HIF3FC-10PA-2.54DSA(71) 数据手册
2.54mm Pitch Low Profile Connector
HIF3FB and HIF3FC Series
■Features
1. Flux Prevention
HIF3FC series straight type takes complete flux
tight measures.
2. Low Profile
Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
The pin header is a low profile of height 9.2mm.
The board to board clearance is 12.2mm for
stacking connection.
■Applications
Photo: HIF3FC Series
Computers, termination equipment, various kinds
of electronic equipment, Office Automation
machines and so on
■Product Specifications
Rating
Current rating: 1A
Operating Temperature Range: -55 to +85ç (Note 1) Storage Temperature Range: -10 to +60ç (Note 2)
Voltage rating: 200V AC
Operating Humidity Range: 40 to 80%
Item
Operating Humidity Range: 40 to 70% (Note 2)
Specification
Condition
1. Insulation Resistance 1000M ohms
500V DC
2. Withstanding Voltage No flashover or insulation breakdown.
650V AC/1 minute.
3. Contact Resistance
15m ohms max.
0.1A
4. Vibration
No electrical discontinuity of 1μs or more
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5. Humidity (Steady state) Insulation resistance: 1000M ohms min
96 hours at temperature of 40ç and humidity of 90% to 95%
6. Temperature Cycle
(-55ç: 30 minutes→15 to 35ç: 5 minutes max.→
85ç: 30 minutes→15 to 35ç: 5 minutes max.) 5 cycles
No damage, cracks, or parts looseness.
7. Durability (Mating/un-mating) Contact resistance: 15 m ohms max.
500 cycles
8. Resistance to Soldering heat No deformation of components affecting performance.
Solder bath: 260ç for 10 seconds
Manual soldering: 350ç for 3 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3. Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for
a specific part number shown.
■Material
Parts
Material
PBT
Insulator
Contact
Pin header
Brass
Receptacle
Copper alloy
Finish
Remarks
Black
UL94V-0
Contact area
: Gold plated
________
Termination area : Pure tin plated
■Ordering Information
HIF3FC- * P A - 2.54 DSA
q
w e
r
t
q Series Name
y
: HIF3FB (60, 64 contacts)
r A: Selective gold plating
: HIF3FC (10~50 contacts)
t Contact pitch: 2.54mm
w Number of contacts: 10, 14, 16, 20, 26, 30, 34, 40, 50, 60, 64 y Contact type
e
P
: Pin header
DSA : Straight type
D
: Socket
DS : Right angle type
B47
HIF3FB and HIF3FC Series●2.54mm Pitch Low Profile Connector
■Straight Type Pin Header
Note 1: Two types of 50 contacts are available. Please use
products according to the table as shown below.
Note 2: The number of polarizing key mounted positions differs
according to products. Please refer to the table as shown below.
Note 3: The 10 contact type has no standoff at the center.
Note 4: * indicates the number of contacts.
Unit: mm
Part Number
CL No.
Number of Contacts
A
B
C
HIF3FC -10PA-2.54DSA(71) 616-0161-4-71
10
20.2
17.5
10.16
4.1
None
HIF3FC -14PA-2.54DSA(71) 616-0162-7-71
14
25.28
22.58
15.24
4.1
1 point on the left side
HIF3FC -16PA-2.54DSA(71) 616-0163-0-71
16
27.82
25.12
17.78
4.1
HIF3FC -20PA-2.54DSA(71) 616-0164-2-71
30.2
22.86
4.1
HIF3FC -26PA-2.54DSA(71) 616-0165-5-71
26
40.52
37.82
30.48
4.1
HIF3FC -30PA-2.54DSA(71) 616-0166-8-71
30
45.6
42.9
35.56
4.1
HIF3FC -34PA-2.54DSA(71) 616-0167-0-71
34
50.68
47.98
40.64
4.1
HIF3FC -40PA-2.54DSA(71) 616-0168-3-71
40
58.30
55.60
48.26
4.1
HIF3FC -50PA-2.54DSA(71) 616-0169-6-71
50
71.0
68.3
60.96
4.1
HIF3FCA-50PA-2.54DSA(71) 616-0170-5-71
50
71.0
68.3
60.96
26.96
D (Note 1) Polarizing Key Mounted Position(Note 2)
RoHS
YES
1 point on the right and left
sides, respectively
Note 1: Two types are available. Please use them according to
Unit: mm
Part Number
B48
Number of Contacts
A
B
C
HIF3FB -60PA-2.54DSA(71) 616-0130-0-71
CL No.
