DF1EC-10P-2.5DSA(35) 数据手册
2.5mm Pitch Connectors for Full Lock and Discrete Wire Connection
DF1E Series
UL, C-UL Listed
Full lock function
added
Inner-lock system
full lock mechanism
Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Mis-insertion
prevention
Fig.1
■Features
1. Full Lock Function Added
Double lock
engaged
The inner lock system adopts a full lock mechanism.
This mechanism prevents disengagement to occur due to
an unexpected external shock. (Fig.1)
Double lock
engaged
2. Increase in Crimping Contact Fixation Force and
Semi-insertion Prevention
The double lock is activated for the use method to give a
stress to the cable, to increase crimping contact fixation
force, and to prevent the semi-insertion of the crimping
contact. (Fig.2)
3. Mold Lance Adopted
Since the contact lance may be deformed involving in the
contact after the crimping process, the mold lance has been
adopted.
4. Mis-insertion Prevention
Fig.2
Equipped with the mechanism to completely prevent reverse
insertion and insertion between dissimilar contacts. (Fig.1)
5. Means to Prevent Solder Crack
The glass enforcement resin is adopted for the pin header to
prevent a solder crack to occur due to heat compression.
6. Correspond to Potting
Corresponding to potting, the pin header is provided for
product variations.
Corresponding to potting up to 8mm and mounting height
19.8mm (no retainer), the low profile is achieved.
8. Various Applications
With the same series, various applications can
be used for the board solder dip type and
in-line.
9. Listed by UL, C-UL
7. Production Facility Cost Reduction
The female crimping contact uses the DF1B series crimping
contact, which has been conventionally marketed.
Investment for new facilities isn't needed. However, if the
retainer is installed in the cable with 22 AWG or more wire,
use the DF1E crimping contact. The female crimping
contact for in-line is used together with the DF1B applicator.
Therefore, no investment is needed for new facilities.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2021.6②
1
DF1E Series●2.5mm Pitch Connectors for Full Lock and Discrete Wire Connection
■Products Specifications
Rating
Current rating (Note 1)
20 to 24 AWG:3A/pin
26 AWG:2A/pin
28 AWG:1A/pin
30 AWG:0.5A/pin
Voltage rating 250V AC/DC
Operating Temperature :
Storage Temperature Range :
-35 to +85℃ (Note 2)
-10 to +60℃ (Note 4)
Operating Moisture Range :
Storage Moisture Range :
40 to 80% (Note 3)
40 to 70% (Notes 4)
■UL/C-UL File No. and Recognition No.
UL
: E52653
C-UL : E52653
UL, C-UL Rating
20 to 22 AWG : 3A/pin
Current rating
Rating
24 to 28 AWG : 1A/pin
30 AWG : 0.5A/pin
29.9V AC/DC
Voltage rating
Item
Specification
Condition
1. Contact Resistance
30mΩ max.
Measured at 20mV max. and 1mA
2. Insulation Resistance
1000MΩ min.
500V DC
3. Withstanding voltage
No flashover or insulation breakdown.
650V AC/1 minute
4. Durability (Mating/un-mating)
30mΩ max
Tin plated : 30 cycles, Gold plated : 50 cycles
5. Vibration
No electrical discontinuity of 1µs or more
6. Shock
7. Humidity (Steady state)
8. Temperature Cycle
30mΩ max
30mΩ max.
No deformation of components
affecting performance.
9. Resistance to Soldering heat
Note
Note
Note
Note
Note
1
2
3
4
5
Frequency : 10 to 55 Hz, single amplitude of 0.75 mm,
2 hours in each of the 3 directions.
Acceleration of 490 m/s2, 11 ms duration, sine half-wave
waveform, 3 cycles in each of the 3 axis
96 hours at temperature of 40±2ç and humidity of 90% to 95%
(-55ç : 30 minutes-> 5 to 35ç : 5 minutes-> 85ç : 30 minutes-> 5 to 35ç : 5 minutes) 5 cicles
Flow : 260ç for 10 seconds
Manual soldering : 300ç for 3 seconds
Current rating of header is 3A.
Includes temperature rise caused by current flow.
Use without condensation on parts.
Applied for the product unused and packaged.
Information contained in this catalog represents general requirements for this Series.
