BCM856BS; BCM856BS/DG
BCM856DS; BCM856DS/DG
PNP/PNP matched double transistors
Rev. 01 — 7 August 2008
Product data sheet
1. Product profile
1.1 General description
PNP/PNP matched double transistors in small Surface-Mounted Device (SMD) plastic
packages. The transistors are fully isolated internally.
Table 1.
Product overview
Type number
BCM856BS
Package
Package configuration
Nexperia
JEITA
SOT363
SC-88
very small
SOT457
SC-74
small
BCM856BS/DG
BCM856DS
BCM856DS/DG
1.2 Features
n
n
n
n
Current gain matching
Base-emitter voltage matching
Drop-in replacement for standard double transistors
AEC-Q101 qualified
1.3 Applications
n Current mirror
n Differential amplifier
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
open base
−65
V
−100
mA
200
290
450
Per transistor
VCEO
collector-emitter voltage
IC
collector current
hFE
DC current gain
VCE = −5 V;
IC = −2 mA
BCM856BS; BCM856DS
Nexperia
Table 2.
Quick reference data …continued
Symbol
Parameter
Conditions
hFE1/hFE2
hFE matching
VCE = −5 V;
IC = −2 mA
VBE1−VBE2
VBE matching
VCE = −5 V;
IC = −2 mA
Min
Typ
Max
[1]
0.9
1
[2]
2
Unit
Per device
[1]
The smaller of the two values is taken as the numerator.
[2]
The smaller of the two values is subtracted from the larger value.
mV
2. Pinning information
Table 3.
Pinning
Pin
Description
1
emitter TR1
2
base TR1
3
collector TR2
4
emitter TR2
5
base TR2
6
collector TR1
Simplified outline
6
5
Graphic symbol
6
4
5
4
TR2
TR1
1
2
3
1
2
3
001aab555
sym018
3. Ordering information
Table 4.
Type number
BCM856BS
Package
Name
Description
Version
SC-88
plastic surface-mounted package; 6 leads
SOT363
SC-74
plastic surface-mounted package (TSOP6); 6 leads
SOT457
BCM856BS/DG
BCM856DS
BCM856DS/DG
BCM856BS_BCM856DS_1
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 14
BCM856BS; BCM856DS
Nexperia
4. Marking
Table 5.
Marking codes
Type number
Marking code[1]
BCM856BS
*BS
BCM856BS/DG
PB*
BCM856DS
DS
BCM856DS/DG
R9
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
Per transistor
VCBO
collector-base voltage
open emitter
−80
V
VCEO
open base
−65
V
VEBO
emitter-base voltage
open collector
−5
V
IC
collector current
−100
mA
ICM
peak collector current
single pulse;
tp ≤ 1 ms
−200
mA
Ptot
total power dissipation
Tamb ≤ 25 °C
BCM856BS (SOT363)
BCM856BS/DG (SOT363)
[1]
200
mW
BCM856DS (SOT457)
BCM856DS/DG (SOT457)
[1]
250
mW
BCM856BS (SOT363)
[1]
300
mW
BCM856DS (SOT457)
[1]
380
mW
Per device
Ptot
Tj
junction temperature
150
°C
Tamb
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
BCM856BS_BCM856DS_1
Product data sheet
Tamb ≤ 25 °C
3 of 14
BCM856BS; BCM856DS
Nexperia
6. Thermal characteristics
Table 7.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
Per transistor
Rth(j-a)
thermal resistance from junction to
ambient
in free air
BCM856BS (SOT363)
[1]
625
K/W
BCM856DS (SOT457)
[1]
500
K/W
BCM856BS (SOT363)
[1]
416
K/W
BCM856DS (SOT457)
[1]
328
K/W
Per device
Rth(j-a)
[1]
ambient
in free air
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
7. Characteristics
Table 8.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCB = −30 V;
IE = 0 A
−15
nA
VCB = −30 V;
IE = 0 A;
Tj = 150 °C
−5
µA
nA
Per transistor
ICBO
collector-base cut-off
current
IEBO
emitter-base cut-off
current
VEB = −5 V;
IC = 0 A
−100
hFE
DC current gain
VCE = −5 V;
IC = −10 µA
250
VCE = −5 V;
IC = −2 mA
200
290
450
IC = −10 mA;
IB = −0.5 mA
−50
−200
mV
IC = −100 mA;
IB = −5 mA
−200
−400
mV
VCEsat
VBEsat
collector-emitter
saturation voltage
base-emitter saturation
voltage
IC = −10 mA;
IB = −0.5 mA
[1]
−760
mV
IC = −100 mA;
IB = −5 mA
[1]
−920
mV
BCM856BS_BCM856DS_1
Product data sheet
4 of 14
BCM856BS; BCM856DS
Nexperia
Table 8.
