PZT2907A/ZLX
PZT2907A/ZLX
    NEXPERIA(安世)
    SOT-223
    SWITCHING TRANSISTOR
PZT2907A/ZLX 数据手册
Discrete semiconductors selection guide 2016 Bipolar transistors, diodes, ESD protection, TVS, filtering and signal conditioning, and MOSFETs Our extensive package range provides maximum flexibility 3 Pins 2 Pins Miniaturization DSN0402 DSN0603-2 DSN1006-2 DSN1006U-2 DFN1006D-2 DFN1006-2 SOD523 DFN1608D-2 (SOD992) (SOD962) (SOD993) (SOD995) (SOD882D) (SOD882) 0.4 x 0.2 x 0.12 0.6. x 0.3 x 0.3 1.0 x 0.6 x 0.3 1.0 x 0.6 x 0.3 1.0 x 0.6 x 0.37 1.0 x 0.6 x 0.48 DFN1006B-3 (SOT883B) 4/5 Pins 1.0 x 0.6 x 0.37 DFN1006-3 (SOT883) (SOT883) DFN1010D-3 (SOT1215)) (SOT1215 1.0 x 0.6 x 0.48 Medium Power >> 1.2 x 0.8 x 0.6 DSN1608-2 (SOD1608) (SOD963/SOD964) 1.6 x 0.8 x 0.37 1.6 x 0.8 x 0.25/0.29 SOT663 SOT66 3 SOT323 SOT23 3 1.6 x 1.2 x 0.55 2.0 x 1.25 x 0.95 5 2.9 x 1.3 x 1.0 1. SOD323F SOD323 SOD123F 1.7 x 1.25 x 0.7 1.7 x 1.25 x 0.95 2.6 x 1.6 x 1.1 DFN2020-3 (SOT1061) (SOT1061 1.1 x 1.0 x 0.37 2.0 x 2.0 x 0.62 WLCSP4* WLCSP5* SOT66 SOT665 SOT35 SOT353 SOT143 SOT143B 0.8 x 0.8 x 0.35 1.51 x 1.14 x 0.65 1.6 x 1.2 x 0.55 0.5 2.0 x 1.25 x 0.95 0.9 2.9 x 1.3 x 1.0 1. CFP3 CFP15 CFP5 D2PAK (SOD123W) (SOD128) (SOT1289) (SOT404) 2.6 x 1.7 x 1.0 3.8 x 2.6 x 1.0 5.8 x 4.3 x 0.78 11.0 x 10.0 x 4.3 DFN2020D-3 (SOT1061D) (SOT1061D SOT89 DPAK (SOT428) 4.5 x 2.5 x 1.5 2.0 x 2.0 x 0.62 6.6 x 6.1 x 2.3 LFPAK56 SOT223 SOT22 (SOT669) 6.5 x 3.5 x 1.65 1.6 DFN1010B-6 (SOT1216) ≥ 7 Pins 1.1 x 1.0 x 0.37 DFN1010-6 DFN1410-6 (SOT891)) (SOT891 (SOT886) 1.0 x 1.0 x 0.48 WLCSP6 SOT666 SOT66 6 SOT363 1.48 x 0.98 x 0.35 1.6 x 1.2 x 0.55 2.0 x 1.25 x 0.95 1.45 x 1.0 x 0.48 DFN2020-6 (SOT1118) 2.0 x 2.0 x 0.62 DFN2020D-6 (SOT1118D) 2.0 x 2.0 x 0.62 DFN2020MD-6 (SOT1220) SOT457 7 2.9 x 1.5 x 1.0 0 2.0 x 2.0 x 0.62 LFPAK56D DFN2110-9 DFN2111-7 DFN2510A-10 DFN2520-9 DFN2521-12 LFPAK33 DFN4020-14 DFN4040-32 DFN5050-32 (SOT1178)) (SOT1178 (SOT1358) (SOT1176) (SOT1333) (SOT1156-1) (SOT1210) (SOT1334 (SOT1334) (SOT1318-1) (SOT617-3) (SOT1205) 2.1 x 1.0 x 0.48 2.1 x 1.1 x 0.5 2.5 x 1.0 x 0.48 2.5 x 2.0 x 0.48 2.5 x 2.1 x 0.5 3.3 x 3.3 x 0.85 4.0 x 2.0 x 0.48 4.0 x 4.0 x 0.5 5.0 x 5.0 x 0.85 5.0 x 6.0 x 1.0 Your global partner for discretes * The exact position of the balls and package dimensions vary. 6 Pins 5.0 x 6.0 x 1.0 Bipolar transistors Page 7 Discretes semiconductors selection guide 2016 Diodes Page 29 ESD protection, TVS, filtering and signal conditioning Page 45 MOSFETs Page 75 Packages Page 130 www.nxp.com/discrete_selection_guide Table of Contents Bipolar transistors 7 High-power transistors 10 Low VCEsat (BISS) transistors 11 High-power transistors single High-current, high-power transistors High-power transistors double Low VCEsat transistors up to 2000 mW Low VCEsat (BISS) transistors single NPN Low VCEsat (BISS) transistors single PNP Low VCEsat (BISS) double transistors Low VCEsat transistors up to 750 mW Low VCEsat (BISS) transistors single NPN Low VCEsat (BISS) transistors single PNP Low VCEsat (BISS) load switches High-voltage low VCEsat (BISS) transistors Low VCEsat (BISS) RETs Low VCEsat (BISS) transistor PNP – N-channel MOSFET combination Advantages of low VCEsat (BISS) technology 10 10 10 11 11 12 13 14 14 15 16 18 18 19 19 Resistor-equipped transistors (RETs) 20 General purpose bipolar transistors 22 RETs RETs RETs RETs 100 100 100 500 mA single - Part 1 mA single - Part 2 mA double mA Single transistors NPN Single transistors PNP Double transistors Single and double switching transistors Medium-power general-purpose transistors High-voltage transistors LED driver Constant-current source Darlington transistors Schmitt triggers Low-noise transistors Matched-pair transistors MOSFET driver Medium-frequency transistors Diodes Schottky barrier diodes and rectifiers Medium-power low VF Schottky rectifiers single ≥1 A - Flatpower packages Medium-power low VF Schottky rectifiers single ≥100 mA - DSN packages Medium-power low VF Schottky rectifiers single ≥200 mA - leadless (DFN) packages Medium-power low VF Schottky rectifiers single ≥200 mA - leaded packages Medium-power low VF Schottky rectifiers dual ≥200 mA General-purpose Schottky diodes ≤250 mA Low-capacitance Schottky diodes 20 20 21 21 22 22 23 23 24 24 25 25 26 26 26 27 28 28 29 33 33 34 35 36 37 38 39 Zener diodes 40 Switching diodes 42 General-purpose Zener diodes Zener diodes specifications General-purpose, high-speed switching diodes < 90 V General-purpose, high-speed switching diodes 100 V General-purpose, switching diodes ≥100 V PN-rectifier Controlled-avalanche switching diodes Low-leakage current-switching diodes ESD protection, TVS, filtering and signal conditioning Ultra low-capacitance ESD protection devices Low-capacitance ESD protection devices Standard ESD protection devices Application-specific ESD and ESD/EMI solutions USB 2.0 protection and filtering Common Mode Filter for USB 2.0 USB 3.x and eSATA protection and filtering 40 41 42 42 43 43 44 44 45 49 53 57 59 59 59 60 Common Mode Filter for USB 3.x Common Mode Filter for video interfaces Ethernet protection HDMI and memory-card signal conditioning Video interface protection NFC antenna protection LCD/camera protection and filtering Audio interface protection and filtering Memory- and SIM-card protection and filtering Automotive high-speed network protection Automotive in-vehicle network bus line protection Transient voltage suppressor (TVS) diodes TVS TVS TVS TVS diodes for mobile applications diodes, 24 / 40 W diodes, 400 W diodes, 600 W MOSFETs Small-signal MOSFETs in ultra-small DFN1006 and DFN1006B packages Small-signal MOSFETs in DFN1010D-3 single and DFN1010B-3 dual package Small-signal MOSFETs in DFN2020MD-6 single and DFN2020-6 dual packages Small-signal MOSFETs in WLCSP4 and WLCSP6 packages Automotive-compliant small-signal MOSFETs Small-signal MOSFETs single (N-channel) Small-signal MOSFETs single (P-channel) Small-signal MOSFET – Schottky combination Small-signal MOSFETs dual Small-signal MOSFETs complementary Power MOSFETs Power MOSFETs Power MOSFETs Power MOSFETs Power MOSFETs Power MOSFETs Power MOSFETs P channel Multi-chip Power MOSFETs 70 70 70 71 72 75 Small-signal MOSFETs Power MOSFETs 61 62 62 63 64 65 66 67 67 68 68 20 - 25 V 30 V 40 V 55 - 60 V 75 - 80 V 100 V 105 - 150 V 200 V Automotive MOSFETs Automotive-compliant small-signal MOSFETS 30 V N-channel automotive TrenchMOS 40 V N-channel automotive TrenchMOS 55 - 60 V N-channel automotive TrenchMOS 75 - 80 V N-channel automotive TrenchMOS 100 V N-channel automotive TrenchMOS TrenchPLUS MOSFETs Packages 75 78 79 81 82 84 86 88 88 90 90 92 101 102 104 105 106 107 108 108 108 109 110 116 118 119 121 124 125 128 130 Package details and packing methods 132 Package cross reference 137 Product orientation (tape and reel pack) Packing methods 144 145 Minimized outline drawings and reflow soldering footprint Index 146 164 Package details and packing methods SMD Package details and packing methods WLCSP Packing details glass diodes, single ended and through hole packages Package cross reference list Package cross reference matrix Tape and reel pack for SMD and WLCSP packages 132 135 136 137 141 145 Our commitment: quality and reliability  We qualify our products according to the automotive AEC-Q101 standard and even exceed it’s requirements, for instance when doing extended lifetime testing.  All our processes and manufacturing plants are subject to regular international and internal audits, including the following:  ISO9001  ISO/TS 16949 for automotive sites  ISO14001  OHSAS18001 Bipolar transistors High-power transistors High-power transistors single High-current, high-power transistors High-power transistors double Low VCEsat (BISS) transistors  NXP’s Design for Excellence (DfX) program ensures that each new development builds on past learning and that best practices are always employed. The result is continual product improvement. Low VCEsat transistors up to 2000 mW Low VCEsat (BISS) transistors single NPN Low VCEsat (BISS) transistors single PNP Low VCEsat (BISS) double transistors Low VCEsat transistors up to 750 mW Low VCEsat (BISS) transistors single NPN Low VCEsat (BISS) transistors single PNP Low VCEsat (BISS) load switches High-voltage low VCEsat (BISS) transistors Low VCEsat (BISS) RETs Low VCEsat (BISS) transistor PNP – N-channel MOSFET combination Advantages of low VCEsat (BISS) technology Resistor-equipped transistors (RETs)  Zero defect is our goal. To ensure continuous improvement failure analysis and the determination to find root causes is performed at all stages of development and production by adoption of quality-analysis tools and methods (e.g. Six-Sigma, Safe-Launch). Rigorous attention to detail and commitment to quality have yielded a very low product failure rate of a single-digit part per billion (ppb). RETs RETs RETs RETs 100 100 100 500 mA single - Part 1 mA single - Part 2 mA double mA 10 10 10 10 11 11 11 12 13 14 14 15 16 18 18 19 19 20 20 20 21 21 General purpose bipolar transistors 22 Single transistors NPN Single transistors PNP Double transistors Single and double switching transistors Medium-power general-purpose transistors High-voltage transistors LED driver Constant-current source Darlington transistors Schmitt triggers Low-noise transistors Matched-pair transistors MOSFET driver Medium-frequency transistors 22 22 23 23 24 24 25 25 26 26 26 27 28 28 7 Medium-power Bipolar transistors in LFPAK56 What you get when you choose NXP for bipolar transistors A comprehensive portfolio for all applications Best in class performing transistors A quality product from an experienced, high volume supplier from general-purpose to low VCEsat transistors Applications  NXP is strongly committed to automotive quality standards  NXP has a track record of more than 60 years in developing and producing transistors  NXP is the #1 in small-signal discretes with a high production capacity A broad range of packages Many options for leaded SMD, medium-power clip-bond and ultra-small leadless packages. Low VCEsat (BISS) transistors LFPAK56 (SOT669) PBHVxxZ In standard SMD and new generation leadless and clip-bond packages PBHVxxV PBSSxxV PBSSxxPAP PBSSxxPAN PBSSxxV PBSSxxD PBSSxxY PBSSxxX 1A PBSSxxZ 10 A LFPAK: Same power dissipation but half the size 15 A IC 55% package size reduction while retaining the same power performance Ptot /package footprint [mW/mm2] 70 mm2 PBSSxxPA PBSSxxT PBSSxxU PBSSxxMB LFPAK56D (SOT1205) PHPTxx 50 mm2 30 mm2 SOT223 LFPAK56 / LFPAK56D In the spotlight 100 V PBHVxxT PMBTxx  Power management  Loadswitch  Linear-mode voltage regulator  Backlight units  Motor drive  LED lighting  Relay replacement  IGBT drive Single package 5 x 6 x 1.1 mm VCEO 600 V Bipolar transistors Bipolar transistors portfolio Bipolar transistors in LFPAK56 and LFPAK56D power packages Dual package 5 x 6 x 1.1 mm High thermal power dissipation up to 3.7 W, Vceo up to 100 V Most types AECQ-101 qualified (IC = 3 A up to 15 A) 2 types in LFPAK56D with current gain matching of 5% and 10% Reduced PCB area requirements compared to transistors in DPAK Suitable for high-temperature applications up to 175 °C Motor drive (2x PHPT60603NY/PY) or a double LFPAK56D (PHPT610030NK/PK) IVN – System Basis Chip (PHPT60603PY) External pass transistor, linear regulator 45 40 35 30 25 20 15 10 5 0 DPAK Reduced PCB area requirements comparison of DPAK, SOT223 and LFPAK 8 9 Low VCEsat transistors up to 2000 mW High-power transistors (single) Low VCEsat (BISS) transistors single NPN LFPAK56 (SOT669) SOT223 (SC-73) SOT89 (SC-62) SOT457 (SC-74) DFN2020-3 (SOT1061) DFN2020D-3 (SOT1061D) Size (mm) 6.5 x 3.5 x 1.65 4.5 x 2.5 x 1.5 2.9 x 1.5 x 1.0 2.0 x 2.0 x 0.62 2.0 x 2.0 x 0.62 Ptot (mW) 1700 1650 750 1300 1300 Package Package Size (mm) 5 x 6 x 1.1 VCEO (V) IC (A) 60 3 ICM (A) 8 3 100 2 6 IC (A) ICM (A) hFE min/typ @ IC (A) @ VCE (V) VCEsat typ (mV); IC = 0.5 A; IB = 0.05 A 5.3 10.6 300 / 530 0.5 2 18 5.8 11.6 300 / 530 0.5 2 18 PHPT61003NY 6 7 280 / 440 0.5 2 20 PNP PHPT61003PY 3 5 220 / 390 0.5 2 40 0.2 NPN PHPT61002NYC 4 15 300 / 450 0.5 2 30 0.2 PNP PHPT61002PYC 5 10 300 / 450 0.5 2 35 5.3 10.6 300 / 570 0.5 2 20 5.8 10.2 300 / 570 0.5 2 20 6 7 280 / 440 0.5 2 20 7 15 300 / 550 0.5 2 12 8 20 300 / 550 0.5 2 9 3 5 300 / 490 0.5 2 45 3 5 300 / 465 0.5 2 40 3.5 6 300 / 500 0.5 2 70 4.7 10 300 / 500 0.5 2 57 5.1 10.2 300 / 480 0.5 2 20 5.4 10 300 / 500 0.5 2 57 PBSS4032NZ 3) PBSS303NZ hFE min/typ @ IC (A) @ VCE (V) VCEsat typ (mV); IC = 0.5 A; IB = 0.05 A VCEsat max (mV) @ IC (A) @ IB (A) Polarity 200 / 400 0.5 2 50 270 3 0.3 NPN 200 / 400 0.5 2 70 360 3 0.3 PNP PHPT60603PY 150 / 250 0.5 10 50 330 3 0.3 NPN 150 / 220 0.5 10 70 360 2 0.2 150 / 250 0.5 10 50 300 2 150 / 220 0.5 10 70 400 2 VCEO (V) PHPT60603NY 12 20 High-current, high-power transistors LFPAK56 (SOT669) Package Size (mm) 5 x 6 x 1.1 30 VCEO (V) IC (A) hFE min/typ @ IC (A) @ VCE (V) Polarity 5.5 11 300 / 480 0.5 2 20 40 6 200/400 0.5 2 NPN PHPT60406NY 6 7 280 / 450 0.5 2 21 40 6 200/400 0.5 2 PNP PHPT60406PY 2.0 3.0 300 / – 0.5 5 140 40 10 200/400 0.5 2 NPN PHPT60410NY 15 300 / 520 0.5 2 35 40 10 200/400 0.5 2 PNP PHPT60410PY 40 15 200/400 0.5 2 NPN PHPT60415NY 10 300 / 500 0.5 2 21 40 15 200/400 0.5 2 PNP PHPT60415PY 5 10 300 / 500 0.5 2 25 60 6 200/400 0.5 2 NPN PHPT60606NY 2 5 300 / – 0.5 2 90 2) 60 6 150/250 0.5 2 PNP PHPT60606PY 200 / 280 0.5 2 65 60 10 200/400 0.5 2 NPN PHPT60610NY 300 / 460 0.5 2 50 200 / 280 0.5 2 60 1) 200 / 360 0.5 5 45 200 / – 0.5 5 45 60 10 150/250 0.5 2 PNP PHPT60610PY 100 6 150/250 0.5 10 NPN PHPT61006NY 100 6 150/220 0.5 10 PNP PHPT61006PY 100 10 150/250 0.5 10 NPN PHPT61010NY 100 10 150/220 0.5 10 PNP PHPT61010PY 40 50 60 High-power transistors (double) LFPAK56D (SOT1205) Package 80 Size (mm) VCEO (V) 100 5 x 6 x 1.1 IC (A) 3 ICM (A) 6 hFE typ 150 @ IC (A) 0.5 @ VCE (V) 10 VCEsat typ (mV); IC = 0.5 A; IB = 0.05 A VCEsat max (mV) @ IC (A) @ IB (A) Polarity 50 300 3 0.2 2XNPN - PHPT610030NK 400 3 0.2 2XPNP - PHPT610030PK 50 / 70 300 / 400 3 0.2 NPN/PNP - PHPT61003NPK 50 300 3 0.2 2XNPN 0.95 70 400 3 0.2 2XPNP 0.9 100 3.0 5.0 3 6 345 / 570 0.5 2 40 4.7 9.4 300 / 520 0.5 2 25 5.2 10.4 300 / 520 0.5 2 25 6 7 280 / 440 0.5 2 22 6.2 15 300 / 500 0.5 2 17 7 15 300 / 500 0.5 2 13 3 6 240 / 360 0.5 2 40 4 10 250 / 400 0.5 2 25 4.6 9.2 300 / 470 0.5 2 25 5.1 10.2 300 / 470 0.5 2 25 5.6 7 270 / 425 0.5 2 25 150 / 290 0.25 10 75 150 / 290 0.25 10 73 150 / 290 0.25 10 73 3 4 170 / 275 0.5 2 45 4.5 9 200 / 330 0.5 2 27 PHPT610035NK 5.1 10.2 200 / 330 0.5 2 27 PHPT610035PK 5.2 6 180 / 285 0.5 2 30 1) 10 4 hFE1/ hFE2 70 types in bold represent new products IC / IB = 20 2) VCEsat (max) 3) Bipolar transistors High-power transistors up to 3 W PBSS301NX PBSS301NZ PBSS4612PA PBSS4320X PBSS301ND PBSS4520X PBSS302NX PBSS302NZ PBSS4620PA PBSS4021NX PBSS4021NZ PBSS4330X PBSS4330PA PBSS4330PAS PBSS4032ND 3) PBSS4032NX 3) PBSS303NX PBSS4630PA PBSS4240X PBSS302ND PBSS4540X PBSS4540Z PBSS4250X PBSS4350D PBSS4350X PBSS4350Z PBSS4360PAS PBSS4360Z PBSS303ND PBSS304NX PBSS304NZ PBSS4560PA PBSS4041NX PBSS4041NZ PBSS304ND PBSS4480X PBSS305NX PBSS305NZ PBSS4580PA PBSS8110D PBSS8110X PBSS8110Z PBSS305ND PBSS306NX PBSS306NZ PBSS8510PA Optimized for high-speed switching 11 Low VCEsat transistors up to 2000 mW Low VCEsat (BISS) transistors single PNP SOT223 (SC-73) SOT89 (SC-62) SOT457 (SC-74) DFN2020-3 (SOT1061) DFN2020D-3 (SOT1061D) Size (mm) 6.5 x 3.5 x 1.65 4.5 x 2.5 x 1.5 2.9 x 1.5 x 1.0 2.0 x 2.0 x 0.62 2.0 x 2.0 x 0.62 Ptot (mW) 1700 1650 750 1300 1300 Package VCEO (V) 12 IC (A) ICM (A) hFE min/typ @ IC (A) @ VCE (V) VCEsat typ (mV); IC = 0.5 A; IB = 0.05 A 5.3 10.6 250 / 400 0.5 2 20 5.7 11.4 250 / 400 0.5 2 20 6 7 220 / 335 0.5 2 20 3 4 20 30 40 50 60 5 15 80 2) 2 50 250 / 400 0.5 2 35 0.5 2 45 PBSS5520X 0.5 2 25 PBSS302PX 5.5 11 250 / 370 0.5 2 25 6 7 230 / 345 0.5 2 25 6.2 15 250 / 400 0.5 2 18 6.6 20 250 / 400 0.5 2 16 2.7 5 200 / 350 0.5 2 87 200 / 380 0.5 2 50 200 / 320 0.5 2 45 4.2 10 200 / 350 0.5 2 70 4.4 10 200 / 350 0.5 2 70 5.1 10.2 250 / 400 0.5 2 25 5.3 10.6 250 / 400 0.5 2 25 6 7 200 / 335 0.5 2 25 2.0 3.0 215 / – 0.5 5 170 15 200 / 310 0.5 2 46 250 / 370 0.5 2 33 250 / 350 0.5 2 40 1) 0.5 2 90 2) 4 10 2.0 5 200 / – 200 / 300 0.5 2 70 3.0 5.0 200 / 375 0.5 2 70 200 / 300 0.5 2 70 130 / 220 0.5 5 55 3 6 130 / – 5 55 180 / 265 4.2 8.4 200 / 295 0.5 2 55 0.5 2 35 4.5 9 200 / 295 0.5 2 35 5 6 170 / 260 0.5 2 35 200 / 300 0.5 2 30 200 / 300 0.5 2 22 155 / 225 0.5 2 55 180 / 265 0.5 2 40 10 200 / 300 0.5 2 35 8 200 / 280 0.5 2 36 9 200 / 280 0.5 2 36 150 / 350 0.5 5 100 150 / 350 0.5 5 90 15 4.0 5 4.5 1.0 3.0 0.5 150 / – 0.5 5 90 2 3 175 / 275 0.5 2 65 2.7 4 180 / 295 0.5 2 45 3.7 7.4 200 / 300 0.5 2 45 4.1 8.2 200 / 300 0.5 5 45 IC / IB = 20 2) VCEsat (max) 3) Optimized for high-speed switching PBSS302PZ SOT457 (SC-74) SOT666 DFN2020-6 (SOT1118) DFN2020D-6 (SOT1118D) 4.9 x 3.9 x 1.75 2.9 x 1.5 x 1.0 1.6 x 1.2 x 0.55 2.0 x 2.0 x 0.62 2.0 x 2.0 x 0.62 750 500 1300 1300 hFE min/ typ @ IC (A) @ VCE (V) 2 x NPN 200 0.01 2 170 2 x PNP 200 0.01 2 NPN / PNP 200 0.01 NPN / PNP 200 0.01 7.5 NPN / NPN 300 6.3 PNP / PNP 250 2) VCEsat max (mV) @ IC (A) @ IB (A) 1) 250 0.5 0.05 PBSS2515VS 170 1) 250 0.5 0.05 PBSS3515VS 2 170 1) 250 0.5 0.05 PBSS2515VPN 2 170 1) 250 0.5 0.05 0.5 2 15 150 4 0.2 PBSS4021SN 0.5 2 24 225 4 0.2 PBSS4021SP NPN / PNP 300 / 250 0.5 2 15 / 24 150 / 225 4 0.2 PBSS4021SPN NPN / NPN 210 0.5 2 75 100 0.5 0.05 PNP / PNP 170 0.5 20 PBSS5620PA VCEsat typ (mV); IC = 0.5 A; IB = 0.05 A Polarity IC (A) 15 SOT96 (SO8) 2000 PBSS301PD 300 / 430 5 VCEO (V) PBSS5320D 250 / 370 3 Ptot (mW) PBSS5320X 10 3 12 2 0.5 Size (mm) PBSS5612PA 10.2 5 100 0.5 types in bold represent new products Package PBSS301PZ 5 5.7 80 200 / – 220 / 450 Low VCEsat (BISS) double transistors PBSS301PX 5.1 5 1) types in bold represent new products Bipolar transistors Low VCEsat transistors up to 2000 mW 7.5 / 6.3 PBSS4021PX PBSS4021PZ PBSS4032PD 1 3) 0.5 2 85 140 0.5 0.05 PBSS5130PAP NPN / PNP 210 / 170 0.5 2 75 / 85 100 / 140 0.5 0.05 PBSS4130PANP NPN / NPN 230 0.5 2 60 80 0.5 0.05 PBSS4230PAN PNP / PNP 210 0.5 2 75 110 0.5 0.05 PBSS5230PAP NPN / PNP 230 / 210 0.5 2 60 / 75 80 / 100 0.5 0.05 5.7 NPN / NPN 300 0.5 2 57 250 4 0.4 PBSS4032SN 3) 4.8 PNP / PNP 200 0.5 2 70 390 4 0.4 PBSS4032SP 3) PBSS4032SPN PBSS5330X PBSS5330PA PBSS5330PAS PBSS4032PX 3) 30 PBSS4032PZ 3) 2 PBSS303PX PBSS303PZ PBSS5630PA PBSS5240X PBSS302PD PBSS4130PAN PBSS4230PANP 5.7 / 4.8 NPN / PNP 300 / 200 0.5 2 57 / 70 250 / 390 4 0.4 1.0 NPN / PNP 300 / 250 0.5 5 130 / 150 500 1 0.1 PBSS4140DPN 2.0 NPN / PNP 300 / 250 0.5 5 80 / 100 400 / 530 2 0.2 PBSS4240DPN PBSS5540X 3) 40 PBSS5540Z PBSS5250X PBSS5350D PBSS5350X 50 2.7 PBSS5350Z 2 x NPN 300 0.5 2 50 340 2.7 0.27 PBSS4350SS 2 x PNP 200 0.5 2 60 370 2.7 0.27 PBSS5350SS PBSS4350SPN NPN / PNP 300 / 200 PBSS5360PAS PBSS5360Z PBSS303PD 1.0 PBSS304PX 0.5 2 50 / 60 340 / 370 2.7 0.27 2 x NPN 200 0.5 5 115 250 1 0.1 PBSS4160DS 2 x PNP 150 0.5 5 120 330 1 0.1 PBSS5160DS NPN / PNP 200 / 150 0.5 5 115 / 120 250 / 330 1 0.1 PBSS4160DPN NPN / NPN 150 0.5 2 90 120 0.5 0.05 PBSS4160PAN PBSS4160PANS PNP / PNP 120 0.5 2 125 180 0.5 0.05 PBSS5160PAP PBSS5160PAPS PBSS304PZ PBSS5560PA 1 PBSS4041PX PBSS4041PZ NPN / PNP 150 / 120 0.5 2 90 / 125 120 / 180 0.5 0.05 PBSS4160PANP PBSS4160PANPS NPN / NPN 210 0.5 2 70 90 0.5 0.05 PBSS4260PAN PBSS4260PANS PNP / PNP 140 0.5 2 100 140 0.5 0.05 PBSS5260PAP PBSS5260PAPS NPN / PNP 210 / 140 0.5 2 70 / 100 90 / 140 0.5 0.05 NPN / NPN 300 0.5 2 20 190 4 0.2 PNP / PNP 200 60 PBSS304PD PBSS5580PA 2 PBSS5480X PBSS305PX PBSS305PZ 6.7 PBSS9110D 5.9 PBSS9110X 6.7 / 5.9 PBSS9110Z PBSS305PD PBSS9410PA 120 PBSS306PX 1 1) Ic / Ib=20 2) PBSS4041SN 0.5 2 35 330 4 0.2 PBSS4041SP NPN / PNP 300 / 200 0.5 2 20 / 35 190 / 330 4 0.2 PBSS4041SPN NPN / NPN 240 0.1 2 90 120 0.5 0.05 PBSS4112PAN PNP / PNP 190 0.1 2 150 220 0.5 0.05 PBSS5112PAP 0.1 2 90 / 150 120 / 220 0.5 0.05 PBSS4112PANP NPN / PNP 240 / 190 PBSS306PZ PBSS4260PANP PBSS4260PANPS Device mounted on a ceramic PCB, AI2O3, standard footprint 3) Optimized for high-speed switching 13 Low VCEsat transistors up to 750 mW Nomenclature for high-power transistors Low VCEsat (BISS) transistors single PNP P HPT 6 10 03 0 N Y Package Code Y = LFPAK56 PAK56 (SOT669) P K = LFPAK56D PAK56D (SOT1205) P Polarity N = NPN P = PNP NP = NPN / PNP Product identifier Max Vceo x 10 e.g.: 10 = 100 V Matching info (only for LFPAK56D) P PAK56D) 0 = No matching 5 = Hfe matching Max Ic current e.g.: 03 = 3 A SOT323 (SC-70) SOT363 (SC-88) DFN1006-3 (SOT883) DFN1006B-3 (SOT883B) DFN1010D-3 (SOT1215) Size (mm) 2.9 x 1.3 x 1.0 2.0 x 1.25 x 0.95 2.0 x 1.25 x 0.95 1.0 x 0.6 x 0.48 1.0 x 0.6 x 0.37 1.1 x 1.0 x 0.37 Ptot (mW) 480 350 430 250 250 750 PBSS3515M PBSS3515MB Package NXP bipolar transistor High Power Transistor SOT23 VCEO (V) IC (A) ICM (A) hFE min/typ @ IC (A) @ VCE (V) VCEsat typ (mV); IC = 0.5 A; IB = 0.05 A 15 0.5 1 200 / 260 0.01 2 150 1 2 300 / 450 0.1 2 125 2) PBSS5120T 3 225 / – 0.5 2 80 2) PBSS5220T 5 220 / 420 0.5 2 50 PBSS5320T 8 250 / 400 0.5 2 35 PBSS4021PT 1.5 180 / 295 0.5 2 85 260 / 350 0.5 2 110 PBSS5130T 300 / 450 0.1 2 70 PBSS5230T 180 / 295 0.5 2 70 20 2.0 Low VCEsat (BISS) transistors single NPN SOT23 3.5 SOT323 (SC-70) Bipolar transistors Low VCEsat transistors up to 750 mW SOT363 (SC-88) DFN1006-3 (SOT883) DFN1006B-3 (SOT883B) PBSS5130QA 1 DFN1010D-3 (SOT1215) Package 3 30 2 Size (mm) 2.9 x 1.3 x 1.0 2.0 x 1.25 x 0.95 2.0 x 1.25 x 0.95 1.0 x 0.6 x 0.48 1.0 x 0.6 x 0.37 1.1 x 1.0 x 0.37 Ptot (mW) 480 350 430 250 250 750 15 20 IC (A) 0.5 1 95 0.5 1 200 / 380 0.01 2 220 300 / 520 0.1 5 130 300 / 800 0.1 5 130 PMMT591A 300 / 510 0.1 5 130 PBSS5140T 1.0 2.0 - PBSS2515M PBSS2515MB 110 2) PBSS4120T 300 / – 0.1 2 110 2 5 220 / 330 0.1 2 45 PBSS4320T 300 / 450 0.1 2 70 4.3 PBSS4021NT 8 300 / 550 0.5 2 21 1.5 230 / 380 0.5 2 90 3 300 / 450 0.5 2 120 2) PBSS4130T 300 / 450 0.5 2 70 PBSS4230T 230 / 380 0.5 2 75 3 2.6 5 300 / 500 0.5 2 80 0.5 1 200 / 550 0.01 2 200 2) 300 / 440 0.5 5 130 300 / 510 0.5 5 120 PMMT491A PBSS4140T 2 5 130 2 70 300 / 450 0.5 2 70 PBSS4240T PBSS4350T 300 / 495 0.5 2 60 0.5 2 90 200 / 420 0.5 5 120 200 / 350 0.5 5 110 3 150 / 240 0.5 2 75 3.8 8 300 / 500 0.5 2 29 1.0 3.0 150 / 400 0.25 10 80 150 / 300 0.25 10 70 2) VCEsat (max) 3) 3 200 / – 0.5 2 2.0 5 200 / 360 0.5 2 55 1.5 120 / 185 0.5 2 125 150 / 250 0.5 5 135 150 / 250 0.5 5 120 60 PBSS2540MB PBSS4140U 0.5 2 IC / IB = 20 PBSS2540M 0.1 150 / 240 90 PBSS5240Y 2) PBSS5240T PBSS5250T PBSS5350T PBSS5160QA PBSS5160U PBSS5160T PBSS4032NT 3) 300 / 420 5 PBSS3540MB PBSS5140U 2) 2.0 1.0 PBSS4230QA 350 / 470 1.5 PBSS3540M 50 PBSS4130QA 2 2.0 PBSS4032PT 3) 40 2 60 14 2 VCEsat typ (mV); IC = 0.5 A; IB = 0.05 A 2 0.1 1.0 1) 0.01 @ VCE (V) 0.5 350 / 470 3.0 100 200 / 325 @ IC (A) 200 / 320 3 40 50 hFE min/typ 5 1 1 30 ICM (A) 2.4 100 PBSS4240Y 1) PBSS4160QA PBSS4160U PBSS4160T PBSS4260QA PBSS4041NT PBSS8110Y 1.7 2.5 120 / 185 0.5 2 105 2.7 8 200 / 300 0.5 2 49 150 / – 0.25 5 93 1.0 3.0 150 / 350 0.5 5 95 IC / IB = 20 In the spotlight VCEO (V) PBSS5230QA 2) VCEsat (max) 3) PBSS5260QA PBSS4041PT PBSS9110Y PBSS9110T Optimized for high-speed switching Low VCEsat transistors in DFN1010D-3: 2 A on 1.1 mm2 footprint High IC performance on ultra-small footprint VCE 30 V and 60 V Leadless DFN1010D-3 (SOT1215) SMD package with solderable sidepads (1.1 x 1.0 x 0.37) AEC-Q101 qualified PBSS8110T Optimized for high-speed switching 15 Bipolar transistors Low VCEsat transistors up to 750 mW DFN2020D-6 with solderable sidepads Low VCEsat (BISS) load switches SOT457 (SC-74) SOT363 (SC-88) Application example: LED lighting in automotive Package Size (mm) 2.9 x 1.5 x 1.0 Ptot (mW) 750 6 VCEO (V) IC (A) VCEsat max (mV); IC = 0.5 A; IB = 0.05 A 0.5 250 5 4 6 R2 R1, R2 (kΩ) TR1 R1 2 006aab506 1 4 TR2 2 3 sym036 150 1.8 0.5 70 350 40 1 1 170 180 1.5 1) 2) 100 3 sym036 2.2 PBLS1501Y PBLS1502Y 10 PBLS1503Y PBLS1504Y 2.2 PBLS2001D 4.7 PBLS2002D 10 PBLS2003D DFN2020D-6 (SOT1118D) Dual package 2.0 x 2.0 x 0.62 mm PBLS2004D 2.2 PBLS2021D 4.7 PBLS2022D 10 PBLS2023D 22 PBLS2024D 2.2 PBLS4001Y 4.7 PBLS4002Y 10 PBLS4003Y 22 PBLS4004Y 47 PBLS4005Y 2.2 PBLS4001D 4.7 PBLS4002D 10 PBLS4003D 22 PBLS4004D 47 PBLS4005D 2.2 PBLS6001D 4.7 PBLS6002D 10 PBLS6003D 22 PBLS6004D 47 60 Matrix light sketch TR2 2 4.7 22 20 4 R2 TR1 1 2) 5 R1 22 1 6 R2 TR1 3 300 1) 5 TR2 R1 1 15 2.0 x 1.25 x 0.95 600 1) PBLS6005D 2.2 PBLS6021D 4.7 PBLS6022D 10 PBLS6023D 22 PBLS6024D Dimming transistor application PBSS5160PAPS in DFN2020D-6 Key package benefits  Industry’s first low VCESat transistor in DFN2020 with 100% solderable sidepads, AOI suitable  Enables individual dimming in the LED front light matrix solution  Saves PCB space by replacing two DFN2020D-3 or two SOT89 packages  Ideal solution for multilayer PCB designs  AEC-Q101 qualified  Suitable for AOI of solder joints  Exposed heat sink for excellent thermal and electrical conductivity  Package size of only 2 x 2 mm and a height of only 0.62 mm  Single version available in DFN2020D-3  DFN2020 is an approved and widely available package platform Device mounted on a ceramic PCB, Al2O3, standard footprint Device mounted on an FR4 PCB, single-sided copper, tin-plated, and standard footprint Low VCEsat double transistors portfolio on DFN2020D-6 Key features and benefits Key applications  Very small input current drives high load current  High efficiency and low-voltage drop due to low VCEsat (BISS) pass transistor  Replaces expensive P-MOSFETs  Inherent reverse-current blocking  Automotive qualified according to AEC-Q101  Fan driver  Battery-charge switch  Supply-line switch  High-side load Low VCEsat (BISS) load switch – the optimal choice for supply-line and high-side switches VCEO (V) IC (A) 20 2 60 60 16 1 2 types in bold represent new products Polarity hFE min @ IC (A) @ VCE (V) VCEsat typ (mV); IC = 0.5 A; IB = 0.05 A Product NPN / NPN 230 0.5 2 60 PBSS4220PANS PNP / PNP 210 0.5 2 70 PBSS5220PAPS NPN / NPN 150 0.5 2 90 PBSS4160PANS PNP / PNP 120 0.5 2 125 PBSS5160PAPS NPN / PNP 150 / 120 0.5 2 90 / 125 PBSS4160PANPS NPN / NPN 210 0.5 2 70 PBSS4260PANS PNP / PNP 140 0.5 2 100 PBSS5260PAPS NPN / PNP 210 / 140 0.5 2 70 / 100 PBSS4260PANPS 17 Low VCEsat (BISS) transistors High-voltage low VCEsat (BISS) transistors types in bold represent new products SOT223 (SC-73) SOT89 (SC-62) SOT1215 Low VCEsat (BISS) transistor PNP – N-channel MOSFET combination DFN2020-6 (SOT1118) SOT23 Package Bipolar transistors Low VCEsat (BISS) transistors Package Size (mm) 6.5 x 3.5 x 1.65 4.5 x 2.5 x 1.5 1.1 x 1.0 x 0.37 2.9 x 1.3 x 1.0 Ptot (mW) 1700 1300 750 250 Polarity VCEO (V) IC (A) PBHV8115QA 0.5 NPN 150 1 PBHV8115Z 2 PBHV8215Z 180 1 400 0.5 PBHV8540Z 1 PBHV8140Z 500 0.15 0.5 PBHV8560Z 4 PBHV9414Z PBHV8540X PNP 600 400 500 1 2.0 x 2.0 x 0.62 Ptot (mW) 1300 VCEO (V) IC (A) 40 2 hFE min hFE max @ IC (mA) @ VCE (V) RCEsat typ (mΩ) VDS (V) VGS (V) ID (A) RDson typ (mΩ) 300 800 100 5 240 30 0.7 0.66 390 PBSM5240PF 100 - 100 5 240 30 0.7 0.66 390 PBSM5240PFH PBHV8540T PMBTA45 6 5 4 PBHV9115QA 0.5 150 PBHV8115T PBHV8118T 600 140 PBHV8115X Size (mm) PBHV9115Z 2 PBHV9215Z 0.5 PBHV9560Z 0.1 PBHV3160Z 0.25 PBHV9040Z 0.5 PBHV9540Z 0.15 PBHV3160Z 0.25 PBHV9050Z PBHV9115X PBHV9115T PBHV9040X PBHV9040T 1 2 3 Combination of low VCEsat transistor with N-channel MOSFET in the very small and ultrathin leadless package DFN2020-6 (SOT1118) 017aaa079 PBHV9050T Advantages of low VCEsat (BISS) technology In the spotlight High-voltage low VCEsat (BISS) transistors in SOT223, SOT23 & SOT89 Our BISS (Breakthrough In Small-Signal) transistors show lowest VCEsat values due to an innovative mesh-emitter technology and further technology improvement. They also reduce board space due to improved collector- current capabilities as shown below. Voltage VCEO up to 600 V Current IC up to 4 A (continuous), 10 A (peak) VCEsat down to 33 mV AEC-Q101 qualified New high-voltage low VCEsat (BISS) in DFN1010D-3 Improved collector-current capabilities  17.87 mm² footprint Low VCEsat (BISS) RETs SOT23 Package DFN2020-3 (SOT1061) M3D088 Size (mm) 2.9 x 1.3 x 1.0 Ptot (mW) VCEO (V) 250 IC (mA) R1 (kΩ) R1 = R2 40 600 R1 ≠ R2 18 R2 (kΩ) NPN PNP 1 1 PBRN113ET PBRP113ET 2.2 2.2 PBRN123ET PBRP123ET 1 10 PBRN113ZT PBRP113ZT 2.2 10 PBRN123YT PBRP123YT DFN2020-3 (SOT1061) DFN2020-3 (SOT1061) 1A 3A 6A BC51PA PBSS5330PA PBSS5630PA General-purpose transistor BISS transistor technology BISS transistor technology 19 Resistor-equipped transistors (RETs) RETs 100 mA single - Part 1 RETs 100 mA double SOT23 types in bold represent new products SOT323 (SC-70) DFN1010B-6 (SOT1216) SOT363 (SC-88) SOT666 Size (mm) 1.1 x 1.0 x 0.37 2.0 x 1.25 x 0.95 1.6 x 1.2 x 0.55 Ptot (mW) 350 300 300 Bipolar transistors Resistor-equipped transistors (RETs) Package Package Size (mm) 2.9 x 1.3 x 1.0 2.0 x 1.25 x 0.95 Ptot (mW) 250 200 VCEO (V) 50 IC (mA) Configuration 100 R1 MSE187 R1 (kΩ) R2 (kΩ) NPN PNP NPN PNP 1 1 PDTA113ET PDTA113EU 2.2 2.2 PDTC123ET PDTA123ET PDTC123EU PDTA123EU 4.7 4.7 PDTC143ET PDTA143ET PDTC143EU PDTA143EU 10 10 PDTC114ET PDTA114ET PDTC114EU PDTA114EU 22 22 PDTC124ET PDTA124ET PDTC124EU PDTA124EU 47 47 PDTC144ET PDTA144ET PDTC144EU PDTA144EU 100 100 PDTC115ET PDTA115ET PDTC115EU PDTA115EU 1 10 2.2 10 2.2 47 PDTC123JT PDTA123JT PDTC123JU PDTA123JU 4.7 10 PDTC143XT PDTA143XT PDTC143XU PDTA143XU 4.7 47 PDTC143ZT PDTA143ZT PDTC143ZU PDTA143ZU 10 47 PDTC114YT PDTA114YT PDTC114YU PDTA114YU 22 47 PDTC124XT PDTA124XT PDTC124XU PDTA124XU 47 10 PDTC144VT PDTA144VT PDTC144VU PDTA144VU 47 22 PDTC144WT PDTA144WT PDTC144WU PDTA144WU 2.2 - PDTC123TT PDTA123TT PDTC123TU PDTA123TU 4.7 - PDTC143TT PDTA143TT PDTC143TU PDTA143TU 10 - PDTC114TT PDTA114TT PDTC114TU PDTA114TU 22 - PDTC124TT PDTA124TT PDTC124TU PDTA124TU 47 - PDTC144TT PDTA144TT PDTC144TU PDTA144TU 100 - PDTC115TT PDTA115TT PDTC115TU PDTA115TU PDTA113ZT PDTC123YT VCEO (V) IC (mA) PDTC123YU RETs 100 mA single - Part 2 PDTA123YU 50 DFN1006B-3 (SOT883B) R1 ≠ R2 SOT1215 Only R1 Package Size (mm) 1.0 x 0.6 x 0.48 1.0 x 0.6 x 0.37 1.1 x 1.0 x 0.37 Ptot (mW) 250 250 750 VCEO (V) IC (mA) 50 Configuration 100 R1 MSE187 20 R1 (kΩ) R2 (kΩ) NPN PNP NPN PDTA113EM PNP NPN PNP 1 1 2.2 2.2 4.7 4.7 PDTC143EM PDTA143EM PDTC143EMB PDTA143EMB PDTC143EQA PDTA143EQA 10 10 PDTC114EM PDTA114EM PDTC114EMB PDTA114EMB PDTC114EQA PDTA114EQA 22 22 PDTC124EM PDTA124EM PDTC124EMB PDTA124EMB PDTC124EQA PDTA124EQA PDTC144EQA PDTA144EQA PDTC123EM PDTA123EM PNP / PNP NPN / NPN NPN / PNP PNP / PNP NPN / NPN NPN / PNP PNP / PNP 2.2 2.2 PUMH20 PUMD20 PUMB20 PEMH20 PEMD20 PEMB20 4.7 4.7 PUMH15 PUMD15 PUMB15 PEMH15 PEMD15 PEMB15 10 10 PUMH11 PUMD3 PUMB11 PEMH11 PEMD3 PEMB11 22 22 PQMD2 PUMH1 PUMD2 PUMB1 PEMH1 PEMD2 PEMB1 47 47 PQMD12 PUMH2 PUMD12 PUMB2 PEMH2 PEMD12 PEMB2 100 100 PUMH24 PUMD24 PUMB24 PEMH24 PEMD24 PEMB24 2.2 47 PUMH10 PUMD10 PUMB10 PEMH10 PEMD10 PEMB10 4.7 10 PUMH18 PUMD18 PUMB18 PEMH18 PEMD18 PEMB18 4.7 47 PQMH13 PUMH13 PUMD13 PUMB13 PEMH13 PEMD13 PEMB13 10 47 PQMH9 PUMH9 PUMD9 PUMB9 PEMH9 PEMD9 PEMB9 22 47 PUMH16 PUMD16 PUMB16 PEMH16 PEMD16 PEMB16 47 22 PUMH17 PUMD17 PUMB17 PEMH17 PEMD17 PEMB17 47 / 2.2 47 / 47 2.2 - PUMH30 PUMD30 PUMB30 PEMH30 PEMD30 PEMB30 4.7 - PUMH7 PUMD6 PUMB3 PEMH7 PEMD6 PEMB3 10 - PUMH4 PUMD4 PUMB4 PEMH4 PEMD4 PEMB4 22 - PUMH19 PUMD19 PUMB19 PEMH19 PEMD19 PEMB19 47 - PUMH14 PUMD14 PUMB14 PEMH14 PEMD14 PEMB14 PQMH11 PQMD3 PQMB11 PQMH2 PQMH10 PQMD10 PQMD13 100 types in bold represent new products DFN1006-3 (SOT883) R1 (kΩ) R2 (kΩ) NPN / NPN NPN / PNP R1 = R2 PDTA113ZU PDTA123YT Configuration PQMD16 PUMD48 PEMD48 RETs 500 mA