Contact us for the drawings and specifications for a specific part number shown.
■Materials / Finish
Product
Part
Material
Finish
Remarks
Socket
Insulator
Polyamide
White
UL94V-0
Insulator
Polyamide
Beige
UL94V-0
Contact
Brass
Tin plated or Gold plated
In-line Plug
Insulator
Polyamide
White
UL94V-0
Retainer
Insulator
Polyamide
Black
UL94V-0
Crimping contact
Contact
Phosphor copper
Header
2
RoHS2
Yes
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Pin Header
DF1E C - * P - 2.5 DSA
q
w
e
r
t
y
q Series Name : DF1E
w Hold Types
e Number of Contacts : 2 to 15 contacts
(Note 1)
Blank : Right Angle Pin Header r Connector Type
C
: Straight Pin Header
G
: Straight Pin Header for t Contact Pitch : 2.5mm
P : Pin Header
y Form type
Potting
DSA : Straight Type
DS : Right Angle Type
Note 1 : Straight pin header for potting has 2 to 11 contacts.
●Socket
DF1E - * S - 2.5 C
q
w
e
r
w Number of Contacts : 2 to 15 contacts
t
e Connector type
S : Socket
r Contact Pitch : 2.5mm
t Form Type
C : Crimping socket
●In-line Plug
DF1E A - * EP - 2.5 C
q
w
e
r
t
y
e Number of Contacts : 2 to 10 contacts
w In-line Plug type
r EP : In-line plug
Blank : With Panel mount Lock
A : Without Panel mount Lock
y Form Type
C : Crimping socket
●Crimping Contact
q Series Name :
DF1E - ** SCF
q
w
e
w Applicable Cable Size
Socket side : DF1B (Note 1)
2022 : 20 to 22 AWG
DF1E (Note 1)
2428 : 24 to 28 AWG
Plug side
: DF1E
30
: 30 AWG
e Packaging Type
SCF : Female contact/reel/Tin plated
SCFA : Female contact/reel/Gold plated
SC : Female contact/pack/Tin plated
SCA : Female contact/pack/Gold plated
PCF : Male contact/reel/Tin plated
PCFA : Male contact/reel/Gold plated
PC : Male contact/pack/Tin plated
PCA : Male contact/pack/Gold plated
Note 1 : When the retainer is used, use DF1E-2022SC(F)(A),
DF1B-2428SC(F)(A), and DF1B-30SC(F)(A) contacts.
Note 1 : When no retainer is used, all DF1B-**SC(F)(A) and
DF1E-2022SC(F)(A) contacts can be used.
●Retainer
DF1E - * RS/P - 2.5
q
w
e
r
w Number of Contacts : 2 to 10 contacts
e Connector Type
RS/P : Retainer
Commonly used for socket and in-line plug
r Contacts Pitch : 2.5mm
3
BApplication Pattern
Pin Header
●Straight Type
●Straight Potting Type
●Right Angle Type
Socket
In-line Plug
●In-line Plug (Panel Mount Lock Type)
●In-line Plug
Retainer
Photo : Contact Inserted
Photo: Contact Inserted
BMated Dimensions
●Standard Header
8.5
DF1E _ * S _ 2.5 C
DF1E _ * RS / P _ 2.5
18.8
DF1E# _ * P _ 2.5 DSA
17.3
DF1E _ * P _ 2.5 DS (**)
8.5
14.3
15.8
DF1E _ * S _ 2.5 C
3.7
3
10.8
14.3
●Header for Potting
8
DF1E _ * S _ 2.5 C
11.7
8 MAX
19.8
21.3
Potting Resin
3.2
●Panel Mounting Lock In-line Plug
●In-line Plug
25.3
25.3
17
DF1E _ * S _ 2.5 C
DF1E _ * S _ 2.5 C
DF1EA _ * EP _ 2.5 C
DF1E _ * EP _ 2.5 C
15.5
22.3
4
9
9
8.1
Panel
22.3
■Right Angle Pin Header
Contact
No. mark
10
Mold Cavity
No. mark
5.9
A
2.9
0.5
8
6.95
5.4
M 0.64
P=2.5
A
Contact
No.1 indicated
8.3
4.5
10.8
13.8
B
3.2
Note 2
Part No.