Characteristics …continued
Symbol
VBE
Parameter
Conditions
Min
Typ
Max
Unit
VCE = −5 V;
IC = −2 mA
[2]
base-emitter voltage
−600
−650
−700
mV
VCE = −5 V;
IC = −10 mA
[2]
−760
mV
Cc
collector capacitance
VCB = −10 V;
IE = ie = 0 A;
f = 1 MHz
2.2
pF
Ce
emitter capacitance
VEB = −0.5 V;
IC = ic = 0 A;
f = 1 MHz
10
pF
fT
transition frequency
VCE = −5 V;
IC = −10 mA;
f = 100 MHz
100
175
MHz
NF
noise figure
VCE = −5 V;
IC = −0.2 mA;
RS = 2 kΩ;
f = 10 Hz to
15.7 kHz
1.6
dB
VCE = −5 V;
IC = −0.2 mA;
RS = 2 kΩ;
f = 1 kHz;
B = 200 Hz
3.1
dB
Per device
hFE matching
VCE = −5 V;
IC = −2 mA
[3]
0.9
1
VBE1−VBE2 VBE matching
VCE = −5 V;
IC = −2 mA
[4]
2
hFE1/hFE2
[1]
VBEsat decreases by about 1.7 mV/K with increasing temperature.
[2]
VBE decreases by about 2 mV/K with increasing temperature.
[3]
[4]
BCM856BS_BCM856DS_1
Product data sheet
mV
5 of 14
BCM856BS; BCM856DS
Nexperia
006aaa540
−0.20
IB (mA) = −2.5
−2.25
−2.0
−1.75
−1.5
−1.25
IC
(A)
−0.16
−0.12
006aaa541
600
hFE
(1)
400
−1.0
(2)
−0.75
−0.08
−0.5
200
(3)
−0.25
−0.04
−2
−4
−6
−10−2
−8
−10
VCE (V)
Tamb = 25 °C
−10−1
−1
−10
−102
−103
IC (mA)
VCE = −5 V
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(3) Tamb = −55 °C
Fig 1.
Collector current as a function of
collector-emitter voltage; typical values
006aaa542
−1.3
VBEsat
(V)
−1.1
Fig 2.
DC current gain as a function of collector
current; typical values
006aaa543
−10
VCEsat
(V)
−0.9
−1
(1)
−0.7
(2)
(3)
−10−1
−0.5
(1)
(2)
(3)
−0.3
−0.1
−10−1
−1
−10
−102
−103
−10−2
−10−1
−1
−10
−102
IC (mA)
IC/IB = 20
IC/IB = 20
(1) Tamb = −55 °C
(1) Tamb = 100 °C
(2) Tamb = 25 °C
(2) Tamb = 25 °C
(3) Tamb = 100 °C
(3) Tamb = −55 °C
Fig 3.
Base-emitter saturation voltage as a function
of collector current; typical values
Fig 4.
Collector-emitter saturation voltage as a
function of collector current; typical values
BCM856BS_BCM856DS_1
Product data sheet
−103
IC (mA)
6 of 14
BCM856BS; BCM856DS
Nexperia
006aaa544
−1
VBE
(V)
006aaa545
103
fT
(MHz)
−0.8
102
−0.6
−0.4
−10−1
−1
−10
−102
10
−103
−10
−1
IC (mA)
VCE = −5 V; Tamb = 25 °C
Fig 5.
−102
IC (mA)
Base-emitter voltage as a function of collector
Fig 6.
006aaa546
8
Transition frequency as a function of collector
006aaa547
15
Ce
(pF)
13
Cc
(pF)
6
11
4
9
2
7
−2
−4
−6
5
−8
−10
VCB (V)
−6
f = 1 MHz; Tamb = 25 °C
Collector capacitance as a function of
collector-base voltage; typical values
Fig 8.
Emitter capacitance as a function of
emitter-base voltage; typical values
BCM856BS_BCM856DS_1
Product data sheet
−4
VEB (V)
Fig 7.
