TSF10H60C
Taiwan Semiconductor
10A, 60V Trench Schottky Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low power loss, high efficiency
High forward surge capability
Compliant RoHS
Halogen-free according to IEC 61249-2-21
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
PARAMETER
VALUE
UNIT
IF
2x5
A
VRRM
60
V
IFSM
90
A
TJ MAX
150
°C
Package
ITO-220AB
Configuration
Dual dies
MECHANICAL DATA
Case: ITO-220AB
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Mounting torque: 0.56 N⋅m maximum
Polarity: As marked
Weight: 1.72g (approximately)
ITO-220AB
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TSF10H60C
UNIT
TSF10H60C
Repetitive peak reverse voltage
VRRM
60
V
Reverse voltage, total rms value
VR(RMS)
42
V
10
A
5
A
90
A
310
A
Forward current
Surge peak forward current single half sinewave superimposed on rated load per diode
per device
per diode
t = 8.3ms
IF
IFSM
t = 1.0ms
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
1
Version: F2102
TSF10H60C
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance per diode
RӨJL
4.1
°C/W
Junction-to-ambient thermal resistance per diode
RӨJA
15.6
°C/W
Junction-to-case thermal resistance per diode
RӨJC
4.2
°C/W
Thermal Performance Note: Mounted on Heat sink with 2" x 3" x 0.25" Al-Plate.
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
IF = 2.5A, TJ = 25°C
Forward voltage per diode
IF = 5.0A, TJ = 25°C
(1)
IF = 2.5A, TJ = 125°C
VF
IF = 5.0A, TJ = 125°C
Reverse current @ rated VR per diode
(2)
TJ = 25°C
TJ = 125°C
Junction capacitance per diode
1MHz, VR = 4.0V
IR
CJ
TYP
MAX
UNIT
0.46
V
0.54
0.62
V
0.36
V
0.48
0.58
V
15
µA
15
mA
378
pF
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE
PACKAGE
PACKING
TSF10H60C
ITO-220AB
50 / Tube
2
Version: F2102
TSF10H60C
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
CAPACITANCE (pF)
10
5
100
10
f=1.0MHz
Vsig=50mVp-p
1
25
50
75
100
125
150
1
10
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
100000
TJ=150°C
1000
TJ=125°C
100
10
1
TJ=25°C
0.1
10
40
50
60
70
80
90 100
10
10
UF1DLW
T =150°C
1
J
TJ=125°C
TJ=125°C
10.1
TJ=25°C
0.01
TJ=25°C
TJ=-55°C
Pulse widthPulse
300μs
1% duty cycle width
0.001
0.1
0 0.3 0.10.4 0.2 0.50.3 0.60.4 0.70.5 0.8
0.6 0.9
0.7
10.8
1.1
FORWARD VOLTAGE (V)
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Fig.5 Typical Transient Thermal Impedance
10
TRANSIENT THERMAL IMPEDANCE (°C/W)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
10000
100
REVERSE VOLTAGE (V)
CASE TEMPERATURE (°C)
(A)
AVERAGE FORWARD CURRENT (A)
15
1
0.1
0.01
0.001
0.000001
0.00001
0.0001
0.001
0.01
0.1
1
10
100
PULSE DURATION (s)
3
Version: F2102
1.2
TSF10H60C
PACKAGE OUTLINE DIMENSIONS
ITO-220AB
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: F2102
TSF10H60C
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: F2102
很抱歉,暂时无法提供与“TSF10H60C C0G”相匹配的价格&库存,您可以联系我们找货
