74AVC16374DGG,112
74AVC16374DGG,112
    NEXPERIA(安世)
    TSSOP48_12.5X6.1MM
    16位边沿触发D型触发器;耐受3.6V;三态
74AVC16374DGG,112 数据手册
74AVC16374 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state Rev. 3 — 16 August 2013 Product data sheet 1. General description The 74AVC16374 is a 16-bit edge triggered flip-flop featuring separate D-type inputs for each flip-flop and 3-state outputs for bus-oriented applications. The 74AVC16374 consist of 2 sections of 8 edge-triggered flip-flops. A clock input (CP) and an output enable (OE) are provided per 8-bit section. The 74AVC16374 is designed to have an extremely fast propagation delay and a minimum amount of power consumption. To ensure the high-impedance output state during power-up or power-down, nOE should be tied to VCC through a pull-up resistor (Live Insertion). A Dynamic Controlled Output (DCO) circuitry is implemented to support termination line drive during transient (see Figure 5 and Figure 6). 2. Features and benefits  Wide supply voltage range from 1.2 V to 3.6 V  Complies with JEDEC standards:  JESD8-7 (1.2 V to 1.95 V)  JESD8-5 (1.8 V to 2.7 V)  JESD8-1A (2.7 V to 3.6 V)  CMOS low power consumption  Input/output tolerant up to 3.6 V  Dynamic Controlled Output (DCO) circuit dynamically changes output impedance, resulting in noise reduction without speed degradation  Low inductance multiple VCC and GND pins to minimize noise and ground bounce  Supports Live Insertion 3. Ordering information Table 1. Ordering information Type number 74AVC16374DGG Package Temperature range Name Description Version 40 C to +85 C TSSOP48 plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 4. Functional diagram 1OE 1CP 2OE 2CP 1D0 1D1 1D2 1D3 1D4 1D5 1D6 1D7 2D0 2D1 2D2 2D3 2D4 2D5 2D6 2D7 1 48 24 25 47 1EN 2EN 1OE 2OE 1D0 1Q0 2 46 1D1 1Q1 1D 1 2 3 1Q0 44 1D2 1Q2 3 5 1Q1 44 5 43 1D3 1Q3 6 1Q2 41 1D4 1Q4 6 43 8 1Q3 40 1D5 1Q5 41 8 9 1Q4 40 9 38 1D6 1Q6 11 1Q5 37 1D7 1Q7 11 38 12 1Q6 36 2D0 2Q0 13 12 37 2D 2 13 1Q7 35 2D1 2Q1 14 2Q0 33 2D2 2Q2 14 35 16 2Q1 32 2D3 2Q3 33 16 17 2Q2 32 17 30 2D4 2Q4 19 2Q3 29 2D5 2Q5 19 30 20 2Q4 27 2D6 2Q6 29 20 22 2Q5 27 22 26 2D7 2Q7 23 26 23 2Q6 1CP 2CP 48 25 2Q7 mna577 Fig 1. 24 47 C2 46 36 1 C1 IEC logic symbol Fig 2. 1D0 D mna576 Logic symbol Q 1Q0 CP FF1 1CP 1OE to 7 other channels 2D0 D Q 2Q0 CP 2CP FF9 2OE to 7 other channels Fig 3. mna578 Logic diagram 74AVC16374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 August 2013 © Nexperia B.V. 2017. All rights reserved 2 of 16 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 5. Pinning information 5.1 Pinning 74AVC16374 1OE 1 48 1CP 1Q0 2 47 1D0 1Q1 3 46 1D1 GND 4 45 GND 1Q2 5 44 1D2 1Q3 6 43 1D3 VCC 7 42 VCC 1Q4 8 41 1D4 1Q5 9 40 1D5 GND 10 39 GND 1Q6 11 38 1D6 1Q7 12 37 1D7 2Q0 13 36 2D0 2Q1 14 35 2D1 GND 15 34 GND 2Q2 16 33 2D2 2Q3 17 32 2D3 VCC 18 31 VCC 2Q4 19 30 2D4 2Q5 20 29 2D5 GND 21 28 GND 2Q6 22 27 2D6 2Q7 23 26 2D7 2OE 24 25 2CP mna575 Fig 4. Pin configuration 74AVC16374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 August 2013 © Nexperia B.V. 2017. All rights reserved 3 of 16 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 5.2 Pin description Table 2. Pin description Symbol Pin Description 1OE 1 output enable input (active LOW) 1Q0 to 1Q7 2, 3, 5, 6, 8, 9, 11, 12 3-state flip-flop outputs GND 4, 10, 15, 21, 28, 34, 39, 45 ground (0 V) VCC 7, 18, 31, 42 supply voltage 2Q0 to 2Q7 13, 14, 16, 17, 19, 20, 22, 23 3-state flip-flop outputs 2OE 24 output enable input (active LOW) 2CP 25 clock input 2D0 to 2D7 36, 35, 33, 32, 30, 29, 27, 26 data input/output 1D0 to 1D7 47, 46, 44, 43, 41, 40, 38, 37 data