HEF4069UB
Hex inverter
Rev. 7 — 11 May 2011
Product data sheet
1. General description
The HEF4069UB is a general purpose hex inverter. Each inverter has a single stage.
It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS
(usually ground). Unused inputs must be connected to VDD, VSS, or another input.
It is also suitable for use over both the industrial (−40 °C to +85 °C) and automotive
(−40 °C to +125 °C) temperature ranges.
2. Features and benefits
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Operates across the automotive temperature range from −40 °C to +125 °C
Complies with JEDEC standard JESD 13-B
3. Applications
Automotive and industrial
Oscillator
4. Ordering information
Table 1.
All types operate from −40 °C to +125 °C.
Type number
Package
Name
Description
Version
HEF4069UBP
DIP14
plastic dual in-line package; 14 leads (300 mil)
SOT27-1
HEF4069UBT
SO14
plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
HEF4069UBTT
TSSOP14
plastic thin shrink small outline package; 14 leads; body width 4.4 mm
SOT402-1
HEF4069UB
NXP Semiconductors
Hex inverter
5. Functional diagram
1A
2A
3A
4A
5A
6A
1
2
3
4
5
6
9
8
11
10
13
12
1Y
2Y
3Y
4Y
VDD
5Y
A
6Y
VSS
001aag154
001aag152
Fig 1.
Y
Functional diagram
Fig 2.
Schematic diagram (one inverter)
6. Pinning information
6.1 Pinning
1A
1
14 VDD
1Y
2
13 6A
2A
3
12 6Y
2Y
4
HEF4069UB 11 5A
3A
5
10 5Y
3Y
6
9
4A
VSS
7
8
4Y
001aag153
Fig 3.
Pin configuration
6.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A to 6A
1, 3, 5, 9, 11, 13
input
1Y to 6Y
2, 4, 6, 8, 10, 12
output
VSS
7
ground (0 V)
VDD
14
supply voltage
HEF4069UB
Product data sheet
All information provided in this document is subject to legal disclaimers.
© NXP B.V. 2011. All rights reserved.
2 of 17
HEF4069UB
NXP Semiconductors
Hex inverter
7. Limiting values
Table 3.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDD
supply voltage
Conditions
Min
Max
−0.5
VI < −0.5 V or VI > VDD + 0.5 V
+18
V
±10
mA
IIK
input clamping current
VI
input voltage
IOK
output clamping current
II/O
input/output current
IDD
supply current
Tstg
storage temperature
−65
+150
°C
Tamb
ambient temperature
−40
+125
°C
Ptot
total power dissipation
P
power dissipation
Unit
−0.5
VO < −0.5 V or VO > VDD + 0.5 V
VDD + 0.5
V
±10
mA
±10
mA
50
mA
Tamb = −40 °C to +125 °C
DIP14
[1]
750
mW
SO14
[2]
500
mW
TSSOP14
[3]
500
mW
100
mW
per output
[1]
For DIP14 packages: above Tamb = 70 °C, Ptot derates linearly with 12 mW/K.
[2]
For SO14 packages: above Tamb = 70 °C, Ptot derates linearly with 8 mW/K.
[3]
For TSSOP14 packages: above Tamb = 60 °C, Ptot derates linearly with 5.5 mW/K.
8. Recommended operating conditions
Table 4.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDD
supply voltage
3
15
V
VI
input voltage
VDD
V
Tamb
ambient temperature
−40
+125
°C
HEF4069UB
Product data sheet
in free air
3 of 17
HEF4069UB
NXP Semiconductors
Hex inverter
9. Static characteristics
Table 5.
VSS = 0 V; VI = VSS or VDD; unless otherwise specified.
Symbol Parameter
Conditions
VDD
Tamb = −40 °C
Min
VIH
VIL
VOH
VOL
IOH
IOL
HIGH-level
input voltage
LOW-level
input voltage
|IO| < 1 μA
|IO| < 1 μA
HIGH-level
|IO| < 1 μA
output voltage
LOW-level
|IO| < 1 μA
output voltage
Max
Tamb = +25 °C
Min
Max
Tamb = +85 °C Tamb = +125 °C Unit
Min
Max
Min
Max
5V
4
4
4
4
V
10 V
8
8
8
8
V
15 V
12.5
12.5
12.5
12.5
V
5V
1
1
1
1
V
10 V
2
2
2
2
V
15 V
2.5
2.5
2.5
2.5
V
5V
4.95
4.95
4.95
4.95
V
10 V
9.95
9.95
9.95
9.95
V
15 V
14.95
14.95
14.95
14.95
V
5V
0.05
0.05
0.05
0.05
V
10 V
0.05
0.05
0.05
0.05
V
15 V
0.05
0.05
0.05
0.05
V
mA
HIGH-level
VO = 2.5 V
output current V = 4.6 V
O
5V
−1.7
−1.4
−1.1
−1.1
5V
−0.64
−0.5
−0.36
−0.36 mA
VO = 9.5 V
10 V
−1.6
−1.3
−0.9
−0.9
mA
VO = 13.5 V
15 V
−4.2
−3.4
−2.4
−2.4
mA
LOW-level
VO = 0.4 V
output current V = 0.5 V
O
5V
0.64
0.5
0.36
0.36
mA
10 V
1.6
1.3
0.9
0.9
mA
VO = 1.5 V
15 V
4.2
3.4
2.4
2.4
mA
μA
II
input leakage
current
15 V
±0.1
±0.1
±1.0
±1.0
IDD
5V
supply current all valid input
combinations; 10 V
IO = 0 A
15 V
0.25
0.25
7.5
7.5
μA
0.5
0.5
15.0
15.0
μA
1.0
1.0
30.0
30.0
μA
7.5
CI
input
capacitance
HEF4069UB
Product data sheet
digital inputs
pF
4 of 17
HEF4069UB
NXP Semiconductors
Hex inverter
10. Dynamic characteristics
Table 6.
