FGN.2M.319.XLC
FGN.2M.319.XLC
    LEMO(雷莫)
    CONN PLUG MALE 19POS GOLD CRIMP
FGN.2M.319.XLC 数据手册
M SERIES CONNECTORS RATCHET COUPLING ® ® Introduction This catalogue gives the complete description of LEMO M series connectors. M series connectors are lightweight triplestart ratchet coupling type connectors designed for avionics, aerospace, military, security, motorsport and heavy duty applications. The LEMO manufacturing programme has been extended to almost 40 series divided into 7 product families with specific mating and environmental characteristics. Each series includes a wide variety of plug, socket and coupler models, available in contact configurations adapted to all round cables. Watertight models are also available. Since LEMO connectors are perfectly screened and designed to guarantee very low resistance to shell electrical continuity, they are particularly adapted to applications where electromagnetic compatibility (EMC) is important. Technical Characteristics Materials and Treatments Shell material code Component Outer shell Conical nut Earthing crown Coupling nut Ratchet Hexagonal nut I X l C l l Material (Standard) l Surface treatment (µm) nickel chrome gold I X Brass (UNS C 38500) Aluminium alloy (AA 6262A or AA 6023) – Brass (UNS C 38500) Aluminium alloy (AA 6262A or AA 6023) – 0.3 ­– – – 14 5 – 0.3 – – – 14 5 Notes – 1) 1) l l l l l Bronze (UNS C 54400) or special brass – – – 1.5 l Brass (UNS C 38500) – – 3 – – Aluminium alloy (AA 6262A or AA 6023) – 14 3 – 1) l l l l l Special PEEK – l Brass (UNS C 38500) – – 3 – Aluminium alloy (AA 6262A or AA 6023) – – 5 – l l Male crimp contact l l l Brass (UNS C 34500) – – – 1.0 – Female crimp contact l l l Bronze (UNS C 54400) – – – 1.5 – Clips l l l Cu-Be or special steel Insulator l l l PEEK – l Silicone O-ring without treatment – ® l l FPM/FKM (Viton ) – Sealing resin l l l Epoxy (Araldite® or Stycast®) – Cable rear seal l l l Fluorosilicone – Spring l l l Stainless steel – Notes: standards for surface treatment are as follows: chrome-plated SAE AMS 2460; nickel-plated SAE AMS QQ N 290 or MIL DTL 32119; gold-plated ISO 27874. 1) anthracite colour. Product safety notice & disclaimers Please read and follow all instructions specified on the last page or on our website carefully and consult all relevent national and international safety regulations for your application. Improper handling, cable assembly, or wrong use of connectors can result in hazardous situations. LEMO products and services are provided “as is.” LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. In no event shall LEMO be liable for any direct, indirect, punitive, incidental, special consequential damages, to property or life, whatsoever arising out of or connected with the use or misuse of LEMO’s products. www.lemo.com 1 ® ® Environmental performance Characteristics Operating temperature (mated) Value IEC international MIL-spec tests -55°C/+200°C 1) (HEl model: -20°C/+80°C) -20°C/+200°C 2) (HEl model: -20°C/+80°C) Ingress protection index IP 68 (at 2 m, 15Hr) Fungus Satisfied - by material analysis MIL-STD 810F-508.5 Flammability 60 sec. front and back face EIA-364-104A Fluid contamination 3) Fuels, gasoline, hydraulic oils, solvents, de-icing MIL-STD-810F method 504 Sand and dust 4) 6 hr, 55°C, blowing < 150 µm dust MIL-STD 810F-510.4 10 K amps - 6 times EIA-364-75 -65°C; 40’000 feet and 400 VAC EIA-364-105A Alum. shell (up to 500Hr), Brass shell (1000Hr) IEC 60512-6 test 11f EIA-364-26 Thermal shock 5 cycles: -65°C to +150°C IEC 60512-11-4 EIA-364-32 test condition IV Altitude immersion No moisture on contacts EIA-364-03 Humidity 21 days at 95% EIA-364-31 method IV Lightning strike Altitude-low temp Salt fog 5) 6) IEC 60529 IEC 60068-2 Note: 1) Shell material code C + Silicone O-ring (see page 1). 2) Shell material code I/X + FPM O-ring (see page 1). 3) Connectors immersed at both 70°C and 25°C according to specification. Connectors are then inspected, no visual signs of damage seen. Fuels: Kerosene, JP4, (Nato F40) at 70°C +/- 2°C. Gasoline: ASTM 4814. Hydraulic oils: Mineral oil based MIL-H-5606. Solvents: Isopropanol. De-icing fluids: 25% ethylene glycol. 4) No signs of damage, connectors opened and closed without difficulty. Dust or sand was not inside connector. 5) Wired mated connectors = no voltage breakdown, shell to all contacts (connected together) w/400 VAC after 1 hour at -65° C at 40’000 feet altitude. 6) Corrosion resistance. Inspection: salt deposits shall be removed by gentle wash in running water with light brushing using soft brush. Aluminium Shell (material code: X) max: 48 hours, (material code: I) max: 500 hours. Brass shell (material code: C) over 1000 hours. Electrical performance Characteristics Value IEC international MIL-spec tests Insulation resist. (at ambient temp.) 6) > 1012 Ω, > 1010 Ω (after humidity) IEC 60512-2 test 3a EIA-364-21 Dielectric withstanding volt. (sea level) See table page 25, 26, 27 IEC 60512-2 test 4a EIA-364-20 Contact resistance See table below IEC 60512-2 test 2a EIA-364-06 Current rating See insulator configuration page 25, 26, 27 IEC 60512-3 test 5a Shell to shell conductivity < 1.5m Ω IEC 60512-2-6 Shielding effectiveness, low frequency ≥ 80 dB up to 1GHz EIA-364-66 Shielding effectiveness, high frequency ≥ 70 dB (3GHz), ≥ 58 dB (6GHz), ≥ 40 dB (10GHz) EIA-364-66 7) EIA-364-83 Note: 6) After humidity test: 21 days at 95% RH according to IEC 60068-2. Insulation resistance measured between the contacts and contact/shell. Contact resistance 7) IEC 60512-2 test 2a 0.5 0.7 0.9 1.3 ≤ 8.7 ≤ 6.1 ≤ 4.8 ≤ 3.6 Value øA (mm) mΩ Notes: 7) after 5000 mating cycles and the salt spray test according to IEC 60512-6 test 11 f. 2 www.lemo.com ® ® Mechanical performance Characteristics Value IEC international 3000 cycles Endurance IEC 60512-5 test 9a MIL-spec tests EIA-364-09 Gunfire vibration 25 to 2000 Hz, 3 axis (Apache helicopter) MIL-STD-810F method 519.5 Vibration-Sine 30 g, 3 axis, 12 hr MIL-STD-202 method 204-G Vibration-Random 50-2000 Hz, 37.8 g rms-3 axes; 4h amb IEC 60512-6-4 EIA-364-28 test cond. V letter I Shock 300 g - 3 msec IEC 60512-6-3 EIA-364-27 condition D Acceleration 50 g acceleration Contact retention > 22 N (ø 0.7mm), > 30N (ø 0.9 mm) Torque See table below 8) MIL-STD-1344 - 2011-1, A IEC 60512-8 test 15a Note: 8) Amplitude: 30G. Frequency: 10 to 2000 Hz. Time per axis: 4 hours (X, Y, Z). No signal discontinuity above 1 µs. Series Coupling torque tightning (N.cm) Coupling torque untightning (N.cm) Series Coupling torque tightning (N.cm) Coupling torque untightning (N.cm) MM 8 4 TM 26 30 0M 4 5 4M 26 25 1M 10 11 LM 48 43 2M 20 14 5M 919) 54 3M 34 29 9) Note: 9) Higher contact density = larger torque force. www.lemo.com 3 ® ® M Series The M Series connector offers a new innovative design for avionics, aerospace, military, security, motorsport and heavy duty applications. Made of high-strength aluminium, this connector is one of the lightest and most compact of the LEMO product line. A one-grip ratchet screw system enables quick and secure coupling of the connectors. The arctic grip makes it easy to manipulate the connector while wearing gloves or when the connector is located in a difficult to access area. Features – Ratchet-coupling mechanism – Compact design for space savings – Oil and fuel resistant – 360° screening for full EMC shielding – Colour coding / keying – Scoop proof – Threaded for MIL-DTL-38999L backshell Metal housing models (page 6) – Quick mating: less than 3/4 turn to seat – Lightweight – High vibration and shock resistance – Sealed to IP68 when mated – Reverse gender configuration – Pin configuration from 2 to 114 contacts Straight plugs Free sockets Fixed sockets FA• FG• FM• EG• FA• FG• FM• EG• PM• PV• PB• FA• PM• PV• PB• FG• FM• EC• FW• FX• EC• FW• FX• ED• PE• PF• PH• FW• FX• ED• PE• PF• PH• USB models (page 24) Straight plugs FG• Fibre optic models (page 21) FM• Straight plugs PM• Watertight model (unmated) Fixed sockets EG• PV• PB• EG• Fixed sockets Free sockets FM• EG• PM• FG• ED• PH• PH• Fixed socket HE• 4 www.lemo.com ® ® Part Numbering System Plug 3 0 5 . X L C F M N . 1 M . 3 0 5 . X L C M F G N . 1 M . Free socket 3 0 5 . X L M T P M N . 1 M . Fixed socket 3 0 5 . X L N P H E N . 1 M . Variant: T = Mold stop P = Potted M = MIL-DTL-38999L shell thread Contact: (page 28) Insulator: L = PEEK (multipole page 25) R = PEEK (mixed multipole p. 27) Model: (page 6) Housing: C = Chrome-plated brass X = Nickel-plated aluminium alloy 1) I = NiCorAITM Nickel fluorocarbon polymer aluminium alloy 2) Alignment key: (page 24) Series: (page 6) Insert configuration: (page 25) FMN.1M.305.XLC = straight plug with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, male crimp contacts. FGN.1M.305.XLCM = straight plug with key (N), arctic grip, 1M series, multipole type with 5 contacts, outer shell in anthracite nickelplated aluminium alloy, PEEK insulator, male crimp contacts and with MIL-DTL-38999L thread for additional backshell (not supplied). PMN.1M.305.XLMT = free socket with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female crimp contacts and mold stop. HEN.1M.305.XLNP = fixed socket, nut fixing, with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female print contacts, watertight. Note: 1) anthracite colour / 48 hours salt fog resistance. 