8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
E
2515
F
3120
H
3473
DESCRIPTION
DATE
REMOVE CONTACT DEPTH TOLERANCE ADD
01/13/2012
"REF.", ADD NOTE 10 MATING PARTS
UPDATE PROCESSING TEMPERATURE FOR NYLON
6T MATERIAL, INSERTION DEPTH TO 1.81mm
(WAS 1.85mm), CURRENT RATING TO 2 AMPS 04/15/2015
(WAS 1 AMP), UPDATE STRAIGHTNESS TOL
ADD 30u GOLD/GOLD FLASH PLATING OPTION,
UPDATE PN CODING FROM NPxNxx2FJFN-RC TO 4/13/2016
NP_N_ _2FJFN-RC
BY
LH
F
LH
JH
E
E
.191 4.85
A±.004 [ 0.10]
.031±.002 0.80±0.05
.079±.002 2.00±0.05
D
D
.079±.004 2.00±0.10
.020±.002 0.50±0.05
.079±.002 2.00±0.05
A .008[ 0.20]
RECOMMENDED PCB LAYOUT
02-20, 0.20mm MAX.
21-30, 0.30mm MAX.
31-40, 0.40mm MAX.
C
.079±.002 2.00±0.05
C
B .014 [ 0.35]
.057±.002 1.45±0.05
.071 1.81
.283 7.20
.079±.004 2.00±0.10
B
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 2 AMPS.
5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: 500 V AC.
8. OPERATING TEMPERATURE: -40° C TO +105° C.
9. PROCESSING TEMP.: WAVE/MANUAL SOLDERING ONLY
10.MATES WITH SULLINS .079 [2.00] CONTACT CENTER MALE HEADER SERIES.
(.020 [0.50] SQUARE POSTS)
8
7
6
5
B
.118±.008 3.00±0.20
.008±.002 0.20±0.05
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
DECIMALS
.X= .012 [.30]
.XX= .008 [.20]
.XXX= .006 [.15]
DRAWN
DATE
NAME
01/09/2009 JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER, FEMALE 2mm CC, 2 ROWS, RA
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 12:1
3
2
NP_N_ _2FJFN-RC
DWG. NO.
10461
SHEET 1 OF 1
1
REV
H
FILE NAME: 10461, NP_N_ _2FJFN-RC
A
很抱歉,暂时无法提供与“NPPN092FJFN-RC”相匹配的价格&库存,您可以联系我们找货
