Technical Data 10712
Effective September 2017
HCV1707
High current power inductors
Applications
Compatible with Picor® Cool-Power® ZVS Buck
and Buck-Boost Regulator Families
Environmental data
Storage temperature range (Component):
-55 °C to +125 °C
Operating temperature range: -55 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Halogen free, lead free, RoHS compliant
HALOGEN
Product features
Flat-wire construction
Low DCR, high efficiency
Secure 3 terminal mounting
17.8 mm x 14.35 mm footprint surface mount
package in a 6.9 mm height
Ferrite core material
Moisture Sensitivity Level: 1
Pb HF
FREE
Picor® and Cool-Power® are trademarks of Vicor Corporation.
HCV1707
Product specifications
Part Number7
OCL1
(µH) ±10%
FLL2
(µH)
minimum
Irms3
(A)
Isat14
(A)
Isat25
(A)
Isat36
(A)
DCR (mΩ)
±10% @ +20 °C
HCV1707R1-R48-R
0.48
0.42
32
55
68
47
1.7
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.1 Vrms, Isat1, +25 °C
3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary
for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the temperature rise. It is recommended that the temperature of the part
not exceed +125 °C under worst case operating conditions verified in the end application.
4. Isat1: Peak current for approximately 2% rolloff @ +25 °C
5. Isat2: Peak current for approximately 2% rolloff @ -55 °C
6. Isat3: Peak current for approximately 2% rolloff @ +125 °C
7. Part Number Definition: HCV1707Rx-Rxxx-R
HCV1707= Product code and size
Rx= Version indicator
Rxx= Inductance value in μH, R= decimal point,
If no R is present last character equals number of zeros
-R suffix = RoHS compliant
Dimensions (mm)
Recommended Pad Layout
9.00
2.00
xxxx
HCV1707Rx-xxx
6.5
0.4
NC
7.8
0.4
17.3
0.5
14.0
0.5
7.20
3.0
0.2
5.75
3.70
2.4
0.3
1.5
0.2
14.0
0.35
9.7
0.5
Part marking: HCV1707Rx-Rxx, Rxx= inductance value in uH, R= decimal point,
if noifRnoisR present
xxxx=lot
code
xxxx=lot
code
Soldering surfaces to be coplanar within 0.1 millimeters
All soldering
surface to be coplanar within 0.1 millimeters
Tolerances are 0.15 millimeters unless stated otherwise
Tolerances
are
±0.15 are
millimeters
unless
otherwise
0.1 millimeters
unlessstated
stated otherwise
Pad layout
tolerances
NC istolerances
for mounting stability.
No connection.
Pad Pin
layout
are ±0.1
Do not route traces or vias underneath the inductor.
Pin NC
is for mounting stability. No connection.
2
www.eaton.com/electronics
2.70
3.00
Schematic
HCV1707
Packaging information (mm)
Supplied in tape and reel packaging , 350 parts per 13” diameter reel
Temperature rise vs. total loss
60
Temperature Rise (°C)
50
40
30
1
1.5
2
2.5
3
Power Loss (W)
3
HCV1707
Inductance characteristics
,sϭϳϬϳZϭͲZϰϴͲZ
ϲϬϬ
ϱϬϬ
/ŶĚƵĐƚĂŶĐĞ;Ŷ,Ϳ
ϰϬϬ
ϯϬϬ
ϮϬϬ
ͲϱϱΣ
ϭϬϬ
нϮϱΣ
нϭϮϱΣ
Ϭ
Ϭ
ϭϬ
ϮϬ
ϯϬ
ϰϬ
ϱϬ
ϲϬ
/ĚĐ;Ϳ
4
ϳϬ
ϴϬ
ϵϬ
ϭϬϬ
ϭϭϬ
HCV1707
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“HCV1707R1-R48-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+26.552751+3.20289
- 10+22.1825910+2.67575
- 25+20.2518425+2.44286
- 50+17.3593450+2.09395
- 100+15.91319100+1.91951
- 国内价格
- 350+9.99398
- 700+9.85525
- 1050+9.72019
- 1750+9.58889
- 3500+9.33654
- 8750+9.09711
- 17500+8.86969
