74ALVCH16373DGG,11
74ALVCH16373DGG,11
    NEXPERIA(安世)
    TSSOP48_12.5X6.1MM
    2.5V/3.3V 16位D型透明锁存器;三态
74ALVCH16373DGG,11 数据手册
74ALVCH16373 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state Rev. 7 — 30 January 2019 Product data sheet 1. General description The 74ALVCH16373 is 16-bit D-type transparent latch featuring separate D-type inputs for each latch and 3-state outputs for bus oriented applications. Incorporates bus hold data inputs which eliminate the need for external pull-up or pull-down resistors to hold unused inputs. One latch enable (LE) input and one output enable (OE) are provided per 8-bit section. The 74ALVCH16373 consists of 2 sections of eight D-type transparent latches with 3-state true outputs. When LE is HIGH, data at the nDn inputs enter the latches. In this condition the latches are transparent, therefore a latch output will change each time its corresponding D-input changes. When LE is LOW, the latches store the information that was present at the nDn inputs at a set-up time preceding the LOW-to-HIGH transition of LE. When OE is LOW, the contents of the eight latches are available at the outputs. When OE is HIGH, the outputs go to the high-impedance OFF-state. Operation of the OE input does not affect the state of the latches. 2. Features and benefits • • • • • • • • • Wide supply voltage range from 1.2 V to 3.6 V Complies with JEDEC standard JESD8-B CMOS low power consumption MULTIBYTE flow-through standard pin-out architecture Low inductance multiple VCC and GND pins for minimum noise and ground bounce Direct interface with TTL levels All data inputs have bus hold Output drive capability 50 Ω transmission lines at 85 °C Current drive ±24 mA at VCC = 3.0 V 3. Ordering information Table 1. Ordering information Type number Temperature range 74ALVCH16373DGG -40 °C to +85 °C Package Name Description Version TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 74ALVCH16373 Nexperia 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 4. Functional diagram Fig. 1. 1 24 1OE 2OE 47 1D0 1Q0 2 46 1D1 1Q1 3 44 1D2 1Q2 5 43 1D3 1Q3 6 41 1D4 1Q4 8 40 1D5 1Q5 9 38 1D6 1Q6 11 37 1D7 1Q7 12 36 2D0 2Q0 13 35 2D1 2Q1 14 33 2D2 2Q2 16 32 2D3 2Q3 17 30 2D4 2Q4 19 29 2D5 2Q5 20 27 2D6 2Q6 22 26 2D7 2Q7 23 1LE 2LE 48 25 001aam007 Logic symbol 1OE 1LE 2OE 2LE 1D0 1D1 1D2 1D3 1D4 1D5 1D6 1D7 2D0 2D1 2D2 2D3 2D4 2D5 2D6 2D7 1 48 24 25 47 46 1EN C1 2EN C4 3D 1 2 3 44 5 43 6 41 8 40 9 38 11 37 12 36 35 4D 2 13 14 33 16 32 17 30 19 29 20 27 22 26 23 1Q0 1Q1 1Q2 1Q3 1Q4 1Q5 1Q6 1Q7 2Q0 2Q1 2Q2 2Q3 2Q4 2Q5 2Q6 2Q7 001aam009 Fig. 2. IEC logic symbol 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 January 2019 © Nexperia B.V. 2019. All rights reserved 2 / 15 74ALVCH16373 Nexperia 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state VCC data input to internal circuit mna705 Fig. 3. Bus hold circuit 1D0 D Q 1Q0 2D0 D Q LATCH 1 LATCH 9 LE LE LE 1LE 2LE 1OE 2OE to 7 other channels 2Q0 LE to 7 other channels 001aam010 Fig. 4. Logic diagram 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 January 2019 © Nexperia B.V. 2019. All rights reserved 3 / 15 74ALVCH16373 Nexperia 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 5. Pinning information 5.1. Pinning 74ALVCH16373 1OE 1 48 1LE 1Q0 2 47 1D0 1Q1 3 46 1D1 GND 4 45 GND 1Q2 5 44 1D2 1Q3 