60
83.7
81.0
73.66
4.1
HIF3FBA -60PA-2.54DSA(71) 616-0142-0-71
60
83.7
81.0
73.66
26.96
HIF3FB -64PA-2.54DSA(71) 616-0131-3-71
64
88.78
86.1
78.74
4.1
HIF3FBA -64PA-2.54DSA(71) 616-0143-2-71
64
88.78
86.1
78.74
26.96
sides, respectively
RoHS
YES
■Right Angle Type Pin Header
Unit: mm
Part Number
CL No.
Number of Contacts
A
B
C
HIF3FC -10PA-2.54DS(71)
616-0061-0-71
10
20.2
17.5
10.16
4.1
None
HIF3FC -14PA-2.54DS(71)
616-0062-2-71
14
25.28
22.58
15.24
4.1
HIF3FC -16PA-2.54DS(71)
616-0063-5-71
16
27.82
25.12
17.78
4.1
HIF3FC -20PA-2.54DS(71)
616-0064-8-71
30.2
22.86
4.1
HIF3FC -26PA-2.54DS(71)
616-0065-0-71
26
40.52
37.82
30.48
4.1
HIF3FC -30PA-2.54DS(71)
616-0066-3-71
30
45.6
42.9
35.56
4.1
HIF3FC -34PA-2.54DS(71)
616-0067-6-71
34
50.68
47.98
40.64
4.1
HIF3FC -40PA-2.54DS(71)
616-0068-9-71
40
58.30
55.60
48.26
4.1
HIF3FC -50PA-2.54DS(71)
616-0069-1-71
50
71.0
68.3
60.96
4.1
HIF3FCA-50PA-2.54DS(71)
616-0070-0-71
50
71.0
68.3
60.96
26.96
RoHS
YES
sides, respectively
Unit: mm
Part Number
CL No.
Number of Contacts
A
B
C
HIF3FB -60PA-2.54DS(71)
616-0030-6-71
60
83.7
81.0
73.66
4.1
HIF3FBA -60PA-2.54DS(71)
616-0042-5-71
60
83.7
81.0
73.66
26.96
HIF3FB -64PA-2.54DS(71)
616-0031-9-71
64
88.78
86.1
78.74
4.1
HIF3FBA -64PA-2.54DS(71)
616-0043-8-71
64
88.78
86.1
78.74
26.96
D (Note 1) Polarizing Key Mounted Position RoHS
sides, respectively
YES
B49
■Straight Type Receptacle
Unit: mm
CL No.
Number of Contacts
A
B
HIF3FB-10DA-2.54DSA(71)
Part Number
616-0201-7-71
10
17.27
10.16
HIF3FB-16DA-2.54DSA(71)
616-0203-2-71
16
24.89
17.78
HIF3FB-20DA-2.54DSA(71)
616-0204-5-71
22.86
HIF3FB-26DA-2.54DSA(71)
616-0205-8-71
26
37.59
30.48
HIF3FB-30DA-2.54DSA(71)
616-0206-0-71
30
42.67
35.56
HIF3FB-34DA-2.54DSA(71)
616-0207-3-71
34
47.75
40.64
HIF3FB-40DA-2.54DSA(71)
616-0208-6-71
40
55.37
48.26
HIF3FB-50DA-2.54DSA(71)
616-0209-9-71
50
68.07
60.96
HIF3FB-60DA-2.54DSA(71)
616-0210-8-71
60
80.77
73.66
Note 1: Standoff number differs according to products.
Note 2: The polarizing key number differs according to products.
B50
None
sides, respectively
YES
HIF3FC-10PA-2.54DSA(71) 价格&库存
很抱歉,暂时无法提供与“HIF3FC-10PA-2.54DSA(71)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+11.81520
- 10+10.21680
- 30+9.21240
- 100+7.78734