types in bold represent new products PDTA113EMB PDTC123EMB PDTA123EMB SOT457 (SC-74) SOT23 SOT323 (SC-70) SOT1215 1.1 x 1.0 x 0.37 Package 47 47 PDTC144EM PDTA144EM PDTC144EMB PDTA144EMB 100 100 PDTC115EM PDTA115EM PDTC115EMB PDTA115EMB Size (mm) 2.9 x 1.5 x 1.0 2.9 x 1.3 x 1.0 2.0 x 1.25 x 0.95 1 10 PDTA113ZMB Ptot (mW) 750 250 200 2.2 10 PDTC123YM PDTA123YM PDTC123YMB PDTA123YMB 2.2 47 PDTC123JM PDTA123JM PDTC123JMB PDTA123JMB PDTC123XQA PDTA123XQA VCEO (V) IC (mA) 4.7 10 PDTC143XM PDTA143XM PDTC143XMB PDTA143XMB PDTC143XQA PDTA143XQA PDTA113ZM 4.7 47 PDTC143ZM PDTA143ZM PDTC143ZMB PDTA143ZMB PDTC143ZQA PDTA143ZQA 10 47 PDTC114YM PDTA114YM PDTC114YMB PDTA114YMB PDTC114YQA PDTA114YQA 22 47 PDTC124XM PDTA124XM PDTC124XMB PDTA124XMB 47 10 PDTC144VM PDTA144VM PDTC144VMB PDTA144VMB 47 22 PDTC144WM PDTA144WM PDTC144WMB PDTA144WMB 2.2 - PDTC123TM PDTA123TM PDTC123TMB PDTA123TMB 4.7 - PDTC143TM PDTA143TM PDTC143TMB PDTA143TMB 10 - PDTC114TM PDTA114TM PDTC114TMB PDTA114TMB 22 - PDTC124TM PDTA124TM PDTC124TMB PDTA124TMB 47 - PDTC144TM PDTA144TM PDTC144TMB PDTA144TMB 100 - PDTC115TM PDTA115TM PDTC115TMB PDTA115TMB R1 (kΩ) R2 (kΩ) NPN / NPN NPN / PNP 750 NPN PNP NPN PNP NPN PNP 1 1 PDTD113ET PDTB113ET PDTD113EU PDTB113EU PDTD113EQA PDTB113EQA 2.2 2.2 PDTD123ET PDTB123ET PDTD123EU PDTB123EU PDTD123EQA PDTB123EQA 4.7 4.7 PDTD143ET PDTB143ET PDTD143EU PDTB143EU PDTD143EQA PDTB143EQA 10 10 PDTD114ET PDTB114ET PDTD114EU PDTB114EU PDTD114EQA PDTB114EQA 1 10 PDTD113ZT PDTB113ZT PDTD113ZU PDTB113ZU PDTD113ZQA PDTB113ZQA 2.2 10 PDTD123YT PDTB123YT PDTD123YU PDTB123YU PDTD123YQA PDTB123YQA 4.7 10 PDTD143XT PDTB143XT PDTD143XU PDTB143XU PDTD143XQA PDTB143XQA 2.2 - PDTD123TT PDTB123TT R1 = R2 50 500 R1 ≠ R2 Only R1 PIMN31 PIMC31 21 General-purpose bipolar transistors Single transistors NPN types in bold represent new products SOT23 Package VCEO (V) IC (mA) hFE min/typ 25 100 30 100 45 50 DFN1010D-3 (SOT1215) DFN1006B-3 (SOT883B) SOT457 (SC-74) SOT363 (SC-88) SOT666 DFN1010B-6 (SOT1216) 100 100 100 hFE max fT min (MHz) 2.9 x 1.3 x 1.0 2.0 x 1.25 x 0.95 1.1 x 1.0 x 0.37 1.0 x 0.6 x 0.48 1.0 x 0.6 x 0.37 250 200 750 250 250 Size (mm) 2.9 x 1.5 x 1.0 2.0 x 1.25 x 0.95 1.6 x 1.2 x 0.55 1.0 x 1.0 x 0.37 Ptot (mW) 750 300 300 350 450 1200 100 110 - 200 450 - 800 100 350 900 100 PUMX1 PEMX1 BC847DS BC847BS BC847BV 110 - 420 220 - 800 100 BCW31 / 32 / 33 180 - 380 310 - 630 250 BCW60B / C / D Polarity PMST5089 BC848B VCEO (V) IC (mA) hFE min hFE max fT min (MHz) 40 100 120 450 100 45 100 200 450 100 110 - 100 BC848W PMST5088 110 - 420 220 - 800 100 BC847 / A / B / C 120 - 380 220 - 630 100 BCX70G / H / J / K 110 - 200 220 - 450 100 BCW71 / 72 500 1250 100 210 - 290 340 - 460 100 - 150 250 650 100 PMBT6429 2PD601ART 2PD601ARL 2PD601ASL PMBT6428 NPN BC847W / AW / BW / CW BC847AQA / BQA / CQA BC847AM / BM / CM BC847AMB / BMB / CMB PMST6429 2PD601ARW / SW PNP 100 200 450 100 50 150 120 560 100 45 500 160 400 80 BC817DS 40 100 120 450 100 PIMT1 PUMT1 PEMT1 45 100 200 450 100 BC857BS BC857BV 110 - 100 BC856S 200 450 100 500 160 400 80 40 100 120 450 100 PUMZ1 PEMZ1 45 100 200 450 100 BC847BPN BC847BVN 50 100 120 560 100 220 - 450 100 BCV71 / 72 65 100 110 - 200 220 - 450 100 BC846 / A / B 80 100 20 80 60 BSS64 150 120 - 200 240 - 400 80 NXP3875Y / G 150 120 - 270 270 - 560 100 210 340 100 2PD601BRL 65 100 200 450 100 290 460 100 2PD601BSL 12 500 200 - 250 / 100 100 - 250 250 - 600 100 BC817 / -16 / -25 / -40 45 500 160 160 100 / 800 100 600 100 BCX19 2PD602AQL 2PD602ARL 2PD602ASL 200 45 500 50 500 85 - 170 170 - 340 140 - 180 60 500 50 - 100 80 500 100 - 50 2PC4081Q / R / S BC817W / -16W / -25W / -40W 2PC4617QM / RM 2PD1820AR / S PMBTA06 32 45 100 100 DFN1006-3 (SOT883) DFN1006B-3 (SOT883B) 1.1 x 1.0 x 0.37 1.0 x 0.6 x 0.48 1.0 x 0.6 x 0.37 200 750 250 250 Size (mm) BC846BPN PEMZ7 BC817DPN types in bold represent new products SOT223 (SC-73) SOT89 (SC-62) SOT23 SOT323 (SC-70) SOT363 (SC-88) 6.5 x 3.5 x 1.65 4.5 x 2.5 x 1.5 2.9 x 1.3 x 1.0 2.0 x 1.25 x 0.95 2.0 x 1.25 x 0.95 SOT666 DFN1006-3 DFN1006B-3 (SOT883) (SOT883B) 125 - 220 500 - 800 100 BC858B 120 - 215 260 - 500 100 BCW29 / 30 180 - 380 310 - 630 100 BCW61B / C / D 210 - 290 340 - 460 70 - 80 2PB709ART 2PB709ARL 2PB709ASL 180 - 380 310 - 630 100 BCX71H / J / K 120 - 215 260 - 500 100 BCW69 / 70 125 - 420 250 - 800 100 BC857 / A / B / C 150 BCW89 65 100 125 - 200 250 - 475 100 BC856 / A / B 100 100 30 - 50 BSS63 150 120 - 270 270 - 560 100 210 340 100 2PB709BRL 290 460 100 2PB709BSL 100 600 80 BCX18 100 - 250 250 - 600 80 BC807 / -16 / -25 / -40 100 600 80 BCX17 2PB710ARL 2PB710ASL 45 500 50 500 85 - 170 170 - 340 100 - 140 60 500 100 - 50 80 500 100 - 50 BC857W / AW / BW / CW 1700 1300 250 200 300 300 250 250 single single single single double double single single PMBT3904YS PMBT3904VS PMBT3904M PMBT3904MB PMBT3906VS PMBT3906M PMBT3906MB Polarity NPN BC857AQA / BQA / CQA BC857AM / BM / CM BC857AMB / BMB / CMB BC856W / AW / BW BC856BM BC856BMB 2PA1576Q / R / S 2PA1774QM / RM / SM 2PA1774QMB / RMB / SMB VCEO (V) IC (mA) hFE min hFE max fT min (MHz) 12 100 40 120 400 20 BSV52 180 1200 PMBS3904 PMSS3904 300 250 500 20 PMBT2369 PMST2369 40 200 100 300 15 600 40 120 BC807 / -25QA / -40QA PNP toff (ns) 40 200 100 300 300 250 30 600 100 300 250 250 250 250 40 600 100 300 40 800 100 40 100 100 40 BC807W / -16W / -25W / -40W 40 200 600 100 100 300 250 300 300 250 300 150 700 300 300 250 200 PZT4401 PXT4401 350 PMBT3904 PMST3904 PMBT2222 PMST2222 PMBT4401 PMST4401 PMBT4401YS PMST2222A PMBT2222AYS MMBT2222A PZT2222A PXT2222A PMBT2222A BSR14 PMBS3906 60 600 100 300 40 200 100 300 200 PZT4403 PXT4403 365 365 NPN / PNP 300 / 250 250 / 300 PMSS3906 MMBT3906 PMBT3906 PMST3906 PMBT3906YS PMBT4403 PMST4403 PMBT4403YS PMBT2907 300 2PB1219AQ / R / S PMSTA56 MMBT3904 300 PMSTA55 PMBTA56 1.0 x 0.6 x 0.37 Configuration BC858W 2PB709ARW / SW 1.6 x 1.2 x 0.55 1.0 x 0.6 x 0.48 Ptot (mW) fT min (MHz) 260 500 DFN1010D-3 (SOT1215) 2.0 x 1.25 x 0.95 120 25 SOT323 (SC-70) 250 100 200 BC847QAPN PUMZ2 PMSTA06 2.9 x 1.3 x 1.0 60 50 PIMZ2 Package Size (mm) Ptot (mW) 100 BC856BS types in bold represent new products Package 30 NPN / PNP BC857QAS BC807DS Single and double switching transistors PMSTA05 SOT23 hFE max 2PC4617QMB / RMB BC817 / -25QA / -40QA Single transistors PNP VCEO (V) IC (mA) hFE min/typ BC846BMB PUMX2 45 110 - 200 BC846BM BC846BS 100 100 BC846W / AW / BW BC846DS 65 PMST6428 BC847QAS BC846S 65 60 50 22 DFN1006-3 (SOT883) Package Size (mm) Ptot (mW) 32 SOT323 (SC-70) Double transistors Bipolar transistors General-purpose bipolar transistors PMST2907A BSR16 PZT2907A PXT2907A PMBT2907A PMBT2907AYS PMBT3946YPN PMBT3946VPN 23 General-purpose bipolar transistors Medium-power general-purpose transistors LED driver SOT223 (SC-73) SOT89 (SC-62) DFN2020-3 (SOT1061) DFN2020D-3 (SOT1061D) Size (mm) 6.5 x 3.5 x 1.65 4.5 x 2.5 x 1.5 2.0 x 2.0 x 0.62 2.0 x 2.0 x 0.62 Ptot (mW) 1700 1300 1300 1300 BC68PA / BC68-25PA BC68PAS / BC68-25PAS BC54PA / BC54-10PA / BC54-16PA BC55PA / BC55-10PA / BC55-16PA BC54PAS / BC54-10PAS / BC54-16PAS BC55PAS / BC55-10PAS / BC55-16PAS BC56PA / BC56-10PA / BC56-16PA BC56PAS / BC56-10PAS / BC56-16PAS BC69PA / BC69-16PA / BC69-25PA BC51PA / BC51-10PA / BC51-16PA BC52PA / BC52-10PA / BC52-16PA BC69PAS / BC569-16PAS / BC69-25PAS BC51PAS / BC51-10PAS / BC51-16PAS BC52PAS / BC52-10PAS / BC52-16PAS BC53PA / BC53-10PA / BC53-16PA BC53PAS / BC53-10PAS / BC53-16PAS Package Polarity VCEO (V) IC (A) hFE min 20 2 85 - 160 375 40 BCP68 / -25 BC868 / -25 45 1 63 - 100 160 - 250 100 BCP54 / -10 / -16 BCX54 / -10 / -16 60 1 63 - 100 160 - 250 100 BCP55 / -10 / -16 BCX55 / -10 / -16 100 300 100 BSP41 BSR41 63 - 100 160 - 250 100 BCP56 / -10 / -16 BCX56 / -10 / -16 40 - 100 120 - 300 100 BSP43 BSR43 40 BCP69 / -16 / -25 BC869 / -16 / -25 BCP51 / -10 / -16 BCX51 / -10 / -16 BCP52 / -10 / -16 BCX52 / -10 / -16 NPN 80 PNP 2 85 - 160 250 - 375 45 1 63 - 100 160 - 250 63 - 100 160 - 250 40 - 100 120 - 300 63 - 100 160 - 250 40 - 100 120 - 300 60 1 1 115 1) - 145 1) 100 100 115 1) - 145 1) 100 BSP31 BSR30 / 31 BCP53 / -10 / -16 BCX53 / -10 / -16 BSP32 / 33 BSR33 Size (mm) Ptot (mW) Vs supply voltage [V] 2.9 x 1.5 x 1.0 2.9 x 1.3 x 1.0 750 480 LED drive current [mA] @ Vs=10V 10 NCR401T 20 NCR402T 18 40 10 NCR401U 20 NCR402U 50 NCR405U Voltage reference for SOT457 VS VSUP VCC Rint Typical value In the spotlight SOT23 Package hFE max fT min (MHz) 20 80 1) 1 SOT457 Bipolar transistors General-purpose bipolar transistors Rext  Single-chip constant-current source with reduced component count  Very small footprint for smaller designs REXT Medium-power transistors in DFN2020-3 and DFN2020D-3 (with solderable sidepads) Excellent electrical performance on a small 2 x 2 mm footprint VO 80% board space reduction (DFN2020 vs. SOT89) IOUT VCEO ranging from 20 V to 80 V High collector-current capability IC up to 2 A LED GND AEC-Q101 qualified Key applications Iout IO 100% solderable sidepads (DFN2020D-3) Key features and benefits LED GND  Constant-current LED driver  Generic constant-current source  Active bias control for audio amplifiers aaa-010022 aaa-019594 High-voltage transistors SOT223 (SC-73) SOT89 (SC-62) SOT457 (SC-74) SOT23 SOT323 (SC-70) 6.5 x 3.5 x 1.65 4.5 x 2.5 x 1.5 2.9 x 1.5 x 1.0 2.9 x 1.3 x 1.0 2.0 x 1.25 x 0.95 1700 1300 750 250 200 Package Size (mm) Ptot (mW) Polarity NPN PNP 2 x NPN VCEO (V) IC (mA) hFE min hFE max fT min (MHz) Constant-current source SOT353 (SC-88A) Package 80 100 20 - 60 BSS64 140 300 60 250 100 PMBT5550 PMST5550 160 300 80 250 100 PMBT5551 / BSR19A PMST5551 Size (mm) 2.0 x 1.25 x 0.95 250 100 50 - 60 300 100 50 - 60 BF720 BF620 BF820 BF820W Ptot (mW) 335 40 - 50 PZTA42 PXTA42 PMBTA42 PMSTA42 350 100 40 - 70 BSP19 BST39 400 300 50 200 20 PZTA44 100 100 30 - 50 50 - 60 50 - 60 BF623 50 - 60 BF621 BF821 40 - 50 PXTA92 PMBTA92 40 - 50 250 100 300 100 300 100 BF722 BF622 BF822 Type BSS63 BF723 PZTA92 PSSI2021SAY PMBTA44 Description maximum supply voltage maximum supply current typical stabilized output current minimum stabilized output current maximum stabilized output current Parameter VS max (V) IS max (mA) Iout typ (µA) Iout min (mA) Iout max (mA) 75 2.2 15 0.015 50 BF823 PMBTA42DS PMSTA92 Value For high-voltage transistors with increased performance please refer to our high-voltage low VCEsat (BISS) transistor portfolio on page 18. 24 25 General-purpose bipolar transistors Darlington transistors Matched-pair transistors SOT223 (SC-73) SOT89 (SC-62) SOT23 SOT143B Package Size (mm) 6.5 x 3.5 x 1.65 4.5 x 2.5 x 1.5 2.9 x 1.3 x 1.0 1700 1300 250 VCEO (V) IC (mA) hFE min fT min (MHz) 10000 30 NPN 500 45 60 1000 2000 200 500 10000 220 2000 PXTA14 BCV29 BSP50 BSP51 BST51 BSP52 BST52 45 1000 2000 200 500 10000 220 1000 2000 200 2.9 x 1.3 x 1.0 2.9 x 1.5 x 1.0 Ptot (mW) Polarity SOT353 (SC-88A) SOT363 (SC-88) SOT666 LFPAK56D (SOT1205) 2.0 x 1.25 x 0.95 2.0 x 1.25 x 0.95 1.6 x 1.2 x 0.55 5 x 6 x 1.1 250 BCV27 NPN BCV47 220 BCV28 BSP60 300 300 300 1250 100 110 800 BSP61 BST61 BSP62 BST62 0.7 1) 0.9 1) 45 100 200 450 65 100 100 3000 200 150 450 400 0.95 0.98 0.9 0.95 0.7 1) 0.9 1) n.a. n.a. 2 2 2 2 n.a. BCV61/A/B/C 1) BCM61B 1) n.a. n.a. 2 2 2 2 n.a. BCV62/A/B/C 1) BCM62B 1) BCM847DS BCM847BS PMP4501G PMP4201G BCM847BV PMP4501Y PMP4201Y PMP4501V PMP4201V BCM846BS PHPT610035NK Configuration BCV26 BST60 BCV48 750 VCEO V -V I (mA) hFE min hFE max hFE1/hFE2 BE1 BE2 (V) C (mV) 30 PMBTA14 PMBTA64 125 20000 Size (mm) BST50 BCV49 200 500 80 PZTA14 220 30 60 PMBTA13 125 20000 1000 80 PNP SOT457 (SC-74) Package Ptot (mW) Polarity types in bold represent new products Bipolar transistors General-purpose bipolar transistors 30 100 100 800 45 100 200 450 65 100 100 3000 200 150 450 220 BCV46 PNP 0.95 0.98 0.9 0.9 BCM857DS BCM857BS PMP5501G PMP5201G BCM856DS BCM857BV PMP5501Y PMP5201Y PMP5501V PMP5201V BCM856BS PHPT610035PK Configuration Schmitt triggers 1) IC1 / IE2 SOT143B Package Size (mm) 2.9 x 1.3 x 1.0 Ptot (mW) 250 Polarity VCEO (V) TR1 VCEO (V) TR2 IC (mA) hFE min hFE max VCEsat typ (mV) NPN 30 6 100 110 800 250 BCV63 / B PNP 30 6 100 220 475 250 BCV64B In the spotlight New transistors in LFPAK56D (SOT1205) power package High thermal power dissipation up to 3 W Vceo up to 100 V All types AECQ-101 qualified 2 types with current gain matching of 5% and 10% Reduced PCB size requirements High-temperature applications up to 175 °C For LED lighting, motor drive, linear regulators, backlight units, PowerMOS, and IGBT drive Low-noise transistors SOT23 SOT323 (SC-70) Size (mm) 2.9 x 1.3 x 1.0 2.0 x 1.25 x 0.95 Ptot (mW) 250 200 Package Polarity VCEO (V) IC (mA) Noise figure max (dB) 30 100 4 NPN 45 100 4 30 100 4 45 100 4 PNP 26 hFE min hFE max fT min (MHz) 200 450 100 BC849B BC849BW BC849CW 420 800 100 BC849C 200 450 100 BC850B BC850BW 420 800 100 BC850C BC850CW 220 475 100 BC859B BC859BW 420 800 100 BC859C BC859CW 220 475 100 BC860B BC860BW 420 800 100 BC860C BC860CW Key features  Current gain matching to 2, 5, or 10%  Base-emitter voltage matching to 2 mV  Choice of standard double transistor pinout or application-optimized pinout  Common-emitter configuration for 5-pin type  Range of small, very small, and ultra-small packages Key applications  Current mirrors  Differential and instrumentation amplifiers  Logarithmic amplifiers  Comparators Differential amplifier Current mirror Key benefits  Improved performance of current mirror and differential amplifier circuits  Drop-in replacement for standard double transistors (BCM series)  Simplified board layout (PMP series)  Eliminates the need for costly additional trimming 27 General-purpose bipolar transistors MOSFET driver VCEO (V) IC (A) Icm [A] Type Package Remark Configuration SOT143B 30 0.1 0.2 BCV65 0.6 1 PMD2001D 1 2 PMD3001D General-purpose transistors SOT457 Switching transistors with reduced storage time 40 Low VCEsat Key features and benefits  Three different configurations  Types available with standard, switching, and low VCEsat (BISS) transistors  Small footprint MOSFET driver for faster switching, lower losses Op-amp booster Schottky barrier diodes and rectifiers Key applications Medium-power low VF Schottky rectifiers single ≥1 A - Flatpower packages Medium-power low VF Schottky rectifiers single ≥200 mA - DSN packages Medium-power low VF Schottky rectifiers single ≥200 mA - leadless (DFN) packages Medium-power low VF Schottky rectifiers single ≥200 mA - leaded packages Medium-power low VF Schottky rectifiers dual ≥200 mA General-purpose Schottky diodes ≤250 mA Low-capacitance Schottky diodes  Power management - (Half) bridge push-pull driver - Isolated DC/DC converters - Secondary synchronous rectification  Peripheral driver - (Half) bridge push-pull driver - Motor driver - Brushless DC motor driver - Op-amp output current booster Zener diodes General-purpose Zener diodes Zener diodes specifications Switching diodes Medium-frequency transistors SOT23 SOT323 (SC-70) Size (mm) 2.9 x 1.3 x 1.0 2.0 x 1.25 x 0.95 Ptot (mW) 250 200 Package Polarity Diodes VCEO (V) IC (mA) 15 100 hFE min hFE max fT typ (MHz) - 500 BF570 85 >275 BFS20 General-purpose, high-speed switching diodes < 90 V General-purpose, high-speed switching diodes 100 V General-purpose, switching diodes ≥100 V PN-rectifier Controlled-avalanche switching diodes Low-leakage current-switching diodes 33 33 34 35 36 37 38 39 40 40 41 42 42 42 43 43 44 44 40 25 NPN 40 30 65 225 260 BFS19 25 67 220 380 BF840 25 50 250 BF824 50 - >325 BF550 30 PNP BF824W 25 40 28 BFS20W 20 29 What you get when you choose NXP for diodes and rectifiers Switching Diodes trr Low leakage, 0.13 – 0.25 A BAV199x BASx16x BAW170 BAW156 A quality product from an experienced, high volume supplier A comprehensive portfolio for all kind of applications NXP is continually innovating parts by reducing power consumption and size while boosting performance and reliability A broad range of packages Including standard leaded SMD, medium-power clip-bond and ultra-small leadless packages with dimensions down to 0.6 x 0.3 x 0.3 mm BAS45Ax 1500 ns  NXP is strongly committed to automotive quality standards  NXP has a track record of more than 60 years in developing and producing diodes  NXP is the #1 in small-signal discretes with a high production capacity Standard, 1 A PNS40010ER 50 ns High speed, 0.25 A High speed, 0.2 – 0.25 A Avalanche, 0.25 A BAS29, BAS3x BAS19, BAS20 BAS21J BAS21x Diodes 3000 ns BAW10x BAS521 BAV10x BAV23x Ultra High Speed, 0.15 A 25 ns BAS16xx 1PS30x 4 ns BAV70x BAV99xx 1PS3xx Portfolio Overview Diodes BAW56x PMLL4x48 Schottky Diodes PMBDxx 11 leaded and 4 leadless packages 1N4x48 100 V 200 V 300 V 400 V VR Next generation process and package technology IF Power Schottky Rectifiers 15 A Zener Diodes PMEGxxPD Ptot 1500 mW Medium Power Schottky Rectifiers BZV90 5A PMEGxxP PMEG 20 – 100 V 10 leaded packages and 1 leadless package 1200 mW PMEGxxR 14 leaded and leadless packages 800 mW BZX84(J) series NZHx series BZT52Hx series 0.2 A PZUxB series General Purpose Schottky Diodes 7 leaded and leadless packages Low Capacitance RF 0.03 A PMBD35x BAT17 BAT54 series BAT 754 / 721 / 85 series 1PS7xSBx BAS40x BAS70x 1PSxxSB8x 0.3 V 30 0.5 V TDZxJ 400 mW BZB984 series BZB784 series B751 series RB52x series 13 leaded and leadless packages 1PSxSB17 500 mW 0.75 V 1V VF 200 mW PDZ- B series BZX384 series PZUxBA series PZUxDB2 series BZX884 series PZUxBL series 1.0 mm 2.0 mm BZB84 series BZX84 series PLVA2600A series PLVA6xxA series 3.0 mm 4.0 mm 5.0 mm Package size 31 Schottky barrier diodes and rectifiers NXP’s FlatPower packages CFP3, CFP5, and CFP15 Medium-power low VF Schottky rectifiers single ≥ 1 A - FlatPower packages 30 1 Large heat sink Silicon die 40  Automatic optical inspection of solder joint 60 100 Low IR Schottky Portfolio, AEC-Q101 30 CFP5 (SOD128) CFP15 (SOT1289) PMEG10030ELP 1.5 Low VF PMEG3010EP PMEG3010ER Low IR PMEG3010BEP PMEG3010BER 450 660 0.0003 Low IR PMEG6010ELR 770 0.00015 Low IR PMEG10010ELR 360 3 Low VF PMEG3020EP 420 1.5 Low VF PMEG3020CEP 450 0.1 Low IR PMEG3020BEP 520 0.05 490 0.1 530 0.2 680 0.0007 770 PMEG4020ER Low VF PMEG4020ETP PMEG4020ETR Low VF PMEG6020EP PMEG6020ER PMEG6020ETP PMEG6020ETR Low IR PMEG6020AELP PMEG6020AELR PMEG10020AELP PMEG10020AELR PMEG6020ELR Low IR Low IR PMEG10020ELR 0.00015 Low IR 5 Low VF PMEG3030EP 450 0.15 Low IR PMEG3030BEP Low VF PMEG4030EP Low VF PMEG4030ETP 0.4 Low VF PMEG6030EVP 0.2 Low VF PMEG6030ETP 690 0.001 Low IR PMEG6030ELP 100 770 0.00045 Low IR PMEG10030ELP 60 530 0.4 Low VF PMEG6045ETP 360 8 Low VF PMEG3050EP 450 0.25 Low IR PMEG3050BEP Low VF PMEG4050EP 490 0.3 Low VF PMEG4050ETP 60 560 0.4 Low VF PMEG060V050EPD 6 100 850 0.001 Low IR PMEG100V060ELPD 8 100 850 0.001 IF Low VF PMEG4030ER PMEG045V050EPD Low IR PMEG100V080ELPD Low VF PMEG045V100EPD Low VF PMEG45U10EPD 490 0.6 540 0.5 Low IR PMEG45A10EPD 60 560 0.7 Low VF PMEG060V100EPD 100 850 0.001 Low IR PMEG100V100ELPD Low IR PMEG045T150EPD 45 45 15 50 580 0.1 PMEG3020BER Low VF 830 550 NXP offers more than 200 products in FlatPower packages, to support a wide range of applications for medium-power rectification and surge protection. PMEG4020EP 360 45 > 6A PMEG3020DEP 530 PMEG6020AELP 3A Low IR 475 10 32 0.0003 PMEG3020ER Low VF PMEG6030EP 40 PMEG6010ER PMEG6010ETR Low IR PMEG6030ELP 2A PMEG6010EP Low VF 5 1A Low VF Low VF 0.2 30 PMEG6020AELR PMEG4010ER PMEG4010ETR 0.1 60 60 V PMEG4010EP PMEG4010ETP 530 PMEG100V060ELPD PMEG6020ELR 0.06 Low VF Low VF 540 3 4.5 PMEG6010ELR 0.05 0.2 PMEG100V080ELPD PMEG10020AELP @ VR max 360 490 40 PMEG100V100ELPD PMEG10020ELR IR max (mA) VF max (mV) PMEG2010ER PMEG2010BER 760 PMEG10020AELR 950 Optimization Low IR 2 due to tin-plated lead ends  Benchmark flat design of only 0.7 mm height PMEG10010ELR 2.6 x 1.7 x 1.0 1050 Low VF 530 clip-bond technology and heatsink 100 V 3.8 x 2.5 x 1.0 2150 1 60  High-power capability due to wire-free CFP3 (SOD123W) 5.8 x 4.3 x 0.78 0.05 490 30 VR Size (mm) Ptot (mW) @ 1 cm² 450 40 100 Tin-plated lead end  AEC-Q101 qualified CFP3 (SOD123W) 340 530 Solid clip  Halogen-free mold compound CFP5 (SOD128) Diodes Robust design @ IF max VR max (V) IF max (A) 20  Flat geometry, of down to 0.78 mm height CFP15 (SOT1289) Package The medium-power solution for shrinking designs Small SMD FlatPower packages in three different versions types in bold represent new products Low IR PMEG45T15EPD Low VF PMEG045V150EPD 490 1 550 0.1 Low IR PMEG050T150EPD 500 1 Low VF PMEG050V150EPD 33 Schottky barrier diodes and rectifiers Medium-power low VF Schottky rectifiers single ≥ 200 mA - Leadless DSN packages 20 0.5 30 40 30 1 40 60 @ VR max IR max (mA) VF max (mV) 1.0 x 0.6 x 0.28 1.0 x 0.6 x 0.28 525 1.000 1.190 Optimization 0.045 Low VF PMEG2002AESF 490 0.0035 Low IR PMEG2002ESF 470 0.08 535 Low VF 0.009 PMEG3002AESF Low IR PMEG3002ESF 0.2 DFN1006D-2 (SOD882D) Size (mm) 2.0 x 2.0 x 0.62 2.0 x 2.0 x 0.62 1.6 x 0.8 x 0.37 1.0 x 0.6 x 0.48 1.0 x 0.6 x 0.37 Ptot (mW) @ 1 cm² 960 960 780 565 660 30 480 0.05 low VF PMEG3002AEL PMEG3002AELD 40 600 0.01 low IR PMEG4002EL PMEG4002ELD 60 600 0.1 low VF Package Optimization 0.08 Low VF PMEG4002AESF 0.0065 Low IR PMEG4002ESF 390 0.2 low VF 550 0.045 Low VF PMEG2005AESF 410 0.3 low VF 620 0.0035 Low IR PMEG2005ESF 630 0.08 Low VF PMEG3005AESF 720 0.009 Low IR PMEG3005ESF Low VF PMEG4005AESF 820 0.08 20 PMEG4005ESF 0.0065 Low IR 480 1.25 Low VF PMEG3010AESB 565 0.045 Low IR PMEG3010ESF 505 0.115 Low VF PMEG4010AESB 610 0.04 Low IR PMEG4010ESB 625 0.65 Low VF PMEG6010AESB 730 0.03 Low IR PMEG6010ESB 1.5 1 PMEG3010AESB versus competitor type PMEG3010AESB PMEG3010AESB PMEG4010AESB PMEG4010AESB PMEG3005AESF PMEG3005AESF PMEG4005AESF PMEG4005AESF 0.8 0.8 0.80.8 0.2 0.2 PMEG2005AEL PMEG2005AELD low IR PMEG2005EL PMEG2005ELD 30 500 0.5 low VF PMEG3005EL PMEG3005ELD 40 590 0.01 low IR 375 1.9 low VF 20 PMEG4005EPK PMEG2010EPA 415 0.6 low VF 490 0.2 low VF 40 600 0.02 low IR PMEG4010EPK 20 420 0.9 low VF PMEG2015EPK 40 610 0.03 low IR 420 1.9 low VF PMEG2010EPK PMEG2010BELD PMEG4015EPK PMEG2020EPA PMEG2020EPAS 450 0.9 low VF 30 470 2.5 low VF PMEG3020EPA PMEG3020EPAS 40 535 0.1 low VF PMEG4020EPA PMEG4020EPAS 530 0.2 low VF 575 0.25 low VF PMEG6020EPA PMEG6020EPAS PMEG2020EPK PMEG4020EPK PMEG3010AESB PMEG3010AESB Competitor type Competitor type Applications  33% lower VF on same footprint  Handheld equipment 0.40.4  Low profile of 0.37 mm  Smartphone backlight units 0.20.2  Solderable side pads  Battery chargers  Visual solder inspection  Shrinked PCB designs reduced reduced VF VF enlarged IF max enlarged IF max 0 0 0.40.4 0.50.5 0.60.6 0.70.7 This diagram shows the broad variety of the DSN portfolio VFV[ FV[ ]V ] 0.2 0.2 0.30.3 0.40.4 0.50.5 Differentiated portfolio with best performance NXP type has higher forward current specified and has benchmark low VF PMEG3010AESB, PMEG6010ESB, low VF Schottky Rectifier Improved performance 30 / 40 / 60 V, 1A Schottky rectifier in DSN1006-2 (SOD993) package Low forward voltage, VF max = 480 mV @ 1 A (PMEG3010AESB) Low leakage current, IR max = 30 µA @ 60 V (PMEG6010ESB) High surge capability up to IFSM = 10 A Ideal for LED backlighting in mobile applications Diagram shows the variety of characteristics in DFN1608D-2 (SOD1608) 34 PMEG2010EPAS Features and benefits IF [ A ] IF [ A ] 0.4 0.4 low VF 60 1 0.60.6 IF [ A ] IF [ A ] 0.6 0.6 1 1.5 0.03 20 2 PMEG2005BELD PMEG2005EPK 440 PMEG3010AESA 1 PMEG6002ELD 500 0.5 880 Selected DSN Schottky rectifier In the spotlight DFN1006-2 (SOD882) 600 VR:30 V, IF: 1A (typical data) 00 VFV[FV[ V ] ] 0.2 0.30.3 0.2 DFN1608D-2 (SOD1608) 525 Forward characteristic survey of Schottkys in DSN1006-2 1 DFN2020D-3 (SOT1061D) IR max (mA) @ VR max 40 0.6 x 0.3 x 0.3 DFN2020-3 (SOT1061) VF max (mV) @ IF max 30 Size (mm) Ptot (mW) @ 1 cm² 420 types in bold represent new products DSN1006U-2 (SOD995) VR max (V) 0.2 DSN1006-2 (SOD993) Medium-power low VF Schottky rectifiers single ≥ 200 mA - Leadless DFN packages IF max (A) 20 @ IF max IF max (A) VR max (V) Package DSN0603-2 (SOD962) types in bold represent new products Diodes Schottky barrier diodes and rectifiers PMEG2010EPK shows significant VF improvement compared to the SOD523 device 35 Schottky barrier diodes and rectifiers Medium-power low VF Schottky rectifiers single ≥ 200 mA - Leaded packages Medium-power low VF Schottky rectifiers dual ≥ 200 mA 830 IR max (mA) @ VR max Optimization 480 0.05 low VF PMEG3002EJ PMEG3002AEB 40 600 0.01 low IR PMEG4002EJ PMEG4002EB 60 600 0.1 low VF PMEG6002EJ PMEG6002EB PMEG2005ET 0.2 low VF 480 0.03 low IR 430 0.15 low VF 500 0.5 low VF 470 0.1 low VF PMEG4005ET 550 1.1 low VF BAT720 430 0.2 low VF PMEG2010AET PMEG2010AEH 500 0.2 low VF PMEG2010ET PMEG2010EH 40 400 PMEG2005EH 390 30 2.0 x 1.25 x 0.95 1.7 x 1.25 x 0.7 1.7 x 1.25 x 0.95 1.6 x 1.2 x 0.55 830 PMEG2005EJ 0.07 low IR 620 1.5 low VF PMEG2005AEA 570 500 30 480 0.03 low VF 60 600 0.1 low VF 20 390 0.2 low VF 30 430 0.15 low VF 40 470 0.1 low VF PMEG3005ET PMEG3005EH PMEG3005EJ PMEG3005AEA 0.5 PMEG2005AEV PMEG4005EJ PMEG4005AEA SOT23 DFN2020-3 (SOT1061) DFN2020D-3 (SOT1061D) SOT666 Size (mm) 6.5 x 3.5 x 1.65 2.9 x 1.3 x 1.0 2.0 x 2.0 x 0.62 2.0 x 2.0 x 0.63 1.6 x 1.2 x 0.55 Ptot (mW) @ 1 cm² 1500 250 1000 1000 300 Package PMEG3002TV PMEG6002TV brb127 PMEG2005CT PMEG3005CT PMEG4005CT brb125 low VF PMEG3005AEV BAT120S brb148 PMEG3005EB PMEG4005EH SOT223 (SC-73) 0.2 PMEG2005EB 25 450 1.0 low VF PMEG4005AEV BAT120C brb149 1PS70SB20 low VF BAT120A brb150 PMEG2010EJ PMEG2010BEA PMEG2010BEV PMEG2010AEJ PMEG2010EA BAT760 PMEG2010EV BAT960 20 550 570 1.2 x 0.8 x 0.6 types in bold represent new products Diodes 420 SOD523 (SC-79) Optimization 540 SOT666 IR max (mA) @ VR max 2.6 x 1.6 x 1.1 SOD323 (SC-76) VF max (mV) @ IF max 2.9 x 1.3 x 1.0 SOD323F (SC-90) VR max (V) 2.9 x 1.5 x 1.0 SOT323 (SC-70) IF max (A) Size (mm) Ptot (mW) @ 1 cm² Package SOD123F 30 20 0.5 SOT23 VF max (mV) @ IF max 0.2 SOT457 (SC-74) VR max (V) IF max (A) Schottky barrier diodes and rectifiers 40 500 0.05 low VF PMEG4010CPA PMEG4010CPAS PMEG6010CPA PMEG6010CPAS PMEG2020CPA PMEG2020CPAS PMEG3020CPA PMEG3020CPAS brb125 1.0 540 PMEG2010AEB 0.06 low VF brb125 1 450 1 low VF 520 0.1 low IR 560 0.15 low VF 680 0.5 low VF 30 1PS74SB23 PMEG3010CEH PMEG3010ET PMEG3010EH PMEG3010EJ BAT160S low VF PMEG3010CEJ PMEG3010BEA brb148 60 PMEG3010BEV 650 PMEG3010EB 0.35 low VF BAT160C brb125 570 0.05 low IR 600 0.02 low IR PMEG4010CEH PMEG4010CEJ low VF BAT160A brb150 40 640 0.05 low VF 650 0.35 low VF 660 0.05 low IR PMEG6010CEH PMEG6010CEJ 20 660 0.2 low IR PMEG2015EH PMEG2015EJ 30 500 1 low VF PMEG3015EH PMEG3015EJ 10 460 3 low VF PMEG1020EH PMEG1020EJ PMEG1020EA 20 525 0.2 low VF PMEG2020EH PMEG2020EJ PMEG2020AEA 30 620 1 low VF PMEG3020EH PMEG3020EJ 10 530 3 low VF PMEG1030EH PMEG1030EJ 60 1.5 2 In the spotlight 3 36 PMEG4010ET PMEG4010EH PMEG4010EJ PMEG4010BEA PMEG4010BEV PMEG6010AED Schottky Rectifier in SOD123F and SOD323F Broad portfolio base of 36 types, 20 / 60 V, 0.2 - 3 A Optimized either for low VF or low IR 20 420 1.0 low VF 30 440 2.0 low VF 2.0 PMEG2015EA PMEG2015EV brb125 PMEG3015EV PMEG1020EV Low VF (MEGA) Schottky rectifier nomenclature P PAS = DFN2020D-3 (SOT1061D) PD = CFP15 (SOT1289) PK = DFN1608D-2 (SOD1608) R = SOD123W SA A = DSN1006U-2 (SOD995) SB = DSN1006-2 (SOD993) SF = DSN0603-2 (SOD962) T = SOT23 V = SOT666 High surge capability up to 10 A High thermal capability due to flat-lead design AEC-Q101 qualified Ideal for DC/DC conversion, free-wheeling, reverse polarity protection 37 Schottky barrier diodes and rectifiers Schottky barrier diodes and rectifiers General-purpose Schottky diodes ≤ 250 mA SOD80C (MiniMelf) SOD68 (DO-34) SOT23 SOT143B SOD123F SOT323 (SC-70) SOT363 (SC-88) SOD323F (SC-90) SOD323 (SC-76) SOT666 SOD523 (SC-79) DFN1006-2 (SOD882)/ DFN1006-3 (SOT883) Size (mm) 3.5 x 1.5 x 1.5 3.04 x 1.6 x 0.55 2.9 x 1.3 x 1.0 2.9 x 1.3 x 1.0 2.6 x 1.6 x 1.1 2.0 x 1.25 x 0.95 2.0 x 1.25 x 0.95 1.7 x 1.25 x 0.7 1.7 x 1.25 x 0.95 1.6 x 1.2 x 0.55 1.2 x 0.8 x 0.6 1.0 x 0.6 x 0.48 Ptot (mW) 300 500 250 250 830 250 300 550 400 300 500 250 BAS70H BAS70W 1PS79SB70 BAS70L RB751V40 RB751S40 RB751CS40 1PS76SB40 1PS79SB40 BAS40L 70 750 0.1 @ VR (V) IR max (μA) @ IF (mA) 10 50 single BAS70 dual series BAS70-04 BAS70-04W dual c.c. BAS70-05 BAS70-05W dual c.a. BAS70-06 dual isolated 1PS76SB70 BAS70-06W BAS70-07 BAS70-07S BAS70-07V triple isolated BAS70VV quad 2x series 370 120 40 500 1 0.5 10 1 30 BAS70XY single 30 single BAS40 dual series BAS40-04 BAS40-04W dual c.c. BAS40-05 BAS40-05W dual c.a. BAS40-06 dual isolated 300 10 30 10 10 2 BAS40W BAS40-06W BAS40-07 BAS40-07V quad c.c./c.c. 1PS88SB48 quad 2x series BAS40XY 1PS79SB31 25 BAT754 dual series BAT754S dual c.c. BAT754C dual c.a. BAT754A triple isolated BAT754L single 30 400 10 2 BAS40-05V single single 340 BAS40H 25 BAS85 BAT85 BAT54 BAT54H BAT54W dual series BAT54S BAT54SW dual c.c. BAT54C BAT54CW dual c.a. BAT54A BAT54AW dual isolated BAT54J 1PS76SB10 BAT74 BAT74S BAT74V quad c.c./c.c. BAT54CV BAT54XY 500 200 30 10 single RB521S30 RB521CS30L 600 200 1 10 single RB520S30 RB520CS30L single 15 30 360 10 0.5 25 dual series BAT721S dual c.c. BAT721C dual c.a. BAT721A single 1PS79SB30 BAT854W dual series BAT854SW dual c.c. BAT854CW 420 30 0.5 25 50 450 10 5 40 single 100 850 250 4 75 single dual c.a. Dual isolated Triple isolated Quad c.c./c.c. Quad 2x series Low-capacitance Schottky diodes brb122 brb124 brb125 brb126 brb127 brb129 brb130 brb131 4 brb123 VF max (mV) Dual c.a. BAT46WJ 450 @ IF (mA) Dual c.c. BAT46WH VR max (V) Dual series BAT86 IF max (mA) Single BAT854AW BAS86 1 1 @ VR = 0 V 10 1PS76SB21 Cd max (pF) 300 BAT721 single 250 SOT23 SOT323 (SC-70) SOT363 (SC-88) SOD323 (SC-76) SOT666 SOD523 (SC-79) DFN1006-2 (SOD882) Size (mm) 2.9 x 1.3 x 1.0 2.0 x 1.25 x 0.95 2.0 x 1.25 x 0.95 1.7 x 1.25 x 0.95 1.6 x 1.2 x 0.55 1.2 x 0.8 x 0.6 1.0 x 0.6 x 0.48 Ptot (mW) 250 250 300 400 300 500 250 single BAT17 Package dual series brb128 1PS76SB17 triple isolated single 30 15 1) 340 1 1 1PS79SB17 1PS66SB17 PMBD353 PMBD354 1) 1PS70SB82 triple isolated 38 BAT54L BAT54VV quad 2x series 40 1PS79SB10 BAT54CM triple isolated 200 Diodes 70 VF max (mV) VR max (V) IF max (mA) Package 1PS10SB82 1PS88SB82 dual series 1PS70SB84 dual c.c. 1PS70SB85 dual c.a. 1PS70SB86 1PS66SB82 Diodes have matched capacitance 39 Zener diodes General-purpose Zener diodes Zener diodes specifications Japanese spec (PZU, PDZ) - 3.3~24 60 3.6~75 500 2.1~36 Configuration Series 1N47xxA series C - Differences in Zener specifications Note VZ tolerance VZ nom (V) PZSM (W) IF max (mA) y= Europe About 2% 4.8 x 2.6 x 0.81 Special 2.4~75 B, C NZX series brb118 400 40 2.4~75 C Europe Single 400 BZX79 series SOT223 (SC-73) 3 1 1000 SOD27 (DO-35) 4.25 x 1.85 x 0.56 Europe Ptot (mW) BZV85 series Single 40 Size (mm) SOD66 (DO-41) Single brb118 250 Package BZV90 series 6.5 x 3.5 x 1.65 1500 2, 4 006aab234 SOT89 (SC-62) 250 40 2.4~75 C Europe Single 1 3 BZV49 series 4.5 x 2.5 x 1.5 1000 2 sym096 SOD80C (MiniMelf) 250 40 2.4~75 B, C Europe Single BZV55 series 3.5 x 1.5 x 1.5 400 brb118 B, C 200 40 2.4~75 Dual c.a. BZB84 series Europe SOT23 brb120 A, B, C 2.9 x 1.3 x 1.0 BZX84 series 250 Single 250 30 5~6.8 0.2 V Ave - 3.0~30 About 2.5% Special 250 brb119 NZH series 2.4~75 B, C 2.6 x 1.6 x 1.1 brb118 Europe 5 40 10 B2 Japan BZT52H series SOT353 (SC-88A) 4 Dual isolated 2.0 x 1.25 x 0.95 PZU10DB2 series 1 2 830 300 3 006aab219 SOT323 (SC-70) 200 40 2.4~15 C Europe Dual c.a. BZB784 series 2.0 x 1.25 x 0.95 350 y= 100 C Europe Back-to-back 200 250 BZB100A mse211 40 2.4~36 B2 Japan 40 2.4~75 B, C Europe SOD323 (SC-76) PDZ-B series Single 1.7 x 1.25 x 0.95 300 BZX384 series