6 43 1D3 VCC 7 42 VCC 1Q4 8 41 1D4 1Q5 9 40 1D5 GND 10 39 GND 1Q6 11 38 1D6 1Q7 12 37 1D7 2Q0 13 36 2D0 2Q1 14 35 2D1 GND 15 34 GND 2Q2 16 33 2D2 2Q3 17 32 2D3 VCC 18 31 VCC 2Q4 19 30 2D4 2Q5 20 29 2D5 GND 21 28 GND 2Q6 22 27 2D6 2Q7 23 26 2D7 2OE 24 25 2LE 001aam008 Fig. 5. Pin configuration SOT362-1 (TSSOP48) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1OE, 2OE 1, 24 output enable input (active LOW) 1Q0, 1Q1, 1Q2, 1Q3, 1Q4, 1Q5, 1Q6, 1Q7 2, 3, 5, 6, 8, 9, 11, 12 data outputs 2Q0, 2Q1, 2Q2, 2Q3, 2Q4, 2Q5, 2Q6, 2Q7 13, 14, 16, 17, 19, 20, 22, 23 data outputs GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) VCC 7, 18, 31, 42 positive supply voltage 1D0, 1D1, 1D2, 1D3, 1D4, 1D5, 1D6, 1D7 47, 46, 44, 43, 41, 40, 38, 37 data inputs 2D0, 2D1, 2D2, 2D3, 2D4, 2D5, 2D6, 2D7 36, 35, 33, 32, 30, 29, 27, 26 data inputs 1LE, 2LE 48, 25 latch enable input (active HIGH) 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 January 2019 © Nexperia B.V. 2019. All rights reserved 4 / 15 74ALVCH16373 Nexperia 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 6. Functional description Table 3. Function table H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the LOW-to-HIGH LE transition; L = LOW voltage level; I = LOW voltage level one set-up time prior to the LOW-to-HIGH LE transition; Z = high-impedance OFF-state. Inputs Internal latches Outputs nQn Operating mode L L L H H H H enable and read register (transparent mode) L L l L L L L h H H H L l L Z H L h H Z nOE nLE nDn L H L latch and read register (hold mode) latch register and disable outputs 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +4.6 V -50 - VCC supply voltage IIK input clamping current VI < 0 V VI input voltage control inputs [1] -0.5 +4.6 V data inputs [1] -0.5 VCC + 0.5 V IOK output clamping current - ±50 VO output voltage -0.5 VCC + 0.5 IO output current - ±50 mA ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 600 mW [1] [2] VO > VCC or VO < 0 V [1] VO = 0 V to VCC Tamb = -40 °C to +85 °C [2] mA mA V The input and output voltage ratings may be exceeded if the input and output current ratings are observed. Above 55 °C the value of Ptot derates linearly with 8 mW/K. 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 January 2019 © Nexperia B.V. 2019. All rights reserved 5 / 15 74ALVCH16373 Nexperia 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions VCC VI Min Typ Max Unit CL = 30 pF 2.3 - 2.7 V CL = 50 pF 3.0 - 3.6 V low voltage applications maximum speed performance supply voltage input voltage 1.2 - 3.6 V data inputs 0 - VCC V control inputs 0 - 5.5 V 0 - VCC V -40 - +85 °C VO output voltage Tamb ambient temperature in free air Δt/ΔV input transition rise and fall rate VCC = 2.3 V to 3.0 V 0 - 20 ns/V VCC = 3.0 V to 3.6 V 0 - 10 ns/V Conditions Min Typ [1] Max Unit VCC = 1.2 V VCC - - V VCC = 1.8 V 0.7VCC 0.9 - V VCC = 2.3 V to 2.7 V 1.7 1.2 - V VCC = 2.7 V to 3.6 V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Tamb = -40 °C to +85 °C VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage 74ALVCH16373 Product data sheet 2.0 1.5 - V VCC = 1.2 V - - 0 V VCC = 1.8 V - 0.9 0.2VCC V VCC = 2.3 V to 2.7 V - 1.2 0.7 V VCC = 2.7 V to 3.6 V - 1.5 0.8 V IO = -100 μA; VCC = 1.8 V to 3.6 V VCC - 0.2 VCC - V IO = -6 mA; VCC = 1.8 V VCC - 0.4 VCC - 0.1 - V IO = -6 