S33310T-19.200-X1-CT 数据手册
RoHS Compliant
Pb - Lead Free
AEC-Q200 Qualified
Ltr
Date
Revisions
Appr
Electrical Specifications:
Frequency Range
Temperature Stability
Aging per Year
Operating Temperature Range
Storage Temperature Range
Supply Voltage
Automotive Temperature
Input Current
Output Voltage
Output Symmetry
Output Level
Output Load
Rise and Fall Time
Phase Jitter (12 KHz to 20 MHz)
Enable-Disable Function
Output Disable Time
Output Enable Time
Start Up Time
2.000 to 9.999 MHz
10.000 to 19.999 Mhz
20.000 to 31.999 Mhz
32.000 to 54.000 Mhz
Logic High (Voh)
Logic Low (Vol)
Standard
Tight
2.000 to 9.999 MHz
1.000 to 54.000
±100
±50
±3
-40 to +125
-55 to +125
1.8 ± 5% 2.5 ± 5% 3.3
5
6
6
8
6
8
15
90% (80% at 1.8)
10% (20% at 1.8)
40 to 60
45 to 55
CMOS
15
7
5
7
5
6
5
6
5
1
Tri-State
150
300
5
10
5 (10 at 1.8 Vdd)
MHz
PPM Max
ºC
± 10%
7
7
12
Vdd
mA Max
Vdd Min
Vdd Max
pF Max
5
5
5
5
ns Max
ps Max RMS
ns Max
ms Max
ms Max
Temperature stability is Inclusive of all conditions:
Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage,
supply voltage change, output load changes, shock, vilbration, and 1st year aging at +25°C.
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: Feb 7, 2017
Clock Oscillator
Automotive Temperature Range
Miniature - Low Profile
3.2 x 2.5 millimeter Surface Mount
General Product Specification
Part Number:
S3 X1 Series
www.aker-usa.com
Mechanical Outline:
Pin1
Pin 3
INH
Output
High or Open
Operating
Low
High Impedance
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: Feb 7, 2017
P/N:
www.aker-usa.com
S3 X1 Series
1.5
2.0
1.75
Carrier Tape Dimensions:
4.0
B-B SECTION
AKER
AKER
AKER
AKER
AKER
AKER
AKER
AKER
A
3.4
Pin #1
A
8.0
3.5
B
B
1.0
4.0
1.4
2.7
A-A SECTION
Solder Reflow Characteristics:
Page:
3/4
Date: Feb 7, 2017
P/N:
www.aker-usa.com
S3 X1 Series
How to build a Part Number:
Series
Package
S
3
Parameter
2.5 x 3.2 mm
Supply Voltage
33
25
18
+3.3 Vdd ± 10%
+2.5 Vdd ± 5%
+1.8 Vdd ± 5%
10
05
±100 PPM
±50 PPM
See Notes
T
40 / 60 %
45 / 55 %
Duty Cycle
Frequency 1.000 to 54.000
X1
Temperature Range
M
Packaging
R
R3
MHz
-40 to +125 ºC
250pcs Reel
1000pcs Reel
3000pcs Reel
Part Number Example:
S33310-30.000-X1-R
S3: 2.5 x 3.2 mm SMD Package
33: +3.3 ± 10% Vdd Supply Voltage
10: ±100 PPM Temperature Stability
30.000 MHz Nominal Frequency
X1: -40 to + 125° C Automotive Temperature Range
R: Tape and Reel Packaging
Notes:
1- Standard Duty Cycle does not need to be included in Part Number
description.
2- Product is shipped in Tape and Reel configuration.
3- Quantities less than 250pcs are shipped in tape
4- Specification subject to change without notice.
Page:
4/4
Date: Feb 7, 2017
P/N:
www.aker-usa.com
S3 X1 Series
S33310T-19.200-X1-CT 价格&库存
很抱歉,暂时无法提供与“S33310T-19.200-X1-CT”相匹配的价格&库存,您可以联系我们找货