brb118 200 40 2.4~36 B, B1, B2, B3 Japan 200 60 100 C Europe 200 40 2.4~36 B, B1, B2, B3 Japan PZUxBA series BZX100A Single SOD323F (SC-90) PZUxB series 1.7 x 1.25 x 0.7 550 brb118 250 40 2.4~75 B, C Europe BZX84J series SOT663 200 40 2.4~15 C Europe Dual c.a. BZB984 series 1.6 x 1.2 x 0.55 350 brb120 SOD523 (SC-79) 200 40 2.4~75 B, C Europe Single BZX585 series 1.2 x 0.8 x 0.6 300 brb118 200 2.4~75 B, C Europe 2.4~36 B, B2 Japan 40 BZX884 series DFN1006-2 (SOD882) Single 1.0 x 0.6 x 0.48 brb118 250 PZUxBL series SOD323F 250 40 2.4~30 B Europe Single TDZxJ series 1.7 x 1.25 x 0.7 brb118 Notes: Japan: B selection: app. 5% Vz tolerance, B1, B2, B3 selections: app. 2% Vz tolerance in sequential intervals Europe: A selection: app. 1% Vz tolerance, B selection: app. 2% Vz tolerance, C selection: app. 5% Vz tolerance; the selections are in overlapping intervals 40 Ave: low-voltage avalanche regulator diodes Dual c.a.: dual common anode 500 B2-series ± 2% ± 2% ± 2% VZ (V) VZ (V) VZ (V) VZ (V) B3-series PZU2.4y 2.3 - 2.6 - - - PZU2.7y 2.5 - 2.9 2.5 - 2.75 2.65 - 2.9 - PZU3.0y 2.8 - 3.2 2.8 - 3.05 2.95 - 3.2 - PZU3.3y 3.1 - 3.5 3.1 - 3.35 3.25 - 3.5 - PZU3.6y 3.4 - 3.8 3.4 - 3.65 3.55 - 3.8 - PZU3.9y 3.7 - 4.1 3.7 - 3.97 3.87 - 4.1 - PZU4.3y 4.01 - 4.48 4.01 - 4.21 4.15 - 4.34 4.28 - 4.48 PZU4.7y 4.42 - 4.9 4.42 - 4.61 4.55 - 4.75 4.69 - 4.9 PZU5.1y 4.84 - 5.37 4.84 - 5.04 4.98 - 5.2 5.14 - 5.37 PZU5.6y 5.31 - 5.92 5.31 - 5.55 5.49 - 5.73 5.67 - 5.92 PZU6.2y 5.86 - 6.53 5.86 - 6.12 6.06 - 6.33 6.26 - 6.53 PZU6.8y 6.47 - 7.14 6.47 - 6.73 6.65 - 6.93 6.86 - 7.14 PZU7.5y 7.06 - 7.84 7.06 - 7.36 7.28 - 7.6 7.52 - 7.84 PZU8.2y 7.76 - 8.64 7.76 - 8.1 8.02 - 8.36 8.28 - 8.64 PZU9.1y 8.56 - 9.55 8.56 - 8.93 8.85 - 9.23 9.15 - 9.55 PZU10y 9.45 - 10.55 9.45 - 9.87 9.77 - 10.21 10.11 - 10.55 PZU11y 10.44 - 11.56 10.44 - 10.88 10.76 - 11.22 11.1 - 11.56 PZU12y 11.42 - 12.6 11.42 - 11.9 11.74 - 12.24 12.08 - 12.6 PZU13y 12.47 - 13.96 12.47 - 13.03 12.91 - 13.49 13.37 - 13.96 PZU14y - - 13.7 - 14.3 - PZU15y 13.84 - 15.52 13.84 - 14.46 14.34 - 14.98 14.85 - 15.52 PZU16y 15.37 - 17.09 15.37 - 16.01 15.85 - 16.51 16.35 - 17.09 PZU18y 16.94 - 19.03 16.94 - 17.7 17.56 - 18.35 18.21 - 19.03 PZU20y 18.86 - 21.08 18.86 - 19.7 19.52 - 20.39 20.21 - 21.08 PZU22y 20.88 - 23.17 20.88 - 21.77 21.54 - 22.47 22.23 - 23.17 PZU24y 22.93 - 25.57 22.93 - 23.96 23.72 - 24.78 24.54 - 25.57 PZU27y 25.1 - 28.9 - - - PZU30y 28 - 32 - - - PZU33y 31 - 35 - - - PZU36y 34 - 38 - - - C-series B-series A-series ±5% ±2% ±1% NZX2V1B 2.0 - 2.2 VZ (V) VZ (V) VZ (V) NZX6V2D 6.1 - 6.4 NZX14C 13.8 - 14.3 VZ (V) VZ (V) VZ (V) NZX2V4A 2.3 - 2.5 NZX6V2E 6.3 - 6.6 NZX15A 14.1 - 14.7 BZX84-y2V4 2.2 - 2.6 2.35 - 2.45 2.37 - 2.43 NZX2V4B 2.4 - 2.6 NZX6V8A 6.4 - 6.7 NZX15B 14.5 - 15.1 BZX84-y2V7 2.5 - 2.9 2.65 - 2.75 2.67 - 2.73 NZX2V7A 2.5 - 2.7 NZX6V8B 6.6 - 6.9 NZX15C 14.9 - 15.5 BZX84-y3V0 2.8 - 3.2 2.94 - 3.06 2.97 - 3.03 NZX2V7B 2.6 - 2.8 NZX6V8C 6.7 - 7 NZX15X 14.35 - 15.09 BZX84-y3V3 3.1 - 3.5 3.23 - 3.37 3.26 - 3.34 NZX2V7C 2.7 - 2.9 NZX6V8D 6.9 - 7.2 NZX16A 15.3 - 15.9 BZX84-y3V6 3.4 - 3.8 3.53 - 3.67 3.56 - 3.64 NZX3V0A 2.8 - 3 NZX7V5A 7 - 7.3 NZX16B 15.7 - 16.5 BZX84-y3V9 3.7 - 4.1 3.82 - 3.98 3.86 - 3.94 NZX3V0B 2.9 - 3.1 NZX7V5B 7.2 - 7.6 NZX16C 16.3 - 17.1 BZX84-y4V3 4 - 4.6 4.21 - 4.39 4.25 - 4.35 NZX3V0C 3 - 3.2 NZX7V5C 7.3 - 7.7 NZX18A 16.9 - 17.7 BZX84-y4V7 4.4 - 5 4.61 - 4.79 4.65 - 4.75 NZX3V3A 3.1 - 3.3 NZX7V5D 7.5 - 7.9 NZX18B 17.5 - 18.3 BZX84-y5V1 4.8 - 5.4 5 - 5.2 5.04 - 5.16 NZX3V3B 3.2 - 3.4 NZX7V5X 7.07 - 7.45 NZX18C 18.1 - 19 BZX84-y5V6 5.2 - 6 5.49 - 5.71 5.54 - 5.66 BZX84-y6V2 5.8 - 6.6 6.08 - 6.32 6.13 - 6.27 NZX3V3C 3.3 - 3.5 NZX8V2A 7.7 - 8.1 NZX20A 18.8 - 19.7 BZX84-y6V8 6.4 - 7.2 6.66 - 6.94 6.73 - 6.87 NZX3V6A 3.4 - 3.6 NZX8V2B 7.9 - 8.3 NZX20B 19.5 - 20.4 BZX84-y7V5 7 - 7.9 7.35 - 7.65 7.42 - 7.58 NZX3V6B 3.5 - 3.7 NZX8V2C 8.1 - 8.5 NZX20C 20.2 - 21.2 BZX84-y8V2 7.7 - 8.7 8.04 - 8.36 8.11 - 8.29 NZX3V6C 3.6 - 3.8 NZX8V2D 8.3 - 8.7 NZX22A 20.9 - 21.9 BZX84-y9V1 8.5 - 9.6 8.92 - 9.28 9 - 9.2 NZX3V9A 3.7 - 3.9 NZX9V1A 8.5 - 8.9 NZX22B 21.6 - 22.6 BZX84-y10 9.4 - 10.6 9.8 - 10.2 9.9 - 10.1 NZX3V9B 3.8 - 4 NZX9V1B 8.7 - 9.1 NZX22C 22.3 - 23.3 BZX84-y11 10.4 - 11.6 10.8 - 11.2 10.8 - 11.11 NZX3V9C 3.9 - 4.1 NZX9V1C 8.9 - 9.3 NZX24A 22.9 - 24 BZX84-y12 11.4 - 12.7 11.8 - 12.2 11.88 - 12.12 NZX4V3A 4 - 4.2 NZX9V1D 9.1 - 9.5 NZX24B 23.6 - 24.7 BZX84-y13 12.4 - 14.1 12.7 - 13.3 12.87 - 13.13 BZX84-y15 13.8 - 15.6 14.7 - 15.3 14.85 - 15.15 BZX84-y16 15.3 - 17.1 15.7 - 16.3 15.84 - 16.16 BZX84-y18 16.8 - 19.1 17.6 - 18.4 17.82 - 18.18 BZX84-y20 18.8 - 21.2 19.6 - 20.4 19.8 - 20.2 BZX84-y22 20.8 - 23.3 21.6 - 22.4 21.78 - 22.22 BZX84-y24 22.8 - 25.6 23.5 - 24.5 23.76 - 24.24 BZX84-y27 25.1 - 28.9 26.5 - 27.5 26.73 - 27.27 BZX84-y30 28 - 32 29.4 - 30.6 BZX84-y33 31 - 35 BZX84-y36 BZX84-y39 brb120 30 B1-series ± 5% NZX-series in SOD27 European spec (BZV, BZX, BZB, 1N47) SOD123F Single 40 200 PLVA600A series B-series Diodes Zener diodes NZX4V3B 4.1 - 4.3 NZX9V1E 9.3 - 9.7 NZX24C 24.3 - 25.5 NZX4V3C 4.2 - 4.4 NZX10A 9.5 - 9.9 NZX24X 22.61 - 23.77 NZX4V3D 4.3 - 4.5 NZX10B 9.7 - 10.1 NZX27A 25.2 - 26.6 NZX4V7A 4.4 - 4.6 NZX10C 9.9 - 10.3 NZX27B 26.2 - 27.6 NZX4V7B 4.5 - 4.7 NZX10D 10.2 - 10.6 NZX27C 27.2 - 28.6 NZX4V7C 4.6 - 4.8 NZX11A 10.4 - 10.8 NZX27X 26.99 - 28.39 NZX4V7D 4.7 - 4.9 NZX11B 10.7 - 11.1 NZX30A 28.2 - 29.6 NZX5V1A 4.8 - 5 NZX11C 10.9 - 11.3 NZX30B 29.2 - 30.6 29.70 - 30.30 NZX5V1B 4.9 - 5.1 NZX11D 11.1 - 11.6 NZX30C 30.2 - 31.6 32.3 - 33.7 32.67 - 33.33 NZX5V1C 5 - 5.2 NZX12A 11.4 - 11.9 NZX30X 29.02 - 30.51 34 - 38 35.3 - 36.7 35.64 - 36.36 NZX5V1D 5.1 - 5.3 NZX12B 11.6 - 12.1 NZX33A 31.2 - 32.6 37 - 41 38.2 - 39.8 38.61 - 39.39 NZX5V6A 5.2 - 5.5 NZX12C 11.9 - 12.4 NZX33B 32.2 - 33.6 BZX84-y43 40 - 46 42.1 - 43.9 42.57 - 43.43 NZX5V6B 5.3 - 5.6 NZX12D 12.2 - 12.7 NZX33C 33.2 - 34.5 BZX84-y47 44 - 50 46.1 - 47.9 - NZX5V6C 5.4 - 5.7 NZX12X 11.44 - 12.03 NZX36A 34.2 - 35.7 BZX84-y51 48 - 54 50 - 52 50.49 - 51.51 NZX5V6D 5.5 - 5.8 NZX13A 12.4 - 12.9 NZX36B 35.3 - 36.8 BZX84-y56 52 - 60 54.9 - 57.1 - NZX5V6E 5.6 - 5.9 NZX13B 12.6 - 13.1 NZX36C 36.4 - 38 BZX84-y62 58 - 66 60.8 - 63.2 - NZX6V2A 5.7 - 6 NZX13C 12.9 - 13.4 NZX36X 35.36 - 37.19 BZX84-y68 64 - 72 66.6 - 69.4 - NZX6V2B 5.8 - 6.1 NZX14A 13.2 - 13.7 BZX84-y75 70 - 79 73.5 - 76.5 74.25 - 75.75 NZX6V2C 6 - 6.3 NZX14B 13.5 - 14 41 Switching diodes Switching diodes General-purpose high-speed switching diodes < 90 V SOD80C (MiniMelf) SOT23 types in bold represent new products SOT323 (SC-70) SOT143B SOT363 (SC-88) DFN1010D-3 (SOT1215) General-purpose switching diodes ≥ 100 V DFN1006-3 (SOT883) SOD80C SOT457 (MiniMelf) (SC-74) 2.0 x 1.25 x 0.95 1.1 x 1.0 x 0.37 1.0 x 0.6 x 0.48 500 250 250 200 300 540 250 50 100 50 50 1000 70 SOT363 (SC-88) 2.0 x 1.25 x 0.95 2.0 x 1.25 x 0.95 1.7 x 1.25 x 0.95 1.7 x 1.25 x 0.7 1.2 x 0.8 x 0.6 300 400 550 500 100 1 100 100 100 50 BAS21J BAS521 3.5 x 1.5 x 1.5 2.9 x 1.5 x 1.0 2.9 x 1.3 x 1.0 2.9 x 1.3 x 1.0 2.6 x 1.6 x 1.1 2.0 x 1.25 x 0.95 Ptot (mW) 300 500 250 250 830 350 SOD323 SOD323F SOD523 (SC-76) (SC-90) (SC-79) BAS19 bra048 BAV74 1 SOT353 (SC-88A) Size (mm) 4 BAV102 bra046 70 SOT323 (SC-70) 150 4 1 100 100 150 Diodes 1 trr max (ns) 2.0 x 1.25 x 0.95 IR max (nA) 2.9 x 1.3 x 1.0 @ VR (V) 2.9 x 1.3 x 1.0 VF max (V) 3.5 x 1.5 x 1.5 Ptot (mW) @ IF (mA) Size (mm) BAL74 50 SOT143B SOD123F Package VR max (V) trr max (ns) @ VR (V) IR max (nA) @ IF (mA) VF max (V) VR max (V) Package SOT23 types in bold represent new products bra036 50 BAL99 BAS20 bra048 50 75 1000 75 4 150 BAS28 BAV103 50 BAS21H BAS321 bra036 bra037 1 100 5000 75 4 BAS21 BAS32L BAS21W bra048 bra036 BAV23 1PS300 bra037 5 bra143 4 BAS21PG 1 80 1 50 500 80 4 2 3 aaa-018440 1PS301 bra046 ≥ 200 1 100 100 200 50 BAV23A BAS21AW bra143 1PS302 BAV23C bra041 bra046 BAW56 BAW56QA BAW56W BAW56M BAV23S bra143 BAS21SW bra041 90 1 50 500 80 4 BAW56S BAS21AVD bra038 BAV756S General-purpose, high-speed switching diodes 100 V BAS21VD bra036 types in bold represent new products SOT323 SOT363 SOD323 SOD323F SOD523 DFN1010D-3 DFN1006-2 DFN1006-3 DFN1006D-2 SOT23 SOD123F SOT666 (SC-70) (SC-88) (SC-76) (SC-90) (SC-79) (SOT1215) (SOD882) (SOT883) (SOD882D) 300 1.1 100 150 250 BAS101S 50 bra041 BAW101 Size (mm) 2.9 x 1.3 x 1.0 Ptot (mW) 250 2.6 x 1.6 2.0 x 1.25 2.0 x 1.25 1.7 x 1.25 1.7 x 1.25 1.6 x 1.2 1.2 x 0.8 x 1.1 x 0.95 x 0.95 x 0.95 x 0.7 x 0.55 x 0.6 830 200 300 BAS16H 400 550 BAS316 BAS16J 180 500 1.1 x 1.0 x 0.37 1.0 x 0.6 x 0.48 1.0 x 0.6 x 0.48 1.0 x 0.6 x 0.37 540 250 250 250 BAS516 BAS16L BAS16LD bra036 BAS16 bra037 BAW101S PN-rectifier BAS16QA BAS16W bra048 BAS16VY CFP3 SOD123W BAS16VV Package 4 BAV70 BAV70QA BAV70W bra046 BAV70S BAV99 BAV70M trr max (ns) 80 (@) VR (V) 500 IR max (μA) 50 (@) IF (A) 1 VF max (V) 100 VR max (V) bra038 Size (mm) 2.6 x 1.7 x 1.0 Ptot (mW) 950 BAV99QA BAV99W bra041 400 BAV99S 42 1.1 1 1 400 1800 PNS40010ER bra036 In the spotlight @ VR (V) trr max (ns) IR max (nA) @ IF (mA) VF max (V) VR max (V) Package BAS101 bra048 Dual high-speed switching diode BAS21PG in SOT353 (SC-88A) VR max = 250 V, IF max = 225 mA, dual isolated configuration Low leakage current: IR max = 100 nA High-speed switching: trr max = 50 ns Low capacitance: Cd max = 2 pF AEC-Q101 qualified 43 Switching diodes Controlled-avalanche switching diodes SOT23 SOT143B Size (mm) 2.9 x 1.3 x 1.0 2.9 x 1.3 x 1.0 Ptot (mW) 250 250 VR max (V) VF max (V) @ IF (mA) IR max (nA) @ VR max IFSM max (A) IFRM max (mA) Cd max (pF) trr max (ns) Package 60 1 200 100 9 600 2.5 6 BAS56 bra037 BAS29 bra048 90 1 200 100 10 600 35 50 ESD protection, TVS, filtering and signal conditioning BAS31 bra041 BAS35 bra143 Low-leakage current-switching diodes SOD80C (MiniMelf) SOD68 (DO-34) SOT23 types in bold represent new products SOD123F SOT323 (SC-70) SOD323 (SC-76) SOD523 (SC-79) DFN1010D-3 (SOT1215) DFN1006-3 (SOT883) DFN1006-2 (SOD882) trr max (μs) IR max (nA) @ VR max @ IF (mA) VF max (V) VR max (V) Package Size (mm) 3.5 x 1.5 x 1.5 3.04 x 1.6 x 0.55 2.9 x 1.3 x 1.0 2.6 x 1.6 x 1.1 2.0 x 1.25 x 0.95 1.7 x 1.25 x 0.95 1.2 x 0.8 x 0.6 1.1 x 1.0 x 0.37 1.0 x 0.6 x 0.48 1.0 x 0.6 x 0.48 Ptot (mW) 300 500 250 830 250 400 500 540 250 250 BAS416 BAS716 BAS116H BAS116L bra036 BAS116QA BAS116 bra048 75 1 10 5 BAV199 3 BAV199W bra041 BAW156 bra143 BAV170 bra046 125 44 1 100 1 1.5 typ BAS45AL bra036 BAS45A BAV170QA BAV170M Ultra low-capacitance ESD protection devices 49 Low-capacitance ESD protection devices 53 Standard ESD protection devices 57 Application-specific ESD and ESD/EMI solutions 59 USB 2.0 protection and filtering Common Mode Filter for USB 2.0 USB 3.x and eSATA protection and filtering Common Mode Filter for USB 3.x Common Mode Filter for video interfaces Ethernet protection HDMI and memory-card signal conditioning Video interface protection NFC antenna protection LCD/camera protection and filtering Audio interface protection and filtering Memory- and SIM-card protection and filtering Automotive high-speed network protection Automotive in-vehicle network bus line protection Transient voltage suppressor (TVS) diodes TVS TVS TVS TVS diodes for mobile applications diodes, 24 / 40 W diodes, 400 W diodes, 600 W 59 59 60 61 62 62 63 64 65 66 67 67 68 68 70 70 70 71 72 45 The best system-chip protection for high-speed data lines (USB 3.1, Type-C connector) ESD protection, TVS devices, and EMI filtering What you get when you choose NXP Solutions for wide application fields High-speed data lines General interfaces Automotive protection Supply lines A broad range of packages that simplify PCB design A quality product from an experienced, high volume supplier  NXP is strongly committed to automotive quality standards  NXP has a track record of more than 12 years in developing and producing ESD / TVS devices  NXP is the #1 in ESD protection with a high production capacity ESD protection characteristics that count CAN, LIN FlexRay BroadR-Reach SENT LVDS There are three key parameters for a perfect ESD protection device:  High robustness against ESD pulses  Low clamping / dynamic resistance – to protect the system chip  Low capacitance – to maintain excellent signal integrity in high-speed interfaces Robustness (surge levels) Automotive IVN protection Some applications require good performance in only one or two of these areas. For the latest interfaces with the highest data rates, optimum performance in all three parameters is key. Until recently, improving one the these key parameters had a negative impact on the others. Addressing this challenge, NXP has developed a new ESD technology (TrEOS Protection) that delivers benchmark performance in all three key parameters. Supply lines Keypads buttons Complexity of ESD protection USB 2.0 NFC USB 3.0 System protect (clamping) Signal integrity (capacitance) Portfolio Overview Diodes Data Rate (Mbit/sec) 0 .03 Audio .05 .13 2 RS232 12 IEEE 1284 RS485 Data Protocols CAN/LIN PTVS (all series) 25 125 320 400 480 800 USB 2.0 IEEE 1394b 3.000 5.000 10.000 Extremely low clamping voltage USB 1.1 Video 10/100 Ethernet IEEE 1394a LCDs  Low capacitance down to 0.1 pF  High robustness up to 9A, 8/20 µs  Packages optimized for communications interfaces 1GB Ethernet SATA Absorbing highest ESD pulses THE key for reliable system protection HDMI 2.0/ USB 3.1 High surge ratings and strongest protection PESDxS-family ESD protection, TVS, filtering and signal conditioning     USB3 / Type C USB2 / Type C USB Vbus / charger port / Type C NFC antenna Wireless charging Audio speaker Battery contact, Vbat Keys / buttons SIM, SD3 Audio PESDxL-family PESDxV-family TrEOS Protection devices PESDxU-family PESDxIVN PESD1CAN PESD1LIN ESD protection for automotive in-vehicle networks Type VRWM (V) Uni- or bidirectional Cd typ (pF) ESD rating max (kV) (Ω) Rdyn TLP (Ω) Number of protected lines Package Size (mm) PRTR-family PUSB3FR4 ESD protection 3.3 uni 0.29 15 0.27 4 DFN2510A-10 2.5 x 1.0 x 0.48 PUSB3FR6 ESD protection 3.3 uni 0.35 15 0.29 6 DFN2111-7 2.1 x 1.1 x 0.48 PESDxX1F-family PUSB3AB4 ESD protection 3.3 bi 0.17 15 0.4 4 DFN2510A-10 2.5 x 1.0 x 0.48 IP3319CX6 PUSB3AB6 ESD protection 3.3 bi 0.15 15 0.4 6 DFN2111-7 2.1 x 1.1 x 0.48 PCMF1USB3S Common Mode Filter with ESD protection 5 uni 0.3 15 0.14 2 WLCSP5 0.8 x 1.2 x 0.5 PCMF2USB3S Common Mode Filter with ESD protection 5 uni 0.3 15 0.14 4 WLCSP10 1.6 x 1.2 x 0.5 PCMF3USB3S Common Mode Filter with ESD protection 5 uni 0.3 15 0.14 6 WLCSP15 2.4 x 1.2 x 0.5 PESD3V3C1BSF ESD protection 3.3 bi 0.2 20 0.23 1 DSN0603-2 0.6 x 0.3 x 0.3 PESD5V0R1BSF ESD protection 5 bi 0.1 10 0.45 1 DSN0603-2 0.6 x 0.3 x 0.3 PCMFxUSB3S PCMFxHDMI25 PESDxUSB35 Low pass and common mode filters with industry leading bandwidth and integrated ESD protection PUSB3AB6/FR6 PUSB3FR4 PUSB3AB4 Optimized for signal integrity, ESD robustness, and system protection PESD5V0C1USF PESD5V0C1BSF PESD5V0H1BSF 46 device Ultra-low capacitance ESD protection for high-speed interfaces PESD5V0H1BSF ESD protection 5 bi 0.15 15 0.25 1 DSN0603-2 0.6 x 0.3 x 0.3 PESD5V0C1BSF ESD protection 5 bi 0.2 20 0.23 1 DSN0603-2 0.6 x 0.3 x 0.3 PESD5V0C1USF ESD protection 5 uni 0.45 20 0.1 1 DSN0603-2 0.6 x 0.3 x 0.3 47 Ultra low-capacitance ESD protection devices ESD rating Type Package 5 0.45 0.5 20 PESD5V0C1USF DSN0603-2 (SOD962) 5 0.6 0.75 10 PESD5V0F1USF 0.95 1.15 8 PESD5V0X1ULD 1.55 1.75 15 PESD5V0X1UALD 0.83 0.98 8 5 1 16 5 L 2 mse209 0.95 1.15 8 PESD5V0X1UB 1.55 1.75 15 PESD5V0X1UAB L NUP1301U 3 DSN0402-2 (SOD992) 80 0.6 0.75 30 1 DSN0402-2 package outline and 2 L L Single package 0.4 x 0.2 x 0.12 mm b (2x) 1 0.3 0.4 8 PESD5V0F1BSH 2 3.3 0.2 0.25 20 PESD3V3C1BSF 0.1 0.15 10 PESD5V0R1BSF 0.15 0.2 15 PESD5V0H1BSF 0.2 0.25 20 PESD5V0C1BSF 5.5 0.25 0.3 10 3.3 – 1.1 5.0 – 1.1 18 0.28 0.45 24 0.25 0.4 5 0.4 0.55 3.3 1.3 1.6 9 5.5 0.4 0.55 10 PESD5V0F1BL 0.49 0.6 8 PESD5V0X1BCL 0.85 0.95 15 PESD5V0X1BCAL 0.9 1.3 9 PESD5V0X1BL b (2x) A e 0.56 0.16 0.20 (2x) EA 0 0.23 (2x) 0.38 0.33 D E 0 0.36 0.5 mm scale 0 1 nds solder paste Dimensions in mm Dimensions (mm are the original dimensions) Unit A Dimensions (mm are the original dimensions) 14-08-22 14-08-25 Unit mm A max 0.14 nom 0.12 min 0.10 Outline version SOD992 E max E D L0.14 b 0.42e mm nom 0.12 0.40 0.42 0.22 min 0.12 0.100.170.38 0.40 0.38 0.20 0.18 0.11 0.10 Outline version IEC 0.16 0.25 0.15 D L 0.22 0.20 0.18 0.12 0.11 0.10 b scale 5 e 0.17 0.16 0.25 0.15 sod992_po References References JEDEC 0.5 mm IEC JEITA JEDEC sod992_po European JEITA projection Issue date 13-10-28 13-11-01 SOD992 European projection 13-10-28 13-11-01 Ultra-low capacitance in DSN0402 Type PESD5V0F1BSH 48 2.0 x 1.25 x 0.95 DSN0402-2 (SOD992) 0.4 x 0.2 x 0.12 PESD5V0F1BSF 10 10 DSN0603-2 (SOD962) 0.6 x 0.3 x 0.3 PESD3V3X1BCSF PESD5V0X1BCSF PESD18VF1BSF mse211 PESD24VF1BSF PESD5V0F1BLD DFN1006D-2 (SOD882D) 1.0 x 0.6 x 0.37 PESD5V0F1BRLD PESD3V3X1BL 18 0.35 0.5 10 PESD18VF1BL 24 0.3 0.45 10 PESD24VF1BL DFN1006-2 (SOD882) 1.0 x 0.6 x 0.48 Issue date Vrwm Config Cd typ Cd max Vesd 5V Bi 0.25 pF 0.3 pF 8 kV [1] according to IEC 61000-4-2 (contact discharge) In the spotlight solder resist 1.2 x 0.8 x 0.6 2.9 x 1.3 x 1.0 PESD5V0F1BRSF 20 D d area SOT323 NUP1301 5 5 0.18 (2x) SOD523 (SC-79) 1.0 x 0.6 x 0.48 e reflow soldering footprint 0.66 DFN1006-2 (SOD882) 1.0 x 0.6 x 0.37 SOT23 2 006aaa763 1 PESD16VX1UL DFN1006D-2 (SOD882D) 0.6 x 0.3 x 0.3 ESD protection, TVS, filtering and signal conditioning Configuration Cline max (pF) Ultra-small dimensions: 0.4 x 0.2 mm (01005 inch) 45% less package area compared to DSN0603-2 Only 120 µm in height Coated sidewalls enable easier soldering Polarity marking Halogen and antimony free; RoHS compliant Cline typ (pF)       types in bold represent new products VRWM (V) DSN0402-2 (SOD992) features and benefits Bidirectional Unidirectional Number of protected lines [1] Reliable ESD protection on minimal space max (kV) Ultra low-capacitance ESD protection devices – Part 1 Size (mm) Tiny but mighty – DSN0402 Ultra low-capacitance ESD protection in DSN0603-2: PESD5V0H1BSF Bidirectional protection for one data line in DSN0603-2 Ultra-low line capacitance of 0.15 pF Ultra-low clamping Minimized capacitance variation over voltage High ESD robustness = 15 kV mse211 Ultra-small package DSN0603-2 (0.6 x 0.3 x 0.3 mm) 49 Ultra low-capacitance ESD protection devices DFN1006B-3 (SOT883B) PESD5V0X2UMB 1.0 x 0.6 x 0.37 6 5 4 1 2 3 SOT457 (SC-74) IP4220CZ6 0.5 0.65 10 Size (mm) types in bold represent new products Package Type Cline max (pF) Cline typ (pF) VRWM (V) Bidirectional Unidirectional Size (mm) Package Type Configuration [1] Configuration max (kV) Ultra low-capacitance ESD protection devices – Part 3 Number of protected lines ESD rating Cline max (pF) Cline typ (pF) VRWM (V) Bidirectional Unidirectional Number of protected lines types in bold represent new products [1] max (kV) Ultra low-capacitance ESD protection devices – Part 2 ESD rating Ultra low-capacitance ESD protection devices 2.9 x 1.5 x 1.0 001aac379 DFN1006-3 (SOT883) PESD5V0X2UM 1 1.0 x 0.6 x 0.48 3 2 brb051 6 5 1 2 DFN1410-6 (SOT886) 4 DFN1006B-3 (SOT883B) PESD5V0X2UAMB IP4221CZ6-S 1.0 x 0.6 x 0.37 1.45 x 1.0 x 0.48 3 001aag273 g g273 5 0.8 0.95 15 1 DFN1006-3 (SOT883) PESD5V0X2UAM - 8 1.0 x 0.6 x 0.48 6 5 1 2 DFN1010-6 (SOT891) 4 IP4221CZ6-XS SOT663 1.0 x 1.0 x 0.48 3 001aag273 g g273 2 PESD5V0X1BQ 1 1.6 x 1.2 x 0.55 3 0.9 1.3 9 2 SOT23 6 5 4 1 2 3 SOT457 (SC-74) 001aaa490 PESD5V0X1BT 2.9 x 1.3 x 1.0 PRTR5V0U4D 2.9 x 1.5 x 1.0 ESD protection, TVS, filtering and signal conditioning 1 001aag273 g g273 1 1.5 8 4 PRTR5V0U2X 0 5.5 SOT143B DFN2110-9 (SOT1178) 2.9 x 1.3 x 1.0 IP4285CZ9-TBB 0 5.5 1.8 - 12 1 1.5 8 2.1 x 1.0 x 0.48 PRTR5V0U2AX I/O1 1 6 I/O1 GND 2 5 VBUS I/O2 3 4 I/O2 DFN1410-6 (SOT886) PRTR5V0U2F 1.45 x 1.0 x 0.48 1 2 4 SOT457 (SC-74) 5 brb182 0.8 [1] - PUSB2X4D 12 according to IEC 61000-4-5 (contact discharge) 3, 8 2.9 x 1.5 x 1.0 001aai619 SOT363 (SC-88) In the spotlight Lowest capacitance ESD protection in DFN1006B-3: PESD5V0X2UAMB PUSB2X4Y Unidirectional double protection for two signal lines Ultra-low line capacitance of 0.8 pF Very low package height of 0.37 mm typ High ESD robustness of 15 kV AEC-Q101 qualified 1 3 2 brb051 1 0.6 Ideal for high-speed data lines, portable electronics, and communication systems - 2 4 [1] DFN2510A-10 (SOT1176) 5 8 IP4283CZ10-TBR 3, 8 50 2.0 x 1.25 x 0.95 2.5 x 1.0 x 0.48 001aai619 according to IEC 61000-4-5 (contact discharge) 51 Low-capacitance ESD protection devices 0.3 [1] PESD3V3L1UL DFN1006-2 (SOD882) Size (mm) 30 Package 45 Type IR max (µA) @ VRWM 40 types in bold represent new products Configuration ESD rating 34 [2] PPP 3.3 max (W) Cline max (pF) Capacitance < 0.2 pF Cline typ (pF) Very small DFN2510A-10 package (2.5 x 1.0 x 0.48 mm) VRWM (V) Lowest clamping in the 0.2 pF class Bidirectional Number of protected lines Protects four very fast data lines of sensitive system chips max (kV) Low-capacitance ESD protection devices – Part 1 PUSB3AB4 - ESD protection in very small DFN2510A-10 package for USB3.1 @ 10 Gbps and Thunderbolt Unidirectional In the spotlight Ultra low-capacitance ESD protection devices 1.0 x 0.6 x 0.48 5 25 30 42 26 0.1 PESD5V0L1UL 5 25 30 42 26 0.1 PESD5V0L1ULD 3.3 34 40 45 30 0.3 PESD3V3L1UB 5 25 30 42 26 0.1 PESD5V0L1UB DFN1006D-2 (SOD882D) Size (mm) 1.0 x 0.6 x 0.37 SOD523 (SC-79) 1.2 x 0.8 x 0.6 SOD323 (SC-76) 1 5.5 0.5 - 10 2 4 5 IP4294CZ10-TBR 5 30 42 26 0.1 1 3, 8 4 25 PESD5V0L1UA 1 0 0 2 mse209 001aai619 DSN0603-2 (SOD962) PUSB3F96 DFN2510A-10 (SOT1176) 1.7 x 1.25 x 0.95 5 12 15 10 30 0.1 PESD5V0L1USF 3.3 2.6 3.1 - 9 0.1 (@ 3 V) PESD3V3U1UL 5 2 2.6 - 9 0.1 PESD5V0U1UL 3.3 2.6 3.1 - 9 0.1 (@ 3 V) PESD3V3U1UB 5 2 2.6 - 9 0.1 PESD5V0U1UB 3.3 2.6 3.1 - 9 0.1 (@ 3 V) PESD3V3U1UA 0.6 x 0.3 x 0.3 2.5 x 1.0 x 0.48 1 2 4 5 3.3 0.27 PUSB3FR4 - 15 0 3 3.3 0.17 0.1 1.0 x 0.6 x 0.48 PUSB3AB4 0.2 1 6 2 5 3 4 PESD5V0F5UF 4 5 0.55 0.7 8 SOD523 (SC-79) 1.2 x 0.8 x 0.6 DFN1410-6 (SOT886) 1.45 x 1.0 x 0.48 006aaa159 5 DFN1006-2 (SOD882) 3,8 ESD protection, TVS, filtering and signal conditioning Package types in bold represent new products Type Configuration IR max (µA) @ VRWM ESD rating Cline max (pF) Cline typ (pF) VRWM (V) Bidirectional Unidirectional Number of protected lines [1] max (kV) Ultra low-capacitance ESD protection devices – Part 4 SOD323 (SC-76) 1.7 x 1.25 x 0.95 0.1 SOT666 PESD5V0F5UV 5 2 2.6 - 9 0.1 PESD5V0U1UA 1.6 x 1.2 x 0.55 DSN0603-2 (SOD962) 0 6 5.5 0.27 0.35 10 PUSB3TB6 0.1 6 0 [1] 52 0 6 3.3 3.3 0.25 0.15 - 0.2 according to IEC 61000-4-2 (contact discharge) 15 15 DFN2111-7 (SOT1358) PUSB3FR6 0 1 5.5 12 15.4 35 30 0.1 PESD5V0L1BSF 3.3 101 - 500 30 2 PESD3V3L1BA 5 75 - 500 30 1 PESD5V0L1BA SOD323 (SC-76) mse211 2.1 x 1.1 x 0.48 0.6 x 0.3 x 0.3 12 19 - 200 30 0.05 PESD12VL1BA 15 16 - 200 30 0.05 PESD15VL1BA 24 11 - 200 23 0.05 PESD24VL1BA 1.7 x 1.25 x 0.95 PUSB3AB6 [1] 8 / 20 µs exponential decay waveform according to IEC 61000-4-5 and IEC 61643-321 [2] according to IEC 61000-4-2 (contact discharge) 53 Low-capacitance ESD protection devices 11 13 45 30 0.01 PESD5V0V1BLD 1.0 x 0.6 x 0.37 11 13 45 30 0.01 PESD5V0V1BB 5 75 12 19 15 SOD523 (SC-79) 5 30 1 PESD5V0L2BT 30 0.05 Type Size (mm) PESD3V3L2BT Configuration 2 Package max (kV) 30 [2] max (W) [1] PPP Cline max (pF) 101 350 DFN1006D-2 (SOD882D) 5 3.3 types in bold represent new products IR max (µA) @ VRWM 1.0 x 0.6 x 0.48 Cline typ (pF) DFN1006-2 (SOD882) PESD5V0V1BL VRWM (V) Bidirectional [1] Unidirectional 0.01 Size (mm) IR max (µA) @ VRWM 30 Package ESD rating 45 Low-capacitance ESD protection devices – Part 3 Number of protected lines Type PPP 13 types in bold represent new products Configuration Cline max (pF) 11 [2] Cline typ (pF) 5 max (W) VRWM (V) Bidirectional Unidirectional Number of protected lines max (kV) Low-capacitance ESD protection devices – Part 2 ESD rating Low-capacitance ESD protection devices 1.2 x 0.8 x 0.6 24 - 16 200 11 30 23 PESD12VL2BT 1 3 0.05 PESD15VL2BT 2 0.05 SOT23 2.9 x 1.3 x 1.0 PESD24VL2BT mse213 SOD323 (SC-76) 11 13 45 30 0.01 PESD5V0V1BA 5 5.3 6 10 20 0.1 PESD5V0V1BCSF 5 5.3 6 20 25 0.1 PESD5V0V1BDSF 35 1.7 x 1.25 x 0.95 DSN0603-2 (SOD962) 5.5 3.5 4.5 8 15 0.1 130 30 0.1 PESD5V0S2BT - PESD5V0U2BT - PESD5V0U2BM DFN1006-3 (SOT883) 0 0.6 x 0.3 x 0.3 2 2.9 0 45 3.5 10 1.0 x 0.6 x 0.48 0.1 PESD5V0V1BSF DFN1006B-3 (SOT883B) mse211 1 DFN1006-2 (SOD882) 12 17 25 290 30 0.01 PESD12VV1BL 15 8 10 - 15 0.1 IP4302CX2/A 1.0 x 0.6 x 0.48 WLCSP2 - 5 PESD5V0U2BMB 1 3 0.7 x 0.52 x 0.40 DFN1006-3 (SOT883) 2 PESD5V0V2BM brb178 DFN1006-2 (SOD882) PESD5V0U1BL 18 1.0 x 0.6 x 0.48 20 110 30 1.0 x 0.6 x 0.37 0.01 DFN1006B-3 (SOT883B) PESD5V0V2BMB DFN1006D-2 (SOD882D) PESD5V0U1BLD 5 2.9 3.5 - 10 0.1 1.0 x 0.6 x 0.37 SOD523 (SC-79) PESD5V0U1BB 3.3 1.2 x 0.8 x 0.6 22 28 30 20 0.3 SOD323 (SC-76) PESD5V0U1BA 3.3 22 28 30 15 0.3 30 15 0.025 PESD3V3L2UM 1.7 x 1.25 x 0.95 1.0 x 0.6 x 0.48 16 2 1 2 19 5 3 - 15 0.025 [1] brb051 PESD5V0L2UMB 38 46 70 30 0.09 (@ 4 V) PESD5V0L2UU 34 40 60 30 0.018 (@ 4.3 V) PESD6V0L2UU 8 / 20 µs exponential decay waveform according to IEC 61000-4-5 and IEC 61643-321 30 20 0.025 3.3 22 28 30 20 0.3 4 DFN1410-6 (SOT886) 1.45 x 1.0 x 0.48 PESD5V0L4UF 006aaa156 PESD3V3L4UW SOT665 [2] 16 19 30 20 0.025 PESD5V0L4UW 3.3 22 28 30 20 0.3 PESD3V3L4UG SOT353 (SC-88A) 2.0 x 1.25 x 0.95 according to IEC 61000-4-5 (contact discharge) Bidrectional protection for one data line Very low line capacitance of 17 pF High ESD robustness of 30 kV 5 SOT323 (SC-70) PESD12VV1BL: Lowest capacitance ESD protection in DFN1006-2 3 5 16 19 30 20 0.025 PESD5V0L4UG 3.3 13 17 25 10 1 PESD3V3V4UK 5 12 15 25 15 0.3 1 6 2 5 3 4 DFN1010-6 (SOT891) PESD5V0V4UK 1.0 x 1.0 x 0.48 006aab474 mse211 AEC-Q101 qualified 9 6.5 10 28 8 0.1 PESD9V0V4UK 3.3 15 18 16 12 0.3 PESD3V3V4UW Ultra-small package DFN1006-2 (SOD882) with a height of only 0.48 mm typ Ideal for portable electronics, communication systems, or audio and video equipment SOT665 1.6 x 1.2 x 0.55 5 [1] 54 3 PESD3V3L4UF 1.6 x 1.2 x 0.55 1.0 x 0.6 x 0.37 4 In the spotlight 19 5 DFN1006B-3 (SOT883B) 2.0 x 1.25 x 0.95 6 16 6 2 DFN1006-3 (SOT883) PESD5V0L2UM 1 5 1 ESD protection, TVS, filtering and signal conditioning 5 12 15 16 12 0.025 8 / 20 µs exponential decay waveform according to IEC 61000-4-5 and IEC 61643-321 PESD5V0V4UW [2] according to IEC 61000-4-5 (contact discharge) 55 2.9 3.5 - 10 0.1 2 5 3 4 PESD5V0U4BF 1.45 x 1.0 x 0.48 brb179 0 4 SOT665 5 1 5 2.9 3.5 - 10 0.1 2 3 PESD5V0U4BW 4 IR max (µA) @ VRWM 0.1 1.6 x 1.2 x 0.55 20 24 28 15 2 PESD3V3L5UK DFN1010-6 (SOT891) 1 1.0 x 1.0 x 0.48 5 3.3 18.5 22 22 28 30 25 20 20 0.5 0 PESD5V0L5UK 1 6 2 5 3 4 0.3 PESD3V3L5UF 006aaa159 DFN1410-6 (SOT886) PESD5V0S1USF [1] 3.3 207 300 150 30 2 PESD3V3S1UL 5 152 200 150 30 1 PESD5V0S1UL 12 38 75 150 30 0.05 PESD12VS1UL 15 32 70 150 30 0.05 PESD15VS1UL 24 23 50 150 23 0.05 PESD24VS1UL 36 18 30 150 30 0.01 PESD36VS1UL 5 152 200 150 30 1 PESD5V0S1ULD 12 38 75 150 30 0.05 PESD12VS1ULD 15 32 70 150 30 0.05 PESD15VS1ULD PESD24VS1ULD brb155 3.3 24 23 50 150 23 0.05 3.3 207 300 330 30 2 PESD3V3S1UB 5 152 200 260 30 1 PESD5V0S1UB 12 38 75 180 30 0.05 15 32 70 160 30 0.05 1 0.6 x 0.3 x 0.3 DFN1006-2 (SOD882) 1.0 x 0.6 x 0.48 DFN1006D-2 (SOD882D) 1.0 x 0.6 x 0.37 SOD523 (SC-79) PESD12VS1UB 2 1.2 x 0.8 x 0.6 PESD15VS1UB mse209 24 23 50 160 23 0.05 PESD24VS1UB 5 480 530 890 30 4 PESD5V0S1UA 12 160 180 600 30 0.1 PESD12VS1UA 24 23 50 160 23 0.05 PESD24VS1UA 5 480 530 890 30 4 PESD5V0S1UJ 12 160 180 600 30 0.1 PESD12VS1UJ SOD323 (SC-76) 1.7 x 1.25 x 0.95 SOD323F (SC-90) 1.45 x 1.0 x 0.48 5 5 16 19 25 20 0.025 1.7 x 1.25 x 0.7 PESD5V0L5UF 4 SOT666 3.3 22 28 25 20 0.3 PESD3V3L5UV 1.6 x 1.2 x 0.55 5 16 19 25 20 0.025 Size (mm) ESD rating 30 Package PPP 40 [2] Cline max (pF) 42 max (W) Cline typ (pF) 35 PESD5V0L5UV 2.5 229 300 260 30 6 PESD5Z2.5 3.3 172 200 260 30 0.05 PESD5Z3.3 5 89 150 180 30 0.05 PESD5Z5.0 6 78 150 180 30 0.01 PESD5Z6.0 7 69 150 180 30 0.01 PESD5Z7.0 12 35 75 200 30 0.01 PESD5Z12 0.1 PESD5V0S1BSF ESD protection, TVS, filtering and signal conditioning 5 6 5 DSN0603-2 (SOD962) DFN1410-6 (SOT886) 1 VRWM (V) Bidirectional Size (mm) Package Type Configuration Unidirectional Number of protected lines IR max (µA) @ VRWM [2] ESD rating max (W) [1] PPP Cline max (pF) Cline typ (pF) VRWM (V) Bidirectional Unidirectional Number of protected lines Type Standard ESD protection devices – Part 1 Configuration Low-capacitance ESD protection devices – Part 4 max (kV) Standard ESD protection devices max (kV) Low-capacitance ESD protection devices SOD523 (SC-79) 1.2 x 0.8 x 0.6 DSN0603-2 (SOD962) 3.3 22 28 25 20 0.3 PESD3V3L5UY SOT363 (SC-88) 5.5 35 45 100 30 2.0 x 1.25 x 0.95 5 16 19 25 20 0.025 DFN1006-2 (SOD882) PESD5V0L5UY 5 35 45 130 30 0.1 PESD5V0S1BL DFN1410-6 (SOT886) 5 2.9 3.5 - 10 0.1 1 6 2 5 3 4 PESD5V0U5BF 0.6 x 0.3 x 0.3 1.0 x 0.6 x 0.48 DFN1006D-2 (SOD882D) 0 1.45 x 1.0 x 0.48 1 5 35 45 130 30 0.1 PESD5V0S1BLD 1.0 x 0.6 x 0.37 mse211 brb180 SOD523 (SC-79) 0 5 5 SOT666 5 2.9 3.5 - 10 0.1 1 6 2 5 3 4 PESD5V0U5BV 56 8 / 20 µs exponential decay waveform according to IEC 61000-4-5 and IEC 61643-321 130 30 0.1 PESD5V0S1BB according to IEC 61000-4-5 (contact discharge) 1.2 x 0.8 x 0.6 SOD323 (SC-76) 5 [2] 45 1.6 x 1.2 x 0.55 brb133 [1] 35 [1] 35 45 130 30 0.1 8 / 20 µs exponential decay waveform according to IEC 61000-4-5 and IEC 61643-321 PESD5V0S1BA [2] 1.7 x 1.25 x 0.95 according to IEC 61000-4-2 (contact discharge) 57 Application-specific ESD and ESD/EMI solutions 1 3.3 200 275 150 23 3 PESD3V3S2UQ 5 150 215 150 30 0.3 PESD5V0S2UQ 12 38 100 150 30 0.03 PESD12VS2UQ 15 32 70 150 30 0.05 PESD15VS2UQ 24 23 50 150 23 0.05 PESD24VS2UQ 3.3 207 300 330 30 2 PESD3V3S2UT 5.2 152 200 260 30 1 PESD5V2S2UT 12 38 75 180 30 1 PESD12VS2UT 15 32 70 160 30 1 PESD15VS2UT 24 23 50 160 23 1 PESD24VS2UT 36 17 35 160 30 1 (@ 30 V) PESD36VS2UT 3.3 207 300 330 30 2 5 152 200 260 30 1 Remark Type Package SOT663 1.0 ESD protection for up to 2 ultra high-speed datalines PRTR5V0U2X SOT143B 1.8 ESD protection for up to 2 ultra high-speed datalines with 12 kV ESD robustness PRTR5V0U2AX ESD protection for up to 2 ultra high-speed datalines PRTR5V0U2F USB protection for USB OTG with 5.5 V Vbat protection PUSBM5V5X4-TL USB protection for USB OTG with 12 V Vbat protection PUSBM12VX4-TL USB protection for USB OTG with 30 V Vbat protection PUSBM30VX4-TL Very low clamp ESD protection for USB2.0 high-speed with 12 kV IEC ESD protection PUSB2X4Y 2 DFN1410-6 (SOT886) 3+1 SOT23 USB2.0 32 70 160 30 0.05 24 23 50 160 23 0.05 2 bra004 0 2 5 35 45 130 30 Very low clamp ESD protection for USB2.0 high-speed with 12 kV IEC ESD protection PUSB2X4D Dual ESD protection for USB2.0 high-speed, SD-card, SIM card IP4220CZ6 PESD15VS2UAT Dual ESD protection for USB2.0 high-speed, SD-card, SIM card PRTR5V0U4D ESD protection for USB2.0 high-speed, SD-card, SIM card IP4221CZ6-S Dual ESD protection for USB2.0 high-speed, SD-card, SIM-card IP4221CZ6-XS 4 PESD24VS2UAT 3 PESD5V0S2BQA 300 110 30 1 (@ 3 V) 5 85 220 110 30 0.1 (@ 4.3 V) 3 107 125 - 8 1 SOT457 (SC-74) 2.9 x 1.5 x 1.0 1.45 x 1.0 x 0.48 DFN1010-6 (SOT891) brb178 110 2.0 x 1.25 x 0.95 1.1 x 1.0 x 0.37 2 3.3 1.6 x 1.6 x 0.48 DFN1410-6 (SOT886) 1 SOT1215 0.1 DFN1616-6 (SOT1189) package) PESD5V0S2UAT 1 1.45 x 1.0 x 0.48 SOT363 (SC-88) 0.8 - (Plastic 2.9 x 1.3 x 1.0 3 15 Size (mm) 2.9 x 1.3 x 1.0 1.6 x 1.2 x 0.55 PESD3V3S2UAT 1 types in bold represent new products Cline (pF) Rline Number of protected lines USB 2.0 protection and filtering Size (mm) Package Type Configuration IR max (µA) @ VRWM [2] ESD rating max (W) [1] PPP Cline max (pF) Cline typ (pF) VRWM (V) types