MPSC-01-24-01-7.70-01-L-V 数据手册
HIGH-POWER SYSTEMS
20-60 A
FEATURES & BENEFITS
p er bla de
• Current Rating: 23 A - 58.7 A per power blade
• 3.81 mm, 5.00 mm and 6.35 mm pitch
• Dual blade contact system
• Power only or power/signal combinations available
• Right-angle and vertical orientations
• Rugged screw down and locking clip options
• Discrete wire cable assembly with 10-16 AWG wire
• “Hinged” for unique mating in any orientation
from 0° to 90° and space confined applications
Selectively loading contacts achieves
customer specific creepage and
clearance requrements.
Hermaphroditic
options available
(samtec.com?MPPT)
Hinging options available
(samtec.com?FMPT
samtec.com?FMPS)
KEY SPECIFICATIONS
PET/PES
PETC/PESC
MPT/MPS
MPTC/MPSC
UPT/UPS
FMPT/
FMPS
UPPT
MPPT
(6.35 mm)
.250"
(6.35 mm) .250" (pwr)
(2.54 mm) .100" (sig)
(5.00 mm)
.1969"
(5.00 mm) .197" (pwr)
(2.00 mm) .079" (sig)
(3.81 mm)
.150"
(5.00 mm)
.1969"
(3.81 mm)
.150"
(5.00 mm)
.1969"
CCC
(1 PIN)*
58.7 A
31.4 A
28.8 A
28.8 A
23 A
26.7 A
21.4 A
23.3 A
CCC
(2 PINS)*
48.5 A
28.0 A
24.7 A
24.7 A
18.6 A
22.9 A
19.8 A
20.5 A
CCC
(3 PINS)*
41.1 A
24.4 A
24.1 A
24.1 A
17.5 A
19.1 A
17.1 A
19.4 A
CREEPAGE
(3.66 mm)
.144"
(3.66 mm) .144"
(2.86 mm)
.113"
(2.86 mm) .113"
(5.5 mm)
.217"
(6.53 mm)
.257"
(1.91 mm)
.075"
(2.95 mm)
.116"
CLEARANCE
(3.31 mm)
.130"
(3.31 mm) .130"
(2.71 mm)
.106"
(2.71 mm) .106"
(1.51 mm)
.059"
(2.71 mm)
.106"
(1.51 mm)
.059"
(2.71 mm)
.106"
VAC
725 VAC
Signal: 450 VAC
Power: 650 VAC
575 VAC
250 VAC
438 VAC
525 VAC
425 VAC
600 VAC
VDC
1025 VDC
Signal: 636 VDC
Power: 919 VDC
812 VDC
354 VDC
620 VDC
742 VDC
600 VDC
848 VDC
100
100
100
100
25
100
100
100
SERIES
PITCH
CYCLES
F-221
samtec.com/PowerStrip
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(5.00 mm) .197"(PWR) / (2.00 mm) .079"(SIG) • 30 A SIGNAL/POWER COMBO SYSTEMS
SERIES
POWER
PINS
MPTC
Per end
MPSC
–02
Terminal
–01
Socket
SIGNAL
PINS
POWER
PINS
–16
Per end
–40
–02
–01
–24
–80
MPTC
LEAD STYLE
–6.30
= (6.30 mm) 0.248"
(MPTC only)
–7.70
= (7.70 mm) 0.303"
(MPSC only)
TAIL LENGTH
–01
OTHER
OPTION
–L
= Use with (1.60 mm)
.062" Thick PCB
–LC
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
(Power & Signal)
–03
= Use with (2.36 mm)
.093" Thick PCB
= Locking Clip
(Manual placement
required)
–T
= Matte tin on
contact and tail
(power),
Gold on contact,
Matte tin on tail
(Signal)
A
Board Mates:
MPSC
Cable Mates:
MPCC
-V-
PLATING
OPTION
(12.45)
.490
(11.38)
.448
POWER
PINS/ENDS
MPSC
A
Board Mates:
MPTC
(10.16)
.400
A
16
24
40
80
SIGNAL SIGNAL SIGNAL SIGNAL
PINS
PINS
PINS
PINS
–01
(27.44)
1.081
(31.45)
1.238
(39.44)
1.553
(59.44)
2.340
–02
(37.44)
1.474
(41.45)
1.632
(49.44)
1.946
(69.44)
2.734
View complete specifications at: samtec.com?MPTC & samtec.com?MPSC
SERIES
POWER
PINS
MPTC
Per end
MPSC
–02
Terminal
Socket
–01
SIGNAL
PINS
–24
–80
POWER
PINS
TAIL LENGTH
–01
Per end
.062" Thick PCB
–01
–02
MPTC-RA
Board Mates:
MPSC
Cable Mates:
MPCC
- 01 -
–03
.093" Thick PCB
A
(15.70)
.618
- RA -
–L
OTHER OPTION
–SD or –LC is a required
callout
= 10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
(Power & Signal)
–SD
= Screw Down
–T
= Matte Tin on contact
and tail (power),
Gold on contact,
Matte tin on tail
(Signal)
POWER
PINS/ENDS
(12.45)
.490
–LC
= Locking Clip
(Manual placement
required)
A
24
SIGNAL PINS
80
SIGNAL PINS
–01
(35.25) 1.388
(63.25) 2.490
–02
(45.25) 1.781
(73.25) 2.884
A
MPSC-RA
Board Mates:
MPTC
PLATING OPTION
(15.06)
.593
POWER
PINS/ENDS
(10.16)
.400
A
24
SIGNAL PINS
80 SIGNAL
PINS
–01
(36.25) 1.438
(64.25) 2.540
–02
(46.25) 1.831
(74.25) 2.934
Note: Some lengths, styles
and options are non-standard,
non-returnable
F-221
MPSC-01-24-01-7.70-01-L-V 价格&库存
很抱歉,暂时无法提供与“MPSC-01-24-01-7.70-01-L-V”相匹配的价格&库存,您可以联系我们找货
