8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2178
INITIAL RELEASE
02/14/2011
LH
F
F
.079±.004 2.00±0.10
E
E
A .004[ 0.10]
.020[0.50] X .006[0.15]
.035±.002 0.89±0.05
.079±.002 2.00±0.05
.079 2.00
.165 4.20
.028±.004 0.70±0.10
D
+.004
+0.10
0.90
.035
- .006
- 0.15
A
.268±.004 6.80±0.10
.079±.002 2.00±0.05
D
.039±.002 1.00±0.05
(NOT REQ'D FOR USE
AS TOP ENTRY)
.065±.002 1.65±0.05
C .004[ 0.10]
2X
.047±.002 1.20±0.05
OPTIONAL
RECOMMENDED PCB LAYOUT
B
.053±.012 1.35±0.30
C
.102 2.60
2X
.110±.008 2.80±0.20
NOTES:
1. INSULATOR MATERIAL: NYLON 6T, UL 94V-0, BLACK.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: .000030" ~ .000050" NICKEL UNDERPLATE, GOLD FLASH OVERALL.
4. CURRENT RATING: 2 AMPS PER CONTACT.
5. VOLTAGE RATING: 150V AC/DC.
6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
8. DIELECTRIC WITHSTANDING: 500 VAC.
9. OPERATING TEMPERATURE: -40° C TO +105° C.
10. *MAX PROCESSING TEMP.: 260° C FOR 10 SECS.
11. MODIFICATION: WITH PICK AND PLACE CAP IN TAPE & REEL.
*INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING
TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB,
AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.
8
7
6
5
.006[0.15]
.006 0.15
.047 1.20
OPTIONAL, SEE
PART NUMBER CODING
C
B
A
.039 1.00
C
DRAWN
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
Pb
TOLERANCES: ANGULAR:
X.X= .012 [0.30]
X.XX= .008 [0.20]
X.XXX= .006 [0.15]
RoHS COMPLIANT
4
30'
INTERPRET DIMENSIONS AND
TOLERANCING
PER: ASME Y14.5M-2009
3
.228±.012 5.80±0.30
DATE
NAME
2/14/2011
LH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
B
TITLE
HEADER FEMALE .079" PITCH, TOP/BOTTOM ENTRY, T&R
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 6:1
2
NPPNxx2GFNx-M81RC
DWG. NO.
11579
SHEET 1 OF 2
1
REV
A
FILE NAME: 11579, NPPNxx2GFNx-M81RC
A
8
7
4
5
6
1
2
3
F
F
*NPPNxx2GFNP-M81RC
*NPPNxx2GFNS-M81RC
OPTIONAL,
SEE P/N CODING
(10-POSITION AS SHOWN)
(SEE T&R DIM TABLE AND NOTE 1)
E
FIRST 20 CELLS EMPTY
D
.079[2.0]
**SEE ABOVE FOR PART
INSIDE EACH CELL
LAST 20 CELLS EMPTY
.059[Ø1.5]
.472 .006[12.0±0.15]
COVER TAPE
.069[1.75]
W±.012[ 0.30]
.158[4.0]
E
D
.059[1.5]
.132[3.35]
UNREELING DIRECTION
.173[4.4]
C
C
LABEL
A±.012[ 0.30]
QA LABEL
RoHS LABEL
13.00 .012[Ø330.0±0.30]
B
FEEDING DIRECTION
Part No.:
COVER TAPE
Cus_P/N:
Quantity:
Data Code:
RoHS6
CARRIER TAPE
B
1200 PCS/REEL
DRAWN
Pb
A
NOTE 1: WHEN THE CARRIER TAPE WIDTH IS EQUAL OR SAMLLER THAN 24mm[.945"],
1.50mm[.059"] CARRIER HOLES ARE LOCATED ON SINGLE SIDE OF CARRIER TAPE.
WHEN THE CARRIER TAPE WIDTH IS OVER THAN 24mm[.945"], 1.50mm[.059"]
CARRIER HOLES ARE LOCATED ON DOUBLE SIDE OF CARRIER TAPE.
8
7
6
X.X= .012 [0.30]
X.XX= .008 [0.20]
X.XXX= .006 [0.15]
RoHS COMPLIANT
5
4
30'
TOLERANCING
3
DATE
NAME
2/14/2011
LH
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 16:1
2
NPPNxx2GFNx-M81RC
DWG. NO.
11579
SHEET 2 OF 2
1
REV
A
A
很抱歉,暂时无法提供与“NPPN092GFNP-M81RC”相匹配的价格&库存,您可以联系我们找货
