FLEXIBLE
POWER SYSTEMS
FEATURES & BENEFITS
• Board-to-board and discrete wire cable systems
• Power Mate® system with polarized guide posts
• Mini Mate® system with reliable Tiger Buy™ contacts
• Individually shrouded contacts
• Elevated stack heights
• Optional polarization
• Vertical and right-angle for parallel, perpendicular
and coplanar applications
• Rugged metal or plastic latching systems
• Cable components and tooling available
Selectively loading contacts achieves
customer specific creepage and
clearance requrements.
KEY SPECIFICATIONS
SERIES
IPT1/IPS1
IPBT/IPBS
HPM/HPW/HPF
FWJ/HFWJ/FHP
(2.54 mm) .100"
(4.19 mm) .165"
(5.08 mm) .200"
(3.96 mm) .156"
CCC (1 PIN)*
5.9 A
10.3 A /pin (2 pins powered)
16.6 A
13.1 A
CCC (2 PINS)*
4.8 A
8.4 A/pin (4 pins powered)
14.4 A
11.2 A
CCC (3 PINS)*
4.1 A
7.6 A/pin (6 pins powered)
13.2 A
10.3 A
CREEPAGE
(2.54 mm) .100"
(4.27 mm) .168"
(3.94 mm) .155"
(3.92 mm) .154"
CLEARANCE
(1.91 mm) .075"
(3.05 mm) .120"
(3.94 mm) .155"
(2.82 mm) .111"
VAC
775
400
850
600
VDC
1095
565
1200
845
1000 (MFG Tested)
100
100
100
PITCH
CYCLES
F-221
samtec.com/minimate or samtec.com/powermate
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(2.54 mm) .100" PITCH • SHROUDED POWER CONNECTOR SET
IPT1
NO. PINS
PER ROW
1
05
LEAD STYLE
D
–L
Specify LEAD
STYLE from
chart
10
PLATING
OPTION
= Alignment Pin
(–VS only) (N/A with –LC)
–LC
–RA
= Locking Clip
(Manual placement required)
(–VS only) (N/A with –A)
= Right-angle
–VS
25
OTHER OPTIONS
–A
Requires -01
Lead Style
(Leave blank for
Through-hole)
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
15
TAIL
OPTION
–K
= Surface Mount
(Standard Sizes)
= (6.00 mm) .236" DIA
Polyimide film
Pick & Place Pad
(–VS only)
–TR
= Tape & Reel
(–VS only)
IPT1
–FR
No. of positions x (2.54) .100
+ (0.51) .020
Board Mates:
IPS1
(5.08)
.200
Through-hole
= Full Reel Tape & Reel
(must order max. quantity
per reel; contact Samtec
for quantity breaks)
(-VS only)
(7.16)
.282
A
Surface Mount
LEAD
STYLE
-VS
IPS1
NO. PINS
PER ROW
1
01
05
PLATING
OPTION
D
–L
10
15
(6.35) .250
(6.35) .250
N/A
–02
(14.00) .551
(9.30) .366
(2.64) .104
–03
(16.00) .630
(11.30) .445
(2.16) .085
–04
(17.00) .669
(12.30) .484
(2.69) .106
–05
(19.00) .748
(14.30) .563
(2.46) .097
–06
(20.00) .787
(15.30) .602
(2.35) .093
–07
(25.00) .984
(20.30) .799
(2.31) .091
–08
(30.00) 1.181
(25.30) .996
(2.39) .094
–09
(35.00) 1.378
(30.30) 1.193
(2.46) .097
TAIL
OPTION
–RA
= Right-angle
–VS
+ (0.38) .015
(Standard Sizes)
= Surface Mount
Board Mates:
IPT1
Through-hole
–LC
= Locking Clip (Manual
placement required)
(–VS only)
–K
= (5.50 mm) .217" DIA
Polyimide film
Pick & Place Pad
(–VS only)
= Tape & Reel
(–VS only)
Surface Mount
–FR
(-VS only)
(7.87)
.310
(8.51)
.335
Note:
Some lengths, styles and
options are non-standard,
non-returnable.
OTHER OPTIONS
–TR
(4.95)
.195
IPS1
(2.16) .085
(11.05) .435
(13.59) .535
Leave blank for
Through-hole
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
B
–01
-RA
A
-01-VS
A
B
MATED
HEIGHT
-VS
-RA
View complete specifications at: samtec.com?IPT1 & samtec.com?IPS1
samtec.com/minimate
F-221
很抱歉,暂时无法提供与“IPT1-118-01-S-D-RA”相匹配的价格&库存,您可以联系我们找货