in bold represent new products 1 6 2 5 3 4 PESD3V3S4UF DFN1410-6 (SOT886) 1.45 x 1.0 x 0.48 PESD5V0S4UF 006aaa156 1.0 x 1.0 x 0.48 Common Mode Filter for USB 2.0 BZA956A ESD protection, TVS, filtering and signal conditioning 2 Bidirectional Unidirectional Number of protected lines max (kV) Standard ESD protection devices – Part 2 Baseband interface Standard ESD protection devices types in bold represent new products 0.5 BZA962A 4.3 78 90 - 8 0.1 BZA968A 1.6 x 1.2 x 0.55 SOT353 (SC-88A) 3 3 200 240 - 8 2 BZA856A 3 200 240 - 8 2 BZA456A 4 165 200 - 15 0.7 BZA462A 15 37 48 - 8 0.1 3.3 215 300 200 30 0.8 5 165 220 200 30 0.2 1 6 2 5 2.0 x 1.25 x 0.95 USB2.0 2 1.5 15 [1] 8 ESD rating - Cline (pF) 105 Number of protected lines 90 Baseband interface 4 4 max (kV) SOT665 Remark Type Common Mode filter with ESD protection for high-speed interfaces such as USB 2.0 IP3319CX6 Package Size (mm) WLCSP6 1.34 x 0.95 x 0.57 BZA420A [1] PESD3V3S4UD 4 3 according to IEC 61000-4-2 (contact discharge) PESD5V0S4UD mse214 0 4 4 40 70 200 23 0.015 PESD24VS4UD 215 300 200 30 0.8 PESD3V3S5UD 5 165 220 200 30 0.2 PESD5V0S5UD 12 73 100 200 30 0.015 PESD12VS5UD 15 60 90 200 30 0.015 PESD15VS5UD 24 45 70 200 23 0.015 PESD24VS5UD 5 45 75 - 15 0.1 1 6 2 5 SOT457 (SC-74) 2.9 x 1.5 x 1.0 BZA408B In the spotlight 5 24 3.3 IP3319CX6 - Common Mode Filter for USB2.0 Very wide differential pass band >1 GHz Very broadband Common Mode attenuation Very low clamping ESD protection, excellent SoC protection Very small WLCSP6 package (footprint area 1.34 x 0.95 mm) 4 3 mse216 [1] 58 8 / 20 µs exponential decay waveform according to IEC 61000-4-5 and IEC 61643-321 [2] according to IEC 61000-4-2 (contact discharge) 59 NXP paves the way for USB Type-C connector Common Mode Filter for USB 3.x NXPs Common Mode Filter offer: USB 3.x 10 Gbps eye diagrams  Best in class system-level protection due to deep snap-back and very low dynamic resistance  Very wide-band Common Mode rejection to cover all critical frequencies  Improved RF performance and small footprint compared to separate ESD/CMF solutions  Protection for MIPI CSI, DSI, USB3.x, and HDMI 2.0 PCMFxUSB3S Key Features of PCMFxUSB3S USB Type-C receptacle USB Type-C plug USB Type-C evaluation board with NXP protection solutions PUSB3FR4 and the new Type-C connector The perfect match. PUSB3FR4 supports protection for the new Type-C connector, in order to enable directionagnostic connection, faster charging and the smallest solution to support SuperSpeed USB. USB 3.1 introduces data rates up to 10 Gbps As shown in the eye diagram, NXP offers protection, which supports data rates up to 10 Gbps with low capacitance and optimized package layouts. PUSB3FR4 on standard FR4 testboard PCMFxUSB3S 12 Better system protection 10 8 6 PCMFxUSB3 Silicon competitor 1 4 Silicon competitor 2 Silicon competitor 3 2 0 0 2 4 6 0.4 0.27 PUSB3FR6 0.27 15 0.5 PUSB3TB6 0.15 15 0.4 PUSB3AB6 DFN2111-7 (SOT1358) 1 PCMF1USB3S 2 PCMF2USB3S 3 PCMF3USB3S 1 PESD1USB3S 2 PESD2USB3S 3 PESD3USB3S Channel series resistance 15 15 ESD rating PUSB3AB4 0.17 0.29 VRWM 2.5 x. 1.0 x 0.48 Cd typical DFN2510A-10 (SOT1176) PUSB3F96 Common Mode rejection 800 MHz - 10 GHz IP4292CZ10-TBR IP4294CZ10-TBR 2.1 x 1.1 x 0.48 USB3.1 - 10 Gbps 1 0.29 15 0.27 PUSB3FR4 0.1 10 0.45 PESD5V0R1BSF 0.15 15 0.25 PESD5V0H1BSF 0.2 20 0.23 PESD5V0C1BSF 0.2 20 0.23 PESD3V3CIBSF 0.45 20 0.1 PESD5V0C1USF 0.25 15 0.16 PESD1USB3S 8 10 12 14 V TLP (V) Package Size (mm) WLCSP5 0.8 x 1.2 x 0.5 DFN2510A-10 (SOT1176) 4 Ferrite CMF trigger at ~ 500 V types in bold represent new products Differential Mode 3dB frequency Size (mm) Package ESD Protection for high-speed interfaces Type 0.3 / 0.4 Type 10 Remark 0.5 14 types in bold represent new products Number of protected line pairs 6 8 ITLP (A) The superior system-level protection is shown in the lower TLP clamping voltage Baseband interface 4 0.55 Clamping performance of PCMFxUSB3S compared to other silicon Common Mode Filter Common Mode Filter for USB 3.x Rdyn (Ω) 4 ESD rating max (kV) Number of protected lines USB3.0 - 5 Gbps Cd (pF) Baseband interface USB 3.x and eSATA protection and filtering for high-speed and super-speed lines  ESD protection is available in the same footprint, allowing last-minute changes between Common Mode Filter with ESD (PCMF) and ESD protection only (PESD)  No ferrite saturation, widest differential pass-band compared to other Si-based solutions and Ferrite-based solutions with additional 15GHz ESD protection  Lowest ESD-clamping compared to all other Common Mode Filters: provides high system-level robustness even for the most sensitive USB3.1 transceiver  Strongest Common Mode rejection for the USB3.1 fundamentals at 2.5 and 5 GHz of all USB3 Common Mode Filters  Smallest footprint  PCMF1USB3S allows very easy RF-routing together with the new USB Type-C connector Only test board ESD protection, TVS, filtering and signal conditioning USB 3.x protection and filtering WLCSP10 2.5 x. 1.0 x 0.48 6 GHz >12 0.3 1.6 x 1.2 x 0.5 WLCSP15 DSN0603-2 (SOD962) 2.4 x 1.2 x 0.5 USB3.x 0.6 x 0.3 x 0.3 5 15 3 WLCSP5 0.8 x 1.2 x 0.5 WLCSP10 17 GHz ESD protection only 0.5 1.6 x 1.2 x 0.5 WLCSP5 2 0.25 15 0.14 Common Mode Filter with TrEOS Protection for ultra high-speed interfaces http://www.nxp.com/products/discretes-and-logic/esd-protection-tvs-filtering-and-signal-conditioning/usb-type-c-protection-family:GRP_13811 60 PCMF1USB3S 1.2 x 0.8 x 0.6 WLCSP15 [1 2.4 x 1.2 x 0.5 according to IEC 61000-4-2 (contact discharge) 61 Application-specific ESD and ESD/EMI solutions Size (mm) Package 5 - - MIPI D-PHY 2.5 x 2.0 x 0.48 3 PCMF3DFN1 HDMI tx 5Ω 0.8 yes yes DFN4020-14 (SOT1334) >2 GHz 100 Ω differential impedance 13 4.0 x 2.0 x 0.48 internal 0 PCMF1HDMI2S 5 CEC LDO. 5V LDO Fully integrated for HDMI control lines including buffer for DDC, CEC, and Hot Plug module IP4791CZ12 Package Size (mm) DFN2521-12 (SOT1156) 2.5 x 2.1 x 0.48 IP4786CZ32 DFN5050-32 (SOT617) 5.0 x 5.0 x 0.85 Fully integrated HDMI source solution with enhanced ESD protection, current limiter, buffer, and level shifter for DDC, CEC, and Hot Plug Fully integrated HDMI source solution with small package, current limiter, buffer, and level shifter for DDC, CEC, and Hot Plug 0.8 x 1.2 x 0.5 15 Type Fully integrated HDMI sink solution with buffer, and level shifter for DDC, CEC, and Hot Plug WLCSP5 1 Remark Fully integrated HDMI source solution with current limiter, buffer, and level shifter for DDC, CEC, and Hot Plug DFN2520-9 (SOT1333) 2 types in bold represent new products LDO Resistor (Ω) Cline (pF) Level shifer Buffer HDMI and memory-card signal conditioning Interface Channel series resistance max (kV) [1] ESD rating >2 GHz types in bold represent new products Vrwm Differential Mode 3 dB frequency (typ.) PCMF2DFN1 Cd pF typical Type Number of protected line pairs bidirectional Number of protected line pairs unidirectional Baseband interface Common Mode Filter for video interfaces Number of protected lines Application-specific ESD and ESD/EMI solutions DFN4040-32 (SOT1318-1) IP4786CZ32S 4.0 x 4.0 x 0.50 IP4786CZ32 5.0 x 5.0 x 0.85 WLCSP10 PCMF2HDMI2S 2 >6 GHz 0.3 3Ω 1.6 x 1.2 x 0.5 Fully integrated HDMI source solution with current limiter, buffer, and level shifter for DDC, CEC, and Hot Plug WLCSP15 PCMF3HDMI2S 3 HDMI2.0 according to IEC 61000-4-2 (contact discharge) In the spotlight [1 PCMFxHDMI2S series: 1, 2 and 3 line pair Common Mode Filters with ESD protection for HDMI 1.4 and 2.0 1 14 2 13 1 14 4 12 2 13 5 11 4 12 5 11 7 10 8 9 SD3.0 Very low clamping ESD protection, excellent SoC protection Smallest footprint Fully integrated HDMI source solution with enhanced ESD protection, current limiter, buffer, and level shifter for DDC, CEC, and Hot Plug IP4788CZ32 5.0 x 5.0 x 0.85 Fully integrated HDMI source solution in a small package with current limiter, buffer, and level shifter for DDC, CEC, and Hot Plug IP4786CZ32S - SD 3.0-compliant memory card with integrated dual voltage- level translator with EMI filter and ESD protection IP4856CX25/C 1.8 V LDO Fully integrated SD 3.0 card level shifter with buffer technology, LDO, and EMI filter IP4855CX25 - 6 yes yes - DFN4040-32 (SOT1318-1) 4.0 x 4.0 x 0.5 WLCSP25 2.4 x 2.4 x 0.4 internal WLCSP25 2.4 x 2.4 x 0.4 aaa-007384 6 7 10 8 9 The IP478x-series offers a complete HDMI-interface in one package. Cline (pF) Ethernet protection Number of protected lines yes 6 3 aaa-007384 Baseband interface 5.0 x 5.0 x 0.85 3 Very wide differential pass band >6 GHz Very broadband Common Mode attenuation 13 100 Ω yes differential integrated impedance DFN5050-32 (SOT617) IP4787CZ32 2.4 x 1.2 x 0.5 ESD protection, TVS, filtering and signal conditioning HDMI2.0 types in bold represent new products Remark Type Ethernet ESD protection VRWM = 3.3 V PESD3V3U1UT Ethernet ESD protection VRWM = 5.0 V PESD5V0U1UT Ethernet ESD protection VRWM = 12 V PESD12VU1UT Ethernet ESD protection VRWM = 15 V PESD15VU1UT Ethernet ESD protection VRWM = 24 V PESD24VU1UT Ethernet ESD protection IP4220CZ6 Package Size (mm) SOT23 1 0.6 LAN 2.9 x 1.3 x 1.0 SOT457 (SC-74) 4 62 1 2.9 x 1.5 x 1.0 63 Application-specific ESD and ESD/EMI solutions Video interface protection Baseband interface Number of protected lines types in bold represent new products Cline (pF) Remark Type Package NFC antenna protection Size (mm) mse211 0.6 ESD protection for ultra high-speed interfaces IP4283CZ10-TBR DSN0603-2 (SOD962) 0.55 Display port 4 ESD protection for ultra high-speed interfaces IP4292CZ10-TBR ESD protection for ultra high-speed interfaces IP4294CZ10-TBR ESD protection for ultra high-speed interfaces PHDMI2F4 ESD protection for ultra high-speed interfaces IP4285CZ9-TBB DFN2510A-10 (SOT1176) Single package 0.6 x 0.3 x 0.3 mm 2.5 x 1.0 x 0.48 0.5 2.1 x 1.0 x 0.48 DFN2510A-10 (SOT1176) 0.6 ESD protection for ultra high-speed interfaces IP4283CZ10-TBR 0.8 ESD protection for ultra high-speed interfaces IP4285CZ9-TBB 0.55 ESD protection for ultra high-speed interfaces IP4292CZ10-TBR ESD protection for HDMI 2.0 PHDMI2F4 ESD protection for ultra high-speed interfaces IP4294CZ10-TBR 0.8 Very low clamp ESD protection with 12 kV IEC ruggedness PUSB2X4D 0.8 Very low clamp ESD protection with 12 kV IEC ruggedness PUSB2X4Y 2.5 x 1.0 x 0.48 DFN2110-9 (SOT1178) HDMI 2.1 x 1.0 x 0.48 4 DFN2510A-10 (SOT1176) 2.5 x 1.0 x 0.48 Features Benefits  Bidirectional configuration, allowing operating voltages up to 18 or 24 V  Very low capacitance, enabling easy design of the antenna-matching circuit  Very small voltage dependency of the diode capacitance, avoiding intermodulation distortion  Small form-factor packages of 1006 (0402 inch) and 0603 (0201 inch) standard size The phone’s NFC antenna is often integrated into the battery cover or the battery itself and is connected to the NFC tags via small contacts on the phone, creating an entry point for ESD strikes that are potentially hazardous to the NFC IC. These new NXP devices are optimized for the requirements of th NFC system and ensure the best-possible protection of the NFC IC. 0.5 LVDS SOT457 (SC-74) 2.9 x 1.5 x 1.0 Circuit diagram Diode capacitance versus bias voltage Using tiny packages makes PCB design more flexible The highly linear diode capacitance, with very small variation, minimizes signal degradation 4 SOT363 (SC-88) 2.0 x 1.25 x 0.95 ESD protection, TVS, filtering and signal conditioning DFN2110-9 (SOT1178) 0.8 PHDMI2F4 PESD HDMI application schematic PHDMI2F4 Cline max [pF] ESD rating [1] max [kV] types in bold represent new products Cline typ [pF] VRWM [V] Number of protected lines (Bidirectional) Interface NFC antenna protection 0.28 0.45 10 0.35 0.5 10 0.25 0.4 10 0.3 0.45 10 Configuration [1 64 PESD18VF1BSF DSN0603-2 (SOD962) PESD18VF1BL mse211 PESD24VF1BSF DFN1006-2 (SOD882) 1.0 x 0.6 x 0.48 DSN0603-2 (SOD962) 0.6 x 0.3 x 0.3 PESD2NFC-SF PESD24VF1BL PESD2NFC-L Size 0.6 x 0.3 x 0.3 PESD1NFC-L 1 24 Package PESD1NFC-SF 18 NFC Antenna Type DFN1006-2 (SOD882) 1.0 x 0.6 x 0.48 according to IEC 61000-4-2 (contact discharge) 65 Application-specific ESD and ESD/EMI solutions Application-specific ESD and ESD/EMI solutions LCD/camera protection and filtering Audio interface protection and filtering Cline (pF) Lline (nH) Digital interface clock speed (MHz) Insertion loss S21~ -3 dB (MHz) Type 40 18 - ~100 300 IP4252CZ8-4 -TTL 45 - ~40 130 IP4254CZ8-4-TTL 100 Remark 200 - ~110 330 IP4251CZ8-4-TTL 45 - ~35 110 IP4253CZ8-4-TTL - 18 18 45 - - ~100 ~40 300 130 - ~110 330 2 PESD5V0V2BMB 1.7 x 1.35 x 0.52 110 IP4254CZ12-6-TTL Baseband interface DFN2514-12 (SOT1167) Number of protected lines Line small-signal equivalents Single-ended or differential microphone IP4049CX5/LF - ~35 110 Rline Cline (pF) 47 Ω / 100 Ω 20 Remark Type ~20 Integrated SIM-card EMI filter and ESD protection IP4264CZ8-20-TTL Quad-channel, low-capacitance ESD protection IP4221CZ6-S Quad-channel, low-capacitance ESD protection IP4221CZ6-XS IP4251CZ12-6-TTL 4 WLCSP15 100 54 - ~35 98 PEMI6CSP/RW 40 18 - ~100 300 IP4252CZ16-8-TTL ~40 130 IP4254CZ16-8-TTL 100 15 - ~110 330 - 1 DFN3314-16 (SOT1168) 40 Ω 12 >52 (Mini) SD card/trans flash ESD protection, EMI filter IP4252CZ12-6-TTL 40 Ω / 100 Ω 11 - 6-channel Micro-SD memory-card interface ESD protection filter IP4340CX15 - ~35 110 Package Size (mm) DFN1714-8 (SOT1166) 1.7 x 1.35 x 0.52 DFN1410-6 (SOT886) 1.0 x 1.0 x 0.48 DFN1010-6 (SOT891) 1.0 x 1.0 x 0.48 DFN2514-12 (SOT1167) 2.5 x 1.35 x 0.53 WLCSP15 1.56 x 1.56 x 0.5 3.3 x 1.35 x 0.53 IP4251CZ16-8-TTL PUSB3TB6 0.27 45 0.91 x 1.28 x 0.65 6 8 200 WLCSP5 ~240 2.36 x 1.05 x 0.61 SD-card / MMC - 1.0 x 0.6 x 0.37 IP4253CZ12-6-TTL SIM card 45 SOT883B 2.5 x 1.35 x 0.53 3 45 1.0 x 0.6 x 0.48 types in bold represent new products Digital interface clock speed (MHz) 6 200 SOT883 IP4252CZ12-6-TTL 100 15 Size (mm) 2 line bidirectional with IPPM=9A Memory- and SIM-card protection and filtering 40 Package Cline (pF) Rline 68 Ω 15 Type PESD5V0V2BM Audio DFN1714-8 (SOT1166) Line small-signal equivalents Size (mm) Package Number of Baseband protected interface lines ESD protection, TVS, filtering and signal conditioning 4 Rline (Ω) Number of protected lines Baseband interface Line small-signal equivalents IP4253CZ16-8-TTL SD 3.0 6 - 0.35 5000 6-line bidirectional ESD protection for ultra high-speed interfaces DFN2111-7 (SOT1358) PUSB3FR6 2.1 x 1.1 x 0.5 WLCSP20 100 54 - ~35 98 PEMI8CSP/RW/P 3.16 x 1.05 x 0.61 0.15 66 PUSB3AB6 67 Application-specific ESD and ESD/EMI solutions types in bold represent new products Size (mm) DFN2510A-10 (SOT1176) PESD2LVDS 5 DFN2510-10 (SOT1165) 4 5.5 0.6 1 3, 8 8 6 5.5 0.6 1 5 001aai619 PESD1LVDS SOT457 PRTR5V0U4D 2 2.9 x 1.5 x 1.0 3 001aag273 g g273 (1) according to IEC 61000-4-2 (contact discharge) Ir max [µA] @ VRWM 13 17 160 23 0.05 types in bold represent new products [1] [2] ESD rating max (kV) max (W) PPP 15 (diode 1) 24 (diode 2) Cline max (pF) 1 Cline typ (pF) Number of protected lines bidirectional Automotive in-vehicle network bus line protection VRWM (V) Configuration 15 V 1 Type Package Size (mm) SOD323 (SC-76) 24 V 2 PESD1LIN 1.7 x 1.25 x 0.95 Surge pulses from the power supply, e.g. via a car charger, are a severe threat for the charger port VBUS line of smart phones and other portables.Supply voltages of these chargers often exceed the 5 V level – requiring high reverse standoff voltages. TVS diodes for mobile applications in DSN1608-2 23 0.05 PESD1CAN 30 0.01 PESD2CAN 11 17 200 23 0.05 1 9.3 12 150 23 0.05 PESD1CAN-U mse213 PTVS5V0Z1USK PTVS5V0Z1USKN 5 6.4 7.80 18 80 1200 12 20 200 1 1000 0.06 PTVS7V5Z1USKN 7.5 8.33 9.65 24 92 2000 13.9 17.5 200 0.1 200 0.08 Package 2.0 x 1.25 x 0.95 PTVS10VZ1USK PTVS15VZ1USK 1 3 2 9.3 11 150 23 PTVS18VZ1USK PESD1IVN-U aaa-018783 26.5 SOT323 0.05 Package PTVS10VZ1USKN SOD964 PTVS12VZ1USK 1 Type 2.9 x 1.3 x 1.0 SOT323 2 PTVS7V5Z1USK Type SOT23 PESD1FLEX 3 24 Irm max @ Vrwm (nA) 200 230 2.0 x 1.25 x 0.95 7 types from VRWM = 5 to 26 V High surge rating Very compact and thin package Low leakage current: down to 1 nA, reduces power consumption  Dynamic resistance down to 0.06 Ohm  High ESD robustness: VESD = 30 kV (IEC61000-4-2) Irm typ @ Vrwm (nA) 17 30      Superior electrical performance  High PCB design flexibility  Easy routing PTVS12VZ1USKN 1.6 x 0.8 x 0.37 PTVS15VZ1USKN PTVS18VZ1USKN SOD963 1.6 x 0.8 x 0.25 VRWM (V) 11 25 Features and benefits NXP’s PTVSxZ1USK series is ideally suited to protect the charger port and offers bra526 2 Single package 1.6 x 0.8 x 0.25 mm 2.5 x 1.0 x 0.48 4 8 1 DSN1608-2 (SOD963) 10 11.1 12.9 27.5 73 2000 17.8 11.1 170 0.1 200 0.1 12 13.3 15.4 29 65 2100 19.9 10.1 180 0.1 200 0.1 15 16.7 19.4 35.4 52 1700 27.6 7.5 175 0.1 200 0.1 18 20 23.2 40.5 41 1700 30.2 6.9 190 0.1 200 0.17 PTVS20VZ1USK PTVS20VZ1USKN 20 22.2 25.4 47 38 1800 36.0 6 175 0.1 200 0.16 PTVS26VZ1USK PTVS26VZ1USKN 26 28.9 33.4 61 30 1600 48.0 3.76 150 0.1 200 0.16 ESD protection, TVS, filtering and signal conditioning 4 Rdyn (TLP) - 8/20µs 2 A new powerful surge protection device in a 1.6 x 0.8 mm small, and 0.25 mm low package for slim mobiles Vcl @ Ippm 10/1000µs (V) Ippm 10/1000µs (A) Pppm 10/1000µs (W) 1 2.5 x 1.0 x 0.5 Pppm 8/20µs (W) 5.5 Ippm 8/20µs (A) 10 Package Vcl @ Ippm 8/20µs (V) 1 Type Vbr max (V) 0.5 Configuration Surge protection for charger ports in mobile devices Vbr min (V) ESD rating max (kV) [1] IRM max @3V (µA) VRWM (V) Cline typ (pF) Number of protected lines Automotive high-speed network protection 1 3 2 PESD2IVN-U 2 Battery and charger port protection – PESD devices mse213 8 / 20 µs surge pulse according to IEC 61000-4-5 In the spotlight [1] 68 [2] Baseband interface according to IEC 61000-4-2 (contact discharge) 1 x uni PESD2IVN-U: CAN bus protection in very small SOT323 package Protection for 2 in-vehicle network BUS lines 1 High reverse standoff voltage VRWM = 26.5 V 3 Very small SOT323 package (2.0 x 1.25 x 0.95 mm) AEC-Q101 compliant ESD robustness of up to 23 kV (contact) Very good capacitance matching Number of protected lines Cline (pF) VRWM (V) IPPM 8/20µs (A) Type Package SOD323F (SC-90) 160 12 22.5 PESD12VS1UJ 480 5 22.5 PESD5V0S1UJ 160 12 47 PESD12VS1UA 480 5 47 PESD5V0S1UA 18 5 9 PESD5V0V2BM 18 5 9 PESD5V0V2BMB 35 5 15 PESD5V0S2BQA Size (mm) 1.7 x 1.25 x 0.7 SOD323 (SC-76) 1.7 x 1.25 x 0.95 SOT883 Battery & charger protection 1.0 x 0.6 x 0.48 SOT883B 2 x bi 2 mse213 1.0 x 0.6 x 0.37 SOT1215 1.1 x 1.0 x 0.37 69 IR (mA) VCL max [1] (V) @ IPP IPP IRM typ (µA) @ VRWM IRM max (µA) @ VRWM IR (mA) VCL max @ IPP IPP IRM typ (µA) @ VRWM IRM max (μA) @ VRWM 1 12.9 23.3 0.3 50 PTVS7V5U1UPA 3.5 5.20 5.60 6.00 10 8.0 43.8 5 600 PTVS3V3S1UR PTVS3V3S1UTR 10 11.1 11.7 12.3 1 17 17.6 0.008 2.5 PTVS10VU1UPA 5.0 6.40 6.70 7.00 10 9.2 43.5 5 400 PTVS5V0S1UR PTVS5V0S1UTR 12 13.3 14 14.7 1 19.9 15.1 0.005 2.5 PTVS12VU1UPA 6.0 6.67 7.02 7.37 10 10.3 38.8 5 400 PTVS6V0S1UR PTVS6V0S1UTR 6.5 7.22 7.60 7.98 10 11.2 35.7 5 250 PTVS6V5S1UR PTVS6V5S1UTR 7.0 7.78 8.20 8.60 10 12.0 33.3 3 100 PTVS7V0S1UR PTVS7V0S1UTR DFN2020-3 (SOT1061) [1] (A) [1] 2.0 x 2.0 x 0.62 16.7 17.6 18.5 1 24.4 12.3 0.001 0.1 PTVS15VU1UPA 18 20 21 22.1 1 29.2 10.3 0.001 0.1 PTVS18VU1UPA 7.5 8.33 8.77 9.21 1 12.9 31.0 0.2 50 PTVS7V5S1UR PTVS7V5S1UTR 26 28.9 30.4 31.9 1 42.1 7 0.001 0.1 PTVS26VU1UPA 8.0 8.89 9.36 9.83 1 13.6 29.4 0.03 25 PTVS8V0S1UR PTVS8V0S1UTR 8.5 9.44 9.92 10.40 1 14.4 27.8 0.01 10 PTVS8V5S1UR PTVS8V5S1UTR 9.0 10.00 10.55 11.10 1 15.4 26.0 0.005 5 PTVS9V0S1UR PTVS9V0S1UTR 10 11.10 11.70 12.30 1 17.0 23.5 0.005 2.5 PTVS10VS1UR PTVS10VS1UTR 11 12.20 12.85 13.50 1 18.2 22.0 0.005 2.5 PTVS11VS1UR PTVS11VS1UTR 12 13.30 14.00 14.70 1 19.9 20.1 0.005 2.5 PTVS12VS1UR PTVS12VS1UTR 13 14.40 15.15 15.90 1 21.5 18.6 0.001 0.1 PTVS13VS1UR PTVS13VS1UTR 14 15.60 16.40 17.20 1 23.2 17.2 0.001 0.1 PTVS14VS1UR PTVS14VS1UTR 15 16.70 17.60 18.50 1 24.4 16.4 0.001 0.1 PTVS15VS1UR PTVS15VS1UTR VBR typ (V) @ IR VBR max (V) @ IR IR (mA) ESD rating max (kV) Cline typ (pF) VCL max @ IPP IPP IRM max (µA) @ VRWM 5.32 5.6 5.88 20 30 210 8 3 5 MMBZ5V6AL 16 17.80 18.75 19.70 1 26.0 15.4 0.001 0.1 PTVS16VS1UR PTVS16VS1UTR 3 5.89 6.2 6.51 1 30 175 8.7 2.76 0.2 MMBZ6V2AL 17 18.90 19.90 20.90 1 27.6 14.5 0.001 0.1 PTVS17VS1UR PTVS17VS1UTR 4.5 6.48 6.8 7.14 1 30 150 9.6 2.5 0.3 MMBZ6V8AL 18 20.00 21.00 22.10 1 29.2 13.7 0.001 0.1 PTVS18VS1UR PTVS18VS1UTR 20 22.20 23.35 24.50 1 32.4 12.3 0.001 0.1 PTVS20VS1UR PTVS20VS1UTR 6 8.65 9.1 9.56 1 30 155 14 1.7 0.1 MMBZ9V1AL 22 24.40 25.60 26.90 1 35.5 11.3 0.001 0.1 PTVS22VS1UR PTVS22VS1UTR 6.5 9.5 10 10.5 1 30 130 14.2 1.7 0.02 MMBZ10VAL 24 26.70 28.10 29.50 1 38.9 10.3 0.001 0.1 PTVS24VS1UR PTVS24VS1UTR 8.5 11.4 12 12.6 1 30 110 17 2.35 0.005 MMBZ12VAL 26 28.90 30.40 31.90 1 42.1 9.5 0.001 0.1 PTVS26VS1UR PTVS26VS1UTR 12 14.25 15 15.75 1 30 85 21 1.9 0.005 MMBZ15VAL 28 31.10 32.80 34.40 1 45.4 8.8 0.001 0.1 PTVS28VS1UR PTVS28VS1UTR 14.5 17.1 18 18.9 1 30 70 25 1.6 0.005 MMBZ18VAL 30 33.30 35.10 36.80 1 48.4 8.3 0.001 0.1 PTVS30VS1UR PTVS30VS1UTR 17 19 20 21 1 30 65 28 1.4 0.005 MMBZ20VAL 33 36.70 38.70 40.60 1 53.3 7.5 0.001 0.1 PTVS33VS1UR PTVS33VS1UTR 36 40.00 42.10 44.20 1 58.1 6.9 0.001 0.1 PTVS36VS1UR PTVS36VS1UTR 22 25.65 27 28.35 1 30 48 40 1 0.005 MMBZ27VAL 40 44.40 46.80 49.10 1 64.5 6.2 0.001 0.1 PTVS40VS1UR PTVS40VS1UTR 26 31.35 33 34.65 1 30 45 46 0.87 0.005 MMBZ33VAL 43 47.80 50.30 52.80 1 69.4 5.8 0.001 0.1 PTVS43VS1UR PTVS43VS1UTR 8.5 11.4 12 12.6 1 30 110 17 2.35 0.005 MMBZ12VDL 45 50.00 52.65 55.30 1 72.7 5.5 0.001 0.1 PTVS45VS1UR PTVS45VS1UTR 12.8 14.3 15 15.8 1 30 85 21.2 1.9 0.005 MMBZ15VDL 48 53.30 56.10 58.90 1 77.4 5.2 0.001 0.1 PTVS48VS1UR PTVS48VS1UTR 14.5 17.1 18 18.9 1 30 70 25 1.6 0.005 51 56.70 59.70 62.70 1 82.4 4.9 0.001 0.1 PTVS51VS1UR PTVS51VS1UTR 54 60.00 63.15 66.30 1 87.1 4.6 0.001 0.1 PTVS54VS1UR PTVS54VS1UTR 58 64.40 67.80 71.20 1 93.6 4.3 0.001 0.1 PTVS58VS1UR PTVS58VS1UTR 60 66.70 70.20 73.70 1 96.8 4.1 0.001 0.1 PTVS60VS1UR PTVS60VS1UTR 64 71.10 74.85 78.60 1 103.0 3.9 0.001 0.1 PTVS64VS1UR PTVS64VS1UTR [1] (A) [1] (V) VBR min (V) @ IR 3 [1] VRWM (V) TVS diodes, 24 / 40 W Power (W) (10 / 1000 µs waveform) [1] Type Type (Tj max = 150 °C) (Tj max = 185 °C) 15 10 / 1000 μs according to IEC 61643-321 24 [1] VBR max (V) @ IR 9.21 Size (mm) Configuration Type 40 1 MMBZ18VCL 3 17 19 20 21 1 30 65 28 1.4 0.005 22 25.65 27 28.35 1 30 48 38 1 0.005 MMBZ27VCL 26 31.35 33 34.65 1 30 45 46 0.87 0.005 MMBZ33VCL Package Package Size (mm) ESD protection, TVS, filtering and signal conditioning VBR max (V) @ IR VBR typ (V) @ IR 8.77 Package (A) VBR typ (V) @ IR 350 [1] VBR min (V) @ IR 8.33 (V) VRWM (V) 7.5 Type 300 (1) VBR min (V) @ IR TVS diodes, 400 W VRWM (V) TVS diodes for mobile applications Power (W) (10/1000 µs waveform) TVS diodes Power (W) (10 / 1000 µs waveform) [1] TVS diodes Size (mm) SOD123W 2.6 x 1.7 x 1.0 400 SOT23 2.9 x 1.3 x 1.0 MMBZ20VCL 2 bra004 (1) 70 10 / 1000 μs according to IEC 61643-321 (2) according to IEC 61000-4-2 (contact discharge) 71 TVS diodes (1) IRM max (µA) @ VRWM IRM typ (µA) @ VRWM (A) [1] IPP VCL max [1] (V) @ IPP IR (mA) VBR max (V) @ IR VBR typ (V) @ IR VBR min (V) @ IR Protection and signal-conditioning nomenclature Type (Tj max = 150 °C) Type (Tj max = 185 °C) 3.5 5.20 5.60 6.00 10 8 75 5 600 PTVS3V3P1UP PTVS3V3P1UTP 5 6.40 6.70 7.00 10 9.2 65.2 5 400 PTVS5V0P1UP PTVS5V0P1UTP 6 6.67 7.02 7.37 10 10.3 58.3 5 400 PTVS6V0P1UP PTVS6V0P1UTP 6.5 7.22 7.60 7.98 10 11.2 53.6 5 250 PTVS6V5P1UP PTVS6V5P1UTP 7 7.78 8.20 8.60 10 12 50 3 100 PTVS7V0P1UP PTVS7V0P1UTP 7.5 8.33 8.77 9.21 1 12.9 46.5 0.2 50 PTVS7V5P1UP PTVS7V5P1UTP 8 8.89 9.36 9.83 1 13.6 44.1 0.03 25 PTVS8V0P1UP PTVS8V0P1UTP 8.5 9.44 9.92 10.40 1 14.4 41.7 0.01 10 PTVS8V5P1UP PTVS8V5P1UTP 9 10.00 10.55 11.10 1 15.4 39 0.005 5 PTVS9V0P1UP PTVS9V0P1UTP 10 11.10 11.70 12.30 1 17 35.3 0.005 2.5 PTVS10VP1UP PTVS10VP1UTP 11 12.20 12.85 13.50 1 18.2 33 0.005 2.5 PTVS11VP1UP PTVS11VP1UTP 12 13.30 14.00 14.70 1 19.9 30.2 0.005 2.5 PTVS12VP1UP PTVS12VP1UTP 13 14.40 15.15 15.90 1 21.5 27.9 0.001 0.1 PTVS13VP1UP PTVS13VP1UTP 14 15.60 16.40 17.20 1 23.2 25.9 0.001 0.1 PTVS14VP1UP PTVS14VP1UTP 15 16.70 17.60 18.50 1 24.4 24.6 0.001 0.1 PTVS15VP1UP PTVS15VP1UTP 16 17.80 18.75 19.70 1 26 23.1 0.001 0.1 PTVS16VP1UP PTVS16VP1UTP 17 18.90 19.90 20.90 1 27.6 21.7 0.001 0.1 PTVS17VP1UP PTVS17VP1UTP 18 20.00 21.00 22.10 1 29.2 20.5 0.001 0.1 PTVS18VP1UP PTVS18VP1UTP 20 22.20 23.35 24.50 1 32.4 18.5 0.001 0.1 PTVS20VP1UP PTVS20VP1UTP 22 24.40 25.60 26.90 1 35.5 16.9 0.001 0.1 PTVS22VP1UP PTVS22VP1UTP 24 26.70 28.10 29.50 1 38.9 15.4 0.001 0.1 PTVS24VP1UP PTVS24VP1UTP 26 28.90 30.40 31.90 1 42.1 14.2 0.001 0.1 PTVS26VP1UP PTVS26VP1UTP 28 31.10 32.80 34.40 1 45.4 13.2 0.001 0.1 PTVS28VP1UP PTVS28VP1UTP 30 33.30 35.10 36.80 1 48.4 12.4 0.001 0.1 PTVS30VP1UP PTVS30VP1UTP 33 36.70 38.70 40.60 1 53.3 11.3 0.001 0.1 PTVS33VP1UP PTVS33VP1UTP 36 40.00 42.10 44.20 1 58.1 10.3 0.001 0.1 PTVS36VP1UP PTVS36VP1UTP 40 44.40 46.80 49.10 1 64.5 9.3 0.001 0.1 PTVS40VP1UP PTVS40VP1UTP 43 47.80 50.30 52.80 1 69.4 8.6 0.001 0.1 PTVS43VP1UP PTVS43VP1UTP 45 50.00 52.65 55.30 1 72.7 8.3 0.001 0.1 PTVS45VP1UP PTVS45VP1UTP 48 53.30 56.10 58.90 1 77.4 7.8 0.001 0.1 PTVS48VP1UP PTVS48VP1UTP 51 56.70 59.70 62.70 1 82.4 7.3 0.001 0.1 PTVS51VP1UP PTVS51VP1UTP 54 60.00 63.15 66.30 1 87.1 6.9 0.001 0.1 PTVS54VP1UP PTVS54VP1UTP 58 64.40 67.80 71.20 1 93.6 6.4 0.001 0.1 PTVS58VP1UP PTVS58VP1UTP 60 66.70 70.20 73.70 1 96.8 6.2 0.001 0.1 PTVS60VP1UP PTVS60VP1UTP 64 71.10 74.85 78.60 1 103 5.8 0.001 0.1 PTVS64VP1UP PTVS64VP1UTP Package Size (mm) NXP P ESD 5V0 S 1 U C L Packages ESD (ESD protection) RTR (rail-to-rail ESD protection) TVS (10/1000 s pulse) Reverse stand-off voltage ESD – Capacitance class Standard capacitance Low capacitance Very low capacitance Ultra low capacitance X-extremely low capacitance R,H,C,F Femto farad capacitance ultra low Clamp Alternative high Temperature *optional Uni-directional Bi-directional Number of protected lines SOD128 3.8 x 2.6 x 1.0 Application specific protection nomenclature A B D F G K L LD M MB P PA Q QA R SF SH SK T U V W X Y SOD323 SOD523 SOT457 SOT886 SOT353 SOT891 SOD882 SOD882D SOT883 SOT883B SOD128 SOT1061 SOT663 SOT1215 SOD123W SOD962 SOD992 SOD963 SOD964 SOT23 SOT323 SOT666 SOT665 SOT143B SOT363 DFN1410-6 DFN1010-6 DFN1006-2 DFN1006D-2 DFN1006-3 DFN1006B-3 FlatPower DFN2020-3 DFN1010D-3 FlatPower DSN0603-2 DSN0402-2 DSN1608-2 ESD protection, TVS, filtering and signal conditioning 600 VRWM (V) Power (W) (10 / 1000 µs waveform) [1] TVS diodes, 600 W Application specific filtering nomenclature 10 / 1000 μs according to IEC 61643-321 In the spotlight High-temperature TVS series in FlatPower package 72 Available in 400 W (PTVSxS1UTR) and 600 W (PTVSxP1UTP) power classes with 35 devices each Very high maximal junction temperature of 185 °C Reverse standoff voltages from 3.3 to 64 V Low height, high performance - save board space by replacing SMA & SMB packages with low-profile SOD123W and SOD128 packages AEC-Q101 qualified 73 D G S MOSFETs Small-signal MOSFETs Small-signal MOSFETs in ultra-small DFN1006 and DFN1006B packages Small-signal MOSFETs in DFN1010D-3 single and DFN1010B-3 dual package Small-signal MOSFETs in DFN2020MD-6 single and DFN2020-6 dual packages Small-signal MOSFETs in WLCSP4 and WLCSP6 packages Automotive-compliant small-signal MOSFETs Small-signal MOSFETs single (N-channel) Small-signal MOSFETs single (P-channel) Small-signal MOSFET – Schottky combination Small-signal MOSFETs dual Small-signal MOSFETs complementary Power MOSFETs Power MOSFETs Power MOSFETs Power MOSFETs Power MOSFETs Power MOSFETs Power MOSFETs Power MOSFETs P channel Multi-chip Power MOSFETs 20 - 25 V 30 V 40 V 55 - 60 V 75 - 80 V 100 V 105 - 150 V 200 V Automotive MOSFETs Automotive-compliant small-signal MOSFETS 30 V N-channel automotive TrenchMOS 40 V N-channel automotive TrenchMOS 55 - 60 V N-channel automotive TrenchMOS 75 - 80 V N-channel automotive TrenchMOS 100 V N-channel automotive TrenchMOS TrenchPLUS MOSFETs 74 75 78 79 81 82 84 86 88 88 90 90 92 101 102 104 105 106 107 108 108 108 109 110 116 118 119 121 124 125 128 75 Small-signal MOSFET portfolio Leadless DFN packages replace leaded packages What you get when you choose NXP for small-signal MOSFETs Ptot [mW] 1800 1600 A comprehensive portfolio for all applications Best in class performing transistors from commodity to low RDSon MOSFETs A quality product from an experienced, high volume supplier SOT223 DFN2020 SOT89 1400  NXP is strongly committed to automotive quality standards  NXP has a track record of more than 60 years in developing and producing discretes  NXP is the #1 in small-signal discretes with a high production capacity A broad range of packages Many options for WLCSP, leaded SMD and ultra-small leadless packages. SO8 SOT457 1200 1000 SOT23AB 800 DFN1010 SOT363 600 SOT666 DFN1006 Leaded packages Leadless packages WLCSP SOT23 400 "1208" SOT323 200 SOT416 SOT723 VMT3 VESM 1.6 x 1.6 1.2 x 1.2 High RDSon   2N7002 family NX7002AK family   5x6 4.5 x 3 3x3 2x2   BSS84 family 1x1 1 x 0.6 Footprint size [mm]   BSS138 family Leadless packages provide the same power capability compared to larger packages on a smaller size or provide a better thermal performance on the same footprint size. For that reason they replace established leaded packages in many applications.   