74AVC16373DGG,112
74AVC16373DGG,112
    NEXPERIA(安世)
    TSSOP48_12.5X6.1MM
    16位D型透明锁存器;耐受3.6V;三态
74AVC16373DGG,112 数据手册
74AVC16373 16-bit D-type transparent latch; 3.6 V tolerant; 3-state Rev. 3 — 20 February 2018 1 Product data sheet General description The 74AVC16373 is a 16-bit D-type transparent latch featuring separate D-type inputs for each latch and 3-state outputs for bus oriented applications. One latch enable (LE) input and one output enable (OE) input are provided per 8-bit section. The 74AVC16373 consist of two sections of eight D-type transparent latches with 3-state true outputs. The 74AVC16373 is designed to have an extremely fast propagation delay and a minimum amount of power consumption. To ensure the high-impedance output state during power-up or power-down, pin nOE should be tied to VCC through a pull-up resistor (Live Insertion). A dynamic controlled output (DCO) circuitry is implemented to support termination line drive during transient (see Figure 5). 2 Features and benefits • Wide supply voltage range from 1.2 V to 3.6 V • Complies with JEDEC standards: – JESD8-7 (1.2 V to 1.95 V) – JESD8-5 (1.8 V to 2.7 V) – JESD8-1A (2.7 V to 3.6 V) • CMOS low power consumption • Input/output tolerant up to 3.6 V • Dynamic Controlled Output (DCO) circuit dynamically changes output impedance, resulting in noise reduction without speed degradation • Low inductance multiple VCC and GND pins to minimize noise and ground bounce • Supports Live Insertion 3 Ordering information Table 1. Ordering information Type number 74AVC16373DGG Package Temperature range Name Description Version −40 °C to +85 °C plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 TSSOP48 74AVC16373 Nexperia 16-bit D-type transparent latch; 3.6 V tolerant; 3-state 4 Functional diagram 1OE 1 1LE 24 2OE 1OE 2LE 2OE 47 1D0 1Q0 2 46 1D1 1Q1 3 44 1D2 1Q2 5 1D1 43 1D3 1Q3 6 1D2 41 1D4 1Q4 8 1D3 40 1D5 1Q5 9 1D4 38 1D6 1Q6 11 1D5 37 1D7 1Q7 12 36 2D0 2Q0 13 1D6 35 2D1 2Q1 14 33 2D2 2Q2 16 32 2D3 2Q3 17 30 2D4 2Q4 19 29 2D5 2Q5 20 27 2D6 2Q6 22 2D4 26 2D7 2Q7 23 2D5 1LE 1D0 1D7 2D0 2D1 2D2 2D3 2D6 2LE 2D7 48 25 1EN 48 C3 24 2EN 25 C4 47 2 1 3D 46 3 44 5 43 6 41 8 40 9 38 11 37 12 36 13 4D 35 2 14 33 16 32 17 30 19 29 20 27 22 26 23 001aam007 1Q0 1Q1 1Q2 1Q3 1Q4 1Q5 1Q6 1Q7 2Q0 2Q1 2Q2 2Q3 2Q4 2Q5 2Q6 2Q7 mgu770 Figure 1. Logic symbol 1D0 1 Figure 2. IEC logic symbol D 1Q0 Q 2D0 LATCH 1 LE D 2Q0 Q LATCH 9 LE LE 1LE 2LE 1OE 2OE to 7 other channels LE to 7 other channels mgu769 Figure 3. Logic diagram 74AVC16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 15 74AVC16373 Nexperia 16-bit D-type transparent latch; 3.6 V tolerant; 3-state 5 Pinning information 5.1 Pinning 74AVC16373 1OE 1 48 1LE 1Q0 2 47 1D0 1Q1 3 46 1D1 GND 4 45 GND 1Q2 5 44 1D2 1Q3 6 43 1D3 VCC 7 1Q4 8 42 VCC 41 1D4 1Q5 9 40 1D5 GND 10 39 GND 1Q6 11 38 1D6 1Q7 12 37 1D7 2Q0 13 36 2D0 2Q1 14 35 2D1 GND 15 34 GND 2Q2 16 33 2D2 2Q3 17 32 2D3 VCC 18 2Q4 19 31 VCC 30 2D4 2Q5 20 29 2D5 GND 21 28 GND 2Q6 22 27 2D6 2Q7 23 26 2D7 2OE 