74AHCT374D-Q100J
74AHCT374D-Q100J
    NEXPERIA(安世)
    SOIC20_300MIL
    八进制D型触发器;正边缘触发;三态
74AHCT374D-Q100J 数据手册
74AHC374-Q100; 74AHCT374-Q100 Octal D-type flip-flop; positive edge-trigger; 3-state Rev. 1 — 11 March 2014 Product data sheet 1. General description The 74AHC374-Q100; 74AHCT374-Q100 is a high-speed Si-gate CMOS device and is pin compatible with Low-power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard No. 7-A. The 74AHC374-Q100; 74AHCT374-Q100 comprises eight D-type flip-flops featuring separate D-type inputs for each flip-flop and 3-state outputs for bus oriented applications. A clock input (CP) and an output enable input (OE) are common to all flip-flops. The eight flip-flops will store the state of their individual D inputs that meet the set-up and hold times requirements for the LOW-to-HIGH CP transition. When OE is LOW the content of the eight flip-flops is available at the outputs. When OE is HIGH, the outputs go to the high-impedance OFF-state. Operation of the OE input does not affect the state of the flip-flops. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Balanced propagation delays  All inputs have Schmitt-trigger actions  Inputs accept voltages higher than VCC  Common 3-state output enable input  Input levels:  For 74AHC374-Q100: CMOS level  For 74AHCT374-Q100: TTL level  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 74AHC374-Q100; 74AHCT374-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AHC374D-Q100 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74AHC374PW-Q100 40 C to +125 C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 40 C to +125 C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74AHC374-Q100 74AHCT374-Q100 74AHCT374D-Q100 74AHCT374PW-Q100 40 C to +125 C 4. Functional diagram 3 D0 Q0 2 4 D1 Q1 5 7 D2 Q2 6 8 D3 Q3 9 13 D4 14 D5 Q5 15 17 D6 Q6 16 18 D7 Q7 19 FF1 to FF8 3-STATE OUTPUTS Q4 12 11 CP 1 OE mna892 Fig 1. Functional diagram 74AHC_AHCT374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 2 of 18 74AHC374-Q100; 74AHCT374-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 1 EN 11 C1 11 3 CP 3 4 7 8 13 14 17 18 D0 Q0 D1 Q1 D2 Q2 D3 Q3 D4 Q4 D5 Q5 D6 Q6 D7 Q7 2 4 5 6 7 6 9 8 9 12 13 12 14 15 17 16 18 19 5 15 16 19 OE 1 Fig 2. mna196 mna891 Logic symbol D0 Fig 3. D1 D Q D2 D CP Q D3 D CP FF1 2 1D Q FF2 D4 D CP Q D5 D CP FF3 IEC logic symbol Q D CP FF4 D6 Q D CP FF5 D7 Q D CP FF6 Q CP FF7 FF8 CP OE Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 mna893 Fig 4. Logic diagram 74AHC_AHCT374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 3 of 18 74AHC374-Q100; 74AHCT374-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 5. Pinning information 5.1 Pinning $+&4 $+&74 2(  4   9&&  4 '   ' '   ' 4   4 4   4 '   ' '   ' 4   4 *1'   &3 DDD Fig 5. Pin configuration SO20 and TSSOP20 5.2 Pin description Table 2. Pin description Symbol Pin Description OE 1 3-state output enable input (active LOW) Q0 2 3-state flip-flop output D0 3 data input D1 4 data input Q1 5 3-state flip-flop output Q2 6 3-state flip-flop output D2 7 data input D3 8 data input Q3 9 3-state flip-flop output GND 10 ground (0 V) CP 11 clock input (LOW-to-HIGH, edge triggered) Q4 12 3-state flip-flop output D4 13 data input D5 14 data input Q5 15 3-state flip-flop output Q6 16 3-state flip-flop output D6 17 data input D7 18 data input Q7 19 3-state flip-flop output VCC 20 supply voltage 74AHC_AHCT374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 4 of 18 Nexperia 74AHC374-Q100; 74AHCT374-Q100 Octal D-type flip-flop; positive edge-trigger; 3-state 6. Functional description Table 3. Function table[1] Operating mode OE CP Dn Internal flip-flop Load and read register L  l L L  h H H Load register and disable outputs H  l L Z H  h H Z [1] Control Input Output L Q0 to Q7 H = HIGH voltage level; h = HIGH voltage level one setup time prior to the LOW-to-HIGH CP transition; L = LOW voltage level; l = LOW voltage level one setup time prior to the LOW-to-HIGH CP transition;  = LOW-to-HIGH CP transition; Z = high-impedance OFF-state. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC VI Conditions Min Max Unit supply voltage 0.5 +7.0 V input voltage 0.5 +7.0 V 20 - mA 20 +20 mA input clamping current VI < 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] VO = 0.5 V to (VCC + 0.5 V) IIK IO output current 25 +25 mA ICC supply current - +75 mA IGND ground current 75 - mA Tstg storage temperature 65 +150 C - 500 mW Ptot total power dissipation Tamb = 40 C to +125 C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO20 packages: above 70 C the value of Ptot derates linearly at 8 mW/K. For TSSOP20 packages: above 60 C the value of Ptot derates linearly at 5.5 mW/K. 74AHC_AHCT374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 5 of 18 74AHC374-Q100; 74AHCT374-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 8. Recommended operating conditions Table 5. Operating conditions Symbol Parameter Conditions Min Typ Max Unit 2.0 5.0 5.5 V 74AHC374-Q100 VCC supply voltage VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C t/V input transition rise and fall rate VCC = 3.0 V to 3.6 V - - 100 ns/V VCC = 4.5 V to 5.5 V - - 20 ns/V 74AHCT374-Q100 VCC supply voltage 4.5 5.0 5.5 V VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C t/V input transition rise and fall rate - - 20 ns/V VCC = 4.5 V to 5.5 V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max 74AHC374-Q100 VIH VIL VOH VOL HIGH-level input voltage VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V LOW-level input voltage VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V HIGH-level VI = VIH or VIL output voltage IO = 50 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 50 A; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = 50 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = 8.0 mA; VCC = 4.5 V 3.94 - - 3.80 - 3.70 - V LOW-level VI = VIH or VIL output voltage IO = 50 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V 74AHC_AHCT374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 6 of 18 74AHC374-Q100; 74AHCT374-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 0.1 - 1.0 - 2.0 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND; VCC = 5.5 V - - 0.25 - 2.5 - 10.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 A CI input capacitance - 3 10 - 10 - 10 pF CO output capacitance - 4 - - - - - pF VI = VCC or GND 74AHCT374-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 A IO = 8.0 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 A IO = 8.0 mA 4.4 4.5 - 4.4 - 4.4 - V 3.94 - - 3.80 - 3.70 - V - 0 0.1 - 0.1 - 0.1 V - - 0.36 - 0.44 - 0.55 V II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V - - 0.1 - 1.0 - 2.0 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND per input pin; other inputs at VCC or GND; IO = 0 A; VCC = 5.5 V - - 0.25 - 2.5 - 10.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 A ICC additional per input pin; supply current VI = VCC  2.1 V; other pins at VCC or GND; IO = 0 A; VCC = 4.5 V to 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 3 10 - 10 - 10 pF CO output capacitance - 4 - - - - - pF 74AHC_AHCT374_Q100 Product data sheet VI = VCC or GND All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 7 of 18 74AHC374-Q100; 74AHCT374-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max CL = 15 pF - 6.4 12.7 1.0 15.0 1.0 16.0 ns CL = 50 pF - 8.4 16.2 1.0 18.5 1.0 20.5 ns - 4.4 8.1 1.0 9.5 1.0 10.0 ns - 5.7 10.1 1.0 11.5 1.0 12.5 ns CL = 15 pF - 5.5 11.0 1.0 13.0 1.0 14.0 ns CL = 50 pF - 7.3 