ASS'Y P/N
FOR CABLE O.D.
NOTES:
W16982-XSG-P-518
.175-.185 [4.4-4.7]
1. ALL PARTS TO BE BULK PACKED
2. CONTACTS ASSEMBLED WITH SOLDER CUPS FACING
OUTWARD RADIALLY
3. ALL DIMENSIONS ARE REFERENCE EXCEPT THOSE
WITH A TOLERANCE
W16982-XSG-P-521
.205-.215 [5.2-5.5]
W16982-XSG-P-522
.215-.225 [5.5-5.7]
1.523
38.7
ASS'Y P/N
KEY STYLE
CONTACT
QTY.
W16982-5SG-P-5XX
W16982-6SG-P-5XX
A-KEY
B-KEY
5
6
W16982-7SG-P-5XX
W16982-XSG-P-5XX
A-KEY
7
.728
18.5
GROMMET SIZE
NUMBER OF CONTACTS
SHOWN ASSEMBLED
FOR CUSTOMER REFERENCE ONLY
CUSTOMER PRINT
.125±.015
3.2±0.4
.900
22.9
KEY
1
5
(5-7) #26 SOCKET CONTACTS, SOLDER
MAT'L: GOLD PLATED COPPER ALLOY
.950
24.1
.898
22.8
2
4
3
FACE VIEW
W16982-5SG-P-5XX
5 POSITION
A-KEY
KEY
1
6
2
5
KEY
KEY
1
1
BACKSHELL
MAT'L: UV PBT, BLACK
KEY
6
6
1
5
W16982-XSG-P-5XX
PART
NUMBER:
GROMMET
MAT'L: RUBBER, BLACK
CABLE END HOUSING, FEMALE
COUPLING RING
O-RING
MAT'L: SILICONE, RED
SPRING
MAT'L: STAINLESS STEEL
7
5
5
4
3
2
W16982-6SG-P-5XX
6 POSITION
B-KEY
2
2
FACE VIEW
3
4
3
WIRING VIEW
W16982-5SG-P-5XX
4
WIRING VIEW
W16982-6SG-P-5XX
4
3
WIRING VIEW
W16982-7SG-P-5XX
KEY
1
6
CUSTOMER APPROVAL
2
5
THIS DOCUMENT CONTAINS CONFIDENTIAL
INFORMATION PROPRIETARY TO CONXALL
CORPORATION. ANY REPRODUCTION,
DISCLOSURE, OR USE OF THIS
DOCUMENT /INFORMATION IS EXPRESSLY
PROHIBITED UNLESS AUTHORIZED IN
WRITING BY CONXALL CORPORATION.
7
4
3
APPROVED BY:
FACE VIEW
W16982-7SG-P-5XX
7 POSITION
A-KEY
DATE:
DIMENSIONS IN BRACKETS [ ] ARE IN MILLIMETERS
RoHS COMPLIANT
A
MA
08-18-20
JGK
2/28/20
JGK
9/09/19
REV. INIT.
DATE
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
UNLESS OTHERWISE SPECIFIED
TOLERANCES:
3 PLACE DECIMALS ±.005
ANGLES ±1°
FRACTIONS ±1/16
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
RELEASED PER PDR 18004-4
ADDED SHEET 2 FOR CABLE-END ASSEMBLY INSTRUCTIONS.
DRAWING CREATED FOR PDR #18004.
DESCRIPTION
ORIG. DRAWN BY:
DATE:
9/09/19
JGK
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
SIZE
SHEET
NTS
B
1 OF 1
FILE:
W16982-XSG-P-5XX
DIRECTORY:
SLW
CABLE-END ASSEMBLY
INSTA-CLICK™ MICRO-CON-X
CUSTOMER:
STANDARD PRODUCT
PART
NUMBER:
W16982-XSG-P-5XX
REV
A
很抱歉,暂时无法提供与“W16982-7SG-P-522”相匹配的价格&库存,您可以联系我们找货