Tamb = 25 °C; for waveforms see Figure 4; for test circuit see Figure 5.
Symbol Parameter
HIGH to LOW
propagation delay
tPHL
tPLH
tTHL
[1]
nA to nY;
LOW to HIGH
propagation delay
nA to nY
HIGH to LOW output
transition time
output nY
LOW to HIGH output
transition time
tTLH
Conditions
output nY
Extrapolation formula[1]
Min
Typ
Max
5V
18 ns + (0.55 ns/pF)CL
45
90
ns
10 V
9 ns + (0.23 ns/pF)CL
ns
15 V
7 ns + (0.16 ns/pF)CL
15
25
ns
5V
13 ns + (0.55 ns/pF)CL
40
80
ns
10 V
ns
15 V
15
30
ns
5V
10 ns + (1.00 ns/pF)CL
60
120
ns
10 V
9 ns + (0.42 ns/pF)CL
30
60
ns
15 V
6 ns + (0.28 ns/pF)CL
ns
VDD
Unit
5V
60
120
ns
10 V
30
60
ns
15 V
ns
The typical value of the propagation delay and output transition time can be calculated with the extrapolation formula (CL in pF).
Table 7.
Dynamic power dissipation
VSS = 0 V; tr = tf ≤ 20 ns; Tamb = 25 °C.
Symbol Parameter
PD
dynamic power dissipation
VDD
Typical formula
Where
5 V PD = 600 × fi + Σ(fo × CL) × VDD (μW)
2
10 V PD = 4000 × fi + Σ(fo × CL) × VDD2 (μW)
fi = input frequency in MHz;
fo = output frequency in MHz;
15 V PD = 22000 × fi + Σ(fo × CL) × VDD2 (μW) CL = output load capacitance in pF;
Σ(fo × CL) = sum of the outputs;
VDD = supply voltage in V.
HEF4069UB
Product data sheet
5 of 17
HEF4069UB
NXP Semiconductors
Hex inverter
11. Waveforms
tr
VI
90 %
VM
input
0V
tf
10 %
tPHL
VOH
tPLH
90 %
VM
output
10 %
VOL
tTLH
001aag185
tTHL
Measurement points: VM = 0.5VDD.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig 4.
Propagation delay and transition times
VDD
VI
VO
G
DUT
CL
RT
001aag182
Definitions for test circuit:
CL = load capacitance including jig and probe capacitance;
RT = termination resistance should be equal to the output impedance Zo of the pulse generator;
For test data refer to Table 8.
Fig 5.
Test circuit for measuring switching times
Table 8.
Test data
Supply voltage
Input
VDD
VI
tr, tf
CL
5 V to 15 V
VSS or VDD
≤ 20 ns
50 pF
HEF4069UB
Product data sheet
Load
6 of 17
HEF4069UB
NXP Semiconductors
Hex inverter
11.1 Transfer characteristics
001aag159
5.0
VO
(V)
(1)
5
(2)
(2)
ID
(mA)
5
250
(2)
2.5
10
VO
(V)
ID
(μA)
2.5
001aag160
10
500
(1)
(2)
VI (V)
10
VI (V)
a. VDD = 5 V; IO = 0 A
b. VDD = 10 V; IO = 0 A
001aag161
VO
(V)
ID
(mA)
10
10
(2)
(1)
(2)
VI (V)
c. VDD = 15 V; IO = 0 A
(1) VO = output voltage.
(2) ID = drain current.
Fig 6.
Typical transfer characteristics
HEF4069UB
Product data sheet
7 of 17
HEF4069UB
NXP Semiconductors
Hex inverter
12. Application information
Some examples of applications for the HEF4069UB.
Figure 7 shows an astable relaxation oscillator using two HEF4069UB inverters and 2
BAW62 diodes. The oscillation frequency is mainly determined by R1 × C1, provided
R1
很抱歉,暂时无法提供与“HEC4069UBT,112”相匹配的价格&库存,您可以联系我们找货