2) anthracite colour / 500 hours salt fog resistance RoHS 2/REACH. Part Section Showing Internal Components Fixed socket 1 2 3 4 5 6 outer shell o-ring hexagonal nut insulator female contact earthing crown 5 4 6 3 2 1 1 3 2 7 5 6 Straight plug 4 1 2 3 4 5 6 7 outer shell insulator male contact rear seal tightening screw ratchet mechanism spring www.lemo.com 5 ® ® Metal housing models FMl Straight plug, key (N) or keys (H, P, R, S, T, U, V, W and X) with knurled grip Dimensions (mm) Reference Model Series A Ls/Lr øA øC P øD øB X B C D Ls Lr P X FMl MM 11.1 6.4 10.7 5.6 21.3 21.3 5.5 5.8 FMl 0M 13.1 8.8 12.7 8.0 24.1 24.1 3.9 6.7 FMl 1M 14.6 10.5 14.2 9.7 24.1 24.1 3.9 6.7 FMl 2M 17.6 14.0 17.2 13.0 24.5 24.5 3.9 7.1 FMl 3M 19.6 16.0 19.2 15.0 24.5 24.5 3.9 7.1 FMl TM 22.5 17.9 22.0 16.7 28.6 28.6 3.4 7.6 FMl 4M 25.0 20.7 24.5 19.5 28.6 28.6 3.4 7.6 FMl LM 28.5 23.9 28.0 22.7 28.6 28.6 3.4 7.6 FMl 5M 34.0 29.7 33.5 28.5 28.6 28.6 3.4 7.6 Part number example: FMN.1M.305.XLC Note: Ls = standard gender, Lr = reverse gender FMl Straight plug, key (N) or keys (H, P, R, S, T, U, V, W and X) with knurled grip and mold stop Dimensions (mm) Reference Model Series A B C D F Ls Lr M P X Ls/Lr øC øD øF øB X 1.5 øA P M FMl MM 11.1 6.4 10.7 5.6 7.8 24.3 24.3 8.8 5.5 5.8 FMl 0M 13.1 8.8 12.7 8.0 10.7 27.1 27.1 9.7 3.9 6.7 FMl 1M 14.6 10.5 14.2 9.7 12.4 27.1 27.1 9.7 3.9 6.7 FMl 2M 17.6 14.0 17.2 13.0 15.5 27.5 27.5 10.1 3.9 7.1 FMl 3M 19.6 16.0 19.2 15.0 17.5 27.5 27.5 10.1 3.9 7.1 FMl TM 22.5 17.9 22.0 16.7 19.8 31.6 31.6 10.6 3.4 7.6 FMl 4M 25.0 20.7 24.5 19.5 22.6 31.6 31.6 10.6 3.4 7.6 FMl LM 28.5 23.9 28.0 22.7 25.8 31.6 31.6 10.6 3.4 7.6 FMl 5M 34.0 29.7 33.5 28.5 31.4 31.6 31.6 10.6 3.4 7.6 Part number example: FMN.1M.305.XLCT Note: Ls = standard gender, Lr = reverse gender FMl Straight plug, key (N) or keys (H, P, R, S, T, U, V, W and X), knurled grip and MIL-DTL-38999L shell thread Dimensions (mm) Reference Model Series A C Ls/Lr øA P øC e 9 e Ls Lr P Code1) FMl 1M 14.6 14.2 M12x1.0 26.4 26.4 3.9 A FMl 2M 17.6 17.2 M15x1.0 26.4 26.4 3.9 B FMl 3M 19.6 19.2 M18x1.0 26.4 26.4 3.9 C FMl TM 22.5 22.0 M18x1.0 30.0 30.0 3.4 C FMl 4M 25.0 24.5 M22x1.0 30.0 30.0 3.4 D FMl LM 28.5 28.0 M25x1.0 30.0 30.0 3.4 E FMl 5M 34.0 33.5 M31x1.0 30.0 30.0 3.4 G Part number example: FMN.1M.305.XLCM Note: Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). 6 www.lemo.com ® ® FGl Straight plug, key (N) or keys (H, P, R, S, T, U, V, W and X) with arctic grip Dimensions (mm) Reference Model Series A Ls/Lr øA øC øD øB P X B C D Ls Lr P X FGl MM 12.0 6.4 10.7 5.6 21.3 21.3 5.5 5.8 FGl 0M 14.4 8.8 12.7 8.0 24.1 24.1 3.9 6.7 FGl 1M 15.9 10.5 14.2 9.7 24.1 24.1 3.9 6.7 FGl 2M 18.9 14.0 17.2 13.0 24.5 24.5 3.9 7.1 FGl 3M 20.9 16.0 19.2 15.0 24.5 24.5 3.9 7.1 FGl TM 23.4 17.9 22.0 16.7 28.6 28.6 3.4 7.6 FGl 4M 25.9 20.7 24.5 19.5 28.6 28.6 3.4 7.6 FGl LM 29.4 23.9 28.0 22.7 28.6 28.6 3.4 7.6 FGl 5M 34.9 29.7 33.5 28.5 28.6 28.6 3.4 7.6 Part number example: FGN.1M.305.XLC Note: Ls = standard gender, Lr = reverse gender FGl Straight plug, key (N) or keys (H, P, R, S, T, U, V, W and X) with arctic grip and mold stop Dimensions (mm) Reference Model Series A B C D F Ls Lr M P X Ls/Lr X 1.5 øA øC P øD øF øB M FGl MM 12.0 6.4 10.7 5.6 7.8 24.3 24.3 8.8 5.5 5.8 FGl 0M 14.4 8.8 12.7 8.0 10.7 27.1 27.1 9.7 3.9 6.7 FGl 1M 15.9 10.5 14.2 9.7 12.4 27.1 27.1 9.7 3.9 6.7 FGl 2M 18.9 14.0 17.2 13.0 15.5 27.5 27.5 10.1 3.9 7.1 FGl 3M 20.9 16.0 19.2 15.0 17.5 27.5 27.5 10.1 3.9 7.1 FGl TM 23.4 17.9 22.0 16.7 19.8 31.6 31.6 10.6 3.4 7.6 FGl 4M 25.9 20.7 24.5 19.5 22.6 31.6 31.6 10.6 3.4 7.6 FGl LM 29.4 23.9 28.0 22.7 25.8 31.6 31.6 10.6 3.4 7.6 FGl 5M 34.9 29.7 33.5 28.5 31.4 31.6 31.6 10.6 3.4 7.6 Part number example: FGN.1M.305.XLCT Note: Ls = standard gender, Lr = reverse gender FGl Straight plug, key (N) or keys (H, P, R, S, T, U, V, W and X), arctic grip and MIL-DTL-38999L shell thread Dimensions (mm) Reference Model Series A C Ls/Lr øA P øC e 9 e Ls Lr P Code1) FGl 1M 15.9 14.2 M12x1.0 26.4 26.4 3.9 A FGl 2M 18.9 17.2 M15x1.0 26.4 26.4 3.9 B FGl 3M 20.9 19.2 M18x1.0 26.4 26.4 3.9 C FGl TM 23.4 22.0 M18x1.0 30.0 30.0 3.4 C FGl 4M 25.9 24.5 M22x1.0 30.0 30.0 3.4 D FGl LM 29.4 28.0 M25x1.0 30.0 30.0 3.4 E FGl 5M 34.9 33.5 M31x1.0 30.0 30.0 3.4 G Part number example: FGN.1M.305.XLCM Note: Ls = standard gender, Lr = reverse gender. size code (backshell not supplied). 1) MIL-DTL-38999L shell www.lemo.com 7 ® ® FXl Straight plug with square flange, key (N) or keys (H, P, R, S, T, U, V, W and X) with knurled grip Dimensions (mm) Reference Model Series A A1 B C D E G H K Ls Lr N V FXl MM 21.5 11.1 6.4 10.7 5.6 9.5 17.0 12.0 1.5 26.1 26.1 17.0 2.7 Ls/Lr X 1.5 øC øV H ø A1 P øD øE N øB øA 26.9 13.1 8.8 12.7 8.0 12.2 18.9 15.1 1.5 29.1 29.1 20.6 2.7 FXl 1M 31.4 14.6 10.5 14.2 9.7 13.7 18.9 18.3 1.5 29.1 29.1 23.8 3.3 FXl 2M 34.6 17.6 14.0 17.2 13.0 16.7 18.9 20.6 1.5 29.5 29.5 26.1 3.3 FXl 3M 34.6 19.6 16.0 19.2 15.0 18.7 18.9 20.6 1.5 29.5 29.5 26.1 3.3 FXl TM 38.0 22.5 17.9 22.0 16.7 21.5 22.5 23.0 2.0 34.8 34.8 28.5 3.3 FXl 4M 40.3 25.0 20.7 24.5 19.5 24.0 22.5 24.6 2.0 34.8 34.8 30.1 3.3 FXl LM 43.7 28.5 23.9 28.0 22.7 27.5 22.5 27.0 2.0 34.8 34.8 32.5 3.3 FXl 5M 47.0 34.0 29.7 33.5 28.5 33.0 22.5 29.4 2.0 34.8 34.8 37.0 3.3 Part number example: FXN.1M.305.XLC G K FXl FXl 0M Note: The dimensions «P» and «X» are the same as the FMl models. Ls = standard gender, Lr = reverse gender. Straight plug with square flange, key (N) or keys (H, P, R, S, T, U, V, W and X), knurled grip and mold stop Dimensions (mm) Reference Model Series A A1 B C D E G H K Ls Lr N V FXl MM 21.5 11.1 6.4 10.7 5.6 9.5 17.0 12.0 1.5 29.1 29.1 17.0 2.7 Ls/Lr øC P øD øF øB øE X 1.5 øV H 1.5 M 26.9 13.1 8.8 12.7 8.0 12.2 18.9 15.1 1.5 32.1 32.1 20.6 2.7 FXl 1M 31.4 14.6 10.5 14.2 9.7 13.7 18.9 18.3 1.5 32.1 32.1 23.8 3.3 FXl 2M 34.6 17.6 14.0 17.2 13.0 16.7 18.9 20.6 1.5 32.5 32.5 26.1 3.3 FXl 3M 34.6 19.6 16.0 19.2 15.0 18.7 18.9 20.6 1.5 32.5 32.5 26.1 3.3 FXl TM 38.0 22.5 17.9 22.0 16.7 21.5 22.5 23.0 2.0 37.8 37.8 28.5 3.3 FXl 4M 40.3 25.0 20.7 24.5 19.5 24.0 22.5 24.6 2.0 37.8 37.8 30.1 3.3 FXl LM 43.7 28.5 23.9 28.0 22.7 27.5 22.5 27.0 2.0 37.8 37.8 32.5 3.3 FXl 5M 47.0 34.0 29.7 33.5 28.5 33.0 22.5 29.4 2.0 37.8 37.8 37.0 3.3 Part number example: FXN.1M.305.XLCT G K FXl ø A1 øA N FXl 0M Note: The dimensions «F», «M», «P» and «X» are the same as the FMl models. Ls = standard gender, Lr = reverse gender. Straight plug with square flange, key (N) or keys (H, P, R, S, T, U, V, W and X) with knurled grip and MIL-DTL-38999L shell thread Dimensions (mm) Reference Model Series A A1 C Ls/Lr 1.5 e øC P ø A1 9 øE N øA e E G H K Ls Lr Code1) FXl 1M 31.4 14.6 14.2 M12x1.0 13.7 18.9 18.3 1.5 31.4 31.4 A FXl 2M 34.6 17.6 17.2 M15x1.0 16.7 18.9 20.6 1.5 31.4 31.4 B FXl 3M 34.6 19.6 19.2 M18x1.0 18.7 18.9 20.6 1.5 31.4 31.4 C FXl TM 38.0 22.5 22.0 M18x1.0 21.5 22.5 23.0 2.0 36.2 36.2 C FXl 4M 40.3 25.0 24.5 M22x1.0 24.0 22.5 24.6 2.0 36.2 36.2 D FXl LM 43.7 28.5 28.0 M25x1.0 27.5 22.5 27.0 2.0 36.2 36.2 E FXl 5M 47.0 34.0 33.5 M31x1.0 33.0 22.5 29.4 2.0 36.2 36.2 F Part number example: FXN.1M.305.XLCM H øV G K Note: The dimensions «N» and «V» are the same as the FXl models and the dimension «P» is the same as the FMl models. Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). 8 www.lemo.com ® ® FWl Straight plug with square flange, key (N) or keys (H, P, R, S, T, U, V, W and X) with arctic grip Dimensions (mm) Reference Model Series A A1 B C Ls/Lr X 1.5 øC øV H ø A1 P øD øE øB øA N D E G H K Ls Lr N V FWl MM 21.5 12.0 6.4 10.7 5.6 9.5 17.0 12.0 1.5 26.1 26.1 17.0 2.7 FWl 0M 26.9 14.4 8.8 12.7 8.0 12.2 18.9 15.1 1.5 29.1 29.1 20.6 2.7 FWl 1M 31.4 15.9 10.5 14.2 9.7 13.7 18.9 18.3 1.5 29.1 29.1 23.8 3.3 FWl 2M 34.6 18.9 14.0 17.2 13.0 16.7 18.9 20.6 1.5 29.5 29.5 26.1 3.3 FWl 3M 34.6 20.9 16.0 19.2 15.0 18.7 18.9 20.6 1.5 29.5 29.5 26.1 3.3 FWl TM 38.0 23.4 17.9 22.0 16.7 21.5 22.5 23.0 2.0 34.8 34.8 28.5 3.3 FWl 4M 40.3 25.9 20.7 24.5 19.5 24.0 22.5 24.6 2.0 34.8 34.8 30.1 3.3 FWl LM 43.7 29.4 23.9 28.0 22.7 27.5 22.5 27.0 2.0 34.8 34.8 32.5 3.3 FWl 5M 47.0 34.9 29.7 33.5 28.5 33.0 22.5 29.4 2.0 34.8 34.8 37.0 3.3 Part number example: FWN.1M.305.XLC G K Note: The dimensions «P» and «X» are the same as the FMl models. Ls = standard gender, Lr = reverse gender. FWl Straight plug with square flange, key (N) or keys (H, P, R, S, T, U, V, W and X), arctic grip and mold stop Dimensions (mm) Reference Model Series A A1 B C D E G H K Ls Lr N V Ls/Lr øC P øD øF øE øB X 1.5 øV H 1.5 M ø A1 øA N FWl MM 21.5 12.0 6.4 10.7 5.6 9.5 17.0 12.0 1.5 29.1 29.1 17.0 2.7 FWl 0M 26.9 14.4 8.8 12.7 8.0 12.2 18.9 15.1 1.5 32.1 32.1 20.6 2.7 FWl 1M 31.4 15.9 10.5 14.2 9.7 13.7 18.9 18.3 1.5 32.1 32.1 23.8 3.3 FWl 2M 34.6 18.9 14.0 17.2 13.0 16.7 18.9 20.6 1.5 32.5 32.5 26.1 3.3 FWl 3M 34.6 20.9 16.0 19.2 15.0 18.7 18.9 20.6 1.5 32.5 32.5 26.1 3.3 FWl TM 38.0 23.4 17.9 22.0 16.7 21.5 22.5 23.0 2.0 37.8 37.8 28.5 3.3 FWl 4M 40.3 25.9 20.7 24.5 19.5 24.0 22.5 24.6 2.0 37.8 37.8 30.1 3.3 FWl LM 43.7 29.4 23.9 28.0 22.7 27.5 22.5 27.0 2.0 37.8 37.8 32.5 3.3 FWl 5M 47.0 34.9 29.7 33.5 28.5 33.0 22.5 29.4 2.0 37.8 37.8 37.0 3.3 Part number example: FWN.1M.305.XLCT G K Note: The dimensions «F», «M», «P» and «X» are the same as the FMl models. Ls = standard gender, Lr = reverse gender. FWl Straight plug with square flange, key (N) or keys (H, P, R, S, T, U, V, W and X) with arctic grip and MIL-DTL-38999L shell thread Dimensions (mm) Reference Model Series A A1 C Ls/Lr 1.5 P e øC 9 ø A1 øA øE N e E G H K Ls Lr Code1) FWl 1M 31.4 15.9 14.2 M12x1.0 13.7 18.9 18.3 1.5 31.4 31.4 A FWl 2M 34.6 18.9 17.2 M15x1.0 16.7 18.9 20.6 1.5 31.4 31.4 B FWl 3M 34.6 20.9 19.2 M18x1.0 18.7 18.9 20.6 1.5 31.4 31.4 C FWl TM 38.0 23.4 22.0 M18x1.0 21.5 22.5 23.0 2.0 36.2 36.2 C FWl 4M 40.3 25.9 24.5 M22x1.0 24.0 22.5 24.6 2.0 36.2 36.2 D FWl LM 43.7 29.4 28.0 M25x1.0 27.5 22.5 27.0 2.0 36.2 36.2 E FWl 5M 47.0 34.9 33.5 M31x1.0 33.0 22.5 29.4 2.0 36.2 36.2 F Part number example: FWN.1M.305.XLCM H øV G K Note: The dimensions «N» and «V» are the same as the FWl models and the dimension «P» is the same as the FMl models. Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). www.lemo.com 9 ® ® FAl Straight plug with square flange, non-coupling, key (N) or keys (H, P, R, S, T, U, V, W and X) Reference Dimensions (mm) Model Series A Ls/Lr øA P øC øD øB X øE N øV H B C D E G H K Ls Lr N P V FAl MM 21.5 6.4 10.7 5.6 9.5 17.0 12.0 1.5 26.1 26.1 17.0 5.5 2.7 FAl 0M 26.9 8.8 12.7 8.0 12.2 18.9 15.1 1.5 29.1 29.1 20.6 3.9 2.7 FAl 1M 31.4 10.5 14.2 9.7 13.7 18.9 18.3 1.5 29.1 29.1 23.8 3.9 3.3 FAl 2M 34.6 14.0 17.2 13.0 16.7 18.9 20.6 1.5 29.5 29.5 26.1 3.9 3.3 FAl 3M 34.6 16.0 19.2 15.0 18.7 18.9 20.6 1.5 29.5 29.5 26.1 3.9 3.3 FAl TM 38.0 17.9 22.0 16.7 21.5 22.5 23.0 2.0 34.8 34.8 28.5 3.4 3.3 FAl 4M 40.3 20.7 24.5 19.5 24.0 22.5 24.6 2.0 34.8 34.8 30.1 3.4 3.3 FAl LM 43.7 23.9 28.0 22.7 27.5 22.5 27.0 2.0 34.8 34.8 32.5 3.4 3.3 FAl 5M 47.0 29.7 33.5 28.5 33.0 22.5 29.4 2.0 34.8 34.8 37.0 3.4 3.3 Part number example: FAN.1M.305.XLC G K Note: The dimension «X» is the same as the FMl models. Ls = standard gender, Lr = reverse gender. FAl Straight plug with square flange, non-coupling, key (N) or keys (H, P, R, S, T, U, V, W and X) with mold stop Reference Dimensions (mm) Model Series A Ls/Lr øA øC X 1.5 øV H P øD øF øB M øE N B C D E G H K Ls Lr N P V FAl MM 21.5 6.4 10.7 5.6 9.5 17.0 12.0 1.5 29.1 29.1 17.0 5.5 2.7 FAl 0M 26.9 8.8 12.7 8.0 12.2 18.9 15.1 1.5 32.1 32.1 20.6 3.9 2.7 FAl 1M 31.4 10.5 14.2 9.7 13.7 18.9 18.3 1.5 32.1 32.1 23.8 3.9 3.3 FAl 2M 34.6 14.0 17.2 13.0 16.7 18.9 20.6 1.5 32.5 32.5 26.1 3.9 3.3 FAl 3M 34.6 16.0 19.2 15.0 18.7 18.9 20.6 1.5 32.5 32.5 26.1 3.9 3.3 FAl TM 38.0 17.9 22.0 16.7 21.5 22.5 23.0 2.0 37.8 37.8 28.5 3.4 3.3 FAl 4M 40.3 20.7 24.5 19.5 24.0 22.5 24.6 2.0 37.8 37.8 30.1 3.4 3.3 FAl LM 43.7 23.9 28.0 22.7 27.5 22.5 27.0 2.0 37.8 37.8 32.5 3.4 3.3 FAl 5M 47.0 29.7 33.5 28.5 33.0 22.5 29.4 2.0 37.8 37.8 37.0 3.4 3.3 Part number example: FAN.1M.305.XLCT G K Note: The dimension «X» is the same as the FMl models. Ls = standard gender, Lr = reverse gender. FAl Straight plug with square flange, non-coupling, key (N) or keys (H, P, R, S, T, U, V, W and X) with MIL-DTL-38999L shell thread Reference Dimensions (mm) Model Series A C Ls/Lr øA P e øC 9 øE N e E G H K Ls Lr N Code1) FAl 1M 31.4 14.2 M12x1.0 13.7 18.9 18.3 1.5 31.4 31.4 23.8 A FAl 2M 34.6 17.2 M15x1.0 16.7 18.9 20.6 1.5 31.4 31.4 26.1 B FAl 3M 34.6 19.2 M18x1.0 18.7 18.9 20.6 1.5 31.4 31.4 26.1 C FAl TM 38.0 22.0 M18x1.0 21.5 22.5 23.0 2.0 36.2 36.2 28.5 C FAl 4M 40.3 24.5 M22x1.0 24.0 22.5 24.6 2.0 36.2 36.2 30.1 D FAl LM 43.7 28.0 M25x1.0 27.5 22.5 27.0 2.0 36.2 36.2 32.5 E FAl 5M 47.0 33.5 M31x1.0 33.0 22.5 29.4 2.0 36.2 36.2 37.0 F Part number example: FAN.1M.305.XLCM H øV G K Note: The dimensions «P» and «V» are the same as the FAl models. Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). 10 www.lemo.com ® ® EGl Fixed socket, nut fixing, key (N) or keys (H, P, R, S, T, U, V, W and X) Dimensions (mm) Reference Model Series C D Ls/Lr S1 e øC P S2 E Ls Lr P S1 S2 EGl MM 10.7 5.2 M7x0.5 4.5 15.0 15.0 3.7 6.3 9.0 EGl 0M 12.7 6.8 M9x0.6 5.0 18.3 18.3 5.3 8.2 11.0 EGl 1M 14.2 6.8 M11x1.0 4.5 18.3 18.3 5.3 9.5 13.0 EGl 2M 17.2 6.8 M14x1.0 4.5 18.3 18.3 5.3 12.5 17.0 EGl 3M 19.2 6.8 M16x1.0 4.0 18.3 18.3 5.3 14.5 19.0 EGl TM 22.0 9.4 M18x1.0 4.0 20.0 21.9 7.9 16.5 22.0 EGl 4M 24.5 9.4 M21x1.0 4.0 20.0 21.9 7.9 19.5 25.0 EGl LM 28.0 9.4 M24x1.0 4.0 20.0 21.9 7.9 22.5 30.0 EGl 5M 33.5 9.4 M30x1.0 4.0 20.0 21.9 7.9 28.5 36.0 Part number example: EGN.1M.305.XLM D E maxi e Panel cut-out (page 36). Note: Ls = standard gender, Lr = reverse gender EGl Fixed socket, nut fixing, key (N) or keys (H, P, R, S, T, U, V, W and X) for printed circuit Dimensions (mm) Reference Model Series C Ls/Lr G P øC S2 e S1 4.5 5.4 D E maxi D e E G Ls Lr P S1 S2 EGl MM 10.7 5.2 M7x0.5 4.5 13.8 15.0 15.0 3.7 6.3 9.0 EGl 0M 12.7 6.8 M9x0.6 5.0 16.8 18.3 18.3 5.3 8.2 11.0 EGl 1M 14.2 6.8 M11x1.0 4.5 16.8 18.3 18.3 5.3 EGl 2M 17.2 6.8 M14x1.0 4.5 16.8 18.3 18.3 5.3 12.5 17.0 EGl 3M 19.2 6.8 M16x1.0 4.0 16.8 18.3 18.3 5.3 14.5 19.0 EGl TM 22.0 9.4 M18x1.0 4.0 18.9 20.0 21.9 7.9 16.5 22.0 EGl 4M 24.5 9.4 M21x1.0 4.0 18.9 20.0 21.9 7.9 19.5 25.0 EGl LM 28.0 9.4 M24x1.0 4.0 18.9 20.0 21.9 7.9 22.5 30.0 EGl 5M 33.5 9.4 M30x1.0 4.0 18.9 20.0 21.9 7.9 28.5 36.0 9.5 13.0 Part number example: EGN.1M.305.XLN Panel cut-out (page 36). PCB drilling pattern (page 37). Note: Ls = standard gender, Lr = reverse gender www.lemo.com 11 ® ® ECl Fixed socket with two nuts, key (N) or keys (H, P, R, S, T, U, V, W and X) Dimensions (mm) Reference Model Series A Ls/Lr S1 e øA P øB øC S3 C E e G Ls Lr P S1 S2 S3 ECl MM 14 2.85 13.5 5.0 M10x0.50 13.8 15.0 15.0 3.7 9.0 11.0 12.0 ECl 0M 17 4.72 18.2 5.0 M13x0.75 16.8 18.3 18.3 5.3 11.5 14.0 16.0 ECl 1M 18 5.95 19.2 5.0 M14x1.00 16.8 18.3 18.3 5.3 12.5 16.0 17.0 ECl 2M 21 8.95 21.5 4.0 M17x1.00 16.8 18.3 18.3 5.3 15.5 18.0 19.0 ECl 3M 23 10.95 25.0 4.0 M19x1.00 16.8 18.3 18.3 5.3 17.5 20.0 22.0 ECl TM 27 12.30 28.0 2.5 M22x1.00 18.9 20.0 21.9 7.9 20.5 23.0 25.0 ECl 4M 29 13.95 34.0 2.5 M24x1.00 18.9 20.0 21.9 7.9 22.5 25.0 30.0 ECl LM 33 17.95 36.0 2.5 M28x1.00 18.9 20.0 21.9 7.9 26.5 29.0 32.0 ECl 5M 38 22.90 41.0 2.5 M33x1.00 18.9 20.0 21.9 7.9 31.5 34.0 37.0 Part number example: ECN.1M.305.XLM S2 E maxi B Panel cut-out (page 36). G Note: Ls = standard gender, Lr = reverse gender. This model is not IP68 (no panel sealing). ECl Fixed socket with two nuts, key (N) or keys (H, P, R, S, T, U, V, W and X) for printed circuit Dimensions (mm) Reference Model Series A B C E S3 S1 4.5 e E maxi G S2 øA P øB øC 5.4 Ls/Lr e G Ls Lr P S1 S2 S3 ECl MM 14 2.85 13.5 5.0 M10x0.50 13.8 15.0 15.0 3.7 9.0 11.0 12.0 ECl 0M 17 4.72 18.2 5.0 M13x0.75 16.8 18.3 18.3 5.3 11.5 14.0 16.0 ECl 1M 18 5.95 19.2 5.0 M14x1.00 16.8 18.3 18.3 5.3 12.5 16.0 17.0 ECl 2M 21 8.95 21.5 4.0 M17x1.00 16.8 18.3 18.3 5.3 15.5 18.0 19.0 ECl 3M 23 10.95 25.0 4.0 M19x1.00 16.8 18.3 18.3 5.3 17.5 20.0 22.0 ECl TM 27 12.30 28.0 2.5 M22x1.00 18.9 20.0 21.9 7.9 20.5 23.0 25.0 ECl 4M 29 13.95 34.0 2.5 M24x1.00 18.9 20.0 21.9 7.9 22.5 25.0 30.0 ECl LM 33 17.95 36.0 2.5 M28x1.00 18.9 20.0 21.9 7.9 26.5 29.0 32.0 ECl 5M 38 22.90 41.0 2.5 M33x1.00 18.9 20.0 21.9 7.9 31.5 34.0 37.0 Part number example: ECN.1M.305.XLN Panel cut-out (page 36). PCB drilling pattern (page 37). Note: Ls = standard gender, Lr = reverse gender. This model is not IP68 (no panel sealing). 12 www.lemo.com ® ® EDl Fixed socket with square flange, key (N) or keys (H, P, R, S, T, U, V, W and X) Dimensions (mm) Reference Model Series A B C G H K Ls Lr N P V Ls/Lr K P øB øC øA N H øV EDl MM 18.6 4.70 10.7 12.3 9.5 1.5 17.0 17.0 14.5 3.7 2.7 EDl 0M 20.6 4.72 12.7 12.8 11.0 1.5 18.3 18.3 16.0 5.3 2.7 EDl 1M 23.8 5.95 14.2 12.8 12.9 1.5 18.3 18.3 18.4 5.3 3.3 EDl 2M 26.9 8.95 17.2 12.8 15.1 1.5 18.3 18.3 20.6 5.3 3.3 EDl 3M 29.0 10.95 19.2 12.8 16.6 1.5 18.3 18.3 22.1 5.3 3.3 EDl TM 31.4 12.30 22.0 14.5 18.3 2.0 20.0 21.9 23.8 7.9 3.3 EDl 4M 34.6 13.95 24.5 14.5 20.6 2.0 20.0 21.9 26.1 7.9 3.3 EDl LM 38.0 17.95 28.0 14.5 23.0 2.0 20.0 21.9 28.5 7.9 3.3 EDl 5M 43.7 22.90 33.5 14.5 27.0 2.0 20.0 21.9 32.5 7.9 3.3 Part number example: EDN.1M.305.XLM G Panel cut-out (page 36). Note: Ls = standard gender, Lr = reverse gender EDl Fixed socket with square flange, key (N) or keys (H, P, R, S, T, U, V, W and X) for printed circuit Reference Dimensions (mm) Model Series A B C G H K Ls Lr N P V Ls/Lr N K øA P øB øC 5.4 4.5 H øV G EDl MM 18.6 4.70 10.7 12.3 9.5 1.5 17.0 17.0 14.5 3.7 2.7 EDl 0M 20.6 4.72 12.7 12.8 11.0 1.5 18.3 18.3 16.0 5.3 2.7 EDl 1M 23.8 5.95 14.2 12.8 12.9 1.5 18.3 18.3 18.4 5.3 3.3 EDl 2M 26.9 8.95 17.2 12.8 15.1 1.5 18.3 18.3 20.6 5.3 3.3 EDl 3M 29.0 10.95 19.2 12.8 16.6 1.5 18.3 18.3 22.1 5.3 3.3 EDl TM 31.4 12.30 22.0 14.5 18.3 2.0 20.0 21.9 23.8 7.9 3.3 EDl 4M 34.6 13.95 24.5 14.5 20.6 2.0 20.0 21.9 26.1 7.9 3.3 EDl LM 38.0 17.95 28.0 14.5 23.0 2.0 20.0 21.9 28.5 7.9 3.3 EDl 5M 43.7 22.90 33.5 14.5 27.0 2.0 20.0 21.9 32.5 7.9 3.3 Part number example: EDN.1M.305.XLN Panel cut-out (page 36). PCB drilling pattern (page 37). Note: Ls = standard gender, Lr = reverse gender www.lemo.com 13 ® ® PEl Fixed socket, nut fixing, key (N) or keys (H, P, R, S, T, U, V, W and X) with mold stop (back panel mounting) Dimensions (mm) Reference Model Series A B Ls/Lr e S2 E maxi X øA øD øF øB øC P S1 M C D E e Ls Lr M P R S1 S2 PEl MM 14 6.4 13.8 5.6 4.0 M10x0.50 21.4 21.4 8.8 3.7 10.5 9.0 11 PEl 0M 17 8.8 16.8 8.0 5.0 M13x0.75 25.6 25.6 9.7 5.3 13.8 11.5 14 PEl 1M 18 10.5 17.8 9.7 5.0 M14x1.00 25.6 25.6 9.7 5.3 13.8 12.5 16 PEl 2M 21 14.0 20.8 13.0 5.0 M17x1.00 26.0 26.0 10.1 5.3 13.8 15.5 18 PEl 3M 23 16.0 22.8 15.0 5.0 M19x1.00 26.0 26.0 10.1 5.3 13.8 17.5 20 PEl TM 27 17.9 25.8 16.7 4.0 M22x1.00 29.5 30.1 10.6 7.9 16.9 20.5 23 PEl 4M 29 20.7 27.8 19.5 4.0 M24x1.00 29.5 30.1 10.6 7.9 16.9 22.5 25 PEl LM 33 23.9 31.8 22.7 4.0 M28x1.00 29.5 30.1 10.6 7.9 16.9 26.5 29 PEl 5M 38 29.7 36.8 28.5 4.0 M33x1.00 29.5 30.1 10.6 7.9 16.9 31.5 34 Part number example: PEN.1M.305.XLMT Panel cut-out (page 36). R 1.5 Note: this model is only available with mold stop. The dimensions «F» and «X» are the same as the PBl models. Ls = standard gender, Lr = reverse gender. PEl Fixed socket, nut fixing, key (N) or keys (H, P, R, S, T, U, V, W and X) with MIL-DTL-38999L shell thread Dimensions (mm) Reference Model Series A C E Ls/Lr e øA P S1 e1 øC 9 e e1 Ls Lr R S1 S2 Code1) PEl 1M 18 17.8 5.0 M14x1.0 M12x1.0 26.4 26.4 13.8 12.5 16 A PEl 2M 21 20.8 5.0 M17x1.0 M15x1.0 26.4 26.4 13.8 15.5 18 B PEl 3M 23 22.8 5.0 M19x1.0 M18x1.0 26.4 26.4 13.8 17.5 20 C PEl TM 27 25.8 4.0 M22x1.0 M18x1.0 28.2 30.1 16.9 20.5 23 C PEl 4M 29 27.8 4.0 M24x1.0 M22x1.0 28.2 30.1 16.9 22.5 25 D PEl LM 33 31.8 4.0 M28x1.0 M25x1.0 28.2 30.1 16.9 26.5 29 E PEl 5M 38 36.8 4.0 M33x1.0 M31x1.0 28.2 30.1 16.9 31.5 34 G Part number example: PEN.1M.305.XLMM E maxi R S2 Panel cut-out (page 36). Note: Ls = standard gender, Lr = reverse gender. The dimension «P» is the same as the PBl models. 1) MIL-DTL-38999L shell size code (backshell not supplied). 