MQF576D25-100.000-1.0/-40+85 数据手册
Temperature Compensated Crystal Oscillators
[ TCXO " M " and VCTCXO " VM " ]
TCXO
VCTCXO
Min.
Max.
MQF _ T
MQF _ P
MQF _ D
VMQF _ T
VMQF _ P
VMQF _ D
10
1,500
CMOS
PECL
LVDS
CMOS
PECL
LVDS
MHz
MHz
1.0 pS Phase Jitter ( typical )
Features
The (V)MQF___T , (V)MQF___P and (V)MQF___D Series are members of Mercury’s Q-Family Quick-Turn
Temperature Compensated oscillators that can be delivered within days. With low current consumption
(44 mA for PECL 212.500 MHz at 3.3V) and an integrated phase jitter performance of 1.0 pS RMS,
they have gained its precision frequency control market position by providing engineers with next-day
samples for prototypes and low cost, fast delivery for volume production ( ± 2.5 ppm over -30°C to +85°C ) .
General specifications , at Ta=+25°C
(V)MQF574T , (V)MQF576T
Model
Output Logic
Supply Voltage VDD ( code )
(V)MQF576P
CMOS
PECL
LVDS
+ 2.5 VDD ± 5% ( voltage code " 25 " )
+ 3.3 VDD ± 5% ( voltage code " 33 " )
10 ~ 250 MHz
10 ~ 1,500 MHz
10 ~ 1,500 MHz
Available Frequency Range
15 pF
50 Ω into Vcc - 2V or Thevenin equiralent
100 Ω
90 % VDD
VDD - 1.03 ( min.) , VDD - 0.6 ( max.)
1.4 V Typical , 1.6 V max.
10 % VDD
VDD - 1.85 ( min.) , VDD - 1.6 ( max.)
1.1 V Typical , 0.9 V min.
Load
Output Logic " High " , " 1 "
Output Logic " Low " , " 0 "
( VDD = + 2.5V )
50 MHz : 24 mA
Current Consumption
All values are typical and over the
156 MHz : 36 mA
125 MHz : 28 mA
600 MHz : 40 mA
600 MHz : 28 mA
800 MHz : 46 mA
800 MHz : 30 mA
1,000 MHz : 50 mA
1,000 MHz : 34 mA
50 MHz : 26 mA
156 MHz : 40 mA
156 MHz : 25 mA
125 MHz : 30mA
600 MHz : 45 mA
600 MHz : 30 mA
operating temperatures.
Current Consumption
200 MHz : 34 mA
156 MHz : 22 mA
200 MHz : 30 mA
( VDD = + 3.3V )
Current with Output Disabled
Rise Time / Fall Time
(V)MQF576D
800 MHz : 48 mA
800 MHz : 32 mA
1,000 MHz : 52 mA
1,000 MHz : 36 mA
18 mA ( typical )
18 mA ( typical )
18 mA ( typical )
1.5 nS. ( Typical ) , 3.0 nS. ( max. )
0.2 nS. ( Typical ) , 0.5 nS. ( max. )
0.2 nS. ( Typical ) , 0.4 nS. ( max. )
Tr / Tf : 10% ↔ 90% waveform
Tr / Tf : 20% ↔ 80% waveform
±2.0 ppm. max. at +25°C±2°C. ( at the shipment )
Initial Calibration Tolerance
± 2.5 ppm over -30°C to +85°C ( default for Quick - Turn )
Temperature ( refer to +25°C)
± 1.0 ppm over -40°C to +85°C ( available )
Aging
± 1.0 ppm max . , per year at 25°C
Frequency Stability Codes
Voltage Change
± 0.2 ppm max . , for a ±5% input voltage change.
Load Change
± 0.2 ppm max . , for a ±10% load condition change.
Reflow
± 1.0 ppm max . , 1 reflow and measured 24 hours afterwards.
Duty Cycle
50 % ± 5%
Start-up Time
5 m sec. ( max.)
Aging at Ta = +25°C
± 2 ppm max. first year at 25°C ; ± 10 ppm max. over 10 years
Storage Temperature
-55°C to + 150°C
SSB Phase Noise
[ dBc / Hz ( typical ) ]
Offset
10 Hz
100 Hz
1K Hz
10K Hz
100K Hz
1M Hz
10M Hz
Phase Jitter ( 12KHz ~ 20 MHz )
156.25 MHz
-65
-92
-108
-114
-117
-139
-147
0.9 pS
212.5 MHz
-61
-90
-106
-110
-112
-133
-142
1.2 pS
622.08 MHz
-51
-79
-97
-102
-103
-125
-134
1.1 pS
Control Voltage Function on Pad 1
Output Enable Function on pad 2
Control Voltage Center and Range +1.5V ± 1.0V for both VDD = 2.5V and 3.3V
Frequency Pulling Range
± 8 ppm min.
Linearity
± 1 % typical. ± 10% max.
Transfer Function
Positive Transfer
Input Impedance
770 KΩ typical.
Harmonics
-5.0 dBc max.
70% of VDD (min.) to enable output.
(Open connection prohibit.)
OE Control
30% of VDD (max.) to disable output
Mercury
www.mercury-crystal.com
Output Enable / Disable Time
200 nS. Max. / 50 nS. Max.
■Taiwan : Tel: (886)-2-2406-2779 / sales-tw@mercury-crystal.com
■USA : Tel: (1)-909-466-0427 / sales-us@mercury-crystal.com
■China : Tel: (86)-512-5763-8100 / sales-cn@mercury-crystal.com
89
A2
TCXO
VCTCXO
Min.
