TSM9926D
Taiwan Semiconductor
Dual N-Channel Power MOSFET
20V, 6.0A, 30mΩ
FEATURES
KEY PERFORMANCE PARAMETERS
Advance Trench Process Technology
High Density Cell Design for Ultra Low On-
PARAMETER
VALUE
UNIT
VDS
V
resistance
RDS(on) (max)
VGS = 4.5V
30
VGS = 2.5V
40
mΩ
APPLICATION
Specially Designed for Li-on Battery Packs
Battery Switch Application
4.86
nC
en
de
d
Qg
mm
SOP-8
eco
Notes: Moisture sensitivity level: level 3. Per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
tR
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current
LIMIT
UNIT
VDS
V
VGS
±12
V
ID
6
A
IDM
30
A
IS
1.7
A
TC = 25°C
(Note 2)
No
Pulsed Drain Current
(Note 1)
SYMBOL
Continuous Source Current (Diode Conduction)
Total Power Dissipation
TA = 25°C
TA = 75°C
Operating Junction and Storage Temperature Range
PDTOT
1.6
1.1
W
TJ, TSTG
- 55 to +150
°C
SYMBOL
LIMIT
UNIT
Junction to Case Thermal Resistance
RӨJC
40
°C/W
Junction to Ambient Thermal Resistance
RӨJA
77
°C/W
THERMAL PERFORMANCE
PARAMETER
Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined
at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board
design. RӨJA shown below for single device operation on FR-4 PCB in still air.
Document Number: DS_P0000156
1
Version: B15
TSM9926D
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Static
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
(Note 3)
VGS = 0V, ID = 250µA
BVDSS
V
Gate Threshold Voltage
VDS = VGS, ID = 250µA
VGS(TH)
0.6
V
Gate Body Leakage
VGS = ±12V, VDS = 0V
IGSS
±100
nA
Zero Gate Voltage Drain Current
VDS = 20V, VGS = 0V
IDSS
1
µA
On-State Drain Current
VDS = 5V, VGS = 4.5V
ID(ON)
30
A
21
30
30
40
Forward Transconductance
VGS = 2.5V, ID = 5.2A
VDS = 10V, ID = 6A
(Note 4)
Total Gate Charge
VDS = 10V, ID = 6A,
Gate-Source Charge
VGS = 4.5V
Gate-Drain Charge
VDS = 8V, VGS = 0V,
Output Capacitance
Reverse Transfer Capacitance
Switching
F = 1.0MHz
(Note 5)
Turn-Off Delay Time
Turn-Off Fall Time
VDD = 10V,
RGEN = 6Ω,
ID = 1A, VGS = 4.5V,
Forward Voltage
Notes:
Qg
4.86
Qgs
0.92
Qgd
1.4
Ciss
562
Coss
106
S
nC
pF
75
td(on)
8.1
tr
9.95
td(off)
21.85
tf
5.35
VSD
0.7
1.2
ns
IS = 1.7A, VGS = 0V
V
Pulse width limited by the Maximum junction temperature.
No
1.
30
mΩ
(Note 3)
tR
Source-Drain Diode
Crss
e co
Turn-On Delay Time
Turn-On Rise Time
gfs
mm
Input Capacitance
RDS(ON)
en
Dynamic
VGS = 4.5V, ID = 6.0A
de
Drain-Source On-State Resistance
d
Drain-Source Breakdown Voltage
2.
Surface Mounted on FR4 Board, t ≤ 5 sec.
3.
Pulse test: PW ≤ 300µs, duty cycle ≤ 2%.
4.
For DESIGN AID ONLY, not subject to production testing.
5.
Switching time is essentially independent of operating temperature.
2
Version: B15
TSM9926D
ORDERING INFORMATION
PART NO.
TSM9926DCS RLG
PACKAGE
PACKING
SOP-8
2,500pcs / 13” Reel
No
tR
e co
mm
en
de
d
Note:
1. Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC
2. Halogen-free according to IEC 61249-2-21 definition
3
Version: B15
TSM9926D
CHARACTERISTICS CURVES
Transfer Characteristics
en
de
d
Output Characteristics
Gate Charge
No
tR
e co
mm
On-Resistance vs. Drain Current
On-Resistance vs. Junction Temperature
Source-Drain Diode Forward Voltage
4
Version: B15
TSM9926D
On-Resistance vs. Gate-Source Voltage
en
de
d
Threshold Voltage
tR
e co
mm
Single Pulse Power
No
Normalized Thermal Transient Impedance, Junction-to-Ambient
5
Version: B15
TSM9926D
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
tR
e co
mm
SUGGESTED PAD LAYOUT (Unit: Millimeters)
en
de
d
SOP-8
MARKING DIAGRAM
No
Y = Year Code
M = Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R =Apr
S =May T =Jun U =Jul
V =Aug
W =Sep X =Oct
Y =Nov Z =Dec
L = Lot Code (1~9, A~Z)
6
Version: B15
TSM9926D
No
tR
e co
mm
en
de
d
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: B15
很抱歉,暂时无法提供与“TSM9926DCS RLG”相匹配的价格&库存,您可以联系我们找货
