8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
DESCRIPTION
DATE
BY
D
2515
REMOVE CONTACT GAP DIM, ADD "REF." IN CONTACT
POINT DIST, ADD NOTE 10 MATING POST
01/13/2012
LH
E
UPDATE PROCESSING TEMPERATURE FOR NYLON 6T
MATERIAL, CURRENT RATING TO 2 AMPS (WAS 1 AMP),
CONTACT POINT DEPTH TO 1.52mm (WAS 1.50mm) AND 04/15/2015
INSULATOR RESISTANCE TO 5000 MEGOHMS MIN (WAS
1000 MEGOHMS MIN), UPDATE STRAIGHTNESS TOL
3120
F
LH
E
E
.094 2.40
D
D
.060 1.52
.173 4.40
.094±.008 2.40±0.20
.020±.002 0.50±0.05
C
.008±.002 0.20±0.05
.079±.002 2.00±0.05
C
A±.008 [ 0.20]
B±.014 [ 0.35]
A±.004 [ 0.10]
.079±.002 2.00±0.05
03-20, 0.20mm MAX.
21-30, 0.30mm MAX.
31-40, 0.40mm MAX.
.031±.002 0.80±0.05
B
A
B
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: .000030"-.000050" MIN NICKEL UNDERPLATE, GOLD FLASH OVERALL.
4. CURRENT RATING: 2 AMPS.
5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: AC 500V.
8. OPERATING TEMPERATURE: -40° C TO +105° C.
9. PROCESSING TEMP.: WAVE/MANUAL SOLDERING ONLY.
10.MATES WITH SULLINS .079 [2.00] CONTACT CENTER MALE HEADER SERIES.
(.020 [0.50] SQUARE POSTS)
RECOMMENDED PCB LAYOUT
Pb
RoHS COMPLIANT
8
7
6
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
5
DECIMALS
.X= .012 [.30]
.XX= .008 [.20]
.XXX= .006 [.15]
DRAWN
DATE
NAME
01/10/2009 JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER, FEMALE 2mm CC, 1 ROW, ST
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 16:1
3
2
NPPNxx1BFCN-RC
DWG. NO.
10483
SHEET 1 OF 1
1
REV
E
FILE NAME: 10483, NPPNxx1BFCN-RC
A
很抱歉,暂时无法提供与“NPPN091BFCN-RC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 20+4.5983820+0.55684
- 50+4.5769050+0.55424
- 200+4.57680200+0.55423
- 500+4.57669500+0.55421
- 2000+4.576592000+0.55420