14 www.lemo.com ® ® PFl Fixed socket with square flange, key (N) or keys (H, P, R, S, T, U, V, W and X) with mold stop Dimensions (mm) Reference Model Series A B C D E F G H K N Ss Sr V Ss/Sr K øA N G P øC øD øF øB øE M PFl MM 18.6 6.4 10.7 5.6 7.8 7.8 12.3 9.5 1.5 14.5 10.6 10.6 2.7 PFl 0M 20.6 8.8 12.7 8.0 10.7 10.7 12.8 11.0 1.5 16.0 11.3 11.3 2.7 PFl 1M 23.8 10.5 14.2 9.7 12.4 12.4 12.8 12.9 1.5 18.4 11.3 11.3 3.3 PFl 2M 26.9 14.0 17.2 13.0 15.5 15.5 12.8 15.1 1.5 20.6 11.7 11.7 3.3 PFl 3M 29.0 16.0 19.2 15.0 17.5 17.5 12.8 16.6 1.5 22.1 11.7 11.7 3.3 PFl TM 31.4 17.9 22.0 16.7 19.8 19.8 14.5 18.3 2.0 23.8 13.0 13.6 3.3 PFl 4M 34.6 20.7 24.5 19.5 22.6 22.6 14.5 20.6 2.0 26.1 13.0 13.6 3.3 PFl LM 38.0 23.9 28.0 22.7 25.8 25.8 14.5 23.0 2.0 28.5 13.0 13.6 3.3 PFl 5M 47.0 29.7 33.5 28.5 33.0 31.4 14.5 29.4 2.0 37.0 13.0 13.6 3.3 Part number example: PFN.1M.305.XLMT X øV H Panel cut-out (page 36). 1.5 Note: this model is only available with mold stop. The dimensions «M», «P» and «X» are the same as the PBl models. Ss = standard gender, Sr = reverse gender. PFl Fixed socket with square flange, key (N) or keys (H, P, R, S, T, U, V, W and X) with MIL-DTL-38999L shell thread Dimensions (mm) Reference Model Series A C Ss/Sr N K øA G P H ø 3.3 øC e øE 9 e E G H K N Ss Sr Code1) PFl 1M 23.8 14.2 M12x1.0 12.4 12.8 12.9 1.5 18.4 12.2 12.2 A PFl 2M 26.9 17.2 M15x1.0 15.5 12.8 15.1 1.5 20.6 12.2 12.2 B PFl 3M 29.0 19.2 M18x1.0 17.5 12.8 16.6 1.5 22.1 12.2 12.2 C PFl TM 31.4 22.0 M18x1.0 19.8 14.5 18.3 2.0 23.8 11.7 13.6 C PFl 4M 34.6 24.5 M22x1.0 22.6 14.5 20.6 2.0 26.1 11.7 13.6 D PFl LM 38.0 28.0 M25x1.0 25.8 14.5 23.0 2.0 28.5 11.7 13.6 E PFl 5M 47.0 33.5 M31x1.0 33.0 14.5 29.4 2.0 37.0 11.7 13.6 G Part number example: PFN.1M.305.XLMM Panel cut-out (page 36). Note: The dimension «P» is the same as the PBl models. Ss = standard gender, Sr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). www.lemo.com 15 ® ® PBl Fixed socket with antivibration flange, key (N) or keys (H, P, R, S, T, U, V, W and X), 2 holes fixing Dimensions (mm) Reference Model Series A B C D G H N P Ss Sr X P Ss/Sr N 1.5 (MM) 2.0 (0M-5M) A øD øB H øC X 2.7 (MM) 3.3 (0M-5M) PBl MM 21.0 6.4 11.3 5.6 6.7 16.2 12.5 3.7 13.2 13.2 5.8 PBl 0M 27.0 8.8 14.5 8.0 8.3 21.4 16.0 5.3 15.3 15.3 6.7 PBl 1M 29.0 10.5 16.5 9.7 8.3 23.4 18.0 5.3 15.3 15.3 6.7 PBl 2M 32.0 14.0 19.5 13.0 8.3 26.4 21.0 5.3 15.7 15.7 7.1 PBl 3M 35.0 16.0 21.5 15.0 8.3 29.0 23.0 5.3 15.7 15.7 7.1 PBl TM 38.5 17.9 24.5 16.7 11.0 32.5 26.0 7.9 15.2 17.1 7.6 PBl 4M 41.0 20.7 27.5 19.5 11.0 35.0 29.0 7.9 15.2 17.1 7.6 PBl LM 44.0 23.9 30.5 22.7 11.0 38.0 32.0 7.9 15.2 17.1 7.6 PBl 5M 51.0 29.7 37.5 28.5 11.0 45.0 39.0 7.9 15.2 17.1 7.6 Panel cut-out (page 36). Part number example: PBN.1M.305.XLM G Note: Ss = standard gender, Sr = reverse gender PBl Fixed socket with antivibration flange, key (N) or keys (H, P, R, S, T, U, V, W and X), 2 holes fixing, mold stop Dimensions (mm) Reference Model Series A B C D F G H M N P Ss Sr X P Ss/Sr 1.5 (MM) 2.0 (0M-5M) N A øC øD øB H øF M X 1.5 2.7 (MM) 3.3 (0M-5M) PBl MM 21.0 6.4 11.3 5.6 7.8 6.7 16.2 8.8 12.5 3.7 16.2 16.2 5.8 PBl 0M 27.0 8.8 14.5 8.0 10.7 8.3 21.4 9.7 16.0 5.3 18.3 18.3 6.7 PBl 1M 29.0 10.5 16.5 9.7 12.4 8.3 23.4 9.7 18.0 5.3 18.3 18.3 6.7 PBl 2M 32.0 14.0 19.5 13.0 15.5 8.3 26.4 10.1 21.0 5.3 18.7 18.7 7.1 PBl 3M 35.0 16.0 21.5 15.0 17.5 8.3 29.0 10.1 23.0 5.3 18.7 18.7 7.1 PBl TM 38.5 17.9 24.5 16.7 19.8 11.0 32.5 10.6 26.0 7.9 18.2 18.2 7.6 PBl 4M 41.0 20.7 27.5 19.5 22.6 11.0 35.0 10.6 29.0 7.9 18.2 18.2 7.6 PBl LM 44.0 23.9 30.5 22.7 25.8 11.0 38.0 10.6 32.0 7.9 18.2 18.2 7.6 PBl 5M 51.0 29.7 37.5 28.5 31.4 11.0 45.0 10.6 39.0 7.9 18.2 18.2 7.6 Part number example: PBN.1M.305.XLMT G Panel cut-out (page 36). Note: Ss = standard gender, Sr = reverse gender PBl Fixed socket with antivibration flange, key (N) or keys (H, P, R, S, T, U, V, W and X), 2 holes fixing with MIL-DTL-38999L shell thread Dimensions (mm) Reference Model Series A C P Ss/Sr 2 e øC H 9 A N e G H N P Ss Sr Code1) PBl 1M 29.0 16.5 M12x1.0 8.3 23.4 18.0 5.3 17.2 17.2 PBl 2M 32.0 19.5 M15x1.0 8.3 26.4 21.0 5.3 17.2 17.2 B PBl 3M 35.0 21.5 M18x1.0 8.3 29.0 23.0 5.3 17.2 17.2 C PBl TM 38.5 24.5 M18x1.0 11.0 32.5 26.0 7.9 16.2 17.1 C PBl 4M 41.0 27.5 M22x1.0 11.0 35.0 29.0 7.9 16.2 17.1 D PBl LM 44.0 30.5 M25x1.0 11.0 38.0 32.0 7.9 16.2 17.1 E PBl 5M 51.0 37.5 M31x1.0 11.0 45.0 39.0 7.9 16.2 17.1 G A Part number example: PBN.1M.305.XLMM 3.3 Panel cut-out (page 36). G Note: Ss = standard gender, Sr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). 16 www.lemo.com ® ® PVl Fixed socket with antivibration square flange, key (N) or keys (H, P, R, S, T, U, V, W and X) Dimensions (mm) Reference Model Series A øC øD øC øB øA N P 1.5 (MM) 2.0 (0M-5M) Ss/Sr X øV H B C D G H N P Ss Sr V X PVl MM 21.5 6.4 11.3 5.6 6.7 12.0 17.0 3.7 13.2 13.2 2.7 5.8 PVl 0M 26.9 8.8 14.5 8.0 8.3 15.1 20.6 5.3 15.3 15.3 2.7 6.7 PVl 1M 31.4 10.5 16.5 9.7 8.3 18.3 23.8 5.3 15.3 15.3 3.3 6.7 PVl 2M 34.6 14.0 19.5 13.0 8.3 20.6 26.1 5.3 15.7 15.7 3.3 7.1 PVl 3M 38.0 16.0 21.5 15.0 8.3 23.0 28.5 5.3 15.7 15.7 3.3 7.1 PVl TM 40.3 17.9 24.5 16.7 11.0 24.6 30.1 7.9 15.2 17.1 3.3 7.6 PVl 4M 43.7 20.7 27.5 19.5 11.0 27.0 32.5 7.9 15.2 17.1 3.3 7.6 PVl LM 47.1 23.9 30.5 22.7 11.0 29.4 34.9 7.9 15.2 17.1 3.3 7.6 PVl 5M 54.9 29.7 37.5 28.5 11.0 34.9 40.4 7.9 15.2 17.1 3.3 7.6 Panel cut-out (page 36). Part number example: PVN.1M.305.XLM G Note: Ss = standard gender, Sr = reverse gender PVl Fixed socket with antivibration square flange, key (N) or keys (H, P, R, S, T, U, V, W and X) with mold stop Dimensions (mm) Reference Model Series A B C D F G H M N P Ss Sr X Ss/Sr øA N øC øD øF øB øC M X 1.5 øV H P 1.5 (MM) 2.0 (0M-5M) PVl MM 21.5 6.4 11.3 5.6 7.8 6.7 12.0 8.8 17.0 3.7 16.2 16.2 5.8 PVl 0M 26.9 8.8 14.5 8.0 10.7 8.3 15.1 9.7 20.6 5.3 18.3 18.3 6.7 PVl 1M 31.4 10.5 16.5 9.7 12.4 8.3 18.3 9.7 23.8 5.3 18.3 18.3 6.7 PVl 2M 34.6 14.0 19.5 13.0 15.5 8.3 20.6 10.1 26.1 5.3 18.7 18.7 7.1 PVl 3M 38.0 16.0 21.5 15.0 17.5 8.3 23.0 10.1 28.5 5.3 18.7 18.7 7.1 PVl TM 40.3 17.9 24.5 16.7 19.8 11.0 24.6 10.6 30.1 7.9 18.2 18.2 7.6 PVl 4M 43.7 20.7 27.5 19.5 22.6 11.0 27.0 10.6 32.5 7.9 18.2 18.2 7.6 PVl LM 47.1 23.9 30.5 22.7 25.8 11.0 29.4 10.6 34.9 7.9 18.2 18.2 7.6 PVl 5M 54.9 29.7 37.5 28.5 31.4 11.0 34.9 10.6 40.4 7.9 18.2 18.2 7.6 Panel cut-out (page 36). Part number example: PVN.1M.305.XLMT G Note: Ss = standard gender, Sr = reverse gender. The dimension «V» is the same as the PVl models without mold stop. PVl Fixed socket with antivibration square flange, key (N) or keys (H, P, R, S, T, U, V, W and X) with MIL-DTL-38999L shell thread Dimensions (mm) Reference Model Series A P Ss/Sr 2 e 9 øC øA øC N C e G H N P Ss Sr V Code1) PVl 1M 31.4 16.5 M12x1.0 8.3 18.3 23.8 5.3 17.2 17.2 3.3 PVl 2M 34.6 19.5 M15x1.0 8.3 20.6 26.1 5.3 17.2 17.2 3.3 B PVl 3M 38.0 21.5 M18x1.0 8.3 23.0 28.5 5.3 17.2 17.2 3.3 C PVl TM 40.3 24.5 M18x1.0 11.0 24.6 30.1 7.9 16.2 17.1 3.3 C PVl 4M 43.7 27.5 M22x1.0 11.0 27.0 32.5 7.9 16.2 17.1 3.3 D PVl LM 47.1 30.5 M25x1.0 11.0 29.4 34.9 7.9 16.2 17.1 3.3 E PVl 5M 54.9 37.5 M31x1.0 11.0 34.9 40.4 7.9 16.2 17.1 3.3 G A Part number example: PVN.1M.305.XLMM H øV G Panel cut-out (page 36). Note: Ss = standard gender, Sr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). www.lemo.com 17 ® ® PMl Free socket, key (N) or keys (H, P, R, S, T, U, V, W and X) with knurled grip Dimensions (mm) Reference Model Series A Ls/Lr øA øC P øD øB X B C D Ls Lr P X PMl MM 11.1 6.4 10.7 5.6 21.4 21.4 3.7 5.8 PMl 0M 13.1 8.8 12.7 8.0 25.6 25.6 5.3 6.7 PMl 1M 14.6 10.5 14.2 9.7 25.6 25.6 5.3 6.7 PMl 2M 17.6 14.0 17.2 13.0 26.0 26.0 5.3 7.1 PMl 3M 19.6 16.0 19.2 15.0 26.0 26.0 5.3 7.1 PMl TM 22.5 17.9 22.0 16.7 28.2 30.1 7.9 7.6 PMl 4M 25.0 20.7 24.5 19.5 28.2 30.1 7.9 7.6 PMl LM 28.5 23.9 28.0 22.7 28.2 30.1 7.9 7.6 PMl 5M 34.0 29.7 33.5 28.5 28.2 30.1 7.9 7.6 Part number example: PMN.1M.305.XLM Note: Ls = standard gender, Lr = reverse gender PMl Free socket, key (N) or keys (H, P, R, S, T, U, V, W and X) with knurled grip and mold stop Dimensions (mm) Reference Model Series A Ls/Lr X 1.5 øA øC P øD øF øB M B C D F Ls Lr M P X PMl MM 11.1 6.4 10.7 5.6 7.8 24.4 24.4 8.8 3.7 5.8 PMl 0M 13.1 8.8 12.7 8.0 10.7 28.6 28.6 9.7 5.3 6.7 PMl 1M 14.6 10.5 14.2 9.7 12.4 28.6 28.6 9.7 5.3 6.7 PMl 2M 17.6 14.0 17.2 13.0 15.5 29.0 29.0 10.1 5.3 7.1 PMl 3M 19.6 16.0 19.2 15.0 17.5 29.0 29.0 10.1 5.3 7.1 PMl TM 22.5 17.9 22.0 16.7 19.8 31.2 31.2 10.6 7.9 7.6 PMl 4M 25.0 20.7 24.5 19.5 22.6 31.2 31.2 10.6 7.9 7.6 PMl LM 28.5 23.9 28.0 22.7 25.8 31.2 31.2 10.6 7.9 7.6 PMl 5M 34.0 29.7 33.5 28.5 31.4 31.2 31.2 10.6 7.9 7.6 Part number example: PMN.1M.305.XLMT Note: Ls = standard gender, Lr = reverse gender PMl Free socket, key (N) or keys (H, P, R, S, T, U, V, W and X), knurled grip and MIL-DTL-38999L shell thread Dimensions (mm) Reference Model Series A C Ls/Lr øA P øC e 9 e Ls Lr P Code1) PMl 1M 14.6 14.2 M12x1.0 27.9 27.9 5.3 A PMl 2M 17.6 17.2 M15x1.0 27.9 27.9 5.3 B PMl 3M 19.6 19.2 M18x1.0 27.9 27.9 5.3 C PMl TM 22.5 22.0 M18x1.0 29.6 30.1 7.9 C PMl 4M 25.0 24.5 M22x1.0 29.6 30.1 7.9 D PMl LM 28.5 28.0 M25x1.0 29.6 30.1 7.9 E PMl 5M 34.0 33.5 M31x1.0 29.6 30.1 7.9 G Part number example: PMN.1M.305.XLMM Note: Ls = standard gender, Lr = reverse gender. 1) MIL-DTL-38999L shell size code (backshell not supplied). 