24 25 2LE aaa-028180 Figure 4. Pin configuration SOT362-1 (TSSOP48) 5.2 Pin description Table 2. Pin description Symbol Pin Description 1D0, 1D1, 1D2, 1D3, 1D4, 1D5, 1D6, 1D7 47, 46, 44, 43, 41, 40, 38, 37 data inputs 2D0, 2D1, 2D2, 2D3, 2D4, 2D5, 2D6, 2D7 36, 35, 33, 32, 30, 29, 27, 26 data inputs 1Q0, 1Q1, 1Q2, 1Q3, 1Q4, 1Q5, 1Q6, 1Q7 2, 3, 5, 6, 8, 9, 11, 12 data outputs 2Q0, 2Q1, 2Q2, 2Q3, 2Q4, 2Q5, 2Q6, 2Q7 13, 14, 16, 17, 19, 20, 22, 23 data outputs 1OE, 2OE 1, 24 output enable inputs (active LOW) 1LE, 2LE 48, 25 latch enable inputs (active HIGH) GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) VCC 7, 18, 31, 42 supply voltage 74AVC16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 15 74AVC16373 Nexperia 16-bit D-type transparent latch; 3.6 V tolerant; 3-state 6 Functional description Table 3. Function table [1] Operating mode Inputs nOE nLE nDn Internal latches L H L L L L H H H H L ↓ l L L L ↓ h H H Hold L L X NC NC Latch register and disable outputs H L X NC Z H H nDn nDn Z enable and read register (transparent mode) latch and read register Outputs nQn [1] H = HIGH voltage level; L = LOW voltage level; ↓ = HIGH-to-LOW LE transition; h = HIGH voltage level one set-up time prior to the HIGH-to-LOW LE transition; l = LOW voltage level one set-up time prior to the HIGH-to-LOW LE transition; X = don’t care; NC = No change; Z = high-impedance OFF-state. 7 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current Conditions VI < 0 V VI input voltage data and control inputs IOK output clamping current VO < 0 V VO output voltage [1] Min Max Unit -0.5 +4.6 V - -50 mA -0.5 +4.6 V - -50 mA output HIGH or LOW [1] -0.5 output 3-state [1] -0.5 +4.6 V - +50 mA IO output current ICC supply current - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C - 500 mW Ptot total power dissipation VO = 0 V to VCC VCC + 0.5 V Tamb = −40 °C to +85 °C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Above 60 °C the value of Ptot derates linearly with 5.5 mW/K. 74AVC16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 15 74AVC16373 Nexperia 16-bit D-type transparent latch; 3.6 V tolerant; 3-state 8 Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VCC for low-voltage applications 1.2 - 3.6 V according to JEDEC Low Voltage Standards 1.4 - 1.6 V 1.65 - 1.95 V 2.3 - 2.7 V 3.0 - 3.6 V 0 - 3.6 V output HIGH or LOW 0 - VCC V output 3-state 0 - 3.6 V −40 - +85 °C supply voltage VI input voltage VO output voltage Tamb ambient temperature in free air Δt/ΔV input transition rise and fall rate VCC = 1.4 V to 1.6 V 0 - 40 ns/V VCC = 1.65 V to 2.3 V 0 - 30 ns/V VCC = 2.3 V to 3.0 V 0 - 20 ns/V VCC = 3.0 V to 3.6 V 0 - 10 ns/V 9 Static characteristics Table 6. Static characteristics At recommended operating conditions; Tamb = −40 °C to +85 °C; Voltages are referenced to GND (ground = 0 V). [1] Symbol Parameter Conditions Min Typ VIH VCC = 1.2 V VCC - - V VCC = 1.4 V to 1.6 V 0.65 × VCC 0.9 - V VCC = 1.65 V to 1.95 V 0.65 × VCC 0.9 - V VCC = 2.3 V to 2.7 V 1.7 1.2 - V VCC = 3.0 