8
7
4
5
6
1
2
3
REVISIONS
F
2X
REV.
ECO. NO
DESCRIPTION
DATE
BY
K
3369
UPDATE MIN PIN HOLE SIZE TO .043 FOR ALL
TERMINATIONS
1/19/2016
MG
L
3577
ADD 02 & 03 POS TO DIM TABLE
12/7/2016
MG
M
3652
REMOVE 'A' MATERIAL, ADD 'Q' MATERIAL, UPDATE 'R'
MATERIAL OPERATING TEMPERATURE, REMOVE 'Y' & 'S'
PLATING
4/6/2017
EP
F
D
.125 3.18
C
A
E
E
+.005
+0.13
.370
9.40
- .015
- 0.38
(.025 0.64 ) DEPTH
FROM TOP OF INSULATOR
TO TOP OF PIN
D
B
FITS EDGECARDS THAT
ACCEPT .062 1.57 PCB's
A
D
.540±.010 13.72±0.25
.030 0.76
.200 5.08
ROW SPACING
C
.250 6.35
A
.025 0.64
SECTION A-A
.156 3.96
_ _M_ _M_ _D
2X
B
C
MW = .125±.025 3.18±0.64
MS = .190 .025[4.83 0.64]
MM = .560 .025[14.22 0.64]
C
.125 3.18
A
.100 2.54
.200 5.08
B
.043 1.09 MIN
NOTES:
RECOMMENDED PCB LAYOUT
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
UNLESS OTHERWISE SPECIFIED: DRAWN
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
DIMENSIONS ARE IN INCHES [MM]
5. PROCESSING TEMP: SEE PART NUMBER CODING
TOLERANCES:
6. UL FLAMMABILITY RATING: 94V-0
ANGULAR: 1
7. OPERATING VOLTAGE: 950 VAC
8. CURRENT RATING: 3 AMP
DECIMALS
.XX= .02 [.5]
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
.XXX= .005 [.13]
10. INSULATION RESISTANCE: 5000 MEGA OHMS
.XXXX= .0005 [.013]
RoHS COMPLIANT
11. CONNECTOR IDENTIFICATION: PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
CUSTOMER COPY
A
Pb
8
7
6
5
4
DATE
NAME
03/14/08 MNH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
3
TITLE
A
MALE, EDGECARD, .156 CC
PART NUMBER
SIZE
C
_ _M_ _M(MW,MS,MM)_
CAGE CODE
54453
SCALE: 3:1
2
DWG. NO.
C11075
SHEET 1 OF 3
1
REV
M
FILE NAME: C11075, _ _M_ _M(MW,MS,MM)_
8
7
4
5
6
1
2
3
F
F
2X #4-40
THREADED
INSERTS
E
C
E
E
_ _M_ _M_ _N
_ _M_ _M_ _T
D
D
2X
.125 3.18
C
C
C
C
2X
.125 3.18
.125 3.18
.125 3.18
B
B
2X #4-40
THREADED
INSERTS
_ _M_ _M_ _Z
_ _M_ _M_ _V
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
03/14/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
_ _M_ _M(MW,MS,MM)_
CAGE CODE
54453
SCALE: 2:1
3
A
2
DWG. NO.
C11075
SHEET 2 OF 3
1
REV
M
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
03/14/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
_ _M_ _M(MW,MS,MM)_
CAGE CODE
54453
SCALE: 2:1
3
A
2
DWG. NO.
C11075
SHEET 3 OF 3
1
REV
M
很抱歉,暂时无法提供与“EBM12MMSD”相匹配的价格&库存,您可以联系我们找货
