VBM16R08
VBM16R08
    VBSEMI(微碧)
    TO-220AB
    MOSFETs N-沟道 600V 5.8A TO-220AB
VBM16R08 数据手册
VBM16R08 www.VBsemi.com /$IBOOFM07 %4 Power MOSFET FEATURES PRODUCT SUMMARY VDS (V) • Low gate charge Qg results in simple drive requirement 600 RDS(on) () VGS = 10 V Qg max. (nC) 0.8 • Improved gate, avalanche and dynamic dV/dt ruggedness 49 Qgs (nC) 13 Qgd (nC) 20 Configuration Available • Fully characterized capacitance and avalanche voltage and current Single APPLICATIONS • Switch mode power supply (SMPS) D • Uninterruptible power supply • High speed power switching TO-220AB APPLICABLE OFF LINE SMPS TOPOLOGIES G • Active clamped forward • Main switch D G S S N-Channel MOSFET ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted) PARAMETER SYMBOL LIMIT Drain-Source Voltage VDS 600 Gate-Source Voltage VGS ± 30 Continuous Drain Current VGS at 10 V TC = 25 °C TC = 100 °C Pulsed Drain Currenta ID UNIT V 8.0 5.8 A IDM 37 1.3 W/°C Single Pulse Avalanche Energy b EAS 290 mJ Repetitive Avalanche Current a IAR 8.0 A EAR 17 mJ PD 170 W dV/dt 5.0 V/ns TJ, Tstg -55 to +150 Linear Derating Factor Repetitive Avalanche Energy a Maximum Power Dissipation TC = 25 °C Peak Diode Recovery dV/dt c Operating Junction and Storage Temperature Range Soldering Recommendations (Peak temperature) d Mounting Torque for 10 s 6-32 or M3 screw 300 °C 10 lbf · in 1.1 N·m Notes a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). b. Starting TJ = 25 °C, L = 6.8 mH, Rg = 25 , IAS = 9.2 A (see fig. 12). c. ISD  9.2 A, dI/dt  50 A/μs, VDD  VDS, TJ  150 °C. d. 1.6 mm from case. 1 Downloaded From Oneyac.com VBM16R08 www.VBsemi.com THERMAL RESISTANCE RATINGS PARAMETER SYMBOL TYP. MAX. Maximum Junction-to-Ambient RthJA - 62 Case-to-Sink, Flat, Greased Surface RthCS 0.50 - Maximum Junction-to-Case (Drain) RthJC - 0.75 UNIT °C/W SPECIFICATIONS (TJ = 25 °C, unless otherwise noted) PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Static Drain-Source Breakdown Voltage VDS Temperature Coefficient VDS VGS = 0 V, ID = 250 μA 600 - - V VDS/TJ Reference to 25 °C, ID = 1 mA - 660 - mV/°C VGS(th) VDS = VGS, ID = 250 μA 2.0 - 4.0 V Gate-Source Leakage IGSS VGS = ± 30 V - - ± 100 nA Zero Gate Voltage Drain Current IDSS VDS = 600 V, VGS = 0 V - - 25 VDS = 480 V, VGS = 0 V, TJ = 125 °C - - 250 Gate-Source Threshold Voltage Drain-Source On-State Resistance Forward Transconductance RDS(on) ID = 5.5 A b VGS = 10 V gfs VDS = 50 V, ID = 5.5 A μA - 0.8 -  5.5 - - S Dynamic Input Capacitance Ciss VGS = 0 V, - 1400 - Output Capacitance Coss VDS = 25 V, - 180 - Reverse Transfer Capacitance Crss f = 1.0 MHz, see fig. 5 - 7.1 - Output Capacitance Coss VDS = 1.0 V, f = 1.0 MHz - 1957 - VDS = 480 V, f = 1.0 MHz - 49 - VDS = 0 V to 480 V - 96 - - - 49 - - 13 - - 20 - 13 - - 25 - - 30 - Effective Output Capacitance Total Gate Charge VGS = 0 V Coss eff. Qg VGS = 10 V Gate-Source Charge Qgs Gate-Drain Charge Qgd Turn-On Delay Time td(on) Rise