14.5 1.0 16.5 1.0 18.0 ns - 3.9 7.6 1.0 9.0 1.0 9.5 ns - 5.2 9.6 1.0 11.0 1.0 12.0 ns CL = 15 pF - 5.6 10.5 1.0 12.5 1.0 13.0 ns CL = 50 pF - 9.4 14.0 1.0 16.0 1.0 17.5 ns CL = 15 pF - 4.2 6.8 1.0 8.0 1.0 8.5 ns CL = 50 pF - 6.4 8.8 1.0 10.0 1.0 11.0 ns CL = 15 pF 80 130 - 70 - 70 - MHz CL = 50 pF 55 85 - 50 - 50 - MHz CL = 15 pF 130 185 - 110 - 110 - MHz CL = 50 pF 85 120 - 75 - 75 - MHz VCC = 3.0 V to 3.6 V 5.0 - - 5.5 - 5.5 - ns VCC = 4.5 V to 5.5 V 5.0 - - 5.0 - 5.0 - ns VCC = 3.0 V to 3.6 V 4.5 - - 4.0 - 4.0 - ns VCC = 4.5 V to 5.5 V 3.0 - - 3.0 - 3.0 - ns 74AHC374-Q100 tpd propagation CP to Qn; see Figure 6 and delay Figure 8 [2] VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF ten enable time OE to Qn; see Figure 7 [3] VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF tdis disable time OE to Qn; see Figure 7 [4] VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V fmax maximum frequency see Figure 6 VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V tW tsu pulse width set-up time 74AHC_AHCT374_Q100 Product data sheet CP HIGH or LOW; see Figure 6 Dn to CP; see Figure 8 All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 8 of 18 74AHC374-Q100; 74AHCT374-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 9. Symbol Parameter th CPD hold time 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max VCC = 3.0 V to 3.6 V 2.0 - - 2.0 - 2.0 - ns VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - ns - 10 - - - - - pF CL = 15 pF - 4.3 9.4 1.0 10.5 1.0 12.0 ns CL = 50 pF - 5.6 10.4 1.0 11.5 1.0 13.0 ns - 3.5 10.2 1.0 11.5 1.0 13.0 ns - 4.8 11.2 1.0 12.5 1.0 14.0 ns CL = 15 pF - 3.6 10.2 1.0 11.0 1.0 13.0 ns CL = 50 pF - 5.7 11.2 1.0 12.0 1.0 14.0 ns CL = 15 pF 90 140 - 80 - 80 - MHz CL = 50 pF 85 130 - 75 - 75 - MHz Dn to CP; see Figure 8 power fi = 1 MHz; VI = GND to VCC dissipation capacitance [5] 74AHCT374-Q100; VCC = 4.5 V to 5.5 V tpd ten propagation CP to Qn; see Figure 6 and delay Figure 8 [2] [3] enable time OE to Qn; see Figure 7 CL = 15 pF CL = 50 pF tdis fmax [4] disable time OE to Qn; see Figure 7 maximum frequency see Figure 6 tW pulse width CP HIGH or LOW; see Figure 6 6.5 - - 6.5 - 6.5 - ns tsu set-up time Dn to CP; see Figure 8 2.5 - - 2.5 - 2.5 - ns th hold time Dn to CP; see Figure 8 2.5 - - 2.5 - 2.5 - ns - 12 - - - - - pF CPD power fi = 1 MHz; VI = GND to VCC dissipation capacitance [5] [1] Typical values are measured at nominal supply voltage (VCC = 3.3 V and VCC = 5.0 V). [2] tpd is the same as tPLH and tPHL. [3] ten is the same as tPZH and tPZL. [4] tdis is the same as tPHZ and tPLZ. [5] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of the outputs. 74AHC_AHCT374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 9 of 18 74AHC374-Q100; 74AHCT374-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 10.1 Waveforms IPD[ 9, &3LQSXW  90 *1' W: W 3+/ W 3/+ 92+ 90 4QRXWSXW DDF 92/ Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 6. Clock pulse width, maximum frequency and input to output propagation delays 9, 2(LQSXW 90 *1' W 3=/ W 3/= 9&& 4QRXWSXW /2:WR2)) 2))WR/2: 90 9; 92/ W 3=+ W 3+= 92+ 9< 4QRXWSXW +,*+WR2)) 2))WR+,*+ *1' 90 RXWSXWV HQDEOHG RXWSXWV GLVDEOHG RXWSXWV HQDEOHG PQD Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 7. Enable and disable times 74AHC_AHCT374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 10 of 18 74AHC374-Q100; 74AHCT374-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state VI VM CP input GND tsu tsu th th VI VM Dn input GND VOH VM Qn output VOL mna202 Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical voltage output levels that occur with the output load. Fig 8. Table 8. Data set-up and hold times Measurement points Type Input Output VM VM VX VY 74AHC374-Q100 0.5  VCC 0.5  VCC VOL + 0.3 V