4 Holes
A
B
C
D
E
F
G
H
E.2; Validé
MALE CONNECTOR
FEMALE CONNECTOR
3,2 0,1
8
8
F Maxi
INSERT
Thread
0.15
0.25
0.25
A
B
7
ØE
SHELL
SOCKET
7
PIN
6
6
D
0.15
C Maxi
B
0.25
A
0.25
UTS0 14
5
SHELL SIZE
A
0.25
B
0.25
C Maxi
D
0.15
ØE
0.15
F Maxi
G
0.25
H
0.10
8
21.00
15.10
21.50
2.30
11.90
11.70
15.10
12.50
10
23.80
18.30
21.50
2.30
14.90
11.70
18.30
15.10
12
26.20
20.60
21.50
2.30
18.95
11.70
20.60
18.20
4
14
28.60
23.00
21.50
2.30
22.15
11.70
23.00
21.40
E 12 P
XX
5
Square flange receptacle UTS
Thread
Shell size
E = Handsolder contacts
Insert arrangement
(See table)
P = Male contact
S = Female contact
Orientations
Normal (no digit), W, X, Y, Z = different orientations
7/16 28 UNEF
Class 2A
9/16 24 UNEF
Class 2A
11/16 24 UNEF
Class 2A
13/16 20 UNEF
Class 2A
4
Specification
MATERIAL :
3
3
Shell:PBT UL94 V-0 Black color
Insert:Polychloroprene
Seal gasket :Sealing IP68/69K : Silicone
O'seal : Nitril
Contact: brass + gold plated
PANEL CUT OUT
Country
FR
H
0.25
0.10
E
02/11/2017
ISS
DATE
Designed by:
G
2
Operating temperature:-40 C up to 105 C
Insulation resistance:5000 M min
Test potential:1500Vrms for #20 layout
Corrosion salt spray:500 hours
Durability:250 matings and unmatings
Sealing in mated and unmated conditions:
-IP68 1 bar during 1 week : immersion under 10 m of water.
(IEC 60529)
-IP69K : exposure to high pressure water of cleaning
equipement(DIN 40050)
TITLE
Scale
3/1
1
NOTE:
Updating shell material
21774A
Latest modification - by:
SORIN V.
Date:
COURTOIS L.
26/10/07
G
SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products
which does not comply with the Specifications issued by either of the Parties or by a third party
(professional recommendation, technical notice.)
F
E
D
FORMAT
A2
C
2
MOD N
CUSTOMER DRAWING
SQUARE FLANGE RECEPTACLE
UTS HI SEAL
General linear
Tolerances:
0.1
WWW.SOURIAU.COM
Insert arrangements : refer to C144-UTS1-A
H
NOT LISTED
P/N : SEE TABLE
3,2 0,1
PERFORMANCE CHARACTERISTICS :
Jurisdiction & Control List
NPRDS / PROJECT
UTS
This document is the property of
SOURIAU
It must not be reproduced or
communicated without permission
SOURIAU DRG N°
C044-UTS1-A
B
SHEET
1/1
A
1
很抱歉,暂时无法提供与“UTS08E2S”相匹配的价格&库存,您可以联系我们找货
