°C
TC = 125°C
TA = 25°C
TA = 125°C
Operating Junction and Storage Temperature Range
48
10
A
IDM
192
A
IAS
EAS
16
38
A
mJ
PD
PD
48
9.6
2
0.4
W
W
TJ, TSTG
- 55 to +150
°C
SYMBOL
MAXIMUM
UNIT
Junction to Case Thermal Resistance
RӨJC
2.6
°C/W
Junction to Ambient Thermal Resistance
RӨJA
61
°C/W
THERMAL PERFORMANCE
PARAMETER
Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. RӨJC is guaranteed by design while RӨCA is
2
determined by the user’s board design. The RӨJA limit presented here is based on mounting on a 1 in pad of 2 oz copper.
1
Version: A2001
TSM110NB04LDCR
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
Static
Drain-Source Breakdown Voltage
VGS = 0V, ID = 250µA
BVDSS
40
V
Gate Threshold Voltage
VGS = VDS, ID = 250µA
VGS(TH)
1
1.6
2.5
V
Gate-Source Leakage Current
VGS = ±20V, VDS = 0V
IGSS
±100
nA
1
100
8
11
11
16
gfs
34
Qg
23
Qg
12
Qgs
4
Qgd
6
Ciss
1269
Coss
142
Crss
82
Rg
0.7
2.2
4.4
td(on)
1
tr
td(off)
13
tf
13
VSD
1.2
V
VGS = 0V, VDS = 40V
Drain-Source Leakage Current
IDSS
VGS = 0V, VDS = 40V
TJ = 125°C
Drain-Source On-State Resistance
VGS = 10V, ID = 10A
(Note 3)
VGS = 4.5V, ID = 8A
Forward Transconductance
Dynamic
(Note 3)
RDS(on)
VDS = 10V, ID = 10A
µA
mΩ
S
(Note 4)
VGS = 10V, VDS = 20V,
Total Gate Charge
ID = 10A
Total Gate Charge
VGS = 4.5V, VDS = 20V,
Gate-Source Charge
ID = 8A
Gate-Drain Charge
Input Capacitance
VGS = 0V, VDS = 20V,
Output Capacitance
f = 1.0MHz
Reverse Transfer Capacitance
Gate Resistance
Switching
f = 1.0MHz
nC
pF
Ω
(Note 4)
Turn-On Delay Time
Turn-On Rise Time
Turn-Off Delay Time
ID = 10A, RG = 2Ω
Turn-Off Fall Time
ns
Source-Drain Diode
Forward Voltage
(Note 3)
VGS = 0V, IS = 10A
Reverse Recovery Time
IS = 10A ,
trr
15
ns
Reverse Recovery Charge
dI/dt = 100A/μs
Qrr
7
nC
Notes:
1.
2.
3.
4.
Silicon limited current only.
L = 0.3mH, VGS = 10V, VDD = 25V, RG = 25Ω, IAS = 16A, Starting TJ = 25°C
Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%.
Switching time is essentially independent of operating temperature.
ORDERING INFORMATION
ORDERING CODE
PACKAGE
PACKING
TSM110NB04LDCR RLG
PDFN56 Dual
2,500pcs / 13” Reel
2
Version: A2001
TSM110NB04LDCR
CHARACTERISTICS CURVES
Output Characteristics
Transfer Characteristics
30
30
ID, Drain Current (A)
18
VGS=10V
VGS=7V
VGS=5V
VGS=4.5V
VGS=4V
VGS=3.5V
24
12
VGS=3V
6
24
18
25℃
12
-55℃
6
150℃
2
3
4
On-Resistance vs. Drain Current
3
4
Gate-Source Voltage vs. Gate Charge
0.016
10
0.014
VGS=4.5V
0.012
0.01
0.008
VGS=10V
0.006
0.004
0.002
12
18
24
VDS=20V
ID=10A
8
6
4
2
2
VGS=10V
ID=10A
1.6
1.4
1.2
1
0.8
0.6
0.4
-75
-50
-25
50
75
15
100 125 150
On-Resistance vs. Gate-Source Voltage
RDS(on), Drain-Source On-Resistance (Ω)
On-Resistance vs. Junction Temperature
1.8
10
Qg, Gate Charge (nC)
(Normalized)
2
VGS, Gate to Source Voltage (V)
RDS(ON), Drain-Source On-Resistance (Ω)
VDS, Drain to Source Voltage (V)
TJ, Junction Temperature (°C)
0.04
0.035
0.03
0.025
0.02
0.015
ID=10A
0.01
0.005
4
5
6
7
8
9
10
3
Version: A2001
TSM110NB04LDCR
Capacitance vs. Drain-Source Voltage
BVDSS (Normalized)
1800
C, Capacitance (pF)
1600
1400
CISS
1200
1000
800
600
CRSS
400
COSS
200
ID=1mA
1.1
1
0.9
0.8
40
-75
Maximum Safe Operating Area, Junction-to-Case
-50
-25
50
75
100 125 150
Source-Drain Diode Forward Current vs. Voltage
100
IS, Reverse Drain Current (A)
1000
BVDSS vs. Junction Temperature
1.2
RDS(ON)
100
10
SINGLE PULSE
RӨJC=2.6°C/W
TC=25°C
1
10
25℃ -55℃
150℃
1
0.1
0.1
1
10
100
0.2
0.4
0.6
0.8
1
1.2
VSD, Body Diode Forward Voltage (V)
Normalized Thermal Transient Impedance, Junction-to-Case
Normalized Effective Transient
Thermal Impedance, ZӨJC
10
SINGLE PULSE
RӨJC=2.6°C/W
1
Duty=0.5
Duty=0.2
Duty=0.1
Duty=0.05
Duty=0.02
Duty=0.01
Single
0.1
0.01
0.0001
0.001
Notes:
Duty = t1 / t2
TJ = TC + PDM x ZӨJC x RӨJC
0.01
0.1
t, Square Wave Pulse Duration (sec)
4
Version: A2001
TSM110NB04LDCR
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
PDFN56 Dual
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
TSC
110NB04LD
YWWLF
Y
WW
L
F
= Year Code
= Week Code (01~52)
= Lot Code (1~9,A~Z)
= Factory Code
5
Version: A2001
TSM110NB04LDCR
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: A2001
