Additional Resources:
Product Page
3D Model
PCB Footprint
date
03/31/2020
page
1 of 3
MODEL: PD-40V │ DESCRIPTION: POWER DIN JACK
FEATURES
• PCB mount
• vertical
• non-shielded
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
rated input current
typ
max
all pins
contact resistance
insulation resistance
at 500 Vdc
voltage withstand
for 1 minute
units
Vdc
7.5
A
30
mΩ
500
Vac
100
MΩ
insertion force
4.5
kgf
withdrawal force
0.9
3.0
kgf
operating temperature
-25
70
°C
storage temperature
-25
70
°C
life
5,000
flammability rating
UL94V-0
RoHS
yes
cycles
SOLDERABILITY
parameter
min
typ
max
units
hand soldering
for 3~5 seconds
350
360
370
°C
cuidevices.com
Product Page
3D Model
PCB Footprint
CUI Devices │ MODEL: PD-40V │ DESCRIPTION: POWER DIN JACK
date 03/31/2020│ page 2 of 3
MECHANICAL DRAWING
units: mm[inch]
tolerance: ±0.3 mm
MATERIAL
4.30 0.169
housing
PBT
cover
PBT
black
contact terminal
0.3T phoshor bronze
silver
inner shield
0.4T bronze
nickel
10.60 0.417
11.20 0.441
0.50 0.020
PLATING
3.50 0.138
1.50 0.059
0.20 (4PLCS)
3.80 0.150
2
14.90 0.587
12.80 0.504
8.80 0.346
4
1.80 0.071
0.20 (2PLCS)
14.90 0.587
2.00 0.079
1
2.40 0.094
3
1.60 0.063
1.50 0.059
0.2 (4PLCS)
5.00 0.197
8.80 0.346
8.80 0.346
1.9X0.7
(4PLCS)
2.2X0.8
(2PLCS)
3.80 0.150
1
8.80 0.346
3
2.40 0.094
2
4
1.60 0.063
1.70 0.067
(4PLCS)
5.00 0.197
10.60 0.417
Recommended PCB Layout
Top View
cuidevices.com
Product Page
3D Model
PCB Footprint
date 03/31/2020│ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
08/02/2011
1.01
brand update
03/31/2020
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“PD-40V”相匹配的价格&库存,您可以联系我们找货