PMT…/ PHT… SOT223   PMPB … single DFN2020   PMV … SOT23   PMDPB … dual DFN2020   PMN … SOT457   PMZ … single DFN1006   PMF … SOT323   PMXB … single DFN1010   PMCM4 … WLCSP4   PMG … SOT363   PMDXB ... dual DFN1010   PMCM6 … WLCSP6 MOSFETs Low RDSon NX3008 family   Leadless DFN and WLCSP packages – dedicated solutions for your application Block diagram for typical MOSFET application RDSon [mΩ] RF functions WLAN, BT, GPS, FM, NFC LTE, 3G, 2G RF 1000 Touchscreen Battery Sensors for proximity, light temp, accel Front camera Rear camera USB 2.0/3.0 APP processor + GPU SD-, eMMC-cards DFN1010B-6 Dual 1.0 x 0.6 x 0.37 mm 120 mΩ and higher 1.1 x 1.0 x 0.37 mm 470 mΩ and higher High RDSon DFN2020-6 Dual PMU 2.0 x 2.0 x 0.65 mm 30 – 80 mΩ LCD Panel Backlight unit DFN1006-3 Single 100 10 HDMI/MHL (ext. RAM) Amps, codecs 76 RDSon performance for a given package size LED flash WLCSP-4 0.78 x 0.78 x 0.35 mm 35 – 55 mΩ DFN1010D-3 Single DFN2020-6 Single WLCSP-6 1.1 x 1.0 x 0.37 mm 34 – 100 mΩ 1.48 x 0.98 x 0.35 mm 15 – 20 mΩ 1.0 x 1.0 1.5 x 1.0 2.0 x 2.0 x 0.65 mm 10 – 55 mΩ Charger 1.0 x 0.6 0.8 x 0.8 Low RDSon 2.0 x 2.0 Package size [mm x mm] 77 Small-signal MOSFETs Small-signal MOSFETs Small-signal MOSFETs in ultra-small DFN1006 and DFN1006B packages types in bold represent new products DFN1006-3 (SOT883) DFN1006B-3 (SOT883B) Size (mm) 1.0 x 0.6 x 0.48 1.0 x 0.6 x 0.37 Ptot (mW) 250 250 Package Size (mm) 5.3 16 1.6 2 10 V - Configuration Polarity 4.5 V 2.5 V 1.8 V 1.5 V 1.2 V 120 160 210 270 - 1.6 0.45 0.95 5.3 16 1.6 2 - 170 200 240 300 - 1 0.5 0.95 6 86 0.45 2 - 270 360 470 600 - PMZ130UNE PMZB150UNE 8 PMZ290UNE2 PMZB290UNE2 0.6 0.45 0.95 5.6 19 0.4 1 - 470 620 845 1125 2210 PMZ600UNE PMZB600UNE 1.5 0.45 0.95 5 17 1.6 2 - 210 240 270 300 - PMZ200UNE PMZB200UNE 1 0.45 0.95 4 12 0.8 2 - 390 460 30 610 - PMZ390UNE PMZB390UNE 0.59 0.45 0.95 4 12 0.6 2 - 550 660 770 890 - PMZ550UNE PMZB550UNE 0.45 1.1 2.1 5 12 0.5 2 1000 1300 - - - - 2N700BKM 2N7002BKMB 0.35 1.1 2.1 4.7 6.9 1 2 2200 2500 - - - - NX7002BKM NX7002BKMB Single 60 20 1.4 20 50 0.45 0.95 4 26 1.3 1.8 - 330 420 520 - - PMZ350UPE PMZB350UPE Complementary 8 0.5 30 P-ch Dual P-channel DFN1010B-6 (SOT1216) 1.1 x 1.0 x 0.37 1.1 x 1.0 x 0.37 1000 350 0.45 0.95 2.3 13.5 1.19 1 - 1020 1270 1700 2300 3500 PMZ950UPE PMZB950UPE 1 0.45 0.95 2.9 22 1.45 2 - 430 470 750 950 - PMZ320UPE PMZB320UPE 0.41 0.45 0.95 3 14 0.7 2 - 1200 1700 2100 3000 - PMZ1200UNE PMZB1200UPE 0.23 1.1 2.1 13 48 0.26 1 4500 5700 - - - - BSS84AKM BSS84AKMB ESD RDSon typ (mΩ) @ VGS = toff QG typ protectyp (nC) tion (ns) 10 V 4.5 V 2.5 V 1.8 V 1.5 V 1.2 V (kV) VDS (V) VGS (V) ID (A) VGS(th) min (V) VGS(th) max (V) ton typ (ns) 12 8 3.2 0.4 0.9 6 18 6.6 1 - 34 39 46 50 121 PMXB40UNE 20 8 3.2 0.5 0.9 6 17 5.7 1 - 42 48 56 64 - PMXB43UNE 3.2 1 2 3 11 3.6 - 49 56 - - - - PMXB56EN 3.2 1 2.5 3 11 6 1 44 56 - - - - PMXB65ENE 30 20 80 20  1.1 1.3 2.7 2 9 3  2 345 390 - - - - PMXB360ENEA 12 8 3.2 0.4 1 6.2 27 6.7 1.5 - 59 78 120 198 880 PMXB65UPE 2.9 0.4 1 6 29 6.8 1 - 69 86 130 205 950 PMXB75UPE 1.2 0.45 0.95 3 18 1.25 1.5 - 350 450 600 760 1200 PMXB350UPE PMXB120EPE 20 8 30 20 2.4 1 2.5 4 16 6.2 1 100 125 - - - - 20 8 0.6 0.45 0.95 5.6 19 0.4 1 - 470 620 845 1125 2210 PMDXB600UNE 30 8 0.59 0.45 0.95 4 12 0.6 2 - 550 660 770 890 - PMDXB550UNE 60 20 0.26 1.1 2.1 4.7 6.9 1 2 2200 2500 - - - - NX7002BKXB 20 8 0.5 0.45 0.95 2.3 13.5 1.19 1 - 1020 1270 1700 2300 3500 PMDXB950UPE PMDXB1200UPE 30 8 0.41 0.45 0.95 3 14 0.7 2 - 1200 1700 2100 3000 - N 20 8 0.6 0.45 0.95 5.6 19 0.4 1 - 470 620 845 1125 2210 P 20 8 0.5 0.45 0.95 2.3 13.5 1.19 1 - 1020 1270 1700 2300 3500 N 30 8 0.59 0.45 0.95 4 12 0.6 2 - 550 660 770 890 - P 30 8 0.41 0.45 0.95 3 14 0.7 2 - 1200 1700 2100 3000 - PMCXB900UE PMCXB1000UE 8 20 Key features   N- and P-channel   Low RDSon down to 120 mΩ   ID up to 1.9 A   Low voltage drive (VGS(th) = 0.65 V typ)   Voltage range of 20 to 60 V   ESD protection of up to 2 kV Package 1.0 x 0.6 mm footprint Single package with different heights: - 0.5 mm for DFN1006 (SOT883) - 0.37 mm for DFN1006B (SOT883B) Power dissipation (Ptot) of 360 mW DFN1006 – The ideal replacement for SOT416 75% size reduction! Key applications Smartphones   Wearables Tablets Key features N- and P-channel Low RDSon to 34 mΩ ID to 3.2 A Low voltage drive (VGS(th) = 0.65 V typ)   Voltage range of 12 to 80 V ESD protection to more than 1 kV Package   1.1 x 1.0 x 0.37 mm package size   Single and dual packages   High power dissipation (Ptot) of 1000 mW single and 350 mW for dual package   Single package with tin-plated, solderable side pads for improved mounting and automotive conformity MOSFETs 30 0.95 RDSon typ (mΩ) @ VGS = 8 N-channel 20 0.45 ESD protection (kV) N-channel ID VGS(th) VGS(th) ton typ toff typ QG typ (A) min (V) max (V) (ns) (ns) (nC) P-channel VGS (V) 1.9 78 DFN1010D-3 (SOT1215) Ptot (mW) VDS (V) types in bold represent new products Package N-ch Polarity Small-signal MOSFETs in DFN1010D-3 single and DFN1010B-3 dual packages DFN1010B-6 dual – The ideal replacement for SOT363 60% size reduction! 79 Small-signal MOSFETs DFN2020 – The low RDSon choice for values > 10 mΩ Small-signal MOSFETs in DFN2020MD-6 single and DFN2020-6 dual packages types in bold represent new products DFN2020MD-6 (SOT1220) DFN2020-6 (SOT1118) Size (mm) 2.0 x 2.0 x 0.65 2.0 x 2.0 x 0.65 Ptot (mW) 1250 1250 In the spotlight Package PMPB15XP – Low RDSon P-channel MOSFET in DFN2020 12 V P-channel with RDSon of 15 mΩ @ VGS = 4.5 V (typ) ID max of 11.8 A for medium current load switch Configuration Polarity Small and leadless ultrathin SMD plastic package: 2.0 x 2.0 x 0.65 mm VDS (V) Exposed drain pad for excellent thermal conduction VGS (V) ID (A) VGS(th) min (V) VGS(th) max (V) 8 11.3 0.4 1 RDSon specified to 1.8 V for low drive voltages RDSon typ (mΩ) @ VGS = ESD ton typ toff typ QG typ protection (ns) (ns) (nC) (kV) 10 V 4.5 V 2.5 V 1.8 V 9 26 8.8 2 - 14 17 21 PMPB12UNE 12.9 0.4 0.9 13 54 23 2.2 - 10 12 16 PMPB10XNE 5.9 0.75 1.25 16 49 31 2 - 14 20 - PMPB20XNEA DFN2020MD-6 (SOT1220) 10.4 0.4 0.9 9 31 13.4 - - 18 21 23 PMPB15XN 10.1 0.4 0.9 9 31 11.6 2.1 - 19 23 31 PMPB23XNE Single package 2 x 2 x 0.65 mm 11.3 0.4 0.9 12 54 24 2.2 - 13 14 17 PMPB13XNE 20 Package N- and P-channel Low RDSon down to 10 mΩ   ID up to 13 A Low voltage drive (VGS(th) = 0.65 V typ)   Voltage range of 12 to 100 V   ESD protection of 3 kV   2.0 x 2.0 x 0.65 mm package size   Single and dual packages   H  igh power dissipation (Ptot) of 1250 mW for single and dual packages   Single package with tin-plated,   solderable side pads for improved mounting and automotive conformity 12 30 5 0.4 0.9 8 33 12.4 2.1 - 28 32 37 PMPB29XNE 5.5 0.45 1.2 6 21 5.1 - - 37 55 - PMPB33XN 13 1 2 9 17 13.7 - 12 14 - - PMPB11EN 20 60 12 P-channel 2 9 9 7.2 - 16.5 20.5 - - PMPB20EN 1.3 2.7 4.5 13.5 7.5 1 42 48 - - PMPB55ENEA 3 1.3 2.7 4 10.5 6.2 2.7 72 85 - - PMPB85ENEA 2.8 1.3 2.7 5 15 9.9 2.8 80 92 - - PMPB95ENEA 1.9 1.3 2.7 3.5 9.5 4.8 2 175 195 - - PMPB215ENEA 11.8 0.47 0.9 18 85 67 - - 15 17 21 PMPB15XP 10.3 0.47 0.9 16 43 28.8 - - 19 21 27 PMPB19XP 10.3 0.47 0.9 13 92 30 2.4 - 19 22 28 PMPB20XPE 20 12 Generic charging path application 20 1 4 20 Single 80 10.4 12 12 30 5 0.47 0.9 12 91 30 2.3 - 28 31 36 PMPB29XPE 7.9 0.47 0.9 12 62 15 - - 30 35 45 PMPB33XP 5 0.47 0.9 9 57 15.6 2.3 - 39 45 56 PMPB43XPE 5 0.47 0.9 15 28 14 - - 47 54 74 PMPB47XP 8.8 1 2.5 10 28 30 - 24 32 - - PMPB27EP 6.8 1 2.5 7.4 27 17 - 40 55 - - PMPB48EP 5.3 0.4 0.9 4 40 14.4 - - 32 40 60 PMDPB30XN MOSFETs Key features N-channel 12 N-ch 20 20 12 30 12 3.1 0.75 1.25 9 19 2.9 2 - 55 72 - PMDPB56XNEA 3.1 0.5 1.5 6 18 1.65 1.8 - 95 130 - PMDPB95XNE2 4.5 0.45 0.95 7 41 6.3 2 - 58 74 97 PMDPB58UPE 3.7 0.45 0.95 6 47 5.4 2 - 82 107 142 PMDPB85UPE 4.5 0.47 0.9 4 135 16.5 - - 55 75 110 PMDPB55XP 4.2 0.75 1.25 7 33 5 2 - 66 98 3.7 0.4 1 6 120 5.7 - - 80 95 120 PMDPB80XP 3.8 0.45 1 3 112 5.2 - - 70 89 - PMDPB70XP 3.7 0.4 1 6 120 5.7 - - 80 95 120 PMFPB8032XP 3.7 0.4 1 6 120 5.7 - - 80 95 120 PMFPB8040XP 3.4 0.45 1 3 112 5.2 - - 85 105 - PMC85XP 8 P-channel Dual Products for charging path application Type 80 Package VDS/VGS (V) ID (A) ESD protection (kV) RDSon typ (mΩ) @ VGS = 20 12 30 12 20 12 Application 10 V 4.5 V 2.5 V 1.8 V PMPB15XP DFN2020MD-6 12 / 12 11.8 1.5 - 15 17 21 Charger Switch, Battery FET PMPB20EN DFN2020MD-6 30 / 20 10.4 - 16.5 20.5 - - Buck Converter PMPB10XNE DFN2020MD-6 20 / 18 12.9 2.2 - 10 12 16 Battery Pack MOSFETSchottky P Pre-biased NPN P 30 12 PMDPB70XPE N 20 12 5.3 0.4 0.9 4 40 14.4 - - 26 33 50 P 20 12 4.5 0.4 0.9 4 40 8.1 - - 55 75 110 Complementary PMCPB5530X 81 Small-signal MOSFETs in WLCSP4 and WLCSP6 packages Small-signal MOSFETs for automotive WLCSP6 Key features Single package 1.48 x 0.98 x 0.35 mm   Two package outlines  · WLCSP4: 0.78 x 0.78 mm package size  · WLCSP6: 1.48 x 0.98 mm package size   Ultra-low height of 0.35 mm   High power dissipation (Ptot) of 1300 mW DFN2020MD-6 (SOT1220) 12 V P-ch with RDSon of typ. 19 mΩ @ VGS = 4.5 V ID max of 8.2 A for high current load switch Single package 2 x 2 x 0.65 mm Ultra-small footprint: 1.48 x 0.98 x 0.35 mm Low voltage gate drive with VGSth typ. 0.6V RDSon specified down to 1.8 V for low drive voltages types in bold represent new products WLCSP4 WLCSP6 Package Size (mm) 0.78 x 0.78 x 0.35 1.48 x 0.98 x 0.35 Ptot (mW) 1300 1300 Polarity VDS (V) VGS (V) N 12 8 P 12 8 ID (A) VGS(th) min (V) VGS(th) max (V) ton typ (ns) toff typ (ns) QG typ (nC) ESD protection (kV) 5 0.4 0.9 6.3 27 5.5 2 57 66 77 90 PMCM440VNE 6 0.4 0.9 6.3 30 6 2 36 46 60 86 PMCM4401VNE 8.4 0.4 0.9 11 80 15.4 2 21 24 28 33 PMCM650VNE 9.6 0.4 0.9 10.8 97.5 16.1 2 15 18 22 30 PMCM6501VNE 4.9 0.4 0.9 4.8 25.1 6.8 2 55 77 110 - 8.2 0.4 0.9 8 72 19.6 2 19 25 37 -   Broad portfolio of standard leaded   packages in SOT23 and SOT457 and innovative leadless DFN packages with solderable side pads   Low RDSon MOSFETS with RDSon down   to 14 mΩ   Standard high RDSon MOSFETs in different   packages with 2 kV ESD protection   Broad portfolio of 60 V low RDSon MOSFETs   RDSon typ (mΩ) @ VGS = 4.5 V 2.5 V 1.8 V 1.5 V PMCM4401VPE PMCM6501VPE DFN1010 and DFN2020 with solderable side pads PMPB85ENEA - Automotive-compliant 60 V N-channel MOSFET with ID max of 4.4 A in DFN2020MD-6 (SOT1220) 60 V N-channel with RDSon of typ. 72mΩ @ VGS = 10 V Small and leadless ultrathin SMD plastic package: 2.0 x 2.0 x 0.65 mm Exposed drain pad for excellent thermal conduction ESD protection to 2 kV HBM AEC-Q101 qualified Reference design for LED lighting MOSFETs Package PMCM6501VPE– Ultra-low RDSon P-ch MOSFET in WLCSP6 In the spotlight In the spotlight   N- and P-channel   Low RDSon down to 15 mΩ   ID up to 9.6 A   Low voltage drive (VGSth = 0.6 V typ)   VDS voltage of 12V   ESD protection of 2 kV PMPB215ENEA DFN RDSon [m ] 200 Performance gain 90 WLCSP 60 30 2 x 2 mm 82 1.5 x 1 mm 1 x 1 mm 0.8 x 0.8 mm Package size MOSFETs in WLCSP   Improved RDSon performance   compared to DFN packages     Smallest footprint     High power capability of 1300 mW     Ideal for mobile and spaceconstrained applications PMPB215ENEA PMPB215ENEA Tin plated solderable side pads enable automatic optical inspection (AOI) 83 Small-Signal MOSFETs Small-Signal MOSFETs Automotive-compliant small-signal MOSFETs types in bold represent new products SOT223 SOT457 (SC-74) 6.5 x 3.5 x 1.65 2.9 x 1.5 x 1.0 1700 600 250 PMN28UNEA PMV28UNEA SOT23 SOT363 (SC-88) SOT323 (SC-70) SOT666 DFN2020MD-6 (SOT1220) DFN2020-6 (SOT1118) DFN1010D-3 (SOT1215) DFN1006-3 (SOT883) Package Size (mm) Ptot (mW) Configuration VDS (V) 20 ID (A) VGS(th) min (V) VGS(th) max (V) ton typ (ns) toff typ (ns) 10 V 4.5 V 2.5 V 1.8 V 8 4.7 0.45 1 8.2 39.5 6.2 2 - 24 29 40 12 6.3 0.75 1.25 16 44 9.9 2 - 16 24 - PMV20XNEA 8 0.4 0.6 1.1 26 88 0.52 2 - 1000 1400 2000 NX3008NBK 3.1 0.75 1.25 9 19 2.9 2 - 55 72 - 5.5 1 2.5 8 33 12.6 2 17 22 - - 12 20 40 20 N-channel single 60 80 20 20 P-channel N P 84 2.5 6.3 14.1 6 2 30 39 - - PMV50ENEA 1 2.5 6 11 3.6 2 54 70 - - PMV100ENEA 3.1 1 2.5 - - - 1 65 88 - - PMV65ENEA 2.5 1 2.5 14 14 2.4 1 95 120 - - PMV130ENEA 4 1.3 2.7 4.5 13.5 7,5 1 42 48 - - 3.1 1.3 2.7 9 33 12.7 2 46 52 - - PMV55ENEA PMV120ENEA 4 1.3 2.7 4 10.5 6.2 2.7 72 85 - - 2.1 1.3 2.7 6.4 15.9 5.9 2 96 108 - - PMN120ENEA PMN230ENEA 1.5 1.3 2.7 6.3 13 3.9 2 176 196 - - 0.8 1.3 2.7 5.3 10.2 2.4 2 300 332 - - PMPB85ENEA PMV230ENEA PMV450ENEA 0.36 0.9 1.5 5 13 0.72 - 900 1000 - - BSS138P BSS138PW 0.36 0.48 1.6 10 58 0.6 1.5 1000 1100 1400 - BSS138BK BSS138BKW 2N7002BKW 0.3 1 2.5 11 19 0.5 2 1000 1300 - - 2N7002BK 0.3 1 2.5 16 60 1.09 3 1100 1300 - - 2N7002CK BSS138AKA 2N7002BKM 0.2 0.8 1.5 5 36 0.39 yes 2700 3000 4000 - 1.9 1.3 2.7 3.5 9.5 4.8 2 175 195 - - PMPB215ENEA 2.8 1.3 2.7 5 15 9.9 2.8 80 92 - - PMPB95ENEA  1.1 1.3 2.7 2 9 3  2 345 390 - - 1.5 1.3 2.7 4.8 9.3 4.5 1 285 300 - - PMT280ENEA PMT560ENEA PMXB360ENEA 1.3 2.7 5.7 10.2 2.9 1 527 555 - - 0.95 10 117 0.45 2 - 380 620 1100 30 8 0.4 0.6 1.1 26 88 0.52 2 - 1000 1400 2000 NX3008NBKS 0.3 1 2.5 11 19 0.5 2 1000 1300 - - 2N7002BKS BSS138BKS 30 250 PMPB55ENEA PMN55ENEA 0.5 single Compl 1 3 1.1 12 dual 3.9 0.8 20 1000 PMV25ENEA 8 8 1250 PMDPB56XNEA PMN25ENEA 20 20 1250 PMPB20XNEA 20 60 300 NX3008NBKW 100 dual 200 RDSon typ (mΩ) @ VGS = VGS (V) 30 300 1.0 x 0.6 x 0.5 0.36 0.48 1.6 10 58 0.6 1.5 1000 1100 1400 - 0.36 0.9 1.5 5 13 0.72 - 900 1000 - - 6 0.45 0.95 8 50 15.6 4 - 37 45 59 PMDT290UNE BSS138PS PMN40UPEA 2 0.5 1.1 7 50 6 - - 100 155 210 NX2301P 4.5 0.45 0.95 11 83 14.7 2 - 27 38 50 PMV27UPEA 5.7 0.75 1.25 15 37 15 2 - 27 39 - PMN27XPEA 5.7 0.75 1.25 17 33 11.5 2 - 41 56 - PMN42XPEA 4.5 0.75 1.25 7.9 59 11 2 - 28 42 - PMN30XPEA PMV30XPEA 3.5 0.75 1.25 11 61 8.5 - - 48 71 - PMN48XPA PMV48XPA 4.1 0.75 1.25 15 51 8.7 - - 48 72 - 2.8 0.75 1.25 7 36 5 2 - 67 99 - 4.1 0.75 1.25 7 40 5.2 2 - 70 101 - 2.3 0.7 1.3 5.3 36 3.4 2 - 100 155 - 8 0.23 0.6 1.1 49 103 0.55 2 - 2800 5300 - 20 4.2 1 3 6.1 3.7 12.8 2 35 47 - - 40 20 1.5 1 2.5 4 26 4.7 1 180 220 - - 50 20 0.2 1.1 2.1 24 73 0.26 1 5300 6000 - - 2.2 1 3 - - - 2 99 110 - - 60 20 0.9 1 3 - - - 2 217 241 - - 70 20 2.3 1 3 - - - 2 156 177 - - NX3008NBKV MOSFETs Polarity ESD QG typ protection (nC) (kV) 2.9 x 1.3 x 1.0 2.0 x 1.25 x 0.95 2.0 x 1.25 x 0.95 1.6 x 1.2 x 0.55 2.0 x 2.0 x 0.65 2.0 x 2.0 x 0.65 1.1 x 1.0 x 0.37 PMV65XPEA PMN70XPEA PMV100XPEA NX3008PBK PMN50EPEA NX3008PBKW PMV50EPEA PMV250EPEA BSS84AK PMN100EPEA PMV100EPEA PMN240EPEA PMV240EPEA BSS84AKW BSS84AKM PMT200EPEA 20 8 0.55 0.5 1.3 48 152 0.76 2 - 670 1200 1800 30 8 0.2 0.6 1.1 49 103 0.55 2 - 2800 5300 - NX3008PBKS PMDT670UPE NX3008PBKV 50 20 0.16 1.1 2.1 24 73 0.26 1 5300 6000 - - BSS84AKS BSS84AKV 20 8 0.73 0.5 0.95 10 117 0.45 2 - 290 420 600 20 8 0.5 0.5 1.3 48 152 0.76 2 - 670 1200 1800 PMGD290UCEA 85 Small-signal MOSFETs Small-signal MOSFETs Small-signal MOSFETs single (N-channel) types in bold represent new products SOT223 SOT457 (SC-74) SOT23 SOT323 (SC-70) DFN1006-3 (SOT883) DFN1006B-3 (SOT883B) Size (mm) 6.5 x 3.5 x 1.65 2.9 x 1.5 x 1.0 2.9 x 1.3 x 1.0 2.0 x 1.25 x 0.95 1.0 x 0.6 x 0.48 1.0 x 0.6 x 0.37 P tot (mW) 1700 600 250 200 250 250 PMN28UNEA PMV28UNEA Package VGS (V) 8 20 12 8 12 30 20 40 20 55 10 60 100 86 20 20 ID (A) VGS(th) min (V) VGS(th) max (V) ESD ton typ (ns) toff typ (ns) QG typ (nC) protection (kV) RDSon typ (mΩ) @ VGS = 10 V 4.5 V 2.5 V 1.8 V 4.7 0.45 1 8.2 39.5 6.2 2 - 24 29 40 1.9 0.4 1 8 31 2.2 2 - 63 77 114 2.2 0.4 1 6 21 2.6 2 - 64 78 110 1.9 0.45 0.95 5.3 16 1.6 2 - 120 155 195 1.6 0.45 0.95 5.3 16 1.6 2 - 155 190 235 1 0.5 0.95 6 86 0.45 2 - 270 360 470 0.6 0.45 0.95 5.6 19 0.4 1 - 470 620 845 6.3 0.75 1.25 16 44 9.9 2 - 16 24 - 8.6 0.47 0.9 7 135 7.7 - - 15 18 22 9.1 0.4 0.9 9 31 12 1 - 15 19 22 5.4 0.4 0.9 7 35 6.2 - - 24 30 40 6 0.4 0.9 5.5 22 5.1 1 - 28 38 42 1.5 0.45 0.95 5 17 1.6 2 - 210 240 270 PMF63UNE PMV65UNE PMZ130UNE PMZB150UNE PMZ290UNE2 PMZB290UNE2 PMZ600UNE PMZB600UNE PMZ200UNE PMZB200UNE PMV20XNEA PMV16XN PMN16XNE PMV30UN2 PMN30UNE 1 0.45 0.95 4 12 0.8 2 - 390 460 530 PMZ390UNE PMZB390UNE 0.59 0.45 0.95 4 12 0.6 2 - 550 660 770 PMZ550UNE PMZB550UNE NX7002BKM NX7002BKMB 0.4 0.6 1.1 26 88 0.52 2 - 1000 1400 2000 NX3008NBK 7.2 0.4 0.9 8 33 12.4 2 - 19 22 17 PMV20XNE 5.7 0.4 0.9 9 34 7 - - 33 42 54 4.4 0.4 0.9 9 34 7 - - 36 43 56 0.9 0.5 1.5 8 11 0.74 2 - 234 324 - 7.6 1 2 9 9 7.2 - 17 21 - - 5.5 1 2.5 8 33 12.6 2 17 22 - - 3.9 1 2.5 6.3 14.1 6 2 30 39 - - 3.1 1 2.5 18 78 6.5 - 28 37 - - 4.5 1 2.5 3 11 6 1 30 44 - - PMN30UN PMV40UN2 PMF250XNE PMV20EN PMN25ENEA PMV25ENEA PMV50ENEA PMV37EN2 PMN40ENE 5.1 1 2 3 11 3.6 - 35 43 - - PMV45EN2 2.1 1 2.5 3 15 2.6 2 70 90 - - PMV90ENE 0.18 0.8 1.5 10 51 0.34 - 2700 3000 4000 - NX3020NAK 3,1 1 2,5 - - - 1 65 88 - - PMV65ENEA 2.5 1 2.5 14 14 2.4 1 95 120 - - PMV130ENEA 2400 3100 0.3 0.4 1.3 4 11 1 3 - 2300 3.1 1.3 2.7 9 33 12.7 2 46 52 2.1 1.3 2.7 6.4 15.9 5.9 2 96 108 - NX3008NBKW MOSFETs VDS (V) NX3020NAKW BSH111BK - PMN55ENEA PMV55ENEA - PMN120ENEA PMV120ENEA PMN230ENEA PMV230ENEA 1.5 1.3 2.7 6.3 13 3.9 2 176 196 - - 0.8 1.3 2.7 5.3 10.2 2.4 2 300 332 - - PMV450ENEA 0.19 0.8 1.5 6 11 0.33 yes 2800 3500 4500 - NX138AK NX138AKW 0.27 0.5 1.5 7.9 12.5 0.49 2 2100 2200 2600 - NX138BK NX138BKW 0.1 0.6 1.4 2 5 2 2800 3800 - - BSN20BK 0.19 1.1 2.1 12 34 0.33 yes 3000 3700 - - NX7002AK NX7002AKW 0.27 1.1 2.1 4.7 6.9 1 2 2200 2500 - - NX7002BK NX7002BKW 1.5 1.3 2.7 4.8 9.3 4.5 1 285 300 - - PMT280ENEA 1.1 1.3 2.7 5.7 10.2 2.9 1 527 555 - - PMT560ENEA 87 Small-signal MOSFETs Small-signal MOSFETs Small-signal MOSFETs single (P-channel) types in bold represent new products SOT223 SOT457 (SC-74) SOT23 SOT363 (SC-88) SOT323 (SC-70) DFN1006-3 (SOT883) DFN1006B-3 (SOT883B) Size (mm) 6.5 x 3.5 x 1.65 2.9 x 1.5 x 1.0 2.9 x 1.3 x 1.0 2.0 x 1.25 x 0.95 2.0 x 1.25 x 0.95 1.0 x 0.6 x 0.48 1.0 x 0.6 x 0.37 P tot (mW) 1700 600 250 300 200 250 250 Package VGS (V) VGS(th) min (V) ID (A) 8 20 12 8 30 20 VGS(th) max (V) ESD ton typ (ns) toff typ (ns) QG typ (nC) protection (kV) RDSon typ (mΩ) @ VGS = 10 V 4.5 V 2.5 V 1.8 V 5.7 0.45 0.95 39 122 21 - - 27 36 57 5.6 0.45 0.95 11 83 14.7 2 - 27 38 50 PMN27UP PMV27UPE 5.3 0.45 0.95 41 122 14.7 2 - 30 38 51 PMV33UPE 5.4 0.45 0.95 34 128 15.5 - - 34 42 57 PMN34UP 6 0.45 0.95 29 84 15.6 4 - 37 45 59 PMN40UPE PMN50UPE PMV32UP 4 0.47 0.9 - - 10.5 3 - 50 57 70 2 0.5 1.1 7 50 6 - - 100 155 210 PMV50UPE NX2301P 1.2 0.45 0.95 33 52 3.3 - - 170 210 280 PMV160UP BSH205G2 0.75 0.4 - 6.5 65 - - - 180 - 420 1.4 0.45 0.95 9 35 1.3 1.8 - 330 420 520 PMZ350UPE PMZB350UPE 0.5 0.45 0.95 2.3 13.5 1.19 1 - 1020 1270 1700 PMZ950UPE PMZB950UPE 4.5 0.75 1.25 7.9 59 11 2 - 28 42 - PMN30XPEA 5.7 0.75 1.25 37 66 15 2 - 27 39 - PMN27XPE 6.8 0.47 0.9 12 62 15 - - 30 35 48 PMN30XP 5.7 0.75 1.25 44 60 11.5 2 - 41 56 - PMN42XPE 4.1 / 3.5 0.75 1.25 24 84 8.5 - - 48 71 - PMN48XP 4.4 0.47 0.9 7 135 7.7 - - 48 60 82 PMV30XPEA PMV48XP PMV50XP PMN52XP 4.7 0.47 0.9 5.1 141 8.5 - - 50 64 88 3.9 0.55 0.95 28 101 7.6 - - 65 90 - PMV65XP 3.3 0.75 1.25 7 36 5 2 - 67 99 - PMV65XPE 4.1 0.75 1.25 20 57 5.2 2 - 70 101 - PMN70XPE 3.9 0.47 0.9 6 120 5 - - 72 88 110 PMN70XP 3.2 0.47 0.9 6 120 5 - - 77 95 120 3.2 0.45 1 20 170 5 - - 80 95 120 2 0.65 1.15 48 64 4.8 - - 90 125 - 2.3 0.7 1.3 5.3 36 3.4 2 - 100 155 - PMV75UP PMN80XP PMG85XP PMV100XPEA 1 0.65 1.15 26 44 2.6 - - 175 240 - 1 0.45 0.95 2.9 22 1.45 2 - 400 480 600 PMZ320UPE PMZB320UPE 0.41 0.45 0.95 3 14 0.7 2 - 1200 1700 2100 PMZ1200UPE PMZB1200UPE 0.23 0.6 1.1 49 103 0.55 2 - 2800 5300 - 4.2 1 3 6.1 3.7 12.8 2 35 47 - - PMN50EPEA PMN70EPE BSS84AKM BSS84AKMB 3.3 1 3 - - - 2 60 96 - - 40 20 1.8 1 2.5 10 40 4.7 1 180 220 - - 50 20 0.2 1.1 2.1 24 73 0.26 1 5300 6000 - - 60 20 2.2 1 3 - - - 2 99 110 - - 70 20 0.9 1 3 - - - 2 217 241 - - 2.3 1 3 - - - 2 156 177 - - PMF170XP NX3008PBK NX3008PBKW PMV50EPEA PMV250EPEA BSS84AK PMN100EPEA PMV100EPEA PMN240EPEA PMV240EPEA BSS84AKW PMT200EPEA 1) MOSFETs VDS (V) SOT23 with enhanced thermal performance Small-signal MOSFET–Schottky combination DFN2020-6 (SOT1118) Size (mm) 2.0 x 2.0 x 0.65 P tot (mW) 1250 Configuration Single + Schottky 88 VDS (V) 20 VGS (V) 8 ID (A) VGS(th) VGS(th) ton typ toff typ QG typ min (V) max (V) (ns) (ns) (nC) IF (A) VR (V) VF typ. (mV) RDSon typ (mΩ) @ VGS = 4.5 V 2.5 V 1.8 V 3.7 0.4 1 20 170 5.7 2 30 455 80 95 120 PMFPB8040XP 3.7 0.4 1 20 170 5.7 2.2 30 325 80 95 120 PMFPB8032XP In the spotlight Package PMV75UP – 20 V, 77 mΩ P-channel MOSFET Cross of Si2301 types Low-voltage gate drive with VGSth = 0.68 V (typ) Industry-standard SOT23 package RDSon specified to 1.8 V for low drive voltages 89 Small-signal MOSFETs Small-signal MOSFETs Small-signal MOSFETs dual types in bold represent new products SOT363 (SC-88) SOT666 DFN2020-6 (SOT1118) DFN1010B-6 (SOT1216) Size (mm) 2.0 x 1.25 x 0.95 1.6 x 1.2 x 0.55 2.0 x 2.0 x 0.65 1.0 x 1.0 x 0.37 P tot (mW) 300 300 1250 350 Package VDS (V) 20 VGS (V) 8 12 N-channel 8 30 12 20 60 20 8 P-channel 20 12 30 50 VGS(th) min (V) ID (A) VGS(th) max (V) ton typ (ns) toff typ (ns) QG typ (nC) ESD protection (kV) RDSon typ (mΩ) @ VGS = 10 V 4.5 V 2.5 V 1.8 V 0.8 0.5 0.95 10 117 0.45 2 - 290 420 600 0.6 0.45 0.95 5.6 19 0.4 1 - 470 620 845 5.3 0.4 0.9 4 40 14.4 - - 32 40 60 0.59 0.45 0.95 4 12 0.6 2 - 550 660 770 0.35 0.6 1.1 26 88 0.52 2 - 1000 1400 2000 PMDXB600UNE PMDPB30XN PMDXB550UNE NX3008NBKS NX3008NBKV PMDPB56XNEA 3.1 0.75 1.25 9 19 2.9 2 - 55 72 - 3.1 0.5 1.5 6 18 1.65 1.8 - 95 130 - 1 0.5 1.5 6.5 14 0.7 2 - 170 240 - PMGD175XNE PMDPB95XNE2 0.18 0.8 1.5 10 51 0.34 yes 2700 3000 4000 - NX3020NAKS 0.18 0.8 1.5 6 11 0.33 yes 2800 3500 4500 - NX138AKS 0.26 0.5 1.5 7.9 12.5 0.49 2 2100 2200 2600 - NX138BKS 0.17 1.1 2.1 12 34 0.33 yes 3000 3700 - - NX7002AKS 0.26 1.1 2.1 4.7 6.9 1 2 2200 2500 - - NX7002BKS 0.55 0.5 1.3 48 152 0.76 2 - 670 1200 1800 NX3020NAKV NX7002BKXB PMDT670UPE 4.5 0.45 0.95 7 41 6.3 2 - 58 74 97 0.5 0.45 0.95 2.3 13.5 1.19 1 - 1020 1270 1700 3.7 0.45 0.95 6 47 5.4 2 - 82 107 142 4.5 0.47 0.9 4 135 16.5 - - 55 75 110 PMDPB55XP 4.2 0.75 1 7 33 5 2 - 66 98 - PMDPB70XPE PMDPB80XP 3.7 0.4 1 6 120 5.7 - - 80 95 120 0.41 0.45 0.95 3 14 0.7 2 - 1200 1700 2100 0.2 0.6 1.1 49 103 0.55 2 - 2800 5300 - 12 3.8 0.45 1 3 112 5.2 - - 70 89 - 20 0.16 1.1 2.1 24 73 0.26 1 4500 5700 - - 8 PMDT290UNE PMDPB58UPE PMDXB950UPE PMDPB85UPE PMDXB1200UPE NX3008PBKS NX3008PBKV BSS84AKS BSS84AKV PMDPB70XP Small-signal MOSFETs complementary Package Type NX1029X NX3008CBKV SOT666 (1.6 x 1.2 x 0.55) SOT363 (SC-88) (2.0 x 1.25 x 0.95) PMDT290UCE DFN2020-6 (2.0 x 2.0 x 0.65) 90 RDSon typ (mΩ) @ VGS = Polarity VDS (V) VGS (V) ID (A) VGSth min (V) VGSth max (V) ton typ (ns) toff typ (ns) QG typ (nC) ESD protection (kV) 10 V 4.5 V 2.5 V 1.8 V 1.5 V N 60 20 0.33 1.1 2.1 11 19 0.5 2 1000 1300 - - - - P 50 20 0.17 1.1 2.1 24 73 0.26 1 4500 5100 - - - - 1.2 V N 30 8 0.4 0.6 1.1 26 88 0.52 2 - 1000 1400 2000 - - P 30 8 0.22 0.6 1.1 49 103 0.55 2 - 2800 5300 - - - N 20 8 0.8 0.5 0.95 10 117 0.45 2 - 290 420 600 - - P 20 8 0.55 0.5 1.3 48 152 0.76 2 - 670 1200 1800 - - N 30 8 0.35 0.6 1.1 26 88 0.52 2 - 1000 1400 2000 - - P 30 8 0.2 0.6 1.1 49 103 0.55 2 - 2800 5300 - - - NX3008CBKS PMCXB900UE DFN1010B-6 (1.1 x 1.0 x 0.37) types in bold represent new products MOSFETs Polarity PMCXB1000UE N 20 8 0.6 0.45 0.95 5.6 19 0.4 1 - 470 620 845 1125 2210 P 20 8 0.5 0.45 0.95 2.3 13.5 1.19 1 - 1020 1270 1700 2300 3500 N 30 8 0.59 0.45 0.95 4 12 0.6 2 - 550 660 770 890 - P 30 8 0.41 0.45 0.95 3 14 0.7 2 - 1200 1700 2100 3000 - N 20 12 5.3 0.4 0.9 19 56 14.4 - - 26 33 50 - - P 20 12 4.5 0.47 0.9 18 56 16.5 - - 55 75 110 - - PMCPB5530X 91 4 steps select a power MOSFET 1 Select a voltage, e.g. 40 V 2 Select a package, e.g. LFPAK56 3 4 High-performance power MOSFETs MOSFET package selection Through-hold Surface-mount Choose an RDSon from our extensive range TO220  Industry standard  Up to 150 A LFPAK56  Power SO8  Up to 100 A TO220F  Industry standard  Up to 75 A LFPAK33  QFN/DFN3333 compatible  Up to 70 A Select a type and visit www.nxp.com/mosfets to download datasheets and models, and order samples MOSFETs PSMN part numbering Segment • Power silicon Max Channel Technology family • C = NextPower • D = NextPowerS3 • E = NextPower Live Package type • N = N-channel • B = D2PAK • D = DPAK RDSon in mΩ • E = I2PAK • 4R0 means 4 mΩ max at 25 °C • K = SO8 Voltage rating • BVDSS rating • L = QFN3333 • P = TO220 • Y = LFPAK56 I2PAK  Industry standard  Up to 120 A D2PAK  Industry standard  Up to 120 A Gate threshold voltage • L = Logic level • S = Standard level • X = TO220F (FULLPACK) • M = LFPAK33 • N = QFN2020 92 93 Featured product: NextPowerS3 Featured product: NextPowerS3 NextPowerS3 – perfectly balanced for DC/DC switching applications High switching frequencies Low spiking Thermal efficiency Typical competitor NextPowerS3 The challenge Low RDSon MOSFETs typically need a big die. Low Qg(tot) MOSFETs typically need a small die. The challenge for manufacturers is to create optimized power MOSFETS that have both low RDSon and low Qg(tot). Low Qg(tot) MOSFETs minimize switching losses, which is especially important at peak efficiency and in higher frequency designs Low RDSon MOSFETs minimize conduction (I2R) losses, which is especially important at high loads Increasing switching frequency from 300 KHz to 1 MHz allows a 70 - 80% reduction in inductor size. NextPowerS3’s excellent switching performance enables such design choices with minimal loss of efficiency. Thanks to optimised output capacitance, body diode and channel structure, NextPowerS3 MOSFETs exhibit “soft-recovery” switching behaviour, resulting in lower voltage spikes, faster decays and virtually no gate glitches. Packaged in the copper-clip based LFPAK package, NextPowerS3 features excellent thermal performance. As RDSon rises with temperature, keeping MOSFETs cool helps efficiency as well as reliability. Low leakage Specialist high sides Improved SOA Unique SchottkyPlus technology offers the benefits of an integrated Schottky diode without the problems associated with leakage current. The NextPowerS3 portfolio contains devices with multiple busbars and low Rg optimized for use as control FETs, further improving system efficiencies. A wide cell pitch makes NextPowerS3 an excellent choice for hot-swap, e-Fuse, and power OR-ing applications. Welcome to NextPowerS3. The Figure of Merit (FOM) of a MOSFET is calculated as the product of the RDSon and Qg(tot). A low FOM indicates good MOSFET performance in switching applications. Peak Peak Higher RDSon NextPowerS3 NextPowerS3 Package Efficiency Efficiency Typical competitor Typical competitor Load current Load current Comparing the performance of a NextPowerS3 Using a NextPowerS3 MOSFET, with a higher RDSon MOSFET with a competitor of similar RDSon typically than a competitor device, reduces the Qg(tot) still shows an efficiency performance advantage across further, resulting in an improved peak efficiency. the load range. Since conduction losses are the same At higher loads, increased conduction losses cancel for both devices, the advantage is more noticeable out the switching advantages and the two parts show at lower loads where switching losses contribute similar performance. proportionally more. 94 LFPAK33 (SOT1210) Power-SO (LFPAK56) VDS [max] (V) RDSon [max] @ VGS = 10 V (mΩ) RDSon [max] @ VGS = 4.5 V (mΩ) ID [max] (A) QG(tot) [typ] (nC) PSMN2R4-30MLD 30 2.4 3.2 70 16 PSMN4R2-30MLD 30 4.3 5.7 70 9.2 PSMN7R5-30MLD 30 7.6 10.3 57 5.8 PSMN0R9-30YLD 30 0.87 1.09 100 51 PSMN1R0-30YLD 30 1.02 1.3 100 38 PSMN1R2-30YLD 30 1.24 1.6 100 32 PSMN1R4-30YLD 30 1.42 1.85 100 27.6 PSMN2R4-30YLD 30 2.4 3.1 100 18 PSMN3R0-30YLD 30 3.1 4 100 14.5 PSMN4R0-30YLD 30 4 5.5 95 9.6 PSMN6R0-30YLD 30 6 8.35 66 6.7 PSMN6R1-30YLD 30 6 8.35 66 6.8 PSMN7R5-30YLD 30 7.5 10.2 51 5.8 PSMN1R0-40YLD 40 1.1 100 54 PSMN1R4-40YLD 40 1.4 100 45 Type number MOSFETs RDSon matched 95 Featured product: NextPowerS3 – the technology Typical competitor The importance of cell design The outstanding performance of NextPowerS3 is largely attributable to NXP’s unique “Super-junction” technology and optimization of cell structures. Most manufacturers of low-voltage MOSFETs use “Split Gate” technology to achieve low RDSon. NextPowerS3 uses a different approach to its cell design. NextPower Live! MOSFETs for a non-stop world Reliable linear-mode performance AND low RDSon efficiency in hot-swap and soft-start applications The drive for RDSon A MOSFET’s RDSon is given by the formula: RDSon = Rchannel + Rdrift + Rsubstrate + (Rpackage) Many manufacturers focus on reducing Rchannel to drive RDSon down. NXP’s Super-junction allows for an optimization of all three components for reduction in RDSon, while also enhancing switching performance and Safe Operating Area (SOA). NextPowerS3 Maximizing switching performance Switching losses result from the energy required to charge / discharge all the cell capacitances across the device. The total charge required is referred to as Qg(tot). With NextPower S3, Qg(tot) is lower and switching losses are kept to a minimum. This is especially beneficial at peak efficiency and in higherfrequency designs, which have a higher number of switching events. SOA and other benefits When a device is operating in its linear mode, the channel current generates localized heating effects, which can cause failure. Reverse recovery and diode leakage in SMPS www.nxp.com/quicklearning33 96 MOSFETs NXP has optimized the cell structure to keep this heating effect under control. As a result, NextPowerS3 enjoys a particularly strong SOA, which is important in hot-swap, e-Fuse, and power OR-ing designs. Non-stop applications Non-stop equipment  Cloud computing  Blade and rack servers  Network storage  Routers, switches & base stations  Communications infrastructure  RAID arrays  Industrial process control  Industrial PCs  Transaction processing  Programmable Logic Controllers (PLCs)  Traffic monitoring & signaling  CCTV digital video recorders  CCTV security  “Hot-swap” & “soft-start” systems NextPowerS3 MOSFETs for DC/DC buck regulators www.nxp.com/quicklearning32 97 Featured product: NextPower Live Mobile phones, ATMs, the internet, traffic signals – Featured product: NextPower Cordless so much of our daily life depends on 24/7/365 computers, communications, and storage, made possible by rack-based systems that can be maintained with the power on. NextPower Live MOSFETs are designed specifically for such applications:  Battery-powered tools, including everything from small engraving devices and screwdrivers to heavy-duty saws and agricultural tools, present a wide variety of requirements for driving the motor. The MOSFETs used in these systems have to perform at demanding levels and must have:  Low on-resistance for optimum battery life  Low thermal resistance for reduced junction temperature    When a replacement board is plugged into a live system, it is important that the in-rush current is carefully controlled, so as to protect the components on the board and ensure that other parts of the system experience no power disruption. This application requires MOSFETs with strong linear mode performance and a wide safe operating area (SOA) to manage current effectively and reliably.    Once the replacement board is safely installed, the MOSFET is turned fully ON. In this mode of operation, a low RDSon is of primary importance, helping to keep temperatures low while maximizing system efficiency.    Only NextPower Live MOSFETs offer reliable linear mode performance AND low RDSon efficiency.  Choice of logic- and standard-level gate drives, depending on battery voltage  Excellent avalanche ruggedness to withstand high-load conditions  Environmental robustness (wide operating/storage temperatures, harsh vibrations) High-current capability All source-bond wires  Competitive cost NextPower Live portfolio Package (for greater reliability)  High current capability (when the motor stalls, for example) Overall, the motor-control MOSFET needs to deliver automotive-grade 30 V for 12 V supplies used in computing applications 100 V for 48 V supplies used in computing telecommunications performance at a commercially competitive price Silicon die D2PAK (SOT404) PSMN1R5-30BLE PSMN3R4-30BLE PSMN4R8-100BSE PSMN7R6-100BSE NXP has developed a range of MOSFETs specifically aimed at motor-control applications. These are based on our highly reliable, automotive-qualified silicon, with specific package enhancements such as thicker wires and multiple bond points (“stitch bonding”) to spread the current evenly over the die surface. PSMN4R8-100PSE PSMN7R8-100PSE TO220 NXP’s long history in automotive MOSFETs means we have the know-how to produce devices with excellent avalanche ruggedness. The same PSMN2R0-30YLE PSMN013-100YSE expertise deployed in power steering and ABS systems worldwide is put to use in our devices for motor control and that means performance you MOSFETs LFPAK56 (Power-SO8) can count on. (specifically for PoE applications) LFPAK33 Single-shot avalance ruggedness www.nxp.com/quicklearning35 PSMN040-100MSE PSMN075-100MSE Max current (ID[max]) depends largely on the number and diameter of the aluminium bond wires. The NXP Power Tools portfolio is typically based on a standard of three 500 μm wires, allowing for an ID[max] rating of up to 150 A in a TO220 package. Some low RDSon devices, based on NXP's LFPAK56 (Power-SO8 compatible) package, can support an ID[max] of 300A, perfect for power tool applications where the motor control MOSFETs must be able to support high torque levels, Power MOSFET operation in linear mode www.nxp.com/quicklearning34 98 MOSFETs for Power-over-Ethernet (PoE) PSE applications www.nxp.com/quicklearning36 Next Power Live! MOSFETs for HOT SWAP and Power over Ethernet www.nxp.com/quicklearning29 even during “locked-rotor” events. NextPower Cordless MOSFETs for battery-powered tools www.nxp.com/quicklearning28 99 Power MOSFETs NextPower Cordless portfolio Power MOSFETs 20 - 25 V Type number VDS [max] (V) RDSon [max] @ VGS = 10 V (mΩ) RDSon [max] @ VGS = 4.5 V (mΩ) ID [max] (A) EAS at rated current [mJ] Package Gate theshold PSMN0R9-30YLD 30 0.87 1.09 300 - Logic Level PSMN1R0-30YLD 30 1.02 1.3 300 - Logic Level PSMN2R0-30YL 30 2 2.63 100 151 LFPAK56 Logic Level PSMN2R0-30YLE 30 2 3.5 100 370 LFPAK56 Logic Level PSMN2R5-30YL 30 2.4 3.16 100 103 LFPAK56 Logic Level PSMN2R6-30YLC 30 2.8 3.65 100 50 LFPAK56 Logic Level PSMN1R9-40PL 40 1.7 1.94 150 1008 TO220 (SOT78) Logic Level PSMN2R1-40PL 40 2.2 2.6 150 622 TO220 (SOT78) Logic Level PSMN1R5-40PS 40 1.6 - 120 1400 TO220 (SOT78) Standard Level PSMN2R2-40PS 40 2.1 - 100 1240 TO220 (SOT78) Standard Level PSMN2R5-60PL 60 2.6 3.15 150 655 TO220 (SOT78) Logic Level PSMN2R6-60PS 60 2.9 - 150 519 TO220 (SOT78) Standard Level PSMN3R3-60PL 60 3.4 3.8 130 404 TO220 (SOT78) Logic Level PSMN3R9-60PS 60 3.9 - 130 372 TO220 (SOT78) Standard Level PSMN4R2-60PL 60 4.3 4.3 130 372 TO220 (SOT78) Logic Level PSMN7R6-60PS 60 7.8 - 92 110 TO220 (SOT78) Standard Level For the most current product information go to www.nxp.com/mosfets (updated daily!) Heavy-duty tools with large batteries require MOSFETs Package LFPAK56; Power-SO8 (SOT669) LFPAK33 (SOT1210) D2PAK (SOT404) VDS [max] (V) RDSon [max] @ VGS = 10 V (mΩ) RDSon [max] @ VGS = 4.5 V (mΩ) ID [max] (A) QG(tot) [typ] (nC) PH3120L 20 2.65 3.7 100 48.5 PH2520U 20 2.7 100 78 PSMN0R9-25YLC 25 0.99 1.25 100 51 PSMN1R1-25YLC 25 1.15 1.5 100 39 PSMN1R2-25YL 25 1.2 1.85 100 50.6 PSMN1R2-25YLC 25 1.3 1.7 100 31 PSMN1R5-25YL 25 1.5 2.2 100 36 PSMN2R2-25YLC 25 2.4 3.15 100 18 PSMN2R9-25YLC 25 3.15 4.1 100 16 PSMN4R0-25YLC 25 4.5 5.8 84 10.9 PSMN6R0-25YLB 25 6.1 7.9 73 9 PSMN6R5-25YLC 25 6.5 8.5 64 8.4 PH2925U 25 3 100 92 PSMN2R8-25MLC 25 2.8 3.75 70 16.3 PSMN3R9-25MLC 25 4.15 5.55 70 9.7 PSMN9R0-25MLC 25 8.65 11.3 55 5.4 PHB66NQ03LT 25 10.5 66 12 PHD38N02LT 20 44.7 15.1 PHD97NQ03LT 25 10.6 75 11.7 PSMN006-20K 20 5 32 32 Type number that withstand higher currents. NXP’s TO-220 NextPower Cordless devices handle up to 150A. The high-reliability LFPAK56 is ideal for smaller tools and space-constrained applications. DPAK (SOT428) SO8 (SOT96-1) 6.3 MOSFETs Power MOSFETs For the most current product information go to www.nxp.com/mosfets (updated daily!) 