74AVC16374
16-bit edge triggered D-type flip-flop; 3.6 V tolerant; 3-state
Rev. 3 — 16 August 2013
Product data sheet
1. General description
The 74AVC16374 is a 16-bit edge triggered flip-flop featuring separate D-type inputs for
each flip-flop and 3-state outputs for bus-oriented applications. The 74AVC16374 consist
of 2 sections of 8 edge-triggered flip-flops. A clock input (CP) and an output enable (OE)
are provided per 8-bit section.
The 74AVC16374 is designed to have an extremely fast propagation delay and a
minimum amount of power consumption.
To ensure the high-impedance output state during power-up or power-down, nOE should
be tied to VCC through a pull-up resistor (Live Insertion).
A Dynamic Controlled Output (DCO) circuitry is implemented to support termination line
drive during transient (see Figure 5 and Figure 6).
2. Features and benefits
Wide supply voltage range from 1.2 V to 3.6 V
Complies with JEDEC standards:
JESD8-7 (1.2 V to 1.95 V)
JESD8-5 (1.8 V to 2.7 V)
JESD8-1A (2.7 V to 3.6 V)
CMOS low power consumption
Input/output tolerant up to 3.6 V
Dynamic Controlled Output (DCO) circuit dynamically changes output impedance,
resulting in noise reduction without speed degradation
Low inductance multiple VCC and GND pins to minimize noise and ground bounce
Supports Live Insertion
3. Ordering information
Table 1.
Type number
74AVC16374DGG
Package
Temperature range
Name
Description
Version
40 C to +85 C
TSSOP48
plastic thin shrink small outline package;
48 leads; body width 6.1 mm
SOT362-1
74AVC16374
Nexperia
4. Functional diagram
1OE
1CP
2OE
2CP
1D0
1D1
1D2
1D3
1D4
1D5
1D6
1D7
2D0
2D1
2D2
2D3
2D4
2D5
2D6
2D7
1
48
24
25
47
1EN
2EN
1OE
2OE
1D0
1Q0
2
46
1D1
1Q1
1D
1
2
3
1Q0
44
1D2
1Q2
3
5
1Q1
44
5
43
1D3
1Q3
6
1Q2
41
1D4
1Q4
6
43
8
1Q3
40
1D5
1Q5
41
8
9
1Q4
40
9
38
1D6
1Q6
11
1Q5
37
1D7
1Q7
11
38
12
1Q6
36
2D0
2Q0
13
12
37
2D
2
13
1Q7
35
2D1
2Q1
14
2Q0
33
2D2
2Q2
14
35
16
2Q1
32
2D3
2Q3
33
16
17
2Q2
32
17
30
2D4
2Q4
19
2Q3
29
2D5
2Q5
19
30
2Q4
27
2D6
2Q6
29
2Q5
27
22
26
2D7
2Q7
23
26
23
2Q6
1CP
2CP
48
25
2Q7
mna577
Fig 1.
24
47
C2
46
36
1
C1
IEC logic symbol
Fig 2.
1D0
D
mna576
Logic symbol
Q
1Q0
CP
FF1
1CP
1OE
to 7 other channels
2D0
D
Q
2Q0
CP
2CP
FF9
2OE
to 7 other channels
Fig 3.
mna578
Logic diagram
74AVC16374
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 16
74AVC16374
Nexperia
5. Pinning information
5.1 Pinning
74AVC16374
1OE
1
48 1CP
1Q0
2
47 1D0
1Q1
3
46 1D1
GND
4
45 GND
1Q2
5
44 1D2
1Q3
6
43 1D3
VCC
7
42 VCC
1Q4
8
41 1D4
1Q5
9
40 1D5
GND 10
39 GND
1Q6 11
38 1D6
1Q7 12
37 1D7
2Q0 13
36 2D0
2Q1 14
35 2D1
GND 15
34 GND
2Q2 16
33 2D2
2Q3 17
32 2D3
VCC 18
31 VCC
2Q4 19
30 2D4
2Q5 20
29 2D5
GND 21
28 GND
2Q6 22
27 2D6
2Q7 23
26 2D7
2OE 24
25 2CP
mna575
Fig 4.
