Additional Resources:
Product Page
date
08/05/2022
page 1 of 5
SERIES: MD-S | DESCRIPTION: MINI DIN CONNECTOR
FEATURES
• PCB mount
• right angle
• non-shielded
PART NUMBER KEY
MD - XX S
Base Number
Notes:
*Discontinued models MD-30S & MD-50S
Pin Options
30* = 3 pins
40 = 4 pins
50* = 5 pins
60 = 6 pins
70 = 7 pins
80 = 8 pins
90 = 9 pins
SPECIFICATIONS
parameter
conditions/description
min
at 100 Vac
at 12 Vdc
contact resistance
insulation resistance
max
100
12
rated input voltage
rated input current
typ
at 250 Vdc
units
Vac
Vdc
1
2
A
A
30
mΩ
250
Vac
50
MΩ
voltage withstand
insertion force
0.8
6.0
kg
withdrawal force
0.8
4.5
kg
operating temperature
-40
life
85
1,000
flammability rating
UL94V-0
RoHS
yes
°C
cycles
SOLDERABILITY
parameter
min
wave soldering
for 10 seconds max
235
hand soldering
for 5±1 seconds
240
cuidevices.com
typ
245
max
units
260
°C
250
°C
Product Page
CUI DEVICES | SERIES: MD-S | DESCRIPTION: MINI DIN CONNECTOR
date 08/05/2022 | page 2 of 5
MECHANICAL DRAWINGS (MD-30S, MD-40S, MD-50S)
units: mm
tolerance: ±0.3 mm
PCB: ±0.1 mm
unless otherwise noted
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
body
PBT (UL94V-0)
black
2
cover
PBT (UL94V-0)
black
3
earth terminal
brass
tin
4
terminals
phosphor bronze
silver
8
7
5
6
3
4
2
1
MD-40S
MD-30S
4
2
MD-50S
3
1
2.5*1
2.2X0.7
4.7 0.185
8.5 0.335
(2 PLCS)
1
0.9 0.035
(3 PLCS)
+0.1
-0.0
2
11.0 0.433
Recommended PCB Layout
Top View
(Date Codes prior to 03/03/2022)
2.2X0.7
4.7 0.185
8.5 0.335
(3 PLCS)
2
3
0.9 0.035
0.9 0.035
(5 PLCS)
+0.1
6.8 0.268
4
1
3
11.0 0.433
(2 PLCS)
5
1.3 0.051
6.8 0.268
(2 PLCS)
Top View
Top View
Top View
(Date Codes after 03/03/2022)
cuidevices.com
Product Page
date 08/05/2022 | page 3 of 5
MECHANICAL DRAWINGS (MD-60S, MD-70S, MD-80S)
units: mm
tolerance: ±0.3 mm
PCB: ±0.1 mm
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
body
PBT (UL94V-0)
black
2
cover
PBT (UL94V-0)
black
3
earth terminal
brass
tin
4
terminals
phosphor bronze
silver
8
7
5
6
3
4
2
1
MD-60S
6
4
MD-70S
MD-80S
5
2
1
8
3
5
2.5*1
7
2
4
1
6
3
2.5*1
Top View
Top View
Top View
Top View
Top View
Top View
cuidevices.com
Product Page
date 08/05/2022 | page 4 of 5
MECHANICAL DRAWING (MD-90S)
units: mm
tolerance: ±0.3 mm
PCB: ±0.1 mm
ITEM
DESCRIPTION
MATERIAL
PLATING/COLOR
1
body
PBT (UL94V-0)
black
2
cover
PBT (UL94V-0)
black
3
earth terminal
brass
tin
4
terminals
phosphor bronze
silver
㻝
㻥㻙㽣
2.5*1
2
4
1
7
3
1.5
11
5
8.2
6
0.5
8
4.85
9
Top View
Top View
cuidevices.com
Product Page
date 08/05/2022 | page 5 of 5
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
02/16/2012
1.02
housing updates
03/29/2012
1.03
updated datasheet
08/25/2017
1.04
discontinued models MD-30S and MD-50S, brand update
10/08/2019
1.05
updated housing
12/12/2019
1.06
updated PCB footprints
09/01/2020
1.07
modified design, changed factory
02/18/2022
logo, datasheet style update
08/05/2022
1.08
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“MD-60S”相匹配的价格&库存,您可以联系我们找货
