EGG.00.305.CLL
www.lemo.com
SUMMARY
# Wires
Low voltage
5
Image is for illustrative purpose only
Series
00
Termination type
Female solder
IP rating
50
AWG wire size
36.00 - 28.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
FGG.00.305.CLAD35Z
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EG*: Fixed receptacle, nut fixing
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
2.59 g
Performance
Configuration
00.305 : 5 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
Specifications
Contact Type: Solder
Contact Dia.: 0.35 mm (0.01in)
Bucket Dia.: 0.4 mm (0.016in)
Max. Solid Conductor: 0.09 mm^2 (AWG 28)
Max. Stranded Conductor: 0.05 mm^2 (AWG 30)
R (max): 8.7 mOhm
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Salt Spray Corrosion: >1000 hr
DRAWINGS
Dimensions
A
B
E
L
M
N
S1
S3
e
mm.
8
10.3
6
15.5
1
13.7
6.3
9
M7x0.5
in.
0,31
0,41
0,24
0,61
0,04
0,54
0,25
0,35
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“EGG.00.305.CLL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+220.36732
- 10+218.01379
- 50+212.78604
- 100+205.46511
- 250+199.78956
