RoHS Compliant
Pb - Lead Free
Ltr
Revisions
Date
Appr
Electrical Specifications:
Frequency Range
Temperature Stability
Aging per Year
Standard
Extended
Operating Temperature Range
Storage Temperature Range
Supply Voltage
Input Current
Output Voltage
Output Symmetry (Duty Cycle)
Output Load
Output Level
Phase Jitter (12 KHz to 20 MHz)
Rise and Fall Time
Standby Function
Start Up Time
4.000 to 10.000 MHz
10.100 to 20.000 MHz
20.100 to 32.000 MHz
32.100 to 50.000 MHz
Logic High (Voh)
Logic Low (Vol)
Standard
4.000 to 50.000
MHz
±100
±50
PPM Max
±25
±3
-10 to +70
-40 to +85
ºC
-55 to +125
+1.8 ± 5% +2.5 ± 5% +3.3 ± 10%
Vdd
3
4
5
4
5
6
mA Max
5
6
7
6
7
8
90%
Vdd Min
10%
Vdd Max
40 to 60
15
pF
CMOS
1
ps Max RMS
6
ns Max
Tri-State
10
ms Max
Temperature stability is Inclusive of all conditions:
Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage,
supply voltage change, output load changes, shock, vilbration, and 1st year aging at +25°C.
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: Oct. 29, 2013
Clock Oscillator
Ultra Miniature
2.0 x 1.6 millimeter Surface Mount
General Product Specification
Part Number:
S1 Series
www.aker-usa.com
Mechanical Outline:
Pin1
INH
High or Open
Low
Pin 3
Output
Operating
High Impedance
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
Page:
2/4
Date: Oct. 29, 2013
P/N:
www.aker-usa.com
S1 Series
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
Date: Oct. 29, 2013
P/N:
www.aker-usa.com
S1 Series
How to build a Part Number:
Series
Package
S
1
Parameter
2.0 x 1.6 mm
Supply Voltage
33
25
18
+3.3 Vdd ± 10%
+2.5 Vdd ± 5%
+1.8 Vdd ± 5%
10
05
025
±100 PPM
±50 PPM
±25 PPM
See Notes
40 to 60%
Duty Cycle
Frequency 4.000 to 50.000
MHz
Temperature Range
See Notes
X
-10 to +70 ºC
-40 to +85 ºC
Packaging
R
Tape and Reel
Part Number Example:
S12505-18.432-X-R
S1: 2.0 x 1.6 mm SMD Package
25: +2.5 Vdd Supply Voltage
05: ±50 PPM Temperature Stability
18.432 MHz Nominal Frequency
X: -40 to + 85° C Extended Temperature Range
R: Tape and Reel Packaging
Notes:
1- Standard Duty Cycle and Temperature Range do not need to be included in
Part Number description.
2- Product is shipped in Tape and Reel configuration. Each reel contains
1000 pieces.
3- Specification subject to change without notice.
Page:
4/4
Date: Oct. 29, 2013
P/N:
www.aker-usa.com
S1 Series
S11810T-25.000-X1-R 价格&库存
很抱歉,暂时无法提供与“S11810T-25.000-X1-R”相匹配的价格&库存,您可以联系我们找货
