QTK532
kHz CMOS Oscillator
Fuel The Digital World
Features
Applications
Frequency range : 32.768 kHz
SMD seam sealing ceramic package
Supply voltage : 1.8V ~ 3.3V
CMOS output
Tri-state function available
External dimensions (mm)
L : 5.0 x W : 3.2 x H : 1.2
RoHS compliant & Pb free
Real-time clock (RTC)
PC, NB, Tablet, STB
Audio, Video, Gaming
Server, Switch, Router
Security devices
Consumer products
Electrical Characteristics
Item
QTK532
Frequency Range (F0)
32.768 kHz
Conditions
±25ppm
-10°C ~ +70°C
±50ppm, ±25ppm
-40°C ~ +85°C
Frequency Stability (Fstab)
-10°C ~ +70°C
Operating Temperature Range (TOTR)
-40°C ~ +85°C
Supply Voltage (VDD)
Current Consumption (IDD)
1.8V, 2.5V, 3.3V
3 mA Max.
Output Type
CMOS
Output Load (CL)
15 pF
Output Voltage High (VOH)
90% VDD Min.
Output Voltage Low (VOL)
10% VDD Max.
Rise & Fall Time (Tr / Tf)
200 ns Max.
Duty Cycle
45% ~ 55%
Start-up Time
10 ms Max.
Enable Voltage High, Logic "1"
70% VDD Min.
Enable Voltage Low, Logic "0"
30% VDD Max.
Aging (Faging)
±5 ppm Max.
Storage Temperature Range (TSTR)
VDD ± 10%
10% ~ 90% of VDD
Input to Pin1
Note [1]
at 25°C±3°C,first year
-55°C ~ +125°C
Notes:
[1] Output will be enable if Pin1 is Logic "1" or Open; Output will be disable if Pin1 is Logic "0".
Rev. 1.01
Page 1
www.qstproducts.com
QTK532
kHz CMOS Oscillator
Dimensions
(Unit: mm)
Ordering Information
QTK532
32.768K
B E - T
Supply Voltage
Packaging Method
B
C
D
T
3.3 V
2.5 V
1.8 V
Tape & Reel
Frequency Stability
A
E
D
Rev. 1.01
± 25 ppm ( -10°C ~ +70°C )
± 50 ppm ( -40°C ~ +85°C )
± 25 ppm ( -40°C ~ +85°C )
Page 2
www.qstproducts.com
QTK532
kHz CMOS Oscillator
Packing
(Unit: mm)
(Unit: mm)
Reflow Profile
Solder melting point : 220°C ± 10°C, 60 sec. Min.
Peak temperature : 260°C ± 10°C, 10 sec. Min.
(°C)
10 sec
260
220
180
150
120 sec
Rev. 1.01
60 sec
Page 3
Time (sec)
www.qstproducts.com
很抱歉,暂时无法提供与“QTK532-32.768KDA-T”相匹配的价格&库存,您可以联系我们找货