VOH  0.3 V 74AHCT374-Q100 1.5 V 0.5  VCC VOL + 0.3 V VOH  0.3 V 74AHC_AHCT374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 11 of 18 74AHC374-Q100; 74AHCT374-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 9, W:  QHJDWLYH SXOVH 90 9 9, WI WU WU WI  SRVLWLYH SXOVH 9 90  90 90  W: 9&& 9&& * 9, 92 5/ 6 RSHQ '87 &/ 57 DDG Test data is given in Table 9. Definitions test circuit: RT = termination resistance should be equal to output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. RL = load resistance. S1 = test selection switch. Fig 9. Table 9. Test circuit for measuring switching times Test data Type Input VI tr, tf CL RL tPHL, tPLH 74AHC374-Q100 VCC  3.0 ns 15 pF, 50 pF 1 k open 74AHCT374-Q100 3.0 V  3.0 ns 15 pF, 50 pF 1 k open 74AHC_AHCT374_Q100 Product data sheet Load All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 S1 position © Nexperia B.V. 2017. All rights reserved 12 of 18 74AHC374-Q100; 74AHCT374-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 11. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' $ ( ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ PP                                           LQFKHV         =       ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 10. Package outline SOT163-1 (SO20) 74AHC_AHCT374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 13 of 18 74AHC374-Q100; 74AHCT374-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 76623SODVWLFWKLQVKULQNVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP ' 627 ( $ ; F +( \ Y 0 $ =   4 $ SLQLQGH[ $   $ $ ș /S /   H GHWDLO; Z 0 ES   PP VFDOH ',0(16,216 PPDUHWKHRULJLQDOGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   ș PP                            R R 1RWHV 3ODVWLFRUPHWDOSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 3ODVWLFLQWHUOHDGSURWUXVLRQVRIPPPD[LPXPSHUVLGHDUHQRWLQFOXGHG 287/,1( 9(56,21 627 5()(5(1&(6 ,(& -('(& -(,7$ (8523($1 352-(&7,21 ,668('$7(   02 Fig 11. Package outline SOT360-1 (TSSOP20) 74AHC_AHCT374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 14 of 18 74AHC374-Q100; 74AHCT374-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description CDM Charged Device Model CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model LSTTL Low-power Schottky Transistor-Transistor Logic MIL Military MM Machine Model 13. Revision history Table 11. Revision history Document ID Release date 74AHC_AHCT374_Q100 v.1 20140311 74AHC_AHCT374_Q100 Product data sheet Data sheet status Change notice Supersedes Product data sheet - - All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 15 of 18 74AHC374-Q100; 74AHCT374-Q100 Nexperia Octal D-type flip-flop; positive edge-trigger; 3-state 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AHC_AHCT374_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 16 of 18 Nexperia 74AHC374-Q100; 74AHCT374-Q100 Octal D-type flip-flop; positive edge-trigger; 3-state No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 15. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74AHC_AHCT374_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 11 March 2014 © Nexperia B.V. 2017. All rights reserved 17 of 18 Nexperia 74AHC374-Q100; 74AHCT374-Q100 Octal D-type flip-flop; positive edge-trigger; 3-state 16. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 14.1 14.2 14.3 14.4 15 16 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Dynamic characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15 Legal information. . . . . . . . . . . . . . . . . . . . . . . 16 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Contact information. . . . . . . . . . . . . . . . . . . . . 17 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 11 March 2014
74AHCT374D-Q100J 价格&库存
很抱歉,暂时无法提供与“74AHCT374D-Q100J”相匹配的价格&库存,您可以联系我们找货