HRS No.
No. of Contacts
A
B
DF1E-02P-2.5DS(**)
541-0985-0 **
2
02.5
07.5
DF1E-03P-2.5DS(**)
541-0986-3 **
3
05.0
10.0
DF1E-04P-2.5DS(**)
541-0987-6 **
4
07.5
12.5
DF1E-05P-2.5DS(**)
541-0988-9 **
5
10.0
15.0
DF1E-06P-2.5DS(**)
541-0989-1 **
6
12.5
17.5
DF1E-07P-2.5DS(**)
541-0990-0 **
7
15.0
20.0
DF1E-08P-2.5DS(**)
541-0991-3 **
8
17.5
22.5
DF1E-09P-2.5DS(**)
541-0992-6 **
9
20.0
25.0
DF1E-10P-2.5DS(**)
541-0993-9 **
10
22.5
27.5
DF1E-11P-2.5DS(**)
541-0994-1 **
11
25.0
30.0
DF1E-12P-2.5DS(**)
541-0995-4 **
12
27.5
32.5
DF1E-13P-2.5DS(**)
541-0996-7 **
13
30.0
35.0
DF1E-14P-2.5DS(**)
541-0997-0 **
14
32.5
37.5
DF1E-15P-2.5DS(**)
541-0998-2 **
15
35.0
40.0
[Specific No.] –* *, (* *)
(36) : Gold plated
(35) : Tin plated
Note 1 : A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the products per bag. However, the
quantity for delivery will be changed according to the Specific No.
Note 2 : The 2 to 4 contacts differ in two convex portions from those in above figures. The 2 and 3 contacts are not contained,
but the 4 contact connector is contained in the center at one point.
Note 3 : Styles of 2 to 4 contact connectors partially differ from those in above figures.
● PCB mounting pattern (Board Thickness t = 1.6 ± 0.1)
A±0.1
P = 2.5±0.05
Ø1
.1
5
5.4
Contact
No. mark
5.9
10
Mold Cavity
No. mark
A
0.5
8
6.95
■Straight Pin Header
P=2.5
A
Contact
No.1 indicated
3.6
10.8
8.3
4.5
B
M 0.64
3.2
Note 2
Part No.
HRS No.
No. of Contacts
A
B
DF1EC-02P-2.5DSA(**)
541-0867-4 **
2
02.5
07.5
DF1EC-03P-2.5DSA(**)
541-0868-7 **
3
05.0
10.0
DF1EC-04P-2.5DSA(**)
541-0869-0 **
4
07.5
12.5
DF1EC-05P-2.5DSA(**)
541-0870-9 **
5
10.0
15.0
DF1EC-06P-2.5DSA(**)
541-0871-1 **
6
12.5
17.5
DF1EC-07P-2.5DSA(**)
541-0872-4 **
7
15.0
20.0
DF1EC-08P-2.5DSA(**)
541-0873-7 **
8
17.5
22.5
DF1EC-09P-2.5DSA(**)
541-0874-0 **
9
20.0
25.0
DF1EC-10P-2.5DSA(**)
541-0875-2 **
10
22.5
27.5
DF1EC-11P-2.5DSA(**)
541-0876-5 **
11
25.0
30.0
DF1EC-12P-2.5DSA(**)
541-0877-8 **
12
27.5
32.5
DF1EC-13P-2.5DSA(**)
541-0878-0 **
13
30.0
35.0
DF1EC-14P-2.5DSA(**)
541-0879-3 **
14
32.5
37.5
DF1EC-15P-2.5DSA(**)
541-0880-2 **
15
35.0
40.0
(36) : Gold plated
(35) : Tin plated
but the 2 and 3 contacts are not contained, and 4 contact is in the center at one point.
Note 3 : Styles of 2 to 4 contacts partially differ from those in above figures.
A±0.1
P = 2.5±0.05
Ø1
.1
6
5.4
10
5.9
C
6.95
■Straight Pin Header for Potting
Contact
No. mark
Mold Cavity
No. mark
A
P=2.5
A
B
8.3
16.3
3
M 0.64
3.2
4.5
Contact
No.1 indicated
Note 2
Note 2
Part No.
HRS No.