Pin configuration
74AVC16374
Product data sheet
3 of 16
74AVC16374
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1OE
1
output enable input (active LOW)
1Q0 to 1Q7
2, 3, 5, 6, 8, 9, 11, 12
3-state flip-flop outputs
GND
4, 10, 15, 21, 28, 34, 39, 45
ground (0 V)
VCC
7, 18, 31, 42
supply voltage
2Q0 to 2Q7
13, 14, 16, 17, 19, 20, 22, 23
2OE
24
2CP
25
clock input
2D0 to 2D7
36, 35, 33, 32, 30, 29, 27, 26
data input/output
1D0 to 1D7
47, 46, 44, 43, 41, 40, 38, 37
data input/output
1CP
48
clock input
6. Functional description
Table 3.
Function table[1]
Operating modes
Inputs
nOE
nCp
nDn
Load and read register
L
L
Load register and disable outputs
[1]
Internal flip-flops
Outputs
I
L
L
h
H
H
H
I
L
Z
H
h
H
Z
nQn
H = HIGH voltage level
h = HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition
L = LOW voltage level
l = LOW voltage level one set-up time prior to the LOW-to-HIGH CP transition
Z = high-impedance OFF-state
= LOW-to-HIGH CP transition
74AVC16374
Product data sheet
4 of 16
74AVC16374
Nexperia
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
Conditions
VI < 0 V
[1]
Min
Max
Unit
0.5
+4.6
V
50
mA
0.5
+4.6
V
50
mA
output HIGH or LOW
[1]
0.5
VCC + 0.5
V
output 3-state
[1]
0.5
+4.6
V
50
mA
VO < 0 V
IO
output current
VO = 0 V to VCC
ICC
supply current
+100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
500
mW
Tamb = 40 C to +85 C
[2]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
Above 60 C, the value of Ptot derates linearly with 5.5 mW/K.
8. Recommended operating conditions
Table 5.
Symbol Parameter
VCC
supply voltage
Conditions
Min
Typ
Max
Unit
according to JEDEC Low Voltage Standards
1.4
1.6
V
1.65
1.95
V
2.3
2.7
V
3.0
3.6
V
for low-voltage applications
VI
input voltage
VO
output voltage
1.2
3.6
V
V
output HIGH or LOW
VCC
V
output 3-state
V
Tamb
ambient temperature
in free air
40
+85
C
t/V
input transition rise and fall
rate
VCC = 1.4 V to 1.6 V
ns/V
VCC = 1.65 V to 2.3 V
ns/V
VCC = 2.3 V to 3.0 V
ns/V
VCC = 3.0 V to 3.6 V
ns/V
74AVC16374
Product data sheet
5 of 16
74AVC16374
Nexperia
9. Static characteristics
Table 6.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ[1]
Max
Unit
HIGH-level input voltage
VIH
LOW-level input voltage
VIL
VOH
HIGH-level output voltage
VCC = 1.2 V
VCC
V
0.65 VCC
0.9
V
VCC = 1.65 V to 1.95 V
0.65 VCC
0.9
V
VCC = 2.3 V to 2.7 V
1.7
1.2
V
2.0
1.5
V
VCC = 1.2 V
GND
V
0.9
0.35 VCC V
0.9
0.35 VCC V
1.2
0.7
V
1.5
0.8
V
VCC 0.20
VCC
V
IO = 3 mA; VCC = 1.4 V
VCC 0.35
VCC 0.23
V
IO = 4 mA; VCC = 1.65 V
VCC 0.45
VCC 0.25
V
IO = 8 mA; VCC = 2.3 V
VCC 0.55
VCC 0.38
V
IO = 12 mA; VCC = 3.0 V
VCC 0.70
VCC 0.48
V
IO = 100 A; VCC = 1.65 V to 3.6 V
GND
0.20
V
0.10
0.35
V
0.10
0.45
V
0.26
0.55
V
0.36
0.70
V
VI = VIH or VIL
LOW-level output voltage
VOL
VI = VIH or VIL
II
input leakage current
per pin; VI = VCC or GND;
VCC = 1.4 V to 3.6 V
0.1
2.5
A
IOFF
power-off leakage current
VI or VO = 3.6 V; VCC = 0.0 V
0.1
10
A
IOZ
OFF-state output current
VI = VIH or VIL; VO = VCC or GND
VCC = 1.4 V to 2.7 V
0.1
5
A
0.1
10
A
0.1
A
0.2
40
A
5
supply current
ICC
input capacitance
CI
[1]
VI = VCC or GND; IO = 0 A
pF
All typical values are measured at Tamb = 25 C.
