QTM750P
MHz LVPECL Oscillator
Fuel The Digital World
Features
Applications
Frequency range : 25MHz to 312.5MHz
SMD seam sealing ceramic package
Supply voltage : 2.5V, 3.3V
LVPECL output
Low phase noise and phase jitter
Tri-state function available
External dimensions (mm)
L : 7.0 x W : 5.0 x H : 1.4
RoHS compliant & Pb free
Networking, Telecommunication,
Data communication, Switch,
Server, Storage
Fibre channel, Ethernet, SONET,
SATA, SAS, PCI-Express
Optical module
Microprocessor, DSP, FPGA,
Clock source for ADC and DAC
Test and measurement
Electrical Characteristics
Item
Frequency Range (F0)
Frequency Stability (Fstab) over
Operating Temperature Range (T OTR)
QTM750P
Conditions
25MHz ~ 312.5MHz
±50ppm, ±25ppm
-40°C ~ +85°C, Note [1]
±50ppm
-40°C ~ +105°C, Note [1]
-40°C ~ +85°C
-40°C ~ +105°C
Supply Voltage (VDD)
2.5V, 3.3V
Current Consumption (IDD)
70 mA Max.
Output Type
LVPECL
Output Load
50 Ω (VDD - 2.0V)
Output Voltage High (VOH)
VDD - 1.025 Min.
Output Voltage Low (VOL)
VDD - 1.62 Max.
Rise & Fall Time (Tr / Tf)
0.6 ns Max.
Duty Cycle
45% ~ 55%
Start-up Time
5 ms Max.
Enable Voltage High, Logic "1"
70% VDD Min.
Enable Voltage Low, Logic "0"
30% VDD Max.
F0 = 156.25MHz
100fs ~ 300fs Max.
F0 = 312.5MHz
70fs Typ. / 100fs Max.
Phase Jitter
VDD ± 10%
20% ~ 80% of output swing
Input to OE pin
Note [2]
12kHz ~ 20MHz, RMS
Aging (Faging)
±3 ppm Max.
Storage Temperature Range (T STR)
-55°C ~ +125°C
Rev. 1.01
Page 1
at 25°C±3°C, first year
www.qstproducts.com
QTM750P
Notes:
[1] Inclusive of frequency tolerance at 25°C, variations over temperature, supply voltage and vibration.
[2] Output will be enabled if OE is Logic "1" or Open; Output will be disabled if OE is Logic "0".
[3] The standard testing environment except temperature test is 25°C±5°C, 40%~70% relative humidity.
Dimensions
Pin function
Pin 1
OE
Pin 2
NC
Pin 3
GND
Pin 4
OUT
Pin 5
OUT
VDD
Pin 6
Recommended pad layout
(Unit: mm)
* Pad dimension tolerance is ±0.2mm
* Power supply decoupling capacitor is required.
Ordering Information
QTM750P -
156.25M B
E
T
Packaging Method
Frequency in Hz
T
Please contact us for
available frequencies
Tape & Reel
Frequency Stability
Supply Voltage
B
C
Rev. 1.01
E
D
G
3.3 V
2.5 V
Page 2
± 50 ppm ( -40°C ~ +85°C )
± 25 ppm ( -40°C ~ +85°C )
± 50 ppm ( -40°C ~ +105°C )
www.qstproducts.com
QTM750P
Packing
(Unit: mm)
Reflow Profile
Solder melting point : 220°C ± 10°C, 60 sec. Min., 200 sec. Max.
Peak temperature : 260°C ± 10°C, 10 sec. Min., 30 sec. Max.
(°C)
10 sec
260
220
180
150
120 sec
Rev. 1.01
60 sec
Page 3
Time (sec)
www.qstproducts.com
QTM750P-25.000MBE-T 价格&库存
很抱歉,暂时无法提供与“QTM750P-25.000MBE-T”相匹配的价格&库存,您可以联系我们找货
