CSD10060–Silicon Carbide Schottky Diode
VRRM = 600 V
Zero Recovery® Rectifier
IF(AVG) = 10 A
Qc = 28 nC
Features
Package
600-Volt Schottky Rectifier
Zero Reverse Recovery Current
Zero Forward Recovery Voltage
High-Frequency Operation
Temperature-Independent Switching Behavior
Extremely Fast Switching
Positive Temperature Coefficient on VF
TO-263-2
TO-220-2
Benefits
Replace Bipolar with Unipolar Rectifiers
Essentially No Switching Losses
Higher Efficiency
Reduction of Heat Sink Requirements
Parallel Devices Without Thermal Runaway
PIN 1
CASE
PIN 2
Applications
Switch Mode Power Supplies
Power Factor Correction
- Typical PFC Pout : 1000W-2000W
Motor Drives
- Typical Power : 3HP-5HP
Part Number
Package
Marking
CSD10060A
TO-220-2
CSD10060
CSD10060G
TO-263-2
CSD10060
Maximum Ratings
.S
D10060, Rev
Datasheet: CS
Symbol
Parameter
Value
Unit
Test Conditions
VRRM
Repetitive Peak Reverse Voltage
600
V
VRSM
Surge Peak Reverse Voltage
600
V
VDC
DC Blocking Voltage
600
V
IF(AVG)
Average Forward Current
10
16.5
A
TC=150˚C
TC=125˚C
IF(Peak)
Peak Forward Current
23
A
TC=125˚, TREP 1KHz
70% Duty
50% Duty
30% Duty
10
100
1000
VR Reverse Voltage (V)
Case Temperature (°C)
TC Case Temperature
10% Duty
Figure 3. Current Derating
Figure 4. Capacitance vs. Reverse Voltage
1.0E+01
Zth (°C/W)
1.0E+00
1.0E-01
1.0E-02
1.0E-03
1.E-07
1.E-06
1.E-05
1.E-04
1.E-03
Tim e (s)
Figure 5. Transient Thermal Impedance
3
CSD10060 Rev. S
1.E-02
1.E-01
1.E+00
Typical Performance
140
140.000
Power Dissipation (W)
120.000
120
100
100.000
80
80.000
60
60.000
40
40.000
25 50 75 100 125 150 175
25
50
75
100
125
150
175
TC Case Temperature (°C)
Figure 6. Power Derating
4
CSD10060 Rev. S
Package Dimensions
POS
Package TO-220-2
A
B
A
F
J
C
P
B
D
X
S
E
Y
1 2
G
T
Z
U
H
V
L
M
W
N
PIN 1
CASE
PIN 2
Millimeters
Min
Max
Min
Max
.381
.410
9.677
10.414
DA
.235
Inc hes
.100
M in
M ax
.395.223 .410
.255
5.969
M illim eters
.120
2.540
M in
M ax
.337
5.664
10.033 10.414
EB
.235.590 .255
.615
5.969
FC
D
G
E
H
F
J G
.102.143 .112
2.591
.153
.337
.337
8.560
1.105
1.147
.590
.610
14.986
.500
.550
.149
.153
3.785
R1.147
0.197 28.626
1.127
LH
MJ
L
N
M
PN
.530.025 .550
R 0.010
.045
.028
.036
.195
.045
.055
.195.165 .205
13.462 13.970
.036
.635
R 0.254
.055
1.143
.711
.914
.205
4.953
1.143
1.397
.185
4.191
4.953
5.207
QP
.170.048 .180
.054
4.318
1.219
4.572
1.372
SQ
S
T
T
U
U
VV
.048 3° .054
1.371
3°
5°
3°
5°
3°
5°
2.388
2.794
6°
3°
5°
.100.094 .110
1.219
6°
3°
6°
3°
6°
3°
.110
2.54
WW
XX
.014.014 .021
3° 3°
5°
.356
.025
3°
5.5°
.533
.356
5°3°
C
P OS
Q
Inches
Y
z
Y
Z
3°
3°
5°
3°
5°
3°
.395
.410
.385
.130
.150
.130
10.033
.410
3.302
.150
14.986
6.477
6.477
3.048
8.560
15.621
2.845
3.632
3.886
8.560
28.067
29.134
15.494
12.700
13.970
3.886
29.134 R 0.197
10.414
9.779
3.810
3.302
.914
1.397
5.207
4.699
6°
6°
2.794
.635
5.5°
10.414
3.810
NOTE:
1. Dimension L, M, W apply for Solder Dip
Finish
Package Dimensions
POS
Package TO-263-2
Inches
Max
Min
Max
A
.396
.406
10.058
10.312
B
.297
.303
7.544
7.696
C
.057
.063
1.448
1.600
D
.237
.243
6.015
6.167
E*
0.00
.070
0.00
1.778
F
.048
.062
1.219
1.575
G
PIN 1
PIN 2
CASE
Millimeters
Min
.100 TYP
2.540 TYP
H
.335
.345
8.509
8.763
J
.028
.034
.711
.864
K
2˚
4˚
2˚
4˚
L
.170
.180
4.318
4.572
M
.048
.052
1.219
1.321
N
.595
.615
15.113
15.621
P
0.00
0.10
0.00
.254
Q
R0.018
TYP
R0.022
TYP
R0.457
TYP
R0.559
TYP
R
.090
.110
2.286
2.794
S
.013
.017
.330
.432
T
6.5˚
8.5˚
6.5˚
8.5˚
U
.103
.107
2.616
2.718
V
R0.028
TYP
R0.032
TYP
R0.711
TYP
R0.813
TYP
W
5.0˚
5.0˚
Note:
* Tab “E” may not be present
5
CSD10060 Rev. S
Recommended Solder Pad Layout
TO-263-2
TO-220-2
Part Number
Package
Marking
CSD10060A
TO-220-2
CSD10060
CSD10060G
TO-263-2
CSD10060
Diode Model
Diode Model CSD10060
Vf T = VT + If*RT
VT= 0.92 + (Tj * -1.35*10-3)
RT= 0.052 + (Tj * 0.29*10-3)
Note: Tj = Diode Junction Temperature In Degrees Celcius
VT
RT
“The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the
maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive
2002/95/EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (RoHS), as amended through April 21, 2006. This part number was
released previously with Sn/Pb solder plating as a standard industry finish. For more information please contact power_sales@cree.com “
This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body
nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited
to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical
equipment, aircraft navigation or communication or control systems, air traffic control systems, or weapons systems.
Copyright © 2006-2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree,
the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc.
6
CSD10060 Rev. S
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
Fax: +1.919.313.5451
www.cree.com/power
很抱歉,暂时无法提供与“CSD10060A”相匹配的价格&库存,您可以联系我们找货
