8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
M
3749
UPGRADE PBT ON 36 POSITION, UPDATE
NOTCH ON TOP VIEW
1/12/2018
JH
F
F
E
E
D
D
.100 2.54
B
A
.050 1.27
A
C
C
HEAD DIMENSION
.100 2.54
TAIL DIMENSION
.100 2.54 TYP.
B
A
.025 0.64
B
SECTION A-A
A
.100 2.54
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. UL FLAMMABILITY RATING: 94V-0
5. DIELECTRIC WITHSTANDING VOLTAGE: 1800 VAC
6. CURRENT RATING: 3 AMPS
7. CONTACT RESISTANCE: 30 MILLIOHMS MAX.
8. INSULATION RESISTANCE: 5000 MEGOHMS MIN.
8
7
.040 1.02 MIN
CUSTOMER COPY
PCB LAYOUT RECOMMENDED
Pb
RoHS COMPLIANT
6
5
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
9/9/2011 JH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPRIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
.100" CC, HEADER, STRAIGHT
PART NUMBER
SIZE
C
_ _C_ _S_ _N - (M500,M594)
CAGE CODE
54453
SCALE: 4:1
3
A
2
DWG. NO.
C10436
SHEET 1 OF 1
1
REV
M
FILE NAME: C10436, _ _C_ _S(AA,AB,AC,AD,AE,AF,AG,AH,AI,AJ,AK,FA,FB,FC,FD,FE,FF,FG,FH,FI,FJ,ZA,ZB,ZC,ZD,ZI,ZJ,ZO,ZQ,ZR)N-(OMIT,M500,M594)
很抱歉,暂时无法提供与“AMC28SAAN”相匹配的价格&库存,您可以联系我们找货