input/output 1CP 48 clock input 6. Functional description Table 3. Function table[1] Operating modes Inputs nOE nCp nDn Load and read register L  L Load register and disable outputs [1] Internal flip-flops Outputs I L L  h H H H  I L Z H  h H Z nQn H = HIGH voltage level h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition L = LOW voltage level l = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition Z = high-impedance OFF-state  = LOW-to-HIGH CP transition 74AVC16374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 August 2013 © Nexperia B.V. 2017. All rights reserved 4 of 16 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current output voltage VO Conditions VI < 0 V [1] Min Max Unit 0.5 +4.6 V  50 mA 0.5 +4.6 V 50 - mA output HIGH or LOW [1] 0.5 VCC + 0.5 V output 3-state [1] 0.5 +4.6 V - 50 mA VO < 0 V IO output current VO = 0 V to VCC ICC supply current - +100 mA IGND ground current 100 - mA Tstg storage temperature 65 +150 C Ptot total power dissipation - 500 mW Tamb = 40 C to +85 C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] Above 60 C, the value of Ptot derates linearly with 5.5 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter VCC supply voltage Conditions Min Typ Max Unit according to JEDEC Low Voltage Standards 1.4 - 1.6 V 1.65 - 1.95 V 2.3 - 2.7 V 3.0 - 3.6 V for low-voltage applications VI input voltage VO output voltage 1.2 - 3.6 V 0 - 3.6 V output HIGH or LOW 0 - VCC V output 3-state 0 - 3.6 V Tamb ambient temperature in free air 40 - +85 C t/V input transition rise and fall rate VCC = 1.4 V to 1.6 V 0 - 40 ns/V VCC = 1.65 V to 2.3 V 0 - 30 ns/V VCC = 2.3 V to 3.0 V 0 - 20 ns/V VCC = 3.0 V to 3.6 V 0 - 10 ns/V 74AVC16374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 August 2013 © Nexperia B.V. 2017. All rights reserved 5 of 16 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 9. Static characteristics Table 6. Static characteristics At recommended operating conditions. Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max Unit Tamb = 40 C to +85 C HIGH-level input voltage VIH LOW-level input voltage VIL VOH HIGH-level output voltage VCC = 1.2 V VCC - - V VCC = 1.4 V to 1.6 V 0.65  VCC 0.9 - V VCC = 1.65 V to 1.95 V 0.65  VCC 0.9 - V VCC = 2.3 V to 2.7 V 1.7 1.2 - V VCC = 3.0 V to 3.6 V 2.0 1.5 - V VCC = 1.2 V - - GND V VCC = 1.4 V to 1.6 V - 0.9 0.35  VCC V VCC = 1.65 V to 1.95 V - 0.9 0.35  VCC V VCC = 2.3 V to 2.7 V - 1.2 0.7 V VCC = 3.0 V to 3.6 V - 1.5 0.8 V VCC  0.20 VCC - V IO = 3 mA; VCC = 1.4 V VCC  0.35 VCC  0.23 - V IO = 4 mA; VCC = 1.65 V VCC  0.45 VCC  0.25 - V IO = 8 mA; VCC = 2.3 V VCC  0.55 VCC  0.38 - V IO = 12 mA; VCC = 3.0 V VCC  0.70 VCC  0.48 - V IO = 100 A; VCC = 1.65 V to 3.6 V - GND 0.20 V IO = 3 mA; VCC = 1.4 V - 0.10 0.35 V IO = 4 mA; VCC = 1.65 V - 0.10 0.45 V IO = 8 mA; VCC = 2.3 V - 0.26 0.55 V IO = 12 mA; VCC = 3.0 V - 0.36 0.70 V VI = VIH or VIL IO = 100 A; VCC = 1.65 V to 3.6 V LOW-level output voltage VOL VI = VIH or VIL II input leakage current per pin; VI = VCC or GND; VCC = 1.4 V to 3.6 V - 0.1 2.5 A IOFF power-off leakage current VI or VO = 3.6 V; VCC = 0.0 V - 0.1 10 A IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND VCC = 1.4 V to 2.7 V - 0.1 5 A VCC = 3.0 V to 3.6 V - 0.1 10 A VCC = 1.4 V to 2.7 V - 0.1 20 A VCC = 3.0 V to 3.6 V - 0.2 40 A - 5 - supply current ICC input capacitance CI [1] VI = VCC or GND; IO = 0 A pF All typical values are measured at Tamb = 25 C. 74AVC16374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 August 2013 © Nexperia B.V. 2017. All rights reserved 6 of 16 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 9.1 Graphs mna506 0 IOH (mA) mna507 300 IOL (mA) 3.3 V 1.8 V -100 200 2.5 V 2.5 V -200 100 1.8 V 3.3 V -300 0 0 1 2 3 4 0 1 2 3 VOH (V) Fig 5. 