Time Turn-Off Delay Time tr Fall Time tf Rg see fig. 6 and 13 b VDD = 300 V, ID = 8.0 A td(off) Gate Input Resistance ID = 8.0A, V DS = 400 V Rg = 9.1 , RD = 35.5 , see fig. 10 b f = 1 MHz, open drain - 22 - 0.5 - 3.2 - - 9.2 - - 37 pF nC ns  Drain-Source Body Diode Characteristics Continuous Source-Drain Diode Current Pulsed Diode Forward Current a Body Diode Voltage IS ISM VSD Body Diode Reverse Recovery Time trr Body Diode Reverse Recovery Charge Qrr Forward Turn-On Time ton MOSFET symbol showing the  integral reverse p - n junction diode D A G TJ = 25 °C, IS = 8.0 A, VGS = 0 S Vb TJ = 25 °C, IF = 8.0 A, dI/dt = 100 A/μs b - - 1.5 V - 530 800 ns - 3.0 4.4 μC Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD) Notes a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). b. Pulse width  300 μs; duty cycle  2 %. c. Coss effective is a fixed capacitance that gives the same charging time as Coss while VDS is rising from 0 % to 80 % VDS. 2 Downloaded From Oneyac.com VBM16R08 www.VBsemi.com TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted) 100 100 VGS 15V 10V 8.0V 7.0V 6.0V 5.5V 5.0V BOTTOM 4.7V I D , Drain-to-Source Current (A) I D , Drain-to-Source Current (A) TOP 10 1 4.7V 20µs PULSE WIDTH TJ = 25 °C 0.1 0.1 1 10 10 TJ = 150 ° C TJ = 25 ° C 1 0.1 4.0 100 VDS , Drain-to-Source Voltage (V) I D , Drain-to-Source Current (A) 10 4.7V 20µs PULSE WIDTH TJ = 150 ° C 10 100 RDS(on) , Drain-to-Source On Resistance (Normalized) 3.0 VGS 15V 10V 8.0V 7.0V 6.0V 5.5V 5.0V BOTTOM 4.7V 1 7.0 8.0 9.0 10.0 ID = 8.0A 2.5 2.0 1.5 1.0 0.5 0.0 -60 -40 -20 VGS = 10V 0 20 40 60 80 100 120 140 160 TJ , Junction Temperature ( °C) VDS , Drain-to-Source Voltage (V) Fig. 2 - Typical Output Characteristics 6.0 Fig. 3 - Typical Transfer Characteristics TOP 1 5.0 VGS , Gate-to-Source Voltage (V) Fig. 1 - Typical Output Characteristics 100 V DS = 50V 20µs PULSE WIDTH Fig. 4 - Normalized On-Resistance vs. Temperature 3 Downloaded From Oneyac.com VBM16R08 www.VBsemi.com 10000 V GS = 0V, f = 1MHz Ciss = Cgs + Cgd , Cds SHORTED Crss = Cgd Coss = Cds + C gd 1000 Ciss 100 ISD , Reverse Drain Current (A) C, Capacitance (pF) 100000 Coss 100 10 Crss 1 10 TJ = 150 ° C 1 TJ = 25 ° C 0.1 0.2 A 1 10 100 1000 Fig. 5 - Typical Capacitance vs. Drain-to-Source Voltage 1.0 1.2 Fig. 7 - Typical Source-Drain Diode Forward Voltage 1000 ID = 9.2A OPERATION IN THIS AREA LIMITED BY RDS(on) 400V VDS = 480V VDS = 300V VDS = 120V 16 100 ID , Drain Current (A) VGS , Gate-to-Source Voltage (V) 0.7 VSD ,Source-to-Drain Voltage (V) V DS , Drain-to-Source Voltage (V) 20 V GS = 0 V 0.5 12 8 10us 10 100us 1ms 1 10ms 4 FOR TEST CIRCUIT SEE FIGURE 13 0 0 10 20 30 40 50 0.1 TC = 25 ° C TJ = 150 ° C Single Pulse 10 100 1000 QG , Total Gate Charge (nC) VDS , Drain-to-Source Voltage (V) Fig. 6 - Typical Gate Charge vs. Gate-to-Source Voltage Fig. 8 - Maximum Safe Operating Area 4 Downloaded From Oneyac.com 10000 VBM16R08 www.VBsemi.com