V to 3.6 V 2.0 1.5 - V VCC = 1.2 V - - GND V VCC = 1.4 V to 1.6 V - 0.9 0.35 × VCC V VCC = 1.65 V to 1.95 V - 0.9 0.35 × VCC V VCC = 2.3 V to 2.7 V - 1.2 0.7 V VCC = 3.0 V to 3.6 V - 1.5 0.8 V IO = -100 μA; VCC = 1.65 V to 3.6 V VCC - 0.20 VCC - V IO = -3 mA; VCC = 1.4 V VCC - 0.35 VCC - 0.23 - V IO = -4 mA; VCC = 1.65 V VCC - 0.45 VCC - 0.25 - V IO = -8 mA; VCC = 2.3 V VCC - 0.55 VCC - 0.38 - V IO = -12 mA; VCC = 3.0 V VCC - 0.70 VCC - 0.48 - V VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 74AVC16373 Product data sheet Max Unit VI = VIH or VIL; see Figure 5 All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 15 74AVC16373 Nexperia 16-bit D-type transparent latch; 3.6 V tolerant; 3-state Symbol Parameter Conditions VOL VI = VIH or VIL; see Figure 5 LOW-level output voltage II input leakage current Min Unit GND 0.20 V IO = 3 mA; VCC = 1.4 V - 0.18 0.35 V IO = 4 mA; VCC = 1.65 V - 0.22 0.45 V IO = 8 mA; VCC = 2.3 V - 0.37 0.55 V IO = 12 mA; VCC = 3.0 V - 0.51 0.70 V - 0.1 2.5 μA - 0.1 ±10 μA VCC = 1.4 V to 2.7 V - 0.1 5 μA VCC = 3.0 V to 3.6 V - 0.1 10 μA VCC = 1.4 V to 2.7 V - 0.1 20 μA VCC = 3.0 V to 3.6 V - 0.2 40 μA - 5.0 - pF VI = VCC or GND; VCC = 1.4 V to 3.6 V power-off leakage current VI or VO = 3.6 V; VCC = 0 V IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND CI Max - IOFF supply current [1] IO = 100 μA; VCC = 1.65 V to 3.6 V per input pin ICC Typ VI = VCC or GND; IO = 0 A input capacitance [1] All typical values are measured at Tamb = 25 °C. 9.1 Dynamic controlled output graphs aaa-003759 0 IOH (mA) aaa-003760 300 3.3 V IOL (mA) 1.8 V -100 200 2.5 V 2.5 V -200 100 1.8 V 3.3 V -300 0 1 2 3 VOH (V) 4 a. HIGH-level output current. 0 0 1 2 3 VOL (V) 4 b. LOW-level output current. Figure 5. Output current as a function of output voltage. 74AVC16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 15 74AVC16373 Nexperia 16-bit D-type transparent latch; 3.6 V tolerant; 3-state 10 Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 10. Symbol Parameter Conditions −40 °C to +85 °C Min tpd propagation delay nDn to nQn; see Figure 6 3.6 - ns VCC = 1.4 V to 1.6 V 1.2 3.1 6.8 ns VCC = 1.65 V to 1.95 V 1.0 2.2 5.7 ns VCC = 2.3 V to 2.7 V 0.7 1.6 3.3 ns 0.7 1.4 2.8 ns - 3.6 - ns VCC = 1.4 V to 1.6 V 2.5 3.1 9.4 ns VCC = 1.65 V to 1.95 V 2.3 2.2 7.8 ns VCC = 2.3 V to 2.7 V 1.3 1.6 4.2 ns 0.7 1.4 3.9 ns - 5.9 - ns VCC = 1.4 V to 1.6 V 1.6 4.2 8.8 ns VCC = 1.65 V to 1.95 V 1.6 3.5 6.7 ns VCC = 2.3 V to 2.7 V 1.4 2.4 4.3 ns 0.7 2.0 3.4 ns - 5.8 - ns VCC = 1.4 V to 1.6 V 2.5 4.6 9.4 ns VCC = 1.65 V to 1.95 V 2.3 3.6 7.8 ns VCC = 2.3 V to 2.7 V 1.3 1.9 4.2 ns VCC = 3.0 V to 3.6 V 1.2 2.1 3.9 ns VCC = 1.2 V - 2.4 - ns VCC = 1.4 V to 1.6 V - 1.9 - ns VCC = 1.65 V to 1.95 V 2.2 1.7 - ns VCC = 2.3 V to 2.7 V 2.0 1.6 - ns VCC = 3.0 V to 3.6 V 1.8 1.4 - ns nLE to nQn; see Figure 7 [2] VCC = 1.2 V VCC = 3.0 V to 3.6 V nOE to nQn; see Figure 8 [2] VCC = 1.2 V VCC = 3.0 V to 3.6 V tdis disable time nOE to nQn; see Figure 8 VCC = 1.2 V tW pulse width 74AVC16373 