CSD10060G
CSD10060G
    WOLFSPEED
    TO-263(D²Pak)
    DIODE SCHOTTKY 600V 16.5A TO263
CSD10060G 数据手册
CSD10060–Silicon Carbide Schottky Diode VRRM = 600 V Zero Recovery® Rectifier IF(AVG) = 10 A Qc = 28 nC Features • • • • • • • Package 600-Volt Schottky Rectifier Zero Reverse Recovery Current Zero Forward Recovery Voltage High-Frequency Operation Temperature-Independent Switching Behavior Extremely Fast Switching Positive Temperature Coefficient on VF TO-263-2 TO-220-2 Benefits • • • • • Replace Bipolar with Unipolar Rectifiers Essentially No Switching Losses Higher Efficiency Reduction of Heat Sink Requirements Parallel Devices Without Thermal Runaway PIN 1 CASE PIN 2 Applications • • • Switch Mode Power Supplies Power Factor Correction - Typical PFC Pout : 1000W-2000W Motor Drives - Typical Power : 3HP-5HP Part Number Package Marking CSD10060A TO-220-2 CSD10060 CSD10060G TO-263-2 CSD10060 Maximum Ratings .S D10060, Rev Datasheet: CS Symbol Parameter Value Unit Test Conditions VRRM Repetitive Peak Reverse Voltage 600 V VRSM Surge Peak Reverse Voltage 600 V VDC DC Blocking Voltage 600 V IF(AVG) Average Forward Current 10 16.5 A TC=150˚C TC=125˚C IF(Peak) Peak Forward Current 23 A TC=125˚, TREP 1KHz 70% Duty 50% Duty 30% Duty 10 100 1000 VR Reverse Voltage (V) Case Temperature (°C) TC Case Temperature 10% Duty Figure 3. Current Derating Figure 4. Capacitance vs. Reverse Voltage 1.0E+01 Zth (°C/W) 1.0E+00 1.0E-01 1.0E-02 1.0E-03 1.E-07 1.E-06 1.E-05 1.E-04 1.E-03 Tim e (s) Figure 5. Transient Thermal Impedance 3 CSD10060 Rev. S 1.E-02 1.E-01 1.E+00 Typical Performance 140 140.000 Power Dissipation (W) 120.000 120 100 100.000 80 80.000 60 60.000 40 40.000 20 20.000 0 0.000 25 50 75 100 125 150 175 25 50 75 100 125 150 175 TC Case Temperature (°C) Figure 6. Power Derating 4 CSD10060 Rev. S Package Dimensions POS Package TO-220-2 A B A F J C P B D X S E Y 1 2 G T Z U H V L M W N PIN 1 CASE PIN 2 Millimeters Min Max Min Max .381 .410 9.677 10.414 DA .235 Inc hes .100 M in M ax .395.223 .410 .255 5.969 M illim eters .120 2.540 M in M ax .337 5.664 10.033 10.414 EB .235.590 .255 .615 5.969 FC D G E H F J G .102.143 .112 2.591 .153 .337 .337 8.560 1.105 1.147 .590 .610 14.986 .500 .550 .149 .153 3.785 R1.147 0.197 28.626 1.127 LH MJ L N M PN .530.025 .550 R 0.010 .045 .028 .036 .195 .045 .055 .195.165 .205 13.462 13.970 .036 .635 R 0.254 .055 1.143 .711 .914 .205 4.953 1.143 1.397 .185 4.191 4.953 5.207 QP .170.048 .180 .054 4.318 1.219 4.572 1.372 SQ S T T U U VV .048 3° .054 1.371 3° 5° 3° 5° 3° 5° 2.388 2.794 6° 3° 5° .100.094 .110 1.219 6° 3° 6° 3° 6° 3° .110 2.54 WW XX .014.014 .021 3° 3° 5° .356 .025 3° 5.5° .533 .356 5°3° C P OS Q Inches Y z Y Z 3° 3° 5° 3° 5° 3° .395 .410 .385 .130 .150 .130 10.033 .410 3.302 .150 14.986 6.477 6.477 3.048 8.560 15.621 2.845 3.632 3.886 8.560 28.067 29.134 15.494 12.700 13.970 3.886 29.134 R 0.197 10.414 9.779 3.810 3.302 .914 1.397 5.207 4.699 6° 6° 2.794 .635 5.5° 10.414 3.810 NOTE: 1. Dimension L, M, W apply for Solder Dip Finish Package Dimensions POS Package TO-263-2 Inches Max Min Max A .396 .406 10.058 10.312 B .297 .303 7.544 7.696 C .057 .063 1.448 1.600 D .237 .243 6.015 6.167 E* 0.00 .070 0.00 1.778 F .048 .062 1.219 1.575 G * PIN 1 PIN 2 CASE Millimeters Min .100 TYP 2.540 TYP H .335 .345 8.509 8.763 J .028 .034 .711 .864 K 2˚ 4˚ 2˚ 4˚ L .170 .180 4.318 4.572 M .048 .052 1.219 1.321 N .595 .615 15.113 15.621 P 0.00 0.10 0.00 .254 Q R0.018 TYP R0.022 TYP R0.457 TYP R0.559 TYP R .090 .110 2.286 2.794 S .013 .017 .330 .432 T 6.5˚ 8.5˚ 6.5˚ 8.5˚ U .103 .107 2.616 2.718 V R0.028 TYP R0.032 TYP R0.711 TYP R0.813 TYP W — 5.0˚ — 5.0˚ Note: * Tab “E” may not be present 5 CSD10060 Rev. S Recommended Solder Pad Layout TO-263-2 TO-220-2 Part Number Package Marking CSD10060A TO-220-2 CSD10060 CSD10060G TO-263-2 CSD10060 Diode Model Diode Model CSD10060 Vf T = VT + If*RT VT= 0.92 + (Tj * -1.35*10-3) RT= 0.052 + (Tj * 0.29*10-3) Note: Tj = Diode Junction Temperature In Degrees Celcius VT RT “The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2002/95/EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (RoHS), as amended through April 21, 2006. This part number was released previously with Sn/Pb solder plating as a standard industry finish. For more information please contact power_sales@cree.com “ This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, air traffic control systems, or weapons systems. Copyright © 2006-2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc. 6 CSD10060 Rev. S Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5451 www.cree.com/power
CSD10060G 价格&库存
很抱歉,暂时无法提供与“CSD10060G”相匹配的价格&库存,您可以联系我们找货
CSD10060G
