For more information, please visit the product page.
date
02/10/2012
page
1 of 3
SERIES: MD-XXSMW │ DESCRIPTION: MINI DIN CONNECTOR
PCB mount
right angle
side shielded
with isolated N/C switch
U
ED
FEATURES
N
RoHS
TI
PART NUMBER KEY
N
MD - XX SMW
Pin Options
30 = 3 pins
40 = 4 pins
50 = 5 pins
60 = 6 pins
70 = 7 pins
80 = 8 pins
IS
C
O
Base Number
SPECIFICATIONS
parameter
conditions/description
min
at 100 Vac
at 12 Vdc
contact resistance
at 250 Vdc
voltage withstand
for 1 minute
D
insulation resistance
max
100
12
rated input voltage
rated input current
typ
units
Vac
Vdc
1
2
A
A
30
mΩ
50
MΩ
insertion force
250
Vac
4.5
kg
withdrawl force
0.8
3
kg
operating temperature
-25
85
°C
life
1,000
cui.com
cycles
CUI Inc │ SERIES: MD-XXSMW │ DESCRIPTION: MINI DIN CONNECTOR
date 02/10/2012 │ page 2 of 3
MECHANICAL DRAWINGS
units: mm[inches]
TOLERANCE: ±0.2mm
4
3
silver
spring terminal (9)
copper titanium
silver
shunt terminal (10)
brass
silver
shield plate
steel
tin
plastic
PBT
12.8 0.504
1
6.5 0.256
3.5 0.138
(TYP)
phosphor bronze
N
2
tin
contact terminals (1~8)
U
7 6
8
PLATING
brass
20.9 0.823
14.0 0.551
5
MATERIAL
ED
earth terminal
2.0 0.079
0.2 0.008
2.0 0.079
(TYP)
TI
0.3 0.012
0.7 0.028
(TYP)
8.5 0.335
5.5 0.217
N
4.7 0.185
O
6.8 0.268
0.9 0.035
9
10
SCHEMATIC
11.0 0.433
13.5 0.531
IS
C
no electrical contact between terminal 9 and terminals 1~8
MD-30SMW
2
3
8.5 0.335
0.7X2.2
(3 PLCS)
D
4.7 0.185
13.5 0.531
16.0 0.630
MD-40SMW
4
1
5.5 0.217
0.9 0.035
(5 PLCS)
0.9 0.035
2
3
6.8 0.268
10
1
11.0 0.433
13.5 0.531
9
2.6 0.102
13.5 0.531
MD-50SMW
3
2
4
5
1
3
2
1
8.5 0.335
0.7X2.2
(3 PLCS)
5.5 0.217
4.7 0.185
13.5 0.531
0.9 0.035
(6 PLCS)
2
4
10
6.8 0.268
1
3
11.0 0.433
13.5 0.531
9
8.5 0.335
0.7X2.2
(3 PLCS)
5.5 0.217
4.7 0.185
13.5 0.531
6.8 0.268
0.9 0.035
(7 PLCS)
3
5
10
1
2
4
11.0 0.433
13.5 0.531
16.0 0.630
16.0 0.630
16.0 0.630
PCB LAYOUT
TOP VIEW
PCB LAYOUT
TOP VIEW
PCB LAYOUT
TOP VIEW
cui.com
9
1.3 0.051
MD-70SMW
7
8.5 0.335
4.7 0.185
4
13.5 0.531
6
2
6.8 0.268
9
6.8 0.268
1
3
5
2
2.6 0.102
2
11.0 0.433
5
11.0 0.433
13.5 0.531
13.5 0.531
0.9 0.035
(10 PLCS)
5
16.0 0.630
PCB LAYOUT
TOP VIEW
PCB LAYOUT
TOP VIEW
2
6.8 0.268
9
2.6 0.102
8
7
1
4
3
6
0.9 0.035
2.6 0.102
11.0 0.433
PCB LAYOUT
TOP VIEW
TI
N
16.0 0.630
REVISION HISTORY
rev.
description
date
initial release
02/23/2006
new template applied
02/10/2012
N
1.0
1.01
4.7 0.185
13.5 0.531
10
1
3
0.9 0.035
7
6
0.7X2.2
(3 PLCS)
5.5 0.217
0.9 0.035
(9 PLCS)
4
3
1
8.5 0.335
0.7X2.2
(3 PLCS)
4.7 0.185
13.5 0.531
10
1
5.5 0.217
0.9 0.035
(8 PLCS)
4
5
8.5 0.335
0.7X2.2
(3 PLCS)
5.5 0.217
7 6
8
3
2
1
2
6 5
4
3
ED
5
6
4
MD-80SMW
U
MD-60SW
date 02/10/2012 │ page 3 of 3
D
IS
C
O
The revision history provided is for informational purposes only and is believed to be accurate.
Headquarters
20050 SW 112th Ave.
Tualatin, OR 97062
800.275.4899
Fax 503.612.2383
cui.com
techsupport@cui.com
CUI offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is
assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical
component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to
affect its safety or effectiveness.
很抱歉,暂时无法提供与“MD-60SMW”相匹配的价格&库存,您可以联系我们找货