18 www.lemo.com ® ® PHl Free socket, key (N) or keys (H, P, R, S, T, U, V, W and X) with arctic grip Dimensions (mm) Reference Model Series A Ls/Lr øC øB øD øA P X B C D Ls Lr P X PHl MM 12.0 6.4 10.7 5.6 21.4 21.4 3.7 5.8 PHl 0M 14.4 8.8 12.7 8.0 25.6 25.6 5.3 6.7 PHl 1M 15.9 10.5 14.2 9.7 25.6 25.6 5.3 6.7 PHl 2M 18.9 14.0 17.2 13.0 26.0 26.0 5.3 7.1 PHl 3M 20.9 16.0 19.2 15.0 26.0 26.0 5.3 7.1 PHl TM 23.4 17.9 22.0 16.7 28.2 30.1 7.9 7.6 PHl 4M 25.9 20.7 24.5 19.5 28.2 30.1 7.9 7.6 PHl LM 29.4 23.9 28.0 22.7 28.2 30.1 7.9 7.6 PHl 5M 34.9 29.7 33.5 28.5 28.2 30.1 7.9 7.6 Part number example: PHN.1M.305.XLM Note: Ls = standard gender, Lr = reverse gender PHl Free socket, key (N) or keys (H, P, R, S, T, U, V, W and X) with arctic grip and mold stop Dimensions (mm) Reference Model Series A Ls/Lr X 1.5 øA øC P øD øF øB M B C D F Ls Lr M P X PHl MM 12.0 6.4 10.7 5.6 7.8 24.4 24.4 8.8 3.7 5.8 PHl 0M 14.4 8.8 12.7 8.0 10.7 28.6 28.6 9.7 5.3 6.7 PHl 1M 15.9 10.5 14.2 9.7 12.4 28.6 28.6 9.7 5.3 6.7 PHl 2M 18.9 14.0 17.2 13.0 15.5 29.0 29.0 10.1 5.3 7.1 PHl 3M 20.9 16.0 19.2 15.0 17.5 29.0 29.0 10.1 5.3 7.1 PHl TM 23.4 17.9 22.0 16.7 19.8 31.2 31.2 10.6 7.9 7.6 PHl 4M 25.9 20.7 24.5 19.5 22.6 31.2 31.2 10.6 7.9 7.6 PHl LM 29.4 23.9 28.0 22.7 25.8 31.2 31.2 10.6 7.9 7.6 PHl 5M 34.9 29.7 33.5 28.5 31.4 31.2 31.2 10.6 7.9 7.6 Part number example: PHN.1M.305.XLMT Note: Ls = standard gender, Lr = reverse gender PHl Free socket, key (N) or keys (H, P, R, S, T, U, V, W and X) with arctic grip and MIL-DTL-38999L shell thread Dimensions (mm) Reference Model Series A C Ls/Lr øA P øC e 9 e Ls Lr P Code1) PHl 1M 15.9 14.2 M12x1.0 27.9 27.9 5.3 A PHl 2M 18.9 17.2 M15x1.0 27.9 27.9 5.3 B PHl 3M 20.9 19.2 M18x1.0 27.9 27.9 5.3 C PHl TM 23.4 22.0 M18x1.0 29.6 30.1 7.9 C PHl 4M 25.9 24.5 M22x1.0 29.6 30.1 7.9 D PHl LM 29.4 28.0 M25x1.0 29.6 30.1 7.9 E PHl 5M 34.9 33.5 M31x1.0 29.6 30.1 7.9 G Part number example: PHN.1M.305.XLMM Note: Ls = standard gender, Lr = reverse gender 1) MIL-DTL-38999L shell size code (backshell not supplied). www.lemo.com 19 ® ® Watertight model (unmated) HEl Fixed socket, nut fixing, key (N) or keys (H, P, R, S, T, U, V, W and X), printed circuit, watertight (back panel mounting) Reference Dimensions (mm) Model Series A Ls/Lr S1 e e E H Ls Lr N P R S1 S2 HEl MM 14 13.8 M10x0.50 4.0 5.08 20.4 20.4 15.3 3.7 10.5 9.0 11 HEl 0M 17 16.8 M13x0.75 5.0 5.08 20.8 21.0 16.8 5.3 13.8 11.5 14 HEl 1M 18 17.8 M14x1.00 5.0 7.62 20.8 21.0 16.8 5.3 13.8 12.5 16 HEl 2M 21 20.8 M17x1.00 5.0 8.89 20.8 21.0 16.8 5.3 13.8 15.5 18 HEl 3M 23 22.8 M19x1.00 5.0 10.16 20.8 21.0 16.8 5.3 13.8 17.5 20 HEl TM 27 25.8 M22x1.00 4.0 12.70 24.6 24.6 19.9 7.9 16.9 20.5 23 HEl 4M 29 27.8 M24x1.00 4.0 13.97 24.6 24.6 19.9 7.9 16.9 22.5 25 HEl LM 33 31.8 M28x1.00 4.0 16.51 24.6 24.6 19.9 7.9 16.9 26.5 29 HEl 5M 38 36.8 M33x1.00 4.0 20.32 24.6 24.6 19.9 7.9 16.9 31.5 34 H øA P øC 0.8 C E maxi R N S2 Part number example: HEN.1M.305.XLNP Panel cut-out (page 36). PCB drilling pattern (page 37). Note: In MM series, the four external earth contacts are shorter. Ls = standard gender, Lr = reverse gender. Operating temperature: -20°C to +80°C. 20 www.lemo.com ® ® Fibre optic models FMl Straight plug with knurled grip Part number L P A C L P S1 S2 FMS.2M.03A.XLZT••Z 17.6 17.2 100.6 3.9 14 14 FMN.3M.95B.XLCT••Z 19.6 19.2 103.3 3.9 16 16 øA FMW.5M.03W.XLZT••Z 34.0 33.5 148.4 3.4 29 29 øC S2 Dimensions (mm) Contact part number (to be ordered separately): PSS.F7.12•.LCE23 (2M series). FFS.F7.12•.LCE23 (3M and 5M series). Note: •• Cable adaptor diameter defined upon request. The bend relief must be ordered separately (see page 33). S1 FGl Straight plug with arctic grip Part number L P A C L P S1 S2 FGS.2M.03A.XLZT••Z 18.9 17.2 100.6 3.9 14 14 FGN.3M.95B.XLCT••Z 20.9 19.2 103.3 3.9 16 16 øA FGW.5M.03W.XLZT••Z 34.9 33.5 148.4 3.4 29 29 øC S2 Dimensions (mm) Contact part number (to be ordered separately): PSS.F7.12•.LCE23 (2M series). FFS.F7.12•.LCE23 (3M and 5M series). Note: •• Cable adaptor diameter defined upon request. The bend relief must be ordered separately (see page 33). S1 PMl Free socket with knurled grip Part number PMS.2M.03A.XLZT••Z A C L P S1 S2 17.6 17.2 105.8 5.3 16 14 PMN.3M.95B.XLMT••Z 19.6 19.2 113.3 5.3 18 16 L P S1 øA PMW.5M.03W.XLZT••Z 34.0 33.5 155.2 7.9 32 29 øC S2 Dimensions (mm) Contact part number (to be ordered separately): FFS.F7.12•.LCL23 (2M series). PSS.F7.12•.LCL23 (3M and 5M series). Note: •• Cable adaptor diameter defined upon request. The bend relief must be ordered separately (see page 33). www.lemo.com 21 ® ® PHl Free socket with arctic grip Dimensions (mm) Part number A C L P S1 S2 PHS.2M.03A.XLZT••Z 18.9 17.2 105.8 5.3 16 14 PHN.3M.95B.XLMT••Z 20.9 19.2 113.3 5.3 18 16 L P S1 S2 øA øC PHW.5M.03W.XLZT••Z 34.9 33.5 155.2 7.9 32 29 Contact part number (to be ordered separately): FFS.F7.12•.LCE23 (2M series). PSS.F7.12•.LCE23 (3M and 5M series). Note: •• Cable adaptor diameter defined upon request. The bend relief must be ordered separately (see page 33). EGl Fixed socket, nut fixing Part number L S1 e øC P Dimensions (mm) C D e E L P S1 S2 EGS.2M.03A.XLZ 17.2 6.8 M14x1.0 4.5 28.9 5.3 12.5 17.0 EGN.3M.95B.XLM 19.2 6.8 M16x1.0 4.0 32.2 5.3 14.5 19.0 EGW.5M.03W.XLZ 33.5 9.4 M30x1.0 4.0 30.8 7.9 28.5 36.0 Panel cut-out (page 36). S2 Contact part number (to be ordered separately): FFS.F7.12•.LCE23 (2M series). PSS.F7.12•.LCE23 (3M and 5M series). D E maxi EDl Fixed socket with square flange Part number L K P øC øA øB N H ø 3.3 Dimensions (mm) A B C G H K L N P EDS.2M.03A.XLZ 26.9 8.95 17.2 12.8 15.1 1.5 28.9 20.6 5.3 EDN.3M.95B.XLM 29.0 10.95 19.2 12.8 16.6 1.5 32.2 22.1 5.3 EDW.5M.03W.XLZ 43.7 22.90 33.5 14.5 27.0 2.0 30.8 32.5 7.9 Panel cut-out (page 36). G Contact part number (to be ordered separately): FFS.F7.12•.LCE23 (2M series). PSS.F7.12•.LCE23 (3M and 5M series). More information on F7 fibre optic contact in LEMO F7 catalog. 22 www.lemo.com ® ® Fibre Type The choice of the ferrule hole diameter is dependent upon the fibre cladding size. LEMO offers a range of ferrule hole diameters to suit the users’ specific requirements. l First choice alternative   125 126 Special order alternative ø Core/Cladding (µm) Référence 128 9/125 50/125 62.5/125 Ferrule hole diameter (µm) Note 125 l 126 l 128 l Accessories PSS Alignment device for F7 fibre optic contact ø 3.2 8.2 Part number PSS.F7.290.NZZ Note: Alignment device should be ordered as replacement item. Tooling DCP Set of flat spanners for collet nuts Part number DCP.2M.110.TN DCP.3M.110.TN DCP.5M.110.TN DCS F7 contact alignment device tool Simple tool with two threaded end for installation/extraction of the F7 contact alignment device. Part number DCS.F7.035.PN WST Cleaning kit Fibre optic cleaning kit of 2 cotton buds, 1 dry and 1 being soaked in Isopropyl Alcohol used for cleaning the fibre optic contacts. Part number WST.KI.125.34 See also F7 tooling in the F7 fibre optic catalog. www.lemo.com 23 ® ® USB models FGl.LM.U2A.XPAT Straight plug, key (W) or key (R) with arctic grip and mold stop FMl.LM.U2A.XPAT Straight plug, key (W) or key (R) with knurled grip and mold stop 31.6 31.6 ø 28 1.5 1.5 7.6 7.6 EGl.LM.U2A.XPL Fixed socket, female to female, nut fixing, key (W) or key (R) 40.5 7.9 S 22.5 ø 28 S 30 18.9 7.9 4 maxi S 30 ø 28 M 24 x 1 S 22.5 Fixed socket, nut fixing, key (W) or key (R) M 24 x 1 EGl.LM.U2A.XPP 3.4 ø 22.7 ø 23.9 ø 25.8 ø 28 ø 28.5 10.6 ø 29.4 3.4 ø 22.7 ø 25.8 ø 23.9 10.6 4 maxi 9.4 9.4 31 Alignment Key Alignment Key and Polarized Keying System MM to 3M Front view of a socket Model M series connector model part numbers are composed of three letters. The LAST LETTER indicates the keys corresponding to a particular contact type. For example, straight plugs with H, N, P, R, U or W keys, are fitted with male contacts; whereas with S, T, V or X keys, plugs are fitted with female contacts. Sockets with H, N, P, R, U or W keys, are fitted with female contacts; whereas with S, T, V or X keys, sockets are fitted with male contacts. ll β N ll ll γ P green S red T orange Model Colour code ll β ll W ll ll R H δ γ TM to 5M α ll ll X V Contact type Plug Socket male female female male Contact type Plug Socket male female 3 3 green red orange female male β γ 165° 30° 130° 100° 155° 50° 150° 5 90° Angles α 95° 5 60° 135° Nb of keys blue yellow Angles Nb of keys blue yellow U ll Front view of a socket Colour code 105° β 115° 115° γ 35° 30° δ 25° 20° 120° 95° 25° 45° 100° 110° 125° 120° 40° 35° 20° 25° 24 www.lemo.com ® ® Insert configuration Contact type MM 0M 1M 2M 3M Female crimp contacts 303 3 0.5 l l 28-30-32 1.15 0.95 3.0 304 4 0.5 l l 28-30-32 0.95 0.90 2.0 302 303 3 0.9 l l 20-22-24 1.70 1.40 8.0 304 4 0.7 l l 22-24-26 1.35 0.90 7.0 305 5 0.7 l l 22-24-26 1.25 1.00 6.5 302 2 1.3 l l 16-18-20 1.55 1.10 19.0 303 3 1.3 l l 16-18-20 1.05 0.95 15.5 305 5 0.9 l l 20-22-24 1.30 1.30 9.0 307 7 0.7 l l 22-24-26 1.45 1.20 7.0 308 8 0.7 l l 22-24-26 1.30 1.10 5.0 304 4 1.3 l l 16-18-20 1.55 1.35 15.5 308 8 0.9 l l 20-22-24 1.95 1.10 10.0 310 10 0.9 l l 20-22-24 1.80 1.20 8.0 312 12 0.7 l l 22-24-26 1.65 1.15 7.0 316 16 0.7 l l 22-24-26 1.20 1.00 4.5 319 19 0.7 l l 22-24-26 1.20 1.00 4.0 312 12 0.9 l l 20-22-24 1.40 1.25 6.0 322 22 0.7 l l 22-24-26 1.25 1.15 4.0 330 30 0.7 l l 22-24-26 1.10 1.00 3.5 2 0.9 l Rated current (A)1) Male crimp contacts Test voltage (kV rms)1) Contact-shell 2 AWG 3 Print (straight)2) 3 Crimp 2 ø A (mm) 1 Number of contacts 4 Reference 4 øA 1 Test voltage (kV rms)1) Contact-contact Multipole l 20-22-24 1.45 1.00 10.0 www.lemo.com 25 ® ® TM 4M LM 5M 325 25 0.9 l l 20-22-24 1.10 1.25 5.0 332 32 0.7 l l 22-24-26 1.25 1.20 3.5 340 40 0.7 l l 22-24-26 1.05 1.20 3.0 340 40 0.7 l l 22-24-26 1.20 1.35 3.5 348 48 l l 22-24-26 1.10 1.35 3.0 355 55 0.9 l l 20-22-24 1.65 1.95 3.5 368 68 l l 22-24-26 1.40 1.65 2.5 366 66 0.9 l l 20-22-24 1.60 1.70 3.0 114 114 l 22-24-26 1.37 1.34 2.0 0.7 0.7 0.7 l Rated current (A)1) Female crimp contacts for sockets AWG Male crimp contacts for plug Test voltage (kV rms)1) Contact-shell Contact type Print (straight)2) 2 Crimp 3 ø A (mm) 1 3 Number of contacts 4 2 Reference 4 øA 1 Test voltage (kV rms)1) Contact-contact Multipole Note: 1) Test voltage according to IEC 60512-2 test 4a. 2) For EG•, EC•, ED•, HE• socket. 