No. of Contacts
A
B
C
DF1EG-02P-2.5DSA(**)
541-0923-3 **
2
02.5
07.5
8.0
DF1EG-03P-2.5DSA(**)
541-0924-6 **
3
05.0
10.0
8.0
DF1EG-04P-2.5DSA(**)
541-0925-9 **
4
07.5
12.5
8.0
DF1EG-05P-2.5DSA(**)
541-0926-1 **
5
10.0
15.0
7.8
DF1EG-06P-2.5DSA(**)
541-0927-4 **
6
12.5
17.5
7.8
DF1EG-07P-2.5DSA(**)
541-0928-7 **
7
15.0
20.0
7.8
DF1EG-08P-2.5DSA(**)
541-0929-0 **
8
17.5
22.5
7.8
DF1EG-09P-2.5DSA(**)
541-0930-9 **
9
20.0
25.0
7.8
DF1EG-10P-2.5DSA(**)
541-0931-1 **
10
22.5
27.5
7.8
DF1EG-11P-2.5DSA(**)
541-0932-4 **
11
25.0
30.0
7.8
(35) : Tin plated
Note 1 : A packaging quantity is delivered by the bag unit (100 pcs.). If needed, please order the product per bag. However, the
quantity for delivery will be changed according to spec number.
Note 2 : The 2 to 6 and 9 to 10 contact connectors differ in two convex portions from those in above figures. The 2 to 5 and 9 to
10 contacts are not contained, but the 6 contact is bonded to the convex portion at both ends.
Note 3 : Styles of 2 to 4 contact may partially differ from the above figures.
A±0.1
P = 2.5±0.05
Ø1
.1
7
■In-line Plug (Panel Mount Lock Type)
2.8
A
0.9
10
A
6.9
8.1
2.8
B
P=2.5 Mold Cavity
No. mark
Contact No. mark
Contact
No.1 indicated
12
18.8
C
10
Contact
No. mark
9
7
5
3
Contact
No. mark
Note 2
Photo: Contact Inserted.
1
Note 3
Part No.
HRS No.
No. of Contacts
A
B
C
D
E
DF1E-02EP-2.5C
541-0943 - 0
2
8.0
2.5
15.0
8.4
11.9
DF1E-03EP-2.5C
541-0944 - 3
3
10.5
5.0
17.5
10.9
14.4
DF1E-04EP-2.5C
541-0945 - 6
4
13.0
7.5
20.0
13.4
16.9
DF1E-05EP-2.5C
541-0946 - 9
5
15.5
10.0
22.5
15.9
19.4
DF1E-06EP-2.5C
541-0947 - 1
6
18.0
12.5
25.0
18.4
21.9
DF1E-07EP-2.5C
541-0948 - 4
7
20.5
15.0
27.5
20.9
24.4
DF1E-08EP-2.5C
541-0949 - 7
8
23.0
17.5
30.0
23.4
26.9
DF1E-09EP-2.5C
541-0950 - 6
9
25.5
20.0
32.5
25.9
29.4
DF1E-10EP-2.5C
541-0951 - 9
10
28.0
22.5
35.0
28.4
31.9
Note 2 : In regard to 2 to 5 contacts, the retainer fixed convex portions are located at both ends.
Note 3 : In regard to 2 to 7 contacts, 2 convex portions are different from those in the above figures.
Note 4 : Use the no radius side at the panel edge in the looking area.
Note 5 : Panel fixation is loosened. (May be enlarged according to the panel board thickness.)
Note 6 : Styles of 2 to 4 contact partially differ from those in the above figures.
* Refer to page 11 for the retainer.
● Panel Cutout
(E+X)
1.0
0.9 to 1.2
0.5
0.7 to 0.8
0.0
Panel
8.4 +0.1
1.3 to 1.6
4.2±0.05
1.7 to 2.0
+0.1
X
5.8 +0.2
Panel Thickness
+0.1
D
+0.1
Note 4
■In-line Plug
A
B
0.9
P=2.5
Mold Cavity
No. mark
Contact No. mark
A
6.9
8.1
10
Contact
No.1 indicated
18.8
10
9
7
5
1
3
Contact
No. mark
Note 2
Contact
No. mark
Note 3
Part No.
HRS No.
