NOTES:
1.
2.
3.
4.
ALL PARTS TO BE BULK PACKED
CONTACTS TO BE INSERTED INTO HOUSING AS SHOWN.
SEE DRAWING HPMCSTD FOR HOLE PATTERN.
ALL DIMENSIONS ARE REFERENCE EXCEPT THOSE WITH A TOLERANCE
.625
15.9
.140
3.6
.050
1.3
.545
13.8
2 #20
W17281-3PG-P-300
3 #20
.131±.015
3.3±0.4
KEY
CUSTOMER PRINT
KEY
2
.040
1
.620
15.7
ACROSS
FLATS
1
2
1
W17281-2PG-P-300
HEX NUT
MAT'L: UV PBT, BLACK
1
7/16-28 UNEF-2A
MOD, THREAD
W17281-2PG-P-300
CAVITY
INDICATOR
TYP.
GASKET
MAT'L: NEOPRENE, BLACK
KEY
WIRE VIEW
(2-3) #20 PIN CONTACTS, PC TAIL
MAT'L: GOLD PLATED COPPER ALLOY
FACE VIEW
W17281-XPG-P-300
CONTACT QTY
.715
18.2
.395
10
D-FLAT
PART
NUMBER:
ASS'Y P/N
W17281-2PG-P-300
PANEL CONNECTOR, MALE
KEY
1
2
2
.401±.003
10.2±0.1
3
3
WIRE VIEW
W17281-3PG-P-300
FACE VIEW
W17281-3PG-P-300
.430±.003
10.9±0.1
CUSTOMER APPROVAL
RECOMMENDED
PANEL CUT-OUT
THIS DOCUMENT CONTAINS CONFIDENTIAL
INFORMATION PROPRIETARY TO CONXALL
CORPORATION. ANY REPRODUCTION,
DISCLOSURE, OR USE OF THIS
DOCUMENT /INFORMATION IS EXPRESSLY
PROHIBITED UNLESS AUTHORIZED IN
WRITING BY CONXALL CORPORATION.
APPROVED BY:
DATE:
DIMENSIONS IN BRACKETS [ ] ARE IN MILLIMETERS UNLESS INDICATED
RoHS COMPLIANT
MA
08-05-20
JGK
8/12/19
A
REV. INIT.
DATE
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
RELEASED PER PDR 18004-2
DRAWING CREATED FOR PDR #18004
DESCRIPTION
ORIG. DRAWN BY:
DATE:
8/12/19
JGK
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
SIZE
NTS
B
FILE:
W17281-XPG-P-300
SHEET
1 OF 1
DIRECTORY:
SLW
PANEL MOUNT ASSEMBLY
INSTA-CLICK™ MICRO-CON-X
CUSTOMER:
STANDARD PRODUCT
PART
NUMBER:
W17281-XPG-P-300
REV
A
很抱歉,暂时无法提供与“W17281-3PG-P-300”相匹配的价格&库存,您可以联系我们找货