Product data sheet Max - VCC = 3.0 V to 3.6 V enable time Unit [2] VCC = 1.2 V ten Typ [1] [2] nLE HIGH; see Figure 7. All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 15 74AVC16373 Nexperia 16-bit D-type transparent latch; 3.6 V tolerant; 3-state Symbol Parameter Conditions −40 °C to +85 °C Min tsu set-up time hold time Max - 0.4 - ns VCC = 1.4 V to 1.6 V 1.2 0.2 - ns VCC = 1.65 V to 1.95 V 1.1 0.1 - ns VCC = 2.3 V to 2.7 V 0.9 -0.1 - ns VCC = 3.0 V to 3.6 V 0.8 -0.1 - ns - -0.2 - ns VCC = 1.4 V to 1.6 V 1.1 -0.1 - ns VCC = 1.65 V to 1.95 V 1.1 0.0 - ns VCC = 2.3 V to 2.7 V 1.1 0.1 - ns 1.0 0.2 - ns outputs enabled - 34 - pF outputs disabled - 1 - pF nDn to nLE; see Figure 9 VCC = 1.2 V VCC = 3.0 V to 3.6 V CPD Unit nDn to nLE; see Figure 9 VCC = 1.2 V th Typ [1] power dissipation capacitance per buffer; VI = GND to VCC [3] [1] Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V respectively. [2] tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. [3] CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching 2 Σ(CL x VCC x fo) = sum of the outputs. 74AVC16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 15 74AVC16373 Nexperia 16-bit D-type transparent latch; 3.6 V tolerant; 3-state 10.1 Waveforms and test circuit VI nDn input VI VM VM tPHL tPLH nLE input GND GND nQn output VM VM VOL VM VM tW tPHL VOH VOH nQn output VM tPLH VM VM VOL 001aam011 001aam012 Measurement points are given in Table 8. Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with VOL and VOH are typical voltage output levels that occur with the output load. the output load. Figure 7. Latch enable input (nLE) to data output (nQn) Figure 6. Input (nDn) to output (nQn) propagation delays propagation delays and pulse width VI nOE input VM VM GND tPLZ nQn output LOW-to-OFF OFF-to-LOW tPZL VCC VM VX VOL tPZH tPHZ nQn output HIGH-to-OFF OFF-to-HIGH VOH VY VM GND outputs enabled outputs disabled outputs enabled 001aal795 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 8. 3-state enable and disable times VI nDn input VM GND th tsu VI nLE input th tsu VM GND 001aam013 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 9. Input (nDn) to input (nLE) data set-up and hold times 74AVC16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 15 74AVC16373 Nexperia 16-bit D-type transparent latch; 3.6 V tolerant; 3-state Table 8. Measurement points Supply voltage Input VCC VI VM VM VX VY ≤2.3 V VCC 0.5 x VCC 0.5 x VCC VOL + 0.15 V VOH - 0.15 V 2.3 V to 2.7 V VCC 0.5 x VCC 0.5 x VCC VOL + 0.15 V VOH - 0.15 V 3.0 V to 3.6 V VCC 0.5 x VCC 0.5 x VCC VOL + 0.3 V VOH - 0.3 V Output VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Figure 10. Test circuit for measuring switching times Table 9. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.2 V VCC ≤ 2.0 ns 15 pF 2000 Ω open 2 x VCC GND 1.4 V to 1.6 V VCC ≤ 2.0 ns 15 pF 2000 Ω open 2 x VCC GND 1.65 V to 1.95 V VCC ≤ 2.0 ns 30 pF 1000 Ω open 2 x VCC GND 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2 x VCC GND 3.0 V to 3.6 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2 x VCC GND 74AVC16373 Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 15 74AVC16373 Nexperia 16-bit D-type transparent latch; 3.6 V tolerant; 3-state 11 Package outline TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 D E A X c v HE y A Z 48 25 Q A2 A1 (A3) pin 1 index A θ Lp 1 L 24 bp e detail X w 0 5 mm 2.5 scale Dimensions (mm are the original dimensions) Unit mm max nom min A 1.2 A1 A2 0.15 1.05 0.05 0.85 A3 0.25 bp c D(1) E(2) 0.28 0.2 12.6 6.2 0.17 0.1 12.4 6.0 e HE 0.5 8.3 7.9 L 1 Lp Q 0.8 0.50 0.4 0.35 v w 0.25 0.08 y 0.1 Z θ 0.8 8° 0.4 0° Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. Outline version SOT362-1 References IEC JEDEC JEITA sot362-1_po European projection Issue date 03-02-19 13-08-05 MO-153 Figure 11. Package outline SOT362-1 (TSSOP48) 74AVC16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 15 74AVC16373 Nexperia 16-bit D-type transparent latch; 3.6 V tolerant; 3-state 12 Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DCO Dynamic Controlled Output DUT Device Under Test 13 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AVC16373 v.3 20180220 Product data sheet - Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74AVC16373 v.2 20000309 Product specification - 74AVC_AVCH16373_N v.1 74AVC_AVCH16373_N v.1 19981211 Product specification - - 74AVC16373 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 74AVC16373 v.2 © Nexperia B.V. 2018. All rights reserved. 12 / 15 74AVC16373 Nexperia 16-bit D-type transparent latch; 3.6 V tolerant; 3-state 14 Legal information 14.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74AVC16373 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 15 74AVC16373 Nexperia 16-bit D-type transparent latch; 3.6 V tolerant; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74AVC16373 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 20 February 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 15 74AVC16373 Nexperia 16-bit D-type transparent latch; 3.6 V tolerant; 3-state Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 9.1 10 10.1 11 12 13 14 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................4 Limiting values .................................................... 4 Recommended operating conditions ................ 5 Static characteristics .......................................... 5 Dynamic controlled output graphs ..................... 6 Dynamic characteristics .....................................7 Waveforms and test circuit ................................ 9 Package outline .................................................11 Abbreviations .................................................... 12 Revision history ................................................ 12 Legal information .............................................. 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 20 February 2018 Document identifier: 74AVC16373
74AVC16373DGG,112 价格&库存
很抱歉,暂时无法提供与“74AVC16373DGG,112”相匹配的价格&库存,您可以联系我们找货