Max.
MQF _ T
MQF _ P
MQF _ D
VMQF _ T
VMQF _ P
VMQF _ D
10
1,500
CMOS
PECL
LVDS
CMOS
PECL
LVDS
MHz
MHz
Part Number Format and Example
Example :
1.VMQF574T33 - 120.000 - 2.5 / -40+85
2.VMQF576P33 - 120.000 - 2.5 / -40+85
VMQF
574
Hold Type
Package
" MQF "
: TCXO
T
33
" 574 " 4pad
T : CMOS
( 5.0 * 7.0 mm )
VMQF
576
P
33
Hold Type
Package
T : CMOS
Supply Voltage
" 576 " 6pad
P : PECL
" 33 " for 3.3V
( 5.0 * 7.0 mm )
D : LVDS
" 25 " for 2.5V
: TCXO
" VMQF " : VCTCXO
2.5
-40+85
Operating
" 33 " for 3.3V
" VMQF " : VCTCXO
" MQF "
120.000
Supply Voltage
Center Freq. ( MHz )
Freq. Stability
Temperature
" 25 " for 2.5V
Range
120.000
2.5
-40+85
Operating
Freq. Stability
Temperature
Range
Outline Dimensions ( Unit : mm ) , Suggested pad Layout for SMDs
[ MQF574T ]
[ MQF576T ] , [ MQF576P ] , [ MQF576D ]
Test Circuits and Output Waveforms
CMOS
Mercury
PECL
LVDS
90
A2
Emboss Taping and Reel Specifications
[ VCXO ]
[ ( VC )TCXO ]
Carrier Type Dimensions ( unit : mm )
A
B
C
D
E
F
G
H
I
pcs / reel
G_324 ( 6 )
8.0
3.4
2.7
4.0
1.4
0.3
4.0
Ø 1.50
1.75
3000
G_534
12.0
5.3
3.6
8.0
1.4
0.3
4.0
Ø 1.55
1.75
1000
G_576
16.0
7.3
5.3
8.0
1.9
0.3
4.0
Ø 1.55
1.75
1000
G_42
24.0
12.4
10.3
16.0
5.0
0.3
4.0
Ø 1.55
1.75
500
G_43
24.0
12.4
10.3
16.0
5.0
0.3
4.0
Ø 1.55
1.75
500
G_62
24.0
12.4
10.3
16.0
5.0
0.3
4.0
Ø 1.55
1.75
500
G_63
24.0
12.4
10.3
16.0
5.0
0.3
4.0
Ø 1.55
1.75
500
(V)M_22
8.0
2.8
2.3
4.0
1.1
0.3
4.0
Ø 1.50
1.75
3000
(V)M_32
8.0
3.4
2.7
4.0
1.4
0.3
4.0
Ø 1.50
1.75
3000
(V)MQ_326
12.0
3.6
2.9
4.0
1.7
0.3
4.0
Ø 1.55
1.75
3000
(V)M_53
12.0
5.3
3.6
8.0
1.4
0.3
4.0
Ø 1.55
1.75
1000
(V)M_57
16.0
7.4
5.5
8.0
2.8
0.4
4.0
Ø 1.50
1.75
500
(V)M_42
24.0
12.4
10.3
16.0
5.0
0.3
4.0
Ø 1.55
1.75
500
(V)M_43
24.0
12.4
10.3
16.0
5.0
0.3
4.0
Ø 1.55
1.75
500
(V)M_62
24.0
12.4
10.3
16.0
5.0
0.3
4.0
Ø 1.55
1.75
500
(V)M_63
24.0
12.4
10.3
16.0
5.0
0.3
4.0
Ø 1.55
1.75
500
K
L
P
Q
R
pcs / reel
Reel Dimensions ( unit : mm )
J
G_324 ( 6 )
180.0
9.0
12.0
13.2
2.1
3000
G_534
180.0
13.0
16.0
13.2
2.5
1000
G_576
180.0
17.2
19.3
13.3
2.2
22.0
1000
G_42
330.0
30.0
25.0
13.4
2.5
19.5
500
G_43
330.0
30.0
25.0
13.4
2.5
19.5
500
G_62
330.0
30.0
25.0
13.4
2.5
19.5
500
G_63
330.0
30.0
25.0
13.4
2.5
19.5
500
(V)M_22
180.0
9.0
12.0
13.2
2.1
3000
(V)M_32
180.0
9.0
12.0
13.2
2.1
3000
(V)MQ_326
180.0
9.0
12.0
13.2
2.1
3000
(V)M_53
180.0
13.0
16.0
13.2
2.5
19.5
1000
(V)M_57
180.0
17.2
19.3
13.3
2.2
22.0
500
(V)M_42
330.0
30.0
25.0
13.4
2.5
19.5
500
(V)M_43
330.0
30.0
25.0
13.4
2.5
19.5
500
(V)M_62
330.0
30.0
25.0
13.4
2.5
19.5
500
(V)M_63
330.0
30.0
25.0
13.4
2.5
19.5
500
Mercury
■Taiwan : Tel: (+886)-2-2406-2779 / sales-tw@mercury-crystal.com
■USA : Tel: (+1)-909-466-0427 / sales-us@mercury-crystal.com
■China : Tel: (+86)-512-5763-8100 / sales-cn@mercury-crystal.com
114
A2
MQF576D25-100.000-1.0/-40+85 价格&库存
很抱歉,暂时无法提供与“MQF576D25-100.000-1.0/-40+85”相匹配的价格&库存,您可以联系我们找货
