Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/11/2020
page
1 of 3
MODEL: PD-40S │ DESCRIPTION: POWER DIN JACK
FEATURES
4 pin power DIN
through hole
shielded
suitable for high power applications
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
rated input current
typ
max
all pins
contact resistance
insulation resistance
at 250 Vdc
voltage withstand
for 1 minute
Vdc
7.5
A
30
mΩ
250
Vac
45
N
30
N
50
MΩ
insertion force
withdrawal force
9
operating temperature
-20
life
85
1,000
flammability rating
UL94V-0
RoHS
yes
units
°C
cycles
SOLDERABILITY
parameter
min
wave soldering
230
cuidevices.com
typ
max
units
250
°C
Product Page
3D Model
PCB Footprint
CUI Devices │ MODEL: PD-40S │ DESCRIPTION: POWER DIN JACK
date 08/11/2020│ page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance:
X.X ±0.20 mm
X.XX ±0.10 mm
X.XXX ±0.05 mm
X.XXXX ±0.01 mm
MATERIAL
PLATING
housing
PBT (UL94V-0)
contact
phoshor bronze
silver
ground
brass
nickel
shell
SPCC
tin
Recommended PCB Layout
Top View
cuidevices.com
Product Page
3D Model
PCB Footprint
date 08/11/2020│ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
11/19/2008
1.01
update to title and tolerance
09/08/2009
1.02
updated datasheet
01/11/2018
1.03
updated housing, brand update
11/15/2019
updated PCB footprint
08/11/2020
1.04
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“PD-40S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+14.0743610+1.70327
- 30+14.0085930+1.69531
- 100+14.00828100+1.69527
- 250+14.00797250+1.69523
- 750+14.00766750+1.69520