RD VDS 10.0 VGS D.U.T. RG + ID , Drain Current (A) 8.0 - VDD 10V Pulse width ≤ 1 µs Duty factor ≤ 0.1 % 6.0 Fig. 10a - Switching Time Test Circuit 4.0 VDS 90 % 2.0 0.0 25 50 75 100 125 150 10 % VGS TC , Case Temperature ( ° C) t d(on) tr t d(off) t f Fig. 10b - Switching Time Waveforms Fig. 9 - Maximum Drain Current vs. Case Temperature Thermal Response (Z thJC ) 1 D = 0.50 0.20 0.1 0.01 0.00001 0.10 PDM 0.05 t1 0.02 0.01 t2 SINGLE PULSE (THERMAL RESPONSE) 0.0001 Notes: 1. Duty factor D = t 1 / t 2 2. Peak T J = P DM x Z thJC + TC 0.001 0.01 0.1 1 t1 , Rectangular Pulse Duration (s) Fig. 11 - Maximum Effective Transient Thermal Impedance, Junction-to-Case 5 Downloaded From Oneyac.com VBM16R08 www.VBsemi.com V DS tp 15 V Driver L VDS D.U.T. RG + V - DD IAS 20 V tp A 0.01 W I AS Fig. 12b - Unclamped Inductive Waveforms EAS , Single Pulse Avalanche Energy (mJ) Fig. 12a - Unclamped Inductive Test Circuit 600 ID 4.1A 5.8A 9.2A TOP 500 BOTTOM 400 300 200 100 0 25 50 75 100 125 150 Starting TJ , Junction Temperature ( °C) Fig. 12c - Maximum Avalanche Energy vs. Drain Current Current regulator Same type as D.U.T. QG 50 kΩ 12 V 10 V 0.2 µF 0.3 µF QGS Q GD + D.U.T. VG - VDS VGS 3 mA Charge IG ID Current sampling resistors Fig. 13a - Basic Gate Charge Waveform Fig. 13b - Gate Charge Test Circuit 6 Downloaded From Oneyac.com VBM16R08 www.VBsemi.com Peak Diode Recovery dV/dt Test Circuit + D.U.T. Circuit layout considerations • Low stray inductance • Ground plane • Low leakage inductance current transformer + + - - Rg • • • • dV/dt controlled by Rg Driver same type as D.U.T. ISD controlled by duty factor “D” D.U.T. - device under test + - VDD Driver gate drive P.W. Period D= P.W. Period VGS = 10 Va D.U.T. lSD waveform Reverse recovery current Body diode forward current dI/dt D.U.T. VDS waveform Diode recovery dV/dt Re-applied voltage Inductor current VDD Body diode forward drop Ripple ≤ 5 % ISD Note a. VGS = 5 V for logic level devices Fig. 14 - For N-Channel        7 Downloaded From Oneyac.com VBM16R08 www.VBsemi.com TO-220-1 A E DIM. Q H(1) D 3 2 L(1) 1 M* L b(1) INCHES MIN. MAX. MIN. MAX. A 4.24 4.65 0.167 0.183 b 0.69 1.02 0.027 0.040 b(1) 1.14 1.78 0.045 0.070 F ØP MILLIMETERS c 0.36 0.61 0.014 0.024 D 14.33 15.85 0.564 0.624 E 9.96 10.52 0.392 0.414 e 2.41 2.67 0.095 0.105 e(1) 4.88 5.28 0.192 0.208 F 1.14 1.40 0.045 0.055 H(1) 6.10 6.71 0.240 0.264 0.115 J(1) 2.41 2.92 0.095 L 13.36 14.40 0.526 0.567 L(1) 3.33 4.04 0.131 0.159 ØP 3.53 3.94 0.139 0.155 Q 2.54 3.00 0.100 0.118 ECN: X15-0364-Rev. C, 14-Dec-15 DWG: 6031 Note • M* = 0.052 inches to 0.064 inches (dimension including protrusion), heatsink hole for HVM C b e J(1) e(1) 8 Downloaded From Oneyac.com VBM16R08 www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A. Downloaded From Oneyac.com 单击下面可查看定价,库存,交付和生命周期等信息 >>VBsemi(台湾微碧) Downloaded From Oneyac.com
VBM16R08 价格&库存
很抱歉,暂时无法提供与“VBM16R08”相匹配的价格&库存,您可以联系我们找货
VBM16R08
