TSM9435CS
Taiwan Semiconductor
P-Channel Power MOSFET
-30V, -5.3A, 60mΩ
KEY PERFORMANCE PARAMETERS
FEATURES
Advance Trench Process Technology
High Density Cell Design for Ultra Low On-
resistance
Compliant to RoHS Directive 2011/65/EU and
WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VDS
-30
V
RDS(on) (max)
VGS = -10V
60
VGS = -4.5V
90
Qg
9.52
mΩ
nC
APPLICATION
Load Switch
PA Switch
SOP-8
Notes: MSL 3 (Moisture Sensitivity Level) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
LIMIT
UNIT
Drain-Source Voltage
VDS
-30
V
Gate-Source Voltage
VGS
±20
V
(Note 1)
Continuous Drain Current, VGS @4.5V
Pulsed Drain Current, VGS @4.5V
-5.3
TC = 25°C
ID
TC = 100°C
(Note 2)
-3.2
A
IDM
-20
A
PDTOT
2.5
W
TJ, TSTG
- 55 to +150
°C
SYMBOL
LIMIT
UNIT
Junction to Case Thermal Resistance
RӨJC
30
°C/W
Junction to Ambient Thermal Resistance
RӨJA
50
°C/W
Total Power Dissipation @ TC = 25°C
Operating Junction and Storage Temperature Range
THERMAL PERFORMANCE
PARAMETER
Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined
at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board
design. RӨJA shown below for single device operation on FR-4 PCB in still air.
1
Version: D1602
TSM9435CS
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Static
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
(Note 3)
Drain-Source Breakdown Voltage
VGS = 0V, ID = -250µA
BVDSS
-30
V
Gate Threshold Voltage
VDS = VGS, ID = -250µA
VGS(TH)
-1.0
-1.5
-3.0
V
Gate Body Leakage
VGS = ±20V, VDS = 0V
IGSS
±100
nA
Zero Gate Voltage Drain Current
VDS = -24V, VGS = 0V
IDSS
-1
µA
50
60
75
90
Qg
9.52
Qgs
3.43
Qgd
1.71
Ciss
551.57
Coss
90.96
Crss
60.79
td(on)
10.8
tr
2.33
td(off)
22.53
tf
3.87
VSD
-1.3
VGS = -10V, ID = -5.3A
Drain-Source On-State Resistance
Dynamic
RDS(ON)
VGS = -4.5V, ID = -4.2A
mΩ
(Note 4)
Total Gate Charge
VDS = -15V, ID = -5.3A,
Gate-Source Charge
VGS = -10V
Gate-Drain Charge
Input Capacitance
VDS = -15V, VGS = 0V,
Output Capacitance
f = 1.0MHz
Reverse Transfer Capacitance
Switching
nC
pF
(Note 5)
Turn-On Delay Time
Turn-On Rise Time
VDD = -15V, RGEN = 6Ω,
Turn-Off Delay Time
ID = -1A, VGS = -10V,
Turn-Off Fall Time
Source-Drain Diode
ns
(Note 3)
Forward On Voltage
IS = -1.9A, VGS = 0V
V
Notes:
1.
Current limited by package
2.
Pulse width limited by the maximum junction temperature
3.
Pulse test: PW ≤ 300µs, duty cycle ≤ 2%
4.
For DESIGN AID ONLY, not subject to production testing.
5.
Switching time is essentially independent of operating temperature.
ORDERING INFORMATION
PART NO.
TSM9435CS RLG
PACKAGE
PACKING
SOP-8
2,500pcs / 13” Reel
2
Version: D1602
TSM9435CS
CHARACTERISTICS CURVES
Output Characteristics
Transfer Characteristics
On-Resistance vs. Drain Current
Gate Charge
On-Resistance vs. Junction Temperature
Source-Drain Diode Forward Voltage
3
Version: D1602
TSM9435CS
On-Resistance vs. Gate-Source Voltage
Threshold Voltage
Single Pulse Power
Normalized Thermal Transient Impedance, Junction-to-Ambient
4
Version: D1602
TSM9435CS
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
SOP-8
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
Y = Year Code
M = Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R =Apr
S =May T =Jun U =Jul
V =Aug
W =Sep X =Oct
Y =Nov Z =Dec
L = Lot Code (1~9, A~Z)
5
Version: D1602
TSM9435CS
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: D1602
很抱歉,暂时无法提供与“TSM9435CS RLG”相匹配的价格&库存,您可以联系我们找货
