Additional Resources:
Product Page
3D Model
date
02/21/2020
page
1 of 4
SERIES: MD │ DESCRIPTION: MINI DIN CONNECTOR
FEATURES
• 3~9 pins
• plastic strain relief
• rated voltage: 100 Vac
PART NUMBER KEY
MD - XX
Base Number
Pin Options
30 = 3 pins
40 = 4 pins
50 = 5 pins
60 = 6 pins
70 = 7 pins
80 = 8 pins
90 = 9 pins
SPECIFICATIONS
parameter
conditions/description
min
max
100
12
rated input voltage
rated input current
typ
at 100 Vac
at 12 Vdc
contact resistance
insulation resistance
at 250 Vdc
voltage withstand
for 1 minute
units
Vac
Vdc
1
2
A
A
30
mΩ
50
MΩ
insertion force
250
Vac
4.5
kg
withdrawal force
0.9
3
kg
operating temperature
-20
105
°C
life
RoHS
5,000
yes
cuidevices.com
cycles
Product Page
3D Model
CUI Devices │ SERIES: MD │ DESCRIPTION: MINI DIN CONNECTOR
date 02/21/2020 │ page 2 of 4
MECHANICAL DRAWINGS
units: mm[inches]
TOLERANCE: ±0.2mm
6.3 0.248
MATERIAL
PLATING
shield
brass
nickel
pin contacts (1~9)
brass
silver
insulator
Polyamide 6 (PA-1010C2)
shell
ABS (PA-757)
cover
UE630 + PELL (LL120)
44.5 1.752
0.5
5.0 0.197
9.0 0.354
14.0 0.551
32.0 1.260
0.3
MD-30
MD-40
MD-50
MD-60
MD-70
MD-80
MD-90
47.3 1.862
0.3
6.45 0.254
8.0 0.315
16.40 0.646
14.85 0.585
9.95 0.392
cuidevices.com
Product Page
3D Model
date 02/21/2020 │ page 3 of 4
MECHANICAL ASSEMBLY
cover
1
2
1
plastic shell
2
3
PIN DETAILS
metel shield
3
MD-30~MD-80
4
housing
4
2
3
MD-30~MD-80
MD-90
housing
4
MD-90
3
2
3
STEP 1
solder wires to
housing (4),
assemble metal
shield pieces (3)
onto housing (4)
72°
90°
STEP 2
assemble plastic
shell pieces (2)
over metal
shield (3)
60°
4
2
3
STEP 3
slide cover (1)
over plastic
shell (2)
2
60°
Note:
0.9
1
45°
1. The mechanical assembly is a genral graphical representation only. Specific models will differ in actual appearance.
2. The metal shield for MD-90 is a single piece in which the pin housing slides into shield for assembly.
cuidevices.com
45°
Product Page
3D Model
date 02/21/2020 │ page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
04/06/2006
1.01
updated dimensions
02/27/2008
1.02
added tolerance
12/01/2009
1.03
added insertion and withdrawal force
05/19/2010
1.04
new template applied
04/09/2012
1.05
updated housing
04/24/2012
1.06
added 9 pin model detail
06/08/2017
brand update
02/21/2020
1.07
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“MD-50”相匹配的价格&库存,您可以联系我们找货
