Additional Resources:
Product Page
3D Model
date
02/19/2020
page
1 of 3
SERIES: SD-LP │ DESCRIPTION: STANDARD DIN CONNECTOR
FEATURES
• locking
• metal bushing
• strain relief
RoHS
PART NUMBER KEY
SD - X X LP
Base Number
Pin Options
30 = 3 pins
40 = 4 pins
50 = 5 pins
60 = 6 pins
70 = 7 pins
80 = 8 pins
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
max
100
units
Vac
rated input current
2
A
contact resistance
mΩ
1000
Vac
85
°C
insulation resistance
at 500 Vdc
voltage withstand
at 50/60Hz for 1 minute
100
operating temperature
RoHS
-40
yes
cuidevices.com
MΩ
Product Page
3D Model
CUI Devices │ SERIES: SD-LP │ DESCRIPTION: STANDARD DIN CONNECTOR
date 02/19/2020 │ page 2 of 3
MECHANICAL DRAWINGS
units: mm[inches]
TOLERANCE: ±0.2mm
MATERIAL
PLATING
contact terminals
brass
silver
clip plate
cold rolled steel
nickel
body/nut
zinc alloy
nickel
screw
steel
nickel
body
zinc alloy
nickel
strain relief
PVC
plastic core
nylon
56.8 2.236
36.0 1.417
M16
9.0 0.354
19.0 0.747
13.3 0.524
8.0 0.315
6.0 0.236
SD-30LP
SD-40LP
1.45 0.057
(3 PLCS)
SD-50LP
1.45 0.057
(5 PLCS)
1.45 0.057
(4 PLCS)
45°
72°
7.0 0.276
7.0 0.276
SD-60LP
7.0 0.276
SD-70LP
1.45 0.057
(6 PLCS)
60°
SD-80LP
1.45 0.057
(7 PLCS)
45°
0.7 0.029
1.45 0.057
(8 PLCS)
45°
7.0 0.276
7.0 0.276
cuidevices.com
7.0 0.276
Product Page
3D Model
date 02/19/2020 │ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
02/07/2012
1.02
updated datasheet
11/24/2015
1.03
updated datasheet
08/25/2017
brand update
02/19/2020
1.04
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SD-30LP”相匹配的价格&库存,您可以联系我们找货