No. of Contacts
A
B
DF1EA-02EP-2.5C
541-0957-5
2
08.0
02.5
DF1EA-03EP-2.5C
541-0958-8
3
10.5
05.0
DF1EA-04EP-2.5C
541-0959-0
4
13.0
07.5
DF1EA-05EP-2.5C
541-0960-0
5
15.5
10.0
DF1EA-06EP-2.5C
541-0961-2
6
18.0
12.5
DF1EA-07EP-2.5C
541-0962-5
7
20.5
15.0
DF1EA-08EP-2.5C
541-0963-8
8
23.0
17.5
DF1EA-09EP-2.5C
541-0964-0
9
25.5
20.0
DF1EA-10EP-2.5C
541-0965-3
10
28.0
22.5
Note 3 : 2 to 7 contacts do not contain two convex portions, which is different from the above figure.
Note 4 : Styles of 2 to 4 contacts partially differ from the above figures.
* Refer to page 11 for retainer.
9
4.55
■Socket
P=2.5
A
B
C
8.5
11.8
Note 2
10
1
Contact
No.1 indicated
Contact
No. mark
7.55
A
Mold Cavity
No. mark
Note 3
Note 3
Note 4
Note 4
Part No.
HRS No.
No. of Contacts
A
B
C
DF1E-02S-2.5C
541-0811-0
2
02.5
08.0
05.4
DF1E-03S-2.5C
541-0812-2
3
05.0
10.5
07.9
DF1E-04S-2.5C
541-0813-5
4
07.5
13.0
10.4
DF1E-05S-2.5C
541-0814-8
5
10.0
15.5
12.9
DF1E-06S-2.5C
541-0815-0
6
12.5
18.0
15.4
DF1E-07S-2.5C
541-0816-3
7
15.0
20.5
17.9
DF1E-08S-2.5C
541-0817-6
8
17.5
23.0
20.4
DF1E-09S-2.5C
541-0818-9
9
20.0
25.5
22.9
DF1E-10S-2.5C
541-0819-1
10
22.5
28.0
25.4
DF1E-11S-2.5C
541-0820-0
11
25.0
30.5
27.9
DF1E-12S-2.5C
541-0821-3
12
27.5
33.0
30.4
DF1E-13S-2.5C
541-0822-6
13
30.0
35.5
32.9
DF1E-14S-2.5C
541-0823-9
14
32.5
38.0
35.4
DF1E-15S-2.5C
541-0824-1
15
35.0
40.5
37.9
Note 2 : The 2 contact connector is equipped with the convex portion to prevent false-insertion.
Note 3 : The 2 consult Has no wall on the locking side
Note 4 : The 2 to 5 contacts contain the retainer fixed convex portions at both ends.
10
■Retainer
A
1.9
B
1.7
P = 2.5
1.5
3.3
5.9
0.7
Note2
Note2
Contact No. mark
A10
Mold Cavity
No. mark
Part No.
HRS No.
No. of Contacts
A
B
DF1E-02RS/P-2.5
541-0971-6
2
08.0
02.5
DF1E-03RS/P-2.5
541-0972-9
3
10.5
05.0
DF1E-04RS/P-2.5
541-0973-1
4
13.0
07.5
DF1E-05RS/P-2.5
541-0974-4
5
15.5
10.0
DF1E-06RS/P-2.5
541-0975-7
6
18.0
12.5
DF1E-07RS/P-2.5
541-0976-0
7
20.5
15.0
DF1E-08RS/P-2.5
541-0977-2
8
23.0
17.5
DF1E-09RS/P-2.5
541-0978-5
9
25.5
20.0
DF1E-10RS/P-2.5
541-0979-8
10
28.0
22.5
Note 2 : The 2 to 4 contacts contain socket and plug fixed holes at both ends.
* This retainer can be used together with the socket and In-line plug.
11
■Plug Crimping Contact
0.68
2 2.4
1.2
18.9
13.9
0.64
●Reel Contact Applicable Tool : Applicator
Part No.
HRS No.