100 101 Power MOSFETs Power MOSFETs Power MOSFETs 30 V – Part 1 Power MOSFETs 30 V – Part 2 LFPAK56; Power-SO8 (SOT669) LFPAK33 (SOT1210) D2PAK (SOT404) VDS [max] (V) RDSon [max] @ VGS = 10 V (mΩ) RDSon [max] @ VGS = 4.5 V (mΩ) ID [max] (A) PSMN0R9-30YLD 30 0.87 1.09 300 51 PSMN1R0-30YLD 30 1.02 1.3 300 38.2 PSMN1R0-30YLC 30 1.15 1.4 100 50 PSMN1R2-30YLD 30 1.24 1.6 100 32 PSMN1R2-30YLC 30 1.25 1.65 100 38 PSMN1R3-30YL 30 1.3 1.95 100 PSMN1R4-30YLD 30 1.42 1.85 100 PSMN1R5-30YL 30 1.5 1.9 PSMN1R5-30YLC 30 1.55 PSMN1R7-30YL 30 PSMN2R0-30YL Type number VDS [max] (V) RDSon [max] @ VGS = 10 V (mΩ) PHD101NQ03LT 30 PHD71NQ03LT 46.6 27.6 100 2.05 1.7 30 PSMN2R0-30YLE RDSon [max] @ VGS = 4.5 V (mΩ) ID [max] (A) QG(tot) [typ] (nC) 5.5 75 23 30 10 75 13.2 PSMN1R1-30PL 30 1.3 1.6 120 118 PSMN1R6-30PL 30 1.7 2.1 100 101 36.2 PSMN1R8-30PL 30 1.8 2.3 100 83 100 30 PSMN2R0-30PL 30 2.1 2.8 100 55 2.1 100 36.2 PSMN2R7-30PL 30 2.7 3.6 100 32 2 2.63 100 30 PSMN3R4-30PL 30 3.4 4.1 100 31 30 2 3.5 100 87 PSMN4R3-30PL 30 4.3 6.2 100 19 PSMN2R2-30YLC 30 2.15 2.8 100 26 PHP36N03LT 30 17 22 43.4 18.5 PSMN2R4-30YLD 30 2.4 3.1 100 18 PSMN017-30PL 30 17 23.4 32 5.1 PSMN2R5-30YL 30 2.4 3.16 100 27 PSMN022-30PL 30 22 34 30 4.4 PSMN2R6-30YLC 30 2.8 3.65 100 18 PSMN3R0-30YL 30 3 4.04 100 21 PSMN1R1-30EL 30 1.3 1.6 120 118 PSMN3R0-30YLD 30 3.1 4 100 14.5 PSMN3R2-30YLC 30 3.5 4.55 100 14.2 PSMN017-30EL 30 17 23.4 32 5.1 PSMN3R5-30YL 30 3.5 4.61 100 19 PSMN4R0-30YL 30 4 5.25 100 17.6 PHK31NQ03LT 30 4.4 5.6 30.4 33 PSMN4R0-30YLD 30 4 5.5 95 9.6 PSMN005-30K 30 5.5 8 PSMN4R1-30YLC 30 4.35 5.7 92 11 PHK18NQ03LT 30 8.9 12.5 20.3 10.6 PSMN4R5-30YLC 30 4.8 6.1 84 9.6 PHK13N03LT 30 20 26 13.8 10.7 PSMN5R0-30YL 30 5 6.7 91 14.1 PHK12NQ03LT 30 14 11.8 PSMN6R0-30YL 30 6 7.87 79 11 PSMN6R0-30YLD 30 6 8.35 66 6.7 PSMN6R1-30YLD 30 6 8.35 66 6.4 PSMN6R0-30YLB 30 6.5 8.1 71 9 PSMN7R0-30YL 30 7 9.1 76 10 PSMN7R0-30YLC 30 7.1 8.9 61 7.9 PSMN7R5-30YLD 30 7.5 10.2 51 5.8 PSMN9R1-30YL 30 9.1 13.6 57 8.4 PSMN9R5-30YLC 30 9.8 12.1 44 5 PSMN011-30YLC 30 11.6 14.5 37 4.9 PSMN013-30YLC 30 13.6 16.9 32 4 PSMN2R4-30MLD 30 2.4 3.2 70 16 PSMN2R9-30MLC 30 2.95 3.8 70 16.7 PSMN3R0-30MLC 30 3.15 4.05 70 16.1 PSMN4R2-30MLD 30 4.3 5.7 70 9.2 PSMN4R4-30MLC 30 4.65 6 70 10.6 PSMN7R0-30MLC 30 7 9 67 8.2 PSMN7R5-30MLD 30 7.6 10.3 57 5.8 PSMN9R8-30MLC 30 9.8 12.4 50 5 PSMN013-30MLC 30 13.6 16.9 39 3.7 PSMN020-30MLC 30 18.1 27 31.8 4.6 PSMNR90-30BL 30 1 1.4 120 118 PSMN1R5-30BLE 30 1.5 1.85 120 228 PSMN1R8-30BL 30 1.8 2.1 100 83 PSMN1R6-30BL 30 1.9 2.2 100 101 PSMN2R0-30BL 30 2.1 2.9 100 55 PSMN2R7-30BL 30 3 3.7 100 32 PSMN3R4-30BL 30 3.3 3.8 100 31 PSMN3R4-30BLE 30 3.4 5 120 81 PSMN4R3-30BL 30 4.1 5.2 100 19 PSMN017-30BL 30 17 23.3 32 5.1 PSMN022-30BL 30 22.6 29.6 30 4.4 Type number QG(tot) [typ] (nC) Package DPAK (SOT428) TO-220AB (SOT78) I2PAK (SOT226) SO8 (SOT96-1) 34 For the most current product information go to www.nxp.com/mosfets (updated daily!) MOSFETs Package types in bold represent new products LFPAK for mechanical and thermal ruggedness NXP LFPAK Lead absorbs any mechanical movement LFPAK pins provide compliance while allowing for thermal expansion due to temperature differences between the MOSFET and the PCB, and allowing for mechanical strain due to PCB bending and flexing Movement due to thermal and/or mechanical stress in PCB For the most current product information go to www.nxp.com/mosfets (updated daily!) 102 103 Power MOSFETs Power MOSFETs 40 V Package VDS [max] (V) RDSon [max] @ VGS = 10 V (mΩ) RDSon [max] @ VGS = 4.5 V (mΩ) ID [max] (A) QG(tot) [typ] (nC) PSMN1R0-40YLD 40 1.1 1.4 100 59 PSMN1R4-40YLD 40 1.4 1.85 100 45 PSMN1R6-40YLC 40 1.55 1.8 100 59 Type number LFPAK56; Power-SO8 (SOT669) D2PAK (SOT404) types in bold represent new products PSMN1R8-40YLC 40 1.8 PSMN2R6-40YS 40 2.8 2.1 100 45 100 63 PSMN3R3-40YS 40 3.3 100 49 PH4840S 40 4.1 94.5 67 PSMN4R0-40YS 40 4.2 100 38 PSMN5R8-40YS 40 5.7 90 28.8 PSMN8R3-40YS 40 8.6 70 Power MOSFETs 55 - 60 V Package LFPAK56; Power-SO8 (SOT669) types in bold represent new products VDS [max] (V) RDSon [max] @ VGS = 10 V (mΩ) ID [max] (A) QG(tot) [typ] (nC) PH955L 55 8.3 62.5 42 PSMN4R0-60YS 60 4 100 56 PSMN4R1-60YL 60 4.1 100 103 PSMN5R2-60YL 60 5.2 100 78.4 Type number PSMN5R5-60YS 60 5.2 100 56 PSMN5R6-60YL 60 5.6 100 66.8 PSMN7R0-60YS 60 6.4 89 45 PSMN7R5-60YL 60 7.5 86 60.6 PSMN8R5-60YS 60 8 76 39 PSMN012-60YS 60 11.1 59 28.4 20 PSMN013-60YL 60 13 53 33.2 60 15.7 44 20 PSMN014-40YS 40 14 46 12 PSMN017-60YS PSMN1R1-40BS 40 1.3 120 136 PSMN030-60YS 60 24.7 29 13 PSMN2R2-40BS 40 2.2 100 130 PSMN011-60ML 60 11.3 61 37.2 PSMN2R8-40BS 40 2.9 100 71 PSMN4R5-40BS 40 4.5 100 35 PSMN011-60MS 60 11.3 61 23 PSMN8R0-40BS 40 7.6 77 21 PHB191NQ06LT 55 3.7 75 95.6 PSMN1R5-40PS 40 1.6 150 136 PHB21N06LT 55 70 19 PHB20N06T 55 75 20.3 11 PSMN1R7-60BS 60 2 120 137 PSMN3R0-60BS 60 3.2 100 130 PSMN004-60B 60 3.6 75 168 PSMN4R6-60BS 60 4.4 100 70.8 LFPAK33 (SOT1210) PSMN1R9-40PL 40 1.7 1.94 150 230 PSMN2R1-40PL 40 2.2 2.6 150 168.9 PSMN2R2-40PS 40 2.1 100 110 PSMN2R8-40PS 40 2.8 100 71 PSMN4R5-40PS 40 4.6 100 35 PSMN7R6-60BS 60 7.8 92 38.7 PSMN8R0-40PS 40 7.6 77 17 PSMN015-60BS 60 14.8 50 20.9 PHB32N06LT 60 37 34 17 PHD20N06T 55 77 18 11 PHP191NQ06LT 55 3.7 75 95.6 Power-SO8 (LFPAK) Design PHP20N06T 55 75 20.3 11 PSMN2R0-60PS 60 2.2 120 137  Low thermal resistance  Low electrical resistance  Low inductance PSMN2R5-60PL 60 2.6 150 223 PSMN2R6-60PS 60 2.6 150 140 PSMN3R0-60PS 60 3 100 130 PSMN3R3-60PL 60 3.4 130 175 PSMN3R9-60PS 60 3.9 130 103 PSMN4R2-60PL 60 3.9 130 151 PSMN4R6-60PS 60 4.6 100 70.8 PSMN7R6-60PS 60 7.8 92 38.7 PSMN015-60PS 60 14.8 50 20.9 PSMN2R0-60ES 60 2.2 120 137 PSMN3R0-60ES 60 3 100 130 TO-220AB (SOT78) I2PAK (SOT226) PSMN1R5-40ES 40 1.6 120 136 D2PAK (SOT404) DPAK (SOT428) For the most current product information go to www.nxp.com/mosfets (updated daily!) Two-part leadframe PCB TO-220AB (SOT78) Chip Plastic PCB bra187 MOSFETs Power MOSFETs I2PAK (SOT226) For the most current product information go to www.nxp.com/mosfets (updated daily!) 104 105 Power MOSFETs Power MOSFETs 75 - 80 V Package LFPAK56; Power-SO8 (SOT669) Type number VDS [max] (V) RDSon [max] @ VGS = 10 V (mΩ) ID [max] (A) QG(tot) [typ] (nC) PSMN8R0-80YL 80 8 100 104 PSMN8R2-80YS 80 8.5 82 55 PSMN010-80YL 80 10 84 84.7 PSMN011-80YS 80 11 67 45 PSMN013-80YS 80 12.9 60 37 PSMN014-80YL 80 14 62 56.9 PSMN018-80YS 80 18 45 26 PSMN025-80YL 80 25 37 34.3 PSMN026-80YS 80 27.5 34 20 PSMN041-80YL 80 41 25 21.9 PSMN045-80YS 80 45 24 12.5 PSMN005-75B 122.8 PHB110NQ08T 75 9 75 113.1 75 27 19 PSMN2R8-80BS 80 3 120 139 PSMN3R3-80BS 80 3.5 120 111 PSMN4R4-80BS 80 4.5 100 125 PSMN5R0-80BS 80 5.1 100 101 PSMN6R5-80BS 80 6.9 100 71 PSMN8R7-80BS 80 8.7 90 52 PSMN012-80BS 80 11 74 36 PSMN017-80BS 80 17 50 26 PSMN050-80BS 80 46 22 11 75 PHP79NQ08LT 75 PHP29N08T 75 5 16 75 73 30 27 19 80 3.3 120 139 PSMN3R5-80PS 80 3.5 120 139 PSMN4R4-80PS 80 4.1 100 112 PSMN4R3-80PS 80 4.3 120 111 PSMN5R0-80PS 80 4.7 100 87 6.9 100 Package LFPAK56; Power-SO8 (SOT669) LFPAK33 (SOT1210) D2PAK (SOT404) DPAK (SOT428) 165 PSMN3R3-80PS 80 Power MOSFETs 100 V 165 75 TO-220AB (SOT78) 71 PSMN8R7-80PS 80 8.7 90 52 PSMN012-80PS 80 11 74 36 PSMN017-80PS 80 17 50 26 PSMN3R3-80ES 80 3.3 120 139 PSMN3R5-80ES 80 3.5 120 139 PSMN4R3-80ES 80 4.3 120 111 For the most current product information go to www.nxp.com/mosfets (updated daily!) 106 75 8.5 PSMN6R5-80PS I2PAK (SOT226) 5 75 PSMN005-75P TO-220AB (SOT78) 75 PSMN008-75B PHB29N08T D2PAK (SOT404) types in bold represent new products I2PAK (SOT226) SC-73 (SOT223) SO8 (SOT96-1) types in bold represent new products VDS [max] (V) RDSon [max] @ VGS = 10 V (mΩ) ID [max] (A) QG(tot) [typ] (nC) PSMN012-100YL 100 11.9 85 118 PSMN012-100YS 100 12 60 64 PSMN013-100YSE 100 13 82 75 PSMN015-100YL 100 14.7 69 86.3 PSMN016-100YS 100 16.3 51 54 PSMN019-100YL 100 18 56 72.4 Type number PSMN020-100YS 100 20.5 43 41 PSMN021-100YL 100 21.5 49 65.6 PH20100S 100 23 34.3 39 PSMN028-100YS 100 27.5 42 33 PSMN038-100YL 100 37.5 30 21.6 PSMN039-100YS 100 39.5 28.1 23 PSMN069-100YS 100 72.4 17 14 PSMN040-100MSE 100 36.6 30 30 PSMN075-100MSE 100 71 18 16.4 PSMN3R8-100BS 100 3.9 120 170 PSMN4R8-100BSE 100 4.8 120 196 PSMN5R6-100BS 100 5.6 100 141 PSMN7R0-100BS 100 6.8 100 125 PSMN7R6-100BSE 100 7.6 75 128 PSMN009-100B 100 8.8 75 156 PSMN9R5-100BS 100 9.6 89 82 PSMN013-100BS 100 13.9 68 59 PSMN015-100B 100 15 75 90 PSMN016-100BS 100 16 57 49 PHB45NQ10T 100 25 47 61 PSMN027-100BS 100 26.8 37 30 PHB47NQ10T 100 28 47 66 PSMN034-100BS 100 34.5 32 23.8 PHB27NQ10T 100 50 28 30 PHB18NQ10T 100 90 18 21 PSMN025-100D 100 25 47 61 PSMN4R3-100PS 100 4.3 120 170 PSMN4R8-100PSE 100 5 120 196 PSMN5R0-100PS 100 5 120 170 PSMN5R6-100PS 100 5.6 100 141 PSMN7R0-100PS 100 6.8 100 125 PSMN7R8-100PSE 100 7.8 83 128 PSMN8R5-100PS 100 8.5 100 111 PSMN009-100P 100 8.8 75 156 PSMN9R5-100PS 100 9.6 89 82 PSMN013-100PS 100 13.9 68 59 PSMN015-100P 100 15 75 90 PSMN016-100PS 100 16 57 49 PHP45NQ10T 100 25 47 61 PSMN027-100PS 100 26.8 37 30 PSMN034-100PS 100 34.5 32 23.8 PHP18NQ10T 100 90 18 21 PSMN4R3-100ES 100 4.3 120 170 PSMN5R0-100ES 100 5 120 170 PSMN7R0-100ES 100 6.8 100 125 PSMN8R5-100ES 100 8.5 100 111 PSMN013-100ES 100 13.9 68 59 PHT6NQ10T 100 90 6.5 21 PHT4NQ10T 100 250 3.5 7.4 PSMN038-100K 100 38 PHKD3NQ10T 100 90 MOSFETs Power MOSFETs 43 3 21 For the most current product information go to www.nxp.com/mosfets (updated daily!) 107 Power MOSFETs Power MOSFETs Power MOSFETs 105 - 150 V Power MOSFETs 200 V Package Typenumber Type number VDS [max] (V) RDSon [max] @ VGS = 10 V (mΩ) ID [max] (A) QG(tot) [typ] (nC) Package Type number VDS [max] (V) RDSon [max] @ VGS = 10 V (mΩ) ID [max] (A) QG(tot) [typ] (nC) LFPAK56; Power-SO8 (SOT669) PSMN059-150Y 150 59 43 27.9 LFPAK56; Power-SO8 (SOT669) PSMN102-200Y 200 102 21.5 30.7 PSMN030-150B 150 30 55.5 98 PSMN057-200B 200 57 39 96 PSMN035-150B 150 35 50 79 PHB45NQ15T 150 42 45.1 32 PSMN070-200B 200 70 35 77 PHB33NQ20T 200 77 32.7 32.2 PHB20NQ20T 200 130 20 65 PSMN130-200D 200 130 20 65 PHD9NQ20T 200 400 8.7 24 PSMN057-200P 200 57 39 96 PSMN070-200P 200 70 35 77 PHP33NQ20T 200 77 32.7 32.2 PHP20NQ20T 200 130 20 65 PHP9NQ20T 200 400 8.7 24 PSMN165-200K 200 165 - 40 D2PAK (SOT404) DPAK (SOT428) TO-220AB (SOT78) I2PAK (SOT226) SO8 (SOT96-1) D2PAK (SOT404) PSMN063-150D 150 63 29 55 PHP45NQ11T 105 25 47 60 PSMN015-110P 110 15 75 90 PHP27NQ11T 110 50 27.6 30 PHP23NQ11T 110 70 23 22 PHP18NQ11T 110 90 18 21 PSMN6R3-120PS 120 6.7 70 207.1 PSMN7R8-120PS 120 7.9 70 167 PSMN030-150P 150 30 55.5 98 PSMN035-150P 150 35 50 79 PHP30NQ15T 150 63 29 55 PHP28NQ15T 150 65 28.5 24 PSMN6R3-120ES PSMN6R3-120ES 120 120 6.7 6.7 70 70 207.1 207.1 PSMN7R8-120ES PSMN7R8-120ES 120 120 7.9 7.9 70 70 167 167 PHK5NQ15T 150 75 5 29 PSMN085-150K 150 85 DPAK (SOT428) TO-220AB (SOT78) SO8 (SOT96-1) For the most current product information go to www.nxp.com/mosfets (updated daily!) 40 PSMN part numbering For the most current product information go to www.nxp.com/mosfets (updated daily!) Package SO8 (SOT96-1) VDS [max] (V) RDSon [max] @ VGS = 10 V (mΩ) RDSon [max] @ VGS = 4.5 V (mΩ) ID [max] (A) QG(tot) [typ] (nC) PMK30EP -30 19 30 -14.9 50 PMK35EP -30 19 35 -14.9 42 PHP225 -30 250 400 - 10 PMK50XP -20 - 50 -7.9 10 PHK04P02T -16 - 120 -4.66 7.2 Type number Technology family, e.g. • Power silicon max max at 25 °C Voltage rating For the most current product information go to www.nxp.com/mosfets (updated daily!) MOSFETs P-channel Logic level Standard level Multi-chip Enhanced logic Package SO8 (SOT96-1) Channel type VDS [max] (V) RDSon [max] @ VGS = 10 V (mΩ) PHP225 P -30 250 - 10 PHKD6N02LT N 20 - 10.9 15.3 PHKD13N03LT N 30 20 10.4 10.7 PHN203 N 30 30 6.3 14.6 PHN210T N 30 100 3.4 6 PHC21025 N/P 30 250 - 10 N 100 90 3 21 N/P 300 6000 - 6.24 Type number PHKD3NQ10T PHC2300 ID [max] (A) QG(tot) [typ] (nC) For the most current product information go to www.nxp.com/mosfets (updated daily!) 108 109 4 steps to select an automotive MOSFET 1 Select a voltage, e.g. 40 V 2 Select a package, e.g D2PAK High-performance automotive MOSFETs MOSFET package selection Through-hold Surface-mount TO220  Industry standard  120 A 3 Choose an RDSon from our extensive range 4 Select a ‘BUK’ type and visit www.nxp.com/automotivemosfets to download datasheets and models, and order samples I2PAK  Industry standard  120 A Automotive-grade MOSFET product numbering 7 6 1R5 40 E Segment ’BUK’ for automotive grade Gate drive 7 = Standard level 6 = Intermediate level 9 = Logic level Package: 6 = D2PAK C = D2PAK-7 2 = DPAK E = I2PAK 5 = TO-220 Y = LFPAK56 K = LFPAK56D TrenchMOS technology Space saving D2PAK-7  Highest performance  190 A LFPAK56  PowerSO8  100 A D2PAK  Industry standard  120 A LFPAK56D  Dual Power-SO8  40 A per channel A = Generation 2 B = Generation 3 C = Generation 4 E = Generation 6 MOSFETs BUK Premium performance DPAK  Industry standard  Proven reliability  100 A Voltage rating BVDSS rating in m 1R5 means 6 pin packages Orientation in tape 144 Orientation in tape Package Packing 12NC ending DFN1006-2 (SOD882) DFN1006D-2 (SOD882D) DFN1608D-2 (SOD1608) DSN0603-2 (SOD962) DSN0402-2 (SOD992) DSN1006-2 (SOD993) DSN1006U-2 (SOD995) DSN1608-2 (SOD963, SOD964) SOD80 SOD123F CFP3 (SOD123W) CFP5 (SOD128) SOD323 SOD323F SOD523 315 315 315 315 315 315 315 115, 135 115 115 115 115, 135 115 115, 135, 315, 335 Package Packing 12NC ending SOT89 146 315 Package Packing 12NC ending DFN1006-3 (SOT883) DFN1006B-3 (SOT883B) SOT23 SOT323 315 315 185, 215, 235 115, 135 Orientation in tape Package Packing 12NC ending DFN1010D-3 (SOT1215) DFN2020-3 (SOT1061) DFN2020D-3 (SOT1061D) SOT89 SOT663 CFP15 (SOT1289) DPAK (SOT428) D2PAK (SOT404) 147 115, 135 115, 135 115, 135 115 139, 146 118 118 Package Packing 12NC ending SOT89 147 Orientation in tape Package Packing 12NC ending Orientation in tape Package Packing 12NC ending Orientation in tape Package Packing 12NC ending SOT353 SOT665 115, 135 115 Package Packing 12NC ending Orientation in tape Package Packing 12NC ending LFPAK56 (SOT669) WLCSP4 115 084 Package Packing 12NC ending SOT143B SOT223 215, 235 115, 135 Package Packing 12NC ending WLCSP5 087 Package Packing 12NC ending Orientation in tape Orientation in tape Package Packing 12NC ending DFN1410-6 (SOT886) DFN1616-6 (SOT1189) DFN2020MD-6 (SOT1220) LFPAK33 (SOT1210) LFPAK56D (SOT1205) WLCSP6 115 115 184 115 115 023 Package Packing 12NC ending DFN1010-6 (SOT891) DFN1410-6 (SOT886) DFN2020MD-6 (SOT1220) SOT363 SOT457 132 132 125 125, 165 125, 165 Orientation in tape Package Packing 12NC ending DFN2020-6 (SOT1118) DFN2020D-6 (SOT1118D) DFN2020MD-6 (SOT1220) DFN1010B-6 (SOT1216) SOT363 SOT457 SOT666 115 115 115 147 115, 135 115, 135 115, 315 Package Packing 12NC ending Packages 2 pin packages Orientation in tape 145 Minimized outline drawings and reflow soldering footprint Outline and footprint drawings DSN0402-2 (SOD992) DSN1006-2 (SOD993) DSN1006U-2 (SOD995) DFN1006-2 (SOD882) DFN1006D-2 (SOD882D) DFN1608D-2 (SOD1608) DSN0603-2 (SOD962) SOD80C SOD123F SOD123W SOD128 SOD323 (SC-76) SOD323F (SC-90) SOD523 (SC-79) 3-pin SMD packages CFP15 (SOT1289) DFN1006-3 (SOT883) DFN1006B-3 (SOT883B) DFN1010D-3 (SOT1215) DFN2020-3 (SOT1061) DFN2020D-3 (SOT1061D) DPAK (SOT428) D2PAK (SOT404) SOT23 SOT89 (SC-62) SOT323 (SC-70) SOT663 4-pin SMD packages LFPAK56 (SOT669) SOT143B SOT223 (SC-73) 5-pin SMD packages SOT353 (SC-88A) SOT665 6-pin SMD packages DFN1010-6 (SOT891) DFN1010B-6 (SOT1216) DFN1410-6 (SOT886) DFN1616-6 (SOT1189) DFN2020-6 (SOT1118) DFN2020D-6 (SOT1118D) DFN2020MD-6 (SOT1220) SOT363 (SC-88) SOT457 (SC-74) SOT666 7-pin SMD Packages DFN2111-7 (SOT1358) D2PAK-7 (SOT428) 146 148 8-pin SMD packages 158 148 148 148 148 149 149 149 149 150 150 150 150 151 151 DFN1714-8 (SOT1166) DFN1714U-8 (SOT983) SOT96 (SO8) LFPAK33 (SOT1210) LFPAK56D (SOT1205) 158 159 159 159 159 151 151 151 152 152 152 152 153 153 153 153 154 154 154 More than 8-pin SMD packages DFN2110-9 (SOT1178) DFN2510-10 (SOT1165) DFN2510A-10 (SOT1176) DFN2514-12 (SOT1167) DFN2520-9 (SOT1333) DFN2521-12 (SOT1156) DFN3314-16 (SOT1168) DFN4020-14 (SOT1334) DFN5050-32 (SOT617) SOT360 (TSSOP20) SOT519 (SSOP16) Glass diodes SOD27 (DO-35) SOD66 (DO-41) SOD68 (DO-34) Single-ended and through-hole packages SOT78 (TO220AB) SOT186A (isolated TO220AB) SOT226 SOT263B-1 160 160 160 160 160 161 161 161 161 162 162 162 162 162 162 162 163 163 163 163 163 154 154 155 155 155 155 155 155 156 156 156 156 157 157 157 157 158 158 158 158 Packages 2-pin SMD packages 147 Minimized outline drawings and reflow soldering footprint Minimized outline drawings and reflow soldering footprint 2-pin SMD packages 2-pin SMD packages 13 L 0.66 L 1 2 0.18 (2x) b (2x) 0.16 0.20 (2x) 0.4 max solder resist 0.23 (2x) 0.38 0.33 solder lands solder paste 07 2 solder resist 08 2 solder paste 1 0.30 0.22 Dimensions in mm 06 2 09 1.05 0.95 0.65 e solder lands 2 0.30 0.22 occupied area occupied area 0.55 0.45 A 03 2 cathode marking on top side Dimensions in mm 04 2 0.36 05 2 DSN0402-2 (SOD992) DSN0402-2 (SOD992) L 0 05 8 07 0.65 0.55 0.56 DFN1006D-2 (SOD882D) DFN1006D-2 (SOD882D) DFN1608D-2 (SOD1608) DFN1608D-2 (SOD1608) 0.65 L 0.4 0.3 1 2 b 0.6 0.5 e1 occupied area solder resist solder lands solder paste Dimensions in mm A1 A 0.25 0.25 0.35 0.35 DSN1006-2 (SOD993) DSN1006-2 (SOD993) L 0.85 1 2 0.4 b R0.025 (8´) solder land solder paste deposit e1 E 0.4 0.22 (2´) solder land plus solder paste solder resist D A Dimensions in mm A1 (2) 0 Unit mm A(1) A1 b D E e1 max 0.32 0.0076 0.25 0.325 0.625 nom 0.4 0.23 0.275 0.575 min 0.28 L 0.15 0.13 Note 1. Dimension A is including coating foil thickness. 2. The marking bar indicates the cathode. DSN0603-2 (SOD962) DSN1006U-2 (SOD995) DSN1006U-2 (SOD995) 0.12 (2´) 0.5 mm scale Dimensions 0.2 (2´) DSN0603-2 (SOD962) and DSN0603B-2 (SOD962B) 1.3 R0.05 (8´) 4.55 4.30 solder lands 0.6 (2´) 0.9 0.7 (2´) solder lands solder paste solder paste occupied area 0.3 (2´) 2.30 solder resist Dimensions in mm 0.4 (2´) 2.25 1.70 1.60 0.3 0.3 3.7 3.3 solder resist 1.60 1.45 occupied area Dimensions in mm 0.90 (2x) sod882_fr DFN1006-2 (SOD882) Dimensions in mm 148 SOD80C DFN1006-2 (SOD882) Packages 0.7 SOD80C Dimensions in mm 149 Minimized outline drawings and reflow soldering footprint Minimized outline drawings and reflow soldering footprint 2-pin SMD packages 2-pin SMD packages 3.05 4.4 2.2 4 2.1 2.9 1.6 solder lands solder lands 2.1 1.6 1.1 1.2 solder resist solder resist 0.5 (2´) 1.65 0.95 0.6 (2´) solder paste occupied area occupied area 0.5 (2´) 0.6 (2´) 1.1 (2´) SOD123F SOD123F Dimensions in mm SOD323F (SC-90) SOD323F (SC-90) 2.15 4.4 1.1 2.9 solder lands 2.8 solder lands 1.1 1.2 (2´) (2´) 2.1 1.6 0.5 0.6 (2´) (2´) 1.2 solder resist solder paste 1.1 (2´) 1.2 (2´) sod123w_fr SOD523 (SC-79) SOD123W SOD523 (SC-79) Package outline 3-pin SMD packages CFP15: plastic, thermal enhanced ultra thin SMD package; 3 leads; body: 5.8 x 4.3 x 0.78 mm 6.2 1 4.4 0.6 0.3 4.0 3.6 3 1.9 2.1 (2´) (2´) solder resist L 2 e L1 L2 solder paste 1 (2x) occupied area 2 0.22 0.10 b2 (2x) b1 3.4 2.5 1.9 1.6 SOT1289 b 4.2 solder lands 5.0 4.4 solder paste Dimensions in mm 0.7 (2´) 0.8 (2´) Dimensions in mm SOD123W 1.1 0.9 solder resist occupied area occupied area 2.7 2.3 solder paste b3 (2x) b3 Dimensions in mm 1.2 (2´) 1.4 (2´) D1 E C A D SOD128 SOD128 CFP15 (SOT1289) CFP15 (SOT1289) 1 3 1.30 2 R = 0.05 (12´) 2.1 0.30 R = 0.05 (12´) solder lands solder lands solder resist 0.5 (2´) 1.65 0.95 0.6 (2´) solder paste 2.2 Dimensions in mm SOD323 (SC-76) Dimensions in mm 150 2.5 A max nom 0.78 min mm C D D1 E 0.2 6.6 6.5 6.4 5.9 5.8 5.7 4.4 4.3 4.2 0.35 (2´) 5 mm scale Dimensions (mm are the original dimensions) Unit occupied area 0.5 (2´) 0.6 (2´) 0 e b b1 b2 b3 L L1 3.41 2.15 4.71 4.11 1.19 2.13 4.61 4.01 1.09 3.31 2.05 4.51 3.91 0.99 0.25 3.21 1.95 L2 1.3 1.2 1.1 Note 1. Dimension A is excluding plating thickness. Outline version sot1289_po References IEC JEDEC JEITA European projection SOD323 (SC-76) © 2010 NXP B.V. All rights reserved. Reproduction in whole or in part is prohibited without prior consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of it’s use. Publication thereof does not convey or imply any license under patent- or other industrial or intellectual property rights. DFN1006-3 (SOT883) Printed in the Netherlands solder resist occupied area Issue date sod323_fr www.nxp.com 0.60 0.70 0.80 0.25 (2´) 13-07-12 13-08-27 SOT1289 solder paste 0.90 0.20 0.30 (2´) 0.40 (2´) 0.50 (2´) 0.30 0.40 0.50 Dimensions in mm Packages 3.05 DFN1006-3 (SOT883) Dimensions in mm 151 1.3 Minimized outline drawings and reflow soldering footprint 0.7 3-pin SMD packages L (2x) L (2x) 2 0.9 0.7 3-pin SMD packages L1 7.00 6.15 5.90 5.80 y 3 e 3 e 0.6 Minimized outline drawings and reflow soldering footprint 0.25 (2x) L1 b (2x) 2 b (2x) R0.05 (8x) 1 1 1.3 b1 b1 0.7 R0.05 (8x) e1 e1 0.3 (2x) 0.3 0.4 (2x) 0.4 E A A A1 b2 E1 mounting base A A1 A A1 solder land 0.9 E 0.7 0.6 E 0.25 (2x) D D occupied area D1 solder land plus solder paste solder paste deposit 4.725 4.60 D2 5.75 5.65 0 0.5 0.5 1 mm scale solder resist 2 L2 1 Dimensions in mm L sot883b_fr 3.60 L1 3 6.00 b w M scale Dimensions Dimensions A(1) Unit mm b A1 Unit b1A(1) D A1 E b e b1 e1 D L E L1 e e1 L L1 0.30 0.30 max0.55 0.400.65 0.041.050.20 0.55 0.65 0.301.05 max 0.40 0.04 0.20 0.30 nom0.50 0.370.60 1.000.15 0.251.00 nom 0.37 0.25 0.35 0.65 0.25 0.25 mm 0.15 0.350.50 0.650.60 0.12 0.220.95 min 0.34 0.22 0.22 0.22 min0.47 0.340.55 0.950.12 0.47 0.55 DFN1006B-3 (SOT883B) solder land 0.3 0.4 (2x) 0.4 solder paste deposit solder resist occupied area Dimensions in mm occupied area 6.125 solder paste c A 0.30 2.40 2.30 0 5 10 mm scale UNIT A A1 b b1 b2 c D1 D2 min E E1 min e e1 HD L L1 min L2 w y max mm 2.38 2.22 0.93 0.46 0.89 0.71 1.1 0.9 5.46 5.00 0.56 0.20 6.22 5.98 4.0 6.73 6.47 4.45 2.285 4.57 10.4 9.6 2.95 2.55 0.5 0.9 0.5 0.2 0.2 4.57 DPAK (SOT428) DFN1006B-3 (SOT883B) 1.30 1.40 1.65 1.50 DIMENSIONS (mm are the original dimensions) solder land plus solder paste solder resist 6.00 2.45 e1 0.3 (2x) 6.50 1.15 b1 1 mm solder lands HD e 0 1.80 1.00 10.85 10.60 10.50 DPAK (SOT428) 1.50 sot883b_fr 2.25 2.15 A A1 E 7.50 7.40 10.85 10.60 10.50 1.50 7.50 7.40 mounting base D1 8.35 8.15 1.50 D HD 1.70 8.275 2.25 2.15 8.35 8.15 4.60 1.70 solder lands 8.275 1.50 solder lands 4.60 1 Lp 3 0.30 e 4.85 Q 0 2.5 5 mm 0.30 solder paste 5.40 7. 5 8.075 7. 5 scale occupied area occupied area 4.85 c b e solder resist solder resist 2 3.00 solder paste 5.40 0.20 8.075 DIMENSIONS (mm are the original dimensions) DFN1010D-3 (SOT1215) UNIT A A1 b c D max. D1 E e Lp HD Q mm 4.50 4.10 1.40 1.27 0.85 0.60 0.64 0.46 11 1.60 1.20 10.30 9.70 2.54 2.90 2.10 15.80 14.80 2.60 2.20 1.20 1.30 1.55 3.00 5.08 D PAK (SOT404) DFN1010D-3 (SOT1215) 2 1.20 1.30 1.55 3.3 5.08 2.9 1 1.05 0.95 1.9 0.5 (2´) 0.65 max 0.45 0.35 2 0.4 (2´) 0.5 (2´) 2.1 1.9 1.1 0.9 0.3 0.2 2.9 1.3 0.35 0.25 msd057 3.3 1.9 2.1 1.3 0.20 msd057 D PAK (SOT404) 2 solder lands 0.6 (2´) solder lands solder paste = solder lands 1.05 0.6 2.3 3 solder resist 0.55 0.25 1.1 0.25 3 0.7 (3´) Dimensions in mm 0.25 0.6 (3´) 0.7 (3´) solder resist solder resist solder paste solder paste occupied area occupied area Dimensions in mm Dimensions in mm (3´) 0.5 0.6 (3´) (3´) 0.5 0.6 1 (3´) 1.6 1.7 DFN2020-3 (SOT1061) 0.6 (3´) 0.5 0.4 2.1 1.9 2 2 1.7 occupied area 1.2 3 1.6 1.4 1.7 SOT23 DFN2020-3 (SOT1061) sot023_fr 1 SOT23 sot023_fr 2.1 4.75 1.7 2.25 1.3 2 0.4 (2x) 0.5 (2x) X 1.2 A B v bp solder lands 0.5 (2x) 0.6 (2x) 0.7 (2x) B A D 1.9 1.1 2.5 0.35 0.3 occupied area 0.25 2.3 1.1 1.2 A A1 0.35 0.35 0.35 solder resist solder resist 1.7 1.2 0.25 1 E 0.2 0.85 0.25 solder lands 4.6 solder paste Dimensions in mm 0.5 1 (3´) 4.85 1.1 (2´) detail X 1.5 0.4 1.5 0.6 (3´) 0.5 1.5 pin 1 index area solderable lead end, protrusion max. 0.02 mm (3x) e C y1 C 2 1 DFN2020D-3 (SOT1061D) Lp e1 E1 Dimensions in mm 3 D1 152 visible depend upon used manufacturing technology (6x) mm A(1) A1 bp max 0.65 0.04 0.35 nom 0 1 D D1 E E1 1.6 2.1 1.1 e 1.3 1.7 3.95 DFN2020D-3 (SOT1061D) SOT89 (SC-62) SOT89 (SC-62) 2 mm scale 2.1 y Dimensions in mm 153 Dimensions (mm are the original dimensions) Unit 0.7 (3´) 1.6 occupied area Dimensions in mm 0.3 pin 1 index area solder paste Packages 0.3 (2x) e1 Lp 0.3 0.45 v 0.1 y y1 0.05 0.05 Minimized outline drawings and reflow soldering footprint Minimized outline drawings and reflow soldering footprint 3-pin SMD packages 4-pin SMD packages 2.65 7 3.85 1.85 3.6 3.5 0.3 1.325 1.3 (4´) solder lands solder resist 4 solder resist 2 0.6 2.35 (3´) solder lands 1.2 (4´) 3 solder paste 1.3 1 2 7.65 6.1 7.65 solder paste occupied area 3 occupied area 0.5 (3´) 1 3.9 Dimensions in mm 2.3 2.3 1.2 (3´) Dimensions in mm 1.3 (3´) 0.55 (3´) 6.15 SOT223 (SC-73) SOT323 (SC-70) SOT323 (SC-70) SOT223 (SC-73) 5-pin SMD packages 2.45 1.9 1.6 2.65 solder lands 0.5 0.55 0.6 (3´) mo (3´)nted (3´) ac age (LFPA Plastic single ended s r ace 2 Power SO ) 4 leads placement area 1 0.8 c2 b2 0.5 (3´) 1 2.35 b3 0.5 (4´) b4 4-pin SMD packages Plastic single ended s r ace mo nted ac age (LFPA 0.9 SOT663 Power SO ) 1 2 3 e 4 leads SOT Footprint information for reflow soldering Dimensions in mm 0.9 sot353_fr SOT353 (SC-88A) SOT353 (SC-88A) 4 c M A b occupied area 0.6 0.6 (4´) D1 2 solder resist solder paste D SOT663 solder lands 0.4 E1 Dimensions in mm mounting base 0.55 (3´) 0.6 (4´) 0.75 occupied area A2 A 0.5 (4´) 0.75 solder paste E 1.65 SOT 1 2e SOT669 2.45 2.1 A2 A E c2 b2 1 E1 4.2 0.9 (3´) b3 mounting base A 4.7 0.25 (2´) b4 0.25 (2´) 1.6 A3 A1 0.6 (4´) etail 0 3.45 2 1 2 3 e 4 0.6 (3´) c M A b 1 2e 2 3.5 2.15 A3 mm 3.3 solder resist UNIT mm A A1 A2 A3 b b2 1.20 0.15 1.10 0.50 4.41 0.25 1.01 0.00 0.95 0.35 3.62 Note 1. lastic o metal OUTLINE VERSION b3 b4 2.2 2.0 0.9 0.7 c D (1) c2 0.7 (4´) 1.27 D1(1) E(1) E1(1) max 0.25 0.30 4.10 4.20 0.19 0.24 3.80 5.0 4.8 3.3 3.1 Dimensions in mm H L L1 L2 w y θ 6.2 5.8 0.85 0.40 1.3 0.8 1.3 0.8 0.25 0.1 8ϒ 0ϒ LFPAK56 (SOT669) REFERENCES IEC JEDEC JEITA MO-235 EUROPEAN PROJECTION ISSUE DATE 06-03-16 11-03-25 0.25 b b2 1.20 0.15 1.10 0.50 4.41 0.25 1.01 0.00 0.95 0.35 3.62 b3 b4 2.2 2.0 0.9 0.7 c D (1) c2 D1(1) E(1) E1(1) max 0.25 0.30 4.10 4.20 0.19 0.24 3.80 5.0 4.8 3.3 3.1 e H L L1 L2 w y θ 1.27 6.2 5.8 0.85 0.40 1.3 0.8 1.3 0.8 0.25 0.1 8ϒ 0ϒ 0.538 solder lands solder paste 125 μm stencil solder resist occupied area Dimensions in mm 1.7 ot usions o 0.15 mm ma imum e si e a e not inclu e . REFERENCES IEC JEDEC EUROPEAN PROJECTION JEITA ISSUE DATE 06-03-16 11-03-25 MO-235 0.3 0.55 placement area solder paste 0.45 0.4 (2´) (2´) LFPAK56 (SOT669) ot usions o 0.15 mm ma imum e si e a e not inclu e . SOT669 A3 SOT669 3.81 e 1.27 A2 OUTLINE VERSION 5 mm occupied area DIMENSIONS (mm are the original dimensions) A1 Note 1. lastic o metal SP opening = Cu − 0.050 etail 2.5 solder paste 125 μmscale stencil A UNIT θ 0 1 DIMENSIONS (mm are the original dimensions) 1.1 A1 solder lands 2 5 mm scale 2.55 0.25 (2´) SR opening = Cu + 0.075 A 2.5 solder lands 0.4 (5´) 0.7 (2´) θ D1 D 0.45 (4´) 0.6 0.5 (4´) 0.65 SOT665 0.325 0.375 (2´) (2´) occupied area Dimensions in mm SOT665 6-pin SMD packages sot669_fr 3.25 1.05 0.6 (3´) 0.5 (3´) solder lands 0.7 0.6 (3´) (3´) 0.5 (6´) solder resist 2 3 1.4 solder paste 0.6 (6´) solder land plus solder paste 0.7 occupied area occupied area 0.7 0.6 Dimensions in mm Dimensions in mm 0.75 0.15 (6´) 0.95 0.9 1 SOT143B Dimensions in mm 154 SOT143B solder resist DFN1010-6 (SOT891) 0.25 (6´) 0.35 Packages 1.9 DFN1010-6 (SOT891) Dimensions in mm 155 Minimized outline drawings and reflow soldering footprint Minimized outline drawings and reflow soldering footprint 6-pin SMD packages 6-pin SMD packages bp (6x) D v A B A B E pin 1 index area solderable lead end protrusion maximum 0.035 mm (6x) DFN1010B-6 (SOT1216) DFN1010B-6 (SOT1216) DFN2020D-6 (SOT1118D) DFN2020D-6 (SOT1118D) DFN2020MD-6 (SOT1220) DFN2020MD-6 (SOT1220) 1.250 0.675 0.370 (6´) 0.500 solder resist 1.700 solder paste = solderland 0.500 occupied area 0.270 (6´) Dimensions in mm 0.425 (6´) 0.325 (6´) DFN1410-6 (SOT886) DFN1410-6 (SOT886) Hx 2.65 Gx A B D P D E solder land solder lands A A1 solder land plus solder paste terminal 1 index area 2.35 1.5 detail X terminal 1 index area e1 e 1 b C C A B C v w 3 y1 C occupied area y Hy L k Ay By SPy SLy Gy 0.4 (2´) 0.6 0.5 (4´) (4´) solder paste solder resist Eh 0.5 (4´) DIMENSIONS in mm 6 Dh 4 0 1 2 mm scale Dimensions Unit(1) mm max nom min A A1 0.5 0.05 A3 b 0.30 0.127 0.25 0.00 0.20 D Dh E Eh 1.7 1.6 1.5 1.3 1.2 1.1 1.7 1.6 1.5 0.6 0.5 0.4 e 0.5 e1 1 k L v 0.2 0.35 0.30 0.25 0.1 w y SPx y1 0.05 0.05 0.05 2.1 1.9 0.77 0.57 (2´) 0.54 0.44 (2´) 3 4 1 6 SLx SLy SPx SPy Gx Gy Hx Hy 1.05 0.25 1.3 0.8 0.4 0.2 1.5 1.85 1.85 2.1 0.49 0.65 (4´) DFN2020-6 (SOT1118) 1.8 SOT363 (SC-88) SOT363 (SC-88) 3.45 0.65 0.49 1.95 0.3 (6´) 0.4 (6´) solder lands 0.45 0.55 (6´) (6´) 0.95 solder paste 1.05 1.15 (2´) (2´) 2.25 0.35 0.25 (6´) occupied area 0.6 (4´) 11-06-27 11-07-06 0.875 Dimensions in mm 156 1.85 D 2.1 0.65 0.95 solder resist solder paste occupied area occupied area 0.7 (6´) Dimensions in mm 10-05-31 0.35 (6´) 0.45 (6´) 0.72 (2´) 0.8 (6´) 0.82 (2´) DFN2020-6 (SOT1118) solder lands solder resist 3.3 2.825 0.875 0.3 0.2 Dimensions in mm 0.50 By DFN1616-6 (SOT1189) 0.04 max 1.1 0.9 Ay Issue date 0.65 max 2.1 1.9 P 0.6 (2´) SLx DFN1616-6 (SOT1189) solder resist 2.4 SOT457 (SC-74) Packages X SOT457 (SC-74) Dimensions in mm 157 Minimized outline drawings and reflow soldering footprint Minimized outline drawings and reflow soldering footprint 6-pin SMD packages 8-pin SMD packages 2.75 Hx Generic footprint pattern. Refer to the package outline drawing for actual layout. 