Technical Data 4085
Effective March 2016
Supersedes December 2014
HCM0703
High current power inductors
Applications
Voltage Regulator Module (VRM)
Multi-phase regulators
Point-of-loadmodules
Desktop and server VRMs and EVRDs
Base station equipment
Laptop and notebook regulators
Battery power systems
Graphics cards
Data networking and storage systems
Environmental Data
Product features
High current carrying capacity
Low core losses
Magnetically shielded, low EMI
Frequency range up to 5 MHz
Inductance range from 0.15 μH to 33 μH
Current range from 1.8 A to 52 A
7.4 mm x 6.8 mm footprint surface mount
package in a 3.0 mm height
Iron powder core material
Storage temperature range (Component):
-55 °C to +125 °C
Operating temperature range: -55 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 compliant (Latest revision)
HALOGEN
Pb HF
FREE
HCM0703
Technical Data 4085
Product Specifications
Part Number6
OCL1
(μH) ±20%
FLL2 (μH)
minimum
Irms3
(A )
Isat4
(A )
DCR (mΩ)
typical @ +20 °C
DCR (mΩ)
maximum @ +20 °C
K-factor5
HCM0703-R15-R
0.15
0.09
26
52
1.9
2.5
1044
HCM0703-R22-R
0.22
0.13
23
40
2.5
2.8
986
HCM0703-R47-R
0.47
0.28
17.5
26
4.0
4.2
580
HCM0703-R68-R
0.68
0.41
15.5
25
5.0
5.5
455
HCM0703-R82-R
0.82
0.49
13
24
6.7
8.0
439
HCM0703- 1R0-R
1.0
0.60
11
22
9.0
10
374
HCM0703- 1R5-R
1.5
0.90
9.0
18
14
15
366
HCM0703- 2R2-R
2.2
1.3
8.0
14
18
HCM0703- 3R3-R
3.3
2.0
6.0
13.5
28
30
252
HCM0703- 4R7-R
4.7
2.8
5.5
10
37
40
210
HCM0703- 6R8-R
6.8
4.1
4.5
8.0
54
60
151
HCM0703- 8R2-R
8.2
4.9
4.0
7.5
64
68
142
HCM0703- 100-R
10
6.0
3.2
7.0
71
78
132
HCM0703- 150-R
14.9±15%
10.1
2.2
5.0
113
127
105
HCM0703- 220-R
22
14.1
2.3
3.0
135
149
83
HCM0703- 330-R
33
19.8
1.8
2.2
220
242
76
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25°C.
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.25 Vrms, Isat, @ +25 °C.
3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating
conditions verified in the end application.
4. Isat: Peak current for approximately 20% rolloff at +25 °C.
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p = K * L * ΔI. Bp-p: (Gauss), K: (K-factor from table), L:
(Inductance in μH), ΔI (Peak to peak ripple current in Amps).
6. Part Number Definition: HCM0703-xxx-R
HCM0703 = Product code and size
-xxx= Inductance value in μH, R = decimal point,
if no R is present then last character equals number of zeros.
“-R” suffix = RoHS compliant
Dimensions (mm)
Part marking: XXX=Inductance value in uH, R= decimal point. If no R is present then last character equals number of zeros.
wly=date code, R=revision level
All soldering surfaces to be coplanar within 0.10 millimeters
Tolerances are ±0.3 millimeters unless stated otherwise
Color: Grey
2
www.eaton.com/electronics
Technical Data 4085
HCM0703
Packaging information (mm)
Supplied in tape and reel packaging, 1500 parts per 13” diameter reel.
Temperature rise vs. total loss
50.0
Temperature Rise (°C)
40.0
30.0
20.0
10.0
0.0
0.0
0.2
0.4
0.6
0.8
1.0
1.2
Total Loss (W)
3
HCM0703
Technical Data 4085
Core loss vs. Bp-p
10000
1 MHz
500 kHz
300 kHz
1000
200 kHz
Core Loss (mW)
100 kHz
100
10
1
0.1
100
10000
1000
Bp-p (Gauss)
Inductance characteristics
110%
100%
100%
90%
90%
80%
70%
70%
60%
50%
50%
30
IDC (A)
40
50
60
70
HCM0703-R22-R
80%
60%
40%
4
% of OCL
% of OCL
HCM0703-R15-R
110%
40%
40
IDC (A)
50
60
70
Technical Data 4085
HCM0703
HCM0703-R47-R
110%
90%
90%
% of OCL
100%
% of OCL
100%
80%
70%
80%
70%
60%
60%
50%
50%
40%
10
15
30
HCM0703-R68-R
110%
35
40
45
50
40%
10
15
IDC (A)
% of OCL
% of OCL
40
45
90%
80%
70%
80%
70%
60%
60%
50%
50%
40%
10
15
30
35
40
45
10
HCM0703-1R5-R
110%
100%
90%
90%
% of OCL
100%
70%
50%
50%
10
15
IDC (A)
25
30
35
30
35
40
70%
60%
5
25
80%
60%
HCM0703-2R2-R
110%
80%
15
IDC (A)
IDC (A)
% of OCL
35
100%
90%
40%
30
HCM0703-1R0-R
110%
100%
40%
25
IDC (A)
HCM0703-R82-R
110%
40%
10
15
30
IDC (A)
5
HCM0703
Technical Data 4085
HCM0703-4R7-R
HCM0703-3R3-R
110%
110%
90%
90%
% of OCL
100%
% of OCL
100%
80%
70%
80%
70%
60%
60%
50%
50%
40%
4
6
8
10
12
14
16
18
40%
IDC (A)
4
6
HCM0703-6R8-R
90%
90%
% of OCL
100%
% of OCL
100%
80%
70%
50%
50%
8
IDC (A)
10
12
14
40%
HCM0703-100-R
110%
90%
% of OCL
90%
% of OCL
100%
80%
70%
50%
50%
4
6
8
IDC (A)
10
12
14
6
8
10
IDC (A)
12
14
HCM0703-150-R
70%
60%
2
18
80%
60%
110%
100%
40%
6
6
16
70%
60%
4
14
80%
60%
2
12
HCM0703-8R2-R
110%
IDC (A)
110%
40%
8
40%
2
3
4
5
IDC (A)
6
7
8
9
10
Technical Data 4085
HCM0703
HCM0703-220-R
HCM0703-330-R
100%
100%
90%
90%
% of OCL
110%
% of OCL
110%
80%
70%
80%
70%
60%
60%
50%
50%
40%
2
3
IDC (A)
4
5
6
40%
2
3
IDC (A)
4
5
6
7
Technical Data 4085
HCM0703
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HCM0703-R68-R”相匹配的价格&库存,您可以联系我们找货
