EBM10MMSD
EBM10MMSD
    SULLINS
    CONN CARDEDGE MALE 20POS 0.156
EBM10MMSD 数据手册
8 7 4 5 6 1 2 3 REVISIONS F 2X REV. ECO. NO DESCRIPTION DATE BY K 3369 UPDATE MIN PIN HOLE SIZE TO .043 FOR ALL TERMINATIONS 1/19/2016 MG L 3577 ADD 02 & 03 POS TO DIM TABLE 12/7/2016 MG M 3652 REMOVE 'A' MATERIAL, ADD 'Q' MATERIAL, UPDATE 'R' MATERIAL OPERATING TEMPERATURE, REMOVE 'Y' & 'S' PLATING 4/6/2017 EP F D .125 3.18 C A E E +.005 +0.13 .370 9.40 - .015 - 0.38 (.025 0.64 ) DEPTH FROM TOP OF INSULATOR TO TOP OF PIN D B FITS EDGECARDS THAT ACCEPT .062 1.57 PCB's A D .540±.010 13.72±0.25 .030 0.76 .200 5.08 ROW SPACING C .250 6.35 A .025 0.64 SECTION A-A .156 3.96 _ _M_ _M_ _D 2X B C MW = .125±.025 3.18±0.64 MS = .190 .025[4.83 0.64] MM = .560 .025[14.22 0.64] C .125 3.18 A .100 2.54 .200 5.08 B .043 1.09 MIN NOTES: RECOMMENDED PCB LAYOUT 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING UNLESS OTHERWISE SPECIFIED: DRAWN 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING DIMENSIONS ARE IN INCHES [MM] 5. PROCESSING TEMP: SEE PART NUMBER CODING TOLERANCES: 6. UL FLAMMABILITY RATING: 94V-0 ANGULAR: 1 7. OPERATING VOLTAGE: 950 VAC 8. CURRENT RATING: 3 AMP DECIMALS .XX= .02 [.5] 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX .XXX= .005 [.13] 10. INSULATION RESISTANCE: 5000 MEGA OHMS .XXXX= .0005 [.013] RoHS COMPLIANT 11. CONNECTOR IDENTIFICATION: PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE CUSTOMER COPY A Pb 8 7 6 5 4 DATE NAME 03/14/08 MNH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. 3 TITLE A MALE, EDGECARD, .156 CC PART NUMBER SIZE C _ _M_ _M(MW,MS,MM)_ CAGE CODE 54453 SCALE: 3:1 2 DWG. NO. C11075 SHEET 1 OF 3 1 REV M FILE NAME: C11075, _ _M_ _M(MW,MS,MM)_ 8 7 4 5 6 1 2 3 F F 2X #4-40 THREADED INSERTS E C E E _ _M_ _M_ _N _ _M_ _M_ _T D D 2X .125 3.18 C C C C 2X .125 3.18 .125 3.18 .125 3.18 B B 2X #4-40 THREADED INSERTS _ _M_ _M_ _Z _ _M_ _M_ _V CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 03/14/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C _ _M_ _M(MW,MS,MM)_ CAGE CODE 54453 SCALE: 2:1 3 A MALE, EDGECARD, .156 CC 2 DWG. NO. C11075 SHEET 2 OF 3 1 REV M FILE NAME: C11075, _ _M_ _M(MW,MS,MM)_ 8 7 4 5 6 1 2 3 F F E E D D C C B B CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 03/14/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C _ _M_ _M(MW,MS,MM)_ CAGE CODE 54453 SCALE: 2:1 3 A MALE, EDGECARD, .156 CC 2 DWG. NO. C11075 SHEET 3 OF 3 1 REV M FILE NAME: C11075, _ _M_ _M(MW,MS,MM)_
EBM10MMSD AI解析
1. 物料型号:文档中提到了多种型号,如M02M, M03M, M04M, 一直到M40M,以及M31M, M32M, M33M等。
2. 器件简介:文档中没有直接提供器件的简介,但根据标题可以推测是关于“MALE, EDGECARD, .156 CC”的连接器。
3. 引脚分配:文档列出了不同型号的引脚数和对应的尺寸,例如M02M有2个引脚,M03M有3个引脚,以此类推。
4. 参数特性:文档提供了详细的尺寸参数,如行间距、引脚间距、绝缘体尺寸等,以及材料和电镀信息。
5. 功能详解:文档中没有直接的功能详解部分,但参数特性部分提供了足够的信息来理解连接器的物理特性和电气特性。
6. 应用信息:文档中没有明确提供应用信息,但根据连接器的规格可以推断其可能用于电子设备中的信号传输或电源连接。
7. 封装信息:文档提供了详细的封装尺寸和形状信息,如引脚长度、行间距、绝缘体尺寸等。
*介绍内容由AI识别生成
EBM10MMSD 价格&库存
很抱歉,暂时无法提供与“EBM10MMSD”相匹配的价格&库存,您可以联系我们找货