2.45 2.1 Gx D P 0.05 1.6 solder lands 0.55 (2´) 0.05 solder land 0.3 (2´) placement area solder paste deposit solder paste occupied area 0.325 0.375 (4´) (4´) 1.7 SOT666 10.85 10.60 10.50 1.50 By SPy DIMENSIONS in mm P Ay By D Slx Sly 0.400 1.780 0.780 0.220 1.400 0.400 Issue date 7.50 7.40 SOT666 7-pin SMD packages Gy occupied area (2´) 0.65 (2´) 0.5 (4´) Ay solder resist Dimensions in mm handbook, full 0.6pagewidth 0.45 (4´) Hy SPy tot SLy solder land plus solder paste nSPy 0.538 1.7 1.075 2 0.4 (6´) 0.25 (2´) SPx tot SPy tot 0.500 0.300 SPx SPy Gx Gy Hx nSPx nSPx nSPy Hy 0.500 0.300 1.630 1.700 1.910 1.990 1 SPx 1 09-12-30 10-04-16 SPx tot SLx 1.70 DFN1714U-8 (SOT983) 5.50 0.60 (8×) DFN1714U-8 (SOT983) 1.30 2.25 2.15 4.00 6.60 7.00 5.50 8.15 8.35 1.30 1.27 (6×) 4.60 X D B 4.00 A A E 4.85 A3 5.40 7.95 b e 1 4 DFN2111-7 (SOT1358) C C A B C y1 C y 3.00 k E 1.50 A1 7 7.50 7.40 D 1.70 e1 solder lands 2.25 2.15 mounting base 5 8.35 8.15 4.60 0 1 max nom min mm A1 0.5 A 4 3 0.05 1 0.00 b 0.25 2.20 0.127 0.20 72.10 0.15 2.05 E e e1 1.2 1.1 1.0 0.5 1.0 e2 Lp 1.5 b k L L1 v 0.2 0.5 0.4 0.3 0.1 0.1 w y y1 IEC JEDEC --- European projection JEITA D2PAK-7 (SOT428) SOT1358-1 sot1358-1_po1.27 SPy P 2.54 0.70 0.80 8.92 MSD059 0.05 D2PAK-7 (SOT428) 13-08-21 13-09-12 Dimensions in mm. Hy Ay By Gy SLx 5 mm mm max nom min b A1 c 4.5 1.40 0.85 0.64 4.1 1.27 0.60 0.46 D1 E e 11 1.6 10.3 1.2 9.7 Lp 1.27 HD SPxGeneric Q 2.90 15.8 2.6 2.10 14.8 2.2 IEC JEDEC European projection JEITA SOT427 E D A1 e1 b 1 8 v w 4 Ay Gy By SPy SPy tot SPy tot w X A SLy LFPAK33 (SOT1210) LFPAK33 (SOT1210) footprint pattern y1 C D Dh 1.3 1.2 1.1 E Eh 1.45 0.45 1.35 0.40 1.25 0.35 e e1 0.4 1.2 k L v 0.30 0.25 0.20 0.1 y mounting base D D1 D2 DIMENSIONS mm By P inAy nSPx P y1 Slx Sly SPx tot SPy tot 1.780 By 0.780 D0.220 1.400 Slx 0.400 Sly0.500SPx0.300 tot Issue date SLx Issue date Generic footprint pattern DFN1714-8 (SOT1166) 0.400 Ay D 09-12-30 10-04-16 0.400 1.780 0.780 0.220 1.400 0.400 SPx tot 0.05 0.05 0.05 L DIMENSIONS in mm SPx w H solder resist solder resist 2 mm 0.2 A c1 occupied area y scale max 0.55 0.05 0.25 1.8 nom 0.20 0.127 1.7 1.6 min 0.00 0.15 A b1 L1 occupied area nSPy 1 Refer to the package outline drawing for actual layout solder land plus solder paste SLy C C A B C tiebars are indicated on arbitrary location and size 0 c b solder paste deposit Hy 5 Dh Dimensions b 4 e solder land plus solder paste c k A1 1 E L A D H solder paste deposit solder land 0.05 Eh mm SLy Generic footprint pattern solder land 0.05 Issue date detail X e P 06-03-16 12-10-16 A terminal 1 index area Unit(1) SPy tot Hx Gx References A B D terminal 1 index area MSD059 SLx sot427_po Outline version c1 SPx tot Refer to the package outline drawing for actual layout D X A A b1 nSPx scale A E e1 L SPx tot Dimensions (mm are the original dimensions) Unit(1) SPy SPx 8-pin SMD packages 2.5 sot096-1_fr nSPx Issue date solder paste Dimensions in mm. 0 Dimensions in mm 0.05 occupied area --- MO-252 (4×) solder resist SOT96 (SO8) Hx 0.20 solder lands Q placement accuracy ± 0.25 Gx D 3.00 Note e e e ofe 0.075 e 1. Plastic or metale protrusions mm maximum per side are not included. Outline version s mounting base 8.075 0.05 0.05 0.05 0.70 0.80 0.05 8.92 By Gy solder paste 5.40 7.95 c References Ay Hy 0.30 4.85 D Dimensions in mm SPy Gx Gy Hx Hy 0.500 1.910 1.990 SPy 0.300 tot 1.630 SPx 1.700 SPy Gx 0.300 1 nSPx nSPy 1 Gy 1 2 e Hx Hy 0.500 0.300 1.630 1.700 1.910 1.990 3 b (8x) nSPx nSPy 1 4 w A c X solder land plus solder paste solder paste deposit solder resist occupied area Dimensions in mm E1 E2 1 09-12-30 10-04-16 DFN1714-8 (SOT1166) Refer to the package outline drawing for actual layout 0.500 SPx solder land LFPAK56D (SOT1205) Packages A 2.54 occupied area 2 mm scale Dimensions (mm are the original dimensions) 0.05 P 1.27 (4×) solder resist 8.275 1.50 D HD placement accuracy ± 0.25 Gx L D1 occupied area 0.20 Hx 10.85 10.60 10.50 handbook, full pagewidth solder lands occupied area L1 A SOT96 (SO8) nSPy e2 terminal 1 index area solder lands 7.00 1.27 (6×) 8.075 nSPy DFN2111-7 (SOT1358) v w 6.60 0.30 A1 terminal 1 index area Unit(1) 0.60 (8×) 8.275 1.50 LFPAK56D (SOT1205) solder land Dimensions in mm Dimensions in mm solder paste deposit solder land plus solder paste occupied area solder resist 158 159 DIMENSIONS in mm P Ay By D Slx Sly SPx tot SPy tot SPx SPy Gx Gy Hx Hy nSPx nSPy DFN2520-9: plastic extremely thin small outline package; no leads; 9 terminals; body 2 x 2.5 x 0.5 mm Minimized outline drawings and reflow soldering footprint More than 8-pin SMD packages SOT1165-1 X D B A Footprint information for reflow soldering of DFN2520-9 package A E c Footprint information for reflow soldering of XSON10 package B SOT1165-1 A A E A1 e1 e 1 b 3 y1 C By Ay 0.5 A1 b c D 0.05 0.25 2.2 0.20 0.127 2.1 0.00 0.15 2.0 E e e1 1.1 1.0 0.9 0.4 1.6 k L v 0.2 0.43 0.38 0.33 0.1 0 w y 1 2 Hy By Ay Unit(1) 0.05 0.05 0.05 E e e1 2.6 2.5 2.4 2.1 2.0 1.9 0.5 2.0 k L v w 0.2 0.9 0.8 0.7 0.1 y y1 C 1.07 0.05 0.05 0.05 DFN2520-9 (SOT1333) References Outline version D1 SOT1165-1 0.05 SOT1333-1 0.05 IEC JEDEC JEITA --- MO-252 --- Generic footprint pattern D1 outline drawing for actual layout Refer to the package D Hx 0.05 P1 Ay 0.50 2.30 C sot1333-1_po European projection 1.07 DFN2520-9 (SOT1333) 13-05-08 13-05-21 Dimensions in mm A B D . 0.4 1.1 1. .4 0. E A .4 . Printed in the Netherlands 1. B D A c 0.01 1. 0.4 E solder paste deposit solder land plus solder paste A A1 0. 0.01 0.1 1 1 0. solder paste deposit solder land C A1 A3 side detail X terminal 1 index area solder resist covered via detail X e1 terminal 1 index area b1 e 1 b 5 Hy C C A B C v w y1 C solder land plus solder paste occupied area By Ay y Dimensions in mm 0.05 1 2 mm By C P Ay By C 0.500 1.3 0.25 0.525 0.500 1.3 A Unit A1 0.5 max nom min b D(1) E(1) e e1 2.6 0.127 2.5 2.4 1.1 1.0 0.9 0.5 2 b1 0.05 0.25 0.20 0.00 0.15 0.4 c k L v 0.2 0.43 0.38 0.33 0.1 w y e1 1 e b D 0. 4 y . 0.25 D D 0.525 0.20 D1 0.20 0.40 Remark: Hy Stencil of 75 μm is recommended. Remark: Stencil of 75Aμm is recommended. stencil of 75 μm gives an aspect ratio of 0.77 1.6 A stencil of 75 μm a gives an aspect ratio 0.77 will obtain an aspect ratio of 0.58 With stencil of 100 μmofone Hx D1 Hy Hx 2.45 0.40 2.45 1.6 With a stencil of 100 μm one will obtain an aspect ratio of 0.58 12 sot1165-1_fr 0 Unit(1) mm max nom min 1 2 mm A1 0.05 A3 b 0.25 0.127 0.20 0.00 0.15 solder land D Dh E Eh 2.6 2.5 2.4 2.25 2.20 2.15 2.2 2.1 2.0 1.15 1.10 1.05 e k L v 0.2 0.30 0.25 0.20 0.1 e1 0.4 2 w y y1 B A C D D1 Hx Hy 0.500 1.3 0.25 0.525 0.20 0.40 2.45 1.6 Remark: Stencil of 75 μm is recommended. A stencil of 75 μm gives an aspect ratio of 0.77 With a stencil of 100 μm one will obtain an aspect ratio of 0.58 terminal 1 index area e b 1 5 Dimensions in mm Hx sot1156-1_fr 0.05 y e1 e b 1 8 y1 C Ay Gy By SPy L nSPy L 1 9 Dh 0.5 max nom min 0.05 0.00 b 0.25 0.127 0.20 0.15 D E e e1 2.6 2.5 2.4 1.1 1.0 0.9 0.5 2 k L 0.2 L1 v 0.40 0.45 0.35 0.40 0.30 0.35 w 0.1 y 0 1 Unit(1) 0.05 0.05 0.05 mm Package outline 2 mm scale Dimensions y1 DIMENSIONS in mm tiebars are indicated on arbitrary location and size 2 mm scale Dimensions mm 16 6 A3 solder resist SLy k 0 A1 SPy tot y Eh A Reflow soldering footprint occupied area Hy C C A B C v w k Unit(1) solder land plus solder paste detail X terminal 1 index area L1 10 solder land 0.05 P c terminal 1 index area C y1 C occupied area 0. 0. side full covered number of vias solder paste deposit A3 C A B C v w solder resist A detail X e1 solder land plus solder paste solder paste deposit D A1 terminal 1 index area solder land A B D footprint 0. sot1165-1_fr E A1 Printed in the Netherlands Gx A E sot1156-1_fr © 2010 NXP B.V. solder resist covered via X By Dimensions in mm DFN2521-12 (SOT1156) Reflow soldering solder resist Ay occupied area 0. 0. side full covered number of vias 1 1 DFN2521-12 (SOT1156) occupied area P solder resist side solder land plus solder paste D 0. Printed in the Netherlands Note 1. On the heat sink pad there are four double mask triangles. This is to create a stand off and prevents solder paste to squeeze out and create solder shorts. Dimensions in mm solder land plus solder paste solder paste deposit 0. consequence of it’s use. Publication thereof 0.01 does not convey or imply any license 0.1 under patent- or other industrial or intellectual property rights. 0.05 0.05 0.05 solder paste deposit X solder land 0. All rights reserved. Reproduction in whole or in part is prohibited with © 2010 NXP B.V. part of any quotation or contract, is believed to be accurate and All rights reserved. Reproduction in whole or in part is prohibited without prior consent of the copyright owner. The information presented in this documentform does not form part of any quotation or contract, is believed to be accurate and reliable and may be 0.01 changed without notice. No liability will be accepted by the publisher for any consequence of it’s use. Publication thereof does not convey or imply Generic footprint pattern Refer to the package outline drawing for actual layout DFN2510-10 (SOT1165) .4 1 www.nxp.com www.nxp.com scale A 0.5 Note 1. On the heat sink pad there are four double mask triangles. This is to create a stand off and prevents solder paste to squeeze out and create solder shorts. 7 Dh sot1165-1_fr 0.05 0.05 0.05 DFN2510-10 (SOT1165) 0.4 1.1 1. .4 0. 0. 0.05 D1 y1 C k Dimensions y1 C C A B C v w 6 Eh scale Dimensions mm Ay P 6 Terminal#3 identification 0 L solder Dimensions in resist mm k 10 terminal 1 index area occupied area solder resist L .4 1 . 0. 4 terminal 1 index area 0.4 sot1333-1_fr 0. 4 12-09-25 13-05-01 All rights reserved. Reproduction in whole or in part is prohibited without prior consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of it’s use. Publication thereof does not convey or imply any license under patent- or other industrial or intellectual property rights. Generic footprint pattern Refer to the package outline drawing for actual layout 13-05-08 13-05-21 Dimensions in mm D1 0.30 Issue date X solder land 1. 0. 4 © 2010 NXP B.V. www.nxp.com P 0.30 . 1. 0. X D1 . DIMENSIONS in mm Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. D Footprint information for reflow soldering of XSON10 package D c 0.05 0.25 0.152 0.20 0.00 0.15 0.050 0.5 min 0.05 DFN2110-9 (SOT1178) b A1 A max nom mm DFN2110-9 (SOT1178) Ay 2.30 occupied area 3 mm scale Dimensions (mm are the original dimensions) y1 P1 0.50 .4 6 1 mm scale A occupied area y C 9 Dimensions 0.5 5 y1 C DIMENSIONS in mm 6 0 max nom min 3 C A B C v w k Hy Unit(1) 1 C b y k mm e L L 9 solder land index area P C C A B C v w 5 terminal 1 index area Cterminal 1 detail X terminal 1 index area detail X e1 Hx c terminal 1 index area SOT1333-1 A1 P X C (8x) More than 8-pin SMD packages Footprint information for reflow soldering of XSON10 package Hx D SOT1333-1 Minimized outline drawings and reflow soldering footprint A A1 b c D Dh max 0.55 0.05 0.25 3.4 nom 0.20 0.127 3.3 E Eh 1.45 0.45 1.35 0.40 2.9 2.8 e e1 0.4 2.8 k L v w 0.30 0.25 0.1 y DFN2510A-10 (SOT1176) P SPx Ay By D Slx Sly 0.400 1.780 0.780 0.220 3.000 0.400 SPx tot of DFN4020-14 package Footprint information for reflow soldering SPx tot SPy tot 2.350 0.300 SPx SPy Gx Gy Hx Hy 0.350 0.300 3.230 1.700 3.510 1.990 SOT1334-1 nSPx nSPy 3 1 SLx y1 0.05 0.05 0.05 DFN4020-14: plasticmin extremely outline package; no leads; terminals; body 2 x 4 x 0.5 mm 0.35 0.00 thin 0.15 small 3.2 2.7 1.25 0.20 0.2 14 DFN2510A-10 (SOT1176) nSPx SOT1334-1 D1 DFN3314-16 (SOT1168) (14x) DFN3314-16 (SOT1168) X D A E Gx D E solder paste deposit e1 terminal 1 index area detail X e1 e b 1 v w 6 C C A B C y1 C y Hy Ay Gy By SPy SPy tot 0 1 A1 b c D Dh 2.1 2.0 1.9 E Eh 1.45 0.45 1.35 0.40 1.25 0.35 e e1 0.4 2.0 k L v 0.2 0.30 0.25 0.20 0.1 w y y1 0.05 0.05 0.05 DFN2514-12 (SOT1167) y occupied area Ay SPx P Ay By 14 D Slx Sly 0.400 1.780 0.780 0.220 2.200 0.400 SPx tot SLx SPx tot SPy tot 1.500 0.300 SPx SPy Gx Gy Hx Hy 0.400 0.300 2.430 1.700 2.710 1.990 2 0 1 1 2 P1 Ay C D1 0.50 2.30 1.07 0.30 solder land 13-05-08 Dimensions inoccupied mm area 13-05-21 sot1334-1_fr Unit(1) max nom min A 0.5 A1 b D E e e1 4.1 4.0 3.9 2.1 2.0 1.9 0.5 3.5 c 0.05 0.25 0.152 0.20 0.00 0.15 0.050 3 mm DIMENSIONS in mm scale Dimensions (mm are the original dimensions) mm DFN2514-12 (SOT1167) 9 P1 nSPx nSPy k L v 0.2 0.9 0.8 0.7 0.1 w y y1 0.05 0.05 0.05 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT1334-1 Dimensions in mm y1 C DIMENSIONS in mm DIMENSIONS in mm nSPx 2 mm scale A C A B C v w 8 nSPy tiebars are indicated on arbitrary location and size Dimensions max 0.55 0.05 0.25 2.6 nom 0.20 0.127 2.5 min 0.00 0.15 2.4 b 6 C (12x) solder land C 3 k Eh 7 D1 (14x) L occupied area k Dh e 1 solder land plus solder paste SLy L 12 Ay c terminal 1 index area 0.05 c SOT1334-1 detail X solder land A1 A1 0.05 A terminal 1 index area terminal 1 index area P Footprint information for reflow soldering of DFN4020-14 package Packages A B D Unit(1) C (12x) A Hx X mm B DFN4020-14 (SOT1334) References IEC JEDEC JEITA --- MO-252 --- European projection sot1334-1_po Issue date P1 P1 Ay C D1 0.50 2.30 1.07 0.30 Dimensions in mm 13-05-08 13-05-21 sot1334-1_fr DFN4020-14 (SOT1334) 12-08-27 13-05-01 Dimensions in mm www.nxp.com © 2010 NXP B.V. All rights reserved. Reproduction in whole or in part is prohibited without prior consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of it’s use. Publication thereof does not convey or imply any license under patent- or other industrial or intellectual property rights. Printed in the Netherlands 160 161 SPx Hx nSPx Gx D SPy tot P 0.025 SPy 0.025 Minimized outline drawings and reflow soldering footprint Hy C Gy SLy nSPy By Minimized outline drawings and reflow soldering footprint Ay (0.105) SPx nSPx More than 8-pin SMD packages HVQFN32: plastic thermal enhanced very thin quad flat package; no leads; 32 terminals; body 5 x 5 x 0.85 mm Gy SPy SLy nSPy SOT617-1 By Single-ended and through-hole packages Ay SPx tot Bx pp E E 1 32 25 Dh X 0 2.5 P Ax 0.500 6.000 2 D (1) Dh E (1) Eh e e1 e2 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 5.1 4.9 3.25 2.95 5.1 4.9 3.25 2.95 0.5 3.5 3.5 0.5 0.3 0.1 0.05 0.05 0.1 4.200 07-05-07 09-06-15 Bx By By 4.200 CC 4.200 4.200 0.900 0.900 D D 0.290 0.290 SLx SLx SLy 3.100 SPx tot SPx SPytot tot SLy 3.100 3.100 1.800 3.100 1.800 1.800 SPx totSPy SPx Gx SPy 0.700 0.700 1.800 5.300 0.700 Gy SPy 5.300 0.700 HxGx Hy 6.250 Gy Hx Hy 5.300 6.250 6.250 6.250 5.300 sot617-1_fr sot617-1_fr Ax Generic footprint pattern Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES IEC JEDEC JEITA --- MO-220 --- EUROPEAN PROJECTION DFN5050-32 (SOT617) ISSUE DATE 0 0 Refer to the package outline drawing for actual layout solder land DFN5050-32 (SOT617) Notes Notes 1. 1. Lead Lead shoulder shoulderdesigns designsmay mayvary. vary. 2. 2. Dimension Dimensionincludes includesexcess excessdambar. dambar. SLx Bx 5 5 scale scale 10 mm 10 mm SOT78 (TO220AB) solder paste deposit 01-08-08 02-10-18 L2(1) L2(1) p cc D D D1D1 E E e e L L L1(1) L1(1)max. p q q Q Q max. 0.7 3.8 3.8 3.0 3.0 2.6 2.6 0.7 16.0 16.0 6.66.6 10.3 10.3 2.54 15.0 15.03.303.30 3.0 2.54 12.8 2.79 3.0 3.5 0.4 0.4 15.2 15.2 5.95.9 9.79.7 12.8 2.79 3.5 2.7 2.7 2.2 2.2 1 c SOT617-1 SPx tot 1.3 1.3 1.0 1.0 A1A b Ay Bx 6.000 07-05-07 09-06-15 Ay AA A1 6.000 6.000 Issue date By 1.6 1.6 1.0 1.0 c A(1) max. OUTLINE VERSION SPy tot 2 SLy nSPy c UNIT AyAx P 0.500 Issue date 5 mm scale DIMENSIONS (mm are the original dimensions) 2 nSPy Dimensions in mm Dimensions in mm 24 terminal 1 index area 2 Gy nSPx 0.9 0.9 0.6 0.6 moun moun ing ing base base 1/2 e nSPy 1.40 1.40 1.25 1.25 qq e2 Eh nSPx bb 4.7 4.7 4.1 4.1 L2(1) L2(1) occupied area AA11 mm mm 3 occupied area AA 3 Hy solder land plus solder paste e (2) (2) bb 1 1(2) b2b2(2) UNIT UNIT 2 solder land plus solder paste 17 DIMENSIONS DIMENSIONS(mm (mmare arethe theoriginal originaldimensions) dimensions) 2 16 8 SPy solder paste deposit b(3´) b(3´) 9 L y y1 C v M C A B w M C b SPx nSPx e e e1 1 (0.105) Generic footprint pattern Refer to the package outline drawing for actual layout solder paste solder deposit land 1 Ax e e Refer to the package outline drawing for actual layout solder land C 1/2 e 0.025 C Generic footprint pattern detail X e 0.025 D1 D 1 SLx c P b1(2) (2) b1(3´) (3´) b2(2) (2) b2(2´) (2´) A1 E D Ax D D Hx Gx Bx A L1(1) L1(1) SLx terminal 1 index area L L A B D SPy tot SPx tot Hy solder land plus solder paste nSPx occupied area nSPy 2 v M A Ay Bx By C D SLx SLy SPx tot SPy tot SPx SPy Gx Gy Hx Hy 6.000 4.200 4.200 0.900 0.290 3.100 3.100 1.800 1.800 0.700 0.700 5.300 5.300 6.250 6.250 Issue date 07-05-07 09-06-15 c Ax 6.000 sot617-1_fr D HE P 0.500 L E j scale mountin base P 0 5 10 mm q w M L1 T Notes 1. Terminal dimensions within this zone are uncontrolled. 2. Both recesses are Æ 2.5 ´ 0.8 max. depth . .0 2 1 N N e t e o 0. 0. 15.8 15.2 .5 . 10. . 1 2.5 e 5.08 e1 2. 1. 0. 0. .2 .0 . 0 1 . 1 .5 2. 1 e s o s 2 1 2. 2. .0 2. 2.5 0. 2 0 1 HE L Lp Q v w y Z (1) θ 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o b2 e 4.5 4.3 b1 E (2) 6.6 6.4 10. . e1 1 2. 1. 5.08 2.5 0. 0. 2 1 2 . 0 1 . 1 .5 2. 2. 2. .2 .0 .0 2. 2.5 0. 5 10 mm scale L D c SOT360 (TSSOP20) SOT360 (TSSOP20) .5 . L2 D (1) 0.2 0.1 D1 c 0.30 0.19 15.8 15.2 e1 1. 1.0 1.1 0. bp 0.25 e 1 0. 0. e 0. 0. 1 A3 0.95 0.80 A A2 0.15 0.05 A1 A1 1.1 Q A max. mm 1. 1.0 3 b 2 2. 2.5 N E P j K DIMENSIONS (mm are the original dimensions) UNIT 1.1 0. mm 5 mm 0. 0. q 2.5 scale 2. 2.5 2 2. Both recesses are Æ 2.5 ´ 0.8 max. depth mountin base 0 . .0 e s o s 1 Notes 1. Terminal dimensions within this zone are uncontrolled. T bp e detail X w M L1 L 10 w M Lp 1 b1 A θ e t e o 1 mm 3 (A 3) A1 b Q N N 2 e e1 A2 pin 1 index N 1 11 20 b2 Z K L2 D1 Generic footprint pattern. Refer to the package outline drawing for actual layout. Q X c y 2 Dimensions in mm A A A1 E D SOT186A (isolated TO220AB) E p1 Hx Generic footprint pattern. Refer to the package outline drawing for actual layout. D1 D1 (0.125) b1 b1 E E p1 b b E 3 3 Ay D1 D2 Gx Gy Hx Hy 0.635 0.660 6.600 4.200 1.200 0.450 0.500 5.245 4.500 5.500 6.850 D2 (4x) P1 D1 D1 0.7 1.3 0.4 1.0 A1 0.7 11 0.4 1.6 11 1.2 mounting base D1 E 10.3 1.6 9.7 1.2 eE Le LL1 L1 Q Q 10.3 2.54 9.7 15.0 2.54 13.5 3.30 15.0 2.79 13.5 3.30 2.6 2.79 2.2 2.6 2.2 L3 0 L 5 10 mm 10 mm 05 A A D scale mounting base L1 R L4 m 1 L2 5 b R w M c Q Q1 D 6.4 5.9 D1 10.3 9.7 E L1 R L2 5 R D1 15.8 15.2 1 D c Q2 L4 m m 0.7 0.4 L L A1 e b w M c Q 5.9 5.3 L1 Q1 E L p1 9.8 9.7 ∅p e b 1.7 0 5 10 mm scale Q2 5 DIMENSIONS (mm are the original dimensions) 0 L4 q L3 w M 2.4 1.6 L3(1) A mm 4.5 4.1 A1 b 1.39 0.85 1.27 0.70 c D D1 E e L L1 L2 L3(1) 0.7 0.4 15.8 15.2 6.4 5.9 10.3 9.7 1.7 9.8 9.7 5.9 5.3 5.2 5.0 2.4 1.6 3.8 3.6 ∅p mounting base m L2 0.8 0.6 10 mm (2) 0.5 L4 max. UNIT 5 L2 scale 5.2 5.0 R 0 A q 2.0 Q R 3.0 2.7 Q2 A1 Q1 Q p1 4.3 4.1 5 10 mm scale DIMENSIONS (mm are the original dimensions) (2) L4 max. 0.5 m ∅p p1 q Q Q1 Q2 R w 0.8 0.6 3.8 3.6 4.3 4.1 3.0 2.7 2.0 4.5 8.2 0.5 0.4 L1 c Q1 4.5 8.2 Q2 0.5 R w 0.4 162 SOD68 (DO-34) 0.85 1.3 A 0.60 1.0 L3 1 1.39 0.85 1.27 0.70 Dimensions in mm SOD66 (DO-41) 0.85 1.40 0.60 1.27 DD 1 max SOT226 e A SOD27 (DO-35) 1.40 4.5 1.27 4.1 Dc max e DIMENSIONS (mm are the original dimensions) 4.5 4.1 b mm UNIT Glass diodes 4.5 mm 4.1 scale Q Q c SOT519 (SSOP16) mm c1 b bb1 c SOT519 (SSOP16) A1 b Packages C AA1 q A1 By A1 mounting base Ay mounting base P2 A UNIT L1 L1 C P1 UNIT ∅p occupied area DIMENSIONS in mm DIMENSIONS (mm are(mm the original DIMENSIONS are original dimensions) D the dimensions) 2 e By 2 e Gy q D1 1 e 1 e Hy A1 D D (0.125) L L P2 solder land A ∅p Gx UNIT A mm 4.5 4.1 A1 b 1.39 0.85 1.27 0.70 c D D1 E e L 0.7 0.4 15.8 15.2 6.4 5.9 10.3 9.7 1.7 9.8 9.7 L1 L2 L3(1) L4(2) m ∅p p1 q Q Q1 Q2 R w 0.6 3.8 3.6 4.3 4.1 3.0 2.7 2.0 4.5 8.2 0.5 0.4 max. SOT263B-1 5.9 5.2 2.4 0.8 0.5 5.3 5.0 1.6 Dimensions in mm 163 Index Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number 1N47xxA series 40 2PD601BRL 22 BAS70-04W 38 BAT160A 37 1PS10SB82 39 2PD601BSL 22 BAS70-05 38 BAT160C 37 1PS66SB17 39 2PD602AQL 22 BAS70-05W 38 BAT160S 37 1PS66SB82 39 2PD602ARL 22 BAS70-06 38 BAT720 36 1PS70SB20 36 2PD602ASL 22 BAS70-06W 38 BAT721 38 1PS70SB82 39 2PD1820AR / S 22 BAS70-07 38 BAT721A 38 1PS70SB84 39 BAL74 42 BAS70-07S 38 BAT721C 38 1PS70SB85 39 BAL99 42 BAS70-07V 38 BAT721S 38 1PS70SB86 39 BAS16 42 BAS70H 38 BAT754 38 1PS74SB23 36 BAS16H 42 BAS70L 38 BAT754A 38 1PS76SB10 38 BAS16J 42 BAS70VV 38 BAT754C 38 Type Number BC52PAS / BC52-10PAS / BC52-16PAS BC53PA / BC53-10PA / BC53-16PA BC53PAS / BC53-10PAS / BC53-16PAS BC54PA / BC54-10PA / BC54-16PA BC54PAS / BC54-10PAS / BC54-16PAS BC55PA / BC55-10PA / BC55-16PA BC55PAS / BC55-10PAS / BC55-16PAS BC56PA / BC56-10PA / BC56-16PA BC56PAS / BC56-10PAS / BC56-16PAS Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number 24 BC856 / A / B 22 BCV49 26 BSP43 24 BUK7K6R2-40E 119 BUK7Y65-100E 125 24 BC856BM 22 BCV61/A/B/C 27 BSP50 26 BUK7K6R8-40E 119 BUK7Y72-80E 124 24 BC856BMB 22 BCV62/A/B/C 27 BSP51 26 BUK7K8R7-40E 119 BUK7Y98-80E 124 24 BC856BS 23 BCV63 / B 26 BSP52 26 BUK7K12-60E 121 BUK7Y102-100B 125 24 BC856S 23 BCV64B 26 BSP60 26 BUK7K13-60E 121 BUK7Y113-100E 125 24 BC856W / AW / BW 22 BCV65 28 BSP61 26 BUK7K17-60E 121 BUK7Y153-100E 125 24 BC857 / A / B / C 22 BCV71 / 72 22 BSP62 26 BUK7K18-40E 119 BUK9C10-55BIT 122, 129 24 BC857AMB / BMB / CMB 22 BCW29 / 30 22 BSR14 23 BUK7K25-40E 119 BUK9E04-40A 120 24 BC857AM / BM / CM 22 BCW31 / 32 / 33 22 BSR16 23 BUK7K29-100E 125 BUK9E06-55A 123 BC68PA / BC68-25PA 24 BC857AQA / BQA / CQA 22 BCW60B / C / D 22 BSR30 / 31 24 BUK7K32-100E 125 BUK9E06-55B 123 BC68PAS / BC68-25PAS 24 BC857BS 23 BCW61B / C / D 22 BSR33 24 BUK7K35-60E 121 BUK9E08-55B 123 24 BC857BV 23 BCW69 / 70 22 BSR41 24 BUK7K45-100E 125 BUK9K5R1-30E 118 24 BC857QAS 23 BCW71 / 72 22 BSR43 24 BUK7K52-60E 121 BUK9K5R6-30E 118 BC69PA / BC69-16PA / BC69-25PA BC69PAS / BC569-16PAS / BC69-25PAS 1PS76SB17 39 BAS16L 42 BAS70W 38 BAT754L 38 1PS76SB21 38 BAS16LD 42 BAS70XY 38 BAT754S 38 1PS76SB40 38 BAS16QA 42 BAS85 38 BAT760 36 BC807 / -16 / -25 / -40 22 BC857W / AW / BW / CW 22 BCW89 22 BSS63 22, 24 BUK7K89-100E 125 BUK9K6R2-40E 119 1PS76SB70 38 BAS16VV 42 BAS86 38 BAT854AW 38 BC807 / -25QA / -40QA 22 BC858B 22 BCX17 22 BSS64 22, 24 BUK7K134-100E 125 BUK9K6R8-40E 119 1PS79SB10 38 BAS16VY 42 BAS101 43 BAT854CW 38 BC807DS 23 BC858W 22 BCX18 22 BSS84AK 84, 88, 116 BUK7L06-34ARC 128 BUK9K8R7-40E 119 78, 84, 88, 116 1PS79SB17 39 BAS16W 42 BAS101S 43 BAT854SW 38 BC807W / -16W / -25W / -40W 22 BC859B 26 BCX19 22 BSS84AKM 1PS79SB30 38 BAS19 43 BAS116 44 BAT854W 38 BC817 / -16 / -25 / -40 22 BC859BW 26 BCX51 / -10 / -16 24 BSS84AKMB 1PS79SB31 38 BAS20 43 BAS116H 44 BAT960 36 BC817 / -25QA / -40QA 22 BC859C 26 BCX52 / -10 / -16 24 1PS79SB40 38 BAS21 43 BAS116L 44 BAV23 43 BC817DPN 23 BC859CW 26 BCX53 / -10 / -16 1PS79SB70 38 BAS21AVD 43 BAS116QA 44 BAV23A 43 BC817DS 23 BC860B 26 1PS88SB48 38 BAS21AW 43 BAS316 42 BAV23C 43 BC817W / -16W / -25W / -40W 22 BC860BW 1PS88SB82 39 BAS21H 43 BAS321 43 BAV23S 43 BC846 / A / B 22 1PS300 42 BAS21J 43 BAS416 44 BAV70 42 BC846BM 22 1PS301 42 BAS21PG 43 BAS521 43 BAV70M 42 BC846BMB 1PS302 42 BAS21SW 43 BAS716 44 BAV70QA 42 2N700BKM 78 BAS21VD 43 BAT17 39 BAV70S BUK7L11-34ARC 128 BUK9K12-60E 121 78, 88 BUK7Y3R5-40E 119 BUK9K13-60E 121 BSS84AKS 84, 90, 116 BUK7Y4R4-40E 119 BUK9K17-60E 121 24 BSS84AKV 84, 90, 116 BUK7Y4R8-60E 121 BUK9K18-40E 119 BCX54 / -10 / -16 24 BSS84AKW 84, 88, 116 BUK7Y6R0-60E 121 BUK9K25-40E 119 26 BCX55 / -10 / -16 24 BSS138AKA 84, 116 BUK7Y07-30B 118 BUK9K29-100E 125 BC860C 26 BCX56 / -10 / -16 24 BSS138BK 84, 116 BUK7Y7R2-60E 121 BUK9K32-100E 125 BC860CW 26 BCX70G / H / J / K 22 BSS138BKS 84, 116 BUK7Y7R6-40E 119 BUK9K35-60E 121 22 BC868 / -25 24 BCX71H / J / K 22 BSS138BKW 84, 116 BUK7Y7R8-80E 124 BUK9K45-100E 125 BC846BPN 23 BC869 / -16 / -25 24 BF550 28 BSS138P 84, 116 BUK7Y08-40B 119 BUK9K52-60E 121 42 BC846BS 23 BCM61B 27 BF570 28 BSS138PS 84, 116 BUK7Y8R7-60E 121 BUK9K89-100E 125 84, 116 2N7002BK 84, 116 BAS21W 43 BAT46WH 38 BAV70W 42 BC846DS 23 BCM62B 27 BF620 24 BSS138PW BUK7Y9R9-80E 124 BUK9K134-100E 125 2N7002BKM 84, 116 BAS28 42 BAT46WJ 38 BAV74 42 BC846S 23 BCM846BS 27 BF621 24 BST39 24 BUK7Y10-30B 118 BUK9Y3R0-40E 119 78 BAS29 44 BAT54 38 BAV99 42 BC846W / AW / BW 22 BCM847BS 27 BF622 24 BST50 26 BUK7Y12-40E 119 BUK9Y3R5-40E 119 2N7002BKS 84, 116 BAS31 44 BAT54A 38 BAV99QA 42 BC847 / A / B / C 22 BCM847BV 27 BF623 24 BST51 26 BUK7Y12-55B 121 BUK9Y4R4-40E 119 2N7002BKW 84, 116 BAS32L 42 BAT54AW 38 BAV99S 42 BC847AMB / BMB / CMB 22 BCM847DS 27 BF720 24 BST52 26 BUK7Y12-100E 125 BUK9Y4R8-60E 121 2N7002CK 2N7002BKMB 164 Index 84, 116 BAS35 44 BAT54C 38 BAV99W 42 BC847AM / BM / CM 22 BCM856BS 27 BF722 24 BST60 26 BUK7Y13-40B 119 BUK9Y6R0-60E 121 2PA1576Q / R / S 22 BAS40 38 BAT54CM 38 BAV102 43 BC847AQA / BQA / CQA 22 BCM856DS 27 BF723 24 BST61 26 BUK7Y14-80E 124 BUK9Y07-30B 118 2PA1774QMB / RMB / SMB 22 BAS40-04 38 BAT54CV 38 BAV103 43 BC847BPN 23 BCM857BS 27 BF820 24 BST62 26 BUK7Y15-60E 121 BUK9Y7R2-60E 121 2PA1774QM / RM / SM 22 BAS40-04W 38 BAT54CW 38 BAV170 44 BC847BS 23 BCM857BV 27 BF820W 24 BSV52 23 BUK7Y15-100E 125 BUK9Y7R6-40E 119 2PB709ARL 22 BAS40-05 38 BAT54H 38 BAV170M 44 BC847BV 23 BCM857DS 27 BF821 24 BUK7C06-40AITE 128 BUK7Y18-55B 121 BUK9Y8R5-80E 124 2PB709ART 22 BAS40-05V 38 BAT54J 38 BAV170QA 44 BC847BVN 23 BCP51 / -10 / -16 24 BF822 24 BUK7C08-55AITE 129 BUK7Y18-75B 124 BUK9Y8R7-60E 121 2PB709ARW / SW 22 BAS40-05W 38 BAT54L 38 BAV199 44 BC847DS 23 BCP52 / -10 / -16 24 BF823 24 BUK7C10-75AITE 129 BUK7Y19-100E 125 BUK9Y09-40B 119 2PB709ASL 22 BAS40-06 38 BAT54S 38 BAV199W 44 BC847QAPN 23 BCP53 / -10 / -16 24 BF824 28 BUK7E1R8-40E 120 BUK7Y20-30B 118 BUK9Y11-30B 118 2PB709BRL 22 BAS40-06W 38 BAT54SW 38 BAV756S 42 BC847QAS 23 BCP54 / -10 / -16 24 BF824W 28 BUK7E1R9-40E 120 BUK7Y21-40E 119 BUK9Y11-80E 124 2PB709BSL 22 BAS40-07 38 BAT54VV 38 BAW56 42 BC847W / AW / BW / CW 22 BCP55 / -10 / -16 24 BF840 28 BUK7E2R3-40E 120 BUK7Y22-100E 125 BUK9Y12-40E 119 2PB710ARL 22 BAS40-07V 38 BAT54W 38 BAW56M 42 BC848B 22 BCP56 / -10 / -16 24 BFS19 28 BUK7E2R6-60E 123 BUK7Y25-40B 119 BUK9Y12-55B 121 2PB710ASL 22 BAS40H 38 BAT54XY 38 BAW56QA 42 BC848W 22 BCP68 / -25 24 BFS20 28 BUK7E3R1-40E 120 BUK7Y25-60E 121 BUK9Y12-100E 125 2PB1219AQ / R / S 22 BAS40L 38 BAT74 38 BAW56S 42 BC849B 26 BCP69 / -16 / -25 24 BFS20W 28 BUK7E3R5-60E 123 BUK7Y25-80E 124 BUK9Y14-40B 119 2PC4081Q / R / S 22 BAS40W 38 BAT74S 38 BAW56W 42 BC849BW 26 BCV26 26 BSH111BK 86 BUK7E04-40A 120 BUK7Y28-75B 124 BUK9Y14-80E 124 2PC4617QMB / RMB 22 BAS40XY 38 BAT74V 38 BAW101 43 BC849C 26 BCV27 26 BSH205G2 88 BUK7E4R6-60E 123 BUK7Y29-40E 119 BUK9Y15-60E 121 2PC4617QM / RM 22 BAS45A 44 BAT85 38 BAW101S 43 BC849CW 26 BCV28 26 BSN20BK 86 BUK7E5R2-100E 126 BUK7Y38-100E 125 BUK9Y15-100E 125 2PD601ARL 22 BAS45AL 44 BAT86 38 BAW156 44 BC850B 26 BCV29 26 BSP19 24 BUK7E8R3-40E 120 BUK7Y41-80E 124 BUK9Y19-55B 121 2PD601ART 22 BAS56 44 BAT120A 37 24 BC850BW 26 BCV46 26 BSP31 24 BUK7E13-60E 123 BUK7Y43-60E 121 BUK9Y19-75B 124 2PD601ARW / SW 22 BAS70 38 BAT120C 37 24 BC850C 26 BCV47 26 BSP32 / 33 24 BUK7K5R1-30E 118 BUK7Y53-100B 125 BUK9Y19-100E 125 2PD601ASL 22 BAS70-04 38 BAT120S 37 24 BC850CW 26 BCV48 26 BSP41 24 BUK7K5R6-30E 118 BUK7Y59-60E 121 BUK9Y21-40E 119 BC51PA / BC51-10PA / BC51-16PA BC51PAS / BC51-10PAS / BC51-16PAS BC52PA / BC52-10PA / BC52-16PA 165 Index Type Number 166 Index Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number BUK9Y22-30B 118 BUK768R3-60E 122 BUK7507-30B 118 BUK7905-40ATE 128 BUK9609-40B 120 BZX84-y3V9 41 IP4254CZ12-6-TTL 66 NX3008CBKS 90 NZX5V1B 41 NZX15C 41 BUK9Y22-100E 125 BUK769R6-80E 124 BUK7507-55B 123 BUK7907-40ATC 129 BUK9609-75A 124 BZX84-y4V3 41 IP4254CZ16-8-TTL 66 NX3008CBKV 90 NZX5V1C 41 NZX15X 41 BUK9Y25-60E 121 BUK952R8-30B 118 BUK7508-40B 120 BUK7907-55AIE 129 BUK9610-100B 125 BZX84-y4V7 41 IP4264CZ8-20-TTL 67 NX3008NBK 84, 86, 116 NZX5V1D 41 NZX16A 41 BUK9Y25-80E 124 BUK953R2-40B 120 BUK7508-55A 123 BUK7907-55ATE 129 BUK9611-80E 124 BZX84-y5V1 41 IP4283CZ10-TBR 51, 64 NX3008NBKS 85, 91, 117 NZX5V6A 41 NZX16B 41 BUK9Y27-40B 119 BUK953R5-60E 123 BUK7509-55A 123 BUK7908-40AIE 129 BUK9612-55B 122 BZX84-y5V6 41 IP4285CZ9-TBB 51, 64 NX3008NBKV 84, 90, 116 NZX5V6B 41 NZX16C 41 BUK9Y29-40E 119 BUK954R2-55B 123 BUK7509-75A 124 BUK7909-75AIE 129 BUK9614-55A 122 BZX84-y6V2 41 IP4292CZ10-TBR 60, 64 NX3008NBKW 84, 86, 116 NZX5V6C 41 NZX18A 41 BUK9Y30-75B 124 BUK954R4-40B 120 BUK7510-100B 126 BUK7909-75ATE 129 BUK9614-60E 122 BZX84-y6V8 41 IP4294CZ10-TBR 52, 60, 64 BUK9Y38-100E 125 BUK954R8-60E 123 BUK7511-55B 123 BUK9107-40ATC 129 BUK9615-100A 125 BZX84-y7V5 41 IP4302CX2 BUK9Y40-55B 121 BUK961R6-40E 119 BUK7513-75B 124 BUK9107-55ATE 129 BUK9615-100E 125 BZX84-y8V2 41 IP4340CX15 BUK9Y41-80E 124 BUK962R5-60E 122 BUK7515-100A 126 BUK9209-40B 120 BUK9616-55A 122 BZX84-y9V1 41 IP4369CX4 135 BUK9Y43-60E 121 BUK962R6-40E 119 BUK7516-55A 123 BUK9212-55B 122 BUK9616-75B 124 BZX84-y10 41 IP4786CZ32 63 BUK9Y53-100B 125 BUK962R8-30B 118 BUK7520-55A 123 BUK9214-30A 118 BUK9620-55A 122 BZX84-y11 41 IP4786CZ32S BUK9Y58-75B 124 BUK962R8-60E 122 BUK7520-100A 126 BUK9215-55A 122 BUK9620-100B 125 BZX84-y12 41 IP4787CZ32 BUK9Y59-60E 121 BUK963R1-40E 119 BUK7526-100B 126 BUK9217-75B 124 BUK9624-55A 122 BZX84-y13 41 BUK9Y65-100E 125 BUK963R2-40B 119 BUK7528-55A 123 BUK9219-55A 122 BUK9628-55A 122 BZX84-y15 BUK9Y72-80E 124 BUK963R3-60E 122 BUK7528-100A 126 BUK9222-55A 123 BUK9628-100A 126 BUK9Y104-100B 125 BUK964R1-40E 119 BUK7535-55A 123 BUK9225-55A 123 BUK9629-100B BUK9Y107-80E 124 BUK964R2-55B 121 BUK7535-100A 126 BUK9226-75A 124 BUK9635-55A BUK9Y113-100E 125 BUK964R2-60E 122 BUK7575-55A 123 BUK9230-100B 126 BUK9Y153-100E 125 BUK964R2-80E 124 BUK7575-100A 126 BUK9237-55A BUK714R1-40BT 128 BUK964R4-40B 119 BUK7604-40A 120 BUK751R8-40E 120 BUK964R7-80E 124 BUK7606-55A BUK752R3-40E 120 BUK964R8-60E 122 BUK753R1-40E 120 BUK965R4-40E 120 BUK753R8-80E 124 BUK965R8-100E BUK754R0-55B 123 BUK755R2-40B NX3008PBK 84, 88, 116 NZX5V6D 41 NZX18B 41 54 NX3008PBKS 84, 90, 116 NZX5V6E 41 NZX18C 41 67, 135 NX3008PBKV 84, 90, 116 NZX6V2A 41 NZX20A 41 NX3008PBKW 84, 88, 116 NZX6V2B 41 NZX20B 41 NX3020NAK 87 NZX6V2C 41 NZX20C 41 63 NX3020NAKS 91 NZX6V2D 41 NZX22A 41 63 NX3020NAKV 91 NZX6V2E 41 NZX22B 41 IP4788CZ32 63 NX3020NAKW 87 NZX6V8A 41 NZX22C 41 41 IP4791CZ12 63 NX7002AK 87 NZX6V8B 41 NZX24A 41 BZX84-y16 41 IP4855CX25 63 NX7002AKS 91 NZX6V8C 41 NZX24B 41 126 BZX84-y18 41 IP4856CX25/C 63 NX7002AKW 87 NZX6V8D 41 NZX24C 41 122 BZX84-y20 41 MMBT2222A 23 NX7002BK 86 NZX7V5A 41 NZX24X 41 BUK9637-100E 126 BZX84-y22 41 MMBT3904 23 NX7002BKM 78, 87 NZX7V5B 41 NZX27A 41 123 BUK9640-100A 126 BZX84-y24 41 MMBT3906 23 NX7002BKMB 78, 87 NZX7V5C 41 NZX27B 41 BUK9240-100A 126 BUK9660-100A 126 BZX84-y27 41 MMBZ5V6AL 70 NX7002BKS 91 NZX7V5D 41 NZX27C 41 121 BUK9245-55A 123 BUK9675-55A 122 BZX84-y30 41 MMBZ6V2AL 70 NX7002BKW 87 NZX7V5X 41 NZX27X 41 BUK7606-55B 121 BUK9275-100A 126 BUK9675-100A 126 BZX84-y33 41 MMBZ6V8AL 70 NX7002BKXB 79, 91 NZX8V2A 41 NZX30A 41 BUK7606-75B 124 BUK9277-55A 123 BUK9907-40ATC 129 BZX84-y36 41 MMBZ9V1AL 70 NXP3875Y / G 22 NZX8V2B 41 NZX30B 41 125 BUK7607-30B 118 BUK9504-40A 120 BUK72150-55A 123 BZX84-y39 41 MMBZ10VAL 70 NZH series 40 NZX8V2C 41 NZX30C 41 BUK966R5-60E 122 BUK7607-55B 121 BUK9506-40B 120 BUK92150-55A 123 BZX84-y43 41 MMBZ12VAL 70 NZX2V1B 41 NZX8V2D 41 NZX30X 41 120 BUK969R0-60E 122 BUK7608-40B 120 BUK9506-75B 124 BUK96180-100A 126 BZX84-y47 41 MMBZ12VDL 70 NZX2V4A 41 NZX9V1A 41 NZX33A 41 BUK755R4-100E 126 BUK969R3-100E 125 BUK7608-55A 122 BUK9507-30B 118 BZA408B 58 BZX84-y51 41 MMBZ15VAL 70 NZX2V4B 41 NZX9V1B 41 NZX33B 41 BUK758R3-40E 120 BUK6213-30A 118 BUK7609-75A 124 BUK9508-55B 123 BZA420A 58 BZX84-y56 41 MMBZ15VDL 70 NZX2V7A 41 NZX9V1C 41 NZX33C 41 BUK761R6-40E 120 BUK7105-40AIE 128 BUK7610-55AL 122 BUK9509-40B 120 BZA456A 58 BZX84-y62 41 MMBZ18VAL 70 NZX2V7B 41 NZX9V1D 41 NZX36A 41 BUK761R7-40E 120 BUK7105-40ATE 128 BUK7610-100B 125 BUK9510-100B 126 BZA462A 58 BZX84-y68 41 MMBZ18VCL 70 NZX2V7C 41 NZX9V1E 41 NZX36B 41 BUK762R0-40E 119 BUK7107-40ATC 129 BUK7611-55A 122 BUK9511-55A 123 BZA856A 58 BZX84-y75 41 MMBZ20VAL 70 NZX3V0A 41 NZX10A 41 NZX36C 41 BUK762R4-60E 122 BUK7107-55AIE 129 BUK7611-55B 122 BUK9512-55B 123 BZA956A 58 BZX100A 40 MMBZ20VCL 70 NZX3V0B 41 NZX10B 41 NZX36X 41 BUK762R6-40E 119 BUK7107-55ATE 129 BUK7613-60E 122 BUK9514-55A 123 BZA962A 58 BZX384 series 40 MMBZ27VAL 70 NZX3V0C 41 NZX10C 41 NZX series 40 BUK762R6-60E 122 BUK7108-40AIE 129 BUK7613-75B 124 BUK9515-100A 126 BZA968A 58 BZX585 series 40 MMBZ27VCL 70 NZX3V3A 41 NZX10D 41 PBHV3160Z 18 BUK762R7-30B 118 BUK7109-75AIE 129 BUK7613-100E 125 BUK9518-55A 123 BZB84 series 40 BZX884 series 40 MMBZ33VAL 70 NZX3V3B 41 NZX11A 41 PBHV8115QA 18 BUK762R9-40E 119 BUK7109-75ATE 129 BUK7620-55A 122 BUK9520-100A 126 BZB100A 40 IP3319CX6 59, 135 MMBZ33VCL 70 NZX3V3C 41 NZX11B 41 PBHV8115T 18 BUK763R1-40B 119 BUK7208-40B 120 BUK7620-100A 126 BUK9520-100B 126 BZB784 series 40 IP4049CX5 135 NCR401T 25 NZX3V6A 41 NZX11C 41 PBHV8115X 18 BUK763R1-60E 122 BUK7210-55B 122 BUK7623-75A 124 BUK9529-100B 126 BZB984 series 40 IP4049CX5/LF 67 NCR401U 25 NZX3V6B 41 NZX11D 41 PBHV8115Z 18 BUK763R4-30B 118 BUK7212-55B 122 BUK7624-55A 122 BUK9535-55A 123 BZT52H series 40 IP4220CZ6 51, 59, 62 NCR402T 25 NZX3V6C 41 NZX12A 41 PBHV8118T 18 BUK763R8-80E 124 BUK7214-75B 124 BUK7626-100B 126 BUK9535-100A 126 BZV49 series 40 IP4221CZ6-S 51, 59, 67 NCR402U 25 NZX3V9A 41 NZX12B 41 PBHV8140Z 18 BUK763R9-60E 122 BUK7215-55A 122 BUK7628-55A 122 BUK9575-55A 123 BZV55 series 40 IP4221CZ6-XS 51, 59, 67 NCR405U 25 NZX3V9B 41 NZX12C 41 PBHV8215Z 18 BUK764R0-40E 120 BUK7219-55A 123 BUK7628-100A 126 BUK9575-100A 126 BZV85 series 40 IP4251CZ8-4-TTL 66 NUP1301 49 NZX3V9C 41 NZX12D 41 PBHV8540T 18 BUK764R0-55B 121 BUK7222-55A 123 BUK7631-100E 126 BUK9604-40A 119 BZV90 series 40 IP4251CZ12-6-TTL 66 NUP1301U 49 NZX4V3A 41 NZX12X 41 PBHV8540X 18 BUK764R2-80E 124 BUK7226-75A 124 BUK7635-55A 122 BUK9605-30A 118 BZX79 series 40 IP4251CZ16-8-TTL 66 NX138AK 87 NZX4V3B 41 NZX13A 41 PBHV8540Z 18 BUK764R4-60E 122 BUK7227-100B 126 BUK7635-100A 126 BUK9606-40B 120 BZX84J series 40 IP4252CZ8-4 -TTL 66 NX138AKS 90 NZX4V3C 41 NZX13B 41 PBHV8560Z 18 BUK765R0-100E 125 BUK7230-55A 123 BUK7640-100A 126 BUK9606-55A 121 BZX84 series 40 IP4252CZ12-6-TTL 66, 67 NX138AKW 86 NZX4V3D 41 NZX13C 41 PBHV9040T 18 BUK765R2-40B 120 BUK7237-55A 123 BUK7660-100A 126 BUK9606-55B 121 BZX84-y2V4 41 IP4252CZ16-8-TTL 66 NX138BK 86 NZX4V7A 41 NZX14A 41 PBHV9040X 18 BUK765R3-40E 120 BUK7240-100A 126 BUK7675-55A 122 BUK9606-75B 124 BZX84-y2V7 41 IP4253CZ8-4-TTL 66 NX138BKS 90 NZX4V7B 41 NZX14B 41 PBHV9040Z 18 BUK766R0-60E 122 BUK7275-100A 126 BUK7675-100A 126 BUK9607-30B 118 BZX84-y3V0 41 IP4253CZ12-6-TTL 66 NX138BKW 86 NZX4V7C 41 NZX14C 41 PBHV9050T 18 BUK768R1-40E 120 BUK7277-55A 123 BUK7905-40AI 128 BUK9608-55A 121 BZX84-y3V3 41 IP4253CZ16-8-TTL 66 NX1029X 90 NZX4V7D 41 NZX15A 41 PBHV9050Z 18 BUK768R1-100E 125 BUK7506-55A 123 BUK7905-40AIE 128 BUK9608-55B 121 BZX84-y3V6 41 IP4254CZ8-4-TTL 66 NX2301P 84, 88, 116 NZX5V1A 41 NZX15B 41 PBHV9115QA 18 167 Index Type Number 168 Index Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number PBHV9115T 18 PBSS301PX 12 PBSS4032NX 11 PBSS4320X 11 PBSS5330X 12 PDTA114TT 20 PDTA143TT 20 PDTC114EMB 20 PDTC143EMB 20 PDTD143ET 21 PBHV9115X 18 PBSS301PZ 12 PBSS4032NZ 11 PBSS4330PA 11 PBSS5350D 12 PDTA114TU 20 PDTA143TU 20 PDTC114EQA 20 PDTC143EQA 20 PDTD143EU 21 PBHV9115Z 18 PBSS302ND 11 PBSS4032PD 12 PBSS4330PAS 11 PBSS5350SS 13 PDTA114YM 20 PDTA143XM 20 PDTC114ET 20 PDTC143ET 20 PDTD143XQA 21 PBHV9215Z 18 PBSS302NX 11 PBSS4032PT 15 PBSS4330X 11 PBSS5350T 15 PDTA114YMB 20 PDTA143XMB 20 PDTC114EU 20 PDTC143EU 20 PDTD143XT 21 PBHV9414Z 18 PBSS302NZ 11 PBSS4032PX 12 PBSS4350D 11 PBSS5350X 12 PDTA114YQA 20 PDTA143XQA 20 PDTC114TM 20 PDTC143TM 20 PDTD143XU 21 PBHV9540Z 18 PBSS302PD 12 PBSS4032PZ 12 PBSS4350SPN 13 PBSS5350Z 12 PDTA114YT 20 PDTA143XT 20 PDTC114TMB 20 PDTC143TMB 20 PDZ-B series 40 PBHV9560Z 18 PBSS302PX 12 PBSS4032SN 13 PBSS4350SS 13 PBSS5360PAS 12 PDTA114YU 20 PDTA143XU 20 PDTC114TT 20 PDTC143TT 20 PEMB1 21 PBLS1501Y 16 PBSS302PZ 12 PBSS4032SP 13 PBSS4350T 14 PBSS5360Z 12 PDTA115EM 20 PDTA143ZM 20 PDTC114TU 20 PDTC143TU 20 PEMB2 21 PBLS1502Y 16 PBSS303ND 11 PBSS4032SPN 13 PBSS4350X 11 PBSS5480X 12 PDTA115EMB 20 PDTA143ZMB 20 PDTC114YM 20 PDTC143XM 20 PEMB3 21 PBLS1503Y 16 PBSS303NX 11 PBSS4041NT 14 PBSS4350Z 11 PBSS5520X 12 PDTA115ET 20 PDTA143ZQA 20 PDTC114YMB 20 PDTC143XMB 20 PEMB4 21 PBLS1504Y 16 PBSS303NZ 11 PBSS4041NX 11 PBSS4360PAS 11 PBSS5540X 12 PDTA115EU 20 PDTA143ZT 20 PDTC114YQA 20 PDTC143XQA 20 PEMB9 21 PBLS2001D 16 PBSS303PD 12 PBSS4041NZ 11 PBSS4360Z 11 PBSS5540Z 12 PDTA115TM 20 PDTA143ZU 20 PDTC114YT 20 PDTC143XT 20 PEMB10 21 PBLS2002D 16 PBSS303PX 12 PBSS4041PT 15 PBSS4480X 11 PBSS5560PA 12 PDTA115TMB 20 PDTA144EM 20 PDTC114YU 20 PDTC143XU 20 PEMB11 21 PBLS2003D 16 PBSS303PZ 12 PBSS4041PX 12 PBSS4520X 11 PBSS5580PA 12 PDTA115TT 20 PDTA144EMB 20 PDTC115EM 20 PDTC143ZM 20 PEMB13 21 PBLS2004D 16 PBSS304ND 11 PBSS4041PZ 12 PBSS4540X 11 PBSS5612PA 12 PDTA115TU 20 PDTA144EQA 20 PDTC115EMB 20 PDTC143ZMB 20 PEMB14 21 PBLS2021D 16 PBSS304NX 11 PBSS4041SN 13 PBSS4540Z 11 PBSS5620PA 12 PDTA123EM 20 PDTA144ET 20 PDTC115ET 20 PDTC143ZQA 20 PEMB15 21 PBLS2022D 16 PBSS304NZ 11 PBSS4041SP 13 PBSS4560PA 11 PBSS5630PA 12 PDTA123EMB 20 PDTA144EU 20 PDTC115EU 20 PDTC143ZT 20 PEMB16 21 PBLS2023D 16 PBSS304PD 12 PBSS4041SPN 13 PBSS4580PA 11 PBSS8110D 11 PDTA123ET 20 PDTA144TM 20 PDTC115TM 20 PDTC143ZU 20 PEMB17 21 PBLS2024D 16 PBSS304PX 12 PBSS4112PAN 13 PBSS4612PA 11 PBSS8110T 14 PDTA123EU 20 PDTA144TMB 20 PDTC115TMB 20 PDTC144EM 20 PEMB18 21 PBLS4001D 16 PBSS304PZ 12 PBSS4112PANP 13 PBSS4620PA 11 PBSS8110X 11 PDTA123JM 20 PDTA144TT 20 PDTC115TT 20 PDTC144EMB 20 PEMB19 21 PBLS4001Y 16 PBSS305ND 11 PBSS4120T 14 PBSS4630PA 11 PBSS8110Y 14 PDTA123JMB 20 PDTA144TU 20 PDTC115TU 20 PDTC144EQA 20 PEMB20 21 PBLS4002D 16 PBSS305NX 11 PBSS4130PAN 13 PBSS5112PAP 13 PBSS8110Z 11 PDTA123JT 20 PDTA144VM 20 PDTC123EM 20 PDTC144ET 20 PEMB24 21 PBLS4002Y 16 PBSS305NZ 11 PBSS4130PANP 13 PBSS5120T 15 PBSS8510PA 11 PDTA123JU 20 PDTA144VMB 20 PDTC123EMB 20 PDTC144EU 20 PEMB30 21 PBLS4003D 16 PBSS305PD 12 PBSS4130QA 14 PBSS5130PAP 13 PBSS9110D 12 PDTA123TM 20 PDTA144VT 20 PDTC123ET 20 PDTC144TM 20 PEMD2 21 PBLS4003Y 16 PBSS305PX 12 PBSS4130T 14 PBSS5130QA 15 PBSS9110T 15 PDTA123TMB 20 PDTA144VU 20 PDTC123EU 20 PDTC144TMB 20 PEMD3 21 PBLS4004D 16 PBSS305PZ 12 PBSS4140DPN 13 PBSS5130T 15 PBSS9110X 12 PDTA123TT 20 PDTA144WM 20 PDTC123JM 20 PDTC144TT 20 PEMD4 21 PBLS4004Y 16 PBSS306NX 11 PBSS4140T 14 PBSS5140T 15 PBSS9110Y 15 PDTA123TU 20 PDTA144WMB 20 PDTC123JMB 20 PDTC144TU 20 PEMD6 21 PBLS4005D 16 PBSS306NZ 11 PBSS4140U 14 PBSS5140U 15 PBSS9110Z 12 PDTA123XQA 20 PDTA144WT 20 PDTC123JT 20 PDTC144VM 20 PEMD9 21 PBLS4005Y 16 PBSS306PX 12 PBSS4160DPN 13 PBSS5160DS 13 PBSS9410PA 12 PDTA123YM 20 PDTA144WU 20 PDTC123JU 20 PDTC144VMB 20 PEMD10 21 PBLS6001D 16 PBSS306PZ 12 PBSS4160DS 13 PBSS5160PAP 13 PCMF1HDMI2S 62 PDTA123YMB 20 PDTB113EQA 21 PDTC123TM 20 PDTC144VT 20 PEMD12 21 PBLS6002D 16 PBSS2515M 14 PBSS4160PAN 13 PBSS5160PAPS 60, 61 PDTA123YT 20 PDTB113ET 21 PDTC123TMB 20 PDTC144VU 20 PEMD13 21 PBLS6003D 16 PBSS2515MB 14 PBSS4160PANP 13 PBSS5160QA 15 PCMF2DFN1 62 PDTA123YU 20 PDTB113EU 21 PDTC123TT 20 PDTC144WM 20 PEMD14 21 PBLS6004D 16 PBSS2515VPN 13 PBSS4160PANPS 13, 17 PBSS5160T 15 PCMF2HDMI2S 62 PDTA124EM 20 PDTB113ZQA 21 PDTC123TU 20 PDTC144WMB 20 PEMD15 21 PBLS6005D 16 PBSS2515VS 13 PBSS4160PANS 13, 17 PBSS5160U 15 PCMF2USB3S 61 PDTA124EMB 20 PDTB113ZT 21 PDTC123XQA 20 PDTC144WT 20 PEMD16 21 PBLS6021D 16 PBSS2540M 14 PBSS4160QA 14 PBSS5220PAPS 17 PCMF3DFN1 62 PDTA124EQA 20 PDTB113ZU 21 PDTC123YM 20 PDTC144WU 20 PEMD17 21 PBLS6022D 16 PBSS2540MB 14 PBSS4160T 14 PBSS5220T 15 PCMF3HDMI2S 62 PDTA124ET 20 PDTB114EQA 21 PDTC123YMB 20 PDTD113EQA 21 PEMD18 21 PBLS6023D 16 PBSS3515M 15 PBSS4160U 14 PBSS5230PAP 13 PCMF3USB3S 61 PDTA124EU 20 PDTB114ET 21 PDTC123YT 20 PDTD113ET 21 PEMD19 21 PBLS6024D 16 PBSS3515MB 15 PBSS4220PANS 17 PBSS5230QA 15 PDTA113EM 20 PDTA124TM 20 PDTB114EU 21 PDTC123YU 20 PDTD113EU 21 PEMD20 21 PBRN113ET 18 PBSS3515VS 13 PBSS4230PAN 13 PBSS5230T 15 PDTA113EMB 20 PDTA124TMB 20 PDTB123EQA 21 PDTC124EM 20 PDTD113ZQA 21 PEMD24 21 PBRN113ZT 18 PBSS3540M 15 PBSS4230PANP 13 PBSS5240T 15 PDTA113ET 20 PDTA124TT 20 PDTB123ET 21 PDTC124EMB 20 PDTD113ZT 21 PEMD30 21 PBRN123ET 18 PBSS3540MB 15 PBSS4230T 14 PBSS5240X 12 PDTA113EU 20 PDTA124TU 20 PDTB123EU 21 PDTC124EQA 20 PDTD113ZU 21 PEMD48 21 PBRN123YT 18 PBSS4021NT 14 PBSS4240DPN 13 PBSS5240Y 15 PDTA113ZM 20 PDTA124XM 20 PDTB123TT 21 PDTC124ET 20 PDTD114EQA 21 PEMH1 21 PBRP113ET 18 PBSS4021NX 11 PBSS4240T 14 PBSS5250T 15 PDTA113ZMB 20 PDTA124XMB 20 PDTB123YQA 21 PDTC124EU 20 PDTD114ET 21 PEMH2 21 PBRP113ZT 18 PBSS4021NZ 11 PBSS4240X 11 PBSS5250X 12 PDTA113ZT 20 PDTA124XT 20 PDTB123YT 21 PDTC124TM 20 PDTD114EU 21 PEMH4 21 PBRP123ET 18 PBSS4021PT 15 PBSS4240Y 14 PBSS5260PAP 13 PDTA113ZU 20 PDTA124XU 20 PDTB123YU 21 PDTC124TMB 20 PDTD123EQA 21 PEMH7 21 PBRP123YT 18 PBSS4021PX 12 PBSS4250X 11 PBSS5260PAPS 13, 17 PDTA114EM 20 PDTA143EM 20 PDTB143EQA 21 PDTC124TT 20 PDTD123ET 21 PEMH9 21 PBSM5240PF 19 PBSS4021PZ 12 PBSS4260PAN 13 PBSS5260QA 15 PDTA114EMB 20 PDTA143EMB 20 PDTB143ET 21 PDTC124TU 20 PDTD123EU 21 PEMH10 21 PBSM5240PFH 19 PBSS4021SN 13 PBSS4260PANP 13 PBSS5320D 12 PDTA114EQA 20 PDTA143EQA 20 PDTB143EU 21 PDTC124XM 20 PDTD123TT 21 PEMH11 21 PBSS301ND 11 PBSS4021SP 13 PBSS4260PANPS 13, 17 PBSS5320T 15 PDTA114ET 20 PDTA143ET 20 PDTB143XQA 21 PDTC124XMB 20 PDTD123YQA 21 PEMH13 21 PBSS301NX 11 PBSS4021SPN 13 PBSS4260PANS 13, 17 PBSS5320X 12 PDTA114EU 20 PDTA143EU 20 PDTB143XT 21 PDTC124XT 20 PDTD123YT 21 PEMH14 21 PBSS301NZ 11 PBSS4032ND 11 PBSS4260QA 14 PBSS5330PA 12 PDTA114TM 20 PDTA143TM 20 PDTB143XU 21 PDTC124XU 20 PDTD123YU 21 PEMH15 21 PBSS301PD 12 PBSS4032NT 14 PBSS4320T 14 PBSS5330PAS 12 PDTA114TMB 20 PDTA143TMB 20 PDTC114EM 20 PDTC143EM 20 PDTD143EQA 21 PEMH16 21 13, 17 PCMF1USB3S 169 Index Type Number Page Number PEMH17 21 PESD3V3U1UA 53 PESD5V0S2UAT 58 PESD6V0L2UU 54 PHB21N06LT 105 PHPT60415NY 10 PMBT4403YS 23 PMEG050T150EPD 33 PMEG2020AEA 36 PMEG3020EP 33 PEMH18 21 PESD3V3U1UB 53 PESD5V0S2UQ 58 PESD9V0V4UK 55 PHB27NQ10T 107 PHPT60415PY 10 PMBT5550 24 PMEG050V150EPD 33 PMEG2020CPA 37 PMEG3020EPA 35 PEMH19 21 PESD3V3U1UL 53 PESD5V0S4UD 58 PESD12VL1BA 53 PHB29N08T 106 PHPT60603NY 10 PMBT5551 / BSR19A 24 PMEG060V050EPD 33 PMEG2020CPAS 37 PMEG3020EPAS 35 PEMH20 21 PESD3V3U1UT 62 PESD5V0S4UF 58 PESD12VL2BT 55 PHB32N06LT 105 PHPT60603PY 10 PMBT6428 22 PMEG060V100EPD 33 PMEG2020EH 36 PMEG3020ER 33 PEMH24 21 PESD3V3V4UK 55 PESD5V0S5UD 58 PESD12VS1UA 57, 69 PHB33NQ20T 109 PHPT60606NY 10 PMBT6429 22 PMEG100V060ELPD 33 PMEG2020EJ 36 PMEG3030BEP 33 PEMH30 21 PESD3V3V4UW 55 PESD5V0U1BA 54 PESD12VS1UB 57 PHB45NQ10T 107 PHPT60606PY 10 PMBTA06 22 PMEG100V080ELPD 33 PMEG2020EPA 35 PMEG3030EP 33 PESD3V3X1BCSF 49 PESD5V0U1BB 54 PESD12VS1UJ 57, 69 PHB45NQ15T 108 PHPT60610NY 10 PMBTA13 26 PMEG100V100ELPD 33 PMEG2020EPAS 35 PMEG3050BEP 33 PESD3V3X1BL 49 PESD5V0U1BL 54 PESD12VS1UL 57 PHB47NQ10T 107 PHPT60610PY 10 PMBTA14 26 PMEG1020EA 36 PMEG2020EPK 35 PMEG3050EP 33 PEMI6CSP-RW 135 PEMI6CSP/RW 66 Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number PEMI8CSP-RW-P 135 PESD5V0C1BSF 49, 60 PESD5V0U1BLD 54 PESD12VS1ULD 57 PHB66NQ03LT 101 PHPT61002NYC 10 PMBTA42 24 PMEG1020EH 36 PMEG3002AEB 36 PMEG4002AESF 34 PEMI8CSP/RW/P 66 PESD5V0C1USF 49, 60 PESD5V0U1UA 53 PESD12VS2UQ 58 PHB110NQ08T 106 PHPT61002PYC 10 PMBTA42DS 24 PMEG1020EJ 36 PMEG3002AEL 35 PMEG4002EB 36 PEMT1 23 PESD5V0F1BL 49 PESD5V0U1UB 53 PESD12VS2UT 58 PHB191NQ06LT 105 PHPT61003NPK 10 PMBTA44 24 PMEG1020EV 36 PMEG3002AELD 35 PMEG4002EJ 36 PEMX1 23 PESD5V0F1BLD 49 PESD5V0U1UL 53 PESD12VS5UD 58 PHC2300 108 PHPT61003NY 10 PMBTA45 18 PMEG1030EH 36 PMEG3002AESF 34 PMEG4002EL 35 PEMZ1 23 PESD5V0F1BRLD 49 PESD5V0U1UT 62 PESD12VU1UT 62 PHC21025 108 PHPT61003PY 10 PMBTA56 22 PMEG1030EJ 36 PMEG3002EJ 36 PMEG4002ELD 35 PEMZ7 23 PESD5V0F1BRSF 49 PESD5V0U2BM 55 PESD12VV1BL 54 PHD9NQ20T 109 PHPT61006NY 10 PMBTA64 26 PMEG2002AESF 34 PMEG3002ESF 34 PMEG4002ESF 34 PESD1CAN 68 PESD5V0F1BSF 49 PESD5V0U2BMB 55 PESD15VL1BA 53 PHD20N06T 105 PHPT61006PY 10 PMBTA92 24 PMEG2002ESF 34 PMEG3002TV 37 PMEG4005AEA 36 PESD1CAN-U 68 PESD5V0F1BSH 48, 49 PESD5V0U2BT 55 PESD15VL2BT 55 PHD38N02LT 101 PHPT61010NY 10 PMC85XP 81 PMEG2005AEA 36 PMEG3005AEA 36 PMEG4005AESF 34 PESD1FLEX 68 PESD5V0F1USF 49 PESD5V0U4BF 56 PESD15VS1UB 57 PHD71NQ03LT 103 PHPT61010PY 10 PMCM440VNE 82, 135 PMEG2005AEL 35 PMEG3005AESF 34 PMEG4005AEV 36 PESD1IVN-U 68 PESD5V0F5UF 52 PESD5V0U4BW 56 PESD15VS1UL 57 PHD97NQ03LT 101 PHPT610030NK 10 PMCM440VPE 135 PMEG2005AELD 35 PMEG3005AEV 36 PMEG4005CT 37 PESD1LIN 68 PESD5V0F5UV 52 PESD5V0U5BF 56 PESD15VS1ULD 57 PHD101NQ03LT 103 PHPT610030PK 10 PMCM650VNE 82, 135 PMEG2005AESF 34 PMEG3005CT 37 PMEG4005EH 36 PESD1LVDS 68 PESD5V0H1BSF 49, 60 PESD5V0U5BV 56 PESD15VS2UAT 58 PHDMI2F4 64 PHPT610035NK 10, 27 PMCM650VPE 135 PMEG2005AEV 36 PMEG3005EB 36 PMEG4005EJ 36 PESD1NFC-L 65 PESD5V0L1BA 53 PESD5V0V1BA 54 PESD15VS2UQ 58 PHK04P02T 108 PHPT610035PK 10, 27 PMCM4401VNE 82, 135 PMEG2005BELD 35 PMEG3005EH 36 PMEG4005EPK 35 PESD1NFC-SF 65 PESD5V0L1BSF 53 PESD5V0V1BB 54 PESD15VS2UT 58 PHK5NQ15T 108 PHT4NQ10T 107 PMCM4401VPE 82, 135 PMEG2005CT 37 PMEG3005EJ 36 PMEG4005ESF 34 PESD1USB3S 170 Index 60, 61 PESD5V0L1UA 53 PESD5V0V1BCSF 54 PESD15VS5UD 58 PHK12NQ03LT 103 PHT6NQ10T 107 PMCM6501VNE 82 PMEG2005EB 36 PMEG3005EL 35 PMEG4005ET 36 PESD2CAN 68 PESD5V0L1UB 53 PESD5V0V1BDSF 54 PESD15VU1UT 62 PHK13N03LT 103 PIMT1 23 PMCM6501VPE 82 PMEG2005EH 36 PMEG3005ELD 35 PMEG4010AESB 34 PESD2IVN-U 68 PESD5V0L1UL 53 PESD5V0V1BL 54 PESD16VX1UL 49 PHK18NQ03LT 103 PIMZ2 23 PMCPB5530X 81, 90 PMEG2005EJ 36 PMEG3005ESF 34 PMEG4010BEA 36 PESD2LVDS 68 PESD5V0L1ULD 53 PESD5V0V1BLD 54 PESD18VF1BL 49, 65 PHK31NQ03LT 103 PLVA600A series 40 PMCXB900UE 79, 90 PMEG2005EL 35 PMEG3005ET 36 PMEG4010BEV 36 PESD2NFC-L 65 PESD5V0L1USF 53 PESD5V0V1BSF 54 PESD18VF1BSF 49, 65 PHKD3NQ10T 107, 108 PMBD353 39 PMCXB1000UE 79, 90 PMEG2005ELD 35 PMEG3010AESA 34 PMEG4010CEH 36 PESD2NFC-SF 65 PESD5V0L2BT 55 PESD5V0V2BM 55, 67, 69 PESD24VF1BL 49, 65 PHKD6N02LT 108 PMBD354 39 PMD2001D 28 PMEG2005EPK 35 PMEG3010AESB 34 PMEG4010CEJ 36 PESD2USB3S 61 PESD5V0L2UM 54 PESD5V0V2BMB 55, 67, 69 PESD24VF1BSF 49, 65 PHKD13N03LT 108 PMBS3904 23 PMD3001D 28 PMEG2005ESF 34 PMEG3010BEA 36 PMEG4010CPA 37 PESD3USB3S 61 PESD5V0L2UMB 54 PESD5V0V4UK 55 PESD24VL1BA 53 PHN203 108 PMBS3906 23 PMDPB30XN 81, 90 PMEG2005ET 36 PMEG3010BEP 33 PMEG4010CPAS 37 PESD3V3C1BSF 49 PESD5V0L2UU 54 PESD5V0V4UW 55 PESD24VL2BT 55 PHN210T 108 PMBT2222 23 PMDPB55XP 81, 90 PMEG2010AEB 36 PMEG3010BER 33 PMEG4010EH 36 PESD3V3CIBSF 60 PESD5V0L4UF 55 PESD5V0X1BCAL 49 PESD24VS1UA 57 PHP9NQ20T 109 PMBT2222A 23 PMDPB56XNEA 81, 84, 90, 116 PMEG2010AEH 36 PMEG3010BEV 36 PMEG4010EJ 36 PESD3V3L1BA 53 PESD5V0L4UG 55 PESD5V0X1BCL 49 PESD24VS1UB 57 PHP18NQ10T 107 PMBT2222AYS 23 PMDPB58UPE 81, 90 PMEG2010AEJ 36 PMEG3010CEH 36 PMEG4010EP 33 PESD3V3L1UB 53 PESD5V0L4UW 55 PESD5V0X1BCSF 49 PESD24VS1UL 57 PHP18NQ11T 108 PMBT2369 23 PMDPB70XP 81, 90 PMEG2010AET 36 PMEG3010CEJ 36 PMEG4010EPK 35 PESD3V3L1UL 53 PESD5V0L5UF 56 PESD5V0X1BL 49 PESD24VS1ULD 57 PHP20N06T 105 PMBT2907 23 PMDPB70XPE 81, 90 PMEG2010BEA 36 PMEG3010EB 36 PMEG4010ER 33 PESD3V3L2BT 55 PESD5V0L5UK 56 PESD5V0X1BQ 50 PESD24VS2UAT 58 PHP20NQ20T 109 PMBT2907A 23 PMDPB80XP 81, 90 PMEG2010BELD 35 PMEG3010EH 36 PMEG4010ESB 34 PESD3V3L2UM 54 PESD5V0L5UV 56 PESD5V0X1BT 50 PESD24VS2UQ 58 PHP23NQ11T 108 PMBT2907AYS 23 PMDPB85UPE 81, 90 PMEG2010BER 33 PMEG3010EJ 36 PMEG4010ET 36 PESD3V3L4UF 55 PESD5V0L5UY 56 PESD5V0X1UAB 49 PESD24VS2UT 58 PHP27NQ11T 108 PMBT3904 23 PMDPB95XNE2 81, 90 PMEG2010BEV 36 PMEG3010EP 33 PMEG4010ETP 33 PESD3V3L4UG 55 PESD5V0R1BSF PESD5V0X1UALD 49 PESD24VS4UD 58 PHP28NQ15T 108 PMBT3904M 23 PMDT290UCE 90 PMEG2010EA 36 PMEG3010ER 33 PMEG4010ETR 33 PESD3V3L4UW 55 PESD5V0S1BA 57 PESD5V0X1UB 49 PESD24VS5UD 58 PHP29N08T 106 PMBT3904MB 23 PMDT290UNE 84, 90, 116 PMEG2010EH 36 PMEG3010ESF 34 PMEG4015EPK 35 PESD3V3L5UF 56 PESD5V0S1BB 57 PESD5V0X1ULD 49 PESD24VU1UT 62 PHP30NQ15T 108 PMBT3904VS 23 PMDT670UPE 84, 90, 116 PMEG2010EJ 36 PMEG3010ET 36 PMEG4020EP 33 PESD3V3L5UK 56 PESD5V0S1BL 57 PESD5V0X2UAM 50 PESD36VS1UL 57 PHP33NQ20T 109 PMBT3904YS 23 PMDXB550UNE 79, 90 PMEG2010EPA 35 PMEG3015EH 36 PMEG4020EPA 35 PESD3V3L5UV 56 PESD5V0S1BLD 57 PESD5V0X2UAMB 50 PESD36VS2UT 58 PHP36N03LT 103 PMBT3906 23 PMDXB600UNE 79, 90 PMEG2010EPAS 35 PMEG3015EJ 36 PMEG4020EPAS 35 PESD3V3L5UY 56 PESD5V0S1BSF 57 PESD5V0X2UM 50 PH955L 105 PHP45NQ10T 107 PMBT3906M 23 PMDXB950UPE 79, 90 PMEG2010EPK 35 PMEG3015EV 36 PMEG4020EPK 35 PESD3V3S1UB 57 PESD5V0S1UA 57, 69 PESD5V0X2UMB 50 PH2520U 101 PHP45NQ11T 108 PMBT3906MB 23 PMDXB1200UPE 79, 90 PMEG2010ER 33 PMEG3020BEP 33 PMEG4020ER 33 PESD3V3S1UL 57 PESD5V0S1UB 57 PESD5V2S2UT 58 PH2925U 101 PHP79NQ08LT 106 PMBT3906VS 23 PMEG45A10EPD 33 PMEG2010ET 36 PMEG3020BER 33 PMEG4020ETP 33 PESD3V3S2UAT 58 PESD5V0S1UJ 57, 69 PESD5Z2.5 57 PH3120L 101 PHP191NQ06LT 105 PMBT3906YS 23 PMEG45T15EPD 33 PMEG2010EV 36 PMEG3020CEP 33 PMEG4020ETR 33 PESD3V3S2UQ 58 PESD5V0S1UL 57 PESD5Z3.3 57 PH4840S 104 PHP225 108 PMBT3946VPN 23 PMEG045T150EPD 33 PMEG2015EA 36 PMEG3020CPA 37 PMEG4030EP 33 PESD3V3S2UT 58 PESD5V0S1ULD 57 PESD5Z5.0 57 PH20100S 107 PHPT60406NY 10 PMBT3946YPN 23 PMEG45U10EPD 33 PMEG2015EH 36 PMEG3020CPAS 37 PMEG4030ER 33 PESD3V3S4UD 58 PESD5V0S1USF 57 PESD5Z6.0 57 PHB18NQ10T 107 PHPT60406PY 10 PMBT4401 23 PMEG045V050EPD 33 PMEG2015EJ 36 PMEG3020DEP 33 PMEG4030ETP 33 PESD3V3S4UF 58 PESD5V0S2BQA 58, 69 PESD5Z7.0 57 PHB20N06T 105 PHPT60410NY 10 PMBT4401YS 23 PMEG045V100EPD 33 PMEG2015EPK 35 PMEG3020EH 36 PMEG4050EP 33 PESD3V3S5UD 58 PESD5V0S2BT 55 PESD5Z12 57 PHB20NQ20T 109 PHPT60410PY 10 PMBT4403 23 PMEG045V150EPD 33 PMEG2015EV 36 PMEG3020EJ 36 PMEG4050ETP 33 49, 60 171 Index Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Page Number PMEG6002EB 36 PMN28UNEA 84, 86, 116 PMPB33XN 81 PMV50EPEA 84, 88, 116 PQMD2 21 PSMN2R1-40PL 100, 104 PSMN4R3-30PL 103 PSMN7R6-100BSE 98, 107 PSMN017-30BL 102 PTVS5V0P1UTP 72 PMEG6002EJ 36 PMN30UN 86 PMPB33XP 81 PMV50UPE 88 PQMD3 21 PSMN2R2-25YLC 101 PSMN4R3-80ES 106 PSMN7R8-100PSE 98, 107 PSMN017-30EL 103 PTVS5V0S1UR 71 PMEG6002ELD 35 PMN30UNE 86 PMPB43XPE 81 PMV50XP 88 PQMD10 21 PSMN2R2-30YLC 102 PSMN4R3-80PS 106 PSMN7R8-120ES 108 PSMN017-30PL 103 PTVS5V0S1UTR 71 PMEG6002TV 37 PMN30XP 88 PMPB47XP 81 PMV55ENEA 84, 86, 116 PQMD12 21 PSMN2R2-40BS 104 PSMN4R3-100ES 107 PSMN7R8-120PS 108 PSMN017-60YS 105 PTVS5V0Z1USK 69 PMEG6010AED 36 PMN30XPEA 84, 88, 116 PMPB48EP 81 PMV65ENEA 84, 86, 116 PQMD13 21 PSMN2R2-40PS 100, 104 PSMN4R3-100PS 107 PSMN008-75B 106 PSMN017-80BS 106 PTVS5V0Z1USKN 69 PMEG6010AESB 34 PMN34UP 88 PMPB55ENEA 81, 84, 116 PMV65UNE 86 PQMD16 21 PSMN2R4-30MLD 95, 102 PSMN4R4-30MLC 102 PSMN8R0-40BS 104 PSMN017-80PS 106 PTVS6V0P1UP 72 PMEG6010CEH 36 PMN40ENE 86 PMPB85ENEA 81, 84, 116 PMV65XP 88 PQMH2 21 PSMN2R4-30YLD 95, 102 PSMN4R4-80BS 106 PSMN8R0-40PS 104 PSMN018-80YS 106 PTVS6V0P1UTP 72 PMEG6010CEJ 36 PMN40UPE 88 PMPB95ENEA 81, 84, 116 PMV65XPE 88 PQMH9 21 PSMN2R5-30YL 100, 102 PSMN4R4-80PS 106 PSMN8R0-80YL 106 PSMN019-100YL 107 PTVS6V0S1UR 71 PMEG6010CPA 37 PMN40UPEA PMPB215ENEA 81, 84, 116 PMV65XPEA 84, 116 PQMH10 21 PSMN2R5-60PL 100, 105 PSMN4R5-30YLC 102 PSMN8R2-80YS 106 PSMN020-30MLC 102 PTVS6V0S1UTR 71 PMEG6010CPAS 37 PMN42XPE 100, 102 PSMN4R5-40BS 104 PSMN8R3-40YS 104 PSMN020-100YS 107 PTVS6V5P1UP 72 PMEG6010ELR 33 PMN42XPEA PMEG6010EP 33 PMN48XP PMEG6010ER 33 PMN48XPA PMEG6010ESB 34 PMN50EPEA PMEG6010ETR 33 PMN50UPE PMEG6020AELP 33 PMN52XP 84, 116 88 PMSS3904 23 PMV75UP 88 PQMH11 21 PSMN2R6-30YLC 84, 116 PMSS3906 23 PMV90ENE 86 PQMH13 21 PSMN2R6-40YS 104 PSMN4R5-40PS 104 PSMN8R5-60YS 105 PSMN021-100YL 107 PTVS6V5P1UTP 72 88 PMST2222 23 PMV100ENEA 84, 116 PRTR5V0U2AX 50, 59 PSMN2R6-60PS 100, 105 PSMN4R6-60BS 105 PSMN8R5-100ES 107 PSMN022-30BL 102 PTVS6V5S1UR 71 PMST2222A 23 PMV100EPEA 84, 88, 116 PRTR5V0U2F 50, 59 PSMN2R7-30BL 102 PSMN4R6-60PS 105 PSMN8R5-100PS 107 PSMN022-30PL 103 PTVS6V5S1UTR 71 PMST2369 23 PMV100XPEA 84, 88, 116 PRTR5V0U2X 50, 59 PSMN2R7-30PL 103 PSMN4R8-100BSE 98, 107 PSMN8R7-80BS 106 PSMN025-80YL 106 PTVS7V0P1UP 72 88 PMST2907A 23 PMV120ENEA 84, 86, 116 PRTR5V0U4D 51, 59, 68 PSMN2R8-25MLC 101 PSMN4R8-100PSE 98, 107 PSMN8R7-80PS 106 PSMN025-100D 107 PTVS7V0P1UTP 72 88 PMST3904 23 PMV130ENEA 84, 86, 116 PSMN0R9-25YLC 101 PSMN2R8-40BS 104 PSMN005-30K 103 PSMN009-100B 107 PSMN026-80YS 106 PTVS7V0S1UR 71 PSMN2R8-40PS 104 PSMN005-75B 106 PSMN009-100P 107 PSMN027-100BS 107 PTVS7V0S1UTR 71 PSMN2R8-80BS 106 PSMN005-75P 106 PSMN9R0-25MLC 101 PSMN027-100PS 107 PTVS7V5P1UP 72 84, 116 84, 88, 116 PMEG6020AELR 33 PMN55ENEA 84, 86, 116 PMST3906 23 PMV160UP 88 PSMN0R9-30YLD 95, 100, 102 PMEG6020ELR 33 PMN70EPE 88 PMST4401 23 PMV230ENEA 84, 86, 116 PSMN1R0-30YLC 102 PMEG6020EP 33 PMN70XP 88 PMST4403 23 PMV240EPEA 84, 88, 116 PSMN1R0-30YLD 95, 100, 102 PSMN2R9-25YLC 101 PSMN5R0-30YL 102 PSMN9R1-30YL 102 PSMN028-100YS 107 PTVS7V5P1UTP 72 PMEG6020EPA 35 PMN70XPE 88 PMST5088 22 PMV250EPEA 84, 88, 116 PSMN1R0-40YLD 95, 104 PSMN2R9-30MLC 102 PSMN5R0-80BS 106 PSMN9R5-30YLC 102 PSMN030-60YS 105 PTVS7V5S1UR 71 PMEG6020EPAS 35 PMN70XPEA 84, 116 PMST5089 22 PMV450ENEA 84, 86, 116 PSMN1R1-25YLC 101 PSMN3R0-30MLC 102 PSMN5R0-80PS 106 PSMN9R5-100BS 107 PSMN030-150B 108 PTVS7V5S1UTR 71 PMEG6020ER 33 PMN80XP 88 PMST5550 24 PMXB40UNE 79 PSMN1R1-30EL 103 PSMN3R0-30YL 102 PSMN5R0-100ES 107 PSMN9R5-100PS 107 PSMN030-150P 108 PTVS7V5U1UPA 70 PMEG6020ETP 33 PMN100EPEA 84, 88, 116 PMST5551 24 PMXB43UNE 79 PSMN1R1-30PL 103 PSMN3R0-30YLD 95, 102 PSMN5R0-100PS 107 PSMN9R8-30MLC 102 PSMN034-100BS 107 PTVS7V5Z1USK 69 PMEG6020ETR 33 PMN120ENEA 84, 86, 116 PMST6428 22 PMXB56EN 79 PSMN1R1-40BS 104 PSMN3R0-60BS 105 PSMN5R2-60YL 105 PSMN010-80YL 106 PSMN034-100PS 107 PTVS7V5Z1USKN 69 PMEG6030ELP 33 PMN230ENEA 84, 86, 116 PMST6429 22 PMXB65ENE 79 PSMN1R2-25YL 101 PSMN3R0-60ES 105 PSMN5R5-60YS 105 PSMN011-30YLC 102 PSMN035-150B 108 PTVS8V0P1UP 72 PMEG6030EP 33 PMN240EPEA 84, 88, 116 PMSTA05 22 PMXB65UPE 79 PSMN1R2-25YLC 101 PSMN3R0-60PS 105 PSMN5R6-60YL 105 PSMN011-60ML 105 PSMN035-150P 108 PTVS8V0P1UTP 72 PMEG6030ETP 33 PMP4201G 27 PMSTA06 22 PMXB75UPE 79 PSMN1R2-30YLC 102 PSMN3R2-30YLC 102 PSMN5R6-100BS 107 PSMN011-60MS 105 PSMN038-100K 107 PTVS8V0S1UR 71 PMEG6030EVP 33 PMP4201V 27 PMSTA42 24 PMXB120EPE 79 PSMN1R2-30YLD 95, 102 PSMN3R3-40YS 104 PSMN5R6-100PS 107 PSMN011-80YS 106 PSMN038-100YL 107 PTVS8V0S1UTR 71 PMEG6045ETP 33 PMP4201Y 27 PMSTA55 22 PMXB350UPE 79 PSMN1R3-30YL 102 PSMN3R3-60PL 100, 105 PSMN5R8-40YS 104 PSMN012-60YS 105 PSMN039-100YS 107 PTVS8V5P1UP 72 PMEG10010ELR 33 PMP4501G 27 PMSTA56 22 PMXB360ENEA PTVS8V5P1UTP 72 PMEG10020AELP 33 PMP4501V 27 PMSTA92 24 PMEG10020AELR 33 PMP4501Y 27 PMT200EPEA PMEG10020ELR 33 PMP5201G 27 PMEG10030ELP 33 PMP5201V 27 PMF63UNE 86 PMP5201Y 27 PMF170XP 88 PMP5501G PMF250XNE 86 PMFPB8032XP PMFPB8040XP 79, 84, 116 PSMN1R4-30YLD 95, 102 PSMN3R3-80BS 106 PSMN006-20K 101 PSMN012-80BS 106 PSMN040-100MSE PMZ130UNE 78, 86 PSMN1R4-40YLD 95, 104 PSMN3R3-80ES 106 PSMN6R0-25YLB 101 PSMN012-80PS 106 PSMN041-80YL 106 PTVS8V5S1UR 71 84, 88, 116 PMZ200UNE 78, 86 PSMN1R5-25YL 101 PSMN3R3-80PS 106 PSMN6R0-30YL 102 PSMN012-100YL 107 PSMN045-80YS 106 PTVS8V5S1UTR 71 PMT280ENEA 84, 86, 116 PMZ290UNE2 78, 86 PSMN1R5-30BLE 98, 102 PSMN3R4-30BL PMT560ENEA 84, 86, 116 PMZ320UPE 78, 88 PSMN1R5-30YL 102 PSMN3R4-30BLE PMV16XN 86 PMZ350UPE 78, 88 PSMN1R5-30YLC 102 27 PMV20EN 86 PMZ390UNE 78, 86 PSMN1R5-40ES PMP5501V 27 PMV20XNE 86 PMZ550UNE 78, 86 81, 88 PMP5501Y 27 PMV20XNEA 84, 86, 116 PMZ600UNE 81, 88 PMPB10XNE 80, 81 PMV25ENEA 84, 86, 116 PMZ950UPE 102 PSMN6R0-30YLB 102 PSMN012-100YS 107 PSMN050-80BS 106 PTVS9V0P1UP 72 98, 102 PSMN6R0-30YLD 95, 102 PSMN013-30MLC 102 PSMN057-200B 109 PTVS9V0P1UTP 72 PSMN3R4-30PL 103 PSMN6R1-30YLD 95, 102 PSMN013-30YLC 102 PSMN057-200P 109 PTVS9V0S1UR 71 104 PSMN3R5-30YL 102 PSMN6R3-120ES 108 PSMN013-60YL 105 PSMN059-150Y 108 PTVS9V0S1UTR 71 PSMN1R5-40PS 100, 104 PSMN3R5-80ES 106 PSMN6R3-120PS 108 PSMN013-80YS 106 PSMN063-150D 108 PTVS10VP1UP 72 78, 86 PSMN1R6-30BL 102 PSMN3R5-80PS 106 PSMN6R5-25YLC 101 PSMN013-100BS 107 PSMN069-100YS 107 PTVS10VP1UTP 72 78, 88 PSMN1R6-30PL 103 PSMN3R8-100BS 107 PSMN6R5-80BS 106 PSMN013-100ES 107 PSMN070-200B 109 PTVS10VS1UR 71 PMZ1200UNE 78 PSMN1R6-40YLC 104 PSMN3R9-25MLC 101 PSMN6R5-80PS 106 PSMN013-100PS 107 PSMN070-200P 109 PTVS10VS1UTR 71 PMV27UPEA 84, 116 PMZ1200UPE 88 PSMN1R7-30YL 102 PSMN3R9-60PS PSMN7R0-30MLC 102 PSMN013-100YSE 98, 107 PTVS10VU1UPA 70 81 PMV28UNEA 84, 86, 116 PMZB150UNE 78, 86 PSMN1R7-60BS 105 PSMN004-60B 105 PSMN7R0-30YL 102 PSMN014-40YS 104 PSMN085-150K 108 PTVS10VZ1USK 69 PMV30UN2 86 PMZB200UNE 78, 86 PSMN1R8-30BL 102 PSMN4R0-25YLC 101 PSMN7R0-30YLC 102 PSMN014-80YL 106 PSMN102-200Y 109 PTVS10VZ1USKN 69 102 88 PMPB11EN 81 PMV27UPE PMGD175XNE 90 PMPB12UNE 81 84, 116 PMPB13XNE PMK30EP 108 PMPB15XN 81 PMK35EP 108 PMPB15XP 80, 81 PMK50XP 108 PMPB19XP 81 PMMT491A 14 PMPB20EN PMMT591A 15 PMPB20XNEA PMN16XNE 86 84, 86, 116 PMN25ENEA PMV30XPEA PMZB290UNE2 78, 86 PSMN1R8-30PL 103 PSMN4R0-30YL PMV32UP 84, 88, 116 88 PMZB320UPE 78, 88 PSMN1R8-40YLC 104 PSMN4R0-30YLD 80, 81 PMV33UPE 88 PMZB350UPE 78, 88 PSMN1R9-40PL 100, 104 81, 84, 116 PMV37EN2 86 PMZB390UNE 78, 86 PSMN2R0-30BL PMPB20XPE 81 PMV40UN2 86 PMZB550UNE 78, 86 105 PSMN015-60BS 105 PSMN130-200D 109 PTVS11VP1UP 72 107 PSMN015-60PS 105 PSMN165-200K 109 PTVS11VP1UTP 72 PSMN4R0-40YS 104 PSMN7R0-100ES 107 PSMN015-100B 107 PSMNR90-30BL 102 PTVS11VS1UR 71 102 PSMN4R0-60YS 105 PSMN7R0-100PS 107 PSMN015-100P 107 PSSI2021SAY 25 PTVS11VS1UTR 71 PSMN2R0-30PL 103 PSMN4R1-30YLC 102 PSMN7R5-30MLD 95, 102 PSMN015-100YL 107 PTVS3V3P1UP 72 PTVS12VP1UP 72 105 PSMN7R5-30YLD 95, 102 81 PMV45EN2 86 PMZB600UNE 78, 86 PSMN2R0-30YL 100, 102 PSMN4R1-60YL PMPB27EP 81 PMV48XP 88 PMZB950UPE 78, 88 PSMN2R0-30YLE 98, 100, 102 PSMN4R2-30MLD PMN27XPE 88 PMPB29XNE 81 PMV48XPA PMZB1200UPE 78, 88 PSMN2R0-60ES 105 84, 116 PMPB29XPE 81 PMV50ENEA 43 PSMN2R0-60PS 105 PNS40010ER PSMN075-100MSE PSMN7R0-100BS PMPB23XNE 84, 86, 116 98, 107 PSMN7R0-60YS 88 84, 116 100, 105 95, 102 PMN27UP PMN27XPEA 98, 107 88 PMG85XP PMGD290UCEA 172 Index PSMN015-110P 108 PTVS3V3P1UTP 72 PTVS12VP1UTP 72 95, 102 PSMN7R5-60YL 105 PSMN016-100BS 107 PTVS3V3S1UR 71 PTVS12VS1UR 71 PSMN4R2-60PL 100, 105 PSMN7R6-60BS 105 PSMN016-100PS 107 PTVS3V3S1UTR 71 PTVS12VS1UTR 71 PSMN4R3-30BL 102 PSMN7R6-60PS 100, 105 PSMN016-100YS 107 PTVS5V0P1UP 72 PTVS12VU1UPA 70 173 Index Type Number 174 Page Number Type Number Page Number Type Number Page Number Type Number Page Number Type Number Support tools Page Number PTVS12VZ1USK 69 PTVS26VZ1USKN 69 PTVS64VS1UTR 71 PUMH30 21 PZU14y 41 PTVS12VZ1USKN 69 PTVS28VP1UP 72 PUMB1 21 PUMT1 23 PZU15y 41 PTVS13VP1UP 72 PTVS28VP1UTP 72 PUMB2 21 PUMX1 23 PZU16y 41 PTVS13VP1UTP 72 PTVS28VS1UR 71 PUMB3 21 PUMX2 23 PZU18y 41 PTVS13VS1UR 71 PTVS28VS1UTR 71 PUMB4 21 PUMZ1 23 PZU20y 41 PTVS13VS1UTR 71 PTVS30VP1UP 72 PUMB9 21 PUMZ2 23 PZU22y 41 PTVS14VP1UP 72 PTVS30VP1UTP 72 PUMB10 21 PUSB2X4D 51, 59, 64 PZU24y 41 PTVS14VP1UTP 72 PTVS30VS1UR 71 PUMB11 21 PUSB2X4Y 51, 59, 64 PZU27y 41 PTVS14VS1UR 71 PTVS30VS1UTR 71 PUMB13 21 PUSB3AB4 52, 60 PZU30y 41 PTVS14VS1UTR 71 PTVS33VP1UP 72 PUMB14 21 PUSB3AB6 52, 60, 67 PZU33y 41 PTVS15VP1UP 72 PTVS33VP1UTP 72 PUMB15 21 PUSB3F96 52, 60 PZU36y 41 PTVS15VP1UTP 72 PTVS33VS1UR 71 PUMB16 21 PUSB3FR4 52, 60 PZUxBA series 40 PTVS15VS1UR 71 PTVS33VS1UTR 71 PUMB17 21 PUSB3FR6 52, 60, 67 PZUxBL series 40 PTVS15VS1UTR 71 PTVS36VP1UP 72 PUMB18 21 PUSB3TB6 52, 60, 67 PZUxB series 40 PTVS15VU1UPA 70 PTVS36VP1UTP 72 PUMB19 21 PUSBM5V5X4-TL 59 RB520CS30L 38 PTVS15VZ1USK 69 PTVS36VS1UR 71 PUMB20 21 PUSBM12VX4-TL 59 RB520S30 38 PTVS15VZ1USKN 69 PTVS36VS1UTR 71 PUMB24 21 PUSBM30VX4-TL 59 RB521CS30L 38 PTVS16VP1UP 72 PTVS40VP1UP 72 PUMB30 21 PXT2222A 23 RB521S30 38 PTVS16VP1UTP 72 PTVS40VP1UTP 72 PUMD2 21 PXT2907A 23 RB751CS40 38 PTVS16VS1UR 71 PTVS40VS1UR 71 PUMD3 21 PXT4401 23 RB751S40 38 PTVS16VS1UTR 71 PTVS40VS1UTR 71 PUMD4 21 PXT4403 23 RB751V40 38 PTVS17VP1UP 72 PTVS43VP1UP 72 PUMD6 21 PXTA14 26 TDZxJ series 40 PTVS17VP1UTP 72 PTVS43VP1UTP 72 PUMD9 21 PXTA42 24 The pdf file of this selection guide can be downloaded here: PTVS17VS1UR 71 PTVS43VS1UR 71 PUMD10 21 PXTA92 24 http://www.nxp.com/discrete_selection_guide PTVS17VS1UTR 71 PTVS43VS1UTR 71 PUMD12 21 PZT2222A 23 PTVS18VP1UP 72 PTVS45VP1UP 72 PUMD13 21 PZT2907A 23 PTVS18VP1UTP 72 PTVS45VP1UTP 72 PUMD14 21 PZT4401 23 PTVS18VS1UR 71 PTVS45VS1UR 71 PUMD15 21 PZT4403 23 PTVS18VS1UTR 71 PTVS45VS1UTR 71 PUMD16 21 PZTA14 26 PTVS18VU1UPA 70 PTVS48VP1UP 72 PUMD17 21 PZTA42 24 PTVS18VZ1USK 69 PTVS48VP1UTP 72 PUMD18 21 PZTA44 24 PTVS18VZ1USKN 69 PTVS48VS1UR 71 PUMD19 21 PZTA92 24 PTVS20VP1UP 72 PTVS48VS1UTR 71 PUMD20 21 PZU2.4y 41 PTVS20VP1UTP 72 PTVS51VP1UP 72 PUMD24 21 PZU2.7y 41 PTVS20VS1UR 71 PTVS51VP1UTP 72 PUMD30 21 PZU3.0y 41 PTVS20VS1UTR 71 PTVS51VS1UR 71 PUMD48 21 PZU3.3y 41 PTVS20VZ1USK 69 PTVS51VS1UTR 71 PUMH1 21 PZU3.6y 41 PTVS20VZ1USKN 69 PTVS54VP1UP 72 PUMH2 21 PZU3.9y 41 PTVS22VP1UP 72 PTVS54VP1UTP 72 PUMH4 21 PZU4.3y 41 PTVS22VP1UTP 72 PTVS54VS1UR 71 PUMH7 21 PZU4.7y 41 PTVS22VS1UR 71 PTVS54VS1UTR 71 PUMH9 21 PZU5.1y 41 PTVS22VS1UTR 71 PTVS58VP1UP 72 PUMH10 21 PZU5.6y 41 PTVS24VP1UP 72 PTVS58VP1UTP 72 PUMH11 21 PZU6.2y 41 PTVS24VP1UTP 72 PTVS58VS1UR 71 PUMH13 21 PZU6.8y 41 PTVS24VS1UR 71 PTVS58VS1UTR 71 PUMH14 21 PZU7.5y 41 PTVS24VS1UTR 71 PTVS60VP1UP 72 PUMH15 21 PZU8.2y 41 PTVS26VP1UP 72 PTVS60VP1UTP 72 PUMH16 21 PZU9.1y 41 PTVS26VP1UTP 72 PTVS60VS1UR 71 PUMH17 21 PZU10DB2 series 40 PTVS26VS1UR 71 PTVS60VS1UTR 71 PUMH18 21 PZU10y 41 PTVS26VS1UTR 71 PTVS64VP1UP 72 PUMH19 21 PZU11y 41 PTVS26VU1UPA 70 PTVS64VP1UTP 72 PUMH20 21 PZU12y 41 PTVS26VZ1USK 69 PTVS64VS1UR 71 PUMH24 21 PZU13y 41 To help you achieve the best, most efficient design with our products, we offer a wide variety of support tools, available on the NXP Semiconductors website www.nxp.com. Models and test data Sales offices and distributors Dedicated and skilled sales and distribution teams provide support on a regional level Selection Guide – digital version Bipolar transistors, diodes, ESD protection, TVS, Filtering and Signal conditioning, Standard Logic/Picogate, Logic and MOSFETs product offerings www.nxp.com © 2016 NXP Semiconductors N.V. All rights reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Date of release: January 2016 Document order number: 9397 750 17631 Printed in the Netherlands
PZT2907A/ZLX 价格&库存
很抱歉,暂时无法提供与“PZT2907A/ZLX”相匹配的价格&库存,您可以联系我们找货