DF1E-2022PCF
541-0937-8
DF1E-2022PCFA
541-1003-0
DF1E-2428PCF
541-0939-3
DF1E-2428PCFA
541-1005-6
Applicable Cable (Tin Plated Annealing Copper Wire)
Purchase
Finish
Wire
Jacket
Unit
AWG
UL Style
Construction
Diameter
20 AWG
21/0.18
Tin plated
22 AWG
17/0.16
1.2 to 1.9mm
20 AWG
21/0.18
Gold plated
22 AWG
17/0.16
24 AWG
11/0.16
UL1007
10000
UL1061
26 AWG
7/0.16
Tin plated
28 AWG
7/0.127
0.9 to 1.5mm
24 AWG
11/0.16
26 AWG
7/0.16
Gold plated
28 AWG
7/0.127
Note : When using cables other than those specified, contact a Hirose sales representative.
●Loose Contact Applicable Tool : Manual Crimping Tool
Part No.
HRS No.
DF1E-2022PC
541-0938-0
DF1E-2022PCA
541-1004-3
DF1E-2428PC
541-0940-2
DF1E-2428PCA
541-1006-9
Purchase
Finish
Wire
Jacket
Unit
AWG
UL Style
Construction
Diameter
1.8mm
20 AWG
21/0.18
Tin plated
1.6mm
22 AWG
17/0.16
1.8mm
20 AWG
21/0.18
Gold plated
1.6mm
22 AWG
17/0.16
1.5mm
24 AWG
11/0.16
UL1007
100
1.3mm
26 AWG
7/0.16
Tin plated
1.2mm
28 AWG
7/0.127
1.5mm
24 AWG
11/0.16
1.3mm
26 AWG
7/0.16
Gold plated
1.2mm
28 AWG
7/0.127
Note : Only the above cables are suitable when using the manual crimping tool.
12
■Socket Crimping Contact
●DF1E-2022SCF (A)
●DF1B - * * * * SCF (A)
1.75
1.4
0.83
Applicable cable indicated
0.55
1.4 1.6
1
14
9.5
6.1
2.4 1.6
2.5
0.975
1.4
12.9
9.4
1.75
1.95
3.35
2.55
1.95
Part No.
HRS No.
DF1E-2022SCF
541-0999-5
DF1E-2022SCFA
541-1001-5
DF1B-2022SCF
541-0223-1
DF1B-2022SCFA
541-0662-1
DF1B-2428SCF
541-0678-1
DF1B-2428SCFA
541-0680-3
DF1B-30SCF
DF1B-30SCFA
541-0682-9
541-0684-4
Purchase
Finish
Wire
Jacket
Unit
AWG
UL Style
Construction
Diameter
20 AWG
21/0.18
1.2 to 1.9mm
Tin plated
22 AWG
17/0.16
20 AWG
21/0.18
1.2 to 1.9mm
Gold plated
22 AWG
17/0.16
20 AWG
21/0.18
1.2 to 1.9mm
Tin plated
22 AWG
17/0.16
20 AWG
21/0.18
1.2 to 1.9mm
Gold plated
22
AWG
17/0.16
UL1007
10000
UL1061
24 AWG
11/0.16
0.9 to 1.5mm
26 AWG
7/0.16
Tin plated
28 AWG
7/0.127
24 AWG
11/0.16
0.9 to 1.5mm
26 AWG
7/0.16
Gold plated
28 AWG
7/0.127
0.6 to 1.2mm
30 AWG
7/0.1
Tin plated
0.6 to 1.2mm
30 AWG
7/0.1
Gold plated
Part No.
HRS No.
DF1E-2022SC
541-1000-2
DF1E-2022SCA
541-1002-8
DF1B-2022SC
541-0224-4
DF1B-2022SCA
541-0663-4
DF1B-2428SC
541-0679-4
DF1B-2428SCA
541-0681-6
DF1B-30SC
DF1B-30SCA
541-0683-1
541-0685-7
Purchase
Finish
Wire
Jacket
Unit
AWG
UL Style
Construction
Diameter
1.8mm
20 AWG
21/0.18
Tin plated
1.6mm
22 AWG
17/0.16
1.8mm
20 AWG
21/0.18
Gold plated
1.6mm
22 AWG
17/0.16
1.8mm
20 AWG
21/0.18
Tin plated
1.6mm
22 AWG
17/0.16
1.8mm
20 AWG
21/0.18
Gold plated
1.6mm
22 AWG
17/0.16
UL1007
100
1.5mm
24 AWG
11/0.16
1.3mm
26 AWG
7/0.16
Tin plated
1.2mm
28 AWG
7/0.127
1.5mm
24 AWG
11/0.16
1.3mm
26 AWG
7/0.16
Gold plated
1.2mm
28 AWG
7/0.127
1.1mm
30 AWG
7/0.1
Tin plated
1.1mm
30 AWG
7/0.1
Gold plated
13
BCrimping Tools
Item
Part No.
