HSEC8-110-01-L-DV-A-K 数据手册
HIGH-SPEED
EDGE CARD SYSTEMS
0.60 mm, 0.80 mm and 1.00 mm PITCH
FEATURES & BENEFITS
• 56 Gbps PAM4 performance
• PCI Express® 3.0, 4.0 and 5.0
• Edge Rate® contacts optimized for
signal integrity performance and cycle life
• Up to 200 positions available
• Vertical, right-angle, edge mount,
pass-through orientations
• Power/signal combo, press-fit tails,
rugged weld tabs, locks and latches
• Mating cable assemblies available
Rugged tucked
beam technology
(HTEC8)
KEY SPECIFICATIONS
Differential pair for
increased speed
(HSEC8-DP)
Custom designs allow
for misalignment in
the X-Y axes (HSEC1)
SERIES
PITCH
TOTAL
POSITIONS
INSULATOR
MATERIAL
CONTACT
MATERIAL
OPERATING
TEMP RANGE
CURRENT
RATING
VOLTAGE
RATING
LEAD-FREE
SOLDERABLE
HSEC6
0.60 mm
56-168
Black LCP
Copper Alloy
-55 ℃ to +125 ℃
0.8 A (12 pins)
300 VAC
Yes
HTEC8
0.80 mm
40-200
Black LCP
Copper Alloy
-55 ℃ to +125 ℃
3.0 A (2 pins)
215 VAC
Yes
HSEC8
0.80 mm
18-200
Black LCP
BeCu
-55 ℃ to +125 ℃
2.8 A (2 pins)
240 VAC
Yes
HSEC1
1.00 mm
20-140
Black LCP
Phosphor Bronze
-55 ℃ to +125 ℃
2.2 A (2 pins)
215 VAC
Yes
F-221
samtec.com/EdgeCard
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(0.80 mm) .0315" PITCH • VERTICAL EDGE CARD SOCKET
HSEC8
POSITIONS
PER ROW
1
09, 10, 13, 20,
25, 30, 37, 40,
49, 50, 60, 70,
80, 100
(13, 25, 49 only
available with -L or
-L2 option; 09 only
available with
-L2 option;
37 only available
with -L option)
CARD
THICKNESS
–01
PLATING
OPTION
DV
A
–L
= (1.60 mm) .062"
thick card
–K
= 10 µ" (0.25 µm)
Gold on contact
area, Matte Tin
on tail
–03
= (2.36 mm) .093"
thick card
OTHER
OPTIONS
= Polyimide
Pick & Place Pad
–BL
= Board Locks; -01 card
only (Weld tab standard)
–S
= 30 µ" (0.76 µm)
Gold on contact
area, Matte Tin
on tail
–L
= Latching Option;
-01 card only
(13, 25, 37, 49 only)
(Weld tab standard)
–L2
= ECDP Latching;
-01 card only
(09, 13, 25, 49 only)
(For use with ECDP)
(Weld tab standard)
No. of Positions x (0.80) .0315 + (7.80) .307
HSEC8-DV
Card Mates:
(1.60 mm) .062" card
(2.36 mm) .093" card
HSC8
–WT
= Weld tab
(7.00)
.276
–TR
(7.00)
.276
A
B
= Tape & Reel
(09 - 70 only)
A
B
Cable Mates:
ECDP
(7.98)
.314
(No. of Positions + 6) x (0.80) .0315 + (0.60) .024
(7.98)
.314
(1.32)
.052
09, 13, 25, 37 & 40
(No. of Positions + 6) xTHRU
(0.80) .0315
(0.60) .024
100+POSITIONS
No. of Positions
x (0.80) .0315 + (4.60) .181
–FR
= Full Reel Tape & Reel
(must order max.
quantities per reel;
contact Samtec for
quantity breaks)
(09-70 only)
(1.32)
.052
No. of Positions
(5.60)
.220x (0.80) .0315 + (4.60) .181
(5.60)
.220
No. of Positions x (0.80) .0315 + (2.20) .087
10, 20, & 30 POSITIONS
OTHER SOLUTIONS
POSITIONS
PER ROW
A
For complete edge card system
with cards and sockets,
visit samtec.com?RU8.
09*†
13*†
25*†
For a card to mate with
an HSEC8 socket,
visit samte.com?HSC8
10 YEAR MFG
EXTENDED LIFE
PRODUCT
HIGH MATING
CYCLES
B
CABLE
CONNECTOR
(4.50) .177
(11.80) .465
ECDP-04
HSEC8-109-L2
(6.10) .240
(15.00) .591
ECDP-08
HSEC8-113-L2
(6.10) .240
(24.60) .969
ECDP-16
HSEC8-125-L2
37†
(18.10) .713
(34.20) 1.346
ECDP-32
HSEC8-149-L2
40
(18.90) .744
(36.60) 1.441
49*†
(22.90) .902
(43.80) 1.724
50
(22.90) .902
(44.60) 1.756
(52.60) 2.071
60
(26.90) 1.059
70†
(26.90) 1.059
(60.60) 2.386
80†
(26.90) 1.059
(68.60) 2.701
100†
(26.90) 1.059
(84.60) 3.331
Positions where no dimensions are given do
not have keying feature.
* Mates with ECDP Series
† Available with -01 Card Only
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
View complete specifications at: samtec.com?HSEC8-DV
samtec.com/EdgeCard
F-221
HSEC8-110-01-L-DV-A-K 价格&库存
很抱歉,暂时无法提供与“HSEC8-110-01-L-DV-A-K”相匹配的价格&库存,您可以联系我们找货
