Technical Data 4146
Effective August 2017
Supersedes September 2011
SD8350
Low profile shielded drum core power inductors
Applications
Server power
Notebook and laptop power
High power LED driver, portable devices
Base station, telecom, and networking
Battery chargers, RAM power supply
Industrial and automotive power systems
Noise filtering output filter chokes
Buck/boost converters, output converters
Environmental data
Product features
Low-profile surface mount inductor
9.5 mm x 8.3 mm x 4.5 mm shielded drum core
Ferrite core material
Inductance range from 1.5 µH to 100 µH
Current range from 0.8 A to 9.1 A
Frequency range up to 1 MHz
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Pb HF
FREE
HALOGEN
Technical Data 4146
Product specifications
Part Number
SD8350-1R8-R
SD8350-3R9-R
SD8350-4R7-R
SD8350-6R8-R
SD8350-100-R
SD8350-150-R
SD8350-220-R
SD8350-330-R
SD8350-470-R
SD8350-680-R
SD8350-101-R
Rated
Inductance (µH)
1.8
3.9
4.7
6.8
10
15
22
33
47
68
100
OCL1
µH±30%
1.5
3.2
4.2
6.8
9.9
13.6
20.4
31.4
44.9
65.1
99.7
Irms2
(A)
5.50
4.50
4.10
3.90
3.20
2.30
1.80
1.40
1.30
1.00
0.80
1. Open Circuit Inductance Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc.
2. Irms: DC current for an approximate ΔT of 40 °C without core loss. Derating is necessary for AC
currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating
components will affect the temperature rise. It is recommended that the temperature of the part
not exceed +125 °C under worst case operating conditions verified in the end application.
3. Isat Amps peak for approximately 35% rolloff (@ +25 °C)
Isat3
(A)
9.1
6.3
5.5
4.4
4.0
2.9
2.6
2.2
1.8
1.5
1.3
DCR mΩ
@ +20 °C Typ
11.8
16.2
18.5
20.8
31.4
45.0
63.5
111.4
130.0
200.8
308.0
DCR mΩ
@ +20 °C Max
14.0
19.0
22.0
25.0
36.0
53.0
75.0
125.0
150.0
240.0
360.0
K-factor4
16.0
9.6
8.5
7.6
6.3
5.3
4.4
3.5
2.9
2.4
2.0
4. K-factor: Used to determine Bp-p for core loss (see graph).
Bp-p = K*L*ΔI, Bp-p (mT), K: (K factor from table), L: (Inductance in µH), ΔI (Peak to
peak ripple current in Amps).
5. Part Number Definition: SD8350-xxx-R
SD8350 = Product code and size; -xxx = Inductance value in µH;
R = decimal point; If no R is present, third character equals number of zeros.
-R suffix = RoHS compliant
Dimensions-mm
RECOMM ENDED PCB LAYOUT
TOP VIEW
BOTTOM VIEW
2.5
8.3 max.
1
SCHEM A TIC
FRONT VI EW
2.9
4.5 max.
1.2
1
1.8
XX X
wwlly R
9.5 max.
6.3
LEFT VIEW
5.7
2
Part Marking: xxx = Inductance value in μH. (R = Decimal point). If no R is present, third character = number of zeros wwlly - or - wwllyy = Date code R= Revision level
Do not route traces or vias underneath the inductor
Packaging information-mm
Supplied in tape-and-reel packaging, 750 parts per reel, 13” diameter reel.
2
www.eaton.com/electronics
2
SD8350
Technical Data 4146
Temperature rise vs total loss
140
Temp eratu re Rise (°C)
120
100
80
60
40
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.9
1MHz
500kHz
1
Total Loss (W)
Core loss vs Bp-p
10
300kHz
100kHz
1
Core Loss (W)
200kHz
0. 1
0. 01
0. 001
0. 000 1
1
10
100
100 0
Bp-p (mT)
Inductance characteristics
OCL Vs. Isat
120%
100%
% OCL
80%
60%
+85 Deg. C
+25 Deg. C
-40 Deg. C
40%
20%
0%
0%
20%
40%
60%
80%
100%
120%
140%
% Isat
3
SD8350
Technical Data 4146
Solder Reflow Profile
TP
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
25°C
Preheat
A
T smax
t
TC -5°C
Table 1 - Standard SnPb Solder (Tc)
Volume
mm3
220°C
220°C
Table 2 - Lead (Pb) Free Solder (T c)
Tsmin
ts
Package
Thickness
2.5mm
Time 25°C to Peak
Volume
mm3
2000
260°C
245°C
245°C
Time
Reference JDEC J-STD-020
Profile Feature
Preheat and Soak
• Temperature min. (Tsmin)
• Temperature max. (Tsmax)
• Time (Tsmin to Tsmax) (ts)
Average ramp up rate Tsmax to Tp
Liquidous temperature (TL)
Time at liquidous (tL)
Peak package body temperature (TP)*
Time (tp)** within 5 °C of the specified classification temperature (Tc)
Average ramp-down rate (Tp to Tsmax)
Time 25°C to Peak Temperature
100°C
150°C
150°C
200°C
60-120 Seconds
60-120 Seconds
3°C/ Second Max.
3°C/ Second Max.
183°C
60-150 Seconds
217°C
60-150 Seconds
Table 1
Table 2
20 Seconds**
30 Seconds**
6°C/ Second Max.
6°C/ Second Max.
6 Minutes Max.
8 Minutes Max.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly
used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 4146 BU-SB111111
August 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“SD8350-101-R”相匹配的价格&库存,您可以联系我们找货