HRS No.
AP105-DF1E-2022S
901-4561-0
AP105-DF1B-2022S
901-4510-9
AP105-DF1B-2428S
901-4518-0
AP105-DF1B-30S
901-4517-8
AP105-DF1B-2022P
901-4509-0
AP105-DF1B-2428P
901-4521-5
CM-105C
901-0001-0
Applicator
Main Press Unit
HT102/DF1E-2022S
550-0277-1
DF1B-TA2022SHC
550-0182-7
DF1B-TA2428SHC
550-0209-1
DF1B-TA30SHC
550-0211-3
Contact Extraction Tool
HT102/DF1BE-2022P
550-0278-4
HT102/DF1BE-2428P
550-0279-7
DF-C-PO(B)
550-0179-2
Applicable Contact
DF1E-2022SCF
DF1E-2022SCFA
DF1B-2022SCF
DF1B-2022SCFA
DF1B-2428SCF
DF1B-2428SCFA
DF1B-30SCF
DF1B-30SCFA
DF1E-2022PCF
DF1E-2022PCFA
DF1E-2428PCF
DF1E-2428PCFA
DF1E-2022SC
DF1E-2022SCA
DF1B-2022SC
DF1B-2022SCA
DF1B-2428SC
DF1B-2428SCA
DF1B-30SC
DF1B-30SCA
DF1E-2022PC
DF1E-2022PCA
DF1E-2428PC
DF1E-2428PCA
DF1E-2022SC(F)
(A)
DF1B- **** SC(F)
(A)
DF1E- **** PC(F)
(A)
Note 1 : Add " ◎ " to the last number of the product, in order to use DF1B series tools, which have been conventionally merchandized.
Note 2 : If any trouble has occurred due to other tools, which are not designated by Hirose, Hirose won't guarantee any products.
Note 3 : Please perform crimping work in accordance with the "Crimp Quality Standard" (ETAD-H0947-00, ETAD-H0949-00) and the "Crimp Condition Table".
Note.4 : Please contact a Hirose sales representative to request the tooth profile drawings when using other than tools specified by our company.
BCrimping Precautions
■Items Required Prior to Crimping
The work-related documents shown below are required before starting the harness assembly.
(The ● mark represents required documents.)
Please contact your Hirose sales representative if you do not have these documents.
Document Title
(1) Crimping Machine Main Unit
Instruction Manual
(2) Applicator Instruction Manual
(3) Applicator Spare Parts List
(4) Crimp Conditions
(5) Crimp Quality Standards
(6) Hand Tool Operating
Instructions
Description
Automatic Crimping Machine Hand Crimping Tool
Remarks
Bundled with purchase of
Explanation of main press
main press machine unit.
unit
Crimp Method
Applicator Installation Instruction
Crimp height, tensile strength
of applicator.
standard value
Various standards for
crimping conditions
Crimp method, crimp height and
tensile height standard value
of hand tool.
■Tools
・Use tools designated by Hirose when crimping.
・Crimping performed using tools other than those specified is outside the scope of warranty.
・The operating instructions are available for the crimping machine and the applicator. Be sure to carefully read
the operating instructions manual before beginning work.
■Applicable Cables
Check that the cables to be used are within the applicable range.
If you intend to use a cable other than those recommended, contact a sales representative.
[Precautions]
• Cables applicable to crimping connectors are tin-plated stranded soft-copper wire.
• Avoid crimping solid wire, wires with polyester threads or tin coated wires.
• Avoid crimping two cables together.
• The crimp height setting values (Note 1) may vary between tin-plated and gold-plated terminals even if the
same electric wires are used.
• The crimp height setting values (Note 1) may vary depending on the difference in the core wire configuration
even if the computed cross-sectional area is the same.
Note 1 : The crimp height is an important item that determines crimping quality. We execute crimping tests for
each electric wire to ensure the optimal value for the crimp height with high precision, thereby ensuring
optimal setup values.