mA; VCC = 2.3 V VCC - 0.3 VCC - 0.08 - V IO = -12 mA; VCC = 2.3 V VCC - 0.5 VCC - 0.17 - V IO = -12 mA; VCC = 2.7 V VCC - 0.5 VCC - 0.14 - V IO = -18 mA; VCC = 2.3 V VCC - 0.6 VCC - 0.26 - V IO = -24 mA; VCC = 3.0 V VCC - 1.0 VCC - 0.28 - V VI = VIH or VIL VI = VIH or VIL IO = 100 μA; VCC = 1.8 V to 3.6 V - 0 0.20 V IO = 6 mA; VCC = 1.8 V - 0.09 0.30 V IO = 6 mA; VCC = 2.3 V - 0.07 0.20 V IO = 12 mA; VCC = 2.3 V - 0.15 0.40 V IO = 12 mA; VCC = 2.7 V - 0.14 0.40 V IO = 18 mA; VCC = 2.3 V - 0.23 0.60 V IO = 24 mA; VCC = 3.0 V - 0.27 0.55 V All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 January 2019 © Nexperia B.V. 2019. All rights reserved 6 / 15 74ALVCH16373 Nexperia 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state Symbol Parameter Conditions II VCC = 1.8 V to 3.6 V input leakage current IOZ OFF-state output current ILIZ OFF-state input leakage current ICC supply current ΔICC additional supply current Min Typ [1] Max Unit control input; VI = 5.5 V or GND - 0.1 5 μA data input; VI = VCC or GND - 0.1 5 μA VCC = 1.8 V to 2.7 V - 0.1 5 μA VCC = 2.7 V to 3.6 V - 0.1 10 μA VCC = 1.8 V to 2.7 V - 0.1 10 μA VCC = 3.6 V - 0.1 15 μA VCC = 1.8 V to 2.7 V - 0.2 40 μA VCC = 2.7 V to 3.6 V - 0.2 40 μA per control input - 5 500 μA per data I/O input - 150 750 μA VI = VIH or VIL; VO = VCC or GND VI = VCC or GND VI = VCC or GND; IO = 0 A; VI = VCC - 0.6 V; IO = 0 A; VCC = 2.7 V to 3.6 V bus hold LOW current VCC = 2.3 V; VI = 0.7 V [2] 45 - - μA VCC = 3.0 V; VI = 0.8 V [2] 75 150 - μA bus hold HIGH current VCC = 2.3 V; VI = 1.7 V [2] -45 - - μA VCC = 3.0 V; VI = 2.0 V [2] -75 -175 - μA bus hold LOW overdrive current VCC = 2.7 V [2] 300 - - μA VCC = 3.6 V [2] 450 - - μA IBHHO bus hold HIGH overdrive current VCC = 2.7 V [2] -300 - - μA VCC = 3.6 V [2] -450 - - μA CI input capacitance - 5.0 - pF IBHL IBHH IBHLO [1] [2] All typical values are measured at Tamb = 25 °C. Valid for data inputs of bus hold parts only. 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 January 2019 © Nexperia B.V. 2019. All rights reserved 7 / 15 74ALVCH16373 Nexperia 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 10. Dynamic characteristics Table 7. Dynamic characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 10. Symbol Parameter Conditions Min Typ [1] Max Unit VCC = 1.2 V - 8.8 - ns VCC = 1.8 V 1.5 3.2 5.7 ns 1.0 2.1 3.9 ns 1.0 2.3 3.7 ns 1.0 2.1 3.3 ns VCC = 1.2 V - 7.4 - ns VCC = 1.8 V 1.5 3.4 5.9 ns 1.0 2.2 3.9 ns 1.0 2.2 3.5 ns 1.0 2.2 3.2 ns VCC = 1.2 V - 8.9 - ns VCC = 1.8 V 1.5 4.0 7.3 ns 1.0 2.6 5.2 ns 1.0 2.9 4.9 ns 1.0 2.3 4.2 ns VCC = 1.2 V - 8.9 - ns VCC = 1.8 V 1.5 3.2 5.6 ns 1.0 2.2 4.1 ns 1.0 3.1 4.7 ns 1.0 2.8 4.1 ns 3.5 1.0 - ns 3.0 1.0 - ns 3.0 1.0 - ns 2.5 1.0 - ns 1.0 -0.1 - ns 1.0 -0.1 - ns 1.0 -0.1 - ns 1.0 0.0 - ns Tamb = -40 °C to +85 °C tpd propagation delay nDn to nQn; see Fig. 6 VCC = 2.3 V to 2.7 V [2] [3] VCC = 2.7 V VCC = 3.0 V to 3.6 V nLE to nQn; see Fig. 7 VCC = 2.3 V to 2.7 V [4] [2] [3] VCC = 2.7 V ten enable time VCC = 3.0 V to 3.6 V [4] nOE to nQn; see Fig. 8 [5] VCC = 2.3 V to 2.7 V [3] VCC = 2.7 V tdis disable time VCC = 3.0 V to 3.6 V [4] nOE to nQn; see Fig. 8 [6] VCC = 2.3 V to 2.7 V [3] VCC = 2.7 V VCC = 3.0 V to 3.6 V tW pulse width [4] nLE HIGH; see Fig. 7 VCC = 1.8 V VCC = 2.3 V to 2.7 V [3] VCC = 2.7 V VCC = 3.0 V to 3.6 