26 www.lemo.com ® ® Rated current (A)1) AWG Female crimp contacts Reference Male crimp contacts Test voltage (kV rms)1) Contact-contact Contact type Print (straight)2) 2 Crimp 1 3 ø A (mm) 4 3 Number of contacts 4 2 øA 1 Test voltage (kV rms)1) Contact-shell Mixed multipole 1M 304 2 0.7 1.30 11.0 l l 22-24-26 1.20 2 1.3 16-18-20 1.45 2.00 18.5 2M 306 3 0.7 1.40 10.5 l l 22-24-26 1.55 3 1.3 16-18-20 2.05 1.35 18.0 308 6 0.7 1.40 7.0 l l 22-24-26 1.95 2 1.3 16-18-20 1.75 1.60 23.0 310 8 0.7 1.35 6.0 l l 22-24-26 1.35 2 1.3 16-18-20 1.90 1.15 23.0 316 10 0.7 0.95 2.0 l l 22-24-26 0.90 6 1.3 16-18-20 1.35 1.15 11.0 366 44 0.7 l l 22-24-26 22 1.3 2) 3M 5M 1.65 2.70 3.0 1.95 1.80 6.0 FGN.1M.304.XRCT2: straight plug with key (N), 1M series, multipole type with 4 mixed contacts (2 x ø 0.7 mm and 2 x ø 1.3 mm), outer shell with mold stop in anthracite nickel-plated aluminium alloy, PEEK insulator, male crimp contacts. FGN.2M.308.XRC6: straight plug with key (N), 2M series, multipole type with 8 mixed contacts (6 x ø 0.7 mm and 2 x ø 1.3 mm), outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, male crimp contacts. Multi fibre and Mixed fibre optic + LV Low Voltage contact 3M 95B 4 4 0.9 03W – – – Rated current (A) – Test voltage (kV rms) Contact-contact – Crimp 2 ø A (mm) Fibre optic No 03A Female contacts Contact No Reference 2M Male contacts Test voltage (kV rms)1) Contact-shell Crimp contact 1) Contact type – l 1.00 0.80 8.0 5M 21 – – – – – – Note: 1) Test voltage according to IEC 60512-2 test 4a. 2) For EG•, EC•, ED•, HE• socket. 2) Reduced crimp barrel. www.lemo.com 27 ® ® LM U2A Rated current (A)1) l Test voltage (kV rms)1) Contact-shell 4 Test voltage (kV rms)1) Contact-contact Solder contact Female front view Number of contacts Male front view Reference USB 1.20 0.95 n.a. Mixed High-Speed coax 2M Test voltage (kV rms) Contact-shell Test voltage (kV rms) Contact-contact Rated current (A) AWG Crimp contact 2 0.9 1 l 22-24-26 0.75 1.05 10 75 C RG179 2 1.3 16-18-20 7 ø A (mm) Female crimp contacts Cable Male crimp contacts Type Number of contacts X04 øA Reference Coax Impedance (Ω) Coax Number of contacts Coax Part number: FMN.2M.X04.XRC and EGN.2M.X04.XRM. Note: Coaxial contacts must be ordered separately: – 75 Ohms male contact FFS.2B.275.ZTCE31 (3GHz) and female contact PSS.2B.275.ZTME31(3GHz) – recommended cable Belden 179DT to reach 6GHz. For more information, please consult: https://www.lemo.com/catalog/ROW/UK_English/3GHz_75_ohms_connector_for_4k_8k_HDTV.pdf – 50 Ohms male contact FFS.2B.250.ZTCE30 and female contact PSS.2B.250.ZTME30 (cable group 1, or other… see more details in coax-triax-mixed catalogue). Contacts Contact type Reference C Contact type Reference Male crimp with standard crimp barrel (fig. 1) M Female crimp with standard crimp barrel (fig. 1) B Male crimp with reduced crimp barrel (fig. 2) P Female crimp with reduced crimp barrel (fig. 2) D Male straight print N Female straight print Crimp contacts for plugs, free or fixed sockets Fig. 1 øA øC øA øC Fig. 2 øA øC øA øC 28 www.lemo.com ® ® Dimension of crimp barrels Contact 0M to 3M MM ø A ø C Form (mm) (mm) per fig. TM to 5M Conductor AWG Section (mm2) Female min. max. min. max. Ref. contact type Male Part number For male contacts For female contacts 0.5 0.45 1 C M 32 28 0.035 0.090 FGG.00.554.ZZC EGG.00.654.ZZM 1.3 1.60 1 C M 20 16 0.616 1.433 FGN.0M.565.ZZC EGN.0M.665.ZZM 0.9 1.10 1 C M 24 20 0.204 0.616 FGN.0M.560.ZZC EGN.0M.660.ZZM 0.9 0.87 2 B P 26 22 0.128 0.382 FGN.0M.561.ZZC EGN.0M.661.ZZM 0.7 0.87 1 C M 26 22 0.128 0.382 FGN.0M.555.ZZC EGN.0M.655.ZZM 0.7 0.44 2 B P 32 28 0.032 0.092 FGN.0M.556.ZZC EGN.0M.656.ZZM 1.3 1.60 1 C M 20 16 0.616 1.433 FGN.0M.565.ZZC EGN.0M.665.ZZM 0.9 1.10 1 C M 24 20 0.204 0.616 FGN.0M.560.ZZC EGW.TM.660.ZZM 0.9 0.87 2 B P 26 22 0.128 0.382 FGN.0M.561.ZZC EGW.TM.661.ZZM 0.7 0.87 1 C M 26 22 0.128 0.382 FGN.0M.555.ZZC EGW.TM.655.ZZM 0.7 0.44 2 B P 32 28 0.032 0.092 FGN.0M.556.ZZC EGW.TM.656.ZZM Note: In order to satisfy crimp pull-test requirements to the IEC 60352-2 standard, the use of single strand cables should be avoided. Accessories BMF Blanking caps for plugs Part number L N øA P øC X sliding loop Note: 1) the tolerance on this dimension is ± 5 mm. Dimensions (mm) A C L N1) P X BMF.MM.100.•AV 11.1 10.7 17.8 60.0 3.7 4.0 BMF.0M.100.•AV 13.1 12.7 24.6 85.0 5.3 6.0 BMF.1M.100.•AV 14.6 14.2 24.6 85.0 5.3 6.0 BMF.2M.100.•AV 17.6 17.2 24.6 85.0 5.3 6.0 BMF.3M.100.•AV 19.6 19.2 24.6 120.0 5.3 6.0 BMF.TM.100.•AV 22.5 22.0 31.1 120.0 7.9 10.0 BMF.4M.100.•AV 25.0 24.5 31.1 120.0 7.9 10.0 BMF.LM.100.•AV 28.5 28.0 31.1 150.0 7.9 10.0 BMF.5M.100.•AV 34.0 33.5 31.1 150.0 7.9 10.0 BGF Blanking caps for plugs Part number L N sliding loop Note: 1) the tolerance on this dimension is ± 5 mm. øA P øC X Dimensions (mm) A C L N1) P X BGF.MM.100.•AV 12.0 10.7 17.8 60.0 3.7 4.0 BGF.0M.100.•AV 14.4 12.7 24.6 85.0 5.3 6.0 BGF.1M.100.•AV 15.9 14.2 24.6 85.0 5.3 6.0 BGF.2M.100.•AV 18.9 17.2 24.6 85.0 5.3 6.0 BGF.3M.100.•AV 20.9 19.2 24.6 120.0 5.3 6.0 BGF.TM.100.•AV 23.4 22.0 31.1 120.0 7.9 10.0 BGF.4M.100.•AV 25.9 24.5 31.1 120.0 7.9 10.0 BGF.LM.100.•AV 29.4 28.0 31.1 150.0 7.9 10.0 BGF.5M.100.•AV 34.9 33.5 31.1 150.0 7.9 10.0 www.lemo.com 29 ® ® BME Blanking caps for fixed sockets Part number L N øA P øC X ø 3.5 Dimensions (mm) A C L N1) P X BME.MM.200.•AZ 11.1 10.7 19.5 60.0 5.5 4.0 BME.0M.200.•AZ 13.1 12.7 23.4 85.0 3.9 6.0 BME.1M.200.•AZ 14.6 14.2 23.4 85.0 3.9 6.0 BME.2M.200.•AZ 17.6 17.2 23.4 85.0 3.9 6.0 BME.3M.200.•AZ 19.6 19.2 23.4 120.0 3.9 6.0 BME.TM.200.•AZ 22.5 22.0 31.0 120.0 3.4 10.0 BME.4M.200.•AZ 25.0 24.5 31.0 120.0 3.4 10.0 BME.LM.200.•AZ 28.5 28.0 31.0 150.0 3.4 10.0 BME.5M.200.•AZ 34.0 33.5 31.0 150.0 3.4 10.0 Note: 1) the tolerance on this dimension is ± 5 mm. BGE Blanking caps for fixed sockets Part number L N øA P øC X ø 3.5 Dimensions (mm) A C L N1) P X BGE.MM.200.•AZ 12.0 10.7 19.5 60.0 5.5 4.0 BGE.0M.200.•AZ 14.4 12.7 23.4 85.0 3.9 6.0 BGE.1M.200.•AZ 15.9 14.2 23.4 85.0 3.9 6.0 BGE.2M.200.•AZ 18.9 17.2 23.4 85.0 3.9 6.0 BGE.3M.200.•AZ 20.9 19.2 23.4 120.0 3.9 6.0 BGE.TM.200.•AZ 23.4 22.0 31.0 120.0 3.4 10.0 BGE.4M.200.•AZ 25.9 24.5 31.0 120.0 3.4 10.0 BGE.LM.200.•AZ 29.4 28.0 31.0 150.0 3.4 10.0 BGE.5M.200.•AZ 34.9 33.5 31.0 150.0 3.4 10.0 Note: 1) the tolerance on this dimension is ± 5 mm. BMF Blanking caps for free sockets Part number L N sliding loop øA P øC X Dimensions (mm) A C L N1) P X BMF.MM.200.•AZ 11.1 10.7 19.5 60.0 5.5 4.0 BMF.0M.200.•AZ 13.1 12.7 23.4 85.0 3.9 6.0 BMF.1M.200.•AZ 14.6 14.2 23.4 85.0 3.9 6.0 BMF.2M.200.•AZ 17.6 17.2 23.4 85.0 3.9 6.0 BMF.3M.200.•AZ 19.6 19.2 23.4 120.0 3.9 6.0 BMF.TM.200.•AZ 22.5 22.0 31.0 120.0 3.4 10.0 BMF.4M.200.•AZ 25.0 24.5 31.0 120.0 3.4 10.0 BMF.LM.200.•AZ 28.5 28.0 31.0 150.0 3.4 10.0 BMF.5M.200.•AZ 34.0 33.5 31.0 150.0 3.4 10.0 Note: 1) the tolerance on this dimension is ± 5 mm. 30 www.lemo.com ® ® BGF Blanking caps for free sockets Part number L N øA P øC X sliding loop Dimensions (mm) A C L N1) P X BGF.MM.200.•AZ 12.0 10.7 19.5 60.0 5.5 4.0 BGF.0M.200.•AZ 14.4 12.7 23.4 85.0 3.9 6.0 BGF.1M.200.•AZ 15.9 14.2 23.4 85.0 3.9 6.0 BGF.2M.200.•AZ 18.9 17.2 23.4 85.0 3.9 6.0 BGF.3M.200.•AZ 20.9 19.2 23.4 120.0 3.9 6.0 BGF.TM.200.•AZ 23.4 22.0 31.0 120.0 3.4 10.0 BGF.4M.200.•AZ 25.9 24.5 31.0 120.0 3.4 10.0 BGF.LM.200.•AZ 29.4 28.0 31.0 150.0 3.4 10.0 BGF.5M.200.•AZ 34.9 33.5 31.0 150.0 3.4 10.0 Note: 1) the tolerance on this dimension is ± 5 mm. BMK Blanking caps, large washer for ECl/PEl/HEl fixed sockets Part number L øE øB N øA P øC X Dimensions (mm) A B C E L N1) P X BMK.MM.200.•AZ 11.1 10.1 10.7 14.0 19.5 60.0 5.5 4.0 BMK.0M.200.•AZ 13.1 13.1 12.7 17.0 23.4 85.0 3.9 6.0 BMK.1M.200.•AZ 14.6 14.1 14.2 18.0 23.4 85.0 3.9 6.0 BMK.2M.200.•AZ 17.6 17.2 17.2 21.0 23.4 85.0 3.9 6.0 BMK.3M.200.•AZ 19.6 19.2 19.2 23.0 23.4 120.0 3.9 6.0 BMK.TM.200.•AZ 22.5 22.2 22.0 27.0 31.0 120.0 3.4 10.0 BMK.4M.200.•AZ 25.0 24.2 24.5 29.0 31.0 120.0 3.4 10.0 BMK.LM.200.•AZ 28.5 28.2 28.0 33.0 31.0 150.0 3.4 10.0 BMK.5M.200.•AZ 34.0 33.2 33.5 38.0 31.0 150.0 3.4 10.0 Note: 1) the tolerance on this dimension is ± 5 mm. BGK Blanking caps, large washer for ECl/PEl/HEl fixed sockets Part number L øE øB N øA P øC X Dimensions (mm) A B C E L N1) P X BGK.MM.200.•AZ 12.0 10.1 10.7 14.0 19.5 60.0 5.5 4.0 BGK.0M.200.•AZ 14.4 13.1 12.7 17.0 23.4 85.0 3.9 6.0 BGK.1M.200.•AZ 15.9 14.1 14.2 18.0 23.4 85.0 3.9 6.0 BGK.2M.200.•AZ 18.9 17.2 17.2 21.0 23.4 85.0 3.9 6.0 BGK.3M.200.•AZ 20.9 19.2 19.2 23.0 23.4 120.0 3.9 6.0 BGK.TM.200.•AZ 23.4 22.2 22.0 27.0 31.0 120.0 3.4 10.0 BGK.4M.200.•AZ 25.9 24.2 24.5 29.0 31.0 120.0 3.4 10.0 BGK.LM.200.•AZ 29.4 28.2 28.0 33.0 31.0 150.0 3.4 10.0 BGK.5M.200.•AZ 34.9 33.2 33.5 38.0 31.0 150.0 3.4 10.0 Note: 1) the tolerance on this dimension is ± 5 mm. These caps are suitable for use with any alignment key configuration. The position «•» of the part number indicates the housing material. See page 5. www.lemo.com 31 ® ® GEA Hexagonal nuts for EC l model Part number A L øB e Series Dimensions (mm) A B e L GEA.MM.241.RL MM 12 13.5 M10x0.50 2.5 GEA.0M.241.RL 0M 16 18.2 M13x0.75 2.5 GEA.0E.240.RL 1M 17 19.2 M14x1.00 2.5 GEA.2M.241.RL 2M 19 21.5 M17x1.00 3.0 GEA.3M.241.RL 3M 25 22.0 M19x1.00 3.0 GEA.TM.241.RL TM 25 28.0 M22x1.00 3.0 GEA.4M.241.RL 4M 30 34.0 M24x1.00 3.0 GEA.LM.241.RL LM 32 36.0 M28x1.00 3.0 GEA.5M.241.RL 5M 37 41.0 M33x1.00 3.0 l Material: Nickel-plated aluminium alloy GEA Hexagonal nuts for EG l model Part number A L øB e Series Dimensions (mm) A B e L GEA.00.240.RL MM 9 10.2 M7x0.50 2.0 GEA.0S.240.RL 0M 11 12.4 M9x0.60 2.0 GEA.1M.240.RL 1M 13 14.5 M11x1.00 2.5 GEA.0E.240.RL 2M 17 19.2 M14x1.00 2.5 GEA.1E.240.RL 3M 19 21.5 M16x1.00 3.0 GEA.3S.240.RL TM 22 25.0 M18x1.00 3.0 GEA.4M.240.RL 4M 25 28.0 M21x1.00 4.0 GEA.3E.240.RL LM 30 34.0 M24x1.00 5.0 GEA.5M.240.RL 5M 36 40.5 M30x1.00 5.0 l Material: Nickel-plated aluminium alloy GEC Conical nut for models HE l, EC l, PE l Part number A L øB e Series Dimensions (mm) A B e L GEC.MM.240.RN MM 11 14 M10x0.50 2.5 GEC.0M.240.RN 0M 14 17 M13x0.75 3.2 GEC.0E.240.RN 1M 16 18 M14x1.00 3.0 GEC.2M.240.RN 2M 18 21 M17x1.00 3.2 GEC.3M.240.RN 3M 20 23 M19x1.00 3.2 GEC.TM.240.RN TM 23 27 M22x1.00 5.0 GEC.4M.240.RN 