−2
7 of 14
BCM856BS; BCM856DS
Nexperia
8. Application information
V−
VCC
OUT2
OUT1
IN1
R1
TR1
IN2
TR2
l out
TR1
TR2
V+
006aaa524
Fig 9.
006aaa526
Current mirror
Fig 10. Differential amplifier
9. Test information
9.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
10. Package outline
2.2
1.8
6
2.2 1.35
2.0 1.15
1.1
0.8
5
3.1
2.7
0.45
0.15
4
6
3.0
2.5
pin 1
index
1
2
3
0.25
0.10
Fig 11. Package outline SOT363 (SC-88)
2
3
0.6
0.2
0.26
0.10
1.9
06-03-16
Dimensions in mm
04-11-08
Fig 12. Package outline SOT457 (SC-74)
BCM856BS_BCM856DS_1
Product data sheet
4
0.40
0.25
0.95
1.3
Dimensions in mm
5
pin 1 index
1
0.3
0.2
0.65
1.7
1.3
1.1
0.9
8 of 14
BCM856BS; BCM856DS
Nexperia
11. Packing information
Table 9.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
BCM856BS
Package Description
SOT363
BCM856BS/DG SOT363
BCM856DS
SOT457
BCM856DS/DG SOT457
Packing quantity
3000
10000
4 mm pitch, 8 mm tape and reel; T1
[2]
-115
-135
4 mm pitch, 8 mm tape and reel; T2
[3]
-125
-165
[2]
-115
-135
[3]
-125
-165
[2]
-115
-135
[3]
-125
-165
[2]
-115
-135
[3]
-125
-165
[1]
For further information and the availability of packing methods, see Section 15.
[2]
T1: normal taping
[3]
T2: reverse taping
12. Soldering
2.65
solder lands
2.35 1.5
0.4 (2×)
0.6 0.5
(4×) (4×)
solder resist
solder paste
0.5
(4×)
0.6
(2×)
0.6
(4×)
occupied area
Dimensions in mm
1.8
sot363_fr
Fig 13. Reflow soldering footprint SOT363 (SC-88)
BCM856BS_BCM856DS_1
Product data sheet
9 of 14
BCM856BS; BCM856DS
Nexperia
1.5
solder lands
0.3 2.5
4.5
solder resist
occupied area
1.5
Dimensions in mm
1.3
preferred transport
direction during soldering
1.3
2.45
5.3
sot363_fw
Fig 14. Wave soldering footprint SOT363 (SC-88)
3.45
1.95
0.45 0.55
(6×) (6×)
0.95
solder lands
solder resist
3.3 2.825
0.95
solder paste
occupied area
0.7
(6×)
Dimensions in mm
0.8
(6×)
2.4
sot457_fr
Fig 15. Reflow soldering footprint SOT457 (SC-74)
BCM856BS_BCM856DS_1
Product data sheet
10 of 14
BCM856BS; BCM856DS
Nexperia
5.3
1.5
(4×)
solder lands
1.475
solder resist
0.45
(2×)
5.05
occupied area
1.475
Dimensions in mm
preferred transport
1.45
(6×)
2.85
sot457_fw
Fig 16. Wave soldering footprint SOT457 (SC-74)
BCM856BS_BCM856DS_1
Product data sheet
11 of 14
BCM856BS; BCM856DS
Nexperia
13. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BCM856BS_BCM856DS_1
20080807
Product data sheet
BCM856BS_BCM856DS_1
Product data sheet
12 of 14
BCM856BS; BCM856DS
Nexperia
14. Legal information
14.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
14.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
14.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
15. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
BCM856BS_BCM856DS_1
Product data sheet
13 of 14
Nexperia
BCM856BS; BCM856DS
16. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
10
11
12
13
14
14.1
14.2
14.3
14.4
15
16
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description. . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data. . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics. . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Application information. . . . . . . . . . . . . . . . . . . 8
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 8
Quality information . . . . . . . . . . . . . . . . . . . . . . 8
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Packing information. . . . . . . . . . . . . . . . . . . . . . 9
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 12
Legal information. . . . . . . . . . . . . . . . . . . . . . . 13
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 13
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Contact information. . . . . . . . . . . . . . . . . . . . . 13
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Date of release: 07 August 2008
很抱歉,暂时无法提供与“BCM856DS,115”相匹配的价格&库存,您可以联系我们找货