14
BPrecautions
1. Cleaning Condition
Refer to Wire-to-Board Connector Use Hand book.
However, if the connector is cleaned by the potting header, the detergent remains
within the connector, which will cause malfunction.
2. Connection Condition
3. Cautions
■ To remove the connector, if the connector is forcedly removed, it will cause
connector damage. If the connector is hardly removed, slightly push the
connector once, and then remove it using the lock.
■ In some method for laying the cable within equipment, a tension may be
applied to the cable so as to remove the contact. In this case, it is
recommended to use the retainer.
■ Incomplete insertion of the contact can be prevented by mounting a retainer;
however, mounting of a retainer might not be possible when the contact protrudes
beyond the socket. Insert the contact securely and then mount the retainer.
■ If the potting process is implemented, it is desirable to fill the connector with
resin, considering the resin surface tensile force.
■ The color phase of this product may be slightly different from that of the forming
product according to the manufacturing lot and future storage conditions,
however the difference doesn't affect the performance.
4. Precautions
Please refer to the following documents when handling the product.
■Crimp Quality Standard (ETAD-H0947-00, ETAD-H0949-00)
■Wire-to-Board Connector Use Handbook
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 06/2021. Contents are subject to change without notice for the purpose of improvements.
15
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Hirose Electric:
DF1E-2S-2.5C DF1E-3S-2.5C DF1E-4S-2.5C DF1E-5S-2.5C DF1E-7S-2.5C DF1E-8S-2.5C DF1E-9S-2.5C
DF1E-11S-2.5C DF1E-12S-2.5C DF1E-14S-2.5C DF1E-15S-2.5C DF1E-2022PCF DF1E-2022PC DF1E-3EP-2.5C
DF1E-4EP-2.5C DF1E-6EP-2.5C DF1E-8EP-2.5C DF1E-9EP-2.5C DF1EA-2EP-2.5C DF1EA-3EP-2.5C DF1EA6EP-2.5C DF1EA-8EP-2.5C DF1EA-9EP-2.5C DF1E-2RS/P-2.5 DF1E-3RS/P-2.5 DF1E-4RS/P-2.5 DF1E-5RS/P2.5 DF1E-6RS/P-2.5 DF1E-10RS/P-2.5 DF1E-2022SCF DF1E-2022SC DF1E-2022SCA DF1E-2022PCA DF1E2428PCFA DF1E-2428PCA DF1EG-2P-2.5DSA(35) DF1EC-10P-2.5DSA(36) DF1E-2P-2.5DS(35) DF1E-10P2.5DS(35) DF1EC-14P-2.5DSA(35) DF1EG-7P-2.5DSA(35) DF1E-12P-2.5DS(35) DF1E-2P-2.5DS(36) DF1EC-10P2.5DSA(35) DF1EC-11P-2.5DSA(35) DF1EG-4P-2.5DSA(35) DF1EG-10P-2.5DSA(35) DF1E-4P-2.5DS(35) DF1E5P-2.5DS(35) DF1EC-4P-2.5DSA(36) DF1EC-4P-2.5DSA(35) DF1EC-9P-2.5DSA(35) DF1E-4P-2.5DS(36) DF1E8P-2.5DS(35) DF1EC-12P-2.5DSA(35) DF1EC-9P-2.5DSA(36) DF1EC-8P-2.5DSA(35) DF1E-3P-2.5DS(35) DF1EG6P-2.5DSA(35) DF1EC-7P-2.5DSA(36) DF1EG-9P-2.5DSA(35) DF1EC-15P-2.5DSA(35) DF1EC-6P-2.5DSA(35)
DF1EC-5P-2.5DSA(36) DF1EC-5P-2.5DSA(35) DF1EG-8P-2.5DSA(35) DF1EC-6P-2.5DSA(36) DF1EG-5P2.5DSA(35) DF1EC-7P-2.5DSA(35) DF1EC-2P-2.5DSA(35) DF1E-3P-2.5DS(36) DF1EC-3P-2.5DSA(36) DF1EC-2P2.5DSA(36) DF1EG-11P-2.5DSA(35) DF1E-6P-2.5DS(35) DF1E-9P-2.5DS(35)