4M 25 29 M24x1.00 5.0 GEC.LM.240.RN LM 29 33 M28x1.00 5.0 GEC.5M.240.RN 5M 34 38 M33x1.00 5.0 l Material: Nickel-plated aluminium alloy (anthracite colour) 32 www.lemo.com ® ® FGN M series constant force spring clips A range of constant force spring clips are available for use with M Series connectors, which permits repair of cable terminations without having to discard any of the existing braid shield system. When used in conjunction with LEMO heatshrink boots, a fully sealed termination is achieved. An additional benefit of the constant force spring is that it provides excellent resistance to shock or vibration due to its self-tensioning properties. Series Braid grounding location diameter (mm) FGN.0M.185.AZ 0M / 1M / 2M 8.0 / 9.7 / 13.0 FGN.3M.185.AZ 3M / TM 15.0 / 16.7 FGN.5M.185.AZ 4M / LM / 5M 19.5 / 22.7 / 28.5 Part number Note: Force spring clips can be assembled by hand. Do not require additional tools. Heatshrink boot Straight boot Elbow boot BEFORE HEATING BEFORE HEATING AFTER HEATING AFTER HEATING Series Straight Part number Raychem ® Elbow 90° Part number LEMO Part number Raychem ® Note Supplier Part number LEMO cable ø min. (mm) MM – GMA.10.290.DN – GHA.10.210.DN 2) 2.2 0M-2M 202 A 111-25/86 GMA.16.254.DN 222 A 111-25/86 GHA.18.170.DN 1) 3.8 Raychem 2M-4M 202 A 121-25/86 GMA.24.380.DN 222 A 121-25/86 GHA.25.200.DN 1) 5.3 4M-5M 202 A 142-25/86 GMA.31.670.DN 222 A 142-25/86 GHA.32.360.DN 1) 7.4 LEMO ® Note: 1) modified elastomer resistant to fluids with hot melt sealant. 2) elastomer resistant to fluids. We recommend a thermosetting sealant with this type of boot. www.lemo.com 33 ® ® GMA Bend relief (for M series fibre optic model only) A bend relief made from thermoplastic polyurethane elastomer can be fitted over LEMO plugs and sockets that are supplied with nut for fitting such bend relief. An other bend relief has been designed for connectors used in applications at high temperature or requiring vapour sterilization. These bend reliefs are different from previous ones as for their material, a silicone elastomer which is noted for its retention of flexibility over a wide temperature range. Main characteristics l Material: TPU (Thermoplastic Polyurethane) l Temperature range in dry atmosphere: -40°C Part number (Polyurethane) Series Part number (Silicone) GMA.2B.0••.DG 2M GMA.2B.0••.RG GMA.3B.0••.DG 3M GMA.3B.0••.RG GMA.4B.0••.DG 5M GMA.4B.0••.RG l Material: Silicone elastomer VMQ l Temperature range in dry atmosphere: -60°C l Temperature range in water steam: +140°C Note: Please see unipole/multipole catalogue for bend relief dimensions. The last letter «G» of the part number indicates the grey colour of the bend relief. For ordering a bend relief with another colour, see table on the right and replace the letter «G» by the letter of the required colour. Colour Ref. Ref. Colour Ref. +80°C +200°C Colour A blue J yellow R red B white M brown S orange G grey N black V green Tooling DCE Positioners for crimp contacts Contact Male For male contacts Contact ø Size 1.3 0M-5M DCE.91.130.5MVC 0.9 0M-5M DCE.91.090.5MVC 0.7 0M-5M DCE.91.070.5MVC 0.5 MM Contact Female DCE.91.050.0VC Positioners part number For female contacts Contact ø Size 1.3 0M-5M DCE.91.130.5MVM 0M-3M DCE.91.090.3MVM TM-5M DCE.91.09T.5MVM 0M-3M DCE.91.070.3MVM TM-5M DCE.91.07T.5MVM 0.9 0.7 These positioners are suitable for use with both manual and pneumatic crimping tools according to the MIL-C-22520/7-01 standard. Positioners part number 0.5 MM DCE.91.050.0VM 34 www.lemo.com ® ® DCF Extractors for crimp contacts Contact ø Part number 1.3 DCF.93.131.4LT 0.9 DCF.93.090.4LT 0.7 DCF.93.070.4LT 0.5 DCF.91.050.2LT Note: this model is used for male and female contacts. DCV Female contact insertion tool Contact ø Part number 1.3 DCV.13.05M.LA 0.9 DCV.09.05M.LA 0.7 DCV.07.05M.LA 0.5 DCV.05.05M.LA DCM Insert conical nut tightening tools Insert conical nut Series Part number Torque (Nm) DCM.65.110.AZ MM 1.0 ECl , HEl , PEl DCM.65.140.AZ 0M 1.0 ECl , HEl , PEl 1M 1.5 ECl , HEl , PEl DCM.65.180.AZ 2M 2.0 ECl , HEl , PEl DCM.65.200.AZ 3M 2.5 ECl , HEl , PEl DCM.65.230.AZ TM 4.0 ECl , HEl , PEl 4M 5.0 ECl , HEl , PEl LM 6.5 ECl , HEl , PEl 5M 8.0 ECl , HEl , PEl Insert conical nut DCM.65.160.AZ Torque wrench DCM.65.250.AZ DCM.65.290.AZ Torque wrench DCM.65.000.4PA DCM.65.040.8PA DCM.65.340.AZ For models DPC Manual crimping tool Part number DPC.91.701.V According to specification MIL-C-22520/7-01. For LEMO contacts ø 0.5-0.7-0.9-1.3 mm Banding tool and Tie-wrap Part number GLEN-AIR TIE-DEX® AXON® ® Banding tool Tie wrap 1) 600-061 A30199 ACDBS100 600-057 A31189 AXCL 02 Note: 1) need to be ordered in addition of tool. The banding tool is to be used with screened cables to ensure a good ground contact. www.lemo.com 35 ® ® Panel Cut-Out Cut-outs Mounting nut torque (on panel) EGl -ECl -HEl -PEl Series ø A+ 0.1 0 L mini B + 0.1 0 EGl ø A B L ECl /HEl /PEl ø A B L Series Torque (Nm) MM 7.1 6.4 12.5 10.1 9.1 16.0 MM 1.0 0M 9.1 8.3 14.5 13.1 11.6 20.0 0M 1.0 1M 11.1 9.6 17.2 14.1 12.6 21.0 1M 1.5 2M 14.1 12.6 20.5 17.1 15.6 24.0 2M 2.0 3M 16.1 14.6 23.0 19.1 17.6 27.0 3M 2.5 TM 18.1 16.6 27.0 22.1 20.6 31.5 TM 4.0 4M 21.1 19.6 30.0 24.1 22.6 35.5 4M 5.0 LM 24.1 22.6 32.0 28.1 26.6 36.5 LM 6.5 5M 30.1 28.6 41.0 33.1 31.6 41.0 5M 8.0 Cut-outs EDl -FAl -FWl -FXl -PVl -PFl + 0.1 0 H øA + 0.1 0 + 0.1 0 H Series B EDl ø A B H FAl /FWl /FXl ø A B H ø A PVl B H ø A PFl B H MM 5.0 M2.5 9.5 9.6 M2.5 12.0 11.8 M2.5 12.0 7.9 M2.5 9.5 0M 5.1 M2.5 11.0 12.3 M2.5 15.1 15.0 M2.5 15.1 10.8 M2.5 11.0 1M 6.1 M3.0 12.9 13.8 M3.0 18.3 17.0 M3.0 18.3 12.5 M3.0 12.9 2M 9.1 M3.0 15.1 16.8 M3.0 20.6 20.0 M3.0 20.6 15.6 M3.0 15.1 3M 11.1 M3.0 16.6 18.8 M3.0 20.6 22.0 M3.0 23.0 18.1 M3.0 16.6 TM 12.5 M3.0 18.3 21.6 M3.0 23.0 25.0 M3.0 24.6 19.9 M3.0 18.3 4M 14.1 M3.0 20.6 24.1 M3.0 24.6 28.0 M3.0 27.0 22.7 M3.0 20.6 LM 18.1 M3.0 23.0 27.6 M3.0 27.0 31.0 M3.0 29.4 25.9 M3.0 23.0 5M 23.2 M3.0 27.0 33.1 M3.0 29.4 38.0 M3.0 34.9 33.1 M3.0 29.4 Cut-outs PBl H øA + 0.1 0 + 0.1 0 Series B PBl ø A B H Series PBl ø A B H MM 11.8 M2.5 16.2 TM 25.0 M3.0 32.5 0M 15.0 M3.0 21.4 4M 28.0 M3.0 35.0 1M 17.0 M3.0 23.4 LM 31.0 M3.0 38.0 2M 20.0 M3.0 26.4 5M 38.0 M3.0 45.0 3M 22.0 M3.0 29.0 36 www.lemo.com ® ® PCB drilling pattern Fixed socket with straight print contact +0.1 0 45° 4xø1 +0.1 0 0° 45° 4xø1 1M.302 +0.1 0 4xø1 ° 72 4xø1 +0.1 0 +0.1 0 7.62 0M.305 +0.1 0 +0.1 0 4xø1 +0.1 0 5.08 ø 2.8 5.08 +0.1 0 2 x ø 1.1 1M.307 ° 72 +0.1 0 1M.308 +0.1 0 4xø1 4xø1 30° +0.1 0 °2 51 4xø1 6' +0.1 0 +0.1 0 2 x ø 1.1 +0.1 0 10.16 ø 8.2 +0.1 0 6 x ø 1.1 7.62 ø 3.8 ø 6.2 8.89 2.4 60 ° 16 x ø 0.8 +0.1 0 3.9 1.8 0 1.8 3.9 + 0.1 0 +0.1 0 4xø1 +0.1 0 +0.1 0 22°30' 12°52' 45 4xø1 3 0.9 0.9 3 16°22’ 4xø1 +0.1 0 43 ' +0.1 0 ’ 44 3M.322 10.16 ° 45 12 x ø 0.8 ° 72 +0.1 0 3 0.9 0.9 3 10 x ø 0.8 2 x ø 1.1 ° 32 ø 6.5 12 x ø 0.8 4.45 2.1 0 2.1 4.45 4xø1 +0.1 0 ø 3.4 +0.1 0 22°30' 90° 15° ø 6.7 ° +0.1 0 8.89 30 45° ø 3.5 6 4xø1 +0.1 0 3M.316.•R 1) 3M.312 0° 22°30' 4 x ø 1 90° 8.89 ø 6.2 8 x ø 0.8 2M.319 19 x ø 0.8 ° 45 2.4 50° +0.1 0 +0.1 0 2M.316 45° 50° 8.89 ø 6.2 45 ° 10 x ø 0.8 2M.312 5.1 ø 2.15 22°30' 4 x ø 1 +0.1 0 6 x ø 0.8 22 x ø 0.8 10.16 +0.1 0 2M.310.•R 1) 2M.310 +0.1 0 ø 8.8 4xø1 8 x ø 0.8 ø 6.6 +0.1 0 +0.1 0 ø 3.1 3 x ø 0.8 4xø1 ø5 +0.1 0 ° ° 5.1 8.89 3 x ø 1.1 45 +0.1 0 ° ø 6.2 +0.1 0 4xø1 60 +0.1 0 ø 6.4 0° 12 8.89 4 x ø 1.1 4xø1 +0.1 0 8.89 ° ø 4.8 ° 60 8.89 45 +0.1 0 8 x ø 0.8 2M.308.•R 1) 2M.308 ø 5.1 4xø1 +0.1 0 25° 2M.306.•R 1) 2M.304 7 x ø 0.8 7.62 +0.1 0 ø 3.7 60 5 x ø 0.8 ø 2.8 ø 2.8 +0.1 0 7.62 2 x ø 0.8 ø 3.4 +0.1 0 7.62 2 x ø 1.1 ø 3.8 ø 3.1 +0.1 0 7.62 12 3 x ø 1.1 5 x ø 0.8 1M.305 +0.1 0 0° 4xø1 +0.1 0 ° 1M.304.•R 1) 1M.303 4 x ø 0.8 ø 2.5 +0.1 0 5.08 3 x ø 0.8 ø 2.3 90° 12 +0.1 0 4xø1 5.08 2 x ø 0.8 ø 2.2 4xø1 0M.304 4 x ø 0.6 ø 2.8 0M.303 +0.1 0 5.08 +0.1 0 3 x ø 0.6 0M.302 ø 1.35 90° 12 0° 4xø1 MM.304 4xø1 5.08 MM.303 For EGl , ECl and EDl models +0.1 0 ø 1.6 For HEl models +0.1 0 Note: 1) Special Mixed Multipole configurations, refer to page 27 for details. www.lemo.com 37 ® TM.325 4xø1 10°35’18’’ 5’’ ’3 4xø1 +0.1 0 16 ° 24 ° 45 13.97 120 ° ' °26 51 1' °5 13 13°51’ 51°25’30’’ 4xø1 +0.1 0 4xø1 6°55'30'' 68 x ø 0.8 ø 10.08 66 x ø 0.8 5M.114 10° 16°21’49’’ 0’’ 4’5 °2 12 ’’ ’49 21 9° ° 15° 4xø1 +0.1 0 5° 6°12’25’’ 8°10’55’’ 4xø1 +0.1 0 ° 45 45° 22 x ø 1.1 +0.1 0 22°30' 114 x ø 0.8 24° ø 20.7 20.32 ø 17.1 ø 9.9 ø 6.3 ø 13.5 ø 2.7 20.32 ø 20 ø 14 ø 6.6 +0.1 0 ø 10.4 ø3 44 x ø 0.8 12 0° 30 ° 16 ° 18 +0.1 0 18°57' +0.1 0 5M.366.•R 1) +0.1 0 16.51 ø15.5 ø8 ø11.75 ø 4.25 27° 41 ’30 16.51 ø15.3 ø 6.9 ø11.1 ø 2.8 36° +0.1 0 12.7 +0.1 0 27°41'30'' 55 x ø 0.8 +0.1 0 5M.366 9° ° 18 ° ’’ 18° ’ 4xø1 22°30' 48 x ø 0.8 6°40’ °20 13 12° 13.97 7°30’ ° 15 ø 11.64 ø 7.94 +0.1 0 LM.368 8°10'55'' '' '49 21 20.32 40 x ø 0.8 +0.1 0 ø 5.6 +0.1 0 LM.355 21 °1 0 9° 27°4 1'3 2 18° 12.7 ø 6.8 40 x ø 0.8 4xø1 5 '' ø 10.2 27° 41 '3 18° 9° ø 3.4 6 2'' 6' 1°2 +0.1 0 ø 4.24 4xø1 0° 4M.348 ø 11.9 4M.340 +0.1 0 ø 8.5 TM.340 32 x ø 0.8 +0.1 0 ø 5.2 25 x ø 0.8 2.6 ø19.84 12.7 ø 9.8 ø 5.8 10.16 ø9 2.2 4.45 ø 5.7 22° 71°51'52'' 3.23 +0.1 0 30 x ø 0.8 +0.1 0 ' 24° 30 ' 4xø1 11°15' ø 6.6 40° ø 10.2 +0.1 0 ø14.96 4xø1 11°15' TM.332 +0.1 0 22 °3 0 32°43'38 '' 36° ø3 3M.330 ø 1.9 ® + 0.1 0 40° Note: 1) Special Mixed Multipole configurations, refer to page 27 for details. 