SK52B – SK515B
Taiwan Semiconductor
5A, 20V - 150V Schottky Barrier Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Guard ring for overvoltage protection
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
5
A
VRRM
20 - 150
V
IFSM
120
A
TJ MAX
150
°C
Package
DO-214AA (SMB)
Configuration
Single die
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.100g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
Repetitive peak reverse voltage
VRRM
Reverse voltage, total rms value
VR(RMS)
Forward current
Surge peak forward current, 8.3ms
single half sine-wave
superimposed on rated load
Critical rate of rise of off-state voltage
SK SK SK SK SK SK
SK
52B 53B 54B 55B 56B 59B 510B
SK
SK
SK
SK
SK
SK
SK
40
50
60
90
100
14
21
28
35
42
63
70
SK
UNIT
515B
SK
515B
150
V
105
V
IF
5
A
IFSM
120
A
dV/dt
10,000
V/μs
Junction temperature
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: P2102
SK52B – SK515B
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
19
°C/W
Junction-to-ambient thermal resistance
RӨJA
60
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
(2)
(2)
SK52B
SK53B
SK54B
SK55B
SK56B
SK59B
SK510B
SK515B
SK52B
SK53B
SK54B
SK55B
SK56B
SK59B
SK510B
SK515B
SK52B
SK53B
SK54B
SK55B
SK56B
SK59B
SK510B
SK515B
SK52B
SK53B
SK54B
SK55B
SK56B
SK59B
SK510B
SK515B
IF = 5A, TJ = 25°C
TJ = 25°C
SYMBOL
VF
TYP
MAX
UNIT
0.55
V
0.75
V
0.85
V
0.95
V
500
µA
100
µA
mA
10
mA
mA
mA
mA
2
mA
IR
TJ = 100°C
TJ = 125°C
IR
IR
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
2
Version: P2102
SK52B – SK515B
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
SK5xB
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1. "x" defines voltage from 20V(SK52B) to 150V(SK515B)
3
Version: P2102
SK52B – SK515B
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
SK52B-SK54B
5
SK55B-SK56B
4
CAPACITANCE (pF)
3
2
100
SK59B-SK515B
1
f=1.0MHz
Vsig=50mVp-p
10
50
75
100
125
0.1
150
1
100
REVERSE VOLTAGE (V)
LEAD TEMPERATURE (°C)
Fig.3 Typical Reverse Characteristics
Fig.4 Typical Forward Characteristics
100
100
=125oC
TJ
10
1
0.1
TJ=75oC
TJ=25oC
0.01
0.001
SK52B-SK54B
SK55B-SK515B
0.0001
10
40
50
60
70
80
90
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
10
10
10
TJ=125oC
UF1DLW
1
TJ=125°C
1
TJ=25°C
0.1
(A)
AVERAGE FORWARD CURRENT (A)
6
=25oC
TJ
0.01
0.1
0.001
0.3
0.4
0.5
0.6
0.7
Pulse width
SK52B-SK54B
SK55B-SK56B
0.8 SK59B-SK515B
0.9
1
1.1
0.01
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
0.2
0.4
0.6
0.8
1
1.2
1.4
FORWARD VOLTAGE (V)
4
Version: P2102
1.2
SK52B – SK515B
Fig.5 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
140
120
8.3ms single half sine wave
100
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
Fig.6 Typical Transient Thermal Characteristics
TRANSIENT THERMAL IMPEDANCE (°C/W)
100
10
1
0.1
0.01
0.1
1
10
100
T-PULSE DURATION(s)
5
Version: P2102
SK52B – SK515B
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: P2102
SK52B – SK515B
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: P2102
很抱歉,暂时无法提供与“SK515B R5G”相匹配的价格&库存,您可以联系我们找货