4 VOL (V) Output voltage as a function of the HIGH-level output current. Fig 6. Output voltage as a function of the LOW-level output current. 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). tr = tf  2 ns. For test circuit, see Figure 10. Symbol tpd Parameter propagation delay 40 C to +85 C Conditions nCP to nQn; see Figure 7 disable time Product data sheet 3.1 - ns 1.2 2.4 8.4 ns 1.0 2.0 6.7 ns VCC = 2.3 V to 2.7 V 0.8 1.5 4.1 ns 0.7 1.3 3.3 ns - 5.4 - ns VCC = 1.4 V to 1.6 V 1.6 3.9 8.5 ns VCC = 1.65 V to 1.95 V 2.3 3.3 6.7 ns VCC = 2.3 V to 2.7 V 0.9 2.3 4.3 ns VCC = 3.0 V to 3.6 V 0.7 2.0 3.4 ns - 5.6 - ns nOE to nQn, nBn; see Figure 8 nOE to nQn; see Figure 8 VCC = 1.2 V 74AVC16374 - VCC = 1.4 V to 1.6 V [1] VCC = 1.2 V tdis Max VCC = 1.65 V to 1.95 V VCC = 3.0 V to 3.6 V enable time Typ[2] [1] VCC = 1.2 V ten Unit Min [1] VCC = 1.4 V to 1.6 V 2.5 4.5 9.4 ns VCC = 1.65 V to 1.95 V 1.8 3.3 7.8 ns VCC = 2.3 V to 2.7 V 1.0 1.8 4.2 ns VCC = 3.0 V to 3.6 V 1.2 2.0 3.9 ns All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 August 2013 © Nexperia B.V. 2017. All rights reserved 7 of 16 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V). tr = tf  2 ns. For test circuit, see Figure 10. Symbol Parameter 40 C to +85 C Conditions Min tW pulse width set-up time tsu VCC = 1.2 V - 0.8 - ns - 0.5 - ns VCC = 1.65 V to 1.95 V 3.1 0.3 - ns VCC = 2.3 V to 2.7 V 2.5 0.2 - ns VCC = 3.0 V to 3.6 V 2.5 0.2 - ns - 0.6 - ns 2.7 0.3 - ns VCC = 1.65 V to 1.95 V 1.9 0.3 - ns VCC = 2.3 V to 2.7 V 1.4 0.2 - ns VCC = 3.0 V to 3.6 V 1.4 0.1 - ns nDn to nCP; see Figure 8 nDn to nCP; see Figure 8 VCC = 1.2 V maximum frequency fmax - 0.8 - ns VCC = 1.4 V to 1.6 V 1.3 0.7 - ns VCC = 1.65 V to 1.95 V 1.2 0.6 - ns VCC = 2.3 V to 2.7 V 1.1 0.5 - ns VCC = 3.0 V to 3.6 V 1.1 0.4 - ns VCC = 1.2 V - 250 - MHz VCC = 1.4 V to 1.6 V - 300 - MHz see Figure 8 VCC = 1.65 V to 1.95 V 160 320 - MHz VCC = 2.3 V to 2.7 V 200 350 - MHz 200 350 - MHz outputs enabled - 66 - pF outputs disabled - 1 - pF VCC = 3.0 V to 3.6 V power dissipation capacitance CPD [1] Max VCC = 1.4 V to 1.6 V VCC = 1.4 V to 1.6 V hold time Unit HIGH; nCP; see Figure 7 VCC = 1.2 V th Typ[2] per input; VI = GND to VCC [3] tpd is the same as tPLH and tPHL. ten is the same as tPZL and tPZH. tdis is the same as tPLZ and tPHZ. [2] Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V respectively. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching (CL  VCC2  fo) = sum of the outputs. 74AVC16374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 August 2013 © Nexperia B.V. 2017. All rights reserved 8 of 16 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 11. Waveforms 1/fmax VI nCP input VM VM GND tW tPHL tPLH VOH nQn output VM VOL mna579 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 7. Clock input (nCP) to output (nQn) propagation delays VI nOE input VM GND t PZL t PLZ VCC output LOW-to-OFF OFF-to-LOW VM VX VOL t PZH t PHZ VOH VY output HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs disabled outputs enabled mna478 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 8. 