38 www.lemo.com ® ® Assembly instructions for plugs and sockets 2 1 2 1 FG● PH● PB● 1. Cable preparation L ± 0.5 1 T ± 0.2 First place the heatshrink boot ➀ over the cable. Strip the cable accor­ding to dimensions of the table, then widen the shield. S ± 0.5 Series L S T MM 14 9 3.0 0M to 5M 20 15 3.5 Note: dimensions are in mm. 2. Cable termination 2 Crimp 2 Crimp 2.1 With shielded cables, widen and pull the shield all the way to the back. Fix the appropriate positioner onto the crimping tool and set the selector to the number corresponding to the AWG of the conductor used as indicated on the positioner label. Fit the conductor into the contact ➁; make sure it is visible through the contact’s inspection hole. Slide the conductor-contact assembly into the open crimping tool; make sure that the contact is pushed fully into the positioner. Close the tool. Remove from crimping tool and check that conductor is secure in contact and shows in inspection hole. 2.2 Arrange the conductor-contact assemblies according to the markings, into the rear cable seal. Push them deeply into the insulator, using tweezers if necessary; check that all the contacts are correctly located in the insulator: 1) by verifying the alignment of the contacts at the front of the insulator and 2) by gently pulling on each conductor. Verification should also be made using the appropriate retention testing tool. 2.3 Bring the shield around the rear of connector. Secure it with a band-it tie-wrap (not furnished) to fix the shield in place. Cut off the possible shield surplus. Steel tie-wrap band (~3 mm wide) Steel tie-wrap band (~3 mm wide) Heat Heat 2.4 Put the heatshrink boot in place and heat gently until it retracts. www.lemo.com 39 ® ® Assembly instructions for plugs and sockets (with optional mold stop) 1 FG● PH● 1 PB● 1. Cable preparation L ± 0.5 T ± 0.2 Strip the cable accor­ding to dimensions of the table, then widen the shield. S ± 0.5 Series L S T MM 14 9 3.0 0M to 5M 20 15 3.5 Note: dimensions are in mm. 2. Cable termination 1 Crimp 1 Crimp 2.1 With shielded cables, widen and pull the shield all the way to the back. Fix the appropriate positioner onto the crimping tool and set the selector to the number corresponding to the AWG of the conductor used as indicated on the positioner label. Fit the conductor into the contact ➀; make sure it is visible through the contact’s inspection hole. Slide the conductor-contact assembly into the open crimping tool; make sure that the contact is pushed fully into the positioner. Close the tool. Remove from crimping tool and check that conductor is secure in contact and shows in inspection hole. 2.2 Arrange the conductor-contact assemblies according to the markings, into the rear cable seal. Push them deeply into the insulator, using tweezers if necessary; check that all the contacts are correctly located in the insulator: 1) by verifying the alignment of the contacts at the front of the insulator and 2) by gently pulling on each conductor. Verification should also be made using the appropriate retention testing tool. Steel tie-wrap band (~3 mm wide) 2.3 Bring the shield around the rear of connector until the mold stop. Secure it with a band-it tie-wrap (not furnished) to fix the shield in place. Cut off the possible shield surplus. Steel tie-wrap band (~3 mm wide) Overmolding 2.4 Custom overmold cable assembly. Overmolding 40 www.lemo.com ® ® Product safety notice PLEASE READ AND FOLLOW ALL INSTUCTIONS CAREFULLY AND CONSULT ALL RELEVENT NATIONAL AND INTERNATIONAL SAFETY REGULATIONS FOR YOUR APPLICATION. IMPROPER HANDLING, CABLE ASSEMBLY, OR WRONG USE OF CONNECTORS CAN RESULT IN HAZARDOUS SITUATIONS. 1. SHOCK AND FIRE HAZARD Incorrect wiring, the use of damaged components, presence of foreign objects (such as metal debris), and / or residue (such as cleaning fluids), can result in short circuits, overheating, and / or risk of electric shock. Mated components should never be disconnected while live as this may result in an exposed electric arc and local overheating, resulting in possible damage to components. 2. HANDLING Connectors and their components should be visually inspected for damage prior to installation and assembly. Suspect components should be rejected or returned to the factory for verification. Connector assembly and installation should only be carried out by properly trained personnel. Proper tools must be used during installation and / or assembly in order to obtain safe and reliable performance. 3. USE Connectors with exposed contacts should never be live (or on the current supply side of a circuit). Under general conditions voltages above 30 VAC and 42 VDC are considered hazardous and proper measures should be taken to eliminate all risk of transmission of such voltages to any exposed metal part of the connector. 4. TEST AND OPERATING VOLTAGES The maximum admissible operating voltage depends upon the national or international standards in force for the application in question. Air and creepage distances impact the operating voltage; reference values are indicated in the catalog however these may be influenced by PC board design and / or wiring harnesses. The test voltage indicated in the catalog is 75% of the mean breakdown voltage; the test is applied at 500 V/s and the test duration is 1 minute. 5. CE MARKING CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. 6. PRODUCT IMPROVEMENTS The LEMO Group reserves the right to modify and improve to our products or specifications without providing prior notification. 7. WARNING (Prop 65 State of California) Proposition 65 requires businesses to provide warnings to Californians about significant exposures to chemicals that cause cancer, birth defects or other reproductive harm. LEMO products are exempt from proposition 65 warnings because they are manufactured, marketed, and sold solely for commercial and industrial use. For further information, please visit https://www.lemo.com/quality/LEMO-Prop-65-compliance-declaration.pdf. Disclaimers LEMO works constantly to improve the quality of its products; the information and illustrations figuring in this document may therefore vary and are not binding. In any case, LEMO makes no specific warranty of merchantability, fitness for a particular purpose, third party components as such or included in assembly, non-infringement, title, accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO component. In no event shall LEMO, its affiliates, officers, agents or employees be liable for any incidental, indirect, special or consequential damages in connection with the products or services provided by LEMO, including (without limitation) loss of profits or revenues, interruption of business, loss of use of the products or any associated equipment, materials, components or products, damages to associated equipment or in combination with other components, materials. Reproduction of significant portions of LEMO information in LEMO data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. LEMO is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. No reproduction or use without express permission of editorial or pictorial content, in any manner. LEMO SA reserves the right to modify and improve specifications, at all times, without any notification. www.lemo.com 41 LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. +41 21 695 16 00 - e-mail: info@lemo.com SUBSIDIARIES AUSTRIA LEMO Elektronik GesmbH Lemböckgasse 49/E6-3 1230 Wien Tel: +43 1 914 23 20 0 Fax:+43 1 914 23 20 11 salesAT@lemo.com BRAZIL LEMO Latin America Ltda Av. Dr. Adhemar de Barros, 566 – Sala 1407, Vila Adyana CEP: 12245-011 São José dos Campos - SP - Brazil Tel: +55 11 94242 4293 info-la@lemo.com CANADA LEMO Canada Inc 44 East Beaver Creek Road, unit 20 Richmond Hill, Ontario L4B 1G8 Tel: +1 905 889 56 78 Fax: +1 905 889 49 70 info-canada@lemo.com CHINA / HONG KONG LEMO Electronics (Shanghai) Co., Ltd First Floor, Block E, 18 Jindian Road, Pudong Shanghai, China, 201206 Tel: +86 21 5899 7721 Fax: +86 21 5899 7727 cn.sales@lemo.com DENMARK LEMO Denmark A/S Mandal Allé 16A 5500 Middelfart Tel: +45 45 20 44 00 Fax: +45 45 20 44 01 info-dk@lemo.com FRANCE LEMO France Sàrl 24/28 Avenue Graham Bell Bâtiment Balthus 4 Bussy Saint Georges 77607 Marne la Vallée Cedex 3 Tel: +33 1 60 94 60 94 Fax: +33 1 60 94 60 90 info-fr@lemo.com GERMANY LEMO Elektronik GmbH Hanns-Schwindt-Str. 6 81829 München Tel: +49 89 42 77 03 Fax: +49 89 420 21 92 info@lemo.de HUNGARY REDEL Elektronika Kft Nagysándor József u. 6-12 1201 Budapest Tel: +36 1 421 47 10 Fax: +36 1 421 47 57 info-hu@lemo.com ITALY LEMO Italia srl Viale Lunigiana 25 20125 Milano Tel: +39 02 66 71 10 46 Fax: +39 02 37 90 80 46 sales.it@lemo.com JAPAN LEMO Japan Ltd 2-7-22, Mita, Minato-ku, Tokyo, 108-0073 Tel: +81 3 54 46 55 10 Fax: +81 3 54 46 55 11 info-jp@lemo.com LEMO NETHERLANDS / BELGIUM LEMO Connectors Nederland B.V. Jacques Meuwissenweg 6 2031 AD Haarlem Tel. +31 23 206 07 01 info-nl@lemo.com NORWAY / ICELAND LEMO Norway A/S Soerumsandvegen 69, 1920 Soerumsand Tel: +47 22 91 70 40 Fax: +47 22 91 70 41 info-no@lemo.com SINGAPORE LEMO Asia Pte Ltd 4 Leng Kee Road, #06-09 SiS Building Singapore 159088 Tel: +65 6476 0672 Fax: +65 6474 0672 sg.sales@lemo.com SPAIN / PORTUGAL IBERLEMO SAU Brasil, 45, 08402 Granollers Barcelona Tel: +34 93 860 44 20 Fax: +34 93 879 10 77 info-es@lemo.com SWEDEN / FINLAND LEMO Nordic AB Gunnebogatan 30, Box 8201 163 08 Spånga Tel: +46 8 635 60 60 Fax: +46 8 635 60 61 info-se@lemo.com SWITZERLAND LEMO Verkauf AG Grundstrasse 22 B, 6343 Rotkreuz Tel: +41 41 790 49 40 ch.sales@lemo.com TAIWAN TAOYUAN TAIWAN Tel: +886 967 132 824 speng@lemo.com UNITED ARAB EMIRATES LEMO Middle East Connectors LLC Concorde Tower 11th Floor, Office 1102, Dubai Media City, P.O. Box 449849 Dubai, United Arab Emirates Tel: +971 4 568 1904 info-me@lemo.com UNITED KINGDOM LEMO UK Ltd 12-20 North Street, Worthing, West Sussex, BN11 1DU Tel: +44 1903 23 45 43 lemouk@lemo.com USA LEMO USA Inc P.O. Box 2408 Rohnert Park, CA 94927-2408 Tel: +1 707 578 88 11 +1 800 444 53 66 Fax: +1 707 578 08 69 info-US@lemo.com DISTRIBUTORS ARGENTINA, AUSTRALIA, BRAZIL, CHILE, COLOMBIA, CZECH REPUBLIC, GREECE, INDIA, ISRAEL, NEW ZEALAND, PERU, POLAND, RUSSIA, SOUTH AFRICA, SOUTH KOREA, TURKEY, UKRAINE www.lemo.com CAT.MM.LEN.P0811, © LEMO / Data subject to change, printed in Switzerland, updated November 2021 LEMO
FGN.2M.319.XLC 价格&库存
很抱歉,暂时无法提供与“FGN.2M.319.XLC”相匹配的价格&库存,您可以联系我们找货