74AVC16374
Product data sheet
6 of 16
74AVC16374
Nexperia
9.1 Graphs
mna506
IOH
(mA)
mna507
300
IOL
(mA)
3.3 V
1.8 V
-100
200
2.5 V
2.5 V
-200
100
1.8 V
3.3 V
-300
2
3
4
2
3
VOH (V)
Fig 5.
4
VOL (V)
Output voltage as a function of the HIGH-level
output current.
Fig 6.
Output voltage as a function of the LOW-level
output current.
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). tr = tf 2 ns. For test circuit, see Figure 10.
Symbol
tpd
Parameter
propagation delay
40 C to +85 C
Conditions
nCP to nQn; see Figure 7
disable time
Product data sheet
3.1
ns
1.2
2.4
8.4
ns
1.0
2.0
6.7
ns
0.8
1.5
4.1
ns
0.7
1.3
3.3
ns
5.4
ns
1.6
3.9
8.5
ns
2.3
3.3
6.7
ns
0.9
2.3
4.3
ns
0.7
2.0
3.4
ns
5.6
ns
nOE to nQn, nBn; see Figure 8
nOE to nQn; see Figure 8
VCC = 1.2 V
74AVC16374
[1]
VCC = 1.2 V
tdis
Max
enable time
Typ[2]
[1]
VCC = 1.2 V
ten
Unit
Min
[1]
2.5
4.5
9.4
ns
1.8
3.3
7.8
ns
1.0
1.8
4.2
ns
1.2
2.0
3.9
ns
7 of 16
74AVC16374
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol
Parameter
40 C to +85 C
Conditions
Min
tW
pulse width
set-up time
tsu
VCC = 1.2 V
0.8
ns
0.5
ns
3.1
0.3
ns
2.5
0.2
ns
2.5
0.2
ns
0.6
ns
2.7
0.3
ns
1.9
0.3
ns
1.4
0.2
ns
1.4
0.1
ns
nDn to nCP; see Figure 8
VCC = 1.2 V
maximum frequency
fmax
0.8
ns
1.3
0.7
ns
1.2
0.6
ns
1.1
0.5
ns
1.1
0.4
ns
VCC = 1.2 V
250
MHz
300
MHz
see Figure 8
160
320
MHz
200
350
MHz
200
350
MHz
outputs enabled
66
pF
outputs disabled
1
pF
power dissipation
capacitance
CPD
[1]
Max
hold time
Unit
HIGH; nCP; see Figure 7
VCC = 1.2 V
th
Typ[2]
per input; VI = GND to VCC
[3]
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
[2]
Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V respectively.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
(CL VCC2 fo) = sum of the outputs.
74AVC16374
Product data sheet
8 of 16
74AVC16374
Nexperia
11. Waveforms
1/fmax
VI
nCP input
VM
VM
GND
tW
tPHL
tPLH
VOH
nQn output
VM
VOL
mna579
Measurement points are given in Table 9.
Logic levels: VOL and VOH are typical output voltage levels that occur with the output load.
Fig 7.
Clock input (nCP) to output (nQn) propagation delays
VI
nOE input
VM
GND
t PZL
t PLZ
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
t PZH
t PHZ
VOH
VY
output
HIGH-to-OFF
OFF-to-HIGH
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
mna478
Fig 8.