3-state enable and disable times 74AVC16374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 August 2013 © Nexperia B.V. 2017. All rights reserved 9 of 16 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state VI VM nCP input GND tsu tsu th th VI VM nDn input GND VOH VM nQn output VOL mna580 Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 9. Table 8. Data set-up and hold times for nDn input to nCP input Measurement points Supply voltage VM VCC Input VI tr = tf VX VY 1.2 V 0.5  VCC VCC  2 ns VOL + 0.15 V VOH  0.15 V 1.4 V to 1.6 V 0.5  VCC VCC  2 ns VOL + 0.15 V VOH  0.15 V 1.65 V to 1.95 V 0.5  VCC VCC  2 ns VOL + 0.15 V VOH  0.15 V 2.3 V to 2.7 V 0.5  VCC VCC  2 ns VOL + 0.15 V VOH  0.15 V 3.0 V to 3.6 V 0.5  VCC VCC  2 ns VOL + 0.3 V VOH  0.3 V 74AVC16374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 August 2013 © Nexperia B.V. 2017. All rights reserved 10 of 16 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VEXT VCC VI RL VO G DUT RT RL CL 001aae331 Test data is given in Table 9. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig 10. Test circuit for measuring switching times Table 9. Test data Supply voltage Input Load VEXT VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 1.2 V VCC  2 ns 15 pF 2 k open 2  VCC GND 1.4 V to 1.6 V VCC  2 ns 15 pF 2 k open 2  VCC GND 1.65 V to 1.95 V VCC  2 ns 30 pF 1 k open 2  VCC GND 2.3 V to 2.7 V VCC  2 ns 30 pF 500  open 2  VCC GND 3.0 V to 3.6 V VCC  2 ns 30 pF 500  open 2  VCC GND 74AVC16374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 August 2013 © Nexperia B.V. 2017. All rights reserved 11 of 16 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 12. Package outline TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm SOT362-1 D E A X c v HE y A Z 48 25 Q A2 (A3) A1 A pin 1 index θ Lp L 1 24 detail X w bp e 0 5 mm 2.5 scale Dimensions (mm are the original dimensions) Unit mm max nom min A A1 A2 A3 0.15 1.05 1.2 bp c D(1) E(2) 0.28 0.2 12.6 6.2 HE 0.17 0.1 12.4 L 8.3 0.5 0.25 0.05 0.85 e 6.0 Lp Q 0.8 0.50 1 7.9 v w 0.25 0.08 0.4 0.35 y Z θ 0.8 8° 0.4 0° 0.1 Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. Outline version SOT362-1 References IEC JEDEC JEITA sot362-1_po European projection Issue date 03-02-19 13-08-05 MO-153 Fig 11. Package outline SOT362-1 (TSSOP48) 74AVC16374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 August 2013 © Nexperia B.V. 2017. All rights reserved 12 of 16 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Order number Supersedes 74AVC16374 v.3 20130816 - Modifications: Product data sheet - 74AVC16374 v.2 • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. 74AVC16374 v.2 20000309 Product specification - - 74AVC16374 v.1 74AVC16374 v.1 19981211 Product specification - - - 74AVC16374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 August 2013 © Nexperia B.V. 2017. All rights reserved 13 of 16 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74AVC16374 Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 August 2013 © Nexperia B.V. 2017. All rights reserved 14 of 16 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74AVC16374 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 16 August 2013 © Nexperia B.V. 2017. All rights reserved 15 of 16 74AVC16374 Nexperia 16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 9.1 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 4 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5 Recommended operating conditions. . . . . . . . 5 Static characteristics. . . . . . . . . . . . . . . . . . . . . 6 Graphs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . . 7 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13 Legal information. . . . . . . . . . . . . . . . . . . . . . . 14 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15 Contact information. . . . . . . . . . . . . . . . . . . . . 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 16 August 2013
74AVC16374DGG,112 价格&库存
很抱歉,暂时无法提供与“74AVC16374DGG,112”相匹配的价格&库存,您可以联系我们找货
