FR101W – FR107W
1.0A GLASS PASSIVATED FAST RECOVERY DIODE
Features
Glass passivated device
Ideally Suited for Automatic Assembly
Low Forward Voltage Drop, High Efficiency
Surge Overload Rating to 2 5 A Peak
Low Power Loss
Ultra-Fast Recovery Time
Plastic Case Material has UL Flammability
Classification Rating 94V-O
SOD - 123
1.0±0.2
Cathode Band
Top View
r
1.9± 0.1
Mechanical Data
0.10-0.30
uc
nd
3.7±0.2
Dimensions in millimeters
mi
0.6±0.25
Case: SOD-123, Molded Plastic
Terminals: Solder Plated, Solderable
per MIL-STD-750, Method 2026
Polarity: Cathode Band or Cathode Notch
Marking: Type Number
Weight: 0.01 grams (approx.)
Lead Free: For RoHS / Lead Free Version
co
to
1.4± 0.15
2.8 ± 0.1
Se
Maximum Ratings and Electrical Characteristics
Characteristic
Symbol
RMS Reverse Voltage
CR
O
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Average Rectified Output Current
@TL = 100°C
JS
MI
FR101 FR102 FR103 FR104 FR105 FR106 FR107
UNITS
VRRM
VRWM
VR
50
100
200
400
600
800
1000
V
VR(RMS)
35
70
140
280
420
560
800
V
IO
1.0
A
IFSM
25
A
@IF = 1.0A
VFM
1.3
V
@TA = 25°C
@TA = 100°C
IRM
10
500
µA
Non-Repetitive Peak Forward Surge Current
8.3ms Single half sine-wave superimposed on
rated load (JEDEC Method)
Forward Voltage
Peak Reverse Current
At Rated DC Blocking Voltage
@TA=25°C unless otherwise specified
Reverse Recovery Time (Note 2)
t rr
Typical Junction Capacitance (Note 2)
Cj
Typical Thermal Resistance (Note 3)
Operating and Storage Temperature Range
150
250
4
RJL
180
Tj, TSTG
-65 to +150
500
nS
pF
°C/W
°C
Note: 1. Measured with IF = 0.5A, IR = 1.0A, Irr = 0.25A. See figure 5.
2. Measured at 1.0 MHz and applied reverse voltage of 4.0 V DC.
3. Mounted on P.C. Board with 8.0mm2 land area.
www.jsmsemi.com
第1/2页
FR101W – FR107 W
1.0
10
IF, INSTANTANEOUS FWD CURRENT (A)
0.4
0.2
Single phase half-wave
60 Hz resistive or inductive load
50
75
100
125
150
175
1.0
0.1
Tj = 25°C
Pulse width = 300 µs
0.01
200
Cj, CAPACITANCE (pF)
co
100
Se
mi
MI
C
RO
10
1
100
10
VR, REVERSE VOLTAGE (V)
Fig. 4 Typical Junction Capacitance
100
+0.5A
10Ω NI
Device
Under
Test
Pulse
Generator
(Note 2)
50V DC
Approx
1.0Ω
NI
10
trr
50Ω NI (Non-inductive)
Tj = 25°C
f = 1MHz
1
10
NUMBER OF CYCLES AT 60 Hz
Fig. 3 Peak Forward Surge Current
1.4
0.6
0.8
1.0
1.2
VF, INSTANTANEOUS FORWARD VOLTAGE (V)
Fig. 2 Typical Forward Characteristics
nd
30
JS
IFSM, PEAK FORWARD SURGE CURRENT (A)
TA, AMBIENT TEMPERATURE (°C)
Fig. 1 Forward Derating Curve
Pulse Width 8.3ms
Single Half-Sine-Wave
(JEDEC Method)
r
0.6
to
0.8
uc
I(AV), AVERAGE FWD RECTIFIED CURRENT (A)
Oscilloscope
(Note 1)
0A
-0.25A
Notes:
1. Rise Time = 7.0ns max. Input Impedance = 1.0MΩ, 22pF.
2. Rise Time = 10ns max. Input Impedance = 50Ω.
-1.0A
Set time base for 5/10ns/cm
Fig. 5 Reverse Recovery Time Characteristic and Test Circuit
www.jsmsemi.com
第2/2页
很抱歉,暂时无法提供与“FR107W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.06000
- 100+0.05600
- 300+0.05200
- 500+0.04800
- 2000+0.04600
- 5000+0.04480
