QT2M
kHz Crystal
Fuel The Digital World
Features
Applications
Frequency range : 32.768 kHz
SMD : Plastic package
External dimensions (mm)
L : 8.0 x W : 3.8 x H : 2.55
RoHS compliant
Contains Pb, exempted by RoHS directive
Real-time clock (RTC)
Smart meters
Security devices
Consumer products
Electrical Characteristics
Item
Symbol
QT2M
f0
32.768 kHz
∆f/f0
±5ppm, ±10ppm, ±20ppm
CL
6.0pF, 7.0pF, 9.0pF, 12.5pF
Operating Temperature Range
TOTR
-40°C ~ +85°C
Storage Temperature Range
TSTR
-55°C ~ +125°C
TM
25°C ± 5°C
Temperature Coefficient
β
-0.034 ± 0.006ppm/°C2
Motional Resistance (ESR)
R1
50 kΩ Max.
Drive Level
DL
1 μW Max.
∆f/f0
±3 ppm Max.
C0
1.35 pF Typ.
Nominal Frequency
Frequency Tolerance
Load Capacitance
Turnover Temperature
Aging
Shunt Capacitance
Conditions
at 25°C
at 25°C
at 25°C ± 3°C,first year
Dimensions
Internal Connection
Recommended Pad Layout
(Unit: mm)
(Note: Do not connect to external terminals with pin2 & pin3.)
Rev. 1.04
Page 1
www.qstproducts.com
QT2M
kHz Crystal
Ordering Information
QT2M - 32.768K
D Z F - T
Frequency Tolerance (at 25°C)
D
E
H
± 20 ppm
± 10 ppm
± 5 ppm
T
Tape & Reel
Load Capacitance
Frequency Stability (over Temp.)
Z
Packaging Method
Standard for kHz
B
Y
C
F
6 pF
7 pF
9 pF
12.5 pF
Packing
(Unit: mm)
Reflow Profile
Rev. 1.04
Page 2
www.qstproducts.com
很抱歉,暂时无法提供与“QT2M-32.768KDZB-T”相匹配的价格&库存,您可以联系我们找货