V tsu set-up time [4] nDn to nLE; see Fig. 9 VCC = 1.8 V VCC = 2.3 V to 2.7 V [3] VCC = 2.7 V VCC = 3.0 V to 3.6 V 74ALVCH16373 Product data sheet [4] All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 January 2019 © Nexperia B.V. 2019. All rights reserved 8 / 15 74ALVCH16373 Nexperia 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state Symbol Parameter Conditions th nDn to nLE; see Fig. 9 hold time Min Typ [1] Max 1.2 0.1 - ns 1.5 0.2 - ns 1.5 0.4 - ns 1.2 0.2 - ns outputs enabled - 16 - pF outputs disabled - 10 - pF VCC = 1.8 V VCC = 2.3 V to 2.7 V [3] VCC = 2.7 V VCC = 3.0 V to 3.6 V CPD [1] [2] [3] [4] [5] [6] [7] power dissipation capacitance [4] per flip-flop; VI = GND to VCC Unit [7] All typical values are measured at Tamb = 25 °C. tpd is the same as tPLH and tPHL. Typical values are measured at VCC = 2.5 V. Typical values are measured at VCC = 3.3 V. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in Volts; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of the outputs. 10.1. Waveforms and test circuit VI nDn input VM VM tPHL tPLH GND VOH nQn output VM VM VOL 001aam011 Measurement points are given in Table 8. VOL and VOH are typical output levels that occur with the output load. Fig. 6. Propagation delay, input (nDn) to data output (nQn) VI nLE input VM GND VM tW tPHL VOH nQn output VM tPLH VM VOL VM 001aam012 Measurement points are given in Table 8. VOL and VOH are typical output levels that occur with the output load. Fig. 7. Propagation delay, latch enable input (nLE) to data output (nQn), and pulse width 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 January 2019 © Nexperia B.V. 2019. All rights reserved 9 / 15 74ALVCH16373 Nexperia 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state VI nOE input VM VM GND tPLZ nQn output LOW-to-OFF OFF-to-LOW tPZL VCC VM VX VOL tPZH tPHZ nQn output HIGH-to-OFF OFF-to-HIGH VOH VY VM GND outputs enabled outputs disabled outputs enabled 001aal795 Measurement points are given in Table 8. VOL and VOH are typical output levels that occur with the output load. Fig. 8. 3-state enable and disable times VI nDn input VM GND th th tsu VI nLE input tsu VM GND 001aam013 Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. Fig. 9. Data setup and hold times for input (nDn) to input (nLE) Table 8. Measurement points Supply voltage Input Output VCC VI VM VM VX VY 2.3 V to 2.7 V and < 2.3 V VCC 0.5 × VCC 0.5 × VCC VOL + 0.15 V VOH - 0.15 V 2.7 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 3.0 V to 3.6 V 2.7 V 1.5 V 1.5 V VOL + 0.3 V VOH - 0.3 V 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 January 2019 © Nexperia B.V. 2019. All rights reserved 10 / 15 74ALVCH16373 Nexperia 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state VEXT VCC G VI RL VO DUT RT CL RL mna616 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 10. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 2.3 V to 2.7 V and < 2.3 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2 × VCC GND 2.7 V 2.7 V 2.5 ns 50 pF 500 Ω open 2 × VCC GND 3.0 V to 3.6 V 2.7 V 2.5 ns 50 pF 500 Ω open 2 × VCC GND 74ALVCH16373 Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 January 2019 © Nexperia B.V. 2019. All rights reserved 11 / 15 74ALVCH16373 Nexperia 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 11. Package outline TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 D E A X c v HE y A Z 48 25 Q A2 A1 (A3) pin 1 index A θ Lp 1 L 24 bp e detail X w 0 5 mm 2.5 scale Dimensions (mm are the original dimensions) Unit max nom min mm A 1.2 A1 A2 0.15 1.05 0.05 0.85 A3 0.25 bp c D(1) E(2) 0.28 0.2 12.6 6.2 0.17 0.1 12.4 6.0 e HE 0.5 8.3 7.9 L 1 Lp Q 0.8 0.50 0.4 0.35 v w 0.25 0.08 y 0.1 Z θ 0.8 8° 0.4 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. Outline version SOT362-1 References IEC JEDEC JEITA sot362-1_po European projection Issue date 03-02-19 13-08-05 MO-153 Fig. 11. Package outline SOT362-1 (TSSOP48) 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 January 2019 © Nexperia B.V. 2019. All rights reserved 12 / 15 74ALVCH16373 Nexperia 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test TTL Transistor-Transistor Logic 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74ALVCH16373 v.7 20190130 Product data sheet - Modifications: • • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number 74ALVCH16373DL (SOT370-1) removed. Package outline drawing SOT362-1 (TSSOP48) updated. 74ALVCH16373 v.6 20120710 Modifications: • 74ALVCH16373 v.5 20111117 Modifications: • 74ALVCH16373 v.4 20100531 74ALVCH16373 v.3 74ALVCH16373 v.2 74ALVCH16373 v.1 74ALVCH16373 Product data sheet 74ALVCH16373 v.6 Product data sheet - 74ALVCH16373 v.5 - 74ALVCH16373 v.4 Product data sheet - 74ALVCH16373 v.3 19990920 Product specification - 74ALVCH16373 v.2 19980629 Product specification - 74ALVCH16373 v.1 19970321 Product specification - - Table 8 corrected (errata). Product data sheet Legal pages updated. All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 January 2019 © Nexperia B.V. 2019. All rights reserved 13 / 15 74ALVCH16373 Nexperia 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74ALVCH16373 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 January 2019 © Nexperia B.V. 2019. All rights reserved 14 / 15 74ALVCH16373 Nexperia 2.5 V/3.3 V 16-bit D-type transparent latch; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................4 5.1. Pinning.........................................................................4 5.2. Pin description............................................................. 4 6. Functional description................................................. 5 7. Limiting values............................................................. 5 8. Recommended operating conditions..........................6 9. Static characteristics....................................................6 10. Dynamic characteristics............................................ 8 10.1. Waveforms and test circuit........................................ 9 11. Package outline........................................................ 12 12. Abbreviations............................................................ 13 13. Revision history........................................................13 14. Legal information......................................................14 © Nexperia B.V. 2019. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 30 January 2019 74ALVCH16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 30 January 2019 © Nexperia B.V. 2019. All rights reserved 15 / 15
74ALVCH16373DGG,11 价格&库存
很抱歉,暂时无法提供与“74ALVCH16373DGG,11”相匹配的价格&库存,您可以联系我们找货