3-state enable and disable times
74AVC16374
Product data sheet
9 of 16
74AVC16374
Nexperia
VI
VM
nCP input
GND
tsu
tsu
th
th
VI
VM
nDn input
GND
VOH
VM
nQn output
VOL
mna580
Fig 9.
Table 8.
Data set-up and hold times for nDn input to nCP input
Measurement points
Supply voltage
VM
VCC
Input
VI
tr = tf
VX
VY
1.2 V
0.5 VCC
VCC
2 ns
VOL + 0.15 V
VOH 0.15 V
1.4 V to 1.6 V
0.5 VCC
VCC
2 ns
VOL + 0.15 V
VOH 0.15 V
1.65 V to 1.95 V
0.5 VCC
VCC
2 ns
VOL + 0.15 V
VOH 0.15 V
2.3 V to 2.7 V
0.5 VCC
VCC
2 ns
VOL + 0.15 V
VOH 0.15 V
3.0 V to 3.6 V
0.5 VCC
VCC
2 ns
VOL + 0.3 V
VOH 0.3 V
74AVC16374
Product data sheet
10 of 16
74AVC16374
Nexperia
VI
tW
90 %
negative
pulse
VM
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VEXT
VCC
VI
RL
VO
G
DUT
RT
RL
CL
001aae331
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 10. Test circuit for measuring switching times
Table 9.
Test data
Supply voltage
Input
Load
VEXT
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
1.2 V
VCC
2 ns
15 pF
2 k
open
2 VCC
GND
1.4 V to 1.6 V
VCC
2 ns
15 pF
2 k
open
2 VCC
GND
1.65 V to 1.95 V
VCC
2 ns
30 pF
1 k
open
2 VCC
GND
2.3 V to 2.7 V
VCC
2 ns
30 pF
500
open
2 VCC
GND
3.0 V to 3.6 V
VCC
2 ns
30 pF
500
open
2 VCC
GND
74AVC16374
Product data sheet
11 of 16
74AVC16374
Nexperia
12. Package outline
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm
SOT362-1
D
E
A
X
c
v
HE
y
A
Z
48
25
Q
A2
(A3)
A1
A
pin 1 index
θ
Lp
L
1
24
detail X
w
bp
e
5 mm
2.5
scale
Dimensions (mm are the original dimensions)
Unit
mm
max
nom
min
A
A1
A2
A3
0.15 1.05
1.2
bp
c
D(1)
E(2)
0.28
0.2
12.6
6.2
HE
0.17
0.1
12.4
L
8.3
0.5
0.25
0.05 0.85
e
6.0
Lp
Q
0.8
0.50
1
7.9
v
w
0.25 0.08
0.4
0.35
y
Z
θ
0.8
8°
0.4
0°
0.1
Note
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
Outline
version
SOT362-1
References
IEC
JEDEC
JEITA
sot362-1_po
European
projection
Issue date
03-02-19
13-08-05
MO-153
Fig 11. Package outline SOT362-1 (TSSOP48)
74AVC16374
Product data sheet
12 of 16
74AVC16374
Nexperia
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
TTL
Transistor-Transistor Logic
14. Revision history
Table 11.
Revision history
Document ID
Release date Data sheet status
Change notice Order number Supersedes
74AVC16374 v.3
20130816
Modifications:
Product data sheet
74AVC16374 v.2
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
74AVC16374 v.2
20000309
Product specification
74AVC16374 v.1
74AVC16374 v.1
19981211
74AVC16374
Product data sheet
13 of 16
74AVC16374
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74AVC16374
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
14 of 16
74AVC16374
Nexperia
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of
non-automotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74AVC16374
Product data sheet
15 of 16
74AVC16374
Nexperia
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
9.1
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 6
Graphs . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 12
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13
Legal information. . . . . . . . . . . . . . . . . . . . . . . 14
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Contact information. . . . . . . . . . . . . . . . . . . . . 15
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Date